Champs.
We have a customer using RTL8201.
They got the posted fail logs, and it's very similar to the above link happening on Jacinto.
However, we have tried the Jacinto patch, it still fails and giving us the similar logs.
Any solution for this?
Thanks.
BR Rio
U-Boot SPL 2021.01-g7de8fba018 (Aug 18 2023 - 03:03:10 +0000) SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar') SPL initial stack usage: 13424 bytes Trying to boot from MMC2 Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Loading Environment from MMC... *** Warning - No MMC card found, using default environment Starting ATF on ARM64 core... NOTICE: BL31: v2.8(release):v2.8-226-g2fcd408bb3-dirty NOTICE: BL31: Built : 01:27:44, Jul 31 2023 U-Boot SPL 2021.01-g7de8fba018 (Aug 18 2023 - 03:03:09 +0000) SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar') Trying to boot from MMC2 Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted U-Boot 2021.01-g7de8fba018 (Aug 18 2023 - 03:03:09 +0000) SoC: AM62X SR1.0 GP Model: Texas Instruments AM625 SK EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -19 DRAM: 1 GiB MMC: mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2 Loading Environment from MMC... MMC: block number 0x3500 exceeds max(0x1000) *** Warning - !read failed, using default environment In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Net: eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 1490 bytes read in 4 ms (363.3 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 2 ms (0 Bytes/s) Already setup. 18948608 bytes read in 800 ms (22.6 MiB/s) 55779 bytes read in 7 ms (7.6 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008feef000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.10.168-rt83-geae3e59505 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT_RT Thu Sep 7 03:59:06 UTC 2023 [ 0.000000] Machine model: Texas Instruments AM625 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB [ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000bfffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff] [ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff] [ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000bfffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff] [ 0.000000] On node 0 totalpages: 262144 [ 0.000000] DMA zone: 4096 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 262144 pages, LIFO batch:63 [ 0.000000] cma: Failed to reserve 512 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 18 pages/cpu s35968 r8192 d29568 u73728 [ 0.000000] pcpu-alloc: s35968 r8192 d29568 u73728 alloc=18*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=8e0f501c-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 951776K/1048576K available (11072K kernel code, 1224K rwdata, 4308K rodata, 1792K init, 439K bss, 96800K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms. [ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads. [ 0.000000] No expedited grace period (rcu_normal_after_boot). [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008543] Console: colour dummy device 80x25 [ 0.013141] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023823] pid_max: default: 32768 minimum: 301 [ 0.028647] LSM: Security Framework initializing [ 0.033438] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.041013] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.051088] rcu: Hierarchical SRCU implementation. [ 0.056546] Platform MSI: msi-controller@1820000 domain created [ 0.062944] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.072244] EFI services will not be available. [ 0.077216] smp: Bringing up secondary CPUs ... [ 0.082653] Detected VIPT I-cache on CPU1 [ 0.086788] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.093826] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000 [ 0.101267] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.108837] Detected VIPT I-cache on CPU2 [ 0.112965] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.120000] GICv3: CPU2: using allocated LPI pending table @0x0000000080060000 [ 0.127417] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.134916] Detected VIPT I-cache on CPU3 [ 0.139039] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.146074] GICv3: CPU3: using allocated LPI pending table @0x0000000080070000 [ 0.153493] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.160263] smp: Brought up 1 node, 4 CPUs [ 0.164467] SMP: Total of 4 processors activated. [ 0.169287] CPU features: detected: 32-bit EL0 Support [ 0.174549] CPU features: detected: CRC32 instructions [ 0.187123] CPU: All CPU(s) started at EL2 [ 0.191330] alternatives: patching kernel code [ 0.197151] devtmpfs: initialized [ 0.209033] KASLR disabled due to lack of seed [ 0.213796] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.223776] futex hash table entries: 1024 (order: 5, 131072 bytes, linear) [ 0.231286] pinctrl core: initialized pinctrl subsystem [ 0.237247] DMI not present or invalid. [ 0.241879] NET: Registered protocol family 16 [ 0.247010] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations [ 0.254283] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.262231] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.270920] thermal_sys: Registered thermal governor 'step_wise' [ 0.271525] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.284696] ASID allocator initialised with 65536 entries [ 0.317543] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.324459] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.331380] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.338233] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.346147] cryptd: max_cpu_qlen set to 1000 [ 0.353793] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected [ 0.362971] vcc_5v0: supplied by vmain_pd [ 0.367583] vcc_3v3_sys: supplied by vmain_pd [ 0.372612] vcc_1v8: supplied by vcc_3v3_sys [ 0.378114] iommu: Default domain type: Translated [ 0.383527] SCSI subsystem initialized [ 0.387868] mc: Linux media interface: v0.10 [ 0.392276] videodev: Linux video capture interface: v2.00 [ 0.398000] pps_core: LinuxPPS API ver. 1 registered [ 0.403075] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.412424] PTP clock support registered [ 0.416463] EDAC MC: Ver: 3.0.0 [ 0.420477] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100 [ 0.427694] FPGA manager framework [ 0.431286] Advanced Linux Sound Architecture Driver Initialized. [ 0.438512] clocksource: Switched to clocksource arch_sys_counter [ 0.444990] VFS: Disk quotas dquot_6.6.0 [ 0.449081] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.462281] NET: Registered protocol family 2 [ 0.467010] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.475560] tcp_listen_portaddr_hash hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.484272] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.492283] TCP bind hash table entries: 8192 (order: 6, 458752 bytes, linear) [ 0.500177] TCP: Hash tables configured (established 8192 bind 8192) [ 0.507019] UDP hash table entries: 512 (order: 4, 65536 bytes, linear) [ 0.513902] UDP-Lite hash table entries: 512 (order: 4, 65536 bytes, linear) [ 0.521435] NET: Registered protocol family 1 [ 0.526568] RPC: Registered named UNIX socket transport module. [ 0.532635] RPC: Registered udp transport module. [ 0.537444] RPC: Registered tcp transport module. [ 0.542253] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.548843] NET: Registered protocol family 44 [ 0.553400] PCI: CLS 0 bytes, default 64 [ 0.558338] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.570858] Initialise system trusted keyrings [ 0.575685] workingset: timestamp_bits=46 max_order=18 bucket_order=0 [ 0.587217] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.593941] NFS: Registering the id_resolver key type [ 0.599202] Key type id_resolver registered [ 0.603493] Key type id_legacy registered [ 0.607736] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.614592] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.622405] 9p: Installing v9fs 9p2000 file system support [ 0.662658] Key type asymmetric registered [ 0.666878] Asymmetric key parser 'x509' registered [ 0.671933] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.679562] io scheduler mq-deadline registered [ 0.684210] io scheduler kyber registered [ 0.690781] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.697220] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.711848] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.733727] brd: module loaded [ 0.746241] loop: module loaded [ 0.750438] megasas: 07.714.04.00-rc1 [ 0.758884] tun: Universal TUN/TAP device driver, 1.6 [ 0.764708] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.771153] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.777285] sky2: driver version 1.30 [ 0.782040] VFIO - User Level meta-driver version: 0.3 [ 0.788562] i2c /dev entries driver [ 0.794066] sdhci: Secure Digital Host Controller Interface driver [ 0.800446] sdhci: Copyright(c) Pierre Ossman [ 0.805340] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.812580] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.820916] optee: probing for conduit method. [ 0.825530] optee: revision 3.20 (8e74d476) [ 0.825841] optee: dynamic shared memory is enabled [ 0.835382] optee: initialized driver [ 0.841458] NET: Registered protocol family 17 [ 0.846290] 9pnet: Installing 9P2000 support [ 0.850765] Key type dns_resolver registered [ 0.855563] printk: bootconsole [ns16550a0]: printing thread started [ 0.855614] Loading compiled-in X.509 certificates [ 0.868632] ti-sci 44043000.system-controller: lpm region is required for suspend but not provided. [ 0.868679] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar') [ 0.933690] davinci-mcasp 2b10000.mcasp: IRQ common not found [ 0.936616] omap-gpmc 3b000000.memory-controller: GPMC revision 6.0 [ 0.936635] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000 [ 0.964161] VDD_CORE: Bringing 750000uV into 850000-850000uV [ 0.964989] VDD_CORE: supplied by vcc_5v0 [ 0.965817] VCC1V8: supplied by vcc_5v0 [ 0.966578] VDDS_DDR: supplied by vcc_5v0 [ 0.967709] VDDSHV_MCU: supplied by vcc_5v0 [ 0.968054] VDDR_CORE: supplied by VCC1V8 [ 0.969053] VDDA_1V8: supplied by vcc_5v0 [ 0.969798] VDD_PHY_2V5: supplied by vcc_5v0 [ 0.971644] tps65219 0-0030: Setup as system-power-controller but pm_power_off function already registered, overwriting [ 0.971850] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz [ 0.974392] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz [ r���rtc-s35390a 2-0030: registered as rtc0 [ 1.003420] rtc-s35390a 2-0030: setting system clock to 2023-08-31T03:02:04 UTC (1693450924) [ 1.029058] printk: console [ttyS2]: printing thread started [ 1.003486] omap_i2c 20030000.i2c: bus 2 rev0.12 at 100 kHz [ 1.029076] printk: console [ttyS2] enabled [ 1.029080] printk: bootconsole [ns16550a0] disabled [ 1.049067] printk: bootconsole [ns16550a0]: printing thread stopped [ 1.050271] panel-simple display0: Specify missing connector_type [ 1.062304] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode [ 1.102530] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.103821] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver RTL8201F Fast Ethernet [ 1.103985] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006 [ 1.104115] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.104122] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.105008] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0 [ 1.106301] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.109954] rtc-ti-k3 2b1f0000.rtc: registered as rtc1 [ 1.214801] mmc0: CQHCI version 5.10 [ 1.216308] mmc2: CQHCI version 5.10 [ 1.217818] davinci-mcasp 2b10000.mcasp: IRQ common not found [ 1.230973] pinctrl-single f4000.pinctrl: pin PIN117 already requested by 20030000.i2c; cannot claim for 1-0022 [ 1.230992] pinctrl-single f4000.pinctrl: pin-117 (1-0022) status -22 [ 1.230998] pinctrl-single f4000.pinctrl: could not request pin 117 (PIN117) from group main-gpio1-ioexp-intr-pins-default on device pinctrl-single [ 1.231005] pca953x 1-0022: Error applying setting, reverse things back [ 1.231024] pca953x: probe of 1-0022 failed with error -22 1.232047] panel-simple display0: Specify missing connector_type [ 1.234428] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0 [ 1.264864] Console: switching to colour frame buffer device 100x37 [ 1.267252] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.281152] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device [ 1.290004] mmc1: CQHCI version 5.10 [ 1.290415] debugfs: Directory 'pd:53' with parent 'pm_genpd' already present! [ 1.290493] debugfs: Directory 'pd:52' with parent 'pm_genpd' already present! [ 1.290569] debugfs: Directory 'pd:51' with parent 'pm_genpd' already present! [ 1.291030] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present! [ 1.304573] ALSA device list: [ 1.304587] No soundcards found. [ 1.342196] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 1.374872] mmc0: new HS200 MMC card at address 0001 [ 1.375766] mmcblk0: mmc0:0001 004GA0 3.69 GiB [ 1.376074] mmcblk0boot0: mmc0:0001 004GA0 partition 1 2.00 MiB [ 1.376381] mmcblk0boot1: mmc0:0001 004GA0 partition 2 2.00 MiB [ 1.376595] mmcblk0rpmb: mmc0:0001 004GA0 partition 3 512 KiB, chardev (237:0) [ 1.378273] mmcblk0: p1 p2 p3 p4 [ 1.431571] mmc1: error -84 whilst initialising SD card [ 1.660286] mmc1: new ultra high speed SDR50 SDXC card at address 59b4 [ 1.661175] mmcblk1: mmc1:59b4 ED2S5 119 GiB [ 1.662882] mmcblk1: p1 p2 [ 2.728187] sdhci-am654 fa20000.mmc: Power on failed [ 2.758814] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit [ 2.766920] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 2.767022] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 2.767879] devtmpfs: mounted [ 2.769227] Freeing unused kernel memory: 1792K [ 2.790594] Run /sbin/init as init process [ 3.007519] NET: Registered protocol family 10 [ 3.008735] Segment Routing with IPv6 [ 3.038353] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 3.039004] systemd[1]: Detected architecture arm64. Welcome to Arago 2021.09! [ 3.087396] systemd[1]: Set hostname to <am62xx-evm>. [ 3.093233] random: systemd: uninitialized urandom read (16 bytes read) [ 3.093341] systemd[1]: Initializing machine ID from random generator. [ 3.442704] random: systemd: uninitialized urandom read (16 bytes read) [ 3.446216] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ OK ] Created slice system-serial\x2dgett[ 3.474791] random: systemd: uninitialized urandom read (16 bytes read) [ 3.476329] systemd[1]: Created slice system-serial\x2dgetty.slice. y.slice. [ OK ] Created slice User and Session Slic[ 3.508082] systemd[1]: Created slice User and Session Slice. e. [ OK ] Started Dispatch Password �Kts to [ 3.531163] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. Console Directory Watch. [ OK ] Started Forward Password R�Kuests [ 3.555005] systemd[1]: Started Forward Password Requests to Wall Directory Watch. to Wall Directory Watch. [ OK ] Reached target Paths. [ 3.578892] systemd[1]: Reached target Paths. [ OK ] Reached target Remote File Systems systemd[1]: Reached target Remote File Systems. [0m. [ OK ] Reached target Slices. [ 3.610716] systemd[1]: Reached target Slices. [ OK ] Reached target Swap. [ 3.622708] systemd[1]: Reached target Swap. [ OK ] Listening on RPCbind Server Activat[ 3.656326] systemd[1]: Listening on RPCbind Server Activation Socket. ion Socket. [ OK ] Reached target RPC Port Mapper.[ 3.678977] systemd[1]: Reached target RPC Port Mapper. [ OK ] Listening on Process Core Dump Sock[ 3.703676] systemd[1]: Listening on Process Core Dump Socket. et. [ OK ] Listening on initctl Compatibility [ 3.731177] systemd[1]: Listening on initctl Compatibility Named Pipe. Named Pipe. [ 3.758449] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 3.759547] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket. [ 3.787474] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Network Service Netlin[ 3.799643] systemd[1]: Listening on Network Service Netlink Socket. k Socket. [ OK ] Listening on udev Control Socket 3.823462] systemd[1]: Listening on udev Control Socket. m. [ OK ] Listening on udev Kernel Socket[ 3.847184] systemd[1]: Listening on udev Kernel Socket. . Mounting Huge Pages File System... [ 3.871923] systemd[1]: Mounting Huge Pages File System... Mounting POSIX Message Queue File System..[ 3.887930] systemd[1]: Mounting POSIX Message Queue File System... . Mounting Kernel Debug File System... [ 3.915728] systemd[1]: Mounting Kernel Debug File System... Mounting Temporary Directory (/tmp)... [ 3.932622] systemd[1]: Mounting Temporary Directory (/tmp)... Starting Create list of st�Kodes for the curr[ 3.952002] systemd[1]: Starting Create list of static device nodes for the current kernel... ent kernel... Starting Start psplash boot splash screen.[ 3.987347] systemd[1]: Starting Start psplash boot splash screen... .. Starting RPC Bind... [ 4.017076] systemd[1]: Starting RPC Bind... [ 4.026995] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 4.034614] systemd[1]: Starting Journal Service... Starting Journal Service... Starting Load Kernel Modules... [ 4.069783] systemd[1]: Starting Load Kernel Modules... Starting Remount Root and Kernel File Systems systemd[1]: Starting Remount Root and Kernel File Systems... [ 4.090475] cryptodev: loading out-of-tree module taints kernel. [ 4.099003] cryptodev: driver 1.10 loaded. [ 4.109939] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [0m... [ 4.125823] random: systemd-journal: uninitialized urandom read (16 bytes read) [ 4.125984] random: systemd-journal: uninitialized urandom read (16 bytes read) [ 4.126481] random: systemd-journal: uninitialized urandom read (16 bytes read) [ 4.140214] systemd[1]: Starting udev Coldplug all Devices... Starting udev Coldplug all Devices... [ OK ] Started Start psplash boot splash s[ 4.174978] systemd[1]: Started Start psplash boot splash screen. creen. [ OK ] Started RPC Bind. [ 4.199492] systemd[1]: Started RPC Bind. [ OK ] Started Journal Service.