Let me confirm about below.
* I would like you to confirm how user can assert TX_EN for RMII interface.
I'm checking description on TRM, it seems that there is no information about this.
Could you please confirm ?
Hello Ryuuichi machida,
Thank you for the query.
I would expect the TX_EN for RMII interface to be enabled as part of the data interface protocol.
I am not sure i understand your question on user asserting TX_EN.
Please elaborate your query.
Sreenivasa
I would like you to confirm about detail of following description.
Do you mean when user send packet to TX buffer, TX_EN is automatically genearted ?
Thank you.
I extracted the description from an app note referenced below..
3.5 TX_EN - Transmit Enable
TX_EN indicates that the MAC is presenting di-bits on TXD[1:0] for transmission. TX_EN shall be asserted
synchronously with the first nibble of the preamble and shall remain asserted while all di-bits to be
transmitted are presented. The MAC should assert TX_EN negated prior to the first REF_CLK rising edge
following the final di-bit of a frame.
TX_EN shall transition synchronously with respect to REF_CLK.
https://www.ti.com/lit/an/snla076a/snla076a.pdf
Please review the RMII specifications for additional information.
Sreenivasa
Thank you for your reply.
What I want to know is what behavior should be done(want to know exact procedure) to output TX_EN.
Could you confirm about above ?
Hello Ryuuichi, machida,
Thank you.
I could not find any descrtiption in the TRM that i could share.
I would assume that the TRM assume customer would be referencing the specific interface standards.
There was a similar question and the EPHY team reference the below link for the standard that you could use.
Could you please help me understand the context of the query for me to support better.
Sreenivasa
- 1 -
https://e2e.ti.com/support/interface-group/interface---internal/f/interface---internal-forum/1249761/rmii-consortium-specification/4729448#4729448
I'm sorry I can not access above URL.
It seems that this is TI internal site, can you extract the point ?
- 2 -
Now, we have problem on case of RMII.
Customer create custom board with RMII PHY and connect AM623. The SDK condition is Linux SDK(ver 08_05_00_21).
The problem of above is user can not observe TX_EN when they send packet from AM62.(Wh have already confirmed "link up".)
If you would like to know detail and need detail discussion, please let me communicate internally.
However, above is the reason why we want to know how user can output TX_EN.
Thank you.
The RMII standard can be found here: http://ebook.pldworld.com/_eBook/-Telecommunications,Networks-/TCPIP/RMII/rmii_rev12.pdf
Could you confirm if the hardware configuration customer made is in line with the recommendations in the data sheet or TRM.
Would customer be Ok to share the schematics for quick review.
Sreenivasa
It seems that this URL has already invalid. (I could not jump pdf page.)
Could you give your email address ? I would share it internally.
Thank you.
You could use the attached for quick reference.
Please send a private message.
Sreenivasa
I sent schematic info which is related to ethernet to private message.
Please let us discuss this on private message.
Thanks. there was a planned maintenance shutdown of E2E on Thursday and Friday.
Let me review the inputs and reply.
Sreenivasa
Trying to understand the note.
Did you mean we do the discussion also as private message.
Sreenivasa
Yes, you are correct. Maybe we include customer information, so please discuss on private message. Please understand my situation.
Thank you for the note and understand.
Will continue the conversation over private message.
Sreenivasa
Hello Schuyler
I added the below input i received from Ryuuichi, machida,
Can you please check with customer on the RMII driver they are using. Was this modified by customer? How was the driver verified?
I heard that customer use kernel standard RMII driver which are included in Linux SDK (Ver 08_06_00_45).
Sreenivasa
I need to ask a few starter questions, I am assuming that Linux is being used.
Assuming the port is eth0 please attach the results of the following commands:
- ifconfig eth0
- ethtool eth0
- ethtool -S eth0
Schuyler
I see a similar query below
The issue description is as below. Can you review and confirm if this is the same project and also clarify the issue observed to continue further analysis.
We have designed Ethernet RMII communication circuit on our new PCB using TI MCU and PHY.
When Ethernet cable connects from this PCB to PC for the test, link up can be done (100Mbps, Full-duplex) but ping cannot success.
Parts name of MCU and PHY are the followings.
MCU: AM6231ASGGGAALW
PHY: DP83825IRMQR x2 (eth0, eth1) used as RMII master mode
We have designed the firmware of Ethernet communication module based on the one for SK-AM62.
