Other Parts Discussed in Thread: AM4372
I am migrating to newer kernel ver. 5.10 from 5.4. I am able to boot the board and get file system loaded and console working. However, the display is not coming up just the backlight is turned on.
On the console I am getting this error: Unable to find DSS platform device.
Below is Linux config for dss.
CONFIG_FB_OMAP2_DSS_INIT=y
CONFIG_FB_OMAP2_DSS=y
CONFIG_FB_OMAP2_DSS_DEBUG=y
# CONFIG_FB_OMAP2_DSS_DEBUGFS is not set
CONFIG_FB_OMAP2_DSS_DPI=y
# CONFIG_FB_OMAP2_DSS_VENC is not set
# CONFIG_FB_OMAP4_DSS_HDMI is not set
# CONFIG_FB_OMAP5_DSS_HDMI is not set
# CONFIG_FB_OMAP2_DSS_SDI is not set
# CONFIG_FB_OMAP2_DSS_DSI is not set
CONFIG_FB_OMAP2_DSS_MIN_FCK_PER_PCK=0
CONFIG_FB_OMAP2_DSS_SLEEP_AFTER_VENC_RESET=y
Please note. The display works properly with my older kernel ver.5.4.
Please help.
Thx,
Kiran.
Below is comparison snap showing some differences (Left: Kernel 5.10, Right Kernel 5.4 ) between lcd0 in dts file. Even the compatible strings are different. I had tried copying over older dts section for lcd0 but didn't worked out.
Attaching logs and dts files for reference.
U-Boot SPL 2017.01 (Aug 29 2022 - 18:47:12) Trying to boot from SPI No matching DT out of these options: tco_am437x_pascal U-Boot 2017.01 (Aug 29 2022 - 18:47:12 -0500) CPU : AM437X-GP rev 1.2 Model: TI AM437x GP EVM DRAM: 512 MiB PMIC: TPS65218 MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 reading uboot.env ** Unable to read "uboot.env" from mmc0:1 ** Using default environment Net: <ethaddr> not set. Validating first E-fuse MAC cpsw, usb_ether Hit any key to stop autoboot: 0 reading tco_fw_update.scr ** Unable to read file tco_fw_update.scr ** reading zImage 5241342 bytes read in 266 ms (18.8 MiB/s) Starting kernel ... U-Boot SPL 2017.01 (Aug 29 2022 - 18:47:12) Trying to boot from SPI No matching DT out of these options: tco_am437x_pascal U-Boot 2017.01 (Aug 29 2022 - 18:47:12 -0500) CPU : AM437X-GP rev 1.2 Model: TI AM437x GP EVM DRAM: 512 MiB PMIC: TPS65218 MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 reading uboot.env ** Unable to read "uboot.env" from mmc0:1 ** Using default environment Net: <ethaddr> not set. Validating first E-fuse MAC cpsw, usb_ether Hit any key to stop autoboot: 0 reading tco_fw_update.scr ** Unable to read file tco_fw_update.scr ** reading zImage 5241342 bytes read in 266 ms (18.8 MiB/s) Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.10.0 (ubuntu@ubuntu2004) (arm-buildroot-linux-gnueabihf-gcc.br_real (Buildroot -g481ecf3-dirty) 10.3.0, GNU ld (GNU Binutils) 2.36.1) #17 Wed Dec 14 15:30:36 IST 2022 [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: AM4 UI Board Rev A [ 0.000000] Memory policy: Data cache writeback [ 0.000000] cma: Reserved 24 MiB at 0x9e800000 [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000080000000-0x000000009fffffff] [ 0.000000] HighMem empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff] [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM437x ES1.2 (sgx neon) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 130048 [ 0.000000] Kernel command line: root=/dev/mmcblk0p2 console=ttyS0,115200 norootwait vram=16M omapfb.vram=0:8M,1:4M,2:4M vt.global_cursor_default=0 [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 482924K/524288K available (7168K kernel code, 421K rwdata, 2540K rodata, 1024K init, 232K bss, 16788K reserved, 24576K cma-reserved, 0K highmem) [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9 [ 0.000000] OMAP L2C310: ROM does not support power control setting [ 0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled [ 0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB [ 0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000 [ 0.000000] random: get_random_bytes called from start_kernel+0x30c/0x4b4 with crng_init=0 [ 0.000000] TI gptimer clocksource: always-on /ocp@44000000/interconnect@44c00000/segment@200000/target-module@31000 [ 