After updating SDK (and kernel) version, we are struggling to get the Ethernet interface working.
I have attached the original and the new version of:
- Device tree
- Kernel Log
- Kernel .config
Following the example from https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1052711/am4378-linux-5-10-ethernet-no-longer-works?tisearch=e2e-sitesearch&keymatch=davinci_mdio_sw#, in the devicetree I have changed
&mac { slaves = <1>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&mii1_pins_default>; pinctrl-1 = <&mii1_pins_sleep>; status = "okay"; }; &davinci_mdio { pinctrl-names = "default", "sleep"; pinctrl-0 = <&davinci_mdio_default>; pinctrl-1 = <&davinci_mdio_sleep>; status = "okay"; }; &cpsw_emac0 { phy_id = <&davinci_mdio>, <0>; phy-mode = "mii"; };
into
&mac_sw { slaves = <1>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&mii1_pins_default>; pinctrl-1 = <&mii1_pins_sleep>; status = "okay"; }; &davinci_mdio_sw { pinctrl-names = "default", "sleep"; pinctrl-0 = <&davinci_mdio_default>; pinctrl-1 = <&davinci_mdio_sleep>; ethphy0: ethernet-phy@0 { reg = <0>; }; }; &cpsw_port1 { phy-handle = <ðphy0>; phy-mode = "mii"; ti,dual-emac-pvid = <1>; };
but the interface does not come up.
Any ideas?
Thank you and regards
Peter
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.19.59-g5f8c1c6121 (phoyer@SmaLin) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #33 PREEMPT Thu Jul 8 20:58:01 CEST 2021 [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: SMaBiT SMaWay [ 0.000000] Memory policy: Data cache writeback [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 48 MiB at 0xbd000000 [ 0.000000] On node 0 totalpages: 262144 [ 0.000000] Normal zone: 1728 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 196608 pages, LIFO batch:63 [ 0.000000] HighMem zone: 65536 pages, LIFO batch:15 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM437x ES1.2 (neon) [ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b0 with crng_init=0 [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260416 [ 0.000000] Kernel command line: console=ttyO4,115200n8 video=vmalloc=512M net.ifnames=0 biosdevnames=0 root=PARTUUID=015884b5-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 975004K/1048576K available (9216K kernel code, 601K rwdata, 2780K rodata, 1024K init, 270K bss, 24420K reserved, 49152K cma-reserved, 212992K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0x(ptrval) - 0x(ptrval) (10208 kB) .init : 0x(ptrval) - 0x(ptrval) (1024 kB) .data : 0x(ptrval) - 0x(ptrval) ( 602 kB) .bss : 0x(ptrval) - 0x(ptrval) ( 271 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] ftrace: allocating 31775 entries in 94 pages [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9 [ 0.000000] OMAP L2C310: ROM does not support power control setting [ 0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled [ 0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB [ 0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000 [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000036] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000046] OMAP clocksource: timer1 at 24000000 Hz [ 0.000510] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000524] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000964] Console: colour dummy device 80x30 [ 0.000995] WARNING: Your 'console=ttyO4' has been replaced by 'ttyS4' [ 0.001002] This ensures that you still see kernel messages. Please [ 0.001008] update your kernel commandline. [ 0.001059] Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816) [ 0.090219] pid_max: default: 32768 minimum: 301 [ 0.090383] Security Framework initialized [ 0.090465] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.090489] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.091376] CPU: Testing write buffer coherency: ok [ 0.091441] CPU0: Spectre v2: using BPIALL workaround [ 0.092472] Setting up static identity map for 0x80100000 - 0x80100060 [ 0.092653] rcu: Hierarchical SRCU implementation. [ 0.093085] EFI services will not be available. [ 0.094112] devtmpfs: initialized [ 0.104379] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.104853] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.104878] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.108875] pinctrl core: initialized pinctrl subsystem [ 0.109665] DMI not present or invalid. [ 0.110131] NET: Registered protocol family 16 [ 0.112867] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.205691] cpuidle: using governor ladder [ 0.205736] cpuidle: using governor menu [ 0.207853] omap_l3_noc 44000000.ocp: L3 debug error: target 8 mod:0 (unclearable) [ 0.207936] omap_l3_noc 44000000.ocp: L3 application error: target 8 mod:0 (unclearable) [ 0.223688] No ATAGs? [ 0.223717] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 0.223734] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.239092] edma 49000000.edma: TI EDMA DMA engine driver [ 0.243175] media: Linux media interface: v0.10 [ 0.243233] videodev: Linux video capture interface: v2.00 [ 0.243343] pps_core: LinuxPPS API ver. 1 registered [ 0.243352] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.243377] PTP clock support registered [ 0.243416] EDAC MC: Ver: 3.0.0 [ 0.244310] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.245027] Advanced Linux Sound Architecture Driver Initialized. [ 0.245618] NetLabel: Initializing [ 0.245635] NetLabel: domain hash size = 128 [ 0.245641] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.245736] NetLabel: unlabeled traffic allowed by default [ 0.246488] clocksource: Switched to clocksource timer1 [ 0.307188] NET: Registered protocol family 2 [ 0.308083] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes) [ 0.308126] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.308201] TCP bind hash table entries: 8192 (order: 3, 32768 bytes) [ 0.308293] TCP: Hash tables configured (established 8192 bind 8192) [ 0.308486] UDP hash table entries: 512 (order: 1, 8192 bytes) [ 0.308516] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes) [ 0.308696] NET: Registered protocol family 1 [ 0.309352] RPC: Registered named UNIX socket transport module. [ 0.309367] RPC: Registered udp transport module. [ 0.309374] RPC: Registered tcp transport module. [ 0.309382] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.311638] Initialise system trusted keyrings [ 0.311973] workingset: timestamp_bits=14 max_order=18 bucket_order=4 [ 0.317343] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.318131] NFS: Registering the id_resolver key type [ 0.318171] Key type id_resolver registered [ 0.318179] Key type id_legacy registered [ 0.318226] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.324898] Key type asymmetric registered [ 0.324919] Asymmetric key parser 'x509' registered [ 0.324991] bounce: pool size: 64 pages [ 0.325069] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.325083] io scheduler noop registered [ 0.325091] io scheduler deadline registered [ 0.325390] io scheduler cfq registered (default) [ 0.325404] io scheduler mq-deadline registered [ 0.325412] io scheduler kyber registered [ 0.328840] pinctrl-single 44e10800.pinmux: 199 pins, size 796 [ 0.383768] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.387519] omap8250 44e09000.serial: No clock speed specified: using default: 48000000 [ 0.388397] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 31, base_baud = 3000000) is a 8250 [ 0.389081] omap8250 48022000.serial: No clock speed specified: using default: 48000000 [ 0.389868] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 32, base_baud = 3000000) is a 8250 [ 0.390479] omap8250 48024000.serial: No clock speed specified: using default: 48000000 [ 0.391229] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 33, base_baud = 3000000) is a 8250 [ 0.391826] omap8250 481a6000.serial: No clock speed specified: using default: 48000000 [ 0.392563] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 34, base_baud = 3000000) is a 8250 [ 0.393189] omap8250 481a8000.serial: No clock speed specified: using default: 48000000 [ 0.393915] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 35, base_baud = 3000000) is a 8250 [ 1.174137] console [ttyS4] enabled [ 1.180094] omap_rng 48310000.rng: Random Number Generator ver. 20 [ 1.186691] random: fast init done [ 1.190363] random: crng init done [ 1.210731] brd: module loaded [ 1.223660] loop: module loaded [ 1.229648] omap2_mcspi 481a2000.spi: registered master spi1 [ 1.230392] omap2_mcspi 48345000.spi: registered master spi2 [ 1.230592] spi spi2.0: setup: speed 1000000, sample leading edge, clk normal [ 1.230608] spi spi2.0: setup mode 0, 8 bits/w, 1000000 Hz max --> 0 [ 1.230815] omap2_mcspi 48345000.spi: registered child spi2.0 [ 1.231754] mdio_bus fixed-0: GPIO lookup for consumer reset [ 1.231764] mdio_bus fixed-0: using lookup tables for GPIO lookup [ 1.231771] mdio_bus fixed-0: No GPIO consumer reset found [ 1.231798] libphy: Fixed MDIO Bus: probed [ 1.237012] CAN device driver interface [ 1.242055] c_can_platform 481cc000.can: c_can_platform device registered (regs=6f6bc430, irq=67) [ 1.266072] mdio_bus 4a101000.mdio: GPIO lookup for consumer reset [ 1.266084] mdio_bus 4a101000.mdio: using device tree for GPIO lookup [ 1.266108] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/ethernet@4a100000/mdio@4a101000[0]' [ 1.266124] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/ethernet@4a100000/mdio@4a101000[0]' [ 1.266134] mdio_bus 4a101000.mdio: using lookup tables for GPIO lookup [ 1.266141] mdio_bus 4a101000.mdio: No GPIO consumer reset found [ 1.316562] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 1.324266] davinci_mdio 4a101000.mdio: detected phy mask fffffffe [ 1.331586] libphy: 4a101000.mdio: probed [ 1.335632] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8740 [ 1.345204] cpsw 4a100000.ethernet: Detected MACID = 30:e2:83:da:bc:63 [ 1.352016] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4 [ 1.358502] cpsw 4a100000.ethernet: ALE Table size 1024 [ 1.363795] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies) [ 1.372557] i2c /dev entries driver [ 1.378609] cpuidle: enable-method property 'ti,am4372' found operations [ 1.385872] sdhci: Secure Digital Host Controller Interface driver [ 1.392198] sdhci: Copyright(c) Pierre Ossman [ 1.397388] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd [ 1.397398] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 1.397427] omap_hsmmc 48060000.mmc: No GPIO consumer cd found [ 1.397645] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer cd [ 1.397653] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup [ 1.397674] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/mmc@481d8000[0]' [ 1.397688] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/mmc@481d8000[0]' [ 1.397698] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup [ 1.397705] omap_hsmmc 481d8000.mmc: No GPIO consumer cd found [ 1.397715] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer wp [ 1.397720] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup [ 1.397734] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/mmc@481d8000[0]' [ 1.397746] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/mmc@481d8000[0]' [ 1.397753] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup [ 1.397760] omap_hsmmc 481d8000.mmc: No GPIO consumer wp found [ 1.398600] omap_hsmmc 47810000.mmc: GPIO lookup for consumer cd [ 1.398610] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup [ 1.398633] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/mmc@47810000[0]' [ 1.398648] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/mmc@47810000[0]' [ 1.398656] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup [ 1.398664] omap_hsmmc 47810000.mmc: No GPIO consumer cd found [ 1.398674] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp [ 1.398679] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup [ 1.398693] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/mmc@47810000[0]' [ 1.398706] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/mmc@47810000[0]' [ 1.398713] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup [ 1.398719] omap_hsmmc 47810000.mmc: No GPIO consumer wp found [ 1.399399] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.406233] ledtrig-cpu: registered to indicate activity on CPUs [ 1.414484] NET: Registered protocol family 10 [ 1.420446] Segment Routing with IPv6 [ 1.424229] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 1.431059] NET: Registered protocol family 17 [ 1.435550] can: controller area network core (rev 20170425 abi 9) [ 1.442090] NET: Registered protocol family 29 [ 1.446654] can: raw protocol (rev 20170425) [ 1.450944] can: broadcast manager protocol (rev 20170425 t) [ 1.456657] can: netlink gateway (rev 20170425) max_hops=1 [ 1.462657] Key type dns_resolver registered [ 1.467268] omap_voltage_late_init: Voltage driver support not added [ 1.474656] Loading compiled-in X.509 certificates [ 1.492541] gpio gpiochip0: (gpio-0-31): added GPIO chardev (254:0) [ 1.492660] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio-0-31) [ 1.492713] OMAP GPIO hardware version 0.1 [ 1.497687] gpio gpiochip1: (gpio-32-63): added GPIO chardev (254:1) [ 1.497779] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio-32-63) [ 1.498410] gpio gpiochip2: (gpio-64-95): added GPIO chardev (254:2) [ 1.498496] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio-64-95) [ 1.499083] gpio gpiochip3: (gpio-96-127): added GPIO chardev (254:3) [ 1.499178] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip3 (gpio-96-127) [ 1.499740] gpio gpiochip4: (gpio-128-159): added GPIO chardev (254:4) [ 1.499836] gpiochip_setup_dev: registered GPIOs 128 to 159 on device: gpiochip4 (gpio-128-159) [ 1.500393] gpio gpiochip5: (gpio-160-191): added GPIO chardev (254:5) [ 1.500487] gpiochip_setup_dev: registered GPIOs 160 to 191 on device: gpiochip5 (gpio-160-191) [ 1.500762] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-mmcwl[0]' - status (0) [ 1.502253] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 100 kHz [ 1.550300] LDO1: Bringing 1800000uV into 2100000-2100000uV [ 1.559131] omap_i2c 4819c000.i2c: bus 2 rev0.12 at 100 kHz [ 1.565150] cpu cpu0: Linked as a consumer to regulator.3 [ 1.570705] cpu cpu0: Dropping the link to regulator.3 [ 1.576072] cpu cpu0: Linked as a consumer to regulator.3 [ 1.582953] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd [ 1.582964] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 1.583007] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp@44000000/mmc@48060000[0]' - status (0) [ 1.583086] gpio gpiochip0: Persistence not supported for GPIO 6 [ 1.583102] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22) [ 1.591989] omap_hsmmc 48060000.mmc: Got CD GPIO [ 