(Changed only some parameters and defines from for RGMII mode to for RMII mode.)
We have confirmed that the port mode setect of both eth0/eth1 is RMII.
CTRL_ENET1_CTRL Register (Offset = 4044h) ENET1_CTRL_PORT_MODE_SEL: b001 - RMII
CTRL_ENET2_CTRL Register (Offset = 4048h) ENET2_CTRL_PORT_MODE_SEL: b001 - RMII
CTRL_ENET1_CTRL_PROXY Register (Offset = 6044h) ENET1_CTRL_PORT_MODE_SEL_PROXY: b001 - RMII
CTRL_ENET2_CTRL_PROXY Register (Offset = 6048h) ENET2_CTRL_PORT_MODE_SEL_PROXY: b001 - RMII
Details of ping NG;
PC --> PCB: PC send ARP request to PCB(as global packet), but PCB send no response message to PC.
PCB --> PC: PCB send ARP request to PC(as global packet), then PC send the response message to PCB, but then PCB send ARP request to PC(as global packet) again. It repeats until ping command of PCB is stopped.
We measured the waveform of main signal lines around PHY.
The waveforms of MDIO, MDC, 50MHzOut, TD_P/M, RD_P/M has the correct changes and seem no problem.
But the waveforms of TX_EN, TX_D0, TX_D1, RX_D0, RX_D1, RX_ER, CRS_DV are always 0V with no change.
Please give us some advice if it can be guessed something suspicious by the above information, or if there are what we need to check more.
Sreenivasa
Hello Sreenuvasa-san and Schuyler-san,
-1-
- ifconfig eth0
- ethtool eth0
- ethtool -S eth0
=> Please see attached file(txt file) about result.
(Status of "From Line 1 to Line 210" is "Disabled link up" with PC, Status of "From Line 211 to Line 424" is "Enabled link up" with PC.)
- 2 -
Thank you for your notification.
Yes, I confirmed with customer and thread which you point out is same as mine.
I discussed customer and we would like to continue discussion on following customer's thread.
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1269687/am623-cannot-establish-ethernet-rmii-data-communication-tx-rx-between-mac-and-phy
You asked to customer about schematic information, but this is same one which I shared on private message. So please refer them.
Therefore, I will close this thread.
root@am62xx-evm:~# ifconfig eth0 eth0 Link encap:Ethernet HWaddr 34:08:E1:87:A8:CA UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) root@am62xx-evm:~# ethtool eth0 Settings for eth0: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Supported pause frame use: Symmetric Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Advertised pause frame use: Symmetric Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Speed: Unknown! Duplex: Unknown! (255) Auto-negotiation: on Port: Twisted Pair PHYAD: 0 Transceiver: external MDI-X: Unknown Supports Wake-on: gs Wake-on: d SecureOn password: 00:00:00:00:00:00 Current message level: 0x000020f7 (8439) drv probe link ifdown ifup rx_err tx_err hw Link detected: no root@am62xx-evm:~# ethtool -S eth0 NIC statistics: p0_rx_good_frames: 0 p0_rx_broadcast_frames: 