AM625: Boot Stall and Crashes
Part Number: AM625
Other Parts Discussed in Thread: SK-AM62-LP, SK-AM62B-P1, SK-AM62
This is a follow-up of previous threads and discussion from months ago:
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1268222/am625-boot-stall-and-rcu-preempt-stall
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1309832/am625-crash-internal-error-synchronous-external-abort-in-mcan-driver-at-low-temperatures-20-degrees-celsius/4978691
Software/Hardware configuration:
- TI SDK 09.02.01.09
- Custom HW (various configurations of memory size and memory vendor, different SOC variants: AM6254, AM6231, AM6252)
- Kernel sources: https://git.toradex.com/cgit/linux-toradex.git/log/?h=toradex_ti-linux-6.1.y
- U-Boot sources: https://git.toradex.com/cgit/u-boot-toradex.git/log/?h=toradex_ti-u-boot-2023.04
- The DDR was validated both internally by us and by the memory vendor on its premises. We have variants with memory with different sizes and vendors and they are all affected by the same issues
- We have variant with 0.75V and 0.85V VDD_CORE, no differences on the behavior because of this
During the testing of our software/hardware, we faced some issues with the boot stalling in different ways. They all happen below -20 Celsius degrees.
1. system stalls with the following error.
[   86.779029] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[   86.785173] rcu: 	Tasks blocked on level-0 rcu_node (CPUs 0-0): P186/1:b..l
[   86.792151] 	(detected by 0, t=18276 jiffies, g=6889, q=115 ncpus=1)
[   86.798506] task:systemd-udevd   state:R  running task     stack:0     pid:186   ppid:173    flags:0x00000a04
[   86.808424] Call trace:
[   86.810870]  __switch_to+0xd4/0x130
[   86.814374]  __schedule+0x230/0x664
[   86.817863]  preempt_schedule_irq+0x44/0xd0
[   86.822047]  el1_interrupt+0x4c/0x70
[   86.825626]  el1h_64_irq_handler+0x18/0x2c
[   86.829725]  el1h_64_irq+0x64/0x68
[   86.833130]  set_root+0x64/0xfc
[   86.836275]  nd_jump_root+0xb8/0xf0
[   86.839764]  path_init+0x2d0/0x380
[   86.843167]  path_parentat+0x20/0xb0
[   86.846743]  __filename_parentat+0xa4/0x1c0
[   86.850927]  do_unlinkat+0x68/0x270
[   86.854416]  __arm64_sys_unlinkat+0x40/0x84
[   86.858600]  invoke_syscall+0x48/0x114
[   86.862352]  el0_svc_common.constprop.0+0xd4/0xfc
[   86.867057]  do_el0_svc+0x20/0x30
[   86.870372]  el0_svc+0x28/0xa0
[   86.873428]  el0t_64_sync_handler+0xbc/0x140
[   86.877701]  el0t_64_sync+0x18c/0x190
[   86.881364] rcu: rcu_preempt kthread timer wakeup didn't happen for 18273 jiffies! g6889 f0x0 RCU_GP_WAIT_FQS(5) ->state=0x402
[   86.892749] rcu: 	Possible timer handling issue on cpu=0 timer-softirq=2071
[   86.899705] rcu: rcu_preempt kthread starved for 18274 jiffies! g6889 f0x0 RCU_GP_WAIT_FQS(5) ->state=0x402 ->cpu=0
[   86.910136] rcu: 	Unless rcu_preempt kthread gets sufficient CPU time, OOM is now expected behavior.
[   86.919260] rcu: RCU grace-period kthread stack dump:
[   86.924305] task:rcu_preempt     state:I stack:0     pid:14    ppid:2      flags:0x00000008
[   86.932656] Call trace:
[   86.935099]  __switch_to+0xd4/0x130
[   86.938587]  __schedule+0x230/0x664
[   86.942074]  schedule+0x5c/0xcc
[   86.945216]  schedule_timeout+0x84/0xfc
[   86.949055]  rcu_gp_fqs_loop+0x12c/0x46c
[   86.952983]  rcu_gp_kthread+0x128/0x164
[   86.956820]  kthread+0x10c/0x110
[   86.960051]  ret_from_fork+0x10/0x20
[   86.963627] rcu: Stack dump where RCU GP kthread last ran:
[   86.969111] CPU: 0 PID: 181 Comm: systemd-udevd Not tainted 6.1.80+git.0d9f1748ac17 #1
[   86.977026] Hardware name: Toradex Verdin AM62 WB on Verdin Development Board (DT)
[   86.984591] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[   86.991550] pc : iomap_read_reg+0x10/0x30 [m_can_platform]
[   86.997049] lr : m_can_get_berr_counter+0x3c/0x10c [m_can]
[   87.002548] sp : ffff8000099735f0
[   87.005858] x29: ffff8000099735f0 x28: 0000000000000240 x27: ffff800000cca1a0
[   87.012998] x26: ffff000003f9e000 x25: ffff000003f9e240 x24: 0000000000000000
[   87.020137] x23: 0000000000000000 x22: ffff0000002ae410 x21: ffff0000035f8000
[   87.027276] x20: ffff0000035f8980 x19: ffff80000997362c x18: 0000000000000000
[   87.034414] x17: ffff800014add000 x16: ffff800008000000 x15: 0000000000000000
[   87.041552] x14: 000000000000022f x13: 0000000000000001 x12: 0000000000000001
[   87.048691] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff8000099731e0
[   87.055829] x8 : ffff00001da1b180 x7 : 0000010000108100 x6 : ffff0000002ae590
[   87.062968] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 0000000000000000
[   87.070106] x2 : ffff800000ca4000 x1 : 0000000000000040 x0 : 000000000071ff00
[   87.077244] Call trace:
[   87.079687]  iomap_read_reg+0x10/0x30 [m_can_platform]
[   87.084832]  can_fill_info+0x108/0x524 [can_dev]
[   87.089477]  rtnl_fill_ifinfo+0x844/0x11b0
[   87.093578]  rtnl_getlink+0x23c/0x424
[   87.097239]  rtnetlink_rcv_msg+0x130/0x3a0
[   87.101334]  netlink_rcv_skb+0x60/0x130
[   87.105174]  rtnetlink_rcv+0x18/0x2c
[   87.108755]  netlink_unicast+0x2f0/0x360
[   87.112677]  netlink_sendmsg+0x1b0/0x420
[   87.116600]  __sys_sendto+0x138/0x174
[   87.120265]  __arm64_sys_sendto+0x28/0x3c
[   87.124275]  invoke_syscall+0x48/0x114
[   87.128024]  el0_svc_common.constprop.0+0xd4/0xfc
[   87.132729]  do_el0_svc+0x20/0x30
[   87.136044]  el0_svc+0x28/0xa0
[   87.139100]  el0t_64_sync_handler+0xbc/0x140
[   87.143372]  el0t_64_sync+0x18c/0x190
Complete logs:
Climate Chamber:       KWP 120
Start Temperature:     -29.2�C
End Temperature:       -28.3�C
Measured Temperature:  -29.2�C
Shelf Temperature:     -28.5�C
Shelf Name:            Shelf_33
Module Serial Number:  15313618
Module Location:       Shelf 1, Carrier Board 5
Test duration:         157.60s
Test Log
22:12:35.84 13->14 Waited 60.00s
22:11:35.75 12->13 Set Reset Low
22:11:35.68 11->12 Power Off
22:11:35.62 5->11 Not found, time out: "login:"
22:10:05.48 4->5 Message found: "Starting kernel"
22:10:00.04 3->4 Message found: "U-Boot"
22:09:59.93 2->3 Waited 1.00s
22:09:58.79 1->2 Set Reset High
22:09:58.68 0->1 Power On
Search Strings
PASS : U-Boot
PASS : Less than 64MB RAM detected
PASS : Booting from mmc failed!
PASS : Starting kernel
PASS : mmcblk0: mmc0
PASS : cut here
FAIL : rcu: INFO: rcu_preempt detected
PASS : rcu: INFO: rcu_preempt self-detected stall
PASS : Internal error
PASS : I/O error
FAIL : login:
FAIL : I2C test, TestResult: PASS
FAIL : RTC test, TestResult: PASS
FAIL : Audio test, TestResult: PASS
FAIL : Wifi test, TestResult: PASS
FAIL : Bluetooth test, TestResult: PASS
FAIL : CPU stress test, TestResult: PASS
PASS : critical temperature reached
FAIL : Ethernet test, TestResult: PASS
FAIL : connected with
FAIL : RAM test, TestResult: PASS
PASS : memtester failed
FAIL : memtester version
PASS : FAILURE
PASS : running CQE recovery
FAIL : eMMC Nand test, TestResult: PASS
PASS : bonnie\+\+ failed
FAIL : Waiting for power-cycle
0 : OAK ERROR
1 : UART ERROR
OK : registered as rtc0
OK : registered as rtc1
OK : xception stack
N/A : Device life time estimation type B
N/A : Pre EOL information
2 : USB hub found
0 : xception stack
PASS : page allocation failure
PASS : hwclock
Terminal
U-Boot SPL 2024.04-00035-gfc942d8282-dirty (Apr 16 2024 - 11:52:32 +0200)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
SPL initial stack usage: 13368 bytes
Trying to boot from MMC1
Authentication passed
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.10.0	(release):v2.10.0-340-g4da4a1a61
NOTICE:  BL31: Built : 11:30:01, Feb  8 2024
I/TC:
I/TC: OP-TEE version: 4.1.0-71-g439c5ecbb (gcc version 12.3.1 20230626 (Arm GNU Toolchain 12.3.Rel1 (Build arm-12.35))) #5 Fri Feb 23 13:00:52 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
I/TC: HUK Initialized
I/TC: Primary CPU switching to normal world boot
U-Boot SPL 2024.04-00035-gfc942d8282-dirty (Apr 16 2024 - 11:47:25 +0200)
SPL initial stack usage: 1840 bytes
U-Boot 2024.04-00035-gfc942d8282-dirty (Apr 16 2024 - 11:47:25 +0200)
SoC:   AM62X SR1.0 HS-FS
DRAM:  512 MiB
Core:  138 devices, 29 uclasses, devicetree: separate
MMC:   mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from MMC... OK
MISSING TORADEX CARRIER CONFIG BLOCKS
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Model: Toradex 0072 Verdin AM62 Solo 512MB WB IT V1.1B
Serial#: 15313618
am65_cpsw_nuss ethernet@8000000: K3 CPSW: nuss_ver: 0x6BA01103 cpsw_ver: 0x6BA81103 ale_ver: 0x00290105 Ports:2 mdio_freq:1000000
Setting variant to wifi
Net:
Warning: ethernet@8000000port@1 MAC addresses don't match:
Address in ROM is		64:1c:10:2a:76:c6
Address in environment is	00:14:2d:e9:aa:d2
eth0: ethernet@8000000port@1 [PRIME]Could not get PHY for ethernet@8000000port@1: addr 7
am65_cpsw_nuss_port ethernet@8000000port@2: phy_connect() failed
Hit any key to stop autoboot:  1  0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
6003 bytes read in 15 ms (390.6 KiB/s)
## Executing script at 90280000
Loading DeviceTree: k3-am625-verdin-wifi-dev.dtb
70049 bytes read in 16 ms (4.2 MiB/s)
82 bytes read in 14 ms (4.9 KiB/s)
Working FDT set to 90200000
Applying Overlay: verdin-am62_dsi-to-hdmi_overlay.dtbo
3050 bytes read in 15 ms (198.2 KiB/s)
Applying Overlay: verdin-am62_spidev_overlay.dtbo
560 bytes read in 15 ms (36.1 KiB/s)
7861931 bytes read in 76 ms (98.7 MiB/s)
Bootargs: root=PARTUUID=f360aa55-02 ro rootwait console=tty1 console=ttyS2,115200 consoleblank=0 earlycon=ns16550a,mmio32,0x02800000
   Uncompressing Kernel Image to 0
## Flattened Device Tree blob at 90200000
   Booting using the fdt blob at 0x90200000
ERROR: reserving fdt memory region failed (addr=9e780000 size=80000 flags=4)
ERROR: reserving fdt memory region failed (addr=9e800000 size=1800000 flags=4)
ERROR: reserving fdt memory region failed (addr=9db00000 size=c00000 flags=4)
   Loading Device Tree to 0000000098ed5000, end 0000000098f09fff ... OK
Working FDT set to 98ed5000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.1.80+git.0d9f1748ac17 (oe-user@oe-host) (aarch64-tdx-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Thu Mar 28 13:48:11 UTC 2024
[    0.000000] Machine model: Toradex Verdin AM62 WB on Verdin Development Board
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009dafffff]
[    0.000000]   node   0: [mem 0x000000009db00000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
[    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000] cma: Reserved 128 MiB at 0x0000000090e00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129024
[    0.000000] Kernel command line: root=PARTUUID=f360aa55-02 ro rootwait console=tty1 console=ttyS2,115200 consoleblank=0 earlycon=ns16550a,mmio32,0x02800000
[    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 326452K/524288K available (11072K kernel code, 1354K rwdata, 3784K rodata, 2176K init, 422K bss, 66764K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=1.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000080030000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008741] Console: colour dummy device 80x25
[    0.013998] printk: console [tty1] enabled
[    0.018258] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.028968] pid_max: default: 32768 minimum: 301
[    0.033771] LSM: Security Framework initializing
[    0.038658] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.046167] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.056427] cblist_init_generic: Setting adjustable number of callback queues.
[    0.063928] cblist_init_generic: Setting shift to 0 and lim to 1.
[    0.070273] cblist_init_generic: Setting adjustable number of callback queues.
[    0.077696] cblist_init_generic: Setting shift to 0 and lim to 1.
[    0.084180] rcu: Hierarchical SRCU implementation.
[    0.089112] rcu: 	Max phase no-delay instances is 1000.
[    0.095333] Platform MSI: msi-controller@1820000 domain created
[    0.102075] EFI services will not be available.
[    0.106997] smp: Bringing up secondary CPUs ...
[    0.111667] smp: Brought up 1 node, 1 CPU
[    0.115785] SMP: Total of 1 processors activated.
[    0.120617] CPU features: detected: 32-bit EL0 Support
[    0.125892] CPU features: detected: CRC32 instructions
[    0.131247] CPU: All CPU(s) started at EL2
[    0.135451] alternatives: applying system-wide alternatives
[    0.142834] devtmpfs: initialized
[    0.158651] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.168727] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.182721] pinctrl core: initialized pinctrl subsystem
[    0.189133] DMI not present or invalid.
[    0.194026] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.201430] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[    0.208807] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.216851] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.225077] audit: initializing netlink subsys (disabled)
[    0.231398] thermal_sys: Registered thermal governor 'step_wise'
[    0.231411] thermal_sys: Registered thermal governor 'power_allocator'
[    0.237604] audit: type=2000 audit(0.148:1): state=initialized audit_enabled=0 res=1
[    0.252296] cpuidle: using governor menu
[    0.256580] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.263608] ASID allocator initialised with 65536 entries
[    0.290281] KASLR disabled due to lack of seed
[    0.303826] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.310960] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.317395] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.324354] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.330781] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.337739] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.344165] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.351122] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.359487] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[    0.369941] iommu: Default domain type: Translated
[    0.375013] iommu: DMA domain TLB invalidation policy: strict mode
[    0.381818] SCSI subsystem initialized
[    0.386153] usbcore: registered new interface driver usbfs
[    0.391852] usbcore: registered new interface driver hub
[    0.397333] usbcore: registered new device driver usb
[    0.403190] pps_core: LinuxPPS API ver. 1 registered
[    0.408292] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.417668] PTP clock support registered
[    0.421892] EDAC MC: Ver: 3.0.0
[    0.426568] FPGA manager framework
[    0.430217] Advanced Linux Sound Architecture Driver Initialized.
