I tried to register a new host and target, but it ultimately caused the program to hang and fail to run
Could you please elaborate the issue you are facing ?
What use case you are looking at ?
Pratik
I have customized a node again, and both the host and target registration have specified the A72 core. However, compilation reported this error. How can I solve this problem? I am looking for tutorials that can be used for kernel registration and node usage under the TIOVX OpenVX framework.
Please refer the below documentation for more about how to create a target kernel.
TIOVX User Guide: User Kernels and User Target Kernels
You could refer the below tutorial for adding a new target kernel and the relevant changes required on host and target side.
TIOVX User Guide: vx_tutorial_graph_user_kernel.c File Reference
It can be found in the SDK in the path ${PSDKRA}/tiovx/tutorial/ch03_graph/vx_tutorial_graph_user_kernel.c.
Nikhil
Why is the document you sent different from what this blog(blog.csdn.net/.../120284981) is about?
This blog: blog.csdn.net/.../120284981
This blog seems to say information on how to add the kernel once it has been created.
But the link that I have provided and the tutorial would also help you get more information on how to create a target kernel.
How to use custom nodes after generation?
You could use it the same way that you use any other node. (i.e., with the Node API create)
Nikhil