1.596695] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp [ 1.596702] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 1.596721] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/mmc@48060000[0]' [ 1.596736] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/mmc@48060000[0]' [ 1.596747] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup [ 1.596755] omap_hsmmc 48060000.mmc: No GPIO consumer wp found [ 1.597219] omap_hsmmc 48060000.mmc: Linked as a consumer to regulator.5 [ 1.631332] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer cd [ 1.631356] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup [ 1.631408] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/mmc@481d8000[0]' [ 1.631446] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/mmc@481d8000[0]' [ 1.631468] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup [ 1.631486] omap_hsmmc 481d8000.mmc: No GPIO consumer cd found [ 1.631510] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer wp [ 1.631524] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup [ 1.631561] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/mmc@481d8000[0]' [ 1.631594] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/mmc@481d8000[0]' [ 1.631612] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup [ 1.631628] omap_hsmmc 481d8000.mmc: No GPIO consumer wp found [ 1.632348] omap_hsmmc 481d8000.mmc: Linked as a consumer to regulator.5 [ 1.663638] omap_hsmmc 47810000.mmc: GPIO lookup for consumer cd [ 1.663651] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup [ 1.663683] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/mmc@47810000[0]' [ 1.663703] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/mmc@47810000[0]' [ 1.663715] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup [ 1.663725] omap_hsmmc 47810000.mmc: No GPIO consumer cd found [ 1.663737] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp [ 1.663744] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup [ 1.663763] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/mmc@47810000[0]' [ 1.663780] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/mmc@47810000[0]' [ 1.663788] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup [ 1.663797] omap_hsmmc 47810000.mmc: No GPIO consumer wp found [ 1.664332] omap_hsmmc 47810000.mmc: Linked as a consumer to regulator.1 [ 1.714549] mmc1: new high speed MMC card at address 0001 [ 1.721919] mmcblk1: mmc1:0001 Q2J54A 3.64 GiB [ 1.727602] mmcblk1boot0: mmc1:0001 Q2J54A partition 1 2.00 MiB [ 1.734514] mmcblk1boot1: mmc1:0001 Q2J54A partition 2 2.00 MiB [ 1.741083] mmcblk1rpmb: mmc1:0001 Q2J54A partition 3 512 KiB, chardev (244:0) [ 1.751215] mmcblk1: p1 p2 p3 p4 [ 1.783310] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led0[0]' - status (0) [ 1.783432] gpio gpiochip3: Persistence not supported for GPIO 17 [ 1.783443] no flags found for gpios [ 1.783834] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led1[0]' - status (0) [ 1.783915] gpio gpiochip5: Persistence not supported for GPIO 8 [ 1.783925] no flags found for gpios [ 1.784186] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led2[0]' - status (0) [ 1.784219] gpio gpiochip0: Persistence not supported for GPIO 7 [ 1.784227] no flags found for gpios [ 1.785662] hctosys: unable to open rtc device (rtc0) [ 1.792753] ALSA device list: [ 1.795860] No soundcards found. [ 1.802805] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range [ 1.825663] mmc2: new high speed SDIO card at address 0001 [ 1.831809] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 1.840646] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 1.847999] devtmpfs: mounted [ 1.856211] Freeing unused kernel memory: 1024K [ 1.861032] Run /sbin/init as init process [ 2.301406] systemd[1]: System time before build time, advancing clock. [ 2.386237] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 2.408734] systemd[1]: Detected architecture arm. [ 2.457708] systemd[1]: Set hostname to <smaway>. [ 3.412579] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ 3.429955] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 3.849731] systemd[1]: Reached target Remote File Systems. [ 3.893542] systemd[1]: Created slice User and Session Slice. [ 3.927854] systemd[1]: Listening on fsck to fsckd communication Socket. [ 3.967945] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 4.007731] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 5.025561] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [ 6.296260] systemd-journald[95]: Received request to flush runtime journal from PID 1 [ 9.164041] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle [ 9.288251] PM: Cannot get wkup_m3_ipc handle [ 10.180956] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle [ 10.237022] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 10.251163] omap_rtc 44e3e000.rtc: char device (253:0) [ 10.251194] omap_rtc 44e3e000.rtc: registered as rtc0 [ 10.291236] PM: Cannot get wkup_m3_ipc handle [ 10.296323] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle [ 10.384009] remoteproc remoteproc0: wkup_m3 is available [ 10.498257] PM: Cannot get wkup_m3_ipc handle [ 10.503331] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle [ 10.708056] PM: Cannot get wkup_m3_ipc handle [ 10.727903] remoteproc remoteproc0: powering up wkup_m3 [ 10.757980] PM: Cannot get wkup_m3_ipc handle [ 10.830849] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 242896 [ 10.859298] PM: Cannot get wkup_m3_ipc handle [ 10.995068] remoteproc remoteproc0: remote processor wkup_m3 is now up [ 11.001754] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192 [ 11.388008] PM: bootloader does not support rtc-only! [ 14.232723] omap-sham 53100000.sham: hw accel on OMAP rev 0.0 [ 14.519235] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1 [ 14.638048] omap-des 53701000.des: OMAP DES hw accel rev: 0.33 [ 14.671356] omap-aes 53501000.aes: will run requests pump with realtime priority [ 14.770775] omap-des 53701000.des: will run requests pump with realtime priority [ 15.287483] net eth0: initializing cpsw version 1.15 (0) [ 15.426859] SMSC LAN8740 4a101000.mdio:00: attached PHY driver [SMSC LAN8740] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL) [ 15.521263] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 17.607900] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 17.679777] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 17.910330] 8021q: 802.1Q VLAN Support v1.8 [ 17.914591] 8021q: adding VLAN 0 to HW filter on device eth0 [ 19.185738] dwc3 48390000.usb: Failed to get clk 'ref': -2 [ 19.289565] dwc3 483d0000.usb: Failed to get clk 'ref': -2 [ 19.478189] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 19.500829] usbcore: registered new interface driver usbfs [ 19.506454] usbcore: registered new interface driver hub [ 19.577308] usbcore: registered new device driver usb [ 19.659785] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 19.700127] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller [ 19.705699] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 1 [ 19.777565] xhci-hcd xhci-hcd.5.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002010010 [ 19.827372] xhci-hcd xhci-hcd.5.auto: irq 104, io mem 0x48390000 [ 19.847535] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 19.855858] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 19.927264] usb usb1: Product: xHCI Host Controller [ 19.932184] usb usb1: Manufacturer: Linux 4.19.59-g5f8c1c6121 xhci-hcd [ 19.977283] usb usb1: SerialNumber: xhci-hcd.5.auto [ 20.005571] hub 1-0:1.0: USB hub found [ 20.026761] hub 1-0:1.0: 1 port detected [ 20.061416] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller [ 20.087275] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 2 [ 20.095020] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed [ 20.157988] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 20.179882] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 20.217648] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 20.224924] usb usb2: Product: xHCI Host Controller [ 20.252967] usb usb2: Manufacturer: Linux 4.19.59-g5f8c1c6121 xhci-hcd [ 20.277696] usb usb2: SerialNumber: xhci-hcd.5.auto [ 20.300485] hub 2-0:1.0: USB hub found [ 20.322920] hub 2-0:1.0: 1 port detected [ 20.339709] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 20.345272] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 3 [ 20.416640] xhci-hcd xhci-hcd.6.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002010010 [ 20.426259] xhci-hcd xhci-hcd.6.auto: irq 105, io mem 0x483d0000 [ 20.436205] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 20.483474] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 20.516636] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 20.534434] usb usb3: Product: xHCI Host Controller [ 20.548842] usb usb3: Manufacturer: Linux 4.19.59-g5f8c1c6121 xhci-hcd [ 20.566913] usb usb3: SerialNumber: xhci-hcd.6.auto [ 20.582398] hub 3-0:1.0: USB hub found [ 20.596669] hub 3-0:1.0: 1 port detected [ 20.612295] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 20.626720] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 4 [ 20.634458] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed [ 20.651496] usb 1-1: New USB device found, idVendor=0480, idProduct=a202, bcdDevice= 3.15 [ 20.672805] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 20.683353] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 20.695420] usb 1-1: Product: External USB 3.0 [ 20.702374] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 20.716840] usb 1-1: Manufacturer: TOSHIBA [ 20.728597] usb 1-1: SerialNumber: 20170905004167C [ 20.739739] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 20.759292] usb usb4: Product: xHCI Host Controller [ 20.775812] usb usb4: Manufacturer: Linux 4.19.59-g5f8c1c6121 xhci-hcd [ 20.797065] usb usb4: SerialNumber: xhci-hcd.6.auto [ 20.804568] hub 4-0:1.0: USB hub found [ 20.815218] hub 4-0:1.0: 1 port detected [ 20.938207] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11) [ 20.980049] wlcore: loaded [ 21.816685] SCSI subsystem initialized [ 21.851675] usb-storage 1-1:1.0: USB Mass Storage device detected [ 21.870922] scsi host0: usb-storage 1-1:1.0 [ 21.886065] usbcore: registered new interface driver usb-storage [ 21.911993] usbcore: registered new interface driver uas [ 22.890153] scsi 0:0:0:0: Direct-Access TOSHIBA External USB 3.0 5438 PQ: 0 ANSI: 6 [ 22.953179] sd 0:0:0:0: [sda] 1953525164 512-byte logical blocks: (1.00 TB/932 GiB) [ 22.970810] sd 0:0:0:0: [sda] Write Protect is off [ 22.975649] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00 [ 22.986840] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 26.471794] sda: sda1 [ 26.483043] sd 0:0:0:0: [sda] Attached SCSI disk [ 30.590876] gpio gpiochip0: Persistence not supported for GPIO 4 [ 30.600580] gpio gpiochip0: Persistence not supported for GPIO 20 [ 30.608364] gpio gpiochip0: Persistence not supported for GPIO 23 [ 30.627768] gpio gpiochip1: Persistence not supported for GPIO 0 [ 30.647134] gpio gpiochip1: Persistence not supported for GPIO 1 [ 30.652273] gpio gpiochip1: Persistence not supported for GPIO 5 [ 30.697028] gpio gpiochip1: Persistence not supported for GPIO 6 [ 30.703447] gpio gpiochip1: Persistence not supported for GPIO 7 [ 30.737198] gpio gpiochip1: Persistence not supported for GPIO 16 [ 30.742560] gpio gpiochip1: Persistence not supported for GPIO 22 [ 30.864671] gpio gpiochip1: Persistence not supported for GPIO 25 [ 30.865832] gpio gpiochip1: Persistence not supported for GPIO 27 [ 30.883292] gpio gpiochip1: Persistence not supported for GPIO 29 [ 30.937684] gpio gpiochip2: Persistence not supported for GPIO 2 [ 30.938890] gpio gpiochip3: Persistence not supported for GPIO 23 [ 30.996206] gpio gpiochip4: Persistence not supported for GPIO 9 [ 31.041114] gpio gpiochip5: Persistence not supported for GPIO 11 [ 31.042908] gpio gpiochip5: Persistence not supported for GPIO 12 [ 31.077655] gpio gpiochip5: Persistence not supported for GPIO 13 [ 32.427906] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 32.602896] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null) [ 32.755228] FAT-fs (mmcblk1p4): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [13487.248342] hrtimer: interrupt took 521834 ns [666376.862360] usb 1-1: USB disconnect, device number 2 [666376.890748] sd 0:0:0:0: [sda] Synchronizing SCSI cache [666376.911647] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.10.100 (phoyer@SmaLin) (arm-linux-gnueabihf-gcc (Ubuntu 11.2.0-17ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #7 SMP PREEMPT Sat Sep 24 18:39:19 CEST 2022 [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: SMaBiT SMaWay [ 0.000000] Memory policy: Data cache writeback [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 48 MiB at 0xbd000000 [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000080000000-0x00000000afffffff] [ 0.000000] HighMem [mem 0x00000000b0000000-0x00000000bfffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x00000000bfffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff] [ 0.000000] On node 0 totalpages: 262144 [ 0.000000] Normal zone: 1728 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 196608 pages, LIFO batch:63 [ 0.000000] HighMem zone: 65536 pages, LIFO batch:15 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM437x ES1.2 (neon) [ 0.000000] percpu: Embedded 20 pages/cpu s49932 r8192 d23796 u81920 [ 0.000000] pcpu-alloc: s49932 r8192 d23796 u81920 alloc=20*4096 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260416 [ 0.000000] Kernel command line: console=ttyO4,115200n8 video=vmalloc=512M net.ifnames=0 biosdevnames=0 root=PARTUUID=015884b5-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 972268K/1048576K available (10240K kernel code, 1113K rwdata, 3436K rodata, 1024K init, 309K bss, 27156K reserved, 49152K cma-reserved, 212992K highmem) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] ftrace: allocating 34359 entries in 101 pages [ 0.000000] ftrace: allocated 101 pages with 4 groups [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9 [ 0.000000] OMAP L2C310: ROM does not support power control setting [ 0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled [ 0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB [ 0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000 [ 0.000000] random: get_random_bytes called from start_kernel+0x394/0x568 with crng_init=0 [ 0.000000] TI gptimer clocksource: always-on /ocp@44000000/interconnect@44c00000/segment@200000/target-module@31000 [ 0.000010] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000027] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000147] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000161] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000439] TI