[    0.437814] clocksource: Switched to clocksource arch_sys_counter
[    0.444498] VFS: Disk quotas dquot_6.6.0
[    0.448589] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.463527] NET: Registered PF_INET protocol family
[    0.469038] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.477741] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.486421] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.494378] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.502365] TCP bind hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.509964] TCP: Hash tables configured (established 4096 bind 4096)
[    0.516621] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.523343] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.530665] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.537040] RPC: Registered named UNIX socket transport module.
[    0.543174] RPC: Registered udp transport module.
[    0.548003] RPC: Registered tcp transport module.
[    0.552828] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.559439] NET: Registered PF_XDP protocol family
[    0.565276] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.576109] Initialise system trusted keyrings
[    0.581058] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[    0.594210] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.601028] NFS: Registering the id_resolver key type
[    0.606329] Key type id_resolver registered
[    0.610625] Key type id_legacy registered
[    0.614824] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.621702] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.685005] Key type asymmetric registered
[    0.689221] Asymmetric key parser 'x509' registered
[    0.694341] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.702143] io scheduler mq-deadline registered
[    0.706816] io scheduler kyber registered
[    0.716168] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.723664] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.739628] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
[    0.759811] brd: module loaded
[    0.768904] loop: module loaded
[    0.777614] tun: Universal TUN/TAP device driver, 1.6
[    0.784036] VFIO - User Level meta-driver version: 0.3
[    0.790746] usbcore: registered new interface driver usb-storage
[    0.797906] i2c_dev: i2c /dev entries driver
[    0.805040] sdhci: Secure Digital Host Controller Interface driver
[    0.811447] sdhci: Copyright(c) Pierre Ossman
[    0.816361] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.823008] ledtrig-cpu: registered to indicate activity on CPUs
[    0.829415] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.836562] usbcore: registered new interface driver usbhid
[    0.842285] usbhid: USB HID core driver
[    0.847709] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    0.852348] optee: revision 4.1 (439c5ecb)
[    0.869055] optee: dynamic shared memory is enabled
[    0.878624] optee: initialized driver
[    0.884857] Initializing XFRM netlink socket
[    0.889476] NET: Registered PF_PACKET protocol family
[    0.894803] Key type dns_resolver registered
[    0.899734] registered taskstats version 1
[    0.903977] Loading compiled-in X.509 certificates
[    0.923699] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
[    1.015166] omap_i2c 4900000.i2c: bus 3 rev0.12 at 100 kHz
[    1.023018] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
[    1.064072] input: tps65219-pwrbutton as /devices/platform/bus@f0000/20000000.i2c/i2c-0/0-0030/tps65219-pwrbutton.2.auto/input/input0
[    1.078851] rtc-ds1307 0-0032: oscillator failed, set time!
[    1.084853] rtc-ds1307 0-0032: registered as rtc0
[    1.089861] rtc-ds1307 0-0032: hctosys: unable to read the hardware clock
[    1.099624] at24 0-0050: supply vcc not found, using dummy regulator
[    1.106713] at24 0-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[    1.113668] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.122378] pca953x 1-0021: supply vcc not found, using dummy regulator
[    1.129424] pca953x 1-0021: using no AI
[    1.153963] pca953x 1-0021: failed writing register
[    1.159208] pca953x: probe of 1-0021 failed with error -121
[    1.165743] at24 1-0057: supply vcc not found, using dummy regulator
[    1.173087] at24 1-0057: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[    1.180058] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    1.187228] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz
[    1.194156] omap_i2c 20030000.i2c: bus 4 rev0.12 at 100 kHz
[    1.200251] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[    1.208680] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.218050] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.231961] ti-udma 485c0100.dma-controller: Number of rings: 82
[    1.241098] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.253263] ti-udma 485c0000.dma-controller: Number of rings: 150
[    1.264895] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.276269] 4a00000.serial: ttyS3 at MMIO 0x4a00000 (irq = 291, base_baud = 3000000) is a 8250
[    1.286834] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 292, base_baud = 3000000) is a 8250
[    1.295832] printk: console [ttyS2] enabled
[    1.304335] printk: bootconsole [ns16550a0] disabled
[    1.315862] 2810000.serial: ttyS0 at MMIO 0x2810000 (irq = 293, base_baud = 3000000) is a 8250
[    1.325583] omap8250 2850000.serial: PM domain pd:156 will not be powered off
[    1.333146] 2850000.serial: ttyS4 at MMIO 0x2850000 (irq = 294, base_baud = 3000000) is a 8250
[    1.341983] serial serial0: tty port ttyS4 registered
[    1.348868] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    1.393827] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.402951] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[    1.416017] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.423205] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    1.430149] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[    1.440812] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    1.458918] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    1.464520] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[    1.472354] xhci-hcd xhci-hcd.3.auto: USB3 root hub has no ports
[    1.478380] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020010010
[    1.487875] xhci-hcd xhci-hcd.3.auto: irq 299, io mem 0x31100000
[    1.495008] hub 1-0:1.0: USB hub found
[    1.498876] hub 1-0:1.0: 1 port detected
[    1.635583] mmc0: CQHCI version 5.10
[    1.642498] gpio-488 (PCIE_1_RESET#): hogged as output/low
[    1.650560] gpio-427 (CTRL_SLEEP_MOCI#): hogged as output/high
[    1.667963] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    1.687190] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    1.713815] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.726778] mdio_bus 8000f00.mdio: MDIO device at address 7 is missing.
[    1.733476] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    1.745358] sdhci-am654 fa00000.mmc: Got CD GPIO
[    1.751185] sdhci-am654 fa20000.mmc: allocated mmc-pwrseq
[    1.757925] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    1.766019] mmc1: CQHCI version 5.10
[    1.769949] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    1.776786] mmc2: CQHCI version 5.10
[    1.787674] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    1.794814] mmc0: Command Queue Engine enabled
[    1.799325] mmc0: new HS200 MMC card at address 0001
[    1.807267] mmcblk0: mmc0:0001 M04A11 3.64 GiB
[    1.815734]  mmcblk0: p1 p2
[    1.820300] mmcblk0boot0: mmc0:0001 M04A11 4.00 MiB
[    1.827956] mmcblk0boot1: mmc0:0001 M04A11 4.00 MiB
[    1.833042] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[    1.842782] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    1.850985] mmcblk0rpmb: mmc0:0001 M04A11 4.00 MiB, chardev (241:0)
[    1.857436] ALSA device list:
[    1.861226]   No soundcards found.
[    1.872204] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    1.879658] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    1.917200] mmc2: new ultra high speed DDR50 SDIO card at address 0001
[    1.929960] EXT4-fs (mmcblk0p2): recovery complete
[    1.939642] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[    1.948436] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.957168] devtmpfs: mounted
[    1.961742] Freeing unused kernel memory: 2176K
[    1.966514] Run /sbin/init as init process
[    2.006634] hub 1-1:1.0: USB hub found
[    2.011231] hub 1-1:1.0: 4 ports detected
[    2.102682] systemd[1]: System time before build time, advancing clock.
[    2.149156] NET: Registered PF_INET6 protocol family
[    2.155807] Segment Routing with IPv6
[    2.159737] In-situ OAM (IOAM) with IPv6
[    2.188938] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[    2.221111] systemd[1]: Detected architecture arm64.
Welcome to TDX Wayland with XWayland 6.6.0+build.12 (kirkstone)!
[    2.271706] systemd[1]: Hostname set to <verdin-am62-15313618>.
[    2.357979] usb 1-1.4: new high-speed USB device number 3 using xhci-hcd
[    2.894162] systemd[1]: Queued start job for default target Graphical Interface.
[    2.953744] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    2.976737] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    3.000622] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    3.024175] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    3.046545] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    3.070547] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    3.094609] systemd[1]: Reached target Host and Network Name Lookups.
[  OK  ] Reached target Host and Network Name Lookups.
[    3.118055] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    3.138407] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    3.162210] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    3.182196] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    3.244264] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    3.266502] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    3.291812] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    3.314946] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    3.340011] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    3.363293] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    3.387496] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    3.412464] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    3.436099] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    3.459534] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    3.485090] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    3.534563] systemd[1]: Mounting Huge Pages File System...
[    3.574641] systemd[1]: Mounting POSIX Message Queue File System...
[    3.618600] systemd[1]: Mounting Kernel Debug File System...
[    3.637393] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[    3.674808] systemd[1]: Mounting Temporary Directory /tmp...
[    3.722804] systemd[1]: Starting Create List of Static Device Nodes...
[    3.770812] systemd[1]: Starting Load Kernel Module configfs...
[    3.818819] systemd[1]: Starting Load Kernel Module drm...
[    3.855089] systemd[1]: Starting Load Kernel Module fuse...
[    3.880254] fuse: init (API version 7.37)
[    3.906760] systemd[1]: Starting RPC Bind...
[    3.945471] systemd[1]: Starting File System Check on Root Device...
[    3.999047] systemd[1]: Starting Journal Service...
[    4.055247] systemd[1]: Starting Load Kernel Modules...
[    4.108670] systemd[1]: Starting Generate network units from Kernel command line...
         Starting Generate network …ts from Kernel command line...
[    4.174316] systemd[1]: Starting Coldplug All udev Devices...
[    4.252030] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    4.291107] systemd[1]: Mounted Huge Pages File System.
[  OK  ] Mounted Huge Pages File System.
[    4.323111] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    4.359027] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[    4.391037] systemd[1]: Mounted Temporary Directory /tmp.
[  OK  ] Mounted Temporary Directory /tmp.
[    4.424539] systemd[1]: Finished Create List of Static Device Nodes.
[  OK  ] Finished Create List of Static Device Nodes.
[    4.463771] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    4.490396] systemd[1]: Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module configfs.
[    4.527063] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[  OK  ] Finished File System Check on Root Device.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Generate network units from Kernel command line.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Remount Root and Kernel File Systems...
         Starting Apply Kernel Variables...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Apply Kernel Variables.
[    4.986677] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Starting Flush Journal to Persistent Storage...
         Starting Create Static Device Nodes in /dev...
[    5.122533] systemd-journald[154]: Received client request to flush runtime journal.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /var/volatile...
[    5.300098] audit: type=1334 audit(1651167748.196:2): prog-id=5 op=LOAD
[    5.325154] audit: type=1334 audit(1651167748.208:3): prog-id=6 op=LOAD
         Starting Rule-based Manage…for Device Events and Files...
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Started Rule-based Manager for Device Events and Files.
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[  OK  ] Finished Coldplug All udev Devices.
         Starting Wait for udev To …plete Device Initialization...
[    6.449919] random: crng init done
[  OK  ] Finished Load/Save Random Seed.
[  OK  ] Started Network Time Synchronizatio[    6.945149] systemd-journald[154]: Oldest entry in /run/log/journal/98d6394cd75d4f2dad68076443517daa/system.journal is older than the configured file retention duration (1month), suggesting rotation.
n.
[  OK  ] Reached target System Time Set.
[    7.020112] systemd-journald[154]: /run/log/journal/98d6394cd75d4f2dad68076443517daa/system.journal: Journal header limits reached or header out-of-date, rotating.
[    7.521756] lm75 0-0048: supply vs not found, using dummy regulator
[    7.541716] omap8250 2b300000.serial: No clock speed specified: using default: 48000000
[    7.575821] 2b300000.serial: ttyS1 at MMIO 0x2b300000 (irq = 485, base_baud = 3000000) is a 8250
[    7.631547] hwmon hwmon1: temp1_input not attached to any thermal zone
[    7.656301] ina2xx 1-0040: error configuring the device: -121
[    7.665554] nau8822 1-001a: Failed to issue reset: -121
[    7.707843] lm75 0-0048: hwmon1: sensor 'tmp1075'
[    7.721699] nau8822: probe of 1-001a failed with error -121
[    7.744113] CAN device driver interface
[    7.766785] lm75 1-004f: supply vs not found, using dummy regulator
[    7.853274] hwmon hwmon2: temp1_input not attached to any thermal zone
[    7.866875] m_can_platform 4e08000.can: m_can device registered (irq=0, version=32)
[    7.929951] lm75 1-004f: hwmon2: sensor 'tmp75c'
[  OK  ] Found device /dev/ttyS2.
[    7.970693] m_can_platform 20701000.can: m_can device registered (irq=487, version=32)
[    8.333694] Bluetooth: Core ver 2.22
[    8.373929] k3-m4-rproc 5000000.m4fss: device does not reserved memory regions, ret = -22
[    8.423953] NET: Registered PF_BLUETOOTH protocol family
[    8.471681] k3-m4-rproc 5000000.m4fss: reserved memory init failed, ret = -22
[    8.492952] Bluetooth: HCI device and connection manager initialized
[    8.547050] remoteproc remoteproc0: releasing 5000000.m4fss
[    8.555637] Bluetooth: HCI socket layer initialized
[    8.611257] Bluetooth: L2CAP socket layer initialized
[    8.616886] k3-m4-rproc: probe of 5000000.m4fss failed with error -22
[    8.686371] Bluetooth: SCO socket layer initialized
[    8.818317] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
[    8.858490] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    9.037121] platform 78000000.r5f: configured R5F for IPC-only mode
[    9.117604] platform 78000000.r5f: device does not have reserved memory regions, ret = -22
[    9.139396] lt8912 1-0048: supply vdd not found, using dummy regulator
[    9.150509] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    9.158689] lt8912 1-0048: supply vccmipirx not found, using dummy regulator
[    9.168500] lt8912 1-0048: supply vccsysclk not found, using dummy regulator
[    9.185702] lt8912 1-0048: supply vcclvdstx not found, using dummy regulator
[    9.202141] lt8912 1-0048: supply vcchdmitx not found, using dummy regulator
[    9.218109] lt8912 1-0048: supply vcclvdspll not found, using dummy regulator
[    9.234095] lt8912 1-0048: supply vcchdmipll not found, using dummy regulator
[    9.273170] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: reserved memory init failed, ret = -22
[    9.291153] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[    9.306164] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[    9.326420] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[    9.363223] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    9.408365] remoteproc remoteproc0: releasing 78000000.r5f
[    9.437554] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    9.456495] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_cluster_rproc_init failed, ret = -22
[    9.582017] k3_r5_rproc: probe of bus@f0000:bus@b00000:r5fss@78000000 failed with error -22
[   10.061498] mwifiex_sdio mmc2:0001:1: info: FW download over, size 570976 bytes
[*     ] A start job is running for Wait for…ice Initialization (2s / 2min 57s)
[   11.477920] mwifiex_sdio mmc2:0001:1: WLAN FW is active
[   11.531305] mwifiex_sdio mmc2:0001:1: Unknown api_id: 5
[   11.575400] mwifiex_sdio mmc2:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.92.21.p84)
[   11.589950] mwifiex_sdio mmc2:0001:1: driver_version = mwifiex 1.0 (16.92.21.p84)
M
[**    ] A start job is running for Wait for…ice Initialization (2s / 2min 57s)
M
[***   ] A start job is running for Wait for…ice Initialization (3s / 2min 57s)
M
[ ***  ] A start job is running for Wait for…ice Initialization (3s / 2min 57s)
M
[  *** ] A start job is running for Wait for…ice Initialization (4s / 2min 57s)
M
[   ***] A start job is running for Wait for…ice Initialization (4s / 2min 57s)
M
[    **] A start job is running for Wait for…itialization (1min 18s / 2min 57s)
[   87.171051] platform sound: deferred probe pending
M
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Created slice Slice /system/systemd-fsck.