[ 4.215628] systemd[1]: Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Started Create list of sta�K nodes for the current kernel. [ OK ] Started Load Kernel Modules. [ OK ] Started Remount Root and Kernel File Systems. Mounting Kernel Configuration File System... [ OK ] Started Start psplash-syst�Kprogress communication helper. Starting Flush Journal to Persistent Storage... [ 4.435737] systemd-journald[236]: Received client request to flush runtime journal. Starting Apply Kernel Variables... Starting Create System Users... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Apply Kernel Variables. [ OK ] Started Create System Users. Starting Create Static Device Nodes in /dev... [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Reached target Local File Systems (Pre). Mounting /media/ram... Mounting /var/volatile... Starting udev Kernel Device Manager... [ OK ] Started udev Coldplug all Devices. [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. [ OK ] Started udev Kernel Device Manager. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Rebuild Dynamic Linker Cache... Starting Create Volatile Files and Directories... [ OK ] Started Create Volatile Files and Directories. [ 5.168024] random: systemd: uninitialized urandom read (16 bytes read) Starting Run pending postinsts... [ 5.189488] random: systemd-journal: uninitialized urandom read (16 bytes read) [ 5.202074] random: systemd: uninitialized urandom read (16 bytes read) Starting Rebuild Journal Catalog... Starting Network Time Synchronization... Starting Update UTMP about System Boot/Shutdown... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Rebuild Journal Catalog. [ OK ] Started Rebuild Dynamic Linker Cache. Starting Update is Completed... [ OK ] Started Update is Completed. [ OK ] Started Run pending postinsts. [ OK ] Created slice system-systemd\x2dbacklight.slice. Starting Load/Save Screen �Kness of backlight:backlight... [ OK ] Started Load/Save Screen B�Khtness of backlight:backlight. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Initializatio[ 6.277907] random: systemd: uninitialized urandom read (16 bytes read) n. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target System Time Set. [ OK ] Reached target System Time Synchronized. [ OK ] Reached target Timers. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. [ 6.450635] random: crng init done [ 6.450658] random: 87 urandom warning(s) missed due to ratelimiting [ OK ] Listening on dropbear.socket. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. [ 6.542831] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000 [ 6.543281] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode [ OK ] Started D-Bus System Message Bus 6.543377] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device m. [ 6.563987] remoteproc remoteproc0: 5000000.m4fss is available [ 6.564800] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2 [ 6.564823] remoteproc remoteproc0: powering up 5000000.m4fss [ 6.564856] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2 [ 6.564864] remoteproc remoteproc0: request_firmware failed: -2 [ 6.687378] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 6.687548] platform 78000000.r5f: configured R5F for IPC-only mode [ 6.687709] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000 [ 6.707667] remoteproc remoteproc1: 78000000.r5f is available [ 6.707795] remoteproc remoteproc1: attaching to 78000000.r5f [ 6.729792] platform 78000000.r5f: R5F core initialized in IPC-only mode [ 6.729842] remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@9da00000 [ 6.745712] virtio_rpmsg_bus virtio0: rpmsg host is online [ 6.746296] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 6.746956] remoteproc1#vdev0buffer: registered virtio0 (type 7) [ 6.746978] remoteproc remoteproc1: remote processor 78000000.r5f is now attached Starting Print notice about GPLv3 packages[ 6.763813] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe ... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... Starting Login Service... [ OK ] Started TEE Supplicant. Starting telnetd.service... [ OK ] Started Load/Save Random Seed. [ OK ] Started IPv6 Packet Filtering Framework. [ OK ] Started IPv4 Packet Filtering Framework. [ OK ] Started telnetd.service. [ OK ] Reached target Network (Pre). Starting LSB: Expand Rootfs of boot device... Starting Network Service... [ OK ] Started Login Service. [ OK ] Started Network Service. Starting Wait for Network to be Configured... Starting Network Name Resolution... [ 8.287129] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [RTL8201F Fast Ethernet] (irq=POLL) [ 8.287180] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: bash cifs-utils dosfstools less libdw1 libelf1 libreadline8 parted If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ OK ] Started Print notice about GPLv3 packages. [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name Lookups. Starting Avahi mDNS/DNS-SD Stack... [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Permit User Sessions... [ OK ] Started Avahi mDNS/DNS-SD Stack. [ OK ] Started Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... [ 9.043408] EXT4-fs (mmcblk1p2): resizing filesystem from 326588 to 125035520 blocks [ OK ] Started Synchronize System and HW clocks. [ OK ] Created slice system-systemd\x2dfsck.slice. [ OK ] Found device /dev/mmcblk1p1. [ OK ] Found device /dev/mmcblk0p1. [ OK ] Found device /dev/mmcblk0p3. [ OK ] Found device /dev/mmcblk0p4. Starting File System Check on /dev/mmcblk0p1... Starting File System Check on /dev/mmcblk0p3... Starting File System Check on /dev/mmcblk0p4... Starting File System Check on /dev/mmcblk1p1... [ OK ] Started File System Check on /dev/mmcblk0p1. [ OK ] Started File System Check on /dev/mmcblk0p3. [ OK ] Started File System Check on /dev/mmcblk0p4. [ OK ] Started File System Check on /dev/mmcblk1p1. Mounting /run/media/mmcblk0p1... [ 10.985830] remoteproc remoteproc2: 30074000.pru is available Mounting /run/media/mmcblk0p3... [ 11.025656] remoteproc remoteproc3: 30078000.pru is available [ 11.115209] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22 Mounting /run/media/mmcblk0p4... [ 11.283044] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null) [ 11.283137] ext4 filesystem being mounted at /run/media/mmcblk0p3 supports timestamps until 2038 (0x7fffffff) [ 11.351129] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 11.351736] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 11.526931] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null) Mounting /run/media/mmcblk1p1... [ 11.630679] usbcore: registered new interface driver usbfs [ 11.640293] usbcore: registered new interface driver hub [ 11.640521] usbcore: registered new device driver usb [ OK ] Mounted /run/media/mmcblk0p1. [ OK ] Mounted /run/media/mmcblk0p3. [ OK ] Mounted /run/media/mmcblk0p4. [ 11.749634] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 11.749706] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 [ 11.749906] xhci-hcd xhci-hcd.2.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010 [ 11.756277] xhci-hcd xhci-hcd.2.auto: irq 510, io mem 0x31100000 [ 11.756555] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 11.756597] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [ 11.756633] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed [ 11.756880] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 11.756892] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 11.756898] usb usb1: Product: xHCI Host Controller [ 11.756902] usb usb1: Manufacturer: Linux 5.10.168-rt83-geae3e59505 xhci-hcd [ 11.756907] usb usb1: SerialNumber: xhci-hcd.2.auto [ 11.757800] hub 1-0:1.0: USB hub found [ 11.757871] hub 1-0:1.0: 1 port detected [ 11.764818] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 11.764949] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 11.764959] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 11.764965] usb usb2: Product: xHCI Host Controller [ 11.764971] usb usb2: Manufacturer: Linux 5.10.168-rt83-geae3e59505 xhci-hcd [ 11.764975] usb usb2: SerialNumber: xhci-hcd.2.auto [ 11.765671] hub 2-0:1.0: USB hub found [ OK ] Mounted /run/media/mmcblk1p1. [ 11.765716] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19) [ OK ] Reached target Hardware activated USB gadget. Starting Save/Restore Sound Card State... [ 12.018750] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ OK ] Started Save/Restore Sound Card State. [ OK ] Reached target Sound Card. [ 12.166926] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3 [ 12.166956] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 12.211833] hub 1-1:1.0: USB hub found [ 12.211989] hub 1-1:1.0: 4 ports detected [ 12.563941] usb 1-1.4: new