0 p0_rx_multicast_frames: 0 p0_rx_crc_errors: 0 p0_rx_oversized_frames: 0 p0_rx_undersized_frames: 0 p0_ale_drop: 0 p0_ale_overrun_drop: 0 p0_rx_octets: 0 p0_tx_good_frames: 0 p0_tx_broadcast_frames: 0 p0_tx_multicast_frames: 0 p0_tx_octets: 0 p0_tx_64B_frames: 0 p0_tx_65_to_127B_frames: 0 p0_tx_128_to_255B_frames: 0 p0_tx_256_to_511B_frames: 0 p0_tx_512_to_1023B_frames: 0 p0_tx_1024B_frames: 0 p0_net_octets: 0 p0_rx_bottom_fifo_drop: 0 p0_rx_port_mask_drop: 0 p0_rx_top_fifo_drop: 0 p0_ale_rate_limit_drop: 0 p0_ale_vid_ingress_drop: 0 p0_ale_da_eq_sa_drop: 0 p0_ale_block_drop: 0 p0_ale_secure_drop: 0 p0_ale_auth_drop: 0 p0_ale_unknown_ucast: 0 p0_ale_unknown_ucast_bytes: 0 p0_ale_unknown_mcast: 0 p0_ale_unknown_mcast_bytes: 0 p0_ale_unknown_bcast: 0 p0_ale_unknown_bcast_bytes: 0 p0_ale_pol_match: 0 p0_ale_pol_match_red: 0 p0_ale_pol_match_yellow: 0 p0_ale_mcast_sa_drop: 0 p0_ale_dual_vlan_drop: 0 p0_ale_len_err_drop: 0 p0_ale_ip_next_hdr_drop: 0 p0_ale_ipv4_frag_drop: 0 p0_tx_mem_protect_err: 0 p0_tx_pri0: 0 p0_tx_pri1: 0 p0_tx_pri2: 0 p0_tx_pri3: 0 p0_tx_pri4: 0 p0_tx_pri5: 0 p0_tx_pri6: 0 p0_tx_pri7: 0 p0_tx_pri0_bcnt: 0 p0_tx_pri1_bcnt: 0 p0_tx_pri2_bcnt: 0 p0_tx_pri3_bcnt: 0 p0_tx_pri4_bcnt: 0 p0_tx_pri5_bcnt: 0 p0_tx_pri6_bcnt: 0 p0_tx_pri7_bcnt: 0 p0_tx_pri0_drop: 0 p0_tx_pri1_drop: 0 p0_tx_pri2_drop: 0 p0_tx_pri3_drop: 0 p0_tx_pri4_drop: 0 p0_tx_pri5_drop: 0 p0_tx_pri6_drop: 0 p0_tx_pri7_drop: 0 p0_tx_pri0_drop_bcnt: 0 p0_tx_pri1_drop_bcnt: 0 p0_tx_pri2_drop_bcnt: 0 p0_tx_pri3_drop_bcnt: 0 p0_tx_pri4_drop_bcnt: 0 p0_tx_pri5_drop_bcnt: 0 p0_tx_pri6_drop_bcnt: 0 p0_tx_pri7_drop_bcnt: 0 rx_good_frames: 0 rx_broadcast_frames: 0 rx_multicast_frames: 0 rx_pause_frames: 0 rx_crc_errors: 0 rx_align_code_errors: 0 rx_oversized_frames: 0 rx_jabber_frames: 0 rx_undersized_frames: 0 rx_fragments: 0 ale_drop: 0 ale_overrun_drop: 0 rx_octets: 0 tx_good_frames: 0 tx_broadcast_frames: 0 tx_multicast_frames: 0 tx_pause_frames: 0 tx_deferred_frames: 0 tx_collision_frames: 0 tx_single_coll_frames: 0 tx_mult_coll_frames: 0 tx_excessive_collisions: 0 tx_late_collisions: 0 rx_ipg_error: 0 tx_carrier_sense_errors: 0 tx_octets: 0 tx_64B_frames: 0 tx_65_to_127B_frames: 0 tx_128_to_255B_frames: 0 tx_256_to_511B_frames: 0 tx_512_to_1023B_frames: 0 tx_1024B_frames: 0 net_octets: 0 rx_bottom_fifo_drop: 0 rx_port_mask_drop: 0 rx_top_fifo_drop: 0 ale_rate_limit_drop: 0 ale_vid_ingress_drop: 0 ale_da_eq_sa_drop: 0 ale_block_drop: 0 ale_secure_drop: 0 ale_auth_drop: 0 ale_unknown_ucast: 0 ale_unknown_ucast_bytes: 0 ale_unknown_mcast: 0 ale_unknown_mcast_bytes: 0 ale_unknown_bcast: 0 ale_unknown_bcast_bytes: 0 ale_pol_match: 0 ale_pol_match_red: 0 ale_pol_match_yellow: 0 ale_mcast_sa_drop: 0 ale_dual_vlan_drop: 0 ale_len_err_drop: 0 ale_ip_next_hdr_drop: 0 ale_ipv4_frag_drop: 0 iet_rx_assembly_err: 0 