Hi Support Team,
Could you please clarify the meaning of the following EMIF registers?
According to TRM(SPRUHL7I),
EMIF Register EMIF4D_EXT_PHY_CTRL_36
Bit[8] Field:REG_PHY_FIFO_FIFO_WE_IN_MISALIGNED_CLR Description:FIFO Write Enable In Misaligned Clear
https://www.ti.com/jp/lit/ug/spruhl7i/spruhl7i.pdf
I do not understand what this value means.
This value is set to the value calculated by AM43xx EMIF Tools,
but when I checked this value after the start of operation, the value was changed from 0 to 1.
Is there any problem with this readout value?
AM43xx EMIF Tools;
http://www.ti.com/lit/zip/sprac70
Kanae
