![](/resized-image/__size/320x240/__key/communityserver-discussions-components-files/791/pastedimage1688351223134v1.png)
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.120_MV-SOC-20230628-dirty (root@motovis) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Wed Jun 28 15:22:05 CST 2023 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d6000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps_ipc_shared-memories@d6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb100400, size 0 MiB [ 0.000000] OF: reserved mem: initialized node ddr-update-rx-fifo-region-memories@fb100400, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb102400, size 0 MiB [ 0.000000] OF: reserved mem: initialized node ddr-update-tx-fifo-region-memories@fb102400, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb200400, size 12 MiB [ 0.000000] OF: reserved mem: initialized node ddr_update_norflash_shm_region_memories@fb200400, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000aeffffff] [ 0.000000] node 0: [mem 0x00000000af000000-0x00000000afffffff] [ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000b7ffffff] [ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff] [ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000e5ffffff] [ 0.000000] node 0: [mem 0x00000000e6000000-0x00000000fb0fffff] [ 0.000000] node 0: [mem 0x00000000fb101000-0x00000000fb103fff] [ 0.000000] node 0: [mem 0x00000000fb105000-0x00000000fb1fffff] [ 0.000000] node 0: [mem 0x00000000fb201000-0x00000000fbdfffff] [ 0.000000] node 0: [mem 0x00000000fbe01000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008a6ffffff] [ 0.000000] node 0: [mem 0x00000008a7000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] On node 0 totalpages: 1048572 [ 0.000000] DMA zone: 8192 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 524284 pages, LIFO batch:63 [ 0.000000] Normal zone: 8192 pages used for memmap [ 0.000000] Normal zone: 524288 pages, LIFO batch:63 [ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges [ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges [ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges [ 0.000000] cma: Failed to reserve 400 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112 [ 0.000000] pcpu-alloc: s50008 r8192 d31912 u90112 alloc=22*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032188 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=8ee26e06-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 2225376K/4194288K available (10816K kernel code, 1126K rwdata, 4188K rodata, 1792K init, 431K bss, 1968912K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008a7030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7040000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008407] Console: colour dummy device 80x25 [ 0.012983] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023655] pid_max: default: 32768 minimum: 301 [ 0.028411] LSM: Security Framework initializing [ 0.033177] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.040759] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.049666] rcu: Hierarchical SRCU implementation. [ 0.054735] Platform MSI: msi-controller@1820000 domain created [ 0.061023] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.070328] EFI services will not be available. [ 0.075071] smp: Bringing up secondary CPUs ... [ 0.088444] Detected PIPT I-cache on CPU1 [ 0.088465] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.088476] GICv3: CPU1: using allocated LPI pending table @0x00000008a7050000 [ 0.088522] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.088592] smp: Brought up 1 node, 2 CPUs [ 0.117937] SMP: Total of 2 processors activated. [ 0.122742] CPU features: detected: 32-bit EL0 Support [ 0.127997] CPU features: detected: CRC32 instructions [ 0.142081] CPU: All CPU(s) started at EL2 [ 0.146279] alternatives: patching kernel code [ 0.151352] devtmpfs: initialized [ 0.160839] KASLR disabled due to lack of seed [ 0.165493] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.175456] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.182551] pinctrl core: initialized pinctrl subsystem [ 0.188140] DMI not present or invalid. [ 0.192356] NET: Registered protocol family 16 [ 0.197184] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.204490] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.212487] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.220815] thermal_sys: Registered thermal governor 'step_wise' [ 0.220817] thermal_sys: Registered thermal governor 'power_allocator' [ 0.227414] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.241047] ASID allocator initialised with 65536 entries [ 0.260683] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.267543] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.274391] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.281237] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.288758] cryptd: max_cpu_qlen set to 1000 [ 0.294948] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected [ 0.303759] vsys_3v3: supplied by evm_12v0 [ 0.308122] vsys_5v0: supplied by evm_12v0 [ 0.312500] vdd_mmc1: supplied by vsys_3v3 [ 0.317220] iommu: Default domain type: Translated [ 0.322374] SCSI subsystem initialized [ 0.326427] mc: Linux media interface: v0.10 [ 0.330799] videodev: Linux video capture interface: v2.00 [ 0.336431] pps_core: LinuxPPS API ver. 1 registered [ 0.341501] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.350838] PTP clock support registered [ 0.354858] EDAC MC: Ver: 3.0.0 [ 0.358677] FPGA manager framework [ 0.362197] Advanced Linux Sound Architecture Driver Initialized. [ 0.368838] clocksource: Switched to clocksource arch_sys_counter [ 0.375174] VFS: Disk quotas dquot_6.6.0 [ 0.379207] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.388950] Carveout Heap: Exported 480 MiB at 0x00000000b8000000 [ 0.395252] NET: Registered protocol family 2 [ 0.400052] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.408709] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.417466] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.425674] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 0.433552] TCP: Hash tables configured (established 32768 bind 32768) [ 0.440373] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.447267] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.454682] NET: Registered protocol family 1 [ 0.459448] RPC: Registered named UNIX socket transport module. [ 0.465505] RPC: Registered udp transport module. [ 0.470321] RPC: Registered tcp transport module. [ 0.475126] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.481710] PCI: CLS 0 bytes, default 64 [ 0.486114] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.496493] Initialise system trusted keyrings [ 0.501153] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.509413] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.515685] NFS: Registering the id_resolver key type [ 0.520873] Key type id_resolver registered [ 0.525145] Key type id_legacy registered [ 0.529267] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.536117] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.543775] 9p: Installing v9fs 9p2000 file system support [ 0.568880] Key type asymmetric registered [ 0.573066] Asymmetric key parser 'x509' registered [ 0.578066] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.585624] io scheduler mq-deadline registered [ 0.590249] io scheduler kyber registered [ 0.595749] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.601940] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.610313] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.616584] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.624432] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.632512] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.640659] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq [ 0.647715] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq [ 0.656606] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs [ 0.669460] brd: module loaded [ 0.676424] loop: module loaded [ 0.680077] sysfs: cannot create duplicate filename '/devices/platform/dma_buf_phys' [ 0.688005] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.120_MV-SOC-20230628-dirty #1 [ 0.696181] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 0.702137] Call trace: [ 0.704643] dump_backtrace+0x0/0x1a0 [ 0.708379] show_stack+0x18/0x68 [ 0.711766] dump_stack+0xd0/0x12c [ 0.715237] sysfs_warn_dup+0x60/0x80 [ 0.718971] sysfs_create_dir_ns+0xe0/0xf8 [ 0.723153] kobject_add_internal+0x98/0x288 [ 0.727509] kobject_add+0x94/0x100 [ 0.731070] device_add+0xe0/0x740 [ 0.734540] platform_device_add+0x100/0x238 [ 0.738898] platform_device_register_full+0xcc/0x150 [ 0.744059] dma_buf_phys_init+0x6c/0x9c [ 0.748060] do_one_initcall+0x54/0x1b8 [ 0.751976] kernel_init_freeable+0x220/0x2a0 [ 0.756422] kernel_init+0x14/0x114 [ 0.759978] ret_from_fork+0x10/0x34 [ 0.763639] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory. [ 0.776843] megasas: 07.714.04.00-rc1 [ 0.782268] tun: Universal TUN/TAP device driver, 1.6 [ 0.787708] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.794113] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.800184] sky2: driver version 1.30 [ 0.804485] VFIO - User Level meta-driver version: 0.3 [ 0.810225] i2c /dev entries driver [ 0.814440] sdhci: Secure Digital Host Controller Interface driver [ 0.820756] sdhci: Copyright(c) Pierre Ossman [ 0.825464] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.831722] ledtrig-cpu: registered to indicate activity on CPUs [ 0.838055] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.845259] optee: probing for conduit method. [ 0.849819] optee: revision 3.12 (7ca85124) [ 0.850079] optee: initialized driver [ 0.859443] NET: Registered protocol family 17 [ 0.864071] 9pnet: Installing 9P2000 support [ 0.868473] Key type dns_resolver registered [ 0.872932] Loading compiled-in X.509 certificates [ 0.880387] pinctrl-single 11c000.pinctrl: Invalid number of rows: 0 [ 0.886905] pinctrl-single 11c000.pinctrl: no pins entries for main-i2c2-pins-default [ 0.894913] omap_i2c: probe of 2020000.i2c failed with error -22 [ 0.903154] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.909487] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.917635] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi') [ 1.018995] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 1.027239] pca953x 0-0020: supply vcc not found, using dummy regulator [ 1.034094] pca953x 0-0020: using no AI [ 1.060885] pca953x 0-0020: failed writing register [ 1.065928] pca953x: probe of 0-0020 failed with error -121 [ 1.071923] omap_i2c 2030000.i2c: bus 0 rev0.12 at 400 kHz [ 1.078244] omap_i2c 2040000.i2c: bus 1 rev0.12 at 100 kHz [ 1.084409] omap_i2c 2050000.i2c: bus 2 rev0.12 at 100 kHz [ 1.090917] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 1.100991] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [ 1.109903] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created [ 1.119910] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 1.142243] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 1.152144] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.158904] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.168108] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 1.178267] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.185033] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 1.193198] printk: console [ttyS2] disabled [ 1.197594] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 18, base_baud = 3000000) is a 8250 [ 1.206347] printk: console [ttyS2] enabled [ 1.214783] printk: bootconsole [ns16550a0] disabled [ 1.225437] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 19, base_baud = 3000000) is a 8250 [ 1.234596] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 20, base_baud = 3000000) is a 8250 [ 1.244603] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 1.255116] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 1.265267] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 1.275504] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 1.286745] scsi host0: ufshcd [ 1.292125] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.336841] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.345181] davinci_mdio 46000f00.mdio: phy[31]: device 46000f00.mdio:1f, driver Jlsemi [ 1.353241] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 1.367691] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 1.477596] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 1.483868] mmc0: CQHCI version 5.10 [ 1.484642] mmc1: CQHCI version 5.10 [ 