gptimer clockevent: 24000000 Hz at /ocp@44000000/interconnect@48000000/segment@0/target-module@40000 [ 0.001542] Console: colour dummy device 80x30 [ 0.001585] WARNING: Your 'console=ttyO4' has been replaced by 'ttyS4' [ 0.001593] This ensures that you still see kernel messages. Please [ 0.001600] update your kernel commandline. [ 0.001660] Calibrating delay loop... 1993.93 BogoMIPS (lpj=9969664) [ 0.058046] pid_max: default: 32768 minimum: 301 [ 0.058177] LSM: Security Framework initializing [ 0.058308] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.058335] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.059465] CPU: Testing write buffer coherency: ok [ 0.059541] CPU0: Spectre v2: using BPIALL workaround [ 0.059905] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.060941] Setting up static identity map for 0x80100000 - 0x80100060 [ 0.061131] rcu: Hierarchical SRCU implementation. [ 0.061446] EFI services will not be available. [ 0.061604] smp: Bringing up secondary CPUs ... [ 0.061617] smp: Brought up 1 node, 1 CPU [ 0.061628] SMP: Total of 1 processors activated (1993.93 BogoMIPS). [ 0.061637] CPU: All CPU(s) started in SVC mode. [ 0.062317] devtmpfs: initialized [ 0.077222] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.077556] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.077586] futex hash table entries: 256 (order: 2, 16384 bytes, linear) [ 0.081355] pinctrl core: initialized pinctrl subsystem [ 0.082402] DMI not present or invalid. [ 0.082929] NET: Registered protocol family 16 [ 0.085552] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.096099] thermal_sys: Registered thermal governor 'fair_share' [ 0.096114] thermal_sys: Registered thermal governor 'bang_bang' [ 0.096130] thermal_sys: Registered thermal governor 'step_wise' [ 0.096138] thermal_sys: Registered thermal governor 'user_space' [ 0.096616] cpuidle: using governor ladder [ 0.096669] cpuidle: using governor menu [ 0.107102] omap_l3_noc 44000000.ocp: L3 debug error: target 8 mod:0 (unclearable) [ 0.107214] omap_l3_noc 44000000.ocp: L3 application error: target 8 mod:0 (unclearable) [ 1.007168] No ATAGs? [ 1.007279] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 1.007292] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 1.038289] reg-fixed-voltage fixedregulator-mmcwl: GPIO lookup for consumer (null) [ 1.038305] reg-fixed-voltage fixedregulator-mmcwl: using device tree for GPIO lookup [ 1.038345] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-mmcwl[0]' [ 1.038374] reg-fixed-voltage fixedregulator-mmcwl: No GPIO consumer (null) found [ 1.039463] iommu: Default domain type: Translated [ 1.041950] mc: Linux media interface: v0.10 [ 1.042005] videodev: Linux video capture interface: v2.00 [ 1.042153] pps_core: LinuxPPS API ver. 1 registered [ 1.042164] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.042190] PTP clock support registered [ 1.042256] EDAC MC: Ver: 3.0.0 [ 1.044428] NetLabel: Initializing [ 1.044450] NetLabel: domain hash size = 128 [ 1.044457] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 1.044538] NetLabel: unlabeled traffic allowed by default [ 1.045063] clocksource: Switched to clocksource dmtimer [ 1.620145] NET: Registered protocol family 2 [ 1.620515] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 1.621975] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) [ 1.622034] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 1.622102] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 1.622209] TCP: Hash tables configured (established 8192 bind 8192) [ 1.622409] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 1.622482] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 1.622689] NET: Registered protocol family 1 [ 1.623492] RPC: Registered named UNIX socket transport module. [ 1.623511] RPC: Registered udp transport module. [ 1.623520] RPC: Registered tcp transport module. [ 1.623527] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.626000] Initialise system trusted keyrings [ 1.626357] workingset: timestamp_bits=14 max_order=18 bucket_order=4 [ 1.631062] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.632021] NFS: Registering the id_resolver key type [ 1.632069] Key type id_resolver registered [ 1.632079] Key type id_legacy registered [ 1.632130] ntfs: driver 2.1.32 [Flags: R/O]. [ 1.711354] Key type asymmetric registered [ 1.711378] Asymmetric key parser 'x509' registered [ 1.711453] bounce: pool size: 64 pages [ 1.711526] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 1.711539] io scheduler mq-deadline registered [ 1.711549] io scheduler kyber registered [ 2.101948] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 2.357689] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present! [ 2.357730] edma 49000000.dma: TI EDMA DMA engine driver [ 2.379044] pinctrl-single 44e10800.pinmux: 199 pins, size 796 [ 2.435902] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 2.440285] omap8250 44e09000.serial: No clock speed specified: using default: 48000000 [ 2.441499] omap8250 44e09000.serial: GPIO lookup for consumer rs485-term [ 2.441512] omap8250 44e09000.serial: using device tree for GPIO lookup [ 2.441557] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@9000/serial@0[0]' [ 2.441583] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@9000/serial@0[0]' [ 2.441597] omap8250 44e09000.serial: using lookup tables for GPIO lookup [ 2.441606] omap8250 44e09000.serial: No GPIO consumer rs485-term found [ 2.441649] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 64, base_baud = 3000000) is a 8250 [ 2.442800] omap8250 48022000.serial: No clock speed specified: using default: 48000000 [ 2.443872] omap8250 48022000.serial: GPIO lookup for consumer rs485-term [ 2.443887] omap8250 48022000.serial: using device tree for GPIO lookup [ 2.443932] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@22000/serial@0[0]' [ 2.443958] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@22000/serial@0[0]' [ 2.443971] omap8250 48022000.serial: using lookup tables for GPIO lookup [ 2.443980] omap8250 48022000.serial: No GPIO consumer rs485-term found [ 2.444022] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 70, base_baud = 3000000) is a 8250 [ 2.445203] omap8250 48024000.serial: No clock speed specified: using default: 48000000 [ 2.446273] omap8250 48024000.serial: GPIO lookup for consumer rs485-term [ 2.446286] omap8250 48024000.serial: using device tree for GPIO lookup [ 2.446333] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@24000/serial@0[0]' [ 2.446359] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@24000/serial@0[0]' [ 2.446373] omap8250 48024000.serial: using lookup tables for GPIO lookup [ 2.446382] omap8250 48024000.serial: No GPIO consumer rs485-term found [ 2.446422] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 71, base_baud = 3000000) is a 8250 [ 2.447528] omap8250 481a6000.serial: No clock speed specified: using default: 48000000 [ 2.448573] omap8250 481a6000.serial: GPIO lookup for consumer rs485-term [ 2.448585] omap8250 481a6000.serial: using device tree for GPIO lookup [ 2.448629] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@a6000/serial@0[0]' [ 2.448656] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@a6000/serial@0[0]' [ 2.448670] omap8250 481a6000.serial: using lookup tables for GPIO lookup [ 2.448679] omap8250 481a6000.serial: No GPIO consumer rs485-term found [ 2.448721] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 79, base_baud = 3000000) is a 8250 [ 2.449738] omap8250 481a8000.serial: No clock speed specified: using default: 48000000 [ 2.450761] omap8250 481a8000.serial: GPIO lookup for consumer rs485-term [ 2.450774] omap8250 481a8000.serial: using device tree for GPIO lookup [ 2.450817] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@a8000/serial@0[0]' [ 2.450843] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@a8000/serial@0[0]' [ 2.450856] omap8250 481a8000.serial: using lookup tables for GPIO lookup [ 2.450864] omap8250 481a8000.serial: No GPIO consumer rs485-term found [ 2.450907] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 80, base_baud = 3000000) is a 8250 [ 3.315413] printk: console [ttyS4] enabled [ 3.323031] omap_rng 48310000.rng: Random Number Generator ver. 20 [ 3.329515] random: fast init done [ 3.333192] random: crng init done [ 3.360453] brd: module loaded [ 3.375260] loop: module loaded [ 3.380542] omap2_mcspi 481a2000.spi: registered master spi1 [ 3.381739] omap2_mcspi 48345000.spi: registered master spi2 [ 3.382921] mdio_bus fixed-0: GPIO lookup for consumer reset [ 3.382934] mdio_bus fixed-0: using lookup tables for GPIO lookup [ 3.382943] mdio_bus fixed-0: No GPIO consumer reset found [ 3.383144] CAN device driver interface [ 3.388877] c_can_platform 481cc000.can: c_can_platform device registered (regs=145874b3, irq=83) [ 3.403196] mdio_bus 4a101000.mdio: GPIO lookup for consumer reset [ 3.403213] mdio_bus 4a101000.mdio: using device tree for GPIO lookup [ 3.403253] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000[0]' [ 3.403281] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000[0]' [ 3.403294] mdio_bus 4a101000.mdio: using lookup tables for GPIO lookup [ 3.403303] mdio_bus 4a101000.mdio: No GPIO consumer reset found [ 3.455150] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 3.464130] mdio_bus 4a101000.mdio:00: GPIO lookup for consumer reset [ 3.464145] mdio_bus 4a101000.mdio:00: using device tree for GPIO lookup [ 3.464197] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000/ethernet-phy@0[0]' [ 3.464229] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/mdio@1000/ethernet-phy@0[0]' [ 3.464241] mdio_bus 4a101000.mdio:00: using lookup tables for GPIO lookup [ 3.464250] mdio_bus 4a101000.mdio:00: No GPIO consumer reset found [ 3.466187] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8740 [ 3.475623] cpsw-switch 4a100000.switch: /ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/switch@0/ethernet-ports/port@2 no phy found [ 3.491129] i2c /dev entries driver [ 3.498067] cpuidle: enable-method property 'ti,am4372' found operations [ 3.505855] sdhci: Secure Digital Host Controller Interface driver [ 3.512068] sdhci: Copyright(c) Pierre Ossman [ 3.517847] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.525282] sdhci-omap 48060000.mmc: GPIO lookup for consumer cd [ 3.525296] sdhci-omap 48060000.mmc: using device tree for GPIO lookup [ 3.525326] sdhci-omap 48060000.mmc: No GPIO consumer cd found [ 3.526069] sdhci-omap 481d8000.mmc: GPIO lookup for consumer cd [ 3.526083] sdhci-omap 481d8000.mmc: using device tree for GPIO lookup [ 3.526127] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]' [ 3.526153] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]' [ 3.526165] sdhci-omap 481d8000.mmc: using lookup tables for GPIO lookup [ 3.526173] sdhci-omap 481d8000.mmc: No GPIO consumer cd found [ 3.526183] sdhci-omap 481d8000.mmc: GPIO lookup for consumer wp [ 3.526188] sdhci-omap 481d8000.mmc: using device tree for GPIO lookup [ 3.526213] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]' [ 3.526236] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]' [ 3.526246] sdhci-omap 481d8000.mmc: using lookup tables for GPIO lookup [ 3.526253] sdhci-omap 481d8000.mmc: No GPIO consumer wp found [ 3.526403] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator [ 3.536829] sdhci-omap 47810000.mmc: GPIO lookup for consumer cd [ 3.536845] sdhci-omap 47810000.mmc: using device tree for GPIO lookup [ 3.536883] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]' [ 3.536907] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]' [ 3.536918] sdhci-omap 47810000.mmc: using lookup tables for GPIO lookup [ 3.536928] sdhci-omap 47810000.mmc: No GPIO consumer cd found [ 3.536936] sdhci-omap 47810000.mmc: GPIO lookup for consumer wp [ 3.536942] sdhci-omap 47810000.mmc: using device tree for GPIO lookup [ 3.536962] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]' [ 3.536982] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]' [ 3.536991] sdhci-omap 47810000.mmc: using lookup tables for GPIO lookup [ 3.536998] sdhci-omap 47810000.mmc: No GPIO consumer wp found [ 3.537194] ledtrig-cpu: registered to indicate activity on CPUs [ 3.545278] sdhci-omap 47810000.mmc: supply vqmmc not found, using dummy regulator [ 3.554184] NET: Registered protocol family 10 [ 3.566639] Segment Routing with IPv6 [ 3.570416] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 3.577270] NET: Registered protocol family 17 [ 3.581761] can: controller area network core [ 3.586312] NET: Registered protocol family 29 [ 3.590777] can: raw protocol [ 3.593761] can: broadcast manager protocol [ 3.598112] can: netlink gateway - max_hops=1 [ 3.602720] Key type dns_resolver registered [ 3.607238] Registering SWP/SWPB emulation handler [ 3.612059] omap_voltage_late_init: Voltage driver support not added [ 3.619150] Loading compiled-in X.509 certificates [ 3.624170] Key type ._fscrypt registered [ 3.628328] Key type .fscrypt registered [ 3.632271] Key type fscrypt-provisioning registered [ 3.659844] reg-fixed-voltage fixedregulator-mmcwl: GPIO lookup for consumer (null) [ 3.659866] reg-fixed-voltage fixedregulator-mmcwl: using device tree for GPIO lookup [ 3.659904] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-mmcwl[0]' [ 3.659933] reg-fixed-voltage fixedregulator-mmcwl: No GPIO consumer (null) found [ 3.661194] gpio gpiochip0: (gpio-0-31): added GPIO chardev (254:0) [ 3.661303] gpio gpiochip0: registered GPIOs 0 to 31 on gpio-0-31 [ 3.661385] OMAP GPIO hardware version 0.1 [ 3.667370] i2c i2c-1: GPIO lookup for consumer scl [ 3.667386] i2c i2c-1: using device tree for GPIO lookup [ 3.667427] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0[0]' [ 3.667453] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0[0]' [ 3.667466] i2c i2c-1: using lookup tables for GPIO lookup [ 3.667475] i2c i2c-1: No GPIO consumer scl found [ 3.667495] i2c i2c-1: GPIO lookup for consumer sda [ 3.667500] i2c i2c-1: using device tree for GPIO lookup [ 3.667524] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0[0]' [ 3.667547] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0[0]' [ 3.667556] i2c i2c-1: using lookup tables for GPIO lookup [ 3.667563] i2c i2c-1: No GPIO consumer sda found [ 3.667621] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 100 kHz [ 3.674241] gpio gpiochip1: (gpio-32-63): added GPIO chardev (254:1) [ 3.674349] gpio gpiochip1: registered GPIOs 32 to 63 on gpio-32-63 [ 3.676013] i2c i2c-2: GPIO lookup for consumer scl [ 3.676030] i2c i2c-2: using device tree for GPIO lookup [ 3.676073] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@9c000/i2c@0[0]' [ 3.676101] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@9c000/i2c@0[0]' [ 