Part Number: TDA4VM
Hi, TI support team.
Using PSDKLA8.1. So we choose to use DSI interface to output image (superframe: 2*640x480 as 1280x480) in RTOS.
Refer to this case, So we modified the resoluation to 1280x480 in Vision-apps, and replaced Elephant image by using 1280x480 in TI-DL demo.
We made chages: 1. RTOS Driver and 2. Vision-apps.
From 28c8c2592f73f574dfdcaae77f501dee20c1550c Mon Sep 17 00:00:00 2001
Date: Tue, 14 Feb 2023 15:12:37 +0800
Subject: [PATCH] [BSP] DSI bring-up For DLP Module & update RTOS driver
Change-Id: Ib71f849a41182c799ef52b636b9a24224286a51a
diff --git a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/pdk_jacinto_08_01_00_36/packages/ti/board/src/devices/common/common.c b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/pdk_jacinto_08_01_00_36/packages/ti/board/src/devices/common/common.c
index 6541a5a..605d598 100755
--- a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/pdk_jacinto_08_01_00_36/packages/ti/board/src/devices/common/common.c
+++ b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/pdk_jacinto_08_01_00_36/packages/ti/board/src/devices/common/common.c
@@ -128,6 +128,168 @@
return BOARD_SOK;
+Board_STATUS Uled_Eviyos_ReadReg(void *handle,
+ uint32_t slaveAddr,
+ uint8_t regAddr,
+ uint32_t *regData,
+ uint8_t numOfBytes,
+ uint8_t byteOrdSel,
+ uint32_t i2cTimeout)
+ Board_STATUS ret = BOARD_SOK;
+ I2C_Transaction transaction;
+ uint8_t tx[2];
+ I2C_Handle i2cHandle = (I2C_Handle)handle;
+ /* Initializes the I2C transaction structure with default values */
+ I2C_transactionInit(&transaction);
+ transaction.slaveAddress = slaveAddr;
+ transaction.writeBuf = &tx[0];
+ transaction.writeCount = 1;
+ transaction.readBuf = NULL;
+ transaction.readCount = 0;
+ transaction.timeout = i2cTimeout;
+ /* 16-bit regAddr data to be sent */
+ if(byteOrdSel == BOARD_I2C_REG_ADDR_MSB_FIRST)
+ tx[0] = (uint8_t)(regAddr & 0xFF);
+ ret = I2C_transfer(i2cHandle, &transaction);
+ if(ret != I2C_STS_SUCCESS)
+ BOARD_DEVICES_ERR_LOG("Failing while transmitting the rd reg addr with error code - %d\n", ret);
+ ret = -1;
+ return ret;
+ transaction.writeBuf = NULL;
+ transaction.writeCount = 0;
+ transaction.readBuf = regData;
+ transaction.readCount = numOfBytes;
+ BOARD_DEVICES_ERR_LOG("Failing while reading the register data by returning - %d\n", ret);
+ ret = -1;
+ return ret;
+ return BOARD_SOK;
+Board_STATUS Board_i2c16BitRegWr16bit(void *handle,
+ uint16_t regAddr,
+ uint16_t *regVal,
+ uint8_t rawRegVal[4];
+#if 1
+ if (numOfBytes > 4u) {
+ ret = BOARD_INVALID_PARAM;
+#endif
+ if(BOARD_SOK == ret) {
+ transaction.writeBuf = rawRegVal;
+ transaction.writeCount = numOfBytes;
+ if (byteOrdSel == BOARD_I2C_REG_ADDR_MSB_FIRST) {
+ /* Convert Registers address and value into 8bit array */
+ rawRegVal[0U] = (uint8_t) ((regAddr >> 8U) & (uint8_t) 0xFF);
+ rawRegVal[1U] = (uint8_t) ((regAddr >> 0U) & (uint8_t) 0xFF);
+ rawRegVal[2U] = (uint8_t) ((*regVal >> 8U) & (uint8_t) 0xFF);
+ rawRegVal[3U] = (uint8_t) ((*regVal >> 0U) & (uint8_t) 0xFF);
+ printf("ZPF_I2C: %s ret = %d !! \n", __func__, ret);
+ if(ret != I2C_STS_SUCCESS) {
+ "Failing while writing data by returning - %d\n\r", ret);
+ ret = -1;
+ return ret;
+ return BOARD_SOK;
+Board_STATUS Board_i2c8BitRegWr32bit(void *handle,
+ uint8_t regAddr,
+ uint32_t *regVal,
+ uint8_t rawRegVal[6];
+#if 0
+#endif
+ transaction.writeBuf = &rawRegVal[0];
+ rawRegVal[0U] = (uint8_t) ((regAddr >> 8U) & (uint8_t) 0xFF);//Need_test 16-bit OR 8-bit regAddr
+ rawRegVal[2U] = (uint8_t) ((*regVal >> 24U) & (uint8_t) 0xFF);
+ rawRegVal[3U] = (uint8_t) ((*regVal >> 16U) & (uint8_t) 0xFF);
+ rawRegVal[4U] = (uint8_t) ((*regVal >> 8U) & (uint8_t) 0xFF);
+ rawRegVal[5U] = (uint8_t) ((*regVal >> 0U) & (uint8_t) 0xFF);
+ //printf("ZPF_I2C: %s ret = %d !! \n", __func__, ret);
+ ret = -1;
+ return BOARD_SOK;
* \brief I2C 16-bit register write fuunction
@@ -186,9 +348,10 @@
tx[0] = (uint8_t)(regAddr & 0x00FF);
tx[1] = (uint8_t)((regAddr & 0xFF00) >> 8);
- txPtr = &tx[2];
+ txPtr = &tx[2];
/* regData to be sent */
+ //printf("ZPF_I2C: Ready to send !! \n");
while(numOfBytes)
*txPtr = *regData;
@@ -198,6 +361,7 @@
@@ -474,3 +638,4 @@
return 0;
diff --git a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/pdk_jacinto_08_01_00_36/packages/ti/board/src/devices/common/common.h b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/pdk_jacinto_08_01_00_36/packages/ti/board/src/devices/common/common.h
index 391fda9..0ec1fa2 100755
--- a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/pdk_jacinto_08_01_00_36/packages/ti/board/src/devices/common/common.h
+++ b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/pdk_jacinto_08_01_00_36/packages/ti/board/src/devices/common/common.h
@@ -243,6 +243,35 @@
uint8_t byteOrdSel,
uint32_t i2cTimeout);
+ * @ Description: Added by zhangpeifeng
+ * Just for DLP POC.