1.500070] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 1.507080] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 1.514116] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 1.521103] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 1.522853] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 1.528119] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 1.546722] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 1.558012] ti-udma 31150000.dma-controller: Failed to allocate IRQs -28 [ 1.564728] ti-udma 31150000.dma-controller: Failed to allocate MSI interrupts [ 1.571975] ti-udma: probe of 31150000.dma-controller failed with error -28 [ 1.580062] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.624843] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.633122] davinci_mdio 46000f00.mdio: phy[31]: device 46000f00.mdio:1f, driver Jlsemi [ 1.641184] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 1.654925] mmc0: Command Queue Engine enabled [ 1.655626] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 1.659377] mmc0: new HS200 MMC card at address 0001 [ 1.666714] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 1.671045] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB [ 1.677961] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.682574] mmcblk0boot0: mmc0:0001 8GUF4R partition 1 31.9 MiB [ 1.692906] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 1.694411] mmcblk0boot1: mmc0:0001 8GUF4R partition 2 31.9 MiB [ 1.704454] cdns-ufshcd 4e84000.ufs: link startup failed 1 [ 1.714663] mmcblk0rpmb: mmc0:0001 8GUF4R partition 3 4.00 MiB, chardev (237:0) [ 1.715387] cdns-ufshcd 4e84000.ufs: UFS Host state=0 [ 1.727118] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 1.728849] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0 [ 1.734205] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 1.739194] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0 [ 1.745601] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present! [ 1.751342] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0 [ 1.758622] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present! [ 1.765394] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0 [ 1.773749] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 1.779272] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0 [ 1.786561] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 1.792854] cdns-ufshcd 4e84000.ufs: Clk gate=1 [ 1.800165] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 1.804667] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0 [ 1.811983] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 1.820120] cdns-ufshcd 4e84000.ufs: last intr at 1602390 us, last intr status=0x404 [ 1.828219] pinctrl-single 4301c000.pinctrl: Invalid number of rows: -2 [ 1.835173] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0 [ 1.841776] pinctrl-single 4301c000.pinctrl: no pins entries for sw11-button-pins-default [ 1.849226] mmcblk0: p1 p2 p3 p4 p5 p6 p7 [ 1.857356] gpio-keys: probe of gpio-keys failed with error -22 [ 1.861495] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0 [ 1.876369] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0 [ 1.882395] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000 [ 1.888665] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000 [ 1.888703] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 1.894750] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000 [ 1.894760] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0 [ 1.894782] host_regs: 00000000: 1587031f 00000000 00000210 00000000 [ 1.925154] host_regs: 00000010: 00000000 00000000 00000000 00000000 [ 1.931523] host_regs: 00000020: 00000000 00000470 00000000 00000000 [ 1.937875] host_regs: 00000030: 00000008 00000001 00000000 00000000 [ 1.944219] host_regs: 00000040: 00000000 00000000 00000000 00000000 [ 1.950569] host_regs: 00000050: 00000000 00000000 00000000 00000000 [ 1.956922] host_regs: 00000060: 00000000 00000000 00000000 00000000 [ 1.963270] host_regs: 00000070: 00000000 00000000 00000000 00000000 [ 1.969621] host_regs: 00000080: 00000000 00000000 00000000 00000000 [ 1.975964] host_regs: 00000090: 00000000 00000000 00000000 00000000 [ 1.982316] cdns-ufshcd 4e84000.ufs: No record of pa_err [ 1.987623] cdns-ufshcd 4e84000.ufs: No record of dl_err [ 1.992926] cdns-ufshcd 4e84000.ufs: No record of nl_err [ 1.998230] cdns-ufshcd 4e84000.ufs: No record of tl_err [ 2.003534] cdns-ufshcd 4e84000.ufs: No record of dme_err [ 2.008923] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err [ 2.015101] cdns-ufshcd 4e84000.ufs: No record of fatal_err [ 2.020666] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1603620 us [ 2.027791] cdns-ufshcd 4e84000.ufs: No record of resume_fail [ 2.033528] cdns-ufshcd 4e84000.ufs: No record of suspend_fail [ 2.039351] cdns-ufshcd 4e84000.ufs: No record of dev_reset [ 2.044914] cdns-ufshcd 4e84000.ufs: No record of host_reset [ 2.050564] cdns-ufshcd 4e84000.ufs: No record of task_abort [ 2.077546] ALSA device list: [ 2.080503] No soundcards found. [ 2.541614] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 2.549721] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 2.555903] Waiting for root device PARTUUID=8ee26e06-02... [ 2.592087] mmc1: new high speed SDHC card at address 59b4 [ 2.597941] mmcblk1: mmc1:59b4 SN32G 29.7 GiB [ 2.604177] mmcblk1: p1 p2 [ 2.608006] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 2.851888] EXT4-fs (mmcblk1p2): recovery complete [ 2.859599] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 2.867717] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 2.874998] devtmpfs: mounted [ 2.878958] Freeing unused kernel memory: 1792K [ 2.883595] Run /sbin/init as init process [ 2.887680] with arguments: [ 2.887682] /sbin/init [ 2.887684] with environment: [ 2.887685] HOME=/ [ 2.887687] TERM=linux [ 3.168273] systemd[1]: System time before build time, advancing clock. [ 3.243284] NET: Registered protocol family 10 [ 3.248281] Segment Routing with IPv6 [ 3.273954] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 3.295704] systemd[1]: Detected architecture arm64. [ 3.333547] systemd[1]: Set hostname to <j7-evm>. [ 3.529316] systemd[1]: /etc/systemd/system/boot_script.service:11: Support for option SysVStartPriority= has been removed and it is ignored [ 3.586915] random: systemd: uninitialized