3.676115] i2c i2c-2: using lookup tables for GPIO lookup [ 3.676124] i2c i2c-2: No GPIO consumer scl found [ 3.676144] i2c i2c-2: GPIO lookup for consumer sda [ 3.676149] i2c i2c-2: using device tree for GPIO lookup [ 3.676174] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@9c000/i2c@0[0]' [ 3.676198] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@9c000/i2c@0[0]' [ 3.676207] i2c i2c-2: using lookup tables for GPIO lookup [ 3.676214] i2c i2c-2: No GPIO consumer sda found [ 3.708121] tps65218-pwrbutton: Failed to locate of_node [id: -2] [ 3.714574] tps65218-gpio: Failed to locate of_node [id: -2] [ 3.731916] LDO1: Bringing 1800000uV into 2100000-2100000uV [ 3.740648] omap_i2c 4819c000.i2c: bus 2 rev0.12 at 100 kHz [ 3.747335] gpio gpiochip2: (gpio-64-95): added GPIO chardev (254:2) [ 3.747441] gpio gpiochip2: registered GPIOs 64 to 95 on gpio-64-95 [ 3.748384] gpio gpiochip3: (gpio-96-127): added GPIO chardev (254:3) [ 3.748500] gpio gpiochip3: registered GPIOs 96 to 127 on gpio-96-127 [ 3.749457] gpio gpiochip4: (gpio-128-159): added GPIO chardev (254:4) [ 3.749558] gpio gpiochip4: registered GPIOs 128 to 159 on gpio-128-159 [ 3.750487] gpio gpiochip5: (gpio-160-191): added GPIO chardev (254:5) [ 3.750588] gpio gpiochip5: registered GPIOs 160 to 191 on gpio-160-191 [ 3.763406] omap_reset_deassert: timedout waiting for gfx:0 [ 3.769107] ti-sysc: probe of 5600fe00.target-module failed with error -110 [ 3.779110] sdhci-omap 48060000.mmc: GPIO lookup for consumer cd [ 3.779127] sdhci-omap 48060000.mmc: using device tree for GPIO lookup [ 3.779194] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]' - status (0) [ 3.779275] gpio gpiochip0: Persistence not supported for GPIO 6 [ 3.779298] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22) [ 3.788713] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led0[0]' - status (0) [ 3.788741] gpio gpiochip3: Persistence not supported for GPIO 17 [ 3.788749] gpio-113 (?): no flags found for gpios [ 3.788918] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led1[0]' - status (0) [ 3.788936] gpio gpiochip5: Persistence not supported for GPIO 8 [ 3.788942] gpio-168 (?): no flags found for gpios [ 3.789123] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led2[0]' - status (0) [ 3.789139] gpio gpiochip0: Persistence not supported for GPIO 7 [ 3.789145] gpio-7 (?): no flags found for gpios [ 3.790514] sdhci-omap 481d8000.mmc: GPIO lookup for consumer cd [ 3.790527] sdhci-omap 481d8000.mmc: using device tree for GPIO lookup [ 3.790568] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]' [ 3.790595] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]' [ 3.790607] sdhci-omap 481d8000.mmc: using lookup tables for GPIO lookup [ 3.790616] sdhci-omap 481d8000.mmc: No GPIO consumer cd found [ 3.790625] sdhci-omap 481d8000.mmc: GPIO lookup for consumer wp [ 3.790631] sdhci-omap 481d8000.mmc: using device tree for GPIO lookup [ 3.790655] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]' [ 3.790679] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]' [ 3.790687] sdhci-omap 481d8000.mmc: using lookup tables for GPIO lookup [ 3.790694] sdhci-omap 481d8000.mmc: No GPIO consumer wp found [ 3.790868] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator [ 3.799406] reg-fixed-voltage fixedregulator-mmcwl: GPIO lookup for consumer (null) [ 3.799419] reg-fixed-voltage fixedregulator-mmcwl: using device tree for GPIO lookup [ 3.799452] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-mmcwl[0]' [ 3.799490] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-mmcwl[0]' - status (0) [ 3.799514] gpio gpiochip4: Persistence not supported for GPIO 5 [ 3.804401] sdhci-omap 47810000.mmc: GPIO lookup for consumer cd [ 3.804418] sdhci-omap 47810000.mmc: using device tree for GPIO lookup [ 3.804460] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]' [ 3.804483] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]' [ 3.804495] sdhci-omap 47810000.mmc: using lookup tables for GPIO lookup [ 3.804503] sdhci-omap 47810000.mmc: No GPIO consumer cd found [ 3.804512] sdhci-omap 47810000.mmc: GPIO lookup for consumer wp [ 3.804519] sdhci-omap 47810000.mmc: using device tree for GPIO lookup [ 3.804539] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]' [ 3.804558] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]' [ 3.804566] sdhci-omap 47810000.mmc: using lookup tables for GPIO lookup [ 3.804574] sdhci-omap 47810000.mmc: No GPIO consumer wp found [ 3.804770] sdhci-omap 47810000.mmc: supply vqmmc not found, using dummy regulator [ 3.813151] sdhci-omap 48060000.mmc: Got CD GPIO [ 3.835157] sdhci-omap 48060000.mmc: GPIO lookup for consumer wp [ 3.835171] sdhci-omap 48060000.mmc: using device tree for GPIO lookup [ 3.835223] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]' [ 3.835249] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]' [ 3.835263] sdhci-omap 48060000.mmc: using lookup tables for GPIO lookup [ 3.835272] sdhci-omap 48060000.mmc: No GPIO consumer wp found [ 3.835433] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator [ 3.892231] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA [ 3.910471] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA [ 3.942452] mmc0: new high speed SDHC card at address 1234 [ 3.949503] mmcblk0: mmc0:1234 SA32G 28.8 GiB [ 3.956926] mmcblk0: p1 p2 p3 p4 [ 3.984422] mmc1: new high speed MMC card at address 0001 [ 3.989958] mmc2: SDHCI controller on 47810000.mmc [47810000.mmc] using External DMA [ 4.000208] mmcblk1: mmc1:0001 M62704 3.53 GiB [ 4.006331] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB [ 4.012989] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB [ 4.019627] mmcblk1rpmb: mmc1:0001 M62704 partition 3 512 KiB, chardev (244:0) [ 4.027016] sdhci-omap 47810000.mmc: card claims to support voltages below defined range [ 4.039063] mmcblk1: [ 4.075531] mmc2: new high speed SDIO card at address 0001 [ 4.092302] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 4.115198] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 4.122648] devtmpfs: mounted [ 4.133241] Freeing unused kernel memory: 1024K [ 4.138150] Run /sbin/init as init process [ 4.142268] with arguments: [ 4.142273] /sbin/init [ 4.142277] with environment: [ 4.142282] HOME=/ [ 4.142287] TERM=linux [ 4.142291] biosdevnames=0 [ 4.759551] systemd[1]: System time before build time, advancing clock. [ 4.905754] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 4.928240] systemd[1]: Detected architecture arm. [ 4.977061] systemd[1]: Set hostname to <smaway>. [ 5.859191] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ 5.876751] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 6.281409] systemd[1]: Listening on udev Kernel Socket. [ 6.319115] systemd[1]: Listening on Journal Socket (/dev/log). [ 6.355941] systemd[1]: Reached target Remote File Systems. [ 6.396452] systemd[1]: Listening on udev Control Socket. [ 6.437198] systemd[1]: Listening on Syslog Socket. [ 7.417238] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 9.557946] systemd-journald[119]: Received request to flush runtime journal from PID 1 [ 16.716846] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 16.880430] omap_rtc 44e3e000.rtc: char device (253:0) [ 16.880463] omap_rtc 44e3e000.rtc: registered as rtc0 [ 16.935899] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800) [ 16.944592] omap_rtc 44e3e000.rtc: GPIO lookup for consumer wp [ 16.944600] omap_rtc 44e3e000.rtc: using device tree for GPIO lookup [ 16.944660] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@3e000/rtc@0[0]' [ 16.944688] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/interconnect@44c00000/segment@200000/target-module@3e000/rtc@0[0]' [ 16.944706] omap_rtc 44e3e000.rtc: using lookup tables for GPIO lookup [ 16.944714] omap_rtc 44e3e000.rtc: No GPIO consumer wp found [ 18.456419] gpiochip_find_base: found new base at 509 [ 18.461091] gpio gpiochip6: (gpio-tps65218): added GPIO chardev (254:6) [ 18.461263] gpio gpiochip6: registered GPIOs 509 to 511 on gpio-tps65218 [ 22.733237] omap-sham 53100000.sham: hw accel on OMAP rev 0.0 [ 22.741733] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1 [ 22.829680] omap-sham 53100000.sham: will run requests pump with realtime priority [ 22.843419] omap-aes 53501000.aes: will run requests pump with realtime priority [ 22.858910] omap-des 53701000.des: OMAP DES hw accel rev: 0.33 [ 22.966863] omap-des 53701000.des: will run requests pump with realtime priority [ 26.283811] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 26.402337] usbcore: registered new interface driver usbfs [ 26.420560] usbcore: registered new interface driver hub [ 26.450578] usbcore: registered new device driver usb [ 26.517832] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 26.526494] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 26.557080] cfg80211: failed to load regulatory.db [ 26.609203] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller [ 26.614792] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 1 [ 26.685890] xhci-hcd xhci-hcd.5.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002010010 [ 26.726045] xhci-hcd xhci-hcd.5.auto: irq 109, io mem 0x48390000 [ 26.738536] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 26.774420] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 26.815755] usb usb1: Product: xHCI Host Controller [ 26.820678] usb usb1: Manufacturer: Linux 5.10.100 xhci-hcd [ 26.857058] usb usb1: SerialNumber: xhci-hcd.5.auto [ 26.877203] hub 1-0:1.0: USB hub found [ 26.905260] hub 1-0:1.0: 1 port detected [ 26.920159] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller [ 26.946200] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 2 [ 26.954579] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed [ 26.995554] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 27.003876] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 27.025335] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 27.032611] usb usb2: Product: xHCI Host Controller [ 27.055686] usb usb2: Manufacturer: Linux 5.10.100 xhci-hcd [ 27.061305] usb usb2: SerialNumber: xhci-hcd.5.auto [ 27.080872] hub 2-0:1.0: USB hub found [ 27.093448] hub 2-0:1.0: 1 port detected [ 27.104310] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 27.121610] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 3 [ 27.157450] wl18xx_driver wl18xx.4.auto: Direct firmware load for ti-connectivity/wl18xx-conf.bin failed with error -2 [ 27.187877] wlcore: ERROR could not get configuration binary ti-connectivity/wl18xx-conf.bin: -2 [ 27.215223] wlcore: WARNING falling back to default config [ 27.221436] xhci-hcd xhci-hcd.6.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002010010 [ 27.245331] xhci-hcd xhci-hcd.6.auto: irq 110, io mem 0x483d0000 [ 27.257692] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 27.275266] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 27.282541] usb usb3: Product: xHCI Host Controller [ 27.305611] usb usb3: Manufacturer: Linux 5.10.100 xhci-hcd [ 27.311231] usb usb3: SerialNumber: xhci-hcd.6.auto [ 27.336644] hub 3-0:1.0: USB hub found [ 27.340536] hub 3-0:1.0: 1 port detected [ 27.356612] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 27.362164] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 4 [ 27.385411] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed [ 27.402549] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 27.422231] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 27.455275] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 27.462553] usb usb4: Product: xHCI Host Controller [ 27.493349] usb usb4: Manufacturer: Linux 5.10.100 xhci-hcd [ 27.506031] usb usb4: SerialNumber: xhci-hcd.6.auto [ 27.528078] hub 4-0:1.0: USB hub found [ 27.531940] hub 4-0:1.0: 1 port detected [ 27.869877] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11) [ 27.957484] wlcore: loaded [ 34.340275] wlcore: PHY firmware version: Rev 8.2.0.0.245 [ 34.580021] wlcore: firmware booted (Rev 8.9.0.0.88) [ 37.082392] gpio gpiochip0: Persistence not supported for GPIO 4 [ 37.107233] gpio gpiochip0: Persistence not supported for GPIO 20 [ 37.120568] gpio gpiochip0: Persistence not supported for GPIO 23 [ 37.121628] gpio gpiochip1: Persistence not supported for GPIO 0 [ 37.122131] gpio gpiochip1: Persistence not supported for GPIO 1 [ 37.123043] gpio gpiochip1: Persistence not supported for GPIO 5 [ 37.123480] gpio gpiochip1: Persistence not supported for GPIO 6 [ 37.123854] gpio gpiochip1: Persistence not supported for GPIO 7 [ 37.124230] gpio gpiochip1: Persistence not supported for GPIO 16 [ 37.124585] gpio gpiochip1: Persistence not supported for GPIO 22 [ 37.194337] gpio gpiochip1: Persistence not supported for GPIO 25 [ 37.194883] gpio gpiochip1: Persistence not supported for GPIO 27 [ 37.225034] gpio gpiochip1: Persistence not supported for GPIO 29 [ 37.250919] gpio gpiochip2: Persistence not supported for GPIO 2 [ 37.251462] gpio gpiochip3: Persistence not supported for GPIO 23 [ 37.252426] gpio gpiochip4: Persistence not supported for GPIO 9 [ 37.253170] gpio gpiochip5: Persistence not supported for GPIO 11 [ 37.254041] gpio gpiochip5: Persistence not supported for GPIO 12 [ 37.254716] gpio gpiochip5: Persistence not supported for GPIO 13 [ 39.142236] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 39.186567] wlan0: authenticate with b8:ec:a3:f2:5b:9c [ 39.261292] wlan0: send auth to b8:ec:a3:f2:5b:9c (try 1/3) [ 39.291344] wlan0: authenticated [ 39.315841] wlan0: associate with b8:ec:a3:f2:5b:9c (try 1/3) [ 39.353485] wlan0: RX AssocResp from b8:ec:a3:f2:5b:9c (capab=0x1411 status=0 aid=1) [ 39.474424] wlan0: associated [ 39.521321] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null) [ 39.557215] ext4 filesystem being mounted at /mnt/data supports timestamps until 2038 (0x7fffffff) [ 39.815734] FAT-fs (mmcblk0p4): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 39.847083] cryptd: max_cpu_qlen set to 1000 [ 40.099207] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 40.141583] wlcore: Association completed. [ 40.287400] wlcore: down [ 40.356419] wlan0: deauthenticating from b8:ec:a3:f2:5b:9c by local choice (Reason: 3=DEAUTH_LEAVING) [ 40.796666] wlcore: down [ 107.677535] wlcore: PHY firmware version: Rev 8.2.0.0.245 [ 108.006488] wlcore: firmware booted (Rev 8.9.0.0.88) [ 111.262525] wlan0: authenticate with b8:ec:a3:f2:5b:9c [ 111.282688] wlan0: send auth to b8:ec:a3:f2:5b:9c (try 1/3) [ 111.310884] wlan0: authenticated [ 111.325198] wlan0: associate with b8:ec:a3:f2:5b:9c (try 1/3) [ 111.338535] wlan0: RX AssocResp from b8:ec:a3:f2:5b:9c (capab=0x1411 status=0 aid=1) [ 111.391773] wlan0: associated [ 111.423660] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 111.453102] wlcore: Association completed.
/* * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ * Copyright (C) 2020 SMaBiT GmbH - http://www.smabit.eu * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. */ /* AM437x SMAWAY */ /dts-v1/; #include "am4372.dtsi" #include <dt-bindings/pinctrl/am43xx.h> #include <dt-bindings/pwm/pwm.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/irq.h> / { model = "SMaBiT SMaWay"; compatible = "ti,am437x-gp-evm","ti,am4372","ti,am43","smabit,smaway"; aliases { }; chosen { stdout-path = &uart4; }; leds { compatible = "gpio-leds"; pinctrl-names = "default"; pinctrl-0 = <&leds_pins>; led0 { label = "am437x-smaway:red:led0"; gpios = <&gpio3 17 GPIO_ACTIVE_HIGH>; default-state = "off"; }; led1 { label = "am437x-smaway:blue:led1"; gpios = <&gpio5 8 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; default-state = "off"; }; led2 { label = "am437x-smaway:green:led2"; gpios = <&gpio0 7 GPIO_ACTIVE_HIGH>; default-state = "off"; }; }; // fixed 12MHz oscillator refclk: oscillator { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <12000000>; }; // fixed 32k external oscillator clock clk_32k_rtc: clk_32k_rtc { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <32768>; }; wlan_en_reg: fixedregulator-mmcwl { compatible = "regulator-fixed"; regulator-name = "vmmcwl_fixed"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; /* WLAN_EN GPIO */ gpio = <&gpio4 5 GPIO_ACTIVE_HIGH>; /* WLAN card specific delay */ startup-delay-us = <70000>; enable-active-high; }; }; &am43xx_pinmux { pinctrl-names = "default", "sleep"; i2c1_pins: i2c1_pins { pinctrl-single,pins = < AM4372_IOPAD(0xa08, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3) // (AE18) cam0_data0.I2C1_SDA AM4372_IOPAD(0xa0c, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3) // (AB18) cam0_data1.I2C1_SCL >; }; i2c2_pins: i2c2_pins { pinctrl-single,pins = < AM4372_IOPAD(0x9e8, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3) // (AB20) cam1_data0.I2C2_SDA AM4372_IOPAD(0x9ec, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3) // (AC21) cam1_data1.I2C2_SCL >; }; spi2_pins: spi2_pins { pinctrl-single,pins = < AM4372_IOPAD(0x9bc, PIN_OUTPUT | MUX_MODE4) // (AD17) cam0_wen.spi2_d0 AM4372_IOPAD(0x9dc, PIN_OUTPUT | MUX_MODE4) // (AE21) cam1_pclk.spi2_sclk AM4372_IOPAD(0x9e0, PIN_OUTPUT | MUX_MODE4) // (AC25) cam1_field.spi2_cs1 AM4372_IOPAD(0x9e4, PIN_OUTPUT | MUX_MODE4) // (AB25) cam1_wen.spi2_d1 >; }; spi4_pins: spi4_pins { pinctrl-single,pins = < AM4372_IOPAD(0xa50, PIN_OUTPUT | MUX_MODE0) // (P25) spi4_sclk.spi4_sclk AM4372_IOPAD(0xa54, PIN_OUTPUT | MUX_MODE0) // (R24) spi4_d0.spi4_d0 AM4372_IOPAD(0xa58, PIN_OUTPUT | MUX_MODE0) // (P24) spi4_d1.spi4_d1 AM4372_IOPAD(0xa5c, PIN_OUTPUT | MUX_MODE0) // (N25) spi4_cs0.spi4_cs0 >; }; mmc0_pins: pinmux_mmc0_pins { pinctrl-single,pins = < AM4372_IOPAD(0x900, PIN_INPUT | MUX_MODE0) // (D1) mmc0_clk.mmc0_clk AM4372_IOPAD(0x904, PIN_INPUT | MUX_MODE0) // (D2) mmc0_cmd.mmc0_cmd AM4372_IOPAD(0x8fc, PIN_INPUT | MUX_MODE0) // (C1) mmc0_dat0.mmc0_dat0 AM4372_IOPAD(0x8f8, PIN_INPUT | MUX_MODE0) // (C2) mmc0_dat1.mmc0_dat1 AM4372_IOPAD(0x8f4, PIN_INPUT | MUX_MODE0) // (B2) mmc0_dat2.mmc0_dat2 AM4372_IOPAD(0x8f0, PIN_INPUT | MUX_MODE0) // (B1) mmc0_dat3.mmc0_dat3 AM4372_IOPAD(0x960, PIN_INPUT | MUX_MODE7) // (R25) spi0_cs1.mmc0_sdcd >; }; mmc1_pins: pinmux_mmc1_pins { pinctrl-single,pins = < AM4372_IOPAD(0x880, PIN_INPUT_PULLUP | MUX_MODE2) // (B9) gpmc_csn1.mmc1_clk AM4372_IOPAD(0x884, PIN_INPUT_PULLUP | MUX_MODE2) // (F10) gpmc_csn2.mmc1_cmd AM4372_IOPAD(0x820, PIN_INPUT_PULLUP | MUX_MODE2) // (B10) gpmc_ad8.mmc1_dat0 AM4372_IOPAD(0x824, PIN_INPUT_PULLUP | MUX_MODE2) // (A10) gpmc_ad9.mmc1_dat1 AM4372_IOPAD(0x828, PIN_INPUT_PULLUP | MUX_MODE2) // (F11) gpmc_ad10.mmc1_dat2 AM4372_IOPAD(0x82c, PIN_INPUT_PULLUP | MUX_MODE2) // (D11) gpmc_ad11.mmc1_dat3 AM4372_IOPAD(0x830, PIN_INPUT_PULLUP | MUX_MODE2) // (E11) gpmc_ad12.mmc1_dat4 AM4372_IOPAD(0x834, PIN_INPUT_PULLUP | MUX_MODE2) // (C11) gpmc_ad13.mmc1_dat5 AM4372_IOPAD(0x838, PIN_INPUT_PULLUP | MUX_MODE2) // (B11) gpmc_ad14.mmc1_dat6 AM4372_IOPAD(0x83c, PIN_INPUT_PULLUP | MUX_MODE2) // (A11) gpmc_ad15.mmc1_dat7 >; }; mmc2_pins: mmc2_pins { // WiFi SDIO pinctrl-single,pins = < AM4372_IOPAD(0x9f0, PIN_INPUT | MUX_MODE3) // (AD21) cam1_data2.mmc2_clk AM4372_IOPAD(0x9f4, PIN_INPUT | MUX_MODE3) // (AE22) cam1_data3.mmc2_cmd AM4372_IOPAD(0x9f8, PIN_INPUT | MUX_MODE3) // (AD22) cam1_data4.mmc2_dat0 AM4372_IOPAD(0x9fc, PIN_INPUT | MUX_MODE3) // (AE23) cam1_data5.mmc2_dat1 AM4372_IOPAD(0xa00, PIN_INPUT | MUX_MODE3) // (AD23) cam1_data6.mmc2_dat2 AM4372_IOPAD(0xa04, PIN_INPUT | MUX_MODE3) // (AE24) cam1_data7.mmc2_dat3 >; }; davinci_mdio_default: davinci_mdio_default { pinctrl-single,pins = < // MDIO AM4372_IOPAD(0x948, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) // (A17) mdio_data.mdio_data AM4372_IOPAD(0x94c, PIN_OUTPUT_PULLUP | MUX_MODE0) // (B17) mdio_clk.mdio_clk >; }; davinci_mdio_sleep: davinci_mdio_sleep { pinctrl-single,pins = < // MDIO AM4372_IOPAD(0x948, PIN_INPUT_PULLDOWN | MUX_MODE7) // mdio_data.mdio_data AM4372_IOPAD(0x94c, PIN_INPUT_PULLDOWN | MUX_MODE7) // mdio_clk.mdio_clk >; }; uart0_pins_default: uart0_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x970, PIN_INPUT_PULLUP | MUX_MODE0) // (K25) uart0_rxd.uart0_rxd AM4372_IOPAD(0x974, PIN_OUTPUT | MUX_MODE0) // (J24) uart0_txd.uart0_txd AM4372_IOPAD(0x9cc, PIN_INPUT_PULLDOWN | MUX_MODE8) // (AC24) cam1_data9.uart0_ctsn AM4372_IOPAD(0x9d0, PIN_OUTPUT_PULLDOWN | MUX_MODE8) // (AD24) cam1_data8.uart0_rtsn >; }; uart1_pins_default: uart1_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x980, PIN_INPUT | MUX_MODE0) // (K21) uart1_rxd.uart1_rxd AM4372_IOPAD(0x984, PIN_OUTPUT | MUX_MODE0) // (L21) uart1_txd.uart1_txd >; }; uart2_pins_default: uart2_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x950, PIN_INPUT | MUX_MODE1) // (P23) spi0_sclk.uart2_rxd AM4372_IOPAD(0x954, PIN_OUTPUT | MUX_MODE1) // (T22) spi0_d0.uart2_txd AM4372_IOPAD(0x988, PIN_INPUT | MUX_MODE2) // (AB24) I2C0_SDA.uart2_ctsn AM4372_IOPAD(0x98c, PIN_OUTPUT | MUX_MODE2) // (Y22) I2C0_SCL.uart2_rtsn >; }; uart3_pins_default: uart3_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0xa28, PIN_INPUT | MUX_MODE0) // (H25) uart3_rxd.uart3_rxd AM4372_IOPAD(0xa2c, PIN_OUTPUT | MUX_MODE0) // (H24) uart3_txd.uart3_txd AM4372_IOPAD(0xa30, PIN_INPUT | MUX_MODE0) // (H22) uart3_ctsn.uart3_ctsn AM4372_IOPAD(0xa34, PIN_OUTPUT | MUX_MODE0) // (K24) uart3_rtsn.uart3_rtsn >; }; uart4_pins_default: uart4_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x968, PIN_INPUT | MUX_MODE1) // (L25) uart0_ctsn.uart4_rxd AM4372_IOPAD(0x96c, PIN_OUTPUT | MUX_MODE1) // (J25) uart0_rtsn.uart4_txd >; }; mii1_pins_default: mii1_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x908, PIN_INPUT | MUX_MODE0) // (D16) mii1_col.gmii1_col AM4372_IOPAD(0x90c, PIN_INPUT | MUX_MODE0) // (B14) mii1_crs.gmii1_crs AM4372_IOPAD(0x910, PIN_INPUT | MUX_MODE0) // (B13) mii1_rx_er.gmii1_rxer AM4372_IOPAD(0x914, PIN_OUTPUT | MUX_MODE0) // (A13) mii1_tx_en.gmii1_txen AM4372_IOPAD(0x918, PIN_INPUT | MUX_MODE0) // (A15) mii1_rx_dv.gmii1_rxdv AM4372_IOPAD(0x92c, PIN_INPUT | MUX_MODE0) // (D14) mii1_tx_clk.gmii1_txclk AM4372_IOPAD(0x930, PIN_INPUT | MUX_MODE0) // (D13) mii1_rx_clk.gmii1_rxclk AM4372_IOPAD(0x928, PIN_OUTPUT | MUX_MODE0) // (B15) mii1_txd0.gmii1_txd0 AM4372_IOPAD(0x924, PIN_OUTPUT | MUX_MODE0) // (A14) mii1_txd1.gmii1_txd1 AM4372_IOPAD(0x920, PIN_OUTPUT | MUX_MODE0) // (C13) mii1_txd2.gmii1_txd2 AM4372_IOPAD(0x91c, PIN_OUTPUT | MUX_MODE0) // (C16) mii1_txd3.gmii1_txd3 AM4372_IOPAD(0x940, PIN_INPUT | MUX_MODE0) // (F17) mii1_rxd0.gmii1_rxd0 AM4372_IOPAD(0x93c, PIN_INPUT | MUX_MODE0) // (B16) mii1_rxd1.gmii1_rxd1 AM4372_IOPAD(0x938, PIN_INPUT | MUX_MODE0) // (E16) mii1_rxd2.gmii1_rxd2 AM4372_IOPAD(0x934, PIN_INPUT | MUX_MODE0) // (C14) mii1_rxd3.gmii1_rxd3 >; }; mii1_pins_sleep: mii1_pins_sleep { pinctrl-single,pins = < AM4372_IOPAD(0x908, PIN_INPUT | MUX_MODE0) // (D16) mii1_col.gmii1_col AM4372_IOPAD(0x90c, PIN_INPUT | MUX_MODE0) // (B14) mii1_crs.gmii1_crs AM4372_IOPAD(0x910, PIN_INPUT | MUX_MODE0) // (B13) mii1_rx_er.gmii1_rxer AM4372_IOPAD(0x914, PIN_OUTPUT | MUX_MODE0) // (A13) mii1_tx_en.gmii1_txen AM4372_IOPAD(0x918, PIN_INPUT | MUX_MODE0) // (A15) mii1_rx_dv.gmii1_rxdv AM4372_IOPAD(0x92c, PIN_INPUT | MUX_MODE0) // (D14) mii1_tx_clk.gmii1_txclk AM4372_IOPAD(0x930, PIN_INPUT | MUX_MODE0) // (D13) mii1_rx_clk.gmii1_rxclk AM4372_IOPAD(0x928, PIN_OUTPUT | MUX_MODE0) // (B15) mii1_txd0.gmii1_txd0 AM4372_IOPAD(0x924, PIN_OUTPUT | MUX_MODE0) // (A14) mii1_txd1.gmii1_txd1 AM4372_IOPAD(0x920, PIN_OUTPUT | MUX_MODE0) // (C13) mii1_txd2.gmii1_txd2 AM4372_IOPAD(0x91c, PIN_OUTPUT | MUX_MODE0) // (C16) mii1_txd3.gmii1_txd3 AM4372_IOPAD(0x940, PIN_INPUT | MUX_MODE0) // (F17) mii1_rxd0.gmii1_rxd0 AM4372_IOPAD(0x93c, PIN_INPUT | MUX_MODE0) // (B16) mii1_rxd1.gmii1_rxd1 AM4372_IOPAD(0x938, PIN_INPUT | MUX_MODE0) // (E16) mii1_rxd2.gmii1_rxd2 AM4372_IOPAD(0x934, PIN_INPUT | MUX_MODE0) // (C14) mii1_rxd3.gmii1_rxd3 >; }; dcan0_pins_default: dcan0_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x978, PIN_OUTPUT | MUX_MODE2) // K22 dcan0_tx P7 pin AM4372_IOPAD(0x97c, PIN_INPUT | MUX_MODE2) // L22 dcan0_rx P7 pin >; }; gpio0_pins: gpio0_pins { pinctrl-single,pins = < AM4372_IOPAD(0x958, PIN_OUTPUT_PULLUP | MUX_MODE7) // (T21) spi0_d1.gpio0[4] - GSM VCC AM4372_IOPAD(0xa64, PIN_OUTPUT_PULLDOWN | MUX_MODE9) // (P22) spi2_d0.gpio0[20] - GSM reset AM4372_IOPAD(0xa6c, PIN_OUTPUT_PULLDOWN | MUX_MODE9) // (T23) spi2_cs0.gpio0[23] - GSM power >; }; gpio1_pins: gpio1_pins { pinctrl-single,pins = < AM4372_IOPAD(0x800, PIN_OUTPUT | MUX_MODE7) // (B5) gpmc_ad0.gpio1[0] - Generic AM4372_IOPAD(0x804, PIN_OUTPUT_PULLUP | MUX_MODE7) // (A5) gpmc_ad1.gpio1[1] - Audio reset AM4372_IOPAD(0x814, PIN_OUTPUT | MUX_MODE7) // (A7) gpmc_ad5.gpio1[5] - Generic AM4372_IOPAD(0x818, PIN_OUTPUT | MUX_MODE7) // (C8) gpmc_ad6.gpio1[6] - Generic AM4372_IOPAD(0x81c, PIN_OUTPUT | MUX_MODE7) // (B8) gpmc_ad7.gpio1[7] - Generic AM4372_IOPAD(0x840, PIN_OUTPUT | MUX_MODE7) // (C3) gpmc_a0.gpio1[16] - Generic AM4372_IOPAD(0x858, PIN_OUTPUT | MUX_MODE7) // (E8) gpmc_a6.gpio1[22] - ZB backdoor 2 AM4372_IOPAD(0x864, PIN_OUTPUT | MUX_MODE7) // (B4) gpmc_a9.gpio1[25] - Generic AM4372_IOPAD(0x86c, PIN_OUTPUT | MUX_MODE7) // (D8) gpmc_a11.gpio1[27] - ZB backdoor 1 AM4372_IOPAD(0x87c, PIN_OUTPUT | MUX_MODE7) // (A8) gpmc_csn0.gpio1[29] - Generic >; }; gpio2_pins: gpio2_pins { pinctrl-single,pins = < AM4372_IOPAD(0x890, PIN_OUTPUT | MUX_MODE7) // (A9) gpmc_advn_ale.gpio2[2] - Generic AM4372_IOPAD(0x894, PIN_OUTPUT_PULLUP | MUX_MODE7) // (E10) gpmc_oen_ren.gpio2[3] - LAN reset >; }; gpio3_pins: gpio3_pins { pinctrl-single,pins = < AM4372_IOPAD(0xa68, PIN_OUTPUT_PULLUP | MUX_MODE7) // (P20) spi2_d1.gpio3[23] - ZB reset >; }; gpio4_pins: gpio4_pins { pinctrl-single,pins = < AM4372_IOPAD(0x9d4, PIN_INPUT | MUX_MODE7) // (AD25) cam1_hd.gpio4[9] - GSM sense >; }; gpio5_pins: gpio5_pins { pinctrl-single,pins = < AM4372_IOPAD(0xa44, PIN_OUTPUT_PULLUP | MUX_MODE7) // (F23) gpio5_11.gpio5[11] - Reset Mikrobus AM4372_IOPAD(0xa48, PIN_OUTPUT_PULLUP | MUX_MODE7) // (E25) gpio5_12.gpio5[12] - IRQ Mikrobus AM4372_IOPAD(0xa4c, PIN_INPUT | MUX_MODE7) // (E24) gpio5_13.gpio5[13] - Push button >; }; leds_pins: leds_pins { pinctrl-single,pins = < AM4372_IOPAD(0xa38, PIN_OUTPUT_PULLDOWN | MUX_MODE7) // (D25) gpio5_8.gpio5[8] - green AM4372_IOPAD(0x99c, PIN_OUTPUT_PULLDOWN | MUX_MODE7) // (M24) mcasp0_ahclkr.gpio3[17] - red AM4372_IOPAD(0x964, PIN_OUTPUT_PULLDOWN | MUX_MODE7) // (G24) eCAP0_in_PWM0_out.gpio0[7] - blue >; }; mcasp0_pins: mcasp0_pins { pinctrl-single,pins = < AM4372_IOPAD(0x990, PIN_INPUT | MUX_MODE0) // (N24) mcasp0_aclkx.mcasp0_aclkx AM4372_IOPAD(0x994, PIN_INPUT | MUX_MODE0) // (N22) mcasp0_fsx.mcasp0_fsx AM4372_IOPAD(0x9a0, PIN_INPUT | MUX_MODE2) // (L23) mcasp0_aclkr.mcasp0_axr2 AM4372_IOPAD(0x9a4, PIN_INPUT | MUX_MODE2) // (K23) mcasp0_fsr.mcasp0_axr3 >; }; wlan_pins: pinmux_wlan_pins { pinctrl-single,pins = < AM4372_IOPAD(0x9b8, PIN_INPUT | MUX_MODE7) // (AC18) cam0_field.gpio4[2] - IRQ WiFi AM4372_IOPAD(0x9c4, PIN_OUTPUT_PULLUP | MUX_MODE7) // (AB19) cam0_data8.gpio4[5] - WiFi enable >; }; }; &uart0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_default>; }; &uart1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart1_pins_default>; }; &uart2 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart2_pins_default>; }; &uart3 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart3_pins_default>; }; &uart4 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart4_pins_default>; }; &i2c2 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c2_pins>; clock-frequency = <100000>; tps65218: tps65218@24 { reg = <0x24>; compatible = "ti,tps65218"; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; interrupt-controller; #interrupt-cells = <2>; dcdc1: regulator-dcdc1 { regulator-name = "vdd_core"; regulator-min-microvolt = <912000>; regulator-max-microvolt = <1144000>; regulator-boot-on; regulator-always-on; }; dcdc2: regulator-dcdc2 { regulator-name = "vdd_mpu"; regulator-min-microvolt = <912000>; regulator-max-microvolt = <1378000>; regulator-boot-on; regulator-always-on; }; dcdc3: regulator-dcdc3 { regulator-name = "vdcdc3"; regulator-min-microvolt = <1350000>; regulator-max-microvolt = <1350000>; regulator-boot-on; regulator-always-on; }; dcdc4: regulator-dcdc4 { regulator-name = "vdcdc4"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-boot-on; regulator-always-on; }; dcdc5: regulator-dcdc5 { regulator-name = "v1_0bat"; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; }; dcdc6: regulator-dcdc6 { regulator-name = "v1_8bat"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; }; ldo1: regulator-ldo1 { regulator-min-microvolt = <2100000>; regulator-max-microvolt = <2100000>; regulator-boot-on; regulator-always-on; }; }; }; &i2c1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins>; }; &epwmss0 { status = "okay"; }; &tscadc { status = "okay"; adc { ti,adc-channels = <0 1 2 3 4 5 6 7>; }; }; &gpio0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&gpio0_pins>; }; &gpio1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&gpio1_pins>; }; &gpio2 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&gpio2_pins>; }; &gpio3 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&gpio3_pins>; }; &gpio4 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&gpio4_pins>; }; &gpio5 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&gpio5_pins>; }; &mmc1 { status = "okay"; vmmc-supply = <&dcdc4>; bus-width = <4>; pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; //broken-cd; }; &mmc2 { status = "okay"; vmmc-supply = <&dcdc4>; bus-width = <8>; pinctrl-names = "default"; pinctrl-0 = <&mmc1_pins>; ti,non-removable; }; &mmc3 { dmas = <&edma_xbar 30 0 1>, <&edma_xbar 31 0 2>; dma-names = "tx", "rx"; status = "okay"; vmmc-supply = <&wlan_en_reg>; bus-width = <4>; pinctrl-names = "default"; pinctrl-0 = <&mmc2_pins &wlan_pins>; ti,non-removable; ti,needs-special-hs-handling; cap-power-off-card; keep-power-in-suspend; max-frequency = <30000000>; #address-cells = <1>; #size-cells = <0>; wlcore: wlcore@0 { compatible = "ti,wl1835"; reg = <2>; interrupt-parent = <&gpio4>; interrupts = <2 IRQ_TYPE_EDGE_RISING>; }; }; &usb2_phy1 { status = "okay"; }; &usb1 { dr_mode = "host"; status = "okay"; }; &usb2_phy2 { status = "okay"; }; &usb2 { dr_mode = "host"; status = "okay"; }; &mac_sw { slaves = <1>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&mii1_pins_default>; pinctrl-1 = <&mii1_pins_sleep>; status = "okay"; }; &davinci_mdio_sw { pinctrl-names = "default", "sleep"; pinctrl-0 = <&davinci_mdio_default>; pinctrl-1 = <&davinci_mdio_sleep>; ethphy0: ethernet-phy@0 { reg = <0>; }; }; &cpsw_port1 { phy-handle = <ðphy0>; phy-mode = "mii"; ti,dual-emac-pvid = <1>; }; &elm { status = "okay"; }; &rtc { clocks = <&clk_32k_rtc>, <&clk_32768_ck>; clock-names = "ext-clk", "int-clk"; status = "okay"; }; &cpu { cpu0-supply = <&dcdc2>; }; &dcan0{ status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&dcan0_pins_default>; }; &spi2 { #address-cells = <1>; #size-cells = <0>; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&spi2_pins>; }; &spi4 { #address-cells = <1>; #size-cells = <0>; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&spi4_pins>; };
/* * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ * Copyright (C) 2020 SMaBiT GmbH - http://www.smabit.eu * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. */ /* AM437x SMAWAY */ /dts-v1/; #include "am4372.dtsi" #include <dt-bindings/pinctrl/am43xx.h> #include <dt-bindings/pwm/pwm.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/irq.h> / { model = "SMaBiT SMaWay"; compatible = "ti,am437x-gp-evm","ti,am4372","ti,am43","smabit,smaway"; aliases { }; chosen { stdout-path = &uart4; }; leds { compatible = "gpio-leds"; pinctrl-names = "default"; pinctrl-0 = <&leds_pins>; led0 { label = "am437x-smaway:red:led0"; gpios = <&gpio3 17 GPIO_ACTIVE_HIGH>; default-state = "off"; }; led1 { label = "am437x-smaway:blue:led1"; gpios = <&gpio5 8 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; default-state = "off"; }; led2 { label = "am437x-smaway:green:led2"; gpios = <&gpio0 7 GPIO_ACTIVE_HIGH>; default-state = "off"; }; }; // fixed 12MHz oscillator refclk: oscillator { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <12000000>; }; // fixed 32k external oscillator clock clk_32k_rtc: clk_32k_rtc { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <32768>; }; sound { compatible = "simple-audio-card"; simple-audio-card,name = "SMaWay Audio"; simple-audio-card,widgets = "Headphone", "Headphone Jack", "Line", "Line In"; simple-audio-card,routing = "Headphone Jack", "HPLOUT", "Headphone Jack", "HPROUT", "LINE1L", "Line In", "LINE1R", "Line In"; simple-audio-card,format = "dsp_b"; simple-audio-card,bitclock-master = <&sound_master>; simple-audio-card,frame-master = <&sound_master>; simple-audio-card,bitclock-inversion; simple-audio-card,cpu { sound-dai = <&mcasp1>; }; sound_master: simple-audio-card,codec { sound-dai = <&tlv320aic3x>; system-clock-frequency = <12000000>; }; }; wlan_en_reg: fixedregulator-mmcwl { compatible = "regulator-fixed"; regulator-name = "vmmcwl_fixed"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; /* WLAN_EN GPIO */ gpio = <&gpio4 5 GPIO_ACTIVE_HIGH>; /* WLAN card specific delay */ startup-delay-us = <70000>; enable-active-high; }; }; &am43xx_pinmux { pinctrl-names = "default", "sleep"; i2c1_pins: i2c1_pins { pinctrl-single,pins = < AM4372_IOPAD(0xa08, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3) // (AE18) cam0_data0.I2C1_SDA AM4372_IOPAD(0xa0c, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3) // (AB18) cam0_data1.I2C1_SCL >; }; i2c2_pins: i2c2_pins { pinctrl-single,pins = < AM4372_IOPAD(0x9e8, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3) // (AB20) cam1_data0.I2C2_SDA AM4372_IOPAD(0x9ec, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3) // (AC21) cam1_data1.I2C2_SCL >; }; spi2_pins: spi2_pins { pinctrl-single,pins = < AM4372_IOPAD(0x9bc, PIN_OUTPUT | MUX_MODE4) // (AD17) cam0_wen.spi2_d0 AM4372_IOPAD(0x9dc, PIN_OUTPUT | MUX_MODE4) // (AE21) cam1_pclk.spi2_sclk AM4372_IOPAD(0x9e0, PIN_OUTPUT | MUX_MODE4) // (AC25) cam1_field.spi2_cs1 AM4372_IOPAD(0x9e4, PIN_OUTPUT | MUX_MODE4) // (AB25) cam1_wen.spi2_d1 >; }; spi4_pins: spi4_pins { pinctrl-single,pins = < AM4372_IOPAD(0xa50, PIN_OUTPUT | MUX_MODE0) // (P25) spi4_sclk.spi4_sclk AM4372_IOPAD(0xa54, PIN_OUTPUT | MUX_MODE0) // (R24) spi4_d0.spi4_d0 AM4372_IOPAD(0xa58, PIN_OUTPUT | MUX_MODE0) // (P24) spi4_d1.spi4_d1 AM4372_IOPAD(0xa5c, PIN_OUTPUT | MUX_MODE0) // (N25) spi4_cs0.spi4_cs0 >; }; mmc0_pins: pinmux_mmc0_pins { pinctrl-single,pins = < AM4372_IOPAD(0x900, PIN_INPUT | MUX_MODE0) // (D1) mmc0_clk.mmc0_clk AM4372_IOPAD(0x904, PIN_INPUT | MUX_MODE0) // (D2) mmc0_cmd.mmc0_cmd AM4372_IOPAD(0x8fc, PIN_INPUT | MUX_MODE0) // (C1) mmc0_dat0.mmc0_dat0 AM4372_IOPAD(0x8f8, PIN_INPUT | MUX_MODE0) // (C2) mmc0_dat1.mmc0_dat1 AM4372_IOPAD(0x8f4, PIN_INPUT | MUX_MODE0) // (B2) mmc0_dat2.mmc0_dat2 AM4372_IOPAD(0x8f0, PIN_INPUT | MUX_MODE0) // (B1) mmc0_dat3.mmc0_dat3 AM4372_IOPAD(0x960, PIN_INPUT | MUX_MODE7) // (R25) spi0_cs1.mmc0_sdcd >; }; mmc1_pins: pinmux_mmc1_pins { pinctrl-single,pins = < AM4372_IOPAD(0x880, PIN_INPUT_PULLUP | MUX_MODE2) // (B9) gpmc_csn1.mmc1_clk AM4372_IOPAD(0x884, PIN_INPUT_PULLUP | MUX_MODE2) // (F10) gpmc_csn2.mmc1_cmd AM4372_IOPAD(0x820, PIN_INPUT_PULLUP | MUX_MODE2) // (B10) gpmc_ad8.mmc1_dat0 AM4372_IOPAD(0x824, PIN_INPUT_PULLUP | MUX_MODE2) // (A10) gpmc_ad9.mmc1_dat1 AM4372_IOPAD(0x828, PIN_INPUT_PULLUP | MUX_MODE2) // (F11) gpmc_ad10.mmc1_dat2 AM4372_IOPAD(0x82c, PIN_INPUT_PULLUP | MUX_MODE2) // (D11) gpmc_ad11.mmc1_dat3 AM4372_IOPAD(0x830, PIN_INPUT_PULLUP | MUX_MODE2) // (E11) gpmc_ad12.mmc1_dat4 AM4372_IOPAD(0x834, PIN_INPUT_PULLUP | MUX_MODE2) // (C11) gpmc_ad13.mmc1_dat5 AM4372_IOPAD(0x838, PIN_INPUT_PULLUP | MUX_MODE2) // (B11) gpmc_ad14.mmc1_dat6 AM4372_IOPAD(0x83c, PIN_INPUT_PULLUP | MUX_MODE2) // (A11) gpmc_ad15.mmc1_dat7 >; }; mmc2_pins: mmc2_pins { // WiFi SDIO pinctrl-single,pins = < AM4372_IOPAD(0x9f0, PIN_INPUT | MUX_MODE3) // (AD21) cam1_data2.mmc2_clk AM4372_IOPAD(0x9f4, PIN_INPUT | MUX_MODE3) // (AE22) cam1_data3.mmc2_cmd AM4372_IOPAD(0x9f8, PIN_INPUT | MUX_MODE3) // (AD22) cam1_data4.mmc2_dat0 AM4372_IOPAD(0x9fc, PIN_INPUT | MUX_MODE3) // (AE23) cam1_data5.mmc2_dat1 AM4372_IOPAD(0xa00, PIN_INPUT | MUX_MODE3) // (AD23) cam1_data6.mmc2_dat2 AM4372_IOPAD(0xa04, PIN_INPUT | MUX_MODE3) // (AE24) cam1_data7.mmc2_dat3 >; }; davinci_mdio_default: davinci_mdio_default { pinctrl-single,pins = < // MDIO AM4372_IOPAD(0x948, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) // (A17) mdio_data.mdio_data AM4372_IOPAD(0x94c, PIN_OUTPUT_PULLUP | MUX_MODE0) // (B17) mdio_clk.mdio_clk >; }; davinci_mdio_sleep: davinci_mdio_sleep { pinctrl-single,pins = < // MDIO AM4372_IOPAD(0x948, PIN_INPUT_PULLDOWN | MUX_MODE7) // mdio_data.mdio_data AM4372_IOPAD(0x94c, PIN_INPUT_PULLDOWN | MUX_MODE7) // mdio_clk.mdio_clk >; }; uart0_pins_default: uart0_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x970, PIN_INPUT_PULLUP | MUX_MODE0) // (K25) uart0_rxd.uart0_rxd AM4372_IOPAD(0x974, PIN_OUTPUT | MUX_MODE0) // (J24) uart0_txd.uart0_txd AM4372_IOPAD(0x9cc, PIN_INPUT_PULLDOWN | MUX_MODE8) // (AC24) cam1_data9.uart0_ctsn AM4372_IOPAD(0x9d0, PIN_OUTPUT_PULLDOWN | MUX_MODE8) // (AD24) cam1_data8.uart0_rtsn >; }; uart1_pins_default: uart1_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x980, PIN_INPUT | MUX_MODE0) // (K21) uart1_rxd.uart1_rxd AM4372_IOPAD(0x984, PIN_OUTPUT | MUX_MODE0) // (L21) uart1_txd.uart1_txd >; }; uart2_pins_default: uart2_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x950, PIN_INPUT | MUX_MODE1) // (P23) spi0_sclk.uart2_rxd AM4372_IOPAD(0x954, PIN_OUTPUT | MUX_MODE1) // (T22) spi0_d0.uart2_txd AM4372_IOPAD(0x988, PIN_INPUT | MUX_MODE2) // (AB24) I2C0_SDA.uart2_ctsn AM4372_IOPAD(0x98c, PIN_OUTPUT | MUX_MODE2) // (Y22) I2C0_SCL.uart2_rtsn >; }; uart3_pins_default: uart3_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0xa28, PIN_INPUT | MUX_MODE0) // (H25) uart3_rxd.uart3_rxd AM4372_IOPAD(0xa2c, PIN_OUTPUT | MUX_MODE0) // (H24) uart3_txd.uart3_txd AM4372_IOPAD(0xa30, PIN_INPUT | MUX_MODE0) // (H22) uart3_ctsn.uart3_ctsn AM4372_IOPAD(0xa34, PIN_OUTPUT | MUX_MODE0) // (K24) uart3_rtsn.uart3_rtsn >; }; uart4_pins_default: uart4_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x968, PIN_INPUT | MUX_MODE1) // (L25) uart0_ctsn.uart4_rxd AM4372_IOPAD(0x96c, PIN_OUTPUT | MUX_MODE1) // (J25) uart0_rtsn.uart4_txd >; }; mii1_pins_default: mii1_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x908, PIN_INPUT | MUX_MODE0) // (D16) mii1_col.gmii1_col AM4372_IOPAD(0x90c, PIN_INPUT | MUX_MODE0) // (B14) mii1_crs.gmii1_crs AM4372_IOPAD(0x910, PIN_INPUT | MUX_MODE0) // (B13) mii1_rx_er.gmii1_rxer AM4372_IOPAD(0x914, PIN_OUTPUT | MUX_MODE0) // (A13) mii1_tx_en.gmii1_txen AM4372_IOPAD(0x918, PIN_INPUT | MUX_MODE0) // (A15) mii1_rx_dv.gmii1_rxdv AM4372_IOPAD(0x92c, PIN_INPUT | MUX_MODE0) // (D14) mii1_tx_clk.gmii1_txclk AM4372_IOPAD(0x930, PIN_INPUT | MUX_MODE0) // (D13) mii1_rx_clk.gmii1_rxclk AM4372_IOPAD(0x928, PIN_OUTPUT | MUX_MODE0) // (B15) mii1_txd0.gmii1_txd0 AM4372_IOPAD(0x924, PIN_OUTPUT | MUX_MODE0) // (A14) mii1_txd1.gmii1_txd1 AM4372_IOPAD(0x920, PIN_OUTPUT | MUX_MODE0) // (C13) mii1_txd2.gmii1_txd2 AM4372_IOPAD(0x91c, PIN_OUTPUT | MUX_MODE0) // (C16) mii1_txd3.gmii1_txd3 AM4372_IOPAD(0x940, PIN_INPUT | MUX_MODE0) // (F17) mii1_rxd0.gmii1_rxd0 AM4372_IOPAD(0x93c, PIN_INPUT | MUX_MODE0) // (B16) mii1_rxd1.gmii1_rxd1 AM4372_IOPAD(0x938, PIN_INPUT | MUX_MODE0) // (E16) mii1_rxd2.gmii1_rxd2 AM4372_IOPAD(0x934, PIN_INPUT | MUX_MODE0) // (C14) mii1_rxd3.gmii1_rxd3 >; }; mii1_pins_sleep: mii1_pins_sleep { pinctrl-single,pins = < AM4372_IOPAD(0x908, PIN_INPUT | MUX_MODE0) // (D16) mii1_col.gmii1_col AM4372_IOPAD(0x90c, PIN_INPUT | MUX_MODE0) // (B14) mii1_crs.gmii1_crs AM4372_IOPAD(0x910, PIN_INPUT | MUX_MODE0) // (B13) mii1_rx_er.gmii1_rxer AM4372_IOPAD(0x914, PIN_OUTPUT | MUX_MODE0) // (A13) mii1_tx_en.gmii1_txen AM4372_IOPAD(0x918, PIN_INPUT | MUX_MODE0) // (A15) mii1_rx_dv.gmii1_rxdv AM4372_IOPAD(0x92c, PIN_INPUT | MUX_MODE0) // (D14) mii1_tx_clk.gmii1_txclk AM4372_IOPAD(0x930, PIN_INPUT | MUX_MODE0) // (D13) mii1_rx_clk.gmii1_rxclk AM4372_IOPAD(0x928, PIN_OUTPUT | MUX_MODE0) // (B15) mii1_txd0.gmii1_txd0 AM4372_IOPAD(0x924, PIN_OUTPUT | MUX_MODE0) // (A14) mii1_txd1.gmii1_txd1 AM4372_IOPAD(0x920, PIN_OUTPUT | MUX_MODE0) // (C13) mii1_txd2.gmii1_txd2 AM4372_IOPAD(0x91c, PIN_OUTPUT | MUX_MODE0) // (C16) mii1_txd3.gmii1_txd3 AM4372_IOPAD(0x940, PIN_INPUT | MUX_MODE0) // (F17) mii1_rxd0.gmii1_rxd0 AM4372_IOPAD(0x93c, PIN_INPUT | MUX_MODE0) // (B16) mii1_rxd1.gmii1_rxd1 AM4372_IOPAD(0x938, PIN_INPUT | MUX_MODE0) // (E16) mii1_rxd2.gmii1_rxd2 AM4372_IOPAD(0x934, PIN_INPUT | MUX_MODE0) // (C14) mii1_rxd3.gmii1_rxd3 >; }; dcan0_pins_default: dcan0_pins_default { pinctrl-single,pins = < AM4372_IOPAD(0x978, PIN_OUTPUT | MUX_MODE2) // K22 dcan0_tx P7 pin AM4372_IOPAD(0x97c, PIN_INPUT | MUX_MODE2) // L22 dcan0_rx P7 pin >; }; gpio0_pins: gpio0_pins { pinctrl-single,pins = < AM4372_IOPAD(0x958, PIN_OUTPUT_PULLUP | MUX_MODE7) // (T21) spi0_d1.gpio0[4] - GSM VCC AM4372_IOPAD(0xa64, PIN_OUTPUT_PULLDOWN | MUX_MODE9) // (P22) spi2_d0.gpio0[20] - GSM reset AM4372_IOPAD(0xa6c, PIN_OUTPUT_PULLDOWN | MUX_MODE9) // (T23) spi2_cs0.gpio0[23] - GSM power >; }; gpio1_pins: gpio1_pins { pinctrl-single,pins = < AM4372_IOPAD(0x800, PIN_OUTPUT | MUX_MODE7) // (B5) gpmc_ad0.gpio1[0] - Generic AM4372_IOPAD(0x804, PIN_OUTPUT_PULLUP | MUX_MODE7) // (A5) gpmc_ad1.gpio1[1] - Audio reset AM4372_IOPAD(0x814, PIN_OUTPUT | MUX_MODE7) // (A7) gpmc_ad5.gpio1[5] - Generic AM4372_IOPAD(0x818, PIN_OUTPUT | MUX_MODE7) // (C8) gpmc_ad6.gpio1[6] - Generic AM4372_IOPAD(0x81c, PIN_OUTPUT | MUX_MODE7) // (B8) gpmc_ad7.gpio1[7] - Generic AM4372_IOPAD(0x840, PIN_OUTPUT | MUX_MODE7) // (C3) gpmc_a0.gpio1[16] - Generic AM4372_IOPAD(0x858, PIN_OUTPUT | MUX_MODE7) // (E8) gpmc_a6.gpio1[22] - ZB backdoor 2 AM4372_IOPAD(0x864, PIN_OUTPUT | MUX_MODE7) // (B4) gpmc_a9.gpio1[25] - Generic AM4372_IOPAD(0x86c, PIN_OUTPUT | MUX_MODE7) // (D8) gpmc_a11.gpio1[27] - ZB backdoor 1 AM4372_IOPAD(0x87c, PIN_OUTPUT | MUX_MODE7) // (A8) gpmc_csn0.gpio1[29] - Generic >; }; gpio2_pins: gpio2_pins { pinctrl-single,pins = < AM4372_IOPAD(0x890, PIN_OUTPUT | MUX_MODE7) // (A9) gpmc_advn_ale.gpio2[2] - Generic AM4372_IOPAD(0x894, PIN_OUTPUT_PULLUP | MUX_MODE7) // (E10) gpmc_oen_ren.gpio2[3] - LAN reset >; }; gpio3_pins: gpio3_pins { pinctrl-single,pins = < AM4372_IOPAD(0xa68, PIN_OUTPUT_PULLUP | MUX_MODE7) // (P20) spi2_d1.gpio3[23] - ZB reset >; }; gpio4_pins: gpio4_pins { pinctrl-single,pins = < AM4372_IOPAD(0x9d4, PIN_INPUT | MUX_MODE7) // (AD25) cam1_hd.gpio4[9] - GSM sense >; }; gpio5_pins: gpio5_pins { pinctrl-single,pins = < AM4372_IOPAD(0xa44, PIN_OUTPUT_PULLUP | MUX_MODE7) // (F23) gpio5_11.gpio5[11] - Reset Mikrobus AM4372_IOPAD(0xa48, PIN_OUTPUT_PULLUP | MUX_MODE7) // (E25) gpio5_12.gpio5[12] - IRQ Mikrobus AM4372_IOPAD(0xa4c, PIN_INPUT | MUX_MODE7) // (E24) gpio5_13.gpio5[13] - Push button >; }; leds_pins: leds_pins { pinctrl-single,pins = < AM4372_IOPAD(0xa38, PIN_OUTPUT_PULLDOWN | MUX_MODE7) // (D25) gpio5_8.gpio5[8] - green AM4372_IOPAD(0x99c, PIN_OUTPUT_PULLDOWN | MUX_MODE7) // (M24) mcasp0_ahclkr.gpio3[17] - red AM4372_IOPAD(0x964, PIN_OUTPUT_PULLDOWN | MUX_MODE7) // (G24) eCAP0_in_PWM0_out.gpio0[7] - blue >; }; mcasp0_pins: mcasp0_pins { pinctrl-single,pins = < AM4372_IOPAD(0x990, PIN_INPUT | MUX_MODE0) // (N24) mcasp0_aclkx.mcasp0_aclkx AM4372_IOPAD(0x994, PIN_INPUT | MUX_MODE0) // (N22) mcasp0_fsx.mcasp0_fsx AM4372_IOPAD(0x9a0, PIN_INPUT | MUX_MODE2) // (L23) mcasp0_aclkr.mcasp0_axr2 AM4372_IOPAD(0x9a4, PIN_INPUT | MUX_MODE2) // (K23) mcasp0_fsr.mcasp0_axr3 >; }; wlan_pins: pinmux_wlan_pins { pinctrl-single,pins = < AM4372_IOPAD(0x9b8, PIN_INPUT | MUX_MODE7) // (AC18) cam0_field.gpio4[2] - IRQ WiFi AM4372_IOPAD(0x9c4, PIN_OUTPUT_PULLUP | MUX_MODE7) // (AB19) cam0_data8.gpio4[5] - WiFi enable >; }; }; &uart0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_default>; }; &uart1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart1_pins_default>; }; &uart2 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart2_pins_default>; }; &uart3 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart3_pins_default>; }; &uart4 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart4_pins_default>; }; &i2c2 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c2_pins>; clock-frequency = <100000>; tps65218: tps65218@24 { reg = <0x24>; compatible = "ti,tps65218"; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; interrupt-controller; #interrupt-cells = <2>; dcdc1: regulator-dcdc1 { regulator-name = "vdd_core"; regulator-min-microvolt = <912000>; regulator-max-microvolt = <1144000>; regulator-boot-on; regulator-always-on; }; dcdc2: regulator-dcdc2 { regulator-name = "vdd_mpu"; regulator-min-microvolt = <912000>; regulator-max-microvolt = <1378000>; regulator-boot-on; regulator-always-on; }; dcdc3: regulator-dcdc3 { regulator-name = "vdcdc3"; regulator-min-microvolt = <1350000>; regulator-max-microvolt = <1350000>; regulator-boot-on; regulator-always-on; }; dcdc4: regulator-dcdc4 { regulator-name = "vdcdc4"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-boot-on; regulator-always-on; }; dcdc5: regulator-dcdc5 { regulator-name = "v1_0bat"; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; }; dcdc6: regulator-dcdc6 { regulator-name = "v1_8bat"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; }; ldo1: regulator-ldo1 { regulator-min-microvolt = <2100000>; regulator-max-microvolt = <2100000>; regulator-boot-on; regulator-always-on; }; }; }; &i2c1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins>; }; &epwmss0 { status = "okay"; }; &tscadc { status = "okay"; adc { ti,adc-channels = <0 1 2 3 4 5 6 7>; }; }; &gpio0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&gpio0_pins>; }; &gpio1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&gpio1_pins>; }; &gpio2 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&gpio2_pins>; }; &gpio3 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&gpio3_pins>; }; &gpio4 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&gpio4_pins>; }; &gpio5 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&gpio5_pins>; }; &mmc1 { status = "okay"; vmmc-supply = <&dcdc4>; bus-width = <4>; pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; //broken-cd; }; &mmc2 { status = "okay"; vmmc-supply = <&dcdc4>; bus-width = <8>; pinctrl-names = "default"; pinctrl-0 = <&mmc1_pins>; ti,non-removable; }; &mmc3 { dmas = <&edma_xbar 30 0 1>, <&edma_xbar 31 0 2>; dma-names = "tx", "rx"; status = "okay"; vmmc-supply = <&wlan_en_reg>; bus-width = <4>; pinctrl-names = "default"; pinctrl-0 = <&mmc2_pins &wlan_pins>; ti,non-removable; ti,needs-special-hs-handling; cap-power-off-card; keep-power-in-suspend; max-frequency = <30000000>; #address-cells = <1>; #size-cells = <0>; wlcore: wlcore@0 { compatible = "ti,wl1835"; reg = <2>; interrupt-parent = <&gpio4>; interrupts = <2 IRQ_TYPE_EDGE_RISING>; }; }; &usb2_phy1 { status = "okay"; }; &usb1 { dr_mode = "host"; status = "okay"; }; &usb2_phy2 { status = "okay"; }; &usb2 { dr_mode = "host"; status = "okay"; }; &mac { slaves = <1>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&mii1_pins_default>; pinctrl-1 = <&mii1_pins_sleep>; status = "okay"; }; &davinci_mdio { pinctrl-names = "default", "sleep"; pinctrl-0 = <&davinci_mdio_default>; pinctrl-1 = <&davinci_mdio_sleep>; status = "okay"; }; &cpsw_emac0 { phy_id = <&davinci_mdio>, <0>; phy-mode = "mii"; }; &elm { status = "okay"; }; &rtc { clocks = <&clk_32k_rtc>, <&clk_32768_ck>; clock-names = "ext-clk", "int-clk"; status = "okay"; }; &cpu { cpu0-supply = <&dcdc2>; }; &sgx { status = "okay"; }; &dcan0{ status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&dcan0_pins_default>; }; &spi2 { #address-cells = <1>; #size-cells = <0>; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&spi2_pins>; }; &spi4 { #address-cells = <1>; #size-cells = <0>; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&spi4_pins>; tlv320aic3x: codec@0 { compatible = "ti,tlv320aic3x"; reg = <0>; // CS number #sound-dai-cells = <0>; spi-max-frequency = <1000000>; AVDD-supply = <&dcdc4>; DRVDD-supply = <&dcdc4>; DVDD-supply = <&ldo1>; ai3x-ocmv = <0>; }; }; &mcasp0 { #sound-dai-cells = <0>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&mcasp0_pins>; status = "okay"; op-mode = <0>; /* MCASP_IIS_MODE */ tdm-slots = <2>; /* 4 serializers */ serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ 0 0 1 2 >; tx-num-evt = <32>; rx-num-evt = <32>; };