[  OK  ] Found device /dev/mmcblk0p1.
[  OK  ] Finished Wait for udev To Complete Device Initialization.
[   88.788341] audit: type=1334 audit(1713384460.956:4): prog-id=7 op=LOAD
[   88.799379] audit: type=1334 audit(1713384460.968:5): prog-id=8 op=LOAD
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Logs some system s…istics to the systemd journal.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on GPS (Global P…ioning System) Daemon Sockets.
         Starting Weston socket...
         Starting File System Check on /dev/mmcblk0p1...
[  OK  ] Listening on Weston socket.
[  OK  ] Reached target Socket Units.
[  OK  ] Reached target Basic System.
         Starting Bluetooth service...
[  OK  ] Started Kernel Logging Service.
[  OK  ] Started System Logging Service.
         Starting D-Bus System Message Bus...
         Starting show continuously some info about the som...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
         Starting Telephony service...
[   89.645375] audit: type=1334 audit(1713384461.812:6): prog-id=9 op=LOAD
[   89.682739] audit: type=1334 audit(1713384461.824:7): prog-id=10 op=LOAD
         Starting User Login Management...
[  OK  ] Started start the tests in climatic chamber.
[  OK  ] Started Timestamping service.
         Starting Load default USB gadget schema g1.schema...
[  OK  ] Started D-Bus System Message Bus.
[   90.069121] using random self ethernet address
[   90.101441] using random host ethernet address
[  OK  ] Finished File System Check on /dev/mmcblk0p1.
[  OK  ] Finished IPv6 Packet Filtering Framework.
[  OK  ] Finished IPv4 Packet Filtering Framework.
[  OK  ] Reached target Preparation for Network.
***** UART ERROR ****
UART Error Code: -1073807253
VISA Read in ModuleProcess.vi:1380011->ClimateChamberControl.viVISA Source: COM16
2. Boot stall without any message.
Log is attached, however from what I can tell there is no hint of what's going on
Start Temperature:     -34.6�C
End Temperature:       -35.5�C
Measured Temperature:  -34.6�C
Shelf Temperature:     -32.7�C
Test duration:         158.31s
Test Log
18:29:29.12 13->14 Waited 60.00s
18:28:28.90 12->13 Set Reset Low
18:28:28.79 11->12 Power Off
18:28:28.68 5->11 Not found, time out: "login:"
18:26:58.48 4->5 Message found: "Starting kernel"
18:26:52.46 3->4 Message found: "U-Boot"
18:26:52.45 2->3 Waited 1.00s
18:26:51.32 1->2 Set Reset High
18:26:51.24 0->1 Power On
Search Strings
PASS : U-Boot
PASS : cut here
PASS : rcu: INFO: rcu_preempt detected
PASS : I/O error
FAIL : login:
PASS : FAILURE
0 : OAK ERROR
1 : UART ERROR
OK : xception stack
2 : USB hub found
0 : xception stack
PASS : hwclock
Terminal
I/TC:
DRAM:  512 MiB
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Serial#: 15313618
Net:
Scanning mmc 0:1...
82 bytes read in 15 ms (4.9 KiB/s)
560 bytes read in 16 ms (34.2 KiB/s)
Starting kernel ...
[    0.008742] Console: colour dummy device 80x25
[    0.014002] printk: console [tty1] enabled
[    0.018262] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.028973] pid_max: default: 32768 minimum: 301
[    0.033774] LSM: Security Framework initializing
[    0.038662] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.046171] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.056437] cblist_init_generic: Setting adjustable number of callback queues.
[    0.063936] cblist_init_generic: Setting shift to 0 and lim to 1.
[    0.070279] cblist_init_generic: Setting adjustable number of callback queues.
[    0.077702] cblist_init_generic: Setting shift to 0 and lim to 1.
[    0.084181] rcu: Hierarchical SRCU implementation.
[    0.095319] Platform MSI: msi-controller@1820000 domain created
[    0.102059] EFI services will not be available.
[    0.106992] smp: Bringing up secondary CPUs ...
[    0.111659] smp: Brought up 1 node, 1 CPU
[    0.115776] SMP: Total of 1 processors activated.
[    0.120607] CPU features: detected: 32-bit EL0 Support
[    0.125884] CPU features: detected: CRC32 instructions
[    0.131240] CPU: All CPU(s) started at EL2
[    0.135444] alternatives: applying system-wide alternatives
[    0.142818] devtmpfs: initialized
[    0.158662] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.168738] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.182772] pinctrl core: initialized pinctrl subsystem
[    0.189190] DMI not present or invalid.
[    0.194079] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.201486] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[    0.208868] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.216913] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.225140] audit: initializing netlink subsys (disabled)
[    0.231468] thermal_sys: Registered thermal governor 'step_wise'
[    0.231482] thermal_sys: Registered thermal governor 'power_allocator'
[    0.237675] audit: type=2000 audit(0.148:1): state=initialized audit_enabled=0 res=1
[    0.252368] cpuidle: using governor menu
[    0.256651] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.263676] ASID allocator initialised with 65536 entries
[    0.290297] KASLR disabled due to lack of seed
[    0.303853] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.310985] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.317422] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.324381] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.330807] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.337764] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.344190] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.351148] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.359513] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[    0.369953] iommu: Default domain type: Translated
[    0.375021] iommu: DMA domain TLB invalidation policy: strict mode
[    0.381822] SCSI subsystem initialized
[    0.391850] usbcore: registered new interface driver hub
[    0.403196] pps_core: LinuxPPS API ver. 1 registered
[    0.408298] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.417674] PTP clock support registered
[    0.421897] EDAC MC: Ver: 3.0.0
[    0.426561] FPGA manager framework
[    0.430206] Advanced Linux Sound Architecture Driver Initialized.
[    0.437794] clocksource: Switched to clocksource arch_sys_counter
[    0.444485] VFS: Disk quotas dquot_6.6.0
[    0.448574] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.463560] NET: Registered PF_INET protocol family
[    0.469066] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.477771] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.486457] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.494413] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.502401] TCP bind hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.509996] TCP: Hash tables configured (established 4096 bind 4096)
[    0.516653] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.523375] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.530710] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.537085] RPC: Registered named UNIX socket transport module.
[    0.543216] RPC: Registered udp transport module.
[    0.548045] RPC: Registered tcp transport module.
[    0.552870] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.559480] NET: Registered PF_XDP protocol family
[    0.565319] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.576123] Initialise system trusted keyrings
[    0.581093] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[    0.594170] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.601074] NFS: Registering the id_resolver key type
[    0.606369] Key type id_resolver registered
[    0.610665] Key type id_legacy registered
[    0.614859] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.621737] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.682736] Key type asymmetric registered
[    0.686951] Asymmetric key parser 'x509' registered
[    0.692072] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.699876] io scheduler mq-deadline registered
[    0.704549] io scheduler kyber registered
[    0.714092] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.721439] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.737297] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
[    0.757528] brd: module loaded
[    0.766705] loop: module loaded
[    0.775454] tun: Universal TUN/TAP device driver, 1.6
[    0.781863] VFIO - User Level meta-driver version: 0.3
[    0.788491] usbcore: registered new interface driver usb-storage
[    0.795622] i2c_dev: i2c /dev entries driver
[    0.802829] sdhci: Secure Digital Host Controller Interface driver
[    0.809215] sdhci: Copyright(c) Pierre Ossman
[    0.814135] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.820781] ledtrig-cpu: registered to indicate activity on CPUs
[    0.827195] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.834338] usbcore: registered new interface driver usbhid
[    0.840065] usbhid: USB HID core driver
[    0.845479] optee: probing for conduit method.
[    0.850116] optee: revision 4.1 (439c5ecb)
[    0.866813] optee: dynamic shared memory is enabled
[    0.876378] optee: initialized driver
[    0.882761] Initializing XFRM netlink socket
[    0.887336] NET: Registered PF_PACKET protocol family
[    0.892634] Key type dns_resolver registered
[    0.897563] registered taskstats version 1
[    0.901816] Loading compiled-in X.509 certificates
[    0.921082] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
[    1.013314] omap_i2c 4900000.i2c: bus 3 rev0.12 at 100 kHz
[    1.021160] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
[    1.064086] input: tps65219-pwrbutton as /devices/platform/bus@f0000/20000000.i2c/i2c-0/0-0030/tps65219-pwrbutton.2.auto/input/input0
[    1.078857] rtc-ds1307 0-0032: oscillator failed, set time!
[    1.084870] rtc-ds1307 0-0032: registered as rtc0
[    1.089875] rtc-ds1307 0-0032: hctosys: unable to read the hardware clock
[    1.099594] at24 0-0050: supply vcc not found, using dummy regulator
[    1.106699] at24 0-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[    1.113665] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.122388] pca953x 1-0021: supply vcc not found, using dummy regulator
[    1.129429] pca953x 1-0021: using no AI
[    1.153942] pca953x 1-0021: failed writing register
[    1.159185] pca953x: probe of 1-0021 failed with error -121
[    1.165720] at24 1-0057: supply vcc not found, using dummy regulator
[    1.173052] at24 1-0057: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[    1.180025] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    1.187181] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz
[    1.194111] omap_i2c 20030000.i2c: bus 4 rev0.12 at 100 kHz
[    1.200205] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[    1.208636] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.218007] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.231963] ti-udma 485c0100.dma-controller: Number of rings: 82
[    1.241104] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.253256] ti-udma 485c0000.dma-controller: Number of rings: 150
[    1.264900] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.276261] 4a00000.serial: ttyS3 at MMIO 0x4a00000 (irq = 291, base_baud = 3000000) is a 8250
[    1.286803] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 292, base_baud = 3000000) is a 8250
[    1.295801] printk: console [ttyS2] enabled
[    1.304305] printk: bootconsole [ns16550a0] disabled
[    1.315813] 2810000.serial: ttyS0 at MMIO 0x2810000 (irq = 293, base_baud = 3000000) is a 8250
[    1.325528] omap8250 2850000.serial: PM domain pd:156 will not be powered off
[    1.333090] 2850000.serial: ttyS4 at MMIO 0x2850000 (irq = 294, base_baud = 3000000) is a 8250
[    1.341943] serial serial0: tty port ttyS4 registered
[    1.348852] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    1.393804] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.402914] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[    1.415992] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.423182] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    1.430115] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[    1.440788] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    1.458899] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    1.464499] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[    1.472331] xhci-hcd xhci-hcd.3.auto: USB3 root hub has no ports
[    1.478355] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020010010
[    1.487847] xhci-hcd xhci-hcd.3.auto: irq 299, io mem 0x31100000
[    1.494975] hub 1-0:1.0: USB hub found
[    1.498843] hub 1-0:1.0: 1 port detected
[    1.639647] mmc0: CQHCI version 5.10
[    1.645286] gpio-488 (PCIE_1_RESET#): hogged as output/low
[    1.654044] gpio-427 (CTRL_SLEEP_MOCI#): hogged as output/high
[    1.671552] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    1.690765] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    1.717790] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.731009] mdio_bus 8000f00.mdio: MDIO device at address 7 is missing.
[    1.737725] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    1.749853] sdhci-am654 fa00000.mmc: Got CD GPIO
[    1.755590] sdhci-am654 fa20000.mmc: allocated mmc-pwrseq
[    1.762660] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    1.770061] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    1.777282] mmc1: CQHCI version 5.10
[    1.781229] mmc2: CQHCI version 5.10
[    1.790433] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    1.801065] mmc0: Command Queue Engine enabled
[    1.806019] mmc0: new HS200 MMC card at address 0001
[    1.812685] mmcblk0: mmc0:0001 M04A11 3.64 GiB
[    1.821196]  mmcblk0: p1 p2
[    1.825647] mmcblk0boot0: mmc0:0001 M04A11 4.00 MiB
[    1.830724] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[    1.840451] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    1.849028] mmcblk0boot1: mmc0:0001 M04A11 4.00 MiB
[    1.855721] ALSA device list:
[    1.859032]   No soundcards found.
[    1.863725] mmcblk0rpmb: mmc0:0001 M04A11 4.00 MiB, chardev (241:0)
[    1.877754] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[    1.886544] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.894806] devtmpfs: mounted
[    1.899448] Freeing unused kernel memory: 2176K
[    1.904237] Run /sbin/init as init process
[    1.935781] mmc2: new ultra high speed DDR50 SDIO card at address 0001
[    1.974596] hub 1-1:1.0: USB hub found
[    1.979376] hub 1-1:1.0: 4 ports detected
[    2.044626] systemd[1]: System time before build time, advancing clock.
[    2.090508] NET: Registered PF_INET6 protocol family
[    2.097294] Segment Routing with IPv6
[    2.101112] In-situ OAM (IOAM) with IPv6
[    2.129609] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[    2.161915] systemd[1]: Detected architecture arm64.
[    2.215565] systemd[1]: Hostname set to <verdin-am62-15313618>.
[    2.341972] usb 1-1.4: new high-speed USB device number 3 using xhci-hcd
[    2.817374] systemd[1]: Queued start job for default target Graphical Interface.
[    2.877711] systemd[1]: Created slice Slice /system/getty.
[    2.900740] systemd[1]: Created slice Slice /system/modprobe.
[    2.924602] systemd[1]: Created slice Slice /system/serial-getty.
[    2.948185] systemd[1]: Created slice User and Session Slice.
[    2.970517] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    2.994551] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.018620] systemd[1]: Reached target Host and Network Name Lookups.
[    3.042022] systemd[1]: Reached target Path Units.
[    3.062290] systemd[1]: Reached target Remote File Systems.
[    3.086176] systemd[1]: Reached target Slice Units.
[    3.106204] systemd[1]: Reached target Swaps.
[    3.174555] systemd[1]: Listening on RPCbind Server Activation Socket.
[    3.198487] systemd[1]: Reached target RPC Port Mapper.
[    3.223769] systemd[1]: Listening on Syslog Socket.
[    3.246940] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    3.272058] systemd[1]: Listening on Journal Audit Socket.
[    3.295278] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.319902] systemd[1]: Listening on Journal Socket.
[    3.346342] systemd[1]: Listening on Network Service Netlink Socket.
[    3.373173] systemd[1]: Listening on udev Control Socket.
[    3.396158] systemd[1]: Listening on udev Kernel Socket.
[    3.420658] systemd[1]: Listening on User Database Manager Socket.
[    3.470927] systemd[1]: Mounting Huge Pages File System...
[    3.515082] systemd[1]: Mounting POSIX Message Queue File System...
[    3.562672] systemd[1]: Mounting Kernel Debug File System...
[    3.581340] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[    3.614544] systemd[1]: Mounting Temporary Directory /tmp...
[    3.662799] systemd[1]: Starting Create List of Static Device Nodes...
[    3.714853] systemd[1]: Starting Load Kernel Module configfs...
[    3.766948] systemd[1]: Starting Load Kernel Module drm...
[    3.814988] systemd[1]: Starting Load Kernel Module fuse...
[    3.837090] fuse: init (API version 7.37)
[    3.874358] systemd[1]: Starting RPC Bind...
[    3.918981] systemd[1]: Starting File System Check on Root Device...
[    3.971035] systemd[1]: Starting Journal Service...
[    4.027301] systemd[1]: Starting Load Kernel Modules...
[    4.080708] systemd[1]: Starting Generate network units from Kernel command line...
[    4.147233] systemd[1]: Starting Coldplug All udev Devices...
[    4.217049] systemd[1]: Started RPC Bind.
[    4.238553] systemd[1]: Mounted Huge Pages File System.
[    4.279047] systemd[1]: Mounted POSIX Message Queue File System.