urandom read (16 bytes read) [ 3.593660] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling. [ 3.605988] systemd[1]: (This warning is only shown for the first unit using IP firewalling.) [ 3.615813] systemd[1]: Created slice system-getty.slice. [ 3.636921] random: systemd: uninitialized urandom read (16 bytes read) [ 3.644095] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 3.664911] random: systemd: uninitialized urandom read (16 bytes read) [ 3.671955] systemd[1]: Created slice User and Session Slice. [ 3.693061] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 3.716967] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 3.740939] systemd[1]: Reached target Paths. [ 3.756905] systemd[1]: Reached target Remote File Systems. [ 3.776887] systemd[1]: Reached target Slices. [ 3.792895] systemd[1]: Reached target Swap. [ 3.811314] systemd[1]: Listening on Process Core Dump Socket. [ 3.833062] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 3.869703] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 3.878119] systemd[1]: Listening on Journal Socket (/dev/log). [ 3.901181] systemd[1]: Listening on Journal Socket. [ 3.917248] systemd[1]: Listening on Network Service Netlink Socket. [ 3.941162] systemd[1]: Listening on udev Control Socket. [ 3.961034] systemd[1]: Listening on udev Kernel Socket. [ 3.983380] systemd[1]: Mounting Huge Pages File System... [ 4.003153] systemd[1]: Mounting POSIX Message Queue File System... [ 4.027333] systemd[1]: Mounting Kernel Debug File System... [ 4.054418] systemd[1]: Mounting Temporary Directory (/tmp)... [ 4.071239] systemd[1]: Starting Create list of static device nodes for the current kernel... [ 4.099325] systemd[1]: Starting Start psplash boot splash screen... [ 4.121082] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 4.133667] systemd[1]: Starting Journal Service... [ 4.153635] systemd[1]: Starting Load Kernel Modules... [ 4.167109] systemd[1]: Starting Remount Root and Kernel File Systems... [ 4.181793] cryptodev: loading out-of-tree module taints kernel. [ 4.190302] systemd[1]: Starting udev Coldplug all Devices... [ 4.196353] cryptodev: driver 1.10 loaded. [ 4.211643] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [ 4.220188] systemd[1]: Started Journal Service. [ 4.429260] systemd-journald[171]: Received client request to flush runtime journal. [ 4.597024] urandom_read_iter: 48 callbacks suppressed [ 4.597033] random: systemd: uninitialized urandom read (16 bytes read) [ 4.611841] random: systemd-journal: uninitialized urandom read (16 bytes read) [ 4.666049] random: systemd: uninitialized urandom read (16 bytes read) [ 5.086530] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.108102] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.359488] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.377530] CAN device driver interface [ 5.432970] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains [ 5.455391] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.464101] PVR_K: 234: Read BVNC 22.104.208.318 from HW device registers [ 5.483702] PVR_K: 234: RGX Device registered with BVNC 22.104.208.318 [ 5.484549] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0 [ 5.502058] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.526983] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.550607] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.643081] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc [ 5.675785] img_enc 4200000.video-encoder: encoder registered as /dev/video0 [ 5.709295] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000 [ 5.719353] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.737484] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.777476] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.792363] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode [ 5.801494] platform 5c00000.r5f: configured R5F for IPC-only mode [ 5.856664] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 5.860014] urandom_read_iter: 49 callbacks suppressed [ 5.860018] random: systemd: uninitialized urandom read (16 bytes read) [ 5.892958] random: systemd: uninitialized urandom read (16 bytes read) [ 5.904946] random: systemd: uninitialized urandom read (16 bytes read) [ 5.921690] remoteproc remoteproc0: 4d80800000.dsp is available [ 5.923407] img_dec 4300000.video-decoder: decoder registered as /dev/video1 [ 5.960918] remoteproc remoteproc0: attaching to 4d80800000.dsp [ 5.968134] remoteproc remoteproc1: 5c00000.r5f is available [ 6.012233] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 6.033062] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode [ 6.040608] remoteproc remoteproc1: attaching to 5c00000.r5f [ 6.116181] platform 5c00000.r5f: R5F core initialized in IPC-only mode [ 6.140943] remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000 [ 6.189063] remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 6.279978] virtio_rpmsg_bus virtio0: rpmsg host is online [ 6.285836] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd [ 6.348327] virtio_rpmsg_bus virtio1: rpmsg host is online [ 6.363945] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd [ 6.370347] remoteproc0#vdev0buffer: registered virtio0 (type 7) [ 6.371864] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:1f] driver [Jlsemi] (irq=POLL) [ 6.390285] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 6.408076] remoteproc1#vdev0buffer: registered virtio1 (type 7) [ 6.410781] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 6.418043] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached [ 6.433182] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000 [ 6.443697] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 6.461656] remoteproc remoteproc1: remote processor 5c00000.r5f is now attached [ 6.473930] platform 5d00000.r5f: configured R5F for IPC-only mode [ 6.480187] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode [ 6.520233] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 6.638967] remoteproc remoteproc2: 4d81800000.dsp is available [ 6.715972] remoteproc remoteproc3: 5d00000.r5f is available [ 6.732856] random: crng init done [ 6.736255] random: 74 urandom warning(s) missed due to ratelimiting [ 6.759950] remoteproc remoteproc2: attaching to 4d81800000.dsp [ 6.768311] remoteproc remoteproc3: attaching to 5d00000.r5f [ 6.774957] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode [ 6.782516] platform 5d00000.r5f: R5F core initialized in IPC-only mode [ 6.790360] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000 [ 6.804913] remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 6.829341] virtio_rpmsg_bus virtio2: rpmsg host is online [ 6.841211] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd [ 6.841263] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 6.856550] remoteproc2#vdev0buffer: registered virtio2 (type 7) [ 6.864022] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 6.883623] virtio_rpmsg_bus virtio3: rpmsg host is online [ 6.899172] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd [ 6.904901] remoteproc remoteproc2: remote processor 4d81800000.dsp is now attached [ 6.916797] remoteproc3#vdev0buffer: registered virtio3 (type 7) [ 6.933478] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 6.970135] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000 [ 7.000935] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 7.008869] remoteproc remoteproc3: remote processor 5d00000.r5f is now attached [ 7.053569] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 7.071487] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode [ 7.079386] remoteproc remoteproc4: 64800000.dsp is available [ 7.105396] remoteproc remoteproc4: attaching to 64800000.dsp [ 7.125720] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 7.149859] remoteproc remoteproc4: unsupported resource 65538 [ 7.175218] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode [ 7.190683] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 7.196730] remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000 [ 7.197765] virtio_rpmsg_bus virtio4: rpmsg host is online [ 7.197814] remoteproc4#vdev0buffer: registered virtio4 (type 7) [ 7.197819] remoteproc remoteproc4: remote processor 64800000.dsp is now attached [ 7.207650] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd [ 7.207754] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15 [ 7.207795] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe [ 7.207845] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15 [ 7.207892] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15 [ 7.207944] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15 [ 7.207987] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15 [ 7.209583] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe [ 7.209835] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe [ 7.217487] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 7.218369] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 7.229375] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe [ 7.231693] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 7.232227] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 7.242110] remoteproc remoteproc5: b034000.pru is available [ 7.242500] remoteproc remoteproc6: b004000.rtu is available [ 7.242674] remoteproc remoteproc7: b00a000.txpru is available [ 7.242815] remoteproc remoteproc8: b038000.pru is available [ 7.242870] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 7.242999] remoteproc remoteproc9: b006000.rtu is available [ 7.243171] remoteproc remoteproc10: b00c000.txpru is available [ 7.243317] remoteproc remoteproc11: b134000.pru is available [ 7.243483] remoteproc remoteproc12: b104000.rtu is available [ 7.243542] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 7.243647] remoteproc remoteproc13: b10a000.txpru is available [ 7.243761] remoteproc remoteproc14: b138000.pru is available [ 7.243909] remoteproc remoteproc15: b106000.rtu is available [ 7.244048] remoteproc remoteproc16: b10c000.txpru is available [ 7.256762] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 7.257897] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 7.275263] usbcore: registered new interface driver usbfs [ 7.275282] usbcore: registered new interface driver hub [ 7.275312] usbcore: registered new device driver usb [ 7.454225] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 7.454791] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 7.473851] virtio_rpmsg_bus virtio1: creating channel ti.ethfw.notifyservice addr 0x1e [ 7.474099] virtio_rpmsg_bus virtio1: creating channel rpmsg-kdrv addr 0x1a [ 7.474665] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 7.475029] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2 [ 7.475033] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 2/Jul/2023 SHA:ed5eb555 [ 7.475207] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 7.645776] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe [ 7.647837] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:1 [ 7.647922] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: Failed to request tx dma channel -517 [ 7.653632] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 7.654732] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 8.372228] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach - fail -16 [ 8.372253] j721e-cpsw-virt-mac: probe of main-r5fss-cpsw9g-virt-mac1 failed with error -16 [ 8.408306] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 8.417727] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 8.445139] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 8.500805] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 8.512144] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010 [ 8.521671] xhci-hcd xhci-hcd.0.auto: irq 584, io mem 0x06010000 [ 8.527852] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 8.536115] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 8.543329] usb usb1: Product: xHCI Host Controller [ 8.548203] usb usb1: Manufacturer: Linux 5.10.120_MV-SOC-20230628-dirty xhci-hcd [ 8.555680] usb usb1: SerialNumber: xhci-hcd.0.auto [ 8.560863] hub 1-0:1.0: USB hub found [ 8.564621] hub 1-0:1.0: 1 port detected [ 8.569659] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 8.575210] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 8.582876] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 8.589709] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 8.592905] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 8.605181] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 8.622757] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 8.631451] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 8.653052] usb usb2: Product: xHCI Host Controller [ 8.657929] usb usb2: Manufacturer: Linux 5.10.120_MV-SOC-20230628-dirty xhci-hcd [ 8.665408] usb usb2: SerialNumber: xhci-hcd.0.auto [ 8.670841] hub 2-0:1.0: USB hub found [ 8.675178] hub 2-0:1.0: 1 port detected [ 8.679818] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 8.681452] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 8.692195] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3 [ 8.709742] xhci-hcd xhci-hcd.1.