+ uint16_t regAddr,
+ uint16_t *regData,
+ uint32_t i2cTimeout);
+ uint8_t regAddr,
+ uint32_t *regVal,
+ uint8_t regAddr,
* \brief I2C 8-bit register read function
@@ -340,3 +369,4 @@
#endif /* _COMMON_H_ */
diff --git a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/pdk_jacinto_08_01_00_36/packages/ti/drv/dss/src/drv/disp/dss_dispApi.c b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/pdk_jacinto_08_01_00_36/packages/ti/drv/dss/src/drv/disp/dss_dispApi.c
index a63dc62..a7c2710 100755
--- a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/pdk_jacinto_08_01_00_36/packages/ti/drv/dss/src/drv/disp/dss_dispApi.c
+++ b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/pdk_jacinto_08_01_00_36/packages/ti/drv/dss/src/drv/disp/dss_dispApi.c
@@ -1468,7 +1468,7 @@
if(FVID2_SOK != retVal)
- GT_0trace(DssTrace, GT_ERR, "Set DSS parameter IOCTL failed\r\n");
+ GT_0trace(DssTrace, GT_ERR, "ZPF: Set DSS parameter IOCTL failed\r\n");
/* Post the instance semaphore */
@@ -1851,11 +1851,22 @@
((dispParams->pipeCfg.outHeight + dispParams->layerPos.startY) >
instObj->dispHeight))
+ GT_6trace(DssTrace,
GT_ERR,
- "Input width+startX/height+startY > display width/height\r\n");
+ "Input width+startX/height+startY > display width/height\r\n \
+ dispParams->pipeCfg.outWidth = %d + dispParams->layerPos.startX = %d instObj->dispWidth = %d\r\n \
+ dispParams->pipeCfg.outHeight = %d + dispParams->layerPos.startY = %d instObj->dispHeight = %d\r\n", \
+ dispParams->pipeCfg.outWidth, dispParams->pipeCfg.outWidth + dispParams->layerPos.startX, instObj->dispWidth, \
+ dispParams->pipeCfg.outHeight, dispParams->pipeCfg.outHeight + dispParams->layerPos.startY, instObj->dispHeight);
//retVal = FVID2_EINVALID_PARAMS;
+ GT_ERR,
+ "[ZPF] Input width+startX/height+startY >=< display width/height\r\n \
/* Interlaced to progressive or vice versa*/
if(dispParams->pipeCfg.inFmt.scanFormat != instObj->dispScanFormat)
@@ -1886,6 +1897,7 @@
GT_ERR,
"Downscaling ratio is more than 0.25x \r\n");
if((dispParams->pipeCfg.inFmt.height != dispParams->pipeCfg.outHeight) ||
@@ -2143,3 +2155,4 @@
return isFarFromVsync;
diff --git a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/apps/basic_demos/app_multi_cam/main.c b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/apps/basic_demos/app_multi_cam/main.c
index a7a7020..475a26e 100755
--- a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/apps/basic_demos/app_multi_cam/main.c
+++ b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/apps/basic_demos/app_multi_cam/main.c
@@ -812,24 +812,24 @@
if (status == VX_SUCCESS)
obj->displayObj1.disp_params.pipeId = 0;
- obj->displayObj1.disp_params.outWidth = 1920;
+ obj->displayObj1.disp_params.outWidth = 960;
obj->displayObj1.disp_params.outHeight = 1080;
obj->displayObj1.disp_params.posX = 0;
- obj->displayObj1.disp_params.posY = 0;
+ obj->displayObj1.disp_params.posY = 1080;
status = app_init_display(obj->context, &obj->displayObj1, "display_obj1");
- APP_PRINTF("Display init done!\n");
+ APP_PRINTF("Left Display init done!\n");
//status = app_init_display(obj->context, &obj->displayObj, "display_obj");
obj->displayObj2.disp_params.pipeId = 2;
- obj->displayObj2.disp_params.outWidth = 1920;
+ obj->displayObj2.disp_params.outWidth = 960;
obj->displayObj2.disp_params.outHeight = 1080;
- obj->displayObj2.disp_params.posX = 1920;
- obj->displayObj2.disp_params.posY = 0;
+ obj->displayObj2.disp_params.posX = 960;
+ obj->displayObj2.disp_params.posY = 1080;
status = app_init_display(obj->context, &obj->displayObj2, "display_obj2");
+ APP_PRINTF("Right Display init done!\n");
appPerfPointSetName(&obj->total_perf , "TOTAL");
@@ -1453,3 +1453,4 @@
vxAddParameterToGraph(graph, parameter);
vxReleaseParameter(¶meter);
diff --git a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/apps/basic_demos/app_single_cam/app_single_cam_main.c b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/apps/basic_demos/app_single_cam/app_single_cam_main.c
index 3b0216b..0e113b5 100755
--- a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/apps/basic_demos/app_single_cam/app_single_cam_main.c
+++ b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/apps/basic_demos/app_single_cam/app_single_cam_main.c
@@ -252,9 +252,9 @@
/* Display initialization */
memset(&obj->display_params, 0, sizeof(tivx_display_params_t));
obj->display_params.opMode = TIVX_KERNEL_DISPLAY_ZERO_BUFFER_COPY_MODE;
- obj->display_params.pipeId = 2;