[    4.315020] systemd[1]: Mounted Kernel Debug File System.
[    4.346964] systemd[1]: Mounted Temporary Directory /tmp.
[    4.380497] systemd[1]: Finished Create List of Static Device Nodes.
[    4.419684] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    4.446457] systemd[1]: Finished Load Kernel Module configfs.
[    4.487009] systemd[1]: Started Journal Service.
[    4.952190] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[    5.094565] systemd-journald[155]: Received client request to flush runtime journal.
[    5.275993] audit: type=1334 audit(1651167748.228:2): prog-id=5 op=LOAD
[    5.298902] audit: type=1334 audit(1651167748.236:3): prog-id=6 op=LOAD
[    6.389871] random: crng init done
[  OK  ] Started Network Time Synchronizatio[    6.932942] systemd-journald[155]: Oldest entry in /run/log/journal/98d6394cd75d4f2dad68076443517daa/system.journal is older than the configured file retention duration (1month), suggesting rotation.
n.
[    7.006135] systemd-journald[155]: /run/log/journal/98d6394cd75d4f2dad68076443517daa/system.journal: Journal header limits reached or header out-of-date, rotating.
[    7.504857] omap8250 2b300000.serial: No clock speed specified: using default: 48000000
[    7.513100] lm75 0-0048: supply vs not found, using dummy regulator
[    7.524666] 2b300000.serial: ttyS1 at MMIO 0x2b300000 (irq = 485, base_baud = 3000000) is a 8250
[    7.598553] hwmon hwmon1: temp1_input not attached to any thermal zone
[    7.634646] ina2xx 1-0040: error configuring the device: -121
[    7.671330] lm75 0-0048: hwmon1: sensor 'tmp1075'
[    7.707383] nau8822 1-001a: Failed to issue reset: -121
[    7.724486] lm75 1-004f: supply vs not found, using dummy regulator
[    7.771641] nau8822: probe of 1-001a failed with error -121
[    7.789487] CAN device driver interface
[    7.830726] hwmon hwmon2: temp1_input not attached to any thermal zone
[    7.879127] lm75 1-004f: hwmon2: sensor 'tmp75c'
[    7.903803] m_can_platform 4e08000.can: m_can device registered (irq=0, version=32)
[    8.018690] m_can_platform 20701000.can: m_can device registered (irq=489, version=32)
[    8.357560] Bluetooth: Core ver 2.22
[    8.361443] k3-m4-rproc 5000000.m4fss: device does not reserved memory regions, ret = -22
[    8.398193] NET: Registered PF_BLUETOOTH protocol family
[    8.442828] k3-m4-rproc 5000000.m4fss: reserved memory init failed, ret = -22
[    8.469919] Bluetooth: HCI device and connection manager initialized
[    8.530610] remoteproc remoteproc0: releasing 5000000.m4fss
[    8.553175] Bluetooth: HCI socket layer initialized
[    8.589020] k3-m4-rproc: probe of 5000000.m4fss failed with error -22
[    8.604202] Bluetooth: L2CAP socket layer initialized
[    8.680960] Bluetooth: SCO socket layer initialized
[    8.782120] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
[    8.881623] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    9.037641] platform 78000000.r5f: configured R5F for IPC-only mode
[    9.100848] platform 78000000.r5f: device does not have reserved memory regions, ret = -22
[    9.135323] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    9.144308] lt8912 1-0048: supply vdd not found, using dummy regulator
[    9.158229] lt8912 1-0048: supply vccmipirx not found, using dummy regulator
[    9.174207] lt8912 1-0048: supply vccsysclk not found, using dummy regulator
[    9.191784] lt8912 1-0048: supply vcclvdstx not found, using dummy regulator
[    9.206175] lt8912 1-0048: supply vcchdmitx not found, using dummy regulator
[    9.227389] lt8912 1-0048: supply vcclvdspll not found, using dummy regulator
[    9.241153] lt8912 1-0048: supply vcchdmipll not found, using dummy regulator
[    9.272838] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: reserved memory init failed, ret = -22
[    9.299259] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[    9.313316] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[    9.334329] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[    9.375274] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    9.409068] remoteproc remoteproc0: releasing 78000000.r5f
[    9.418689] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    9.486254] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_cluster_rproc_init failed, ret = -22
[    9.589986] k3_r5_rproc: probe of bus@f0000:bus@b00000:r5fss@78000000 failed with error -22
[   10.043966] mwifiex_sdio mmc2:0001:1: info: FW download over, size 570976 bytes
[   11.465914] mwifiex_sdio mmc2:0001:1: WLAN FW is active
[   11.510599] mwifiex_sdio mmc2:0001:1: Unknown api_id: 5
M
[   11.564064] mwifiex_sdio mmc2:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.92.21.p84)
[   11.582133] mwifiex_sdio mmc2:0001:1: driver_version = mwifiex 1.0 (16.92.21.p84)
M
M
M
M
  • Hi Franz
    Thanks, if disabling runtime suspend is not showing the data, that is a really good data point.
    Let me brainstorm further with the development team
    Thank you for these data points.Much appreciated
  • Hi Franz,
    We are preparing the instructions for you to dump the SYSFW debug trace in the pass and failure cases. Does your board have WKUP_UART or JTAG access? The debug trace can be dump from one of the interfaces.
  • Hi Bin,
    Thanks for preparing the instructions. Yes, we do have the possibilities to debug it with both.
  • Hi Franz,
    Great, using WKUP_UART is much easier to get the SYSFW debug trace.
    Please apply the following U-Boot patch to SDK9.2, then rebuild U-Boot.
    diff --git a/board/ti/am62x/board-cfg.yaml b/board/ti/am62x/board-cfg.yaml
    index a26ef55bd45b..d9bfbdbb480e 100644
    --- a/board/ti/am62x/board-cfg.yaml
    +++ b/board/ti/am62x/board-cfg.yaml
    @@ -32,5 +32,5 @@ board-cfg:
             subhdr:
                 magic: 0x020C
    -        trace_dst_enables : 0x00
    -        trace_src_enables : 0x00
    +        trace_dst_enables : 0x0d
    +        trace_src_enables : 0x3f
    Now if you connect to the WKUP_UART from a PC using the same UART setting as the console UART - 115200n8, you would see a list of hex string dump during u-boot/kernel runtime, this is the SYSFW debug trace.
    Please capture the trace twice, one for a normal/pass boot, the other is for the CAN failure case (without the 50ms delay).
  • Hi Bin,
    Here the traces.
    normal cycle:
    LogPass.txt
    failed cycle:
    LogFail.txt
  • Hi Franz,
    Thanks for capturing the logs. They are helpful.
    I see some transaction failures in the CAN failure case. We will look into it, and keep you posted.
  • Hi Bin,
    Do you have any updates on this?
  • Hi Franz,
    Based on the information provided in the debug trace, we are working on reproducing the issue with focus on the PD/PSC transitions on MCAN modules, but the progress has been slow in the last few days due to the holiday long weekends, and this morning Dallas area had severe thunder storm and our office is closed at least for today, which would cause extra delay. Thanks for your patience.
  • we are working on reproducing the issue with focus on the PD/PSC transitions on MCAN modules
    Just a heads-up, even if this was written since the very beginning. This is non-systematic and happens at temperatures below -20 degrees Celsius. Hopefully, it helps focus your debugging.
    In addition to that we can run any debug firmware if it helps moving forward, we have a solid reproducer on our side, just let us know what we should test.
  • Do you have any estimate on getting this issue solved? Anything we can do to help progress on this?
  • Hi Francesco
    Thank you for the offer to help. We may take up that offer, as so far our rudimentary attempts to make simpler bare metal test fail at -40C with a thermostream (on the EVM) have not resulted in any failures
    Few potential areas to follow up
    1) We may give you another firmware image to further help diagnose the issue , this will likely be mid next week
    2) Do you have any ability to show reproducibility on the EVM , Bin may try to replicate your test, but he has a few other escalations ahead in the queue, so anything that rules out this to be a board issue helps.
    3) On the % failures etc, how many iterations does it take for the failure to show up. We have run 100's of iterations and did not see failure (with a bare metal renditions) , but think you have had to run over night ? Can you clarify?
    Mukul
  • 2) Do you have any ability to show reproducibility on the EVM , Bin may try to replicate your test, but he has a few other escalations ahead in the queue, so anything that rules out this to be a board issue helps.
    We can try to put the TI AM62 SK in our climate chamber at -25 Celsius degrees. But given that this board is not designed for such a temperature range we might not get reliable results (e.g. it might crash for other reasons). At the same time, we have only a few boards, probably only one board with LPDDR4 that is the closest to our HW, so the coverage will be very limited and we have seen some board just not fails. We normally run 7 boards in parallel for a few hours to have some level of confidence in the results.
    If you are fine with these constraints I think we can plan for it (actual details I need to check internally, however, it's not myself nor my team that is going to work on this). We might need some help to be sure that we have the required debug logs enabled and that the CAN interfaces are enabled.
    : can you comment on this and the other points? you are more familiar with the actual test topics than myself.
  • Hi Mukul
    Yes, most of the tests ran overnight and lasted about 18 hours.
    About the % of failures. In our case, without any changes (adding delay, etc.), with seven boards running in parallel at -40°C ambient temperature, two to three of them will run into the problem 50% of the time or more. One or two boards may not run into the problem and the others may run into it from time to time.
    So 100's of iteration would be more than enough in our case if the board is affected.
    Was it tested on your side on multiple EVMs or only on a single one?
    It would also be nice to know what SOC temperature the sensors are reporting in your setup, if it's also in the same area (-25°C to -30°C) as in our case.
    As for testing it on an AM62 SK on our end, I'm checking if we have an SK-AM62-LP to do the test with an LPDDR4 board. In the worst case we would need to order one (or more).
  • Yes , the board is not designed to work at low temperature. We used the thermostream on the SOC , to localize the cold temperature testing - so may not work with the temp chamber, but would appreciate if you could give it a shot.
    If you damage the SK board, will figure out how to get you another one without issues :).
    The additional debug log generation requires a developers help, who is currently out of office, so my hope is some time next week we maybe able to facilitate that. If it is too onerous to do a test run with and without this debug logs then lets wait for the developer to enable these.
    Thank you for the patience and working along with us on this
  • Hi Mukul,
    Any updates on the debug firmware?
    In the meantime, I tried to reproduce the problem with the SK-AM62B-P1 in our climate chamber. I was not successful. I'm going to order an SK-AM62-LP to try to reproduce the problem on an EVM that is more similar to our hardware.
    Franz
  • Hi Mukul,
    Are there any updates on when we can get the new debug firmware?
    We can also send you some of our hardware if it helps to move this issue forward.
    Today I tried to reproduce the problem on the LP EVM but was not successful yet. The test is still running in our climate chamber.
    Is there anything else we can do to make progress in the meantime?
  • Hello Franz
    Sorry for the extreme delay in responding back, I was on travel and could not manage to put an update.
    Unfortunately I do not have a timeline on providing you a debug firmware, the key developer is out this week and next and I will see if if there is someone else who can generate this.
    It is intriguing that TI EVM is not able to reproduce this, we had the same read after trying this many times on 1-2 EVMs to the best of our ability (using a thermostream instead of temp chamber and using even bare metal tests for fuller control and minimal intervention from other factors)
    Given you were seeing this on every one of your boards but we are not seeing this on the EVM, we need your help to figure out what is different between the 2 boards. We have even tried just init/deinit CAN (PSC etc) so that there is no dependencies on what is hooked on the CAN interface, but could not reproduce it.
    Your inputs on what could be different on the 2 boards that make your board more susceptible would be helpful.
    I will keep you posted on the debug firmware release to help you diagnose this further (again regret the extreme delay in following up on that)
    Mukul
  • It is intriguing that TI EVM is not able to reproduce this
    I agree with this.
    On the other hand, we have clear proof that this is happening within the DM firmware, and there we are just running your exact binary.
    Maybe on the SK board we are just lucky, the software runs slower for some reason and this allows the powerdomain to properly wake up (we already know that a few milliseconds sleep solves the issue).
    Or maybe the reason for the different behavior could be around a different clocking of the SOC?
    can you look at which differences we have compared to the SK board in this area?
  • Hi Mukul,
    Thanks for coming back to me.
    After speaking with our senior hardware engineer, one difference we have not considered in this problem yet is that the power circuit on our board is based more on the BeaglePlay than the TI EVM. It would be interesting to see if the problem could be reproduced there.
    I measured the 25Mhz on both boards.
    Until I get a new debug firmware, I'll try to reproduce the problem on a BeaglePlay.
    Franz
  • Hello Franz
    Thanks for the patience. I likely will need another week to get the debug firmware, the expert is out of office this week.
    So no big differences in what CAN busses are attached to on your board vs TI EVM (or they are not in picture as there is no activity happening on CAN with the tests) ?
  • Hi Mukul,
    Thanks for the update of the debug firmware.
    In our tests there is no activity on the CAN buses. The interface is only initialized.
  • Hi Franz,
    Please integrate the debug firmware attached below and collect the debug trace from wakeup uart as before.
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/3225.ipc_5F00_echo_5F00_testb_5F00_mcu1_5F00_0_5F00_release_5F00_strip.xer5f
  • Franz
    The developer was able to work on this this weekend prior to going on time bank, I was not aware of this, Bin has shared the debug firmware - would appreciate if you give it a shot when you get a chance.
    Thanks for the provided debug firmware.
    I assume the provided file should be copied to `ti-linux-firmware/ti-dm/am62xx/` and replace the existing file there and then rebuild u-boot? Correct me if I'm wrong, otherwise I've already collected the SYSFW trace for a fail and pass case:
    dbgTIFail.txt
    dbgTIPass.txt
    If of any interest, here is the dmesg of fail and pass cycle:
    Climate Chamber:       KWP 120
    Start Temperature:     -36.8�C
    End Temperature:       -36.7�C
    Measured Temperature:  -36.8�C
    Shelf Temperature:     -36.5�C
    Shelf Name:            Shelf_20
    Module Serial Number:  15313467
    Module Location:       Shelf 1, Carrier Board 4
    Test duration:         132.67s
    Test Log
    16:22:08.01 10->11 Waited 30.00s
    16:21:37.82 9->10 Set Reset Low
    16:21:37.71 8->9 Power Off
    16:21:37.60 6->8 Not found, time out: "login:"
    16:20:07.51 5->6 Message found: "Starting kernel"
    16:20:02.50 4->5 Message found: "U-Boot"
    16:20:02.49 3->4 Waited 1.00s
    16:20:01.35 2->3 Set Reset High
    16:20:01.24 1->2 Power On
    16:20:01.13 0->1 Waited 5.00s
    Search Strings
    PASS : U-Boot
    PASS : Less than 64MB RAM detected
    PASS : Booting from mmc failed!
    PASS : Starting kernel
    PASS : mmcblk0: mmc0
    PASS : cut here
    PASS : rcu: INFO: rcu_preempt self-detected stall
    PASS : Internal error
    PASS : m_can device registered
    PASS : I/O error
    FAIL : login:
    PASS : critical temperature reached
    Disabled : RAM test, TestResult: PASS
    PASS : memtester failed
    Disabled : memtester version
    PASS : FAILURE
    PASS : running CQE recovery
    Disabled : Waiting for power-cycle
    0 : OAK ERROR
    0 : UART ERROR
    N/A : Device life time estimation type B
    N/A : Pre EOL information
    3 : USB hub found
    0 : xception stack
    PASS : page allocation failure
    PASS : hwclock
    Terminal
    U-Boot SPL 2023.04-28170-gc997b1b09f-dirty (Jul 17 2024 - 12:13:12 +0200)
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)')
    Changed A53 CPU frequency to 1250000000Hz (T grade) in DT
    SPL initial stack usage: 13424 bytes
    Trying to boot from MMC1
    Authentication passed
    Loading Environment from nowhere... OK
    init_env from device 9 not supported!
