Other Parts Discussed in Thread: TDA2
hi:
I have a question about the usage of cubemap in fbo;
the simple code as bellow:
glGenFramebuffers(1, &fboID);
glBindFramebuffer(GL_FRAMEBUFFER,fboID);
glGenTextures(1, &cubemapID);
glBindTexture(GL_TEXTURE_CUBE_MAP, cubemapID);
for (unsigned int i = 0; i < 6; ++i)
glTexImage2D(GL_TEXTURE_CUBE_MAP_POSITIVE_X + i, 0, GL_RGB, 256, 256, 0, GL_RGB, GL_UNSIGNED_BYTE, nullptr);
glTexParameteri(GL_TEXTURE_CUBE_MAP, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_CUBE_MAP, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_CUBE_MAP, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_CUBE_MAP, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
glUniform.. //update the uniform variable
glViewport(0, 0, 256, 256);
glFramebufferTexture2D(GL_FRAMEBUFFER, GL_COLOR_ATTACHMENT0, GL_TEXTURE_CUBE_MAP_POSITIVE_X + i, cubemapID, 0);
if (glCheckFramebufferStatus(GL_FRAMEBUFFER) != GL_FRAMEBUFFER_COMPLETE)
printf("glCheckFramebufferStatus error!\n");
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
renderCube();
when i test the code, it works well on windows,
but when i move it to the tda2 platform, the question is comming, sometimes the effiect is black , or is white, or white and black , or other colors, it's change every time.
how is this? and how to resolved it?
thanks