- obj->display_params.outHeight = 1080;
- obj->display_params.outWidth = 1920;
+ obj->display_params.pipeId = 0;
+ obj->display_params.outHeight = 640;//1080;
+ obj->display_params.outWidth = 480;//1920;
obj->display_params.posX = 0;
obj->display_params.posY = 0;
@@ -724,8 +724,8 @@
else
- obj->display_params.posX = (1920U - obj->display_params.outWidth)/2;
- obj->display_params.posY = (1080U - obj->display_params.outHeight)/2;
+ obj->display_params.posX = 0;//(1920U - obj->display_params.outWidth)/2;
+ obj->display_params.posY = 0;//(1080U - obj->display_params.outHeight)/2;
obj->display_param_obj = vxCreateUserDataObject(obj->context, "tivx_display_params_t", sizeof(tivx_display_params_t), &obj->display_params);
obj->displayNode = tivxDisplayNode(obj->graph, obj->display_param_obj, obj->display_image);
@@ -1710,3 +1710,4 @@
return status;
diff --git a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/modules/src/app_display_module.c b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/modules/src/app_display_module.c
index e44f2e7..733222a 100644
--- a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/modules/src/app_display_module.c
+++ b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/modules/src/app_display_module.c
@@ -96,18 +96,18 @@
if (dispId == 0)
displayObj->disp_params.pipeId = 0; /* pipe ID = 2 */
- displayObj->disp_params.outWidth = 1920;
- displayObj->disp_params.outHeight = 1080;
+ displayObj->disp_params.outWidth = 640;//960;
+ displayObj->disp_params.outHeight = 480;//1080;
displayObj->disp_params.posX = 0;
displayObj->disp_params.posY = 0;
else
displayObj->disp_params.pipeId = 2; /* pipe ID = 2 */
- displayObj->disp_params.posX = 1920;
- displayObj->disp_params.posY = 0;
+ displayObj->disp_params.posX = 640;//1280;
+ displayObj->disp_params.posY = 0;//80;
displayObj->disp_params_obj = vxCreateUserDataObject(context, "tivx_display_params_t", sizeof(tivx_display_params_t), &displayObj->disp_params);
@@ -162,3 +162,4 @@
return status;
diff --git a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/platform/j721e/rtos/common/app_init.c b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/platform/j721e/rtos/common/app_init.c
index 806079d..a2e31fe 100755
--- a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/platform/j721e/rtos/common/app_init.c
+++ b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/platform/j721e/rtos/common/app_init.c
@@ -541,20 +541,39 @@
#ifdef ENABLE_DSS_DSI
prm.display_type = APP_DSS_DEFAULT_DISPLAY_TYPE_DSI;
- //prm.timings.width = 1280U;
- //prm.timings.height = 800U;
- prm.timings.width = 1920U;
- prm.timings.height = 1080U;
- prm.timings.hFrontPorch = 160U;
- prm.timings.hBackPorch = 100U;
- prm.timings.hSyncLen = 80U;
- prm.timings.vFrontPorch = 5U;
- prm.timings.vBackPorch = 5U;
- prm.timings.vSyncLen = 5U;
- //prm.timings.pixelClock = 274626000ULL;
- //prm.timings.pixelClock = 190530000ULL;
+ //prm.timings.width = 2560U;
+ //prm.timings.height = 1080U;
+ //prm.timings.width = 3840U;
+ //prm.timings.width = 1920U;
+ prm.timings.width = 1280U;//640 * 2 = 1280
+ prm.timings.height = 480U;
+ //prm.timings.hFrontPorch = 320U;//160U;
+ //prm.timings.hFrontPorch = 160U;
+ prm.timings.hFrontPorch = 32U;//16U;
+ //prm.timings.hBackPorch = 200U;//100U;
+ //prm.timings.hBackPorch = 100U;
+ prm.timings.hBackPorch = 96U;//48U;
+ //prm.timings.hSyncLen = 160U;//80U;
+ //prm.timings.hSyncLen = 80U;
+ prm.timings.hSyncLen = 192U;//96U;
+ //prm.timings.vFrontPorch = 5U;
+ //prm.timings.vBackPorch = 5U;
+ //prm.timings.vSyncLen = 5U;
+ prm.timings.vFrontPorch = 10U;
+ prm.timings.vBackPorch = 33U;
+ prm.timings.vSyncLen = 2U;
+ //prm.timings.pixelClock = 274626000ULL;
+ //prm.timings.pixelClock = 190530000ULL;//(2560 + 160 + 100 + 80) * (1080 + 5 + 5 + 5) * 60
//prm.timings.pixelClock = 137313000ULL;
- prm.timings.pixelClock = 148482000ULL;
+ //prm.timings.pixelClock = 148500000ULL;//(1920 + 160 + 100 + 80) * (1080 + 5 + 5 + 5) * 60
+ //prm.timings.pixelClock = 297000000ULL;//(1920*2 + 160*2 + 100*2 + 80*2) * (1080 + 5 + 5 + 5) * 60
+ //prm.timings.pixelClock = 25200000ULL;//For DLP Module: (640 + 16 + 48 + 96)800 * (480 + 10 + 33 + 2)525 * 60
+ prm.timings.pixelClock = 50400000ULL;//For DLP Module: (1280 + 32 + 96 + 192)1600 * (480 + 10 + 33 + 2)525 * 60
#endif
status = appDssDefaultInit(&prm);
APP_ASSERT_SUCCESS(status);
@@ -864,3 +883,4 @@
__asm(" IDLE");
#endif
diff --git a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dctrl.c b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dctrl.c