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b8
    NOTICE:  BL31: Built : 10:41:42, May 21 2024
    I/TC:
    I/TC: OP-TEE version: 4.1.0-51-g012cdca49 (gcc version 12.3.1 20230626 (Arm GNU Toolchain 12.3.Rel1 (Build arm-12.35))) #7 Wed Jul 17 09:56:34 UTC 2024 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: GIC redistributor base address not provided
    I/TC: Assuming default GIC group status and modifier
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)')
    I/TC: HUK Initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2023.04-28170-gc997b1b09f-dirty (Jul 17 2024 - 12:13:46 +0200)
    SPL initial stack usage: 1904 bytes
    U-Boot 2023.04-28170-gc997b1b09f-dirty (Jul 17 2024 - 12:13:46 +0200)
    SoC:   AM62X SR1.0 HS-FS
    DRAM:  1 GiB
    Core:  143 devices, 31 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from MMC... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Model: Toradex 0075 Verdin AM62 Dual 1GB WB IT V1.1B
    Serial#: 15313467
    Carrier: Toradex UNKNOWN CARRIER BOARD V1.1B, Serial# 11386995
    am65_cpsw_nuss ethernet@8000000: K3 CPSW: nuss_ver: 0x6BA01103 cpsw_ver: 0x6BA81103 ale_ver: 0x00290105 Ports:2 mdio_freq:1000000
    Setting variant to wifi
    Net:
    Warning: ethernet@8000000port@1 MAC addresses don't match:
    Address in ROM is		1c:63:49:1f:e0:05
    Address in environment is	00:14:2d:e9:aa:3b
    eth0: ethernet@8000000port@1 [PRIME]Could not get PHY for ethernet@8000000port@1: addr 7
    am65_cpsw_nuss_port ethernet@8000000port@2: phy_connect() failed
    Hit any key to stop autoboot:  1  0
    MMC: no card present
    switch to partitions #0, OK
    mmc0(part 0) is current device
    Scanning mmc 0:1...
    Found U-Boot script /boot.scr
    6003 bytes read in 10 ms (585.9 KiB/s)
    ## Executing script at 90280000
    Loading DeviceTree: k3-am625-verdin-wifi-dev.dtb
    70051 bytes read in 12 ms (5.6 MiB/s)
    82 bytes read in 9 ms (8.8 KiB/s)
    Working FDT set to 90200000
    Applying Overlay: verdin-am62_dsi-to-hdmi_overlay.dtbo
    3415 bytes read in 10 ms (333 KiB/s)
    Applying Overlay: verdin-am62_spidev_overlay.dtbo
    560 bytes read in 9 ms (60.5 KiB/s)
    8305029 bytes read in 68 ms (116.5 MiB/s)
    Bootargs: root=PARTUUID=386d8b8f-02 ro rootwait console=tty1 console=ttyS2,115200 consoleblank=0 earlycon=ns16550a,mmio32,0x02800000
       Uncompressing Kernel Image
    ## Flattened Device Tree blob at 90200000
       Booting using the fdt blob at 0x90200000
       Loading Device Tree to 0000000098eab000, end 0000000098edffff ... OK
    Working FDT set to 98eab000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.1.83-6.7.0+git.0a32d33d5fb7 (oe-user@oe-host) (aarch64-tdx-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Fri Jun 28 09:20:37 UTC 2024
    [    0.000000] Machine model: Toradex Verdin AM62 WB on Verdin Development Board
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000bfffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009dafffff]
    [    0.000000]   node   0: [mem 0x000000009db00000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
    [    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000bfffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff]
    [    0.000000] cma: Reserved 128 MiB at 0x00000000b6c00000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258048
    [    0.000000] Kernel command line: root=PARTUUID=386d8b8f-02 ro rootwait console=tty1 console=ttyS2,115200 consoleblank=0 earlycon=ns16550a,mmio32,0x02800000
    [    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 839568K/1048576K available (11648K kernel code, 1412K rwdata, 4076K rodata, 2304K init, 424K bss, 77936K reserved, 131072K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008608] Console: colour dummy device 80x25
    [    0.013619] printk: console [tty1] enabled
    [    0.017864] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.028559] pid_max: default: 32768 minimum: 301
    [    0.033338] LSM: Security Framework initializing
    [    0.038212] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
    [    0.045800] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
    [    0.055761] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.063243] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.069551] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.076957] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.083354] rcu: Hierarchical SRCU implementation.
    [    0.088271] rcu: 	Max phase no-delay instances is 1000.
    [    0.094355] Platform MSI: msi-controller@1820000 domain created
    [    0.100813] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.110271] EFI services will not be available.
    [    0.115243] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.166895] Detected VIPT I-cache on CPU1
    [    0.167029] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.167050] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [    0.167115] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.167239] smp: Brought up 1 node, 2 CPUs
    [    0.196657] SMP: Total of 2 processors activated.
    [    0.201476] CPU features: detected: 32-bit EL0 Support
    [    0.206754] CPU features: detected: CRC32 instructions
    [    0.212073] CPU: All CPU(s) started at EL2
    [    0.216267] alternatives: applying system-wide alternatives
    [    0.223627] devtmpfs: initialized
    [    0.236603] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.246658] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.259477] pinctrl core: initialized pinctrl subsystem
    [    0.265701] DMI not present or invalid.
    [    0.270360] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.277633] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
    [    0.284988] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.292999] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.301206] audit: initializing netlink subsys (disabled)
    [    0.307029] audit: type=2000 audit(0.176:1): state=initialized audit_enabled=0 res=1
    [    0.307607] thermal_sys: Registered thermal governor 'step_wise'
    [    0.314971] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.321318] cpuidle: using governor menu
    [    0.332233] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.339246] ASID allocator initialised with 65536 entries
    [    0.358057] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/dsi@e
    [    0.368312] platform connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.380174] KASLR disabled due to lack of seed
    [    0.391144] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.398140] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.404558] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.411506] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.417920] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.424867] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.431281] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.438227] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.446351] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.456473] iommu: Default domain type: Translated
    [    0.461499] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.468222] SCSI subsystem initialized
    [    0.472462] usbcore: registered new interface driver usbfs
    [    0.478123] usbcore: registered new interface driver hub
    [    0.483587] usbcore: registered new device driver usb
    [    0.489319] pps_core: LinuxPPS API ver. 1 registered
    [    0.494410] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.503771] PTP clock support registered
    [    0.507936] EDAC MC: Ver: 3.0.0
    [    0.512300] FPGA manager framework
    [    0.515900] Advanced Linux Sound Architecture Driver Initialized.
    [    0.523190] clocksource: Switched to clocksource arch_sys_counter
    [    0.529736] VFS: Disk quotas dquot_6.6.0
    [    0.533811] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.546933] NET: Registered PF_INET protocol family
    [    0.552220] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.560931] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
    [    0.569589] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.577535] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.585528] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
    [    0.593254] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.599957] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.606776] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.614202] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.620588] RPC: Registered named UNIX socket transport module.
    [    0.626697] RPC: Registered udp transport module.
    [    0.631515] RPC: Registered tcp transport module.
    [    0.636330] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.642931] NET: Registered PF_XDP protocol family
    [    0.647877] PCI: CLS 0 bytes, default 64
    [    0.652764] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.663087] Initialise system trusted keyrings
    [    0.667933] workingset: timestamp_bits=46 max_order=18 bucket_order=0
    [    0.678991] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.685742] NFS: Registering the id_resolver key type
    [    0.690989] Key type id_resolver registered
    [    0.695274] Key type id_legacy registered
    [    0.699441] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.706307] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.748558] Key type asymmetric registered
    [    0.752765] Asymmetric key parser 'x509' registered
    [    0.757817] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.765626] io scheduler mq-deadline registered
    [    0.770276] io scheduler kyber registered
    [    0.778458] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.785700] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.799448] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
    [    0.816875] brd: module loaded
    [    0.824943] loop: module loaded
    [    0.832935] tun: Universal TUN/TAP device driver, 1.6
    [    0.839032] VFIO - User Level meta-driver version: 0.3
    [    0.845767] usbcore: registered new interface driver usb-storage
    [    0.852051] usbcore: registered new device driver onboard-usb-hub
    [    0.859280] i2c_dev: i2c /dev entries driver
    [    0.866039] sdhci: Secure Digital Host Controller Interface driver
    [    0.872442] sdhci: Copyright(c) Pierre Ossman
    [    0.877447] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.883988] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.890363] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.897366] usbcore: registered new interface driver usbhid
    [    0.903080] usbhid: USB HID core driver
    [    0.908143] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.912756] optee: revision 4.1 (012cdca4)
    [    0.929418] optee: dynamic shared memory is enabled
    [    0.938902] optee: initialized driver
    [    0.944844] Initializing XFRM netlink socket
    [    0.949306] NET: Registered PF_PACKET protocol family
    [    0.954571] Key type dns_resolver registered
    [    0.959416] registered taskstats version 1
    [    0.963648] Loading compiled-in X.509 certificates
    [    0.982036] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)')
    [    2.628858] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=81, clk=20, ret=-19
    [    3.185085] omap_i2c 4900000.i2c: bus 3 rev0.12 at 100 kHz
    [    3.195370] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/dsi@e
    [    3.204500] i2c 0-000e: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/hdmi@48
    [    3.212623] i2c 0-000e: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    3.220590] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
    [    3.259634] input: tps65219-pwrbutton as /devices/platform/bus@f0000/20000000.i2c/i2c-0/0-0030/tps65219-pwrbutton.2.auto/input/input0
    [    3.273959] rtc-ds1307 0-0032: oscillator failed, set time!
    [    3.279873] rtc-ds1307 0-0032: registered as rtc0
    [    3.284842] rtc-ds1307 0-0032: hctosys: unable to read the hardware clock
    [    3.294042] at24 0-0050: supply vcc not found, using dummy regulator
    [    3.301003] at24 0-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
    [    3.307932] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    3.318869] i2c 0-000e: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/hdmi@48
    [    3.327128] platform hdmi-connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/hdmi@48
    [    3.336512] i2c 1-0048: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/dsi@e
    [    3.344498] i2c 1-0048: Fixed dependency cycle(s) with /hdmi-connector
    [    3.351905] pca953x 1-0021: supply vcc not found, using dummy regulator
    [    3.358835] pca953x 1-0021: using no AI
    [    3.383332] pca953x 1-0021: failed writing register
    [    3.388534] pca953x: probe of 1-0021 failed with error -121
    [    3.394846] at24 1-0057: supply vcc not found, using dummy regulator
    [    3.402070] at24 1-0057: 256 byte 24c02 EEPROM, writable, 16 bytes/write
    [    3.409007] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    3.419707] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz
    [    3.429835] omap_i2c 20030000.i2c: bus 4 rev0.12 at 100 kHz
    [    3.444992] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    3.462503] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    3.490066] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    3.581590] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    3.617372] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    3.628590] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    3.803348] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    3.817322] 4a00000.serial: ttyS3 at MMIO 0x4a00000 (irq = 291, base_baud = 3000000) is a 8250
    [    3.830887] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 292, base_baud = 3000000) is a 8250
    [    3.839819] printk: console [ttyS2] enabled
    [    3.848286] printk: bootconsole [ns16550a0] disabled
    [    3.862906] 2810000.serial: ttyS0 at MMIO 0x2810000 (irq = 293, base_baud = 3000000) is a 8250
    [    3.875795] omap8250 2850000.serial: PM domain pd:156 will not be powered off
    [    3.883269] 2850000.serial: ttyS4 at MMIO 0x2850000 (irq = 294, base_baud = 3000000) is a 8250
    [    3.892011] serial serial0: tty port ttyS4 registered
    [    3.913480] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    3.959197] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    3.968057] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    3.980987] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    3.988126] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    4.001782] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    4.154356] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    4.343742] platform connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    4.353337] platform 31000000.usb: Fixed dependency cycle(s) with /connector
    [    4.540173] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
    [    4.545769] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
    [    4.553572] xhci-hcd xhci-hcd.3.auto: USB3 root hub has no ports
    [    4.559587] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020010010
    [    4.569083] xhci-hcd xhci-hcd.3.auto: irq 299, io mem 0x31100000
    [    4.575982] hub 1-0:1.0: USB hub found
    [    4.579780] hub 1-0:1.0: 1 port detected
    [    4.839246] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    4.893099] gpio-488 (PCIE_1_RESET#): hogged as output/low
    [    5.035323] mmc0: CQHCI version 5.10
    [    5.055821] hub 1-1:1.0: USB hub found
    [    5.059788] hub 1-1:1.0: 4 ports detected
    [    5.081577] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    5.142628] mmc0: new HS200 MMC card at address 0001
    [    5.149313] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
    [    5.157673]  mmcblk0: p1 p2
    [    5.162292] mmcblk0boot0: mmc0:0001 Q2J55L 16.0 MiB
    [    5.170460] mmcblk0boot1: mmc0:0001 Q2J55L 16.0 MiB
    [    5.177989] mmcblk0rpmb: mmc0:0001 Q2J55L 4.00 MiB, chardev (241:0)
    [    5.260778] reg-fixed-voltage regulator-force-sleep-moci: nonexclusive access to GPIO for regulator-force-sleep-moci
    [    5.407228] usb 1-1.4: new high-speed USB device number 3 using xhci-hcd
    [    5.572424] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    5.619312] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    5.635637] mdio_bus 8000f00.mdio: MDIO device at address 7 is missing.
    [    5.642307] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    5.656457] usb 1-1.4: USB disconnect, device number 3
    [    5.700788] sdhci-am654 fa00000.mmc: Got CD GPIO
    [    5.704511] sdhci-am654 fa20000.mmc: allocated mmc-pwrseq
    [    5.720687] mmc1: CQHCI version 5.10
    [    5.727596] mmc2: CQHCI version 5.10
    [    5.759615] hub 1-1:1.0: USB hub found
    [    5.763500] hub 1-1:1.0: 4 ports detected
    [    5.772747] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
    [    5.780596] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    5.824856] mmc2: new ultra high speed DDR50 SDIO card at address 0001
    [    5.864368] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    5.878825] input: gpio-keys as /devices/platform/gpio-keys/input/input1
    [    6.007225] usb 1-1.4: new high-speed USB device number 4 using xhci-hcd
    [    6.134961] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=81, clk=20, ret=-19
    [    6.434967] ALSA device list:
    [    6.437957]   No soundcards found.
    [    6.450336] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [    6.457784] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [    7.387036] EXT4-fs (mmcblk0p2): recovery complete
    [    7.393692] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    7.402477] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    7.413631] devtmpfs: mounted
    [    7.418705] Freeing unused kernel memory: 2304K
    [    7.423408] Run /sbin/init as init process
    [    7.582945] systemd[1]: System time before build time, advancing clock.
    [    7.632738] NET: Registered PF_INET6 protocol family
    [    7.639958] Segment Routing with IPv6
    [    7.643820] In-situ OAM (IOAM) with IPv6
    [    7.675413] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    7.707505] systemd[1]: Detected architecture arm64.
    Welcome to TDX Wayland with XWayland 6.7.0+build.13 (kirkstone)!
    [    7.776611] systemd[1]: Hostname set to <verdin-am62-15313467>.
    [    8.286676] systemd[1]: Queued start job for default target Graphical Interface.
    [    8.344797] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    8.369825] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    8.393597] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    8.417019] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    8.439812] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    8.463740] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    8.487970] systemd[1]: Reached target Host and Network Name Lookups.