0.000008] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000023] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000124] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000136] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000412] TI gptimer clockevent: 24000000 Hz at /ocp@44000000/interconnect@48000000/segment@0/target-module@40000 [ 0.001668] Console: colour dummy device 80x30 [ 0.001732] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896) [ 0.057752] pid_max: default: 32768 minimum: 301 [ 0.057853] LSM: Security Framework initializing [ 0.057935] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.057951] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.058630] CPU: Testing write buffer coherency: ok [ 0.058695] CPU0: Spectre v2: using BPIALL workaround [ 0.059237] Setting up static identity map for 0x80100000 - 0x80100060 [ 0.059752] devtmpfs: initialized [ 0.070298] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.070617] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.070640] futex hash table entries: 256 (order: -1, 3072 bytes, linear) [ 0.072007] pinctrl core: initialized pinctrl subsystem [ 0.073117] NET: Registered protocol family 16 [ 0.074616] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.080803] thermal_sys: Registered thermal governor 'fair_share' [ 0.080815] thermal_sys: Registered thermal governor 'step_wise' [ 0.080828] thermal_sys: Registered thermal governor 'user_space' [ 0.081190] cpuidle: using governor ladder [ 0.081203] cpuidle: using governor menu [ 0.871594] No ATAGs? [ 0.871627] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 0.871636] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.894434] iommu: Default domain type: Translated [ 0.895788] SCSI subsystem initialized [ 0.895988] usbcore: registered new interface driver usbfs [ 0.896037] usbcore: registered new interface driver hub [ 0.896120] usbcore: registered new device driver usb [ 0.896651] mc: Linux media interface: v0.10 [ 0.896690] videodev: Linux video capture interface: v2.00 [ 0.896747] pps_core: LinuxPPS API ver. 1 registered [ 0.896755] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.896777] PTP clock support registered [ 0.897799] clocksource: Switched to clocksource dmtimer [ 0.897989] VFS: Disk quotas dquot_6.6.0 [ 0.898067] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.904278] NET: Registered protocol family 2 [ 0.904861] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear) [ 0.904886] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear) [ 0.904920] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear) [ 0.904961] TCP: Hash tables configured (established 4096 bind 4096) [ 0.905086] UDP hash table entries: 256 (order: 0, 4096 bytes, linear) [ 0.905104] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear) [ 0.905230] NET: Registered protocol family 1 [ 0.905724] RPC: Registered named UNIX socket transport module. [ 0.905741] RPC: Registered udp transport module. [ 0.905747] RPC: Registered tcp transport module. [ 0.905753] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.907514] Unable to find DSS platform device [ 0.908757] workingset: timestamp_bits=30 max_order=17 bucket_order=0 [ 0.909479] NFS: Registering the id_resolver key type [ 0.909521] Key type id_resolver registered [ 0.909528] Key type id_legacy registered [ 0.984785] NET: Registered protocol family 38 [ 0.984817] io scheduler mq-deadline registered [ 0.984825] io scheduler kyber registered [ 1.289444] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 1.475179] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present! [ 1.475213] edma 49000000.dma: TI EDMA DMA engine driver [ 1.485022] pinctrl-single 44e10800.pinmux: 199 pins, size 796 [ 1.487426] panel-dpi display: failed to find video source [ 1.489073] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 1.491652] omap8250 44e09000.serial: No clock speed specified: using default: 48000000 [ 1.492122] printk: console [ttyS0] disabled [ 