index 79f3894..fe660c2 100755
--- a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dctrl.c
+++ b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dctrl.c
@@ -536,10 +536,14 @@
//dsi_params.numOfLanes = prms->num_lanes;
dsi_params.numOfLanes = 4u;//prms->num_lanes;
- dsi_params.laneSpeedInKbps = 890892u;
- //dsi_params.laneSpeedInKbps = 1143180u;
- //dsi_params.laneSpeedInKbps = 1647756u;
- appLogPrintf("DCTRL: ERROR: zpf_setting numOfLanes = %d, lane-Tx-rate = %ld !!!\n", dsi_params.numOfLanes, dsi_params.laneSpeedInKbps);
+ //dsi_params.laneSpeedInKbps = 890892u;//(1920 + 160 + 100 + 80)2260 * (1080 + 5 + 5 +5)1095 * 60 * 24 / 4
+ //dsi_params.laneSpeedInKbps = 151200u;//(640 + 16 + 48 + 96)800 * (480 + 10 + 33 + 2)525 * 60 * 24 / 4
+ dsi_params.laneSpeedInKbps = 302400u;//(1280 + 32 + 96 + 192)1600 * (480 + 10 + 33 + 2)525 * 60 * 24 / 4
+ //dsi_params.laneSpeedInKbps = 1143180u;//(2560 + 160 + 100 + 80) * (1080 + 5 + 5 + 5) * 60 * 24 / 4 per-lane
+ //dsi_params.laneSpeedInKbps = 1781784u;//(1920*2 + 160*2 + 100*2 + 80*2) * (1080 + 5 + 5 +5) * 24 / 4 lane-speed
+ appLogPrintf("DCTRL: zpf_setting numOfLanes = %d, lane-Tx-rate = %ld !!!\n", dsi_params.numOfLanes, dsi_params.laneSpeedInKbps);
retVal = Fvid2_control(handle, IOCTL_DSS_DCTRL_SET_DSI_PARAMS,
&dsi_params, NULL);
@@ -547,3 +551,4 @@
return (retVal);
diff --git a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dss_defaults.c b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dss_defaults.c
index 15b2486..8dbb2c3 100755
--- a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dss_defaults.c
+++ b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dss_defaults.c
@@ -148,7 +148,7 @@
if (prm->display_type == APP_DSS_DEFAULT_DISPLAY_TYPE_DSI)
- //appDssConfigureUB941AndUB925(prm);
+ appDssConfigureUB941AndUB925(prm);
appDssInitParamsInit(&dssParams);
@@ -350,6 +350,7 @@
/* Only two lanes output supported for AOU LCD */
dsiParams.num_lanes = 4u;
retVal+= appRemoteServiceRun(cpuId, APP_DCTRL_REMOTE_SERVICE_NAME, APP_DCTRL_CMD_SET_DSI_PARAMS, &dsiParams, sizeof(app_dctrl_dsi_params_t), 0U);
+ //appLogPrintf("ZPF: ERROR: Set DSI params default init failed !!!\n");
retVal+= appRemoteServiceRun(cpuId, APP_DCTRL_REMOTE_SERVICE_NAME, APP_DCTRL_CMD_SET_PATH, &pathInfo, sizeof(pathInfo), 0U);
@@ -380,3 +381,4 @@
return retVal;
diff --git a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dss_j721e.c b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dss_j721e.c
index 4529bc0..5ba8aa2 100755
--- a/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dss_j721e.c
+++ b/ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dss_j721e.c
@@ -59,70 +59,245 @@
/* Global Variables */
+//#define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0]))
+#define ARRAY_SIZE(x) (sizeof(x) / sizeof(*(x)))
+#define BIT8_ADDR 0
+#define BIT16_ADDR 1
+typedef struct Board_I2cReg
+ /** GMSL slave address */
+ uint8_t clientAddr;
+ /** regAddr bit */
+ uint8_t regAddrBit;
+ /** GMSL register offset address */
+ uint16_t regAddr;
+ /** GMSL register data */
+ uint8_t regData;
+ /** GMSL i2c delay in milliseconds */
+ uint8_t i2cDelay;
+} Board_I2cReg_t;
static I2C_Handle gI2cHandle = NULL;
+static Board_I2cReg_t *g_Board_I2cReg_t_ptr = NULL;
-uint8_t Ub941Ub925Config[][4] = {
-{0x16, 0x01, 0x0A, 0x5},
-{0x16, 0x03, 0x9A, 0x5},
-{0x16, 0x17, 0x9E, 0x5},
-{0x16, 0x07, 0x58, 0x5},
-{0x16, 0x08, 0x22, 0x5},
-{0x16, 0x70, 0x80, 0x5},
-{0x16, 0x77, 0x24, 0x5},
-{0x16, 0x01, 0x08, 0x5},
-{0x16, 0x1E, 0x01, 0x5},
-{0x16, 0x40, 0x04, 0x5},
-{0x16, 0x40, 0x05, 0x5},
-{0x16, 0x41, 0x21, 0x5},
-{0x16, 0x42, 0x60, 0x5},
-{0x16, 0x40, 0x09, 0x5},
-{0x16, 0x5b, 0x85, 0x5},
-{0x16, 0x4f, 0x8c, 0x5},
-{0x16, 0x4f, 0x84, 0x5},
-{0x16, 0x41, 0x05, 0x5},
-{0x16, 0x42, 0x16, 0x5},
-{0x16, 0x40, 0x08, 0x5},
-{0x16, 0x42, 0x0c, 0x5},
-{0x16, 0x01, 0x00, 0x5},
-{0x16, 0x66, 0x03, 0x5},
-{0x16, 0x67, 0x03, 0x5},
-{0x16, 0x65, 0x01, 0x5},
-{0x16, 0x64, 0x00, 0x5},
-{0x16, 0x64, 0x04, 0x5},
-{0x27, 0x00, 0xFE, 0x5},
-{0x11, 0x1D, 0x28, 0x5},
-{0x11, 0x1D, 0x29, 0x5},
-{0x11, 0x01, 0x06, 0x5},
-{0x11, 0x01, 0x04, 0x5},
-{0x11, 0x03, 0xf0, 0x5},
-{0x11, 0x03, 0xf8, 0x5},
-{0x11, 0x29, 0x00, 0x5},
-{0x11, 0x65, 0x00, 0x5},
-{0x12, 0x0C, 0x20, 0x5},
-{0x12, 0x00, 0x01, 0x5},
-{0x12, 0x04, 0xE6, 0x5},
+#if 0
+Board_I2cReg_t Ub941Ub925ConfigEviyosTest[] = {
+ //Just DLP Test_Patterns That Verfiy SPB pass-through OK !!!.