    [  OK  ] Reached target Host and Network Name Lookups.
    [    8.511452] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    8.527613] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    8.547465] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    8.563600] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    8.638248] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    8.659936] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    8.685148] systemd[1]: Listening on Syslog Socket.
    [  OK  ] Listening on Syslog Socket.
    [    8.708439] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    8.735655] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    8.761917] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    8.786461] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    8.811145] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    8.838632] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    8.861697] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    8.885909] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    8.943993] systemd[1]: Mounting Huge Pages File System...
    [    8.973751] systemd[1]: Mounting POSIX Message Queue File System...
    [    9.001304] systemd[1]: Mounting Kernel Debug File System...
    [    9.020156] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    9.055977] systemd[1]: Mounting Temporary Directory /tmp...
    [    9.078621] systemd[1]: Starting Create List of Static Device Nodes...
    [    9.128456] systemd[1]: Starting Load Kernel Module configfs...
    [    9.152052] systemd[1]: Starting Load Kernel Module drm...
    [    9.175127] systemd[1]: Starting Load Kernel Module fuse...
    [    9.198031] fuse: init (API version 7.37)
    [    9.212597] systemd[1]: Starting RPC Bind...
    [    9.239643] systemd[1]: Starting File System Check on Root Device...
    [    9.288883] systemd[1]: Starting Journal Service...
    [    9.314147] systemd[1]: Starting Load Kernel Modules...
    [    9.336553] systemd[1]: Starting Generate network units from Kernel command line...
             Starting Generate network …ts from Kernel command line...
    [    9.388032] systemd[1]: Starting Coldplug All udev Devices...
    [    9.419998] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    9.444653] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    9.468366] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [    9.497004] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [  OK  ] Finished File System Check on Root Device.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Remount Root and Kernel File Systems...
             Starting Apply Kernel Variables...
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [    9.862753] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    [  OK  ] Finished Remount Root and Kernel File Systems.
    [  OK  ] Finished Apply Kernel Variables.
             Starting Flush Journal to Persistent Storage...
    [    9.973068] systemd-journald[170]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
    [   10.088623] audit: type=1334 audit(1651167747.504:2): prog-id=5 op=LOAD
    [   10.100222] audit: type=1334 audit(1651167747.512:3): prog-id=6 op=LOAD
             Starting Rule-based Manage…for Device Events and Files...
    [  OK  ] Finished Coldplug All udev Devices.
             Starting Wait for udev To …plete Device Initialization...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
             Mounting /var/volatile...
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [   10.937774] lm75 0-0048: supply vs not found, using dummy regulator
    [   11.022717] nau8822 1-001a: Failed to issue reset: -121
    [   11.043443] hwmon hwmon1: temp1_input not attached to any thermal zone
    [   11.103405] ina2xx 1-0040: error configuring the device: -121
    [   11.128562] nau8822: probe of 1-001a failed with error -121
    [   11.166472] lm75 0-0048: hwmon1: sensor 'tmp1075'
    [  OK  ] Started Network Time Synchronizatio[   11.183768] systemd-journald[170]: Oldest entry in /run/log/journal/fe0a3f53032541f8af21c573ff5c27ad/system.journal is older than the configured file retention duration (1month), suggesting rotation.
    n.
    [   11.188382] lm75 1-004f: supply vs not found, using dummy regulator
    [   11.209695] systemd-journald[170]: /run/log/journal/fe0a3f53032541f8af21c573ff5c27ad/system.journal: Journal header limits reached or header out-of-date, rotating.
    [  OK  ] Reached target System Time Set.
    [   11.371521] CAN device driver interface
    [   11.375967] hwmon hwmon2: temp1_input not attached to any thermal zone
    [   11.431248] random: crng init done
    [   11.433705] lm75 1-004f: hwmon2: sensor 'tmp75c'
    [  OK  ] Finished Load/Save Random Seed.
    [  OK  ] Found device /dev/ttyS2.
    [   11.485619] m_can_platform 4e08000.can: m_can device registered (irq=0, version=32)
    [   11.651604] Bluetooth: Core ver 2.22
    [   11.658512] NET: Registered PF_BLUETOOTH protocol family
    [   11.677484] Bluetooth: HCI device and connection manager initialized
    [   11.687878] Bluetooth: HCI socket layer initialized
    [   11.693205] Bluetooth: L2CAP socket layer initialized
    [   11.703935] Bluetooth: SCO socket layer initialized
    [   11.736110] k3-m4-rproc 5000000.m4fss: device does not reserved memory regions, ret = -22
    [   11.744705] k3-m4-rproc 5000000.m4fss: reserved memory init failed, ret = -22
    [   11.775910] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   11.805807] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   11.814040] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [   11.829097] remoteproc remoteproc0: releasing 5000000.m4fss
    [   11.835016] k3-m4-rproc: probe of 5000000.m4fss failed with error -22
    [   12.124577] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [   12.192128] pvrsrvkm: loading out-of-tree module taints kernel.
    [   12.194420] platform 78000000.r5f: configured R5F for IPC-only mode
    [   12.210233] platform 78000000.r5f: device does not have reserved memory regions, ret = -22
    [   12.220522] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: reserved memory init failed, ret = -22
    [   12.231543] remoteproc remoteproc0: releasing 78000000.r5f
    [   12.238253] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_cluster_rproc_init failed, ret = -22
    [   12.250089] k3_r5_rproc: probe of bus@f0000:bus@b00000:r5fss@78000000 failed with error -22
    [   12.305096] PVR_K:  194: Device: fd00000.gpu
    [   12.309735] PVR_K:  194: Read BVNC 33.15.11.3 from HW device registers
    [   12.368487] PVR_K:  194: RGX Device registered with BVNC 33.15.11.3
    [   12.377360] [drm] Initialized pvr 23.3.6512818 20170530 for fd00000.gpu on minor 1
    [   12.385166] mwifiex_sdio mmc2:0001:1: info: FW download over, size 578116 bytes
    [   12.630268] lt8912 1-0048: supply vccmipirx not found, using dummy regulator
    [   12.640800] lt8912 1-0048: supply vccsysclk not found, using dummy regulator
    [   12.654032] lt8912 1-0048: supply vcclvdstx not found, using dummy regulator
    [   12.666639] lt8912 1-0048: supply vcchdmitx not found, using dummy regulator
    [   12.678331] lt8912 1-0048: supply vcclvdspll not found, using dummy regulator
    [   12.692364] lt8912 1-0048: supply vcchdmipll not found, using dummy regulator
    [   12.815870] m_can_platform 20701000.can: m_can device registered (irq=490, version=32)
    [   12.972863] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
    [   13.152335] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [   13.162591] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [   13.367671] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [   13.907315] mwifiex_sdio mmc2:0001:1: WLAN FW is active
    [   13.940209] mwifiex_sdio mmc2:0001:1: event: unknown event id: 0x81
    [   13.946770] mwifiex_sdio mmc2:0001:1: Unknown api_id: 5
    [   13.952189] mwifiex_sdio mmc2:0001:1: Unknown GET_HW_SPEC TLV type: 0x23e
    [   13.997340] mwifiex_sdio mmc2:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.92.21.p119)
    [   14.010085] mwifiex_sdio mmc2:0001:1: driver_version = mwifiex 1.0 (16.92.21.p119)
    [*     ] A start job is running for Wait for…ice Initialization (2s / 2min 58s)
    M
    [  OK  ] Created slice Slice /system/systemd-fsck.
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
             Starting Load/Save RF Kill Switch Status...
    Start Temperature:     -36.7�C
    End Temperature:       -36.2�C
    Measured Temperature:  -36.7�C
    Test duration:         70.22s
    Test Log
    16:23:18.34 10->11 Waited 30.00s
    16:22:48.13 9->10 Set Reset Low
    16:22:48.02 8->9 Power Off
    16:22:47.91 7->8 Waited 5.00s
    16:22:42.79 6->7 Message found: "login:"
    16:22:20.49 5->6 Message found: "Starting kernel"
    16:22:15.39 4->5 Message found: "U-Boot"
    16:22:15.31 3->4 Waited 1.00s
    16:22:14.13 2->3 Set Reset High
    16:22:14.02 1->2 Power On
    16:22:13.91 0->1 Waited 5.00s
    Search Strings
    PASS : U-Boot
    PASS : cut here
    PASS : rcu: INFO: rcu_preempt detected
    PASS : I/O error
    PASS : login:
    PASS : FAILURE
    0 : OAK ERROR
    0 : UART ERROR
    3 : USB hub found
    0 : xception stack
    PASS : hwclock
    Terminal
    I/TC:
    DRAM:  1 GiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Serial#: 15313467
    Net:
    Scanning mmc 0:1...
    70051 bytes read in 11 ms (6.1 MiB/s)
    560 bytes read in 10 ms (54.7 KiB/s)
    Starting kernel ...
    [    0.013615] printk: console [tty1] enabled
    [    0.017862] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.028558] pid_max: default: 32768 minimum: 301
    [    0.038215] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
    [    0.045803] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
    [    0.055767] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.063246] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.069555] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.076963] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.083359] rcu: Hierarchical SRCU implementation.
    [    0.088277] rcu: 	Max phase no-delay instances is 1000.
    [    0.094362] Platform MSI: msi-controller@1820000 domain created
    [    0.100801] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.110251] EFI services will not be available.
    [    0.115212] smp: Bringing up secondary CPUs ...
    [    0.166857] Detected VIPT I-cache on CPU1
    [    0.166994] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.167014] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [    0.167079] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.167205] smp: Brought up 1 node, 2 CPUs
    [    0.196628] SMP: Total of 2 processors activated.
    [    0.201447] CPU features: detected: 32-bit EL0 Support
    [    0.206725] CPU features: detected: CRC32 instructions
    [    0.212043] CPU: All CPU(s) started at EL2
    [    0.216236] alternatives: applying system-wide alternatives
    [    0.223612] devtmpfs: initialized
    [    0.236569] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.246626] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.259435] pinctrl core: initialized pinctrl subsystem
    [    0.265659] DMI not present or invalid.
    [    0.270325] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.277605] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
    [    0.284957] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.292969] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.301171] audit: initializing netlink subsys (disabled)
    [    0.306991] audit: type=2000 audit(0.176:1): state=initialized audit_enabled=0 res=1
    [    0.307576] thermal_sys: Registered thermal governor 'step_wise'
    [    0.314933] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.321282] cpuidle: using governor menu
    [    0.332199] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.339212] ASID allocator initialised with 65536 entries
    [    0.358075] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/dsi@e
    [    0.368345] platform connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.380196] KASLR disabled due to lack of seed
    [    0.391197] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.398193] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.404611] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.411559] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.417975] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.424922] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.431336] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.438282] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.446412] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.456521] iommu: Default domain type: Translated
    [    0.461547] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.468274] SCSI subsystem initialized
    [    0.472521] usbcore: registered new interface driver usbfs
    [    0.478183] usbcore: registered new interface driver hub
    [    0.483649] usbcore: registered new device driver usb
    [    0.489388] pps_core: LinuxPPS API ver. 1 registered
    [    0.494477] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.503839] PTP clock support registered
    [    0.508007] EDAC MC: Ver: 3.0.0
    [    0.512378] FPGA manager framework
    [    0.515980] Advanced Linux Sound Architecture Driver Initialized.
    [    0.523287] clocksource: Switched to clocksource arch_sys_counter
    [    0.529834] VFS: Disk quotas dquot_6.6.0
    [    0.533906] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.547025] NET: Registered PF_INET protocol family
    [    0.552315] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.561024] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
    [    0.569677] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.577626] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.585618] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
    [    0.593346] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.600048] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.606862] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.614292] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.620677] RPC: Registered named UNIX socket transport module.
    [    0.626785] RPC: Registered udp transport module.
    [    0.631602] RPC: Registered tcp transport module.
    [    0.636417] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.643018] NET: Registered PF_XDP protocol family
    [    0.647962] PCI: CLS 0 bytes, default 64
    [    0.652856] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.663182] Initialise system trusted keyrings
    [    0.668046] workingset: timestamp_bits=46 max_order=18 bucket_order=0
    [    0.679103] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.685855] NFS: Registering the id_resolver key type
    [    0.691108] Key type id_resolver registered
    [    0.695393] Key type id_legacy registered
    [    0.699558] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.706423] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.748767] Key type asymmetric registered
    [    0.752973] Asymmetric key parser 'x509' registered
    [    0.758028] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.765827] io scheduler mq-deadline registered
    [    0.770473] io scheduler kyber registered
    [    0.778663] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.785909] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.799657] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
    [    0.817055] brd: module loaded
    [    0.825108] loop: module loaded
    [    0.833149] tun: Universal TUN/TAP device driver, 1.6
    [    0.839258] VFIO - User Level meta-driver version: 0.3
    [    0.845996] usbcore: registered new interface driver usb-storage
    [    0.852281] usbcore: registered new device driver onboard-usb-hub
    [    0.859510] i2c_dev: i2c /dev entries driver
    [    0.866285] sdhci: Secure Digital Host Controller Interface driver
    [    0.872680] sdhci: Copyright(c) Pierre Ossman
    [    0.877692] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.884239] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.890616] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.897633] usbcore: registered new interface driver usbhid
    [    0.903355] usbhid: USB HID core driver
    [    0.908404] optee: probing for conduit method.
    [    0.913021] optee: revision 4.1 (012cdca4)
    [    0.929681] optee: dynamic shared memory is enabled
    [    0.939168] optee: initialized driver
    [    0.945074] Initializing XFRM netlink socket
    [    0.949542] NET: Registered PF_PACKET protocol family
    [    0.954804] Key type dns_resolver registered
    [    0.959655] registered taskstats version 1
    [    0.963889] Loading compiled-in X.509 certificates
    [    0.982625] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)')
    [    2.629255] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=81, clk=20, ret=-19
    [    3.185669] omap_i2c 4900000.i2c: bus 3 rev0.12 at 100 kHz
    [    3.195929] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/dsi@e
    [    3.205052] i2c 0-000e: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/hdmi@48
    [    3.213174] i2c 0-000e: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    3.221169] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
    [    3.263889] input: tps65219-pwrbutton as /devices/platform/bus@f0000/20000000.i2c/i2c-0/0-0030/tps65219-pwrbutton.2.auto/input/input0
    [    3.278216] rtc-ds1307 0-0032: oscillator failed, set time!