high-speed USB device number 3 using xhci-hcd [ 12.715225] EXT4-fs (mmcblk1p2): resizing filesystem from 33947649 to 125035520 blocks [ 12.715268] EXT4-fs (mmcblk1p2): Converting file system to meta_bg [ 12.715386] EXT4-fs (mmcblk1p2): resizing filesystem from 33947649 to 125035520 blocks [ 13.622465] usb 1-1.4: New USB device found, idVendor=1005, idProduct=b128, bcdDevice= 1.00 [ 13.622491] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 13.622595] usb 1-1.4: Product: FLASH DRIVE [ 13.622605] usb 1-1.4: Manufacturer: USB3.0 [ 13.622609] usb 1-1.4: SerialNumber: 07000312EFB1F358 [ 13.667053] usb-storage 1-1.4:1.0: USB Mass Storage device detected [ 13.667763] scsi host0: usb-storage 1-1.4:1.0 [ 13.668280] usbcore: registered new interface driver usb-storage [ 14.690836] scsi 0:0:0:0: Direct-Access USB3.0 FLASH DRIVE PMAP PQ: 0 ANSI: 6 [ 14.694284] sd 0:0:0:0: [sda] 30310400 512-byte logical blocks: (15.5 GB/14.5 GiB) [ 14.695508] sd 0:0:0:0: [sda] Write Protect is off [ 14.710634] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [ 14.847171] sda: sda1 [ 14.858650] sd 0:0:0:0: [sda] Attached SCSI removable disk _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project am62xx-evm ttyS2 Arago 2021.09 am62xx-evm ttyS2 am62xx-evm login: root[ 19.056830] EXT4-fs (mmcblk1p2): resized to 77070337 blocks root@am62xx-evm:~# root@am62xx-evm:~# root@am62xx-evm:~# root@am62xx-evm:~# root@am62xx-evm:~# ifconfig eth0 Link encap:Ethernet HWaddr 1C:63:49:07:F1:D4 inet6 addr: fe80::1e63:49ff:fe07:f1d4/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:22 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:3692 (3.6 KiB) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:82 errors:0 dropped:0 overruns:0 frame:0 TX packets:82 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:6220 (6.0 KiB) TX bytes:6220 (6.0 KiB) root@am62xx-evm:~# ifconfig [ 29.087514] EXT4-fs (mmcblk1p2): resized to 120455169 blocks e[ 30.586387] EXT4-fs (mmcblk1p2): resized filesystem to 125035520 root@am62xx-evm:~# root@am62xx-evm:~# root@am62xx-evm:~# root@am62xx-evm:~# ifconfig eth0 192.168.1.55 root@am62xx-evm:~# ifconfig eth0 Link encap:Ethernet HWaddr 1C:63:49:07:F1:D4 inet addr:192.168.1.55 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fe80::1e63:49ff:fe07:f1d4/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:37 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:6298 (6.1 KiB) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:82 errors:0 dropped:0 overruns:0 frame:0 TX packets:82 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:6220 (6.0 KiB) TX bytes:6220 (6.0 KiB) root@am62xx-evm:~# ping 192.168.1.10 PING 192.168.1.10 (192.168.1.10): 56 data bytes [ 184.886518] ------------[ cut here ]------------ [ 184.886536] NETDEV WATCHDOG: eth0 (am65-cpsw-nuss): transmit queue 0 timed out [ 184.886621] WARNING: CPU: 2 PID: 29 at net/sched/sch_generic.c:467 dev_watchdog+0x374/0x380 [ 184.886648] Modules linked in: usb_storage xhci_plat_hcd rpmsg_char xhci_hcd usbcore dwc3 udc_core usb_common cdns_csi2rx v4l2_fwnode pru_rproc irq_pruss_intc crct10dif_ce snd_soc_simple_card snd_soc_simple_card_utils dwc3_am62 ti_k3_r5_remoteproc virtio_rpmsg_bus ti_k3_m4_remoteproc rti_wdt j721e_csi2rx videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 sa2ul cdns_dphy sha512_generic videobuf2_common authenc mcrc pruss tps6598x typec roles snd_soc_tlv320aic3x sch_fq_codel cryptodev(O) ipv6 [ 184.886753] CPU: 2 PID: 29 Comm: ksoftirqd/2 Tainted: G O 5.10.168-rt83-geae3e59505 #1 [ 184.886761] Hardware name: Texas Instruments AM625 SK (DT) [ 184.886765] pstate: 40000005 (nZcv daif -PAN -UAO -TCO BTYPE=--) [ 184.886772] pc : dev_watchdog+0x374/0x380 [ 184.886779] lr : dev_watchdog+0x374/0x380 [ 184.886784] sp : ffff8000114abc20 [ 184.886786] x29: ffff8000114abc20 x28: ffff000001d2bb00 [ 184.886793] x27: 0000000000000004 x26: 0000000000000180 [ 184.886799] x25: 00000000ffffffff x24: 0000000000000002 [ 184.886804] x23: ffff000001d2a3e0 x22: ffff000001d2a000 [ 184.886810] x21: ffff000001d2a4b0 x20: ffff8000110e9000 [ 184.886815] x19: 0000000000000000 x18: 0000000000000000 [ 184.886821] x17: 0000000000000000 x16: 0000000000000000 [ 184.886828] x15: ffff000000166e60 x14: ffffffffffffffff [ 184.886833] x13: ffff800011224dfe x12: ffff800011224df1 [ 184.886839] x11: 0000000000000000 x10: ffff80001110b1e8 [ 184.886845] x9 : 00000000fffffffe x8 : 6575657571207469 [ 184.886850] x7 : 6d736e617274203a x6 : ffff8000114aba70 [ 184.886856] x5 : ffff00003fdb6b40 x4 : 0000000000000000 [ 184.886861] x3 : 0000000000000027 x2 : 0000000100000000 [ 184.886867] x1 : 771f929f21b59300 x0 : 0000000000000000 [ 184.886873] Call trace: [ 184.886876] dev_watchdog+0x374/0x380 [ 184.886886] call_timer_fn.isra.0+0x24/0x80 [ 184.886899] run_timer_softirq+0x4d4/0x548 [ 184.886906] efi_header_end+0x110/0x214 [ 184.886913] run_ksoftirqd+0x50/0xb8 [ 184.886920] smpboot_thread_fn+0x2e4/0x330 [ 184.886928] kthread+0x174/0x198 [ 184.886935] ret_from_fork+0x10/0x30 [ 184.886944] ---[ end trace 0000000000000002 ]--- [ 185.887229] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:8712 dql_avail:-2 free_desc:508 [ 191.030533] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:13856 dql_avail:-2 free_desc:508 [ 195.894529] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:18720 dql_avail:-2 free_desc:508 [ 201.014533] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:23840 dql_avail:-2 free_desc:508 [ 206.134533] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:28960 dql_avail:-2 free_desc:508 [ 212.022531] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:34848 dql_avail:-2 free_desc:508 [ 216.886535] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:39712 dql_avail:-2 free_desc:508 ^C --- 192.168.1.10 ping statistics --- 151 packets transmitted, 0 packets received, 100% packet loss root@am62xx-evm:~# root@am62xx-evm:~# root@am62xx-evm:~# root@am62xx-evm:~# ethtool -S eth0 NIC statistics: p0_rx_good_frames: 116 p0_rx_broadcast_frames: 83 p0_rx_multicast_frames: 33 p0_rx_crc_errors: 0 p0_rx_oversized_frames: 0 p0_rx_undersized_frames: 0 p0_ale_drop: 0 p0_ale_overrun_drop: 0 p0_rx_octets: 12070 p0_tx_good_frames: 0 p0_tx_broadcast_frames: 0 p0_tx_multicast_frames: 0 p0_tx_octets: 0 p0_tx_64B_frames: 75 p0_tx_65_to_127B_frames: 20 p0_tx_128_to_255B_frames: 10 p0_tx_256_to_511B_frames: 11 p0_tx_512_to_1023B_frames: 0 p0_tx_1024B_frames: 0 p0_net_octets: 12070 p0_rx_bottom_fifo_drop: 0 p0_rx_port_mask_drop: 0 p0_rx_top_fifo_drop: 0 p0_ale_rate_limit_drop: 0 p0_ale_vid_ingress_drop: 0 p0_ale_da_eq_sa_drop: 0 p0_ale_block_drop: 0 p0_ale_secure_drop: 0 p0_ale_auth_drop: 0 p0_ale_unknown_ucast: 0 p0_ale_unknown_ucast_bytes: 0 p0_ale_unknown_mcast: 0 p0_ale_unknown_mcast_bytes: 0 p0_ale_unknown_bcast: 0 p0_ale_unknown_bcast_bytes: 0 p0_ale_pol_match: 0 p0_ale_pol_match_red: 0 p0_ale_pol_match_yellow: 0 p0_ale_mcast_sa_drop: 0 p0_ale_dual_vlan_drop: 0 p0_ale_len_err_drop: 0 p0_ale_ip_next_hdr_drop: 0 p0_ale_ipv4_frag_drop: 0 p0_tx_mem_protect_err: 0 p0_tx_pri0: 0 p0_tx_pri1: 0 p0_tx_pri2: 0 p0_tx_pri3: 0 p0_tx_pri4: 0 p0_tx_pri5: 0 p0_tx_pri6: 0 p0_tx_pri7: 0 p0_tx_pri0_bcnt: 0 p0_tx_pri1_bcnt: 0 p0_tx_pri2_bcnt: 0 p0_tx_pri3_bcnt: 0 p0_tx_pri4_bcnt: 0 p0_tx_pri5_bcnt: 0 p0_tx_pri6_bcnt: 0 p0_tx_pri7_bcnt: 0 p0_tx_pri0_drop: 0 p0_tx_pri1_drop: 0 p0_tx_pri2_drop: 0 p0_tx_pri3_drop: 0 p0_tx_pri4_drop: 0 p0_tx_pri5_drop: 0 p0_tx_pri6_drop: 0 p0_tx_pri7_drop: 0 p0_tx_pri0_drop_bcnt: 0 p0_tx_pri1_drop_bcnt: 0 p0_tx_pri2_drop_bcnt: 0 p0_tx_pri3_drop_bcnt: 0 p0_tx_pri4_drop_bcnt: 0 p0_tx_pri5_drop_bcnt: 0 p0_tx_pri6_drop_bcnt: 0 p0_tx_pri7_drop_bcnt: 0 rx_good_frames: 0 rx_broadcast_frames: 0 rx_multicast_frames: 0 rx_pause_frames: 0 rx_crc_errors: 0 rx_align_code_errors: 0 rx_oversized_frames: 0 rx_jabber_frames: 0 rx_undersized_frames: 0 rx_fragments: 0 ale_drop: 0 ale_overrun_drop: 0 rx_octets: 0 tx_good_frames: 0 tx_broadcast_frames: 0 tx_multicast_frames: 0 tx_pause_frames: 0 tx_deferred_frames: 0 tx_collision_frames: 0 tx_single_coll_frames: 0 tx_mult_coll_frames: 0 tx_excessive_collisions: 0 tx_late_collisions: 0 rx_ipg_error: 0 tx_carrier_sense_errors: 0 tx_octets: 0 tx_64B_frames: 0 tx_65_to_127B_frames: 0 tx_128_to_255B_frames: 0 tx_256_to_511B_frames: 0 tx_512_to_1023B_frames: 0 tx_1024B_frames: 0 net_octets: 0 rx_bottom_fifo_drop: 0 rx_port_mask_drop: 0 rx_top_fifo_drop: 0 ale_rate_limit_drop: 0 ale_vid_ingress_drop: 0 ale_da_eq_sa_drop: 0 ale_block_drop: 0 ale_secure_drop: 0 ale_auth_drop: 0 ale_unknown_ucast: 0 ale_unknown_ucast_bytes: 0 ale_unknown_mcast: 0 ale_unknown_mcast_bytes: 0 ale_unknown_bcast: 0 ale_unknown_bcast_bytes: 0 ale_pol_match: 0 ale_pol_match_red: 0 ale_pol_match_yellow: 0 ale_mcast_sa_drop: 0 ale_dual_vlan_drop: 0 ale_len_err_drop: 0 ale_ip_next_hdr_drop: 0 ale_ipv4_frag_drop: 0 iet_rx_assembly_err: 0 iet_rx_assembly_ok: 0 iet_rx_smd_err: 0 iet_rx_frag: 0 iet_tx_hold: 0 iet_tx_frag: 0 tx_mem_protect_err: 0 tx_pri0: 115 tx_pri1: 0 tx_pri2: 0 tx_pri3: 0 tx_pri4: 0 tx_pri5: 0 tx_pri6: 0 tx_pri7: 0 tx_pri0_bcnt: 12006 tx_pri1_bcnt: 0 tx_pri2_bcnt: 0 tx_pri3_bcnt: 0 tx_pri4_bcnt: 0 tx_pri5_bcnt: 0 tx_pri6_bcnt: 0 tx_pri7_bcnt: 0 tx_pri0_drop: 0 tx_pri1_drop: 0 tx_pri2_drop: 0 tx_pri3_drop: 0 tx_pri4_drop: 0 tx_pri5_drop: 0 tx_pri6_drop: 0 tx_pri7_drop: 0 tx_pri0_drop_bcnt: 0 tx_pri1_drop_bcnt: 0 tx_pri2_drop_bcnt: 0 tx_pri3_drop_bcnt: 0 tx_pri4_drop_bcnt: 0 tx_pri5_drop_bcnt: 0 tx_pri6_drop_bcnt: 0 tx_pri7_drop_bcnt: 0 root@am62xx-evm:~# root@am62xx-evm:~# [ 222.006544] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:44832 dql_avail:-2 free_desc:508 root@am62xx-evm:~#