+ //Set Port A Lane Mapping
+ {0x40, BIT16_ADDR, 0x0404 ,0x43, 0x5},
+ //Set Port B Lane Mapping
+ {0x40, BIT16_ADDR, 0x0604 ,0x43, 0x5},
+ //Set GMSL type
+ {0x40, BIT16_ADDR, 0x044D ,0x80, 0x5},
+ //Set BWS DRS DBL Phy A
+ {0x40, BIT16_ADDR, 0x064D ,0x80, 0x5},
+ //Access to LinkA & Change DES0 addr as 0xB0 >> 1 = 0x58
+ {0x40, BIT16_ADDR, 0x0004 ,0x12, 0x5},
+ {0x5A, BIT8_ADDR, 0x01 ,0xB0, 0x5},
+ //Access to LinkB & Change DES1 addr as 0xB4 >> 1 = 0x5A
+ {0x40, BIT16_ADDR, 0x0004 ,0x22, 0x5},
+ {0x5A, BIT8_ADDR, 0x01 ,0xB4, 0x5},
+ //LinkA & B both Enabled
+ {0x40, BIT16_ADDR, 0x0004 ,0x32, 0x5}
+#endif
+#if 1
+Board_I2cReg_t Ub941Ub925Config[] = {
+ * @ Description: MAX96789 + MAX96706 Settings For DLP RGB8
+ * Superframe For 640*2 x 480
+ * 2022-10-25
+ //Symmetric 7_13_15-34 Using MAX96789/91/F (GMSL-1/2)
+ //#Write TX Enable Y
+ {0x40, BIT16_ADDR, 0x0002, 0x73, 0x05},
+ //#Set Port A Lane Mapping
+ {0x40, BIT16_ADDR, 0x0332, 0x4E, 0x05},
+ //#Set Port B Lane Mapping
+ {0x40, BIT16_ADDR, 0x0333, 0xE4, 0x05},
+ //#Set GMSL type
+ {0x40, BIT16_ADDR, 0x0004, 0x32, 0x05},
+ //#Set BWS DRS DBL Phy A
+ {0x40, BIT16_ADDR, 0x0407, 0x00, 0x05},
+ //#Set BWS DRS DBL Phy B
+ {0x40, BIT16_ADDR, 0x0607, 0x00, 0x05},
+ //#Set oLDI/VESA format phy A
+ {0x40, BIT16_ADDR, 0x0415, 0x01, 0x05},
+ //#Set oLDI/VESA format phy B
+ {0x40, BIT16_ADDR, 0x0615, 0x01, 0x05},
+ //#Clock Select
+ {0x40, BIT16_ADDR, 0x0308, 0x5C, 0x05},
+ //#Start DSI Port
+ {0x40, BIT16_ADDR, 0x0311, 0x03, 0x05},
+ //#Number of Lanes
+ {0x40, BIT16_ADDR, 0x0331, 0x03, 0x05},
+ //#Set phy_config
+ {0x40, BIT16_ADDR, 0x0330, 0x06, 0x05},
+#if 0
+ //#Set soft_dtx_en
+ {0x40, BIT16_ADDR, 0x031C, 0x98, 0x05},
+ //#Set soft_dtx
+ {0x40, BIT16_ADDR, 0x0321, 0x24, 0x05},
+ //#Set soft_dty_en
+ {0x40, BIT16_ADDR, 0x031D, 0x98, 0x05},
+ //#Set soft_dty_
+ {0x40, BIT16_ADDR, 0x0322, 0x24, 0x05},
+#endif
+ //#Default
+ {0x40, BIT16_ADDR, 0x0326, 0xE4, 0x05},
+ //#SSPLL_ODIV_EXP
+ {0x40, BIT16_ADDR, 0x056E, 0x09, 0x05},
+ //#SSPLL_ODIV_EXP
+ {0x40, BIT16_ADDR, 0x056F, 0x1A, 0x05},
+ //#SSPLL_FORCE_DIV/SSPLL_FB_DIV_H
+ {0x40, BIT16_ADDR, 0x0570, 0x40, 0x05},
+ //#CSI_SSPLL_FB_FRACTION_IN_L
+ {0x40, BIT16_ADDR, 0x055B, 0x55, 0x05},
+ //#CSI_SSPLL_FB_FRACTION_IN_H
+ {0x40, BIT16_ADDR, 0x055C, 0x05, 0x05},
+ //#SSPLL_ODIV_EXP
+ {0x40, BIT16_ADDR, 0x0571, 0x09, 0x05},
+ //#SSPLL_FB_DIV_L
+ {0x40, BIT16_ADDR, 0x0572, 0x1A, 0x05},
+ {0x40, BIT16_ADDR, 0x0573, 0x40, 0x05},
+ {0x40, BIT16_ADDR, 0x056C, 0x55, 0x05},
+ {0x40, BIT16_ADDR, 0x056D, 0x05, 0x05},
+ //#HSYNC_WIDTH_L
+ {0x40, BIT16_ADDR, 0x0385, 0xC0, 0x05},
+ //#VSYNC_WIDTH_L
+ {0x40, BIT16_ADDR, 0x0386, 0x02, 0x05},
+ //#HSYNC_WIDTH_H/VSYNC_WIDTH_H
+ {0x40, BIT16_ADDR, 0x0387, 0x00, 0x05},
+ //#VFP_L
+ {0x40, BIT16_ADDR, 0x03A5, 0x0A, 0x05},
+ //#VBP_H
+ {0x40, BIT16_ADDR, 0x03A7, 0x02, 0x05},
+ //#VFP_H/VBP_L
+ {0x40, BIT16_ADDR, 0x03A6, 0x10, 0x05},
+ //#VRES_L
+ {0x40, BIT16_ADDR, 0x03A8, 0xE0, 0x05},
+ //#VRES_H
+ {0x40, BIT16_ADDR, 0x03A9, 0x01, 0x05},
+ //#HFP_L
+ {0x40, BIT16_ADDR, 0x03AA, 0x20, 0x05},
+ //#HBP_H
+ {0x40, BIT16_ADDR, 0x03AC, 0x06, 0x05},
+ //#HFP_H/HBP_L
+ {0x40, BIT16_ADDR, 0x03AB, 0x00, 0x05},
+ //#HRES_L
+ {0x40, BIT16_ADDR, 0x03AD, 0x00, 0x05},
+ //#HRES_H
+ {0x40, BIT16_ADDR, 0x03AE, 0x05, 0x05},
+#if 0
+ //#FIFO/DESKEW_EN
+ {0x40, BIT16_ADDR, 0x03A4, 0xC1, 0x05},
+#endif
+ //#Enable Dual View Block Port A
+ {0x40, BIT16_ADDR, 0x032A, 0x07, 0x05},
+ //#Video Pipe Enable
+#if 0
+ //#Enable splitter mode reset one shot
+ {0x40, BIT16_ADDR, 0x0010, 0x23, 0x05},
+ //#end for RGB888 setting
+#endif
+ //#set crossbar for link A
+ {0x40, BIT16_ADDR, 0x01B8, 0x06, 0x05},
+ {0x40, BIT16_ADDR, 0x01B9, 0x07, 0x05},
