[FAQ] TDA4VM: How to browse memory using CCS while running Linux
Part Number: TDA4VM
This FAQ explains how to browse memory using CCS memory browser while Linux is running on A72 without halting the A72 core.
  • Please follow the below steps to browse memory via CCS:
    1) Once Linux is booted launch the target configuration for your board.
    2) Right-click in the Debug window and select Show all cores
    3) Expand Non Debuggable Devices
    4) Double-click on your ccxml file, go to advance tab and check which of these DAP is attached to A72, for example it’s CS_DAP_0 in case of TDA4VM
    5) Connect to that DAP, CS_DAP_0 in this case
    6) Once it is connected, click on the memory browser and access the memory, you should be able to see the content
    Parth