U-Boot 2021.01-g7de8fba018 (Aug 18 2023 - 03:03:09 +0000) SoC: AM62X SR1.0 GP Model: Texas Instruments AM625 SK EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -19 DRAM: 1 GiB MMC: mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2 Loading Environment from MMC... MMC: block number 0x3500 exceeds max(0x1000) *** Warning - !read failed, using default environment In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Net: eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 1490 bytes read in 3 ms (484.4 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 3 ms (0 Bytes/s) Already setup. 18948608 bytes read in 793 ms (22.8 MiB/s) 55779 bytes read in 7 ms (7.6 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008feef000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.10.168-rt83-geae3e59505 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT_RT Wed Aug 30 05:12:30 UTC 2023 [ 0.000000] Machine model: Texas Instruments AM625 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB [ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000bfffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009c7fffff] [ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff] [ 0.000000] node 0: [mem 0x000000009e780000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000bfffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff] [ 0.000000] On node 0 totalpages: 262144 [ 0.000000] DMA zone: 4096 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 262144 pages, LIFO batch:63 [ 0.000000] cma: Failed to reserve 512 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 18 pages/cpu s35968 r8192 d29568 u73728 [ 0.000000] pcpu-alloc: s35968 r8192 d29568 u73728 alloc=18*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=c04c7c71-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 951776K/1048576K available (11072K kernel code, 1224K rwdata, 4308K rodata, 1792K init, 439K bss, 96800K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms. [ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads. [ 0.000000] No expedited grace period (rcu_normal_after_boot). [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008545] Console: colour dummy device 80x25 [ 0.013143] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023825] pid_max: default: 32768 minimum: 301 [ 0.028649] LSM: Security Framework initializing [ 0.033442] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.041016] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.051084] rcu: Hierarchical SRCU implementation. [ 0.056537] Platform MSI: msi-controller@1820000 domain created [ 0.062930] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.072229] EFI services will not be available. [ 0.077191] smp: Bringing up secondary CPUs ... [ 0.082625] Detected VIPT I-cache on CPU1 [ 0.086757] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.093795] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000 [ 0.101235] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.108802] Detected VIPT I-cache on CPU2 [ 0.112929] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.119964] GICv3: CPU2: using allocated LPI pending table @0x0000000080060000 [ 0.127383] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.134866] Detected VIPT I-cache on CPU3 [ 0.138988] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.146022] GICv3: CPU3: using allocated LPI pending table @0x0000000080070000 [ 0.153439] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.160208] smp: Brought up 1 node, 4 CPUs [ 0.164414] SMP: Total of 4 processors activated. [ 0.169233] CPU features: detected: 32-bit EL0 Support [ 0.174495] CPU features: detected: CRC32 instructions [ 0.187096] CPU: All CPU(s) started at EL2 [ 0.191305] alternatives: patching kernel code [ 0.197128] devtmpfs: initialized [ 0.209060] KASLR disabled due to lack of seed [ 0.213829] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.223808] futex hash table entries: 1024 (order: 5, 131072 bytes, linear) [ 0.231316] pinctrl core: initialized pinctrl subsystem [ 0.237265] DMI not present or invalid. [ 0.241887] NET: Registered protocol family 16 [ 0.247021] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations [ 0.254295] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.262244] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.270947] thermal_sys: Registered thermal governor 'step_wise' [ 0.271553] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.284716] ASID allocator initialised with 65536 entries [ 0.317510] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.324420] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.331283] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.338145] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.346046] cryptd: max_cpu_qlen set to 1000 [ 0.353613] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected [ 0.362827] vcc_5v0: supplied by vmain_pd [ 0.367401] vcc_3v3_sys: supplied by vmain_pd [ 0.372404] vcc_1v8: supplied by vcc_3v3_sys [ 0.377848] iommu: Default domain type: Translated [ 0.383274] SCSI subsystem initialized [ 0.387634] mc: Linux media interface: v0.10 [ 0.392037] videodev: Linux video capture interface: v2.00 [ 0.397770] pps_core: LinuxPPS API ver. 1 registered [ 0.402853] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.412204] PTP clock support registered [ 0.416243] EDAC MC: Ver: 3.0.0 [ 0.420315] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100 [ 0.427543] FPGA manager framework [ 0.431143] Advanced Linux Sound Architecture Driver Initialized. [ 0.438370] clocksource: Switched to clocksource arch_sys_counter [ 0.444840] VFS: Disk quotas dquot_6.6.0 [ 0.448930] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.462097] NET: Registered protocol family 2 [ 0.466816] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.475343] tcp_listen_portaddr_hash hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.484066] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.492072] TCP bind hash table entries: 8192 (order: 6, 458752 bytes, linear) [ 0.499974] TCP: Hash tables configured (established 8192 bind 8192) [ 0.506820] UDP hash table entries: 512 (order: 4, 65536 bytes, linear) [ 0.513706] UDP-Lite hash table entries: 512 (order: 4, 65536 bytes, linear) [ 0.521243] NET: Registered protocol family 1 [ 0.526301] RPC: Registered named UNIX socket transport module. [ 0.532401] RPC: Registered udp transport module. [ 0.537211] RPC: Registered tcp transport module. [ 0.542019] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.548610] NET: Registered protocol family 44 [ 0.553169] PCI: CLS 0 bytes, default 64 [ 0.558089] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.570569] Initialise system trusted keyrings [ 0.575393] workingset: timestamp_bits=46 max_order=18 bucket_order=0 [ 0.586959] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.593684] NFS: Registering the id_resolver key type [ 0.598939] Key type id_resolver registered [ 0.603233] Key type id_legacy registered [ 0.607413] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.614279] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.622095] 9p: Installing v9fs 9p2000 file system support [ 0.662226] Key type asymmetric registered [ 0.666453] Asymmetric key parser 'x509' registered [ 0.671501] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.679076] io scheduler mq-deadline registered [ 0.683729] io scheduler kyber registered [ 0.690212] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.696608] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.711206] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.733014] brd: module loaded [ 0.745362] loop: module loaded [ 0.749553] megasas: 07.714.04.00-rc1 [ 0.757836] tun: Universal TUN/TAP device driver, 1.6 [ 0.763703] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.770155] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.776287] sky2: driver version 1.30 [ 0.781075] VFIO - User Level meta-driver version: 0.3 [ 0.787602] i2c /dev entries driver [ 0.793072] sdhci: Secure Digital Host Controller Interface driver [ 0.799434] sdhci: Copyright(c) Pierre Ossman [ 0.804261] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.811498] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.819929] optee: probing for conduit method. [ 0.824556] optee: revision 3.20 (8e74d476) [ 0.824860] optee: dynamic shared memory is enabled [ 0.834412] optee: initialized driver [ 0.840522] NET: Registered protocol family 17 [ 0.845307] 9pnet: Installing 9P2000 support [ 0.849793] Key type dns_resolver registered [ 0.854596] printk: bootconsole [ns16550a0]: printing thread started [ 0.854648] Loading compiled-in X.509 certificates [ 0.867471] ti-sci 44043000.system-controller: lpm region is required for suspend but not provided. [ 0.867517] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.6.4--v08.06.04 (Chill Capybar') [ 0.932465] davinci-mcasp 2b10000.mcasp: IRQ common not found [ 0.935194] omap-gpmc 3b000000.memory-controller: GPMC revision 6.0 [ 0.935214] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000 [ 0.964018] VDD_CORE: Bringing 750000uV into 850000-850000uV [ 0.964872] VDD_CORE: supplied by vcc_5v0 [ 0.965706] VCC1V8: supplied by vcc_5v0 [ 0.966442] VDDS_DDR: supplied by vcc_5v0 [ 0.967578] VDDSHV_MCU: supplied by vcc_5v0 [ 0.967926] VDDR_CORE: supplied by VCC1V8 [ 0.968938] VDDA_1V8: supplied by vcc_5v0 [ 0.969656] VDD_PHY_2V5: supplied by vcc_5v0 [ 0.971486] tps65219 0-0030: Setup as system-power-controller but pm_power_off function already registered, overwriting [ 0.971702] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz [ 0.974193] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz [ r? 瘲tc-s35390a 2-0030: registered as rtc0 [ 1.003284] rtc-s35390a 2-0030: setting system clock to 2023-08-23T03:03:03 UTC (1692759783) [ 1.028742] printk: console [ttyS2]: printing thread started [ 1.003353] omap_i2c 20030000.i2c: bus 2 rev0.12 at 100 kHz [ 1.028759] printk: console [ttyS2] enabled [ 1.028763] printk: bootconsole [ns16550a0] disabled [ 1.048775] printk: bootconsole [ns16550a0]: printing thread stopped [ 1.049921] panel-simple display0: Specify missing connector_type [ 1.061766] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode [ 1.098384] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.099664] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver RTL8201F Fast Ethernet [ 1.099830] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006 [ 1.099959] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.099965] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.100851] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0 [ 1.102133] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.105769] rtc-ti-k3 2b1f0000.rtc: registered as rtc1 [ 1.210807] mmc2: CQHCI version 5.10 [ 1.210858] mmc0: CQHCI version 5.10 [ 1.213098] davinci-mcasp 2b10000.mcasp: IRQ common not found [ 1.230642] pinctrl-single f4000.pinctrl: pin PIN117 already requested by 20030000.i2c; cannot claim for 1-0022 [ 1.230662] pinctrl-single f4000.pinctrl: pin-117 (1-0022) status -22 [ 1.230669] pinctrl-single f4000.pinctrl: could not request pin 117 (PIN117) from group main-gpio1-ioexp-intr-pins-default on device pinctrl-single [ 1.230676] pca953x 1-0022: Error applying setting, reverse things back [ 1.230694] pca953x: probe of 1-0022 failed with error -22 [ 1.231719] panel-simple display0: Specify missing connector_type [ 1.234017] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0 [ 1.262654] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.268048] Console: switching to colour frame buffer device 100x37 [ 1.284074] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device [ 1.292786] mmc1: CQHCI version 5.10 [ 1.293646] debugfs: Directory 'pd:53' with parent 'pm_genpd' already present! [ 1.293728] debugfs: Directory 'pd:52' with parent 'pm_genpd' already present! [ 1.293764] debugfs: Directory 'pd:51' with parent 'pm_genpd' already present! [ 1.294460] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present! [ 1.308127] ALSA device list: [ 1.308141] No soundcards found. [ 1.339369] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 1.357933] mmc0: new HS200 MMC card at address 0001 [ 1.358852] mmcblk0: mmc0:0001 004GA0 3.69 GiB [ 1.359174] mmcblk0boot0: mmc0:0001 004GA0 partition 1 2.00 MiB [ 1.359487] mmcblk0boot1: mmc0:0001 004GA0 partition 2 2.00 MiB [ 1.359713] mmcblk0rpmb: mmc0:0001 004GA0 partition 3 512 KiB, chardev (237:0) [ 1.361360] mmcblk0: p1 p2 p3 p4 [ 1.427054] mmc1: error -84 whilst initialising SD card [ 1.655843] mmc1: new ultra high speed SDR50 SDXC card at address 59b4 [ 1.656776] mmcblk1: mmc1:59b4 ED2S5 119 GiB [ 1.658745] mmcblk1: p1 p2 [ 2.727963] sdhci-am654 fa20000.mmc: Power on failed [ 2.758593] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit [ 2.765599] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 2.765702] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 2.766533] devtmpfs: mounted [ 2.767905] Freeing unused kernel memory: 1792K [ 2.786459] Run /sbin/init as init process [ 3.001379] NET: Registered protocol family 10 [ 3.002771] Segment Routing with IPv6 [ 3.032227] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 3.032707] systemd[1]: Detected architecture arm64. Welcome to Arago 2021.09! [ 3.079278] systemd[1]: Set hostname to <am62xx-evm>. [ 3.085015] random: systemd: uninitialized urandom read (16 bytes read) [ 3.085115] systemd[1]: Initializing machine ID from random generator. [ 3.427990] random: systemd: uninitialized urandom read (16 bytes read) [ 3.431741] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ OK ] Created slice system-serial\x2dgett[ 3.458652] random: systemd: uninitialized urandom read (16 bytes read) [ 3.460196] systemd[1]: Created slice system-serial\x2dgetty.slice. y.slice. [ OK ] Created slice User and Session Slic[ 3.491893] systemd[1]: Created slice User and Session Slice. e. [ OK ] Started Dispatch Password …ts to [ 3.515004] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. Console Directory Watch. [ OK ] Started Forward Password R…uests [ 3.538829] systemd[1]: Started Forward Password Requests to Wall Directory Watch. to Wall Directory Watch. [ OK ] Reached target Paths. [ 3.562761] systemd[1]: Reached target Paths. [ OK ] Reached target Remote File Systems systemd[1]: Reached target Remote File Systems. [0m. [ OK ] Reached target Slices. [ 3.594541] systemd[1]: Reached target Slices. [ OK ] Reached target Swap. [ 3.606567] systemd[1]: Reached target Swap. [ OK ] Listening on RPCbind Server Activat[ 3.640058] systemd[1]: Listening on RPCbind Server Activation Socket. ion Socket. [ OK ] Reached target RPC Port Mapper.[ 3.666813] systemd[1]: Reached target RPC Port Mapper. [ OK ] Listening on Process Core Dump Sock[ 3.691441] systemd[1]: Listening on Process Core Dump Socket. et. [ OK ] Listening on initctl Compatibility [ 3.715095] systemd[1]: Listening on initctl Compatibility Named Pipe. Named Pipe. [ 3.742310] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 3.743472] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket. [ 3.771351] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Network Service Netlin[ 3.783448] systemd[1]: Listening on Network Service Netlink Socket. k Socket. [ OK ] Listening on udev Control Socket 3.807281] systemd[1]: Listening on udev Control Socket. m. [ OK ] Listening on udev Kernel Socket[ 3.831066] systemd[1]: Listening on udev Kernel Socket. . Mounting Huge Pages File System... [ 3.855721] systemd[1]: Mounting Huge Pages File System... Mounting POSIX Message Queue File System..[ 3.871786] systemd[1]: Mounting POSIX Message Queue File System... . Mounting Kernel Debug File System... [ 3.899546] systemd[1]: Mounting Kernel Debug File System... Mounting Temporary Directory (/tmp)... [ 3.916295] systemd[1]: Mounting Temporary Directory (/tmp)... Starting Create list of st…odes for the curr[ 3.936012] systemd[1]: Starting Create list of static device nodes for the current kernel... ent kernel... Starting Start psplash boot splash screen.[ 3.975180] systemd[1]: Starting Start psplash boot splash screen... .. [ 4.004923] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 4.031004] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 4.038832] systemd[1]: Starting Journal Service... Starting Journal Service... Starting Load Kernel Modules... [ 4.074002] systemd[1]: Starting Load Kernel Modules... [ 4.086880] random: systemd: uninitialized urandom read (16 bytes read) [ 4.094522] systemd[1]: Starting Remount Root and Kernel File Systems... [ 4.094618] cryptodev: loading out-of-tree module taints kernel. Starting Remount Root and Kernel File Systems cryptodev: driver 1.10 loaded. [0m... [ 4.127517] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [ 4.131877] random: systemd-journal: uninitialized urandom read (16 bytes read) [ 4.132086] random: systemd-journal: uninitialized urandom read (16 bytes read) [ 4.148582] systemd[1]: Starting udev Coldplug all Devices... Starting udev Coldplug all Devices... [ OK ] Started Start psplash boot splash s[ 4.173352] systemd[1]: Started Start psplash boot splash screen. creen. [ OK ] Started RPC Bind. [ 4.195407] systemd[1]: Started RPC Bind. [ OK ] Started Journal Service.