iet_rx_assembly_ok: 0 iet_rx_smd_err: 0 iet_rx_frag: 0 iet_tx_hold: 0 iet_tx_frag: 0 tx_mem_protect_err: 0 tx_pri0: 0 tx_pri1: 0 tx_pri2: 0 tx_pri3: 0 tx_pri4: 0 tx_pri5: 0 tx_pri6: 0 tx_pri7: 0 tx_pri0_bcnt: 0 tx_pri1_bcnt: 0 tx_pri2_bcnt: 0 tx_pri3_bcnt: 0 tx_pri4_bcnt: 0 tx_pri5_bcnt: 0 tx_pri6_bcnt: 0 tx_pri7_bcnt: 0 tx_pri0_drop: 0 tx_pri1_drop: 0 tx_pri2_drop: 0 tx_pri3_drop: 0 tx_pri4_drop: 0 tx_pri5_drop: 0 tx_pri6_drop: 0 tx_pri7_drop: 0 tx_pri0_drop_bcnt: 0 tx_pri1_drop_bcnt: 0 tx_pri2_drop_bcnt: 0 tx_pri3_drop_bcnt: 0 tx_pri4_drop_bcnt: 0 tx_pri5_drop_bcnt: 0 tx_pri6_drop_bcnt: 0 tx_pri7_drop_bcnt: 0 root@am62xx-evm:~# [ 88.762291] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 88.768596] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx ifconfig ^C root@am62xx-evm:~# ifconfig eth0 eth0 Link encap:Ethernet HWaddr 34:08:E1:87:A8:CA inet6 addr: fe80::3608:e1ff:fe87:a8ca/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:25 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:4186 (4.0 KiB) root@am62xx-evm:~# ethtool eth0 Settings for eth0: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Supported pause frame use: Symmetric Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Advertised pause frame use: Symmetric Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Link partner advertised pause frame use: Symmetric Receive-only Link partner advertised auto-negotiation: Yes Link partner advertised FEC modes: Not reported Speed: 100Mb/s Duplex: Full Auto-negotiation: on Port: Twisted Pair PHYAD: 0 Transceiver: external MDI-X: Unknown Supports Wake-on: gs Wake-on: d SecureOn password: 00:00:00:00:00:00 Current message level: 0x000020f7 (8439) drv probe link ifdown ifup rx_err tx_err hw Link detected: yes root@am62xx-evm:~# ethtool -S eth0 NIC statistics: p0_rx_good_frames: 36 p0_rx_broadcast_frames: 12 p0_rx_multicast_frames: 24 p0_rx_crc_errors: 0 p0_rx_oversized_frames: 0 p0_rx_undersized_frames: 0 p0_ale_drop: 0 p0_ale_overrun_drop: 0 p0_rx_octets: 6948 p0_tx_good_frames: 0 p0_tx_broadcast_frames: 0 p0_tx_multicast_frames: 0 p0_tx_octets: 0 p0_tx_64B_frames: 0 p0_tx_65_to_127B_frames: 17 p0_tx_128_to_255B_frames: 7 p0_tx_256_to_511B_frames: 12 p0_tx_512_to_1023B_frames: 0 p0_tx_1024B_frames: 0 p0_net_octets: 6948 p0_rx_bottom_fifo_drop: 0 p0_rx_port_mask_drop: 0 p0_rx_top_fifo_drop: 0 p0_ale_rate_limit_drop: 0 p0_ale_vid_ingress_drop: 0 p0_ale_da_eq_sa_drop: 0 p0_ale_block_drop: 0 p0_ale_secure_drop: 0 p0_ale_auth_drop: 0 p0_ale_unknown_ucast: 0 p0_ale_unknown_ucast_bytes: 0 p0_ale_unknown_mcast: 0 p0_ale_unknown_mcast_bytes: 0 p0_ale_unknown_bcast: 0 p0_ale_unknown_bcast_bytes: 0 p0_ale_pol_match: 0 p0_ale_pol_match_red: 0 p0_ale_pol_match_yellow: 0 p0_ale_mcast_sa_drop: 0 p0_ale_dual_vlan_drop: 0 p0_ale_len_err_drop: 0 p0_ale_ip_next_hdr_drop: 0 p0_ale_ipv4_frag_drop: 