    [    3.284130] rtc-ds1307 0-0032: registered as rtc0
    [    3.289102] rtc-ds1307 0-0032: hctosys: unable to read the hardware clock
    [    3.298237] at24 0-0050: supply vcc not found, using dummy regulator
    [    3.305224] at24 0-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
    [    3.312159] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    3.323016] i2c 0-000e: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/hdmi@48
    [    3.331296] platform hdmi-connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/hdmi@48
    [    3.340679] i2c 1-0048: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/dsi@e
    [    3.348669] i2c 1-0048: Fixed dependency cycle(s) with /hdmi-connector
    [    3.356090] pca953x 1-0021: supply vcc not found, using dummy regulator
    [    3.363002] pca953x 1-0021: using no AI
    [    3.387425] pca953x 1-0021: failed writing register
    [    3.392631] pca953x: probe of 1-0021 failed with error -121
    [    3.398930] at24 1-0057: supply vcc not found, using dummy regulator
    [    3.406160] at24 1-0057: 256 byte 24c02 EEPROM, writable, 16 bytes/write
    [    3.413098] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    3.423749] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz
    [    3.433860] omap_i2c 20030000.i2c: bus 4 rev0.12 at 100 kHz
    [    3.448996] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    3.466517] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    3.494060] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    3.585627] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    3.621405] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    3.632671] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    3.807372] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    3.821369] 4a00000.serial: ttyS3 at MMIO 0x4a00000 (irq = 291, base_baud = 3000000) is a 8250
    [    3.834929] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 292, base_baud = 3000000) is a 8250
    [    3.843859] printk: console [ttyS2] enabled
    [    3.852325] printk: bootconsole [ns16550a0] disabled
    [    3.866966] 2810000.serial: ttyS0 at MMIO 0x2810000 (irq = 293, base_baud = 3000000) is a 8250
    [    3.879852] omap8250 2850000.serial: PM domain pd:156 will not be powered off
    [    3.887312] 2850000.serial: ttyS4 at MMIO 0x2850000 (irq = 294, base_baud = 3000000) is a 8250
    [    3.896050] serial serial0: tty port ttyS4 registered
    [    3.917495] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    3.963298] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    3.972162] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    3.985102] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    3.992243] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    4.005900] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    4.158414] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    4.347747] platform connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    4.357360] platform 31000000.usb: Fixed dependency cycle(s) with /connector
    [    4.528212] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
    [    4.533787] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
    [    4.541599] xhci-hcd xhci-hcd.3.auto: USB3 root hub has no ports
    [    4.547612] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020010010
    [    4.557073] xhci-hcd xhci-hcd.3.auto: irq 299, io mem 0x31100000
    [    4.563979] hub 1-0:1.0: USB hub found
    [    4.567861] hub 1-0:1.0: 1 port detected
    [    4.827345] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    4.896340] gpio-488 (PCIE_1_RESET#): hogged as output/low
    [    5.036763] mmc0: CQHCI version 5.10
    [    5.044156] hub 1-1:1.0: USB hub found
    [    5.048242] hub 1-1:1.0: 4 ports detected
    [    5.084442] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    5.143717] mmc0: new HS200 MMC card at address 0001
    [    5.150388] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
    [    5.158907]  mmcblk0: p1 p2
    [    5.163486] mmcblk0boot0: mmc0:0001 Q2J55L 16.0 MiB
    [    5.171450] mmcblk0boot1: mmc0:0001 Q2J55L 16.0 MiB
    [    5.178881] mmcblk0rpmb: mmc0:0001 Q2J55L 4.00 MiB, chardev (241:0)
    [    5.252960] reg-fixed-voltage regulator-force-sleep-moci: nonexclusive access to GPIO for regulator-force-sleep-moci
    [    5.395408] usb 1-1.4: new high-speed USB device number 3 using xhci-hcd
    [    5.601311] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    5.647410] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    5.664294] mdio_bus 8000f00.mdio: MDIO device at address 7 is missing.
    [    5.670974] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    5.683746] usb 1-1.4: USB disconnect, device number 3
    [    5.724218] sdhci-am654 fa00000.mmc: Got CD GPIO
    [    5.729678] sdhci-am654 fa20000.mmc: allocated mmc-pwrseq
    [    5.748845] mmc1: CQHCI version 5.10
    [    5.756381] mmc2: CQHCI version 5.10
    [    5.779595] hub 1-1:1.0: USB hub found
    [    5.783476] hub 1-1:1.0: 4 ports detected
    [    5.799362] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
    [    5.807643] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    5.860272] mmc2: new ultra high speed DDR50 SDIO card at address 0001
    [    5.886632] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    5.900973] input: gpio-keys as /devices/platform/gpio-keys/input/input1
    [    6.027333] usb 1-1.4: new high-speed USB device number 4 using xhci-hcd
    [    6.163510] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=81, clk=20, ret=-19
    [    6.465197] ALSA device list:
    [    6.468220]   No soundcards found.
    [    6.481112] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [    6.488583] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [    7.424839] EXT4-fs (mmcblk0p2): recovery complete
    [    7.431479] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    7.440142] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    7.450600] devtmpfs: mounted
    [    7.455400] Freeing unused kernel memory: 2304K
    [    7.460082] Run /sbin/init as init process
    [    7.607470] systemd[1]: System time before build time, advancing clock.
    [    7.655948] NET: Registered PF_INET6 protocol family
    [    7.662491] Segment Routing with IPv6
    [    7.666301] In-situ OAM (IOAM) with IPv6
    [    7.695852] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    7.727930] systemd[1]: Detected architecture arm64.
    [    7.788265] systemd[1]: Hostname set to <verdin-am62-15313467>.
    [    8.281300] systemd[1]: Queued start job for default target Graphical Interface.
    [    8.341495] systemd[1]: Created slice Slice /system/getty.
    [    8.365918] systemd[1]: Created slice Slice /system/modprobe.
    [    8.389695] systemd[1]: Created slice Slice /system/serial-getty.
    [    8.413104] systemd[1]: Created slice User and Session Slice.
    [    8.435891] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    8.459851] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    8.483955] systemd[1]: Reached target Host and Network Name Lookups.
    [    8.507559] systemd[1]: Reached target Path Units.
    [    8.527899] systemd[1]: Reached target Remote File Systems.
    [    8.551702] systemd[1]: Reached target Slice Units.
    [    8.571962] systemd[1]: Reached target Swaps.
    [    8.651979] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    8.675978] systemd[1]: Reached target RPC Port Mapper.
    [    8.697248] systemd[1]: Listening on Syslog Socket.
    [    8.720512] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    8.747267] systemd[1]: Listening on Journal Audit Socket.
    [    8.772843] systemd[1]: Listening on Journal Socket (/dev/log).
    [    8.798402] systemd[1]: Listening on Journal Socket.
    [    8.823487] systemd[1]: Listening on Network Service Netlink Socket.
    [    8.850797] systemd[1]: Listening on udev Control Socket.
    [    8.873716] systemd[1]: Listening on udev Kernel Socket.
    [    8.898004] systemd[1]: Listening on User Database Manager Socket.
    [    8.951965] systemd[1]: Mounting Huge Pages File System...
    [    8.981041] systemd[1]: Mounting POSIX Message Queue File System...
    [    9.028041] systemd[1]: Mounting Kernel Debug File System...
    [    9.044308] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    9.064717] systemd[1]: Mounting Temporary Directory /tmp...
    [    9.088599] systemd[1]: Starting Create List of Static Device Nodes...
    [    9.136448] systemd[1]: Starting Load Kernel Module configfs...
    [    9.158701] systemd[1]: Starting Load Kernel Module drm...
    [    9.200407] systemd[1]: Starting Load Kernel Module fuse...
    [    9.214671] fuse: init (API version 7.37)
    [    9.232320] systemd[1]: Starting RPC Bind...
    [    9.255732] systemd[1]: Starting File System Check on Root Device...
    [    9.310047] systemd[1]: Starting Journal Service...
    [    9.329183] systemd[1]: Starting Load Kernel Modules...
    [    9.360600] systemd[1]: Starting Generate network units from Kernel command line...
    [    9.386276] systemd[1]: Starting Coldplug All udev Devices...
    [    9.436889] systemd[1]: Started RPC Bind.
    [    9.460505] systemd[1]: Mounted Huge Pages File System.
    [    9.492452] systemd[1]: Mounted POSIX Message Queue File System.
    [    9.520440] systemd[1]: Started Journal Service.
    [    9.869815] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    [   10.008566] systemd-journald[173]: Received client request to flush runtime journal.
    [   10.161329] audit: type=1334 audit(1651167747.552:2): prog-id=5 op=LOAD
    [   10.169491] audit: type=1334 audit(1651167747.560:3): prog-id=6 op=LOAD
    [  OK  ] Started Network Time Synchronizatio[   10.935011] systemd-journald[173]: Oldest entry in /run/log/journal/fe0a3f53032541f8af21c573ff5c27ad/system.journal is older than the configured file retention duration (1month), suggesting rotation.
    n.
    [   10.959589] systemd-journald[173]: /run/log/journal/fe0a3f53032541f8af21c573ff5c27ad/system.journal: Journal header limits reached or header out-of-date, rotating.
    [   11.211350] random: crng init done
    [   11.271801] lm75 0-0048: supply vs not found, using dummy regulator
    [   11.286095] hwmon hwmon1: temp1_input not attached to any thermal zone
    [   11.324586] lm75 0-0048: hwmon1: sensor 'tmp1075'
    [   11.335817] nau8822 1-001a: Failed to issue reset: -121
    [   11.338295] lm75 1-004f: supply vs not found, using dummy regulator
    [   11.350422] ina2xx 1-0040: error configuring the device: -121
    [   11.363074] hwmon hwmon2: temp1_input not attached to any thermal zone
    [   11.376817] nau8822: probe of 1-001a failed with error -121
    [   11.383001] lm75 1-004f: hwmon2: sensor 'tmp75c'
    [   11.401743] CAN device driver interface
    [   11.548456] Bluetooth: Core ver 2.22
    [   11.559585] NET: Registered PF_BLUETOOTH protocol family
    [   11.571459] Bluetooth: HCI device and connection manager initialized
    [   11.583522] Bluetooth: HCI socket layer initialized
    [   11.592304] Bluetooth: L2CAP socket layer initialized
    [   11.599674] Bluetooth: SCO socket layer initialized
    [   11.608934] m_can_platform 4e08000.can: m_can device registered (irq=0, version=32)
    [   11.704686] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   11.727457] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   11.737610] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [   11.783255] k3-m4-rproc 5000000.m4fss: device does not reserved memory regions, ret = -22
    [   11.807443] k3-m4-rproc 5000000.m4fss: reserved memory init failed, ret = -22
    [   11.854519] remoteproc remoteproc0: releasing 5000000.m4fss
    [   11.862328] k3-m4-rproc: probe of 5000000.m4fss failed with error -22
    [   12.117924] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [   12.177158] pvrsrvkm: loading out-of-tree module taints kernel.
    [   12.221141] platform 78000000.r5f: configured R5F for IPC-only mode
    [   12.228737] platform 78000000.r5f: device does not have reserved memory regions, ret = -22
    [   12.237630] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: reserved memory init failed, ret = -22
    [   12.248090] remoteproc remoteproc0: releasing 78000000.r5f
    [   12.254182] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_cluster_rproc_init failed, ret = -22
    [   12.264112] k3_r5_rproc: probe of bus@f0000:bus@b00000:r5fss@78000000 failed with error -22
    [   12.291942] PVR_K:  206: Device: fd00000.gpu
    [   12.303654] PVR_K:  206: Read BVNC 33.15.11.3 from HW device registers
    [   12.352546] mwifiex_sdio mmc2:0001:1: info: FW download over, size 578116 bytes
    [   12.400991] PVR_K:  206: RGX Device registered with BVNC 33.15.11.3
    [   12.410407] [drm] Initialized pvr 23.3.6512818 20170530 for fd00000.gpu on minor 1
    [   12.574164] lt8912 1-0048: supply vccmipirx not found, using dummy regulator
    [   12.584350] lt8912 1-0048: supply vccsysclk not found, using dummy regulator
    [   12.599127] lt8912 1-0048: supply vcclvdstx not found, using dummy regulator
    [   12.611873] lt8912 1-0048: supply vcchdmitx not found, using dummy regulator
    [   12.626524] lt8912 1-0048: supply vcclvdspll not found, using dummy regulator
    [   12.638463] lt8912 1-0048: supply vcchdmipll not found, using dummy regulator
    [   12.846444] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
    [   12.936802] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [   12.982918] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [   13.121886] m_can_platform 20701000.can: m_can device registered (irq=492, version=32)
    [   13.183700] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [   13.875481] mwifiex_sdio mmc2:0001:1: WLAN FW is active
    [  OK  ] Created slice Slice /system/systemd[   13.914600] mwifiex_sdio mmc2:0001:1: event: unknown event id: 0x81
    -fsck.
    [   13.922984] mwifiex_sdio mmc2:0001:1: Unknown api_id: 5
    [   13.929128] mwifiex_sdio mmc2:0001:1: Unknown GET_HW_SPEC TLV type: 0x23e
    [   13.976105] mwifiex_sdio mmc2:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.92.21.p119)
    [   13.984476] mwifiex_sdio mmc2:0001:1: driver_version = mwifiex 1.0 (16.92.21.p119)
    [  OK  ] Found device /dev/mmcblk0p1.
             Starting File System Check on /dev/mmcblk0p1[[   14.714859] remoteproc remoteproc0: 30074000.pru is available
    0m...
    [   14.765737] remoteproc remoteproc1: 30078000.pru is available
    [  OK  ] Finished File System Check on /dev/mmcblk0p1.
             Mounting /media/BOOT-mmcblk0p1...
    [  OK  ] Mounted /media/BOOT-mmcblk0p1.
             Mounting /boot...
    [  OK  ] Mounted /boot.
    [  OK  ] Started Load/Save RF Kill Switch Status.
    [  OK  ] Finished Wait for udev To Complete Device Initialization.
    [   15.488757] audit: type=1334 audit(1721212812.559:4): prog-id=7 op=LOAD
    [   15.496597] audit: type=1334 audit(1721212812.567:5): prog-id=8 op=LOAD
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on GPS (Global P…ioning System) Daemon Sockets.
             Starting Weston socket...
    [  OK  ] Listening on Weston socket.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
             Starting Bluetooth service...
    [  OK  ] Started Kernel Logging Service.
    [  OK  ] Started System Logging Service.
             Starting D-Bus System Message Bus...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
             Starting Telephony service...
    [   16.005266] audit: type=1334 audit(1721212813.075:6): prog-id=9 op=LOAD
    [   16.022481] audit: type=1334 audit(1721212813.091:7): prog-id=10 op=LOAD
             Starting User Login Management...
    [  OK  ] Started Timestamping service.
             Starting Load default USB gadget schema g1.schema...
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [   16.185878] using random self ethernet address
    [   16.193865] using random host ethernet address
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Reached target Preparation for Network.
             Starting Connection service...
             Starting Network Configuration...
    [  OK  ] Started Telephony service.
    [  OK  ] Started Bluetooth service.
    [   16.409118] audit: type=1334 audit(1721212875.236:8): prog-id=11 op=LOAD
    [   16.421494] audit: type=1334 audit(1721212875.248:9): prog-id=12 op=LOAD
    [   16.454601] Bluetooth: MGMT ver 1.22
             Starting BlueALSA service...
    [   16.515007] NET: Registered PF_ALG protocol family
    [   16.515101] audit: type=1334 audit(1721212875.340:10): prog-id=13 op=LOAD
             Starting Hostname Service...
    [   16.546837] audit: type=1334 audit(1721212875.356:11): prog-id=14 op=LOAD
    [   16.662017] usb0: HOST MAC 42:48:5f:01:4b:e8
    [   16.676809] Bluetooth: RFCOMM socket layer initialized
    [   16.687395] usb0: MAC 8e:c4:54:3e:6a:a3
    [   16.692954] Bluetooth: RFCOMM ver 1.11
    [  OK  ] Finished Load default USB gadget schema g1.schema.
    [  OK  ] Reached target Hardware activated USB gadget.
    [  OK  ] Started Connection service.
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started User Login Management.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
             Starting WPA supplicant...
    [  OK  ] Started WPA supplicant.
    [  OK  ] Started Hostname Service.
    [  OK  ] Started BlueALSA service.
    [  OK  ] Reached target Bluetooth Support.
    [   18.403741] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=359)
    [   18.414830] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Started Network Configuration.
    [  OK  ] Reached target Network.
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Permit User Sessions...
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
    [  OK  ] Reached target Multi-User System.
             Starting Weston, a Wayland…ositor, as a system service...
    [   18.784059] audit: type=1334 audit(1721212877.612:12): prog-id=15 op=LOAD
    [   18.791987] audit: type=1334 audit(1721212877.616:13): prog-id=16 op=LOAD
             Starting User Database Manager...