1.492200] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 56, base_baud = 3000000) is a 8250 [ 2.131322] printk: console [ttyS0] enabled [ 2.136316] omap8250 48022000.serial: No clock speed specified: using default: 48000000 [ 2.144904] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 61, base_baud = 3000000) is a 8250 [ 2.154305] omap8250 48024000.serial: No clock speed specified: using default: 48000000 [ 2.162836] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 62, base_baud = 3000000) is a 8250 [ 2.172240] omap8250 481a8000.serial: No clock speed specified: using default: 48000000 [ 2.180749] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 69, base_baud = 3000000) is a 8250 [ 2.191943] omap_rng 48310000.rng: Random Number Generator ver. 20 [ 2.198339] random: fast init done [ 2.201846] random: crng init done [ 2.215807] brd: module loaded [ 2.226880] loop: module loaded [ 2.240178] libphy: Fixed MDIO Bus: probed [ 2.244434] CAN device driver interface [ 2.258346] c_can_platform 481cc000.can: c_can_platform device registered (regs=d1bd652a, irq=72) [ 2.270499] tpm_tis_spi spi1.2: 2.0 TPM (device-id 0x1B, rev-id 22) [ 2.278031] c_can_platform 481d0000.can: c_can_platform device registered (regs=15407bd8, irq=73) [ 2.302626] tpm tpm0: A TPM error (256) occurred attempting the self test [ 2.309502] tpm tpm0: starting up the TPM manually [ 2.320955] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 2.326506] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 [ 2.340426] xhci-hcd xhci-hcd.2.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002010010 [ 2.358103] xhci-hcd xhci-hcd.2.auto: irq 91, io mem 0x483d0000 [ 2.365730] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 2.374062] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.381325] usb usb1: Product: xHCI Host Controller [ 2.386222] usb usb1: Manufacturer: Linux 5.10.0 xhci-hcd [ 2.391649] usb usb1: SerialNumber: xhci-hcd.2.auto [ 2.397282] hub 1-0:1.0: USB hub found [ 2.401605] hub 1-0:1.0: 1 port detected [ 2.406379] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 2.412413] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [ 2.420625] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed [ 2.427694] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 2.436363] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 2.444681] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.451942] usb usb2: Product: xHCI Host Controller [ 2.456838] usb usb2: Manufacturer: Linux 5.10.0 xhci-hcd [ 2.462265] usb usb2: SerialNumber: xhci-hcd.2.auto [ 2.468130] hub 2-0:1.0: USB hub found [ 2.472414] hub 2-0:1.0: 1 port detected [ 2.477316] usbcore: registered new interface driver usb-storage [ 2.485390] input: ti-tsc as /devices/platform/44000000.ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0d000.target-module/44e0d000.tscadc/TI-am335x-tsc.0.auto/input/input0 [ 2.504696] rtc-pcf2123 spi1.1: clock was stopped. Time is not valid [ 2.512474] rtc-pcf2123 spi1.1: spiclk 100 KHz. [ 2.518248] rtc-pcf2123 spi1.1: clock was stopped. Time is not valid [ 2.525299] rtc-pcf2123 spi1.1: registered as rtc0 [ 2.531323] rtc-pcf2123 spi1.1: clock was stopped. Time is not valid [ 2.537715] rtc-pcf2123 spi1.1: hctosys: unable to read the hardware clock [ 2.545181] i2c /dev entries driver [ 2.552494] sdhci: Secure Digital Host Controller Interface driver [ 2.558751] sdhci: Copyright(c) Pierre Ossman [ 2.563127] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.571154] ledtrig-cpu: registered to indicate activity on CPUs [ 2.578393] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator [ 2.588673] usbcore: registered new interface driver usbhid [ 2.594300] usbhid: USB HID core driver [ 2.599481] remoteproc remoteproc0: wkup_m3 is available [ 2.610771] remoteproc remoteproc0: powering up wkup_m3 [ 2.618416] Initializing XFRM netlink socket [ 2.623231] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA [ 2.631558] NET: Registered