0 p0_tx_mem_protect_err: 0 p0_tx_pri0: 0 p0_tx_pri1: 0 p0_tx_pri2: 0 p0_tx_pri3: 0 p0_tx_pri4: 0 p0_tx_pri5: 0 p0_tx_pri6: 0 p0_tx_pri7: 0 p0_tx_pri0_bcnt: 0 p0_tx_pri1_bcnt: 0 p0_tx_pri2_bcnt: 0 p0_tx_pri3_bcnt: 0 p0_tx_pri4_bcnt: 0 p0_tx_pri5_bcnt: 0 p0_tx_pri6_bcnt: 0 p0_tx_pri7_bcnt: 0 p0_tx_pri0_drop: 0 p0_tx_pri1_drop: 0 p0_tx_pri2_drop: 0 p0_tx_pri3_drop: 0 p0_tx_pri4_drop: 0 p0_tx_pri5_drop: 0 p0_tx_pri6_drop: 0 p0_tx_pri7_drop: 0 p0_tx_pri0_drop_bcnt: 0 p0_tx_pri1_drop_bcnt: 0 p0_tx_pri2_drop_bcnt: 0 p0_tx_pri3_drop_bcnt: 0 p0_tx_pri4_drop_bcnt: 0 p0_tx_pri5_drop_bcnt: 0 p0_tx_pri6_drop_bcnt: 0 p0_tx_pri7_drop_bcnt: 0 rx_good_frames: 0 rx_broadcast_frames: 0 rx_multicast_frames: 0 rx_pause_frames: 0 rx_crc_errors: 0 rx_align_code_errors: 0 rx_oversized_frames: 0 rx_jabber_frames: 0 rx_undersized_frames: 0 rx_fragments: 0 ale_drop: 0 ale_overrun_drop: 0 rx_octets: 0 tx_good_frames: 36 tx_broadcast_frames: 12 tx_multicast_frames: 24 tx_pause_frames: 0 tx_deferred_frames: 0 tx_collision_frames: 0 tx_single_coll_frames: 0 tx_mult_coll_frames: 0 tx_excessive_collisions: 0 tx_late_collisions: 0 rx_ipg_error: 0 tx_carrier_sense_errors: 0 tx_octets: 6948 tx_64B_frames: 0 tx_65_to_127B_frames: 17 tx_128_to_255B_frames: 7 tx_256_to_511B_frames: 12 tx_512_to_1023B_frames: 0 tx_1024B_frames: 0 net_octets: 6948 rx_bottom_fifo_drop: 0 rx_port_mask_drop: 0 rx_top_fifo_drop: 0 ale_rate_limit_drop: 0 ale_vid_ingress_drop: 0 ale_da_eq_sa_drop: 0 ale_block_drop: 0 ale_secure_drop: 0 ale_auth_drop: 0 ale_unknown_ucast: 0 ale_unknown_ucast_bytes: 0 ale_unknown_mcast: 0 ale_unknown_mcast_bytes: 0 ale_unknown_bcast: 0 ale_unknown_bcast_bytes: 0 ale_pol_match: 0 ale_pol_match_red: 0 ale_pol_match_yellow: 0 ale_mcast_sa_drop: 0 ale_dual_vlan_drop: 0 ale_len_err_drop: 0 ale_ip_next_hdr_drop: 0 ale_ipv4_frag_drop: 0 iet_rx_assembly_err: 0 iet_rx_assembly_ok: 0 iet_rx_smd_err: 0 iet_rx_frag: 0 iet_tx_hold: 0 iet_tx_frag: 0 tx_mem_protect_err: 0 tx_pri0: 36 tx_pri1: 0 tx_pri2: 0 tx_pri3: 0 tx_pri4: 0 tx_pri5: 0 tx_pri6: 0 tx_pri7: 0 tx_pri0_bcnt: 6948 tx_pri1_bcnt: 0 tx_pri2_bcnt: 0 tx_pri3_bcnt: 0 tx_pri4_bcnt: 0 tx_pri5_bcnt: 0 tx_pri6_bcnt: 0 tx_pri7_bcnt: 0 tx_pri0_drop: 0 tx_pri1_drop: 0 tx_pri2_drop: 0 tx_pri3_drop: 0 tx_pri4_drop: 0 tx_pri5_drop: 0 tx_pri6_drop: 0 tx_pri7_drop: 0 tx_pri0_drop_bcnt: 0 tx_pri1_drop_bcnt: 0 tx_pri2_drop_bcnt: 0 tx_pri3_drop_bcnt: 0 tx_pri4_drop_bcnt: 0 tx_pri5_drop_bcnt: 0 tx_pri6_drop_bcnt: 0 tx_pri7_drop_bcnt: 0 root@am62xx-evm:~#
Thank you for the note.
It took me some time to realize the queries are for the same project since the issues reported were different.
Schuyler,
In the other thread customer reported there is no clock from the PHY side.
I will review if there are any issues that can be seen from the hardware side before i assign for you to support.
Sreenivasa
