AM6442: Downgrade Cgroup version
Part Number: AM6442
Hi
On our hardware based on AM6442 we want to use cgroup in version 1. Here I found that it is possible to switch between cgroup version by adding kernel parameter to cmdline (in include/configs/am64x_evm.h):
systemd.unified_cgroup_hierarchy=0
But unfortunately this isn't working with ti kernel.
So am I setting from kernel parameter or there is other way to force using cgroup v1?
root@puma:~# cat /proc/cmdline
console=ttyS2,115200n8 systemd.unified_cgroup_hierarchy=0 rauc.slot=A systemd.unified_cgroup_hierarchy=0 earlycon=ns16550a,mmio32,0x02800000 mtdparts=fc40000.spi.0:1m(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);omap2-nand.0:2m(NAND.tiboot3),2m(NAND.tispl),2m(NAND.tiboot3.backup),4m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup),-(NAND.file-system) root=PARTUUID=09769651-02 rw rootfstype=ext4 rootwait
root@puma:~#
root@puma:~#
root@puma:~#
root@puma:~#
root@puma:~# mount | grep cgroup
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,size=4096k,nr_inodes=1024,mode=755)
cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
BR
Jakub
  • Hi Jakub,
    I am not an expert on cgroup, but with "systemd.unified_cgroup_hierarchy=1", command 'mount | grep cgroup' prints
    root@am62xx-evm:~# mount | grep cgroup
    cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
    root@am62xx-evm:~#
    with "systemd.unified_cgroup_hierarchy=0", command 'mount | grep cgroup' prints
    root@am62xx-evm:~#
    You can see all the cgroups, such as cpuset, memory, pids, etc, are not using v2.