protocol family 17 [ 2.636687] remoteproc remoteproc0: Direct firmware load for am335x-pm-firmware.elf failed with error -2 [ 2.646836] NET: Registered protocol family 15 [ 2.652337] Bridge firewalling registered [ 2.656387] can: controller area network core [ 2.661290] remoteproc remoteproc0: request_firmware failed: -2 [ 2.667251] wkup_m3_ipc 44e11324.wkup_m3_ipc: rproc_boot failed [ 2.673758] NET: Registered protocol family 29 [ 2.678733] can: raw protocol [ 2.682337] can: broadcast manager protocol [ 2.687096] can: netlink gateway - max_hops=1 [ 2.692157] Key type dns_resolver registered [ 2.697648] oprofile: no performance counters [ 2.702705] oprofile: using timer interrupt. [ 2.707593] ThumbEE CPU extension supported. [ 2.712392] Registering SWP/SWPB emulation handler [ 2.717216] omap_voltage_late_init: Voltage driver support not added [ 2.724258] PM: Cannot get wkup_m3_ipc handle [ 2.748140] OMAP GPIO hardware version 0.1 [ 2.777145] mmc0: new high speed SDHC card at address aaaa [ 2.787506] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 400 kHz [ 2.794325] mmcblk0: mmc0:aaaa SS04G 3.69 GiB [ 2.804129] mmcblk0: p1 p2 p3 p4 [ 2.829424] tw9990 1-0045: tw9990 1-0045 sensor driver registered !! [ 2.836406] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 400 kHz [ 2.850561] pwm-backlight lcd_backlight: supply power not found, using dummy regulator [ 2.859726] panel-dpi display: failed to find video source [ 2.867282] PM: Cannot get wkup_m3_ipc handle [ 2.872345] panel-dpi display: failed to find video source [ 2.878558] PM: Cannot get wkup_m3_ipc handle [ 2.883548] panel-dpi display: failed to find video source [ 2.890566] input: gpio-keys as /devices/platform/gpio-keys/input/input1 [ 2.898537] PM: Cannot get wkup_m3_ipc handle [ 2.905812] panel-dpi display: failed to find video source [ 3.030916] PM: Cannot get wkup_m3_ipc handle [ 3.036169] panel-dpi display: failed to find video source [ 3.041867] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem [ 3.062102] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 3.070344] VFS: Mounted root (ext3 filesystem) readonly on device 179:2. [ 3.084928] devtmpfs: mounted [ 3.089727] Freeing unused kernel memory: 1024K [ 3.094421] Run /sbin/init as init process INIT: version booting INIT: No inittab.d directory found [ 4.356355] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) INIT: Entering runlevel: 3 Starting rsyslogd: OK Running sysctl: OK Starting mdev... OK [ 5.511702] input: matrix_keypad0 as /devices/platform/matrix_keypad0/input/input2 [ 5.528677] PM: Cannot get wkup_m3_ipc handle [ 5.533291] panel-dpi display: failed to find video source [ 5.561861] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 5.569115] PM: Cannot get wkup_m3_ipc handle [ 5.573714] panel-dpi display: failed to find video source Saving random seed: OK Starting system message bus: done Starting rpcbind: OK Starting network: OK Starting dhcpcd... dhcpcd-9.4.0 starting sandbox unavailable: seccomp sandbox unavailable: seccomp forked to background, child pid 144[ 6.131037] c_can_platform 481cc000.can can0: bit-timing not yet defined [ 6.138115] c_can_platform 481cc000.can can0: failed to open can device Starting lighttpd: [ 6.155651] net can1: c_can_hw_raminit_wait_syscon: time out [ 6.161403] c_can_platform 481d0000.can can1: bit-timing not yet defined [ 6.168146] c_can_platform 481d0000.can can1: failed to open can device OK ssh-keygen: generating new host keys: RSA DSA ECDSA ED25519 Starting sshd: OK FFS: mounting mmcblk0p2 to / as read only [ 11.280912] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) FFS: Running fsck on ffs mmcblk0p2 FFS: /dev/mmcblk0p2 file system okay FFS: Running fsck on ffs mmcblk0p1 Cannot initialize conversion from codepage 850 to ANSI_X3.4-1968: Invalid argument Cannot initialize conversion from ANSI_X3.4-1968 to codepage 850: Invalid argument Using internal CP850 conversion table Seek to 3790601728:Invalid argument FFS: /dev/mmcblk0p1 VFAT file system repaired FFS: Running fsck on ffs mmcblk0p3 FFS: /dev/mmcblk0p3 file system okay FFS: Running fsck on ffs mmcblk0p4 Cannot initialize conversion from codepage 850 to ANSI_X3.4-1968: Invalid argument Cannot initialize conversion from ANSI_X3.4-1968 to codepage 850: Invalid argument Using internal CP850 conversion table FFS: /dev/mmcblk0p4 VFAT file system okay FFS: mounting mmcblk0p1 to /mnt/boot as read only FSS: mounting mmcblk0p3 to /mnt/data [ 13.602654] EXT4-fs: Warning: mounting with data=journal disables delayed allocation, dioread_nolock, O_DIRECT and fast_commit support! [ 13.626877] EXT4-fs (mmcblk0p3): mounted filesystem with journalled data mode. Opts: (null) FFS: mounting mmcblk0p4 to /mnt/media modprobe: FATAL: Module st_lsm6dsm_i2c not found in directory /lib/modules/5.10.0 Starting DHCP server: /opt/storyboard/bin/gstreamer-backend: error while loading shared libraries: libgstreamer-0.10.so.0: cannot open shared object file: No such file or directory FAIL [ 14.041429] remoteproc remoteproc0: powering up wkup_m3 [ 14.058686] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148 [ 14.079045] remoteproc remoteproc0: remote processor wkup_m3 is now up [ 14.085628] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192 [ 14.108101] Mass Storage Function, version: 2009/09/11 [ 14.114470] LUN: removable file: (no medium) UI Board am4-industrial login: /opt/tco/crank.sh: line 20: cd: /opt/tco/UI_LCD_GUI: No such file or directory [ 14.393500] rtc-pcf2123 spi1.1: clock was stopped. Time is not valid INIT: Id "crnk" respawning too fast: disabled for 5 minutes Starting candump CAN0 Starting candump CAN1 [ 33.117826] vbat: disabling UI Board am4-industrial login: UI Board am4-industrial login: root Password: # # ls /dev [1;34mbus[m [1;35mram0[m [1;35mtty20[m [1;35mtty54[m [1;35mconsole[m [1;35mram1[m [1;35mtty21[m [1;35mtty55[m [1;35mcpu_dma_latency[m [1;35mram10[m [1;35mtty22[m [1;35mtty56[m [1;36mfd[m [1;35mram11[m [1;35mtty23[m [1;35mtty57[m [1;35mfull[m [1;35mram12[m [1;35mtty24[m [1;35mtty58[m [1;35mgpiochip0[m [1;35mram13[m [1;35mtty25[m [1;35mtty59[m [1;35mgpiochip1[m [1;35mram14[m [1;35mtty26[m [1;35mtty6[m [1;35mgpiochip2[m [1;35mram15[m [1;35mtty27[m [1;35mtty60[m [1;35mgpiochip3[m [1;35mram2[m [1;35mtty28[m [1;35mtty61[m [1;35mgpiochip4[m [1;35mram3[m [1;35mtty29[m [1;35mtty62[m [1;35mgpiochip5[m [1;35mram4[m [1;35mtty3[m [1;35mtty63[m [1;35mhidg0[m [1;35mram5[m [1;35mtty30[m [1;35mtty7[m [1;35mhwrng[m [1;35mram6[m [1;35mtty31[m [1;35mtty8[m [1;35mi2c-0[m [1;35mram7[m [1;35mtty32[m [1;35mtty9[m [1;35mi2c-1[m [1;35mram8[m [1;35mtty33[m [1;35mttyS0[m [1;35miio:device0[m [1;35mram9[m [1;35mtty34[m [1;35mttyS1[m [1;34minput[m [1;35mrandom[m [1;35mtty35[m [1;35mttyS2[m [1;35mkmsg[m [1;36mroot[m [1;35mtty36[m [1;35mttyS3[m [1;35mlog[m [1;35mrtc0[m [1;35mtty37[m [1;35mttyS4[m [1;35mloop-control[m [1;34mshm[m [1;35mtty38[m [1;35mttyS5[m [1;35mloop0[m [1;35msnapshot[m [1;35mtty39[m [1;35mttyS6[m [1;35mloop1[m [1;35mtpm0[m [1;35mtty4[m [1;35mttyS7[m [1;35mloop2[m [1;35mtpmrm0[m [1;35mtty40[m [1;35mttyS8[m [1;35mloop3[m [1;35mtty[m [1;35mtty41[m [1;35mttyS9[m [1;35mloop4[m [1;35mtty0[m [1;35mtty42[m [1;35murandom[m [1;35mloop5[m [1;35mtty1[m [1;35mtty43[m [1;35mvcs[m [1;35mloop6[m [1;35mtty10[m [1;35mtty44[m [1;35mvcs1[m [1;35mloop7[m [1;35mtty11[m [1;35mtty45[m [1;35mvcsa[m [1;35mmem[m [1;35mtty12[m [1;35mtty46[m [1;35mvcsa1[m [1;35mmmcblk0[m [1;35mtty13[m [1;35mtty47[m [1;35mvcsu[m [1;35mmmcblk0p1[m [1;35mtty14[m [1;35mtty48[m [1;35mvcsu1[m [1;35mmmcblk0p2[m [1;35mtty15[m [1;35mtty49[m [1;35mvideo0[m [1;35mmmcblk0p3[m [1;35mtty16[m [1;35mtty5[m [1;35mwatchdog[m [1;35mmmcblk0p4[m [1;35mtty17[m [1;35mtty50[m [1;35mwatchdog0[m [1;35mnull[m [1;35mtty18[m [1;35mtty51[m [1;35mzero[m [1;35mptmx[m [1;35mtty19[m [1;35mtty52[m [1;34mpts[m [1;35mtty2[m [1;35mtty53[m # #
![](/resized-image/__size/320x240/__key/communityserver-discussions-components-files/791/6354.pic.png)
