HI Team TI,
GBE_SDP signal is required for Hardware implementation of PTP as per SMARC requirements.
We are using DP83867IRRGZ LAN phy in our compute board and using GPIO_0 (Pin 39) of Phy to set as IEEE 1588 trigger. Signal is connected with soc and smarc connector as well.
Signal should be I/O as per specifications.
How the functionality of this pin will be after setting it to 1588 trigger mode? Will it work as normal level trigger, Edge trigger, Active high/low for communication communication?
Please advise functionality in detail.