+ {0x40, BIT16_ADDR, 0x01BD, 0x1A, 0x05},
+ {0x40, BIT16_ADDR, 0x01C2, 0x18, 0x05},
+ {0x40, BIT16_ADDR, 0x01C3, 0x19, 0x05},
+ //#set crossbar for link B
+ {0x40, BIT16_ADDR, 0x01FB, 0x06, 0x05},
+ {0x40, BIT16_ADDR, 0x01FC, 0x07, 0x05},
+ {0x40, BIT16_ADDR, 0x0200, 0x1A, 0x05},
+ {0x40, BIT16_ADDR, 0x0205, 0x18, 0x05},
+ {0x40, BIT16_ADDR, 0x0206, 0x19, 0x05},
+ //#set HIM
+ {0x40, BIT16_ADDR, 0x044D, 0x80, 0x05},
+ {0x40, BIT16_ADDR, 0x064D, 0x80, 0x05},
+ //#end of setting serializer
+#if 0
+ {0x40, BIT16_ADDR, 0x0404, 0x43, 0x05},
+ {0x40, BIT16_ADDR, 0x0604, 0x43, 0x05},
+ //#Access to link A
+ //#set deserializer on link A
+ //#change deserializer A address as 0xB0
+ {0x40, BIT16_ADDR, 0x0004, 0x12, 0x05},
+ {0x5A, BIT8_ADDR, 0x01, 0xB0, 0x05},
+ //#set BWS
+ {0x5A, BIT8_ADDR, 0x07, 0x00, 0x05},
+ //#Access to link B
+ //#change deserializer B address as 0x98
+ {0x40, BIT16_ADDR, 0x0004, 0x22, 0x05},
+ {0x5A, BIT8_ADDR, 0x01, 0xB4, 0x05},
+ //#set BWS
+ {0x58, BIT8_ADDR, 0x07, 0x00, 0x05},
+ //#set serializer BWS
+ //#enable video link
+// {0x40, BIT16_ADDR, 0x0404, 0x83, 0x05},
+// {0x40, BIT16_ADDR, 0x0604, 0x83, 0x05},
+#endif
+ //#enable link A/B at GMSL1 mode
+ //#enable splitter mode
+ //#end of SERDES setting
+ //#No need to write deserializer
+#endif
+uint32_t configEviyos[][4] = {
+ * Eviyos Setting & CRC For FPGA verification
+ * High 16-bit for register setting, Low 16-bit for CRC verification.
+ {0x50, 0x0000, 0x1098F456, 0x5},
+ {0x50, 0x002C, 0xFE0036FD, 0x5},
+ {0x50, 0x001F, 0x0002BA84, 0x5},
+ {0x50, 0x0021, 0x00037401, 0x5},
+ {0x50, 0x001E, 0x0000ADF6, 0x5},
+ {0x50, 0x000F, 0x003C2E7A, 0x5},
+ {0x50, 0x0013, 0x0000EFA7, 0x5},
+ {0x50, 0x0020, 0x00007352, 0x5},
+#if 0
+ {0x50, 0x0000, 0x0000F594, 0x5},
+#endif
+#if 0
+ //Different Test Patterns can Achieved By Writing 0x00 -- 0x07 in Register 0x22
+ {0x50, 0x0022, 0x00010D13, 0x5},//test_pattern 0x1
+ {0x50, 0x0022, 0x00001D32, 0x5},//test_pattern 0x0
+ {0x50, 0x0022, 0x00023D70, 0x5},//test_pattern 0x2
+ {0x50, 0x0022, 0x00032D51, 0x5},//test_pattern 0x3
+ {0x50, 0x0022, 0x00045DB6, 0x5},//test_pattern 0x4
+ {0x50, 0x0022, 0x00054D97, 0x5},//test_pattern 0x5
+ {0x50, 0x0022, 0x00067DF4, 0x5},//test_pattern 0x6
+ {0x50, 0x0022, 0x00076DD5, 0x5},//test_pattern 0x7
+#endif
+ //{0x50, 0x0022, 0x00010D13, 0x5},//test_pattern 0x1
+ //Enter Test Pattern Mode
+ //{0x50, 0x0001, 0x0007B243, 0x5}
+ //Enter Normal Mode
+ {0x50, 0x0001, 0x0003F2C7, 0x5}
@@ -131,6 +306,14 @@
static int32_t appDssDsiSetBoardMux();
static int32_t appDssDsiInitI2c();
+//static int32_t DispApp_InitI2c();
+static void toConfigEviyos();
+static int32_t Eviyos_ReadReg(I2C_Handle handle,
+ uint8_t clientAddr,
+ uint8_t regAddr,
+ uint32_t *regVal,
+ uint32_t numOfByte,
+ uint32_t numRegs);
@@ -267,47 +450,177 @@
-void appDssConfigureUB941AndUB925(app_dss_default_prm_t *prm)
+ uint8_t regAddr,
+ uint32_t *regVal,
+ uint32_t numRegs)
- int32_t status;
- uint32_t cnt, clientAddr;
+ int32_t status = -1;
+ static uint8_t I2cByteOrder = BOARD_I2C_REG_ADDR_MSB_FIRST;
+ uint32_t readReg32bit = 0xFFFF;
+ uint32_t count;
- if(prm->display_type==APP_DSS_DEFAULT_DISPLAY_TYPE_DSI)
- appLogPrintf("DSS: Configuring SERDES ... !!!\n");
- status = appDssDsiSetBoardMux();
- if (FVID2_SOK == status)
- status = appDssDsiInitI2c();
+ for (count = 0; count < numRegs; count++) {
+ /* Read a 16-bit value from Eviyos FPGA */
+ status = Uled_Eviyos_ReadReg(handle, clientAddr, regAddr, &readReg32bit, numOfByte, I2cByteOrder, BOARD_I2C_TRANSACTION_TIMEOUT);
+ if (status != 0 ) {
+ appLogPrintf("ZPF_DSS_Eviyos_CHECK_VALUE: Failed to read DLP Eviyos readReg16bit ... !!!\n");
