Part Number: TDA4VM
How can we boot from the emmc uda partition in the FS boot mode using SPL boot flow ?
Part Number: TDA4VM
Hi
If you want to boot from the UDA partion in FS mode please follow these steps.
diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index 34457c35d8..6af7f59cd3 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -34,8 +34,8 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_EARLY_BSS=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 +#CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +#CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR is not set CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_EXT4=y diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index e71a862a6f..d4e6fc0b52 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -33,8 +33,8 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 +#CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +#CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR is not set CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y
NOTE:With these changes you will not be able to use emmc raw mode If you want to use revert the above mentioned changes
Diwakar