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010 [ 8.719151] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 8.727041] xhci-hcd xhci-hcd.1.auto: irq 587, io mem 0x06410000 [ 8.739687] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 8.742330] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 8.763257] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 8.770473] usb usb3: Product: xHCI Host Controller [ 8.775362] usb usb3: Manufacturer: Linux 5.10.120_MV-SOC-20230628-dirty xhci-hcd [ 8.782837] usb usb3: SerialNumber: xhci-hcd.1.auto [ 8.787956] hub 3-0:1.0: USB hub found [ 8.791722] hub 3-0:1.0: 1 port detected [ 8.797234] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 8.811694] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4 [ 8.828665] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 8.836319] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 8.848612] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 8.856766] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 8.865031] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 8.872249] usb usb4: Product: xHCI Host Controller [ 8.877123] usb usb4: Manufacturer: Linux 5.10.120_MV-SOC-20230628-dirty xhci-hcd [ 8.884595] usb usb4: SerialNumber: xhci-hcd.1.auto [ 8.889715] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 8.890030] hub 4-0:1.0: USB hub found [ 8.900382] hub 4-0:1.0: 1 port detected [ 8.933544] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 8.950625] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517 [ 13.779501] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 13.845704] 8021q: 802.1Q VLAN Support v1.8 [ 13.849918] 8021q: adding VLAN 0 to HW filter on device eth0 [ 33.860858] vdd_mmc1: disabling [ 33.864001] tlv71033: disabling [ 37.907612] PVR_K: 633: RGX Firmware image 'rgx.fw.22.104.208.318' loaded [ 37.934463] PVR_K: 633: Shader binary image 'rgx.sh.22.104.208.318' loaded
[MCU2_0] 5.205875 s: CIO: Init ... Done !!! [MCU2_0] 5.205933 s: ### CPU Frequency = 1000000000 Hz [MCU2_0] 5.205977 s: APP: Init ... !!! [MCU2_0] 5.206004 s: SCICLIENT: Init ... !!! [MCU2_0] 5.206493 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [MCU2_0] 5.206546 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_0] 5.206582 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_0] 5.206621 s: SCICLIENT: Init ... Done !!! [MCU2_0] 5.206649 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2 [MCU2_0] 5.206891 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 5.206928 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18 [MCU2_0] 5.207130 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 5.207171 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=13 freq=121359600 [MCU2_0] 5.208829 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success [MCU2_0] 5.208867 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=4 parent=7 [MCU2_0] 5.209075 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 5.209114 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=3 [MCU2_0] 5.209324 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 5.209512 s: ==================>> Status = 0 Parent = 7 [MCU2_0] 5.209829 s: ==================>> 1 Status = 0 Parent = 3 [MCU2_0] 5.210004 s: ===================>> 1 Status = 0 Freq = 121359600 [MCU2_0] 5.210044 s: UDMA: Init ... !!! [MCU2_0] 5.212755 s: UDMA: Init ... Done !!! [MCU2_0] 5.212819 s: MEM: Init ... !!! [MCU2_0] 5.212866 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!! [MCU2_0] 5.212948 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!! [MCU2_0] 5.213015 s: MEM: Init ... Done !!! [MCU2_0] 5.213041 s: IPC: Init ... !!! [MCU2_0] 5.213108 s: IPC: 6 CPUs participating in IPC !!! [MCU2_0] 5.213158 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_0] 15.365767 s: IPC: HLOS is ready !!! [MCU2_0] 15.381920 s: IPC: Init ... Done !!! [MCU2_0] 15.381990 s: APP: Syncing with 5 CPUs ... !!! [MCU2_0] 16.218228 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_0] 16.218429 s: REMOTE_SERVICE: Init ... !!! [MCU2_0] 16.220007 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_0] 16.220071 s: ETHFW: Init ... !!! [MCU2_0] 16.473609 s: Warning: Using 6 MAC address(es) from static pool [MCU2_0] 16.473737 s: ETHFW: Shared multicasts (software fanout): [MCU2_0] 16.473784 s: 01:00:5e:00:00:01 [MCU2_0] 16.473838 s: 01:00:5e:00:00:fb [MCU2_0] 16.473887 s: 01:00:5e:00:00:fc [MCU2_0] 16.473936 s: 33:33:00:00:00:01 [MCU2_0] 16.473984 s: 33:33:ff:1d:92:c2 [MCU2_0] 16.474032 s: 01:80:c2:00:00:00 [MCU2_0] 16.474080 s: 01:80:c2:00:00:03 [MCU2_0] 16.474129 s: ETHFW: Reserved multicasts: [MCU2_0] 16.474157 s: 01:80:c2:00:00:0e [MCU2_0] 16.474205 s: 01:1b:19:00:00:00 [MCU2_0] 16.474470 s: EnetMcm: CPSW_9G on MAIN NAVSS [MCU2_0] 16.487733 s: PHY 0 is alive [MCU2_0] 16.487825 s: PHY 4 is alive [MCU2_0] 16.488202 s: EnetPhy_bindDriver: PHY 4: OUI:006037 Model:10 Ver:02 <-> 'tja1101' : OK [MCU2_0] 16.489950 s: [MCU2_0] ETHFW Version : 0.02.00 [MCU2_0] 16.490025 s: ETHFW Build Date: Jul 2, 2023 [MCU2_0] 16.490064 s: ETHFW Build Time: 18:59:19 [MCU2_0] 16.490093 s: ETHFW Commit SHA: ed5eb555 [MCU2_0] 16.490170 s: ETHFW: Init ... DONE !!! [MCU2_0] 16.490208 s: ETHFW: Remove server Init ... !!! [MCU2_0] 16.490405 s: CpswProxyServer: Virtual port configuration: [MCU2_0] 16.490465 s: mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1 [MCU2_0] 16.491322 s: CpswProxyServer: initialization completed (core: mcu2_0) [MCU2_0] 16.491392 s: ETHFW: Remove server Init ... DONE !!! [MCU2_0] 16.492743 s: Starting lwIP, local interface IP is dhcp-enabled [MCU2_0] 16.501582 s: Host MAC address: 70:ff:76:1d:92:c2 [MCU2_0] 16.506626 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully [MCU2_0] 16.508253 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6 [MCU2_0] 16.536839 