- for (cnt = 0; cnt < sizeof(Ub941Ub925Config)/4; cnt ++)
- clientAddr = Ub941Ub925Config[cnt][0];
- status = Board_i2c8BitRegWr(
- gI2cHandle, clientAddr, Ub941Ub925Config[cnt][1],
- &Ub941Ub925Config[cnt][2], 1U, BOARD_I2C_TRANSACTION_TIMEOUT);
- appLogWaitMsecs((uint32_t)Ub941Ub925Config[cnt][3]);
- if (0 != status)
- appLogPrintf("DSS: Write Failed for ClientAddr 0x%x RegAddr 0x%x Value 0x%x !\n",
- clientAddr, Ub941Ub925Config[cnt][1], Ub941Ub925Config[cnt][2]);
- break;
- I2C_close(gI2cHandle);
- appLogPrintf("DSS: SERDES Configuration... Done !!!\n");
+ return (status);
+ uint8_t clientAddr = 0x00;
+ uint16_t regAddr = 0x00;
+ uint32_t regValueRead = 0xFFFFFFFF;
+ uint32_t cnt;
+ uint32_t status = 0;
+ appLogPrintf("ZPF_DSS: Start Configuring DLP Eviyos ... !!!\n");
+ for (cnt = 0; cnt < ARRAY_SIZE(configEviyos); cnt ++) {
+ clientAddr = (uint8_t)configEviyos[cnt][0];
+ status = Board_i2c8BitRegWr32bit(gI2cHandle,
+ clientAddr,//0xA0 >> 1 = 0x50
+ (uint16_t)configEviyos[cnt][1],//Need_test 16-bit regAddr
+ //(uint8_t)configEviyos[cnt][1],//Need_test 8-bit regAddr
+ (uint32_t *)(&configEviyos[cnt][2]),
+ 6U,//"6U" for <16-bit(regAddr) + 32-bit(regData)>
+ BOARD_I2C_REG_ADDR_MSB_FIRST,
+ BOARD_I2C_TRANSACTION_TIMEOUT);
+ appLogWaitMsecs((uint32_t)configEviyos[cnt][3]);
+#if 1
+ if (0 != status) {
+ appLogPrintf("ZPF_DSS: Eviyos Write %d: Failed for ClientAddr 0x%x RegAddr 0x%x Value 0x%x ARRAY_SIZE(configEviyos) = %d!\n",
+ cnt, clientAddr, configEviyos[cnt][1], configEviyos[cnt][2], ARRAY_SIZE(configEviyos));
+ break;
+ //continue;
+#endif
+#if 0
+ Eviyos_ReadReg(gI2cHandle, (uint8_t)configEviyos[cnt][0], (uint8_t)configEviyos[cnt][1], ®ValueRead, 4U, 1);
+ if (status == 0) {
+ appLogPrintf("Eviyos Debug Reg ReadBack Eviyos Addr: 0x%x EviyosRegAddr: 0x%x, Value 0x%x \n", configEviyos[cnt][0], configEviyos[cnt][1], regValueRead);
+#endif
+ appLogPrintf("ZPF_DSS: Configuring DLP Eviyos Done ... !!!\n");
+void appDssConfigureUB941AndUB925(app_dss_default_prm_t *prm)
+ int32_t status;
+ int32_t status1, status2;
+ uint32_t cnt, clientAddr, count;
+ uint8_t rd_back = 0xFF;
+ uint8_t des_rdbk0 = 0xFF, des_rdbk1 = 0xFF;
+ g_Board_I2cReg_t_ptr = Ub941Ub925Config;
+ //g_Board_I2cReg_t_ptr = Ub941Ub925ConfigEviyosTest;
+ if(prm->display_type==APP_DSS_DEFAULT_DISPLAY_TYPE_DSI) {
+ appLogPrintf("ZPF_DSS: SERDES Configuration... Start !!!\n");
+ status = appDssDsiSetBoardMux();
+ if (FVID2_SOK == status) {
+ status = appDssDsiInitI2c();
+ //for (cnt = 0; cnt < ARRAY_SIZE(Ub941Ub925ConfigEviyosTest); cnt++) {
+ for (cnt = 0; cnt < ARRAY_SIZE(Ub941Ub925Config); cnt++) {
+ if (g_Board_I2cReg_t_ptr->regAddrBit == BIT16_ADDR) {
+ status = Board_i2c16BitRegWr(gI2cHandle,
+ g_Board_I2cReg_t_ptr->clientAddr,
+ (uint16_t)g_Board_I2cReg_t_ptr->regAddr,
+ (uint8_t *)&(g_Board_I2cReg_t_ptr->regData),
+ 1U, BOARD_I2C_REG_ADDR_MSB_FIRST, BOARD_I2C_TRANSACTION_TIMEOUT);
+ appLogWaitMsecs(g_Board_I2cReg_t_ptr->i2cDelay);
+ appLogPrintf("ZPF_DSS: SERDES Write Failed for ClientAddr 0x%x RegAddr 0x%x Value 0x%x ARRAY_SIZE(array) = %d !\n",
+ //g_Board_I2cReg_t_ptr->clientAddr, g_Board_I2cReg_t_ptr->regAddr, g_Board_I2cReg_t_ptr->regData, ARRAY_SIZE(Ub941Ub925ConfigEviyosTest));
+ g_Board_I2cReg_t_ptr->clientAddr, g_Board_I2cReg_t_ptr->regAddr, g_Board_I2cReg_t_ptr->regData, ARRAY_SIZE(Ub941Ub925Config));
+ break;
+ } else {
+ Board_i2c8BitRegWr(gI2cHandle,
+ (uint8_t)g_Board_I2cReg_t_ptr->regAddr,
+ 1U, BOARD_I2C_TRANSACTION_TIMEOUT);
+ break;
+#if 0
+ break;
+#endif
+#if 1 //For debug Read SER
+ status1 = Board_i2c16BitRegRd(gI2cHandle,
+ &rd_back,
+ if (0 == status1) {
+ appLogPrintf("ZPF_DSS: SER Read Back from ClientAddr 0x%x RegAddr 0x%04x Value 0x%04x!\n",
