[FAQ] TDA4VM: Details/information about CPSW instances supported in J7 devices and software supported from TI SDK.
Part Number: TDA4VM
Other Parts Discussed in Thread: DRA829, , DRA821, TDA4VL, TDA4VH
  • The following table will illustrate the different instances of CPSW supported in each of J7 device along with S/W support from TI SDK.
    S.No
    J7 Device
    MCU CPSW2G
    Main CPSW2G
    Main CPSW5G
    Main CPSW9G
    Main CPSW3G
    1
    J721E/TDA4VM/DRA829
    R: YES
    L: YES
    E: NO
    M: YES
    NA
    NA
    R: YES
    L: YES
    E: YES
    M: NO
    NA
    2
    J7200/DRA821
    R: YES
    L: YES
    E: NO
    M: YES
    NA
    R: YES
    L: YES
    E: YES
    M: NO
    NA
    NA
    3
    J721S2/TDA4VL
    R: YES
    L: YES
    E: NO
    M: YES
    R: YES
    L: YES
    E: NO
    M: NO
    NA
    NA
    NA
    4
    J784S4/TDA4VH
    R: YES
    L: YES
    E: NO
    M: YES
    R: YES
    L: YES
    E: NO
    M: NO
    NA
    R: YES
    L: YES
    E: YES
    M: NO
    NA
    5
    J722S/J7AEN
    NA
    NA
    NA
    NA
    R: NO
    L: YES
    E: NO
    M: YES
    R: RTOS Enet Example
    L: Native Linux Driver
    E: RTOS EthFw Application
    M: MCAL Eth Driver
    NA: Not Applicable (CPSW instance is not supported in respective SoC)
    Note:
    We can’t use multiple applications at the same time for any of the CPSW instances. Only one of the above can be used.
    Interface Supported from CPSW Instances:
    S.No
    CPSW Instance\ Interface
    RGMII/RMII
    SGMII
    XAUI (2.5G SGMII)
    QSGMII
    USXGMII/XFI
    (5G/10G)
    1
    MCU CPSW2G
    YES
    2
    Main CPSW2G
    YES
    3
    Main CPSW5G
    YES
    YES
    YES
    YES
    YES (Only from Port-1)
    4
    Main CPSW9G (J721E)
    YES
    YES
    YES
    YES
    YES (Only from Port-1, Port-2)
    5
    Main CPSW9G (J784S4)
    YES
    YES
    YES
    6
    Main CPSW3G
    YES
    YES
    Note:
    Only one interface can be used at a time, we can’t enable multiple interfaces at the same time.
    CPSWnG: Has one Internal Host Port + (n-1) External Physical Port for connecting to the External world.