s: [LWIPIF_LWIP_IC] Interface started successfully [MCU2_0] 16.536910 s: [LWIPIF_LWIP_IC] NETIF INIT SUCCESS [MCU2_0] 16.546498 s: FVID2: Init ... !!! [MCU2_0] 16.546603 s: FVID2: Init ... Done !!! [MCU2_0] 16.546641 s: SCICLIENT: Sciclient_pmSetModuleState module=187 state=2 [MCU2_0] 16.546857 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 16.546919 s: DSS: Init ... !!! [MCU2_0] 16.546951 s: DSS: Display type is BT601 on VOUT1 !!! [MCU2_0] 16.546984 s: DSS: M2M Path is enabled !!! [MCU2_0] 16.547018 s: DSS: Board init ... !!! [MCU2_0] 16.551517 s: DSS: Board init ... Done !!! [MCU2_0] 16.554696 s: appBt601DctrlDefaultInit: 401 !!! [MCU2_0] 16.555056 s: appBt601DctrlDefaultInit: retVal:0 [MCU2_0] 16.555119 s: DSS: Init ... Done !!! [MCU2_0] 16.555150 s: VHWA: VPAC Init ... !!! [MCU2_0] 16.555177 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2 [MCU2_0] 16.555636 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 16.555698 s: VHWA: LDC Init ... !!! [MCU2_0] 16.561199 s: VHWA: LDC Init ... Done !!! [MCU2_0] 16.561265 s: VHWA: MSC Init ... !!! [MCU2_0] 16.579962 s: VHWA: MSC Init ... Done !!! [MCU2_0] 16.580031 s: VHWA: NF Init ... !!! [MCU2_0] 16.582891 s: VHWA: NF Init ... Done !!! [MCU2_0] 16.582959 s: VHWA: VISS Init ... !!! [MCU2_0] 16.600003 s: VHWA: VISS Init ... Done !!! [MCU2_0] 16.600074 s: VHWA: VPAC Init ... Done !!! [MCU2_0] 16.600126 s: VX_ZONE_INIT:Enabled [MCU2_0] 16.600158 s: VX_ZONE_ERROR:Enabled [MCU2_0] 16.600186 s: VX_ZONE_WARNING:Enabled [MCU2_0] 16.601710 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target MCU2-0 [MCU2_0] 16.601987 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_NF [MCU2_0] 16.602236 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_LDC1 [MCU2_0] 16.602688 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_MSC1 [MCU2_0] 16.602990 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_MSC2 [MCU2_0] 16.603297 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_VISS1 [MCU2_0] 16.603739 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE1 [MCU2_0] 16.604045 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE2 [MCU2_0] 16.604333 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DISPLAY1 [MCU2_0] 16.604765 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DISPLAY2 [MCU2_0] 16.605029 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CSITX [MCU2_0] 16.605331 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE3 [MCU2_0] 16.605765 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE4 [MCU2_0] 16.606058 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE5 [MCU2_0] 16.606351 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE6 [MCU2_0] 16.606804 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE7 [MCU2_0] 16.607128 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE8 [MCU2_0] 16.607394 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M1 [MCU2_0] 16.607829 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M2 [MCU2_0] 16.608114 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M3 [MCU2_0] 16.608389 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M4 [MCU2_0] 16.608448 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [MCU2_0] 16.608668 s: APP: OpenVX Target kernel init ... !!! [MCU2_0] 16.633097 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_0] 16.633204 s: CSI2RX: Init ... !!! [MCU2_0] 16.633240 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 16.633611 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 16.633670 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2 [MCU2_0] 16.633939 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 16.633981 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2 [MCU2_0] 16.634202 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 16.634241 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2 [MCU2_0] 16.634404 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 16.634441 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2 [MCU2_0] 16.634704 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 16.635766 s: CSI2RX: Init ... Done !!! [MCU2_0] 16.635833 s: CSI2TX: Init ... !!! [MCU2_0] 16.635864 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 16.636116 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 16.636156 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2 [MCU2_0] 16.636453 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 16.636614 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2 [MCU2_0] 16.636889 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 16.637791 s: CSI2TX: Init ... Done !!! [MCU2_0] 16.637855 s: ISS: Init ... !!! [MCU2_0] 16.637901 s: IssSensor_Init ... Done !!! [MCU2_0] 16.637995 s: IttRemoteServer_Init ... Done !!! [MCU2_0] 16.638034 s: VISS REMOTE SERVICE: Init ... !!! [MCU2_0] 16.638102 s: VISS REMOTE SERVICE: Init ... Done !!! [MCU2_0] 16.638136 s: UDMA Copy: Init ... !!! [MCU2_0] 16.640969 s: UDMA Copy: Init ... Done !!! [MCU2_0] 16.641085 s: APP: Init set GPIO0_45 to '1' !!! [MCU2_0] 16.641130 s: appInit: HdmiEnableOutput return :-1 [MCU2_0] 16.641169 s: APP: Init ... Done !!! [MCU2_0] 16.641196 s: APP: Run ... !!! [MCU2_0] 16.641220 s: IPC: Starting echo test ... [MCU2_0] 16.644630 s: APP: Run ... Done !!! [MCU2_0] 16.644766 s: I2C Instance = 1, status:0 [MCU2_0] 16.644865 s: dvr 0x42 Addr_16 0x404 write Value_w 0x80 status -1 [MCU2_0] 16.649546 s: dvr 0x42 Addr_16 0x404 read Value_r 0xff status -1 [MCU2_0] 16.649671 s: dvr 0x42 Addr_16 0x44d write Value_w 0x80 status -1 [MCU2_0] 16.654550 s: dvr 0x42 Addr_16 0x44d read Value_r 0xff status -1 [MCU2_0] 16.654679 s: dvr 0x42 Addr_16 0x407 write Value_w 0x20 status -1 [MCU2_0] 16.662040 s: [LWIPIF_LWIP_IC] Interface started successfully [MCU2_0] 16.662117 s: [LWIPIF_LWIP_IC] NETIF INIT SUCCESS [MCU2_0] 16.662235 s: Added interface 'br4', IP is 0.0.0.0 [MCU2_0] 16.662301 s: ipaddr->addr=0 [MCU2_0] 16.664350 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 16.664625 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 16.664758 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_0] 16.664856 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_0] 16.670555 s: dvr 0x42 Addr_16 0x407 read Value_r 0xff status -1 [MCU2_0] 16.670693 s: dvr 0x42 Addr_16 0x331 write Value_w 0x11 status -1 [MCU2_0] 16.675549 s: dvr 0x42 Addr_16 0x331 read Value_r 0xff status -1 [MCU2_0] 16.675682 s: dvr 0x42 Addr_16 0x308 write Value_w 0x71 status -1 [MCU2_0] 16.680542 s: dvr 0x42 Addr_16 0x308 read Value_r 0xff status -1 [MCU2_0] 16.680664 s: dvr 0x42 Addr_16 0x311 write Value_w 0x10 status -1 [MCU2_0] 16.696545 s: dvr 0x42 Addr_16 0x311 read Value_r 0xff status -1 [MCU2_0] 16.696671 s: dvr 0x42 Addr_16 0x314 write Value_w 0x64 status -1 [MCU2_0] 16.712550 s: dvr 0x42 Addr_16 0x314 read Value_r 0xff status -1 [MCU2_0] 16.712680 s: dvr 0x42 Addr_16 0x415 write Value_w 0x3 status -1 [MCU2_0] 16.728540 s: dvr 0x42 Addr_16 0x415 read Value_r 0xff status -1 [MCU2_0] 16.728662 s: dvr 0x42 Addr_16 0x6 write Value_w 0x1f status -1 [MCU2_0] 16.744542 s: dvr 0x42 Addr_16 0x6 read Value_r 0xff status -1 [MCU2_0] 16.744746 s: DTC_SVC_TASK Create successfully!!! [MCU2_0] 16.744787 s: creat task end [MCU2_0] 16.793994 s: EnetPhy_enableState: PHY 4: falling back to manual mode [MCU2_0] 16.794071 s: EnetPhy_enableState: PHY 4: new link caps: FD100 [MCU2_0] 22.193994 s: EnetPhy_enableState: PHY 4: falling back to manual mode [MCU2_0] 22.194079 s: EnetPhy_enableState: PHY 4: new link caps: FD100 [MCU2_0] 26.509456 s: dvr 0x29 Addr_16 0x40b write Value_w 0x0 status -1 [MCU2_0] 26.510627 s: dvr 0x29 Addr_16 0x40b read Value_r 0xff status -1 [MCU2_0] 26.510746 s: dvr 0x29 Addr_16 0x10 write Value_w 0x11 status -1 [MCU2_0] 26.511609 s: dvr 0x29 Addr_16 0x10 read Value_r 0xff status -1 [MCU2_0] 26.511732 s: dvr 0x29 Addr_16 0x11 write Value_w 0x11 status -1 [MCU2_0] 26.711623 s: dvr 0x29 Addr_16 0x11 read Value_r 0xff status -1 [MCU2_0] 26.711751 s: dvr 0x29 Addr_16 0x18 write Value_w 0xf status -1 [MCU2_0] 26.712616 s: dvr 0x29 Addr_16 0x18 read Value_r 0xff status -1 [MCU2_0] 26.712740 s: dvr 0x29 Addr_16 0x6 write Value_w 0xf0 status -1 [MCU2_0] 26.912611 s: dvr 0x29 Addr_16 0x6 read Value_r 0xff status -1 [MCU2_0] 26.912745 s: dvr 0x29 Addr_16 0x6 write Value_w 0xff status -1 [MCU2_0] 27.012607 s: dvr 0x29 Addr_16 0x6 read Value_r 0xff status -1 [MCU2_0] 27.012813 s: dvr 0x40 Addr_16 0x2be write Value_w 0x88 status 0 [MCU2_0] 27.013728 s: dvr 0x40 Addr_16 0x2be read Value_r 0x80 status 0 [MCU2_0] 27.013919 s: dvr 0x40 Addr_16 0x2bf write Value_w 0x20 status 0 [MCU2_0] 27.014722 s: dvr 0x40 Addr_16 0x2bf read Value_r 0x20 status 0 [MCU2_0] 27.014917 s: dvr 0x40 Addr_16 0x2be write Value_w 0x90 status 0 [MCU2_0] 27.015724 s: dvr 0x40 Addr_16 0x2be read Value_r 0x98 status 0 [MCU2_0] 27.015846 s: dvr 0x29 Addr_16 0x40b write Value_w 0x0 status -1 [MCU2_0] 27.016601 s: dvr 0x29 Addr_16 0x40b read Value_r 0xff status -1 [MCU2_0] 27.016718 s: dvr 0x29 Addr_16 0xf0 write Value_w 0x62 status -1 [MCU2_0] 27.017602 s: dvr 0x29 Addr_16 0xf0 read Value_r 0xff status -1 [MCU2_0] 27.017720 s: dvr 0x29 Addr_16 0xf1 write Value_w 0xea status -1 [MCU2_0] 27.018594 s: dvr 0x29 Addr_16 0xf1 read Value_r 0xff status -1 [MCU2_0] 27.018714 s: dvr 0x29 Addr_16 0xf4 write Value_w 0xf status -1 [MCU2_0] 27.019599 s: dvr 0x29 Addr_16 0xf4 read Value_r 0xff status -1 [MCU2_0] 27.019793 s: dvr 0x40 Addr_16 0x330 write Value_w 0x0 status 0 [MCU2_0] 27.020719 s: dvr 0x40 Addr_16 0x330 read Value_r 0x0 status 0 [MCU2_0] 27.020910 s: dvr 0x40 Addr_16 0x331 write Value_w 0x33 status 0 [MCU2_0] 27.021719 s: dvr 0x40 Addr_16 0x331 read Value_r 0x33 status 0 [MCU2_0] 27.021913 s: dvr 0x40 Addr_16 0x332 write Value_w 0xee status 0 [MCU2_0] 27.022714 s: dvr 0x40 Addr_16 0x332 read Value_r 0xe0 status 0 [MCU2_0] 27.022907 s: dvr 0x40 Addr_16 0x333 write Value_w 0xe4 status 0 [MCU2_0] 27.023742 s: dvr 0x40 Addr_16 0x333 read Value_r 0x4 status 0 [MCU2_0] 27.023935 s: dvr 0x40 Addr_16 0x5b write Value_w 0x2 status 0 [MCU2_0] 27.024718 s: dvr 0x40 Addr_16 0x5b read Value_r 0x2 status 0 [MCU2_0] 27.024908 s: dvr 0x40 Addr_16 0x383 write Value_w 0x0 status 0 [MCU2_0] 27.025719 s: dvr 0x40 Addr_16 0x383 read Value_r 0x0 status 0 [MCU2_0] 27.025912 s: dvr 0x40 Addr_16 0x318 write Value_w 0x5e status 0 [MCU2_0] 27.026719 s: dvr 0x40 Addr_16 0x318 read Value_r 0x5e status 0 [MCU2_0] 27.026837 s: dvr 0x29 Addr_16 0x4a0 write Value_w 0x4 status -1 [MCU2_0] 27.027606 s: dvr 0x29 Addr_16 0x4a0 read Value_r 0xff status -1 [MCU2_0] 27.027726 s: dvr 0x29 Addr_16 0x4a2 write Value_w 0x0 status -1 [MCU2_0] 27.028599 s: dvr 0x29 Addr_16 0x4a2 read Value_r 0xff status -1 [MCU2_0] 27.028716 s: dvr 0x29 Addr_16 0x4aa write Value_w 0x0 status -1 [MCU2_0] 27.029596 s: dvr 0x29 Addr_16 0x4aa read Value_r 0xff status -1 [MCU2_0] 27.029712 s: dvr 0x29 Addr_16 0x4ab write Value_w 0x0 status -1 [MCU2_0] 27.030593 s: dvr 0x29 Addr_16 0x4ab read Value_r 0xff status -1 [MCU2_0] 27.030714 s: dvr 0x29 Addr_16 0x4af write Value_w 0xc0 status -1 [MCU2_0] 27.031598 s: dvr 0x29 Addr_16 0x4af read Value_r 0xff status -1 [MCU2_0] 27.031720 s: dvr 0x29 Addr_16 0x4a7 write Value_w 0xc status -1 [MCU2_0] 27.032601 s: dvr 0x29 Addr_16 0x4a7 read Value_r 0xff status -1 [MCU2_0] 27.032719 s: dvr 0x29 Addr_16 0x4a6 write Value_w 0xb7 status -1 [MCU2_0] 27.033603 s: dvr 0x29 Addr_16 0x4a6 read Value_r 0xff status -1 [MCU2_0] 27.033722 s: dvr 0x29 Addr_16 0x4a5 write Value_w 0x35 status -1 [MCU2_0] 27.034599 s: dvr 0x29 Addr_16 0x4a5 read Value_r 0xff status -1 [MCU2_0] 27.034718 s: dvr 0x29 Addr_16 0x4b1 write Value_w 0x40 status -1 [MCU2_0] 27.035601 s: dvr 0x29 Addr_16 0x4b1 read Value_r 0xff status -1 [MCU2_0] 27.035795 s: dvr 0x40 Addr_16 0x2d6 write Value_w 0x84 status 0 [MCU2_0] 27.036711 s: dvr 0x40 Addr_16 0x2d6 read Value_r 0x8c status 0 [MCU2_0] 27.036829 s: dvr 0x29 Addr_16 0x90b write Value_w 0x7 status -1 [MCU2_0] 27.037600 s: dvr 0x29 Addr_16 0x90b read Value_r 0xff status -1 [MCU2_0] 27.037717 s: dvr 0x29 Addr_16 0x92d write Value_w 0x15 status -1 [MCU2_0] 27.038601 s: dvr 0x29 Addr_16 0x92d read Value_r 0xff status -1 [MCU2_0] 27.038719 s: dvr 0x29 Addr_16 0x90d write Value_w 0x1e status -1 [MCU2_0] 27.039598 s: dvr 0x29 Addr_16 0x90d read Value_r 0xff status -1 [MCU2_0] 27.039716 s: dvr 0x29 Addr_16 0x90e write Value_w 0x1e status -1 [MCU2_0] 27.040603 s: dvr 0x29 Addr_16 0x90e read Value_r 0xff status -1 [MCU2_0] 27.040723 s: dvr 0x29 Addr_16 0x90f write Value_w 0x0 status -1 [MCU2_0] 27.041600 s: dvr 0x29 Addr_16 0x90f read Value_r 0xff status -1 [MCU2_0] 27.041717 s: dvr 0x29 Addr_16 0x910 write Value_w 0x0 status -1 [MCU2_0] 27.042591 s: dvr 0x29 Addr_16 0x910 read Value_r 0xff status -1