+ g_Board_I2cReg_t_ptr->clientAddr, (uint16_t)g_Board_I2cReg_t_ptr->regAddr, (rd_back & 0xFF));
+ } else {
+ appLogPrintf("ZPF_DSS: SER Failed Read Back from ClientAddr 0x%x RegAddr 0x%04x Value 0x%04x status1 = %d!\n",
+ g_Board_I2cReg_t_ptr->clientAddr, (uint16_t)g_Board_I2cReg_t_ptr->regAddr, (rd_back & 0xFF), status1);
+#endif
+ g_Board_I2cReg_t_ptr++;
+#if 0 //For debug read DES
+ status2 = Board_i2c8BitRegRd(gI2cHandle, 0x5A, 0x01, &des_rdbk0, 1U, BOARD_I2C_TRANSACTION_TIMEOUT);
+ if ( 0 == status2) {
+ appLogPrintf("DES_ReadBack1 ZPF_DSS: Read Back from DesAddr1: 0x5A RegAddr: 0x01 Value: 0x%x !\n", (des_rdbk0 & 0xFF));
+ status2 = Board_i2c8BitRegRd(gI2cHandle, 0x58, 0x01, &des_rdbk1, 1U, BOARD_I2C_TRANSACTION_TIMEOUT);
+ appLogPrintf("DES_ReadBack2 ZPF_DSS: Read Back from DesAddr2: 0x58 RegAddr: 0x01 Value: 0x%x !\n", (des_rdbk1 & 0xFF));
+#endif
+ appLogPrintf("ZPF_DSS: SERDES Configuration... Done !!!\n");
+ toConfigEviyos();
+ I2C_close(gI2cHandle);
+#if 1
Board_I2cInitCfg_t i2cCfg;
@@ -317,7 +630,8 @@
i2cCfg.socDomain = BOARD_SOC_DOMAIN_MAIN;
i2cCfg.enableIntr = false;
Board_setI2cInitConfig(&i2cCfg);
+ SET_DEVICE_STATE_ON(TISCI_DEV_I2C1);
+#if 0
/* Enable DSI in IO Expander */
Board_i2cIoExpInit();
@@ -346,16 +660,22 @@
PIN_NUM_2,
GPIO_SIGNAL_LEVEL_HIGH);
Board_i2cIoExpDeInit();
+#endif
return (FVID2_SOK);
+#endif
int32_t status = FVID2_SOK;
uint8_t domain, i2cInst, slaveAddr;
+ //uint8_t domain = BOARD_SOC_DOMAIN_MAIN;
+ //uint8_t i2cInst = 1U;
+ //uint8_t slaveAddr = 0x40; //0x80 >> 1
I2C_Params i2cParams;
+ //DispApp_InitI2c();
/* Initializes the I2C Parameters */
I2C_Params_init(&i2cParams);
i2cParams.bitRate = I2C_400kHz; /* 400KHz */
@@ -373,4 +693,41 @@
return (status);
+#if 0
+static int32_t DispApp_InitI2c()
+ int32_t status = FVID2_SOK;
+ uint32_t loopCnt;
+ //uint8_t domain, i2cInst, slaveAddr;
+ //I2C_Params i2cParams;
+ I2C_HwAttrs i2cConfig;
+ /* Initialize I2C Driver */
+ for(loopCnt = 0; loopCnt < I2C_HWIP_MAX_CNT; loopCnt++)
+ I2C_socGetInitCfg(loopCnt, &i2cConfig);
+ i2cConfig.enableIntr = false;
+ I2C_socSetInitCfg(loopCnt, &i2cConfig);
+ /* Initializes the I2C */
+ I2C_init();
+#if 0
+ /* Initializes the I2C Parameters */
+ I2C_Params_init(&i2cParams);
+ i2cParams.bitRate = I2C_400kHz; /* 400KHz */
+ Board_fpdUb941GetI2CAddr(&domain, &i2cInst, &slaveAddr);
+ /* Configures the I2C instance with the passed parameters*/
+ gI2cHandle = I2C_open(i2cInst, &i2cParams);
+ if(gI2cHandle == NULL)
+ App_print("\nI2C Open failed!\n");
+ status = FVID2_EFAIL;
+#endif
+ return (status);
+#endif
patch as attachment, please focus on below files modifications:
ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/platform/j721e/rtos/common/app_init.c <set resolution as 1280x480 superframe> ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dctrl.c <lane-num and lane-speed> ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dss_defaults.c ti-processor-sdk-rtos-j721e-evm-08_01_00_13/vision_apps/utils/dss/src/app_dss_j721e.c <config SERDES>
Q:
1. Could you please confirm <DSI IP interface output 1280x480 superframe parameters> whether the modification is correct or if there are any omissions that have not been modified yet ?
2. My understanding is that the parameters set in these files will be called in the end to configure the DSI D-PHY output 1280x480 image. Please correct me !!!
3. If the thses configuration parameters are set correctly, can you confirm that the DSI interface can output images normally ?
By the way
Application layer colleagues linqiang.huang@ecarxgroup.com will then synchronize the changes (modifications made on TI-DL demo) in this thread !!!
Looking forward to your reply.
Best Regards
Murphy