[ 4.211428] systemd[1]: Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Started Create list of sta… nodes for the current kernel. [ OK ] Started Load Kernel Modules. [ OK ] Started Remount Root and Kernel File Systems. Mounting Kernel Configuration File System... [ OK ] Started Start psplash-syst…progress communication helper. Starting Flush Journal to Persistent Storage... [ 4.434520] systemd-journald[232]: Received client request to flush runtime journal. Starting Apply Kernel Variables... Starting Create System Users... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Apply Kernel Variables. [ OK ] Started Create System Users. Starting Create Static Device Nodes in /dev... [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Reached target Local File Systems (Pre). Mounting /media/ram... Mounting /var/volatile... Starting udev Kernel Device Manager... [ OK ] Started udev Coldplug all Devices. [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Rebuild Dynamic Linker Cache... Starting Create Volatile Files and Directories... [ OK ] Started udev Kernel Device Manager. [ OK ] Started Create Volatile Files and Directories. Starting Run pending postinsts... Starting Rebuild Journal Catalog... Starting Network Time Synchronization... [ 5.129399] random: systemd-journal: uninitialized urandom read (16 bytes read) [ 5.139210] random: systemd: uninitialized urandom read (16 bytes read) Starting Update UTMP about System Boot/Shutdown... [ 5.195081] random: systemd-journal: uninitialized urandom read (16 bytes read) [ OK ] Started Rebuild Journal Catalog. [ OK ] Started Rebuild Dynamic Linker Cache. Starting Update is Completed... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Update is Completed. [ OK ] Started Run pending postinsts. [ OK ] Created slice system-systemd\x2dbacklight.slice. Starting Load/Save Screen …ness of backlight:backlight... [ 6.252310] random: systemd-journal: uninitialized urandom read (16 bytes read) [ OK ] Started Load/Save Screen B…htness of backlight:backlight. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target System Time Set. [ OK ] Reached target System Time Synchronized. [ OK ] Reached target Timers. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. [ 6.499278] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000 [ 6.499444] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode [ 6.499514] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device [ 6.536065] remoteproc remoteproc0: 5000000.m4fss is available [ 6.537019] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2 [ 6.537052] remoteproc remoteproc0: powering up 5000000.m4fss [ 6.537083] remoteproc remoteproc0: Direct firmware load for am62-mcu-m4f0_0-fw failed with error -2 [ 6.537091] remoteproc remoteproc0: request_firmware failed: -2 [ 6.582465] random: crng init done [ 6.582489] random: 89 urandom warning(s) missed due to ratelimiting [ OK ] Listening on dropbear.socket. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. [ OK ] Started D-Bus System Message Bus. Starting Print notice about GPLv3 packages... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... Starting Login Service... [ OK ] Started TEE Supplicant. [ 6.947612] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 6.948339] platform 78000000.r5f: configured R5F for IPC-only mode [ 6.948582] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000 [ 6.960113] remoteproc remoteproc1: 78000000.r5f is available Starting telnetd.service...[ 6.960328] remoteproc remoteproc1: attaching to 78000000.r5f [ 6.968087] platform 78000000.r5f: R5F core initialized in IPC-only mode [ 6.968136] remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@9da00000 [ 7.004257] virtio_rpmsg_bus virtio0: rpmsg host is online [ 7.006336] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 7.007349] remoteproc1#vdev0buffer: registered virtio0 (type 7) [ 7.007376] remoteproc remoteproc1: remote processor 78000000.r5f is now attached [ 7.047405] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ OK ] Started IPv6 Packet Filtering Framework. [ OK ] Started IPv4 Packet Filtering Framework. [ OK ] Started telnetd.service. [ OK ] Reached target Network (Pre). Starting LSB: Expand Rootfs of boot device... Starting Network Service... [ OK ] Started Network Service. Starting Wait for Network to be Configured... Starting Network Name Resolution... [ 7.819268] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [RTL8201F Fast Ethernet] (irq=POLL) [ 7.819312] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode [ OK ] Started Login Service. [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name Lookups. Starting Avahi mDNS/DNS-SD Stack... [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Permit User Sessions... [ OK ] Started Permit User Sessions. [ OK ] Started Getty on tty1. [ 8.457099] EXT4-fs (mmcblk1p2): resizing filesystem from 326588 to 125035520 blocks [ OK ] Started Serial Getty on ttyS2. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... [ OK ] Started Avahi mDNS/DNS-SD Stack. [ OK ] Started Synchronize System and HW clocks. *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: bash cifs-utils dosfstools less libdw1 libelf1 libreadline8 parted If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ OK ] Started Print notice about GPLv3 packages. [ OK ] Created slice system-systemd\x2dfsck.slice. [ OK ] Found device /dev/mmcblk1p1. Starting File System Check on /dev/mmcblk1p1... [ OK ] Found device /dev/mmcblk0p3. Starting File System Check on /dev/mmcblk0p3... [ OK ] Found device /dev/mmcblk0p1. Starting File System Check on /dev/mmcblk0p1... [ OK ] Started File System Check on /dev/mmcblk1p1. [ OK ] Found device /dev/mmcblk0p4. Mounting /run/media/mmcblk1p1... Starting File System Check on /dev/mmcblk0p4... [ OK ] Started File System Check on /dev/mmcblk0p3. Mounting /run/media/mmcblk0p3... [ OK ] Started File System Check on /dev/mmcblk0p1. [ OK ] Mounted /run/media/mmcblk1p1. [ 10.859950] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null) [ 10.860016] ext4 filesystem being mounted at /run/media/mmcblk0p3 supports timestamps until 2038 (0x7fffffff) [ OK ] Started File System Check on /dev/mmcblk0p4. [ 10.901643] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 10.903773] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ OK ] Mounted /run/media/mmcblk0p3. Mounting /run/media/mmcblk0p1... Mounting /run/media/mmcblk0p4... [ 11.250560] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null) [ OK ] Mounted /run/media/mmcblk0p1. [ OK ] Mounted /run/media/mmcblk0p4. [ 11.303987] remoteproc remoteproc2: 30074000.pru is available [ 11.378991] remoteproc remoteproc3: 30078000.pru is available [ 11.599434] cdns-csi2rx: probe of 30101000.csi-bridge failed with error -22 Starting Save/Restore Sound Card State... [ OK ] Reached target Hardware activated USB gadget. [ 11.973694] usbcore: registered new interface driver usbfs [ 11.973860] usbcore: registered new interface driver hub [ 11.987795] usbcore: registered new device driver usb [ OK ] Started Save/Restore Sound Card State. [ OK ] Reached target Sound Card. [ 12.152037] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 12.152277] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 [ 12.152528] xhci-hcd xhci-hcd.2.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000000000010010 [ 12.166944] xhci-hcd xhci-hcd.2.auto: irq 510, io mem 0x31100000 [ 12.167255] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 12.167288] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [ 12.167321] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed [ 12.167799] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 12.167815] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 12.167823] usb usb1: Product: xHCI Host Controller [ 12.167827] usb usb1: Manufacturer: Linux 5.10.168-rt83-geae3e59505 xhci-hcd [ 12.167832] usb usb1: SerialNumber: xhci-hcd.2.auto [ 12.280006] hub 1-0:1.0: USB hub found [ 12.280101] hub 1-0:1.0: 1 port detected [ 12.318589] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 12.318729] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 12.318739] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 12.318746] usb usb2: Product: xHCI Host Controller [ 12.318750] usb usb2: Manufacturer: Linux 5.10.168-rt83-geae3e59505 xhci-hcd [ 12.318755] usb usb2: SerialNumber: xhci-hcd.2.auto [ 12.352633] EXT4-fs (mmcblk1p2): resizing filesystem from 33947649 to 125035520 blocks [ 12.352667] EXT4-fs (mmcblk1p2): Converting file system to meta_bg [ 12.352811] EXT4-fs (mmcblk1p2): resizing filesystem from 33947649 to 125035520 blocks [ 12.364493] hub 2-0:1.0: USB hub found [ 12.364568] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19) [ 12.554457] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 12.710779] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3 [ 12.710807] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 12.778574] hub 1-1:1.0: USB hub found [ 12.778686] hub 1-1:1.0: 4 ports detected [ 13.136011] usb 1-1.4: new high-speed USB device number 3 using xhci-hcd [ 14.195904] usb 1-1.4: New USB device found, idVendor=1005, idProduct=b128, bcdDevice= 1.00 [ 14.195932] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 14.195937] usb 1-1.4: Product: FLASH DRIVE [ 14.195942] usb 1-1.4: Manufacturer: USB3.0 [ 14.195968] usb 1-1.4: SerialNumber: 07000312EFB1F358 [ 14.259684] usb-storage 1-1.4:1.0: USB Mass Storage device detected [ 14.260448] scsi host0: usb-storage 1-1.4:1.0 [ 14.260938] usbcore: registered new interface driver usb-storage _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project am62xx-evm ttyS2 Arago 2021.09 am62xx-evm ttyS2 am62xx-evm login: [ 15.283118] scsi 0:0:0:0: Direct-Access USB3.0 FLASH DRIVE PMAP PQ: 0 ANSI: 6 [ 15.298951] sd 0:0:0:0: [sda] 30310400 512-byte logical blocks: (15.5 GB/14.5 GiB) [ 15.300202] sd 0:0:0:0: [sda] Write Protect is off [ 15.301443] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [ 15.453269] sda: sda1 [ 15.463907] sd 0:0:0:0: [sda] Attached SCSI removable disk am62xx-evm login: [ 18.483860] EXT4-fs (mmcblk1p2): resized to 75628545 blocks am62xx-evm login: root root@am62xx-evm:~# root@am62xx-evm:~# [ 28.499752] EXT4-fs (mmcblk1p2): resized to 119275521 blocks root@am62xx-evm:~# root@am62xx-evm:~# root@am62xx-evm:~# root@am62xx-evm:~# [ 30.297895] EXT4-fs (mmcblk1p2): resized filesystem to 125035520 root@am62xx-evm:~# root@am62xx-evm:~# root@am62xx-evm:~# root@am62xx-evm:~# ifconfig eth0 Link encap:Ethernet HWaddr 1C:63:49:07:F1:D4 inet6 addr: fe80::1e63:49ff:fe07:f1d4/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:24 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:4116 (4.0 KiB) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:82 errors:0 dropped:0 overruns:0 frame:0 TX packets:82 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:6220 (6.0 KiB) TX bytes:6220 (6.0 KiB) root@am62xx-evm:~# ifconfig eth0 192.168.1.55 root@am62xx-evm:~# ping 192.168.1.10 PING 192.168.1.10 (192.168.1.10): 56 data bytes [ 172.082376] ------------[ cut here ]------------ [ 172.082398] NETDEV WATCHDOG: eth0 (am65-cpsw-nuss): transmit queue 0 timed out [ 172.082480] WARNING: CPU: 1 PID: 22 at net/sched/sch_generic.c:467 dev_watchdog+0x374/0x380 [ 172.082508] Modules linked in: usb_storage xhci_plat_hcd xhci_hcd rpmsg_char usbcore dwc3 cdns_csi2rx udc_core v4l2_fwnode usb_common irq_pruss_intc pru_rproc crct10dif_ce snd_soc_simple_card snd_soc_simple_card_utils ti_k3_r5_remoteproc dwc3_am62 virtio_rpmsg_bus rti_wdt ti_k3_m4_remoteproc sa2ul j721e_csi2rx videobuf2_dma_contig videobuf2_memops sha512_generic authenc videobuf2_v4l2 videobuf2_common pruss cdns_dphy mcrc tps6598x typec roles snd_soc_tlv320aic3x sch_fq_codel cryptodev(O) ipv6 [ 172.082609] CPU: 1 PID: 22 Comm: ksoftirqd/1 Tainted: G O 5.10.168-rt83-geae3e59505 #1 [ 172.082616] Hardware name: Texas Instruments AM625 SK (DT) [ 172.082621] pstate: 40000005 (nZcv daif -PAN -UAO -TCO BTYPE=--) [ 172.082628] pc : dev_watchdog+0x374/0x380 [ 172.082634] lr : dev_watchdog+0x374/0x380 [ 172.082640] sp : ffff800011473c20 [ 172.082642] x29: ffff800011473c20 x28: ffff000001de9b00 [ 172.082649] x27: 0000000000000004 x26: 0000000000000180 [ 172.082654] x25: 00000000ffffffff x24: 0000000000000001 [ 172.082660] x23: ffff000001de83e0 x22: ffff000001de8000 [ 172.082666] x21: ffff000001de84b0 x20: ffff8000110e9000 [ 172.082671] x19: 0000000000000000 x18: 0000000000000000 [ 172.082677] x17: 0000000000000000 x16: 0000000000000000 [ 172.082682] x15: ffff000000160560 x14: ffffffffffffffff [ 172.082688] x13: ffff800011224e06 x12: ffff800011224df9 [ 172.082694] x11: 000000000000003d x10: ffff80001110b1e8 [ 172.082700] x9 : 00000000fffffffe x8 : 64656d6974203020 [ 172.082705] x7 : 6575657571207469 x6 : ffff800011473a70 [ 172.082711] x5 : ffff00003fda4b40 x4 : 0000000000000000 [ 172.082716] x3 : 0000000000000027 x2 : 0000000100000000 [ 172.082721] x1 : 43904581fef12400 x0 : 0000000000000000 [ 172.082728] Call trace: [ 172.082731] dev_watchdog+0x374/0x380 [ 172.082738] call_timer_fn.isra.0+0x24/0x80 [ 172.082752] run_timer_softirq+0x4d4/0x548 [ 172.082759] efi_header_end+0x110/0x214 [ 172.082765] run_ksoftirqd+0x50/0xb8 [ 172.082772] smpboot_thread_fn+0x2e4/0x330 [ 172.082781] kthread+0x174/0x198 [ 172.082791] ret_from_fork+0x10/0x30 [ 172.082799] ---[ end trace 0000000000000002 ]--- [ 173.083067] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:7272 dql_avail:-2 free_desc:508 [ 177.970393] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:12160 dql_avail:-2 free_desc:508 [ 183.090393] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:17280 dql_avail:-2 free_desc:508 [ 187.954390] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:22144 dql_avail:-2 free_desc:508 [ 193.074394] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:27264 dql_avail:-2 free_desc:508 [ 197.938391] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:32128 dql_avail:-2 free_desc:508 [ 203.058391] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:37248 dql_avail:-2 free_desc:508 ^C --- 192.168.1.10 ping statistics --- 152 packets transmitted, 0 packets received, 100% packet loss root@am62xx-evm:~# [ 207.922397] am65-cpsw-nuss 8000000.ethernet eth0: txq:0 DRV_XOFF:0 tmo:42112 dql_avail:-2 free_desc:508 root@am62xx-evm:~# root@am62xx-evm:~# root@am62xx-evm:~# ethtool -S eth0 NIC statistics: p0_rx_good_frames: 116 p0_rx_broadcast_frames: 83 p0_rx_multicast_frames: 33 p0_rx_crc_errors: 0 p0_rx_oversized_frames: 0 p0_rx_undersized_frames: 0 p0_ale_drop: 0 p0_ale_overrun_drop: 0 p0_rx_octets: 12090 p0_tx_good_frames: 0 p0_tx_broadcast_frames: 0 p0_tx_multicast_frames: 0 p0_tx_octets: 0 p0_tx_64B_frames: 75 p0_tx_65_to_127B_frames: 20 p0_tx_128_to_255B_frames: 10 p0_tx_256_to_511B_frames: 11 p0_tx_512_to_1023B_frames: 0 p0_tx_1024B_frames: 0 p0_net_octets: 12090 p0_rx_bottom_fifo_drop: 0 p0_rx_port_mask_drop: 0 p0_rx_top_fifo_drop: 0 p0_ale_rate_limit_drop: 0 p0_ale_vid_ingress_drop: 0 p0_ale_da_eq_sa_drop: 0 p0_ale_block_drop: 0 p0_ale_secure_drop: 0 p0_ale_auth_drop: 0 p0_ale_unknown_ucast: 0 p0_ale_unknown_ucast_bytes: 0 p0_ale_unknown_mcast: 0 p0_ale_unknown_mcast_bytes: 0 p0_ale_unknown_bcast: 0 p0_ale_unknown_bcast_bytes: 0 p0_ale_pol_match: 0 p0_ale_pol_match_red: 0 p0_ale_pol_match_yellow: 0 p0_ale_mcast_sa_drop: 0 p0_ale_dual_vlan_drop: 0 p0_ale_len_err_drop: 0 p0_ale_ip_next_hdr_drop: 0 p0_ale_ipv4_frag_drop: 0 p0_tx_mem_protect_err: 0 p0_tx_pri0: 0 p0_tx_pri1: 0 p0_tx_pri2: 0 p0_tx_pri3: 0 p0_tx_pri4: 0 p0_tx_pri5: 0 p0_tx_pri6: 0 p0_tx_pri7: 0 p0_tx_pri0_bcnt: 0 p0_tx_pri1_bcnt: 0 p0_tx_pri2_bcnt: 0 p0_tx_pri3_bcnt: 0 p0_tx_pri4_bcnt: 0 p0_tx_pri5_bcnt: 0 p0_tx_pri6_bcnt: 0 p0_tx_pri7_bcnt: 0 p0_tx_pri0_drop: 0 p0_tx_pri1_drop: 0 p0_tx_pri2_drop: 0 p0_tx_pri3_drop: 0 p0_tx_pri4_drop: 0 p0_tx_pri5_drop: 0 p0_tx_pri6_drop: 0 p0_tx_pri7_drop: 0 p0_tx_pri0_drop_bcnt: 0 p0_tx_pri1_drop_bcnt: 0 p0_tx_pri2_drop_bcnt: 0 p0_tx_pri3_drop_bcnt: 0 p0_tx_pri4_drop_bcnt: 0 p0_tx_pri5_drop_bcnt: 0 p0_tx_pri6_drop_bcnt: 0 p0_tx_pri7_drop_bcnt: 0 rx_good_frames: 0 rx_broadcast_frames: 0 rx_multicast_frames: 0 rx_pause_frames: 0 rx_crc_errors: 0 rx_align_code_errors: 0 rx_oversized_frames: 0 rx_jabber_frames: 0 rx_undersized_frames: 0 rx_fragments: 0 ale_drop: 0 ale_overrun_drop: 0 rx_octets: 0 tx_good_frames: 0 tx_broadcast_frames: 0 tx_multicast_frames: 0 tx_pause_frames: 0 tx_deferred_frames: 0 tx_collision_frames: 0 tx_single_coll_frames: 0 tx_mult_coll_frames: 0 tx_excessive_collisions: 0 tx_late_collisions: 0 rx_ipg_error: 0 tx_carrier_sense_errors: 0 tx_octets: 0 tx_64B_frames: 0 tx_65_to_127B_frames: 0 tx_128_to_255B_frames: 0 tx_256_to_511B_frames: 0 tx_512_to_1023B_frames: 0 tx_1024B_frames: 0 net_octets: 0 rx_bottom_fifo_drop: 0 rx_port_mask_drop: 0 rx_top_fifo_drop: 0 ale_rate_limit_drop: 0 ale_vid_ingress_drop: 0 ale_da_eq_sa_drop: 0 ale_block_drop: 0 ale_secure_drop: 0 ale_auth_drop: 0 ale_unknown_ucast: 0 ale_unknown_ucast_bytes: 0 ale_unknown_mcast: 0 ale_unknown_mcast_bytes: 0 ale_unknown_bcast: 0 ale_unknown_bcast_bytes: 0 ale_pol_match: 0 ale_pol_match_red: 0 ale_pol_match_yellow: 0 ale_mcast_sa_drop: 0 ale_dual_vlan_drop: 0 ale_len_err_drop: 0 ale_ip_next_hdr_drop: 0 ale_ipv4_frag_drop: 0 iet_rx_assembly_err: 0 iet_rx_assembly_ok: 0 iet_rx_smd_err: 0 iet_rx_frag: 0 iet_tx_hold: 0 iet_tx_frag: 0 tx_mem_protect_err: 0 tx_pri0: 115 tx_pri1: 0 tx_pri2: 0 tx_pri3: 0 tx_pri4: 0 tx_pri5: 0 tx_pri6: 0 tx_pri7: 0 tx_pri0_bcnt: 12026 tx_pri1_bcnt: 0 tx_pri2_bcnt: 0 tx_pri3_bcnt: 0 tx_pri4_bcnt: 0 tx_pri5_bcnt: 0 tx_pri6_bcnt: 0 tx_pri7_bcnt: 0 tx_pri0_drop: 0 tx_pri1_drop: 0 tx_pri2_drop: 0 tx_pri3_drop: 0 tx_pri4_drop: 0 tx_pri5_drop: 0 tx_pri6_drop: 0 tx_pri7_drop: 0 tx_pri0_drop_bcnt: 0 tx_pri1_drop_bcnt: 0 tx_pri2_drop_bcnt: 0 tx_pri3_drop_bcnt: 0 tx_pri4_drop_bcnt: 0 tx_pri5_drop_bcnt: 0 tx_pri6_drop_bcnt: 0 tx_pri7_drop_bcnt: 0 root@am62xx-evm:~#