    [  OK  ] Started User Database Manager.
    [  OK  ] Created slice User Slice of UID 0.
             Starting User Runtime Directory /run/user/0...
    [  OK  ] Finished User Runtime Directory /run/user/0.
             Starting User Manager for UID 0...
    [  OK  ] Started User Manager for UID 0.
    [  OK  ] Started Session c1 of User root.
    [   20.125540] PVR_K:  623: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
    [   20.173754] PVR_K:  623: Shader binary image 'rgx.sh.33.15.11.3' loaded
    [  OK  ] Started Weston, a Wayland …mpositor, as a system service.
    [  OK  ] Started Start a wayland application.
    [  OK  ] Reached target Graphical Interface.
             Starting Record Runlevel Change in UTMP...
    [  OK  ] Finished Record Runlevel Change in UTMP.
    TDX Wayland with XWayland 6.7.0+build.13 (kirkstone) verdin-am62-15313467 -
    Verdin-AM62_Reference-Multimedia-Image
    verdin-am62-15313467 login: [   21.935079] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   21.941599] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   21.979106] 8021q: 802.1Q VLAN Support v1.8
    [   21.983712] 8021q: adding VLAN 0 to HW filter on device eth0
    [   26.778696] platform sound: deferred probe pending
  • Hi Franz,
    I assume the provided file should be copied to `ti-linux-firmware/ti-dm/am62xx/` and replace the existing file there and then rebuild u-boot?
    Yes, correct.
    I've already collected the SYSFW trace for a fail and pass case:
    Thanks. I will review them and discuss with our dev team.
  • Hi Franz,
    Can you please capture the failure trace again but with the message timestamp (with milliseconds precision) enabled in the terminal program? We'd like to see the relative time when the timeout message is printed in the wakeup uart console. If you use minicom, it is by pressing 'Ctrl-A, N' twice to turn on the message timestamp in msec format.
  • Hi Bin,
    as ordered:
    dbgFailTime.txt
    A pass as reference:
    dbgTime.txt
    Something to add:
    Does this debug firmware add any delays to the DM in general? It was not as easy as usual to run into the issue and if you remember the experiments done in the beginning adding a delay in the CAN driver, now collecting the logs I had the occurrence rate as if I would have add a 20ms delay (~2%).
  • Hi Franz,
    Thanks for the logs.
    This debug firmware adds two more print before and after the timeout loop check. It would add some delay due to printing to UART, but I wouldn't think the delay would be much as 20ms. Anyway, I have passed the logs to our dev team and am waiting for the next step.
  • Hi Franz,
    Please use the DM firmware binary attached below in your U-Boot build and collect the wkup uart debug trace. This version removes the timeout check to get the exact transition time in low temp.
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/3007.ipc_5F00_echo_5F00_testb_5F00_mcu1_5F00_0_5F00_release_5F00_strip.xer5f
  • Hi Franz,
    Since the DM firmware removes the timeout, it suppose always wait until the transition complete then return succeed to kernel, so I suspect you won't see MCAN failure in Linux with this DM firmware. But the wakeup uart log would show the failure case, which takes longer in the state transition.
    Now since you cannot check the failure in Linux to stop the test when the failure happens, I guess you would have to run the test for the duration which you typically see the failure in previous tests, then we will search the wkup uart log.
  • Hi Bin,
    I ran the test overnight and can provide you with the logs:
    TI_DM_FW_run3.txt
    I can see the '0x75002001' string there which I think indicates the transition failure, and also
    in Linux I was able to see some problems, but it came with some different messages than normally related to 'Mbox'. Below are some examples:
    Climate Chamber:       KWP 120
    Start Temperature:     -36.5�C
    End Temperature:       -36.9�C
    Measured Temperature:  -36.5�C
    Shelf Temperature:     -36.5�C
    Shelf Name:            Shelf_20
    Module Serial Number:  15313467
    Module Location:       Shelf 1, Carrier Board 4
    Test duration:         132.95s
    Test Log
    00:13:50.85 10->11 Waited 30.00s
    00:13:20.66 9->10 Set Reset Low
    00:13:20.53 8->9 Power Off
    00:13:20.42 6->8 Not found, time out: "login:"
    00:11:50.21 5->6 Message found: "Starting kernel"
    00:11:45.19 4->5 Message found: "U-Boot"
    00:11:45.08 3->4 Waited 1.00s
    00:11:43.95 2->3 Set Reset High
    00:11:43.83 1->2 Power On
    00:11:43.72 0->1 Waited 5.00s
    Search Strings
    PASS : U-Boot
    PASS : Less than 64MB RAM detected
    PASS : Booting from mmc failed!
    PASS : Starting kernel
    PASS : mmcblk0: mmc0
    PASS : cut here
    PASS : rcu: INFO: rcu_preempt self-detected stall
    FAIL : Internal error
    PASS : m_can device registered
    PASS : I/O error
    FAIL : login:
    PASS : critical temperature reached
    Disabled : RAM test, TestResult: PASS
    PASS : memtester failed
    Disabled : memtester version
    PASS : FAILURE
    PASS : running CQE recovery
    Disabled : Waiting for power-cycle
    0 : OAK ERROR
    0 : UART ERROR
    N/A : Device life time estimation type B
    N/A : Pre EOL information
    3 : USB hub found
    0 : xception stack
    PASS : page allocation failure
    PASS : hwclock
    Terminal
    U-Boot SPL 2023.04-28170-gc997b1b09f-dirty (Jul 25 2024 - 17:52:28 +0200)
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)')
    Changed A53 CPU frequency to 1250000000Hz (T grade) in DT
    SPL initial stack usage: 13424 bytes
    Trying to boot from MMC1
    Authentication passed
    Loading Environment from nowhere... OK
    init_env from device 9 not supported!
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b8
    NOTICE:  BL31: Built : 10:41:42, May 21 2024
    I/TC:
    I/TC: OP-TEE version: 4.1.0-51-g012cdca49 (gcc version 12.3.1 20230626 (Arm GNU Toolchain 12.3.Rel1 (Build arm-12.35))) #7 Wed Jul 17 09:56:34 UTC 2024 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: GIC redistributor base address not provided
    I/TC: Assuming default GIC group status and modifier
    I/TC: SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)')
    I/TC: HUK Initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot SPL 2023.04-28170-gc997b1b09f-dirty (Jul 25 2024 - 17:53:45 +0200)
    SPL initial stack usage: 1904 bytes
    U-Boot 2023.04-28170-gc997b1b09f-dirty (Jul 25 2024 - 17:53:45 +0200)
    SoC:   AM62X SR1.0 HS-FS
    DRAM:  1 GiB
    Core:  143 devices, 31 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from MMC... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Model: Toradex 0075 Verdin AM62 Dual 1GB WB IT V1.1B
    Serial#: 15313467
    Carrier: Toradex UNKNOWN CARRIER BOARD V1.1B, Serial# 11386995
    am65_cpsw_nuss ethernet@8000000: K3 CPSW: nuss_ver: 0x6BA01103 cpsw_ver: 0x6BA81103 ale_ver: 0x00290105 Ports:2 mdio_freq:1000000
    Setting variant to wifi
    Net:
    Warning: ethernet@8000000port@1 MAC addresses don't match:
    Address in ROM is		1c:63:49:1f:e0:05
    Address in environment is	00:14:2d:e9:aa:3b
    eth0: ethernet@8000000port@1 [PRIME]Could not get PHY for ethernet@8000000port@1: addr 7
    am65_cpsw_nuss_port ethernet@8000000port@2: phy_connect() failed
    Hit any key to stop autoboot:  1  0
    MMC: no card present
    switch to partitions #0, OK
    mmc0(part 0) is current device
    Scanning mmc 0:1...
    Found U-Boot script /boot.scr
    6003 bytes read in 10 ms (585.9 KiB/s)
    ## Executing script at 90280000
    Loading DeviceTree: k3-am625-verdin-wifi-dev.dtb
    82 bytes read in 9 ms (8.8 KiB/s)
    Working FDT set to 90200000
    Applying Overlay: verdin-am62_dsi-to-hdmi_overlay.dtbo
    3415 bytes read in 10 ms (333 KiB/s)
    Applying Overlay: verdin-am62_spidev_overlay.dtbo
    8305029 bytes read in 68 ms (116.5 MiB/s)
    Bootargs: root=PARTUUID=d6171697-02 ro rootwait console=tty1 console=ttyS2,115200 consoleblank=0 earlycon=ns16550a,mmio32,0x02800000
       Uncompressing Kernel Image
    ## Flattened Device Tree blob at 90200000
       Booting using the fdt blob at 0x90200000
       Loading Device Tree to 0000000098eab000, end 0000000098edffff ... OK
    Working FDT set to 98eab000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.1.83-6.7.0+git.0a32d33d5fb7 (oe-user@oe-host) (aarch64-tdx-linux-gcc (GCC) 11.4.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Fri Jun 28 09:20:37 UTC 2024
    [    0.000000] Machine model: Toradex Verdin AM62 WB on Verdin Development Board
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000bfffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009dafffff]
    [    0.000000]   node   0: [mem 0x000000009db00000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e77ffff]
    [    0.000000]   node   0: [mem 0x000000009e780000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000bfffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff]
    [    0.000000] cma: Reserved 128 MiB at 0x00000000b6c00000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 20 pages/cpu s41064 r8192 d32664 u81920
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258048
    [    0.000000] Kernel command line: root=PARTUUID=d6171697-02 ro rootwait console=tty1 console=ttyS2,115200 consoleblank=0 earlycon=ns16550a,mmio32,0x02800000
    [    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 839568K/1048576K available (11648K kernel code, 1412K rwdata, 4076K rodata, 2304K init, 424K bss, 77936K reserved, 131072K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080040000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008604] Console: colour dummy device 80x25
    [    0.013611] printk: console [tty1] enabled
    [    0.017856] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.028549] pid_max: default: 32768 minimum: 301
    [    0.033328] LSM: Security Framework initializing
    [    0.038204] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
    [    0.045793] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
    [    0.055772] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.063250] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.069561] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.076968] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.083364] rcu: Hierarchical SRCU implementation.
    [    0.088281] rcu: 	Max phase no-delay instances is 1000.
    [    0.094377] Platform MSI: msi-controller@1820000 domain created
    [    0.100836] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.110295] EFI services will not be available.
    [    0.115269] smp: Bringing up secondary CPUs ...
    I/TC: Secondary CPU 1 initializing
    I/TC: Secondary CPU 1 switching to normal world boot
    [    0.160073] Detected VIPT I-cache on CPU1
    [    0.160206] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.160227] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [    0.160294] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.160418] smp: Brought up 1 node, 2 CPUs
    [    0.189837] SMP: Total of 2 processors activated.
    [    0.194657] CPU features: detected: 32-bit EL0 Support
    [    0.199935] CPU features: detected: CRC32 instructions
    [    0.205253] CPU: All CPU(s) started at EL2
    [    0.209445] alternatives: applying system-wide alternatives
    [    0.216811] devtmpfs: initialized
    [    0.229809] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.239860] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.252680] pinctrl core: initialized pinctrl subsystem
    [    0.258909] DMI not present or invalid.
    [    0.263570] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.270852] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
    [    0.278201] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.286213] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.294416] audit: initializing netlink subsys (disabled)
    [    0.300238] audit: type=2000 audit(0.176:1): state=initialized audit_enabled=0 res=1
    [    0.300816] thermal_sys: Registered thermal governor 'step_wise'
    [    0.308180] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.314523] cpuidle: using governor menu
    [    0.325437] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.332449] ASID allocator initialised with 65536 entries
    [    0.351313] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/dsi@e
    [    0.361579] platform connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.373448] KASLR disabled due to lack of seed
    [    0.384456] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.391453] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.397872] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.404819] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.411233] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.418180] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.424594] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.431540] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.439663] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.449763] iommu: Default domain type: Translated
    [    0.454789] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.461518] SCSI subsystem initialized
    [    0.465758] usbcore: registered new interface driver usbfs
    [    0.471417] usbcore: registered new interface driver hub
    [    0.476882] usbcore: registered new device driver usb
    [    0.482622] pps_core: LinuxPPS API ver. 1 registered
    [    0.487710] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.497071] PTP clock support registered
    [    0.501236] EDAC MC: Ver: 3.0.0
    [    0.505601] FPGA manager framework
    [    0.509202] Advanced Linux Sound Architecture Driver Initialized.
    [    0.516490] clocksource: Switched to clocksource arch_sys_counter
    [    0.523041] VFS: Disk quotas dquot_6.6.0
    [    0.527112] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.540235] NET: Registered PF_INET protocol family
    [    0.545532] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.554248] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
    [    0.562904] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.570853] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.578847] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
    [    0.586574] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.593283] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.600103] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.607527] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.613912] RPC: Registered named UNIX socket transport module.
    [    0.620021] RPC: Registered udp transport module.
    [    0.624837] RPC: Registered tcp transport module.
    [    0.629652] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.636255] NET: Registered PF_XDP protocol family
    [    0.641198] PCI: CLS 0 bytes, default 64
    [    0.646088] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.656403] Initialise system trusted keyrings
    [    0.661258] workingset: timestamp_bits=46 max_order=18 bucket_order=0
    [    0.672320] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.679073] NFS: Registering the id_resolver key type
    [    0.684324] Key type id_resolver registered
    [    0.688608] Key type id_legacy registered
    [    0.692776] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.699640] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.741834] Key type asymmetric registered
    [    0.746040] Asymmetric key parser 'x509' registered
    [    0.751095] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.758894] io scheduler mq-deadline registered
    [    0.763543] io scheduler kyber registered
    [    0.771767] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.778978] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.792547] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
    [    0.809990] brd: module loaded
    [    0.818139] loop: module loaded
    [    0.826130] tun: Universal TUN/TAP device driver, 1.6
    [    0.832216] VFIO - User Level meta-driver version: 0.3
    [    0.838917] usbcore: registered new interface driver usb-storage
    [    0.845192] usbcore: registered new device driver onboard-usb-hub
    [    0.852423] i2c_dev: i2c /dev entries driver
    [    0.859180] sdhci: Secure Digital Host Controller Interface driver
    [    0.865575] sdhci: Copyright(c) Pierre Ossman
    [    0.870300] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.876794] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.883153] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.890153] usbcore: registered new interface driver usbhid
    [    0.895866] usbhid: USB HID core driver
    [    0.900944] optee: probing for conduit method.
    I/TC: Reserved shared memory is enabled
    I/TC: Dynamic shared memory is enabled
    I/TC: Normal World virtualization support is disabled
    I/TC: Asynchronous notifications are disabled
    [    0.905553] optee: revision 4.1 (012cdca4)
    [    0.922195] optee: dynamic shared memory is enabled
    [    0.931675] optee: initialized driver
    [    0.937606] Initializing XFRM netlink socket
    [    0.942075] NET: Registered PF_PACKET protocol family
    [    0.947339] Key type dns_resolver registered
    [    0.952174] registered taskstats version 1
    [    0.956408] Loading compiled-in X.509 certificates
    [    0.974689] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)')
    [    2.620939] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=81, clk=20, ret=-19
    [    3.177167] omap_i2c 4900000.i2c: bus 3 rev0.12 at 100 kHz
    [    3.187356] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/dsi@e
    [    3.196496] i2c 0-000e: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/hdmi@48
    [    3.204617] i2c 0-000e: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    3.212620] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
    [    3.252935] input: tps65219-pwrbutton as /devices/platform/bus@f0000/20000000.i2c/i2c-0/0-0030/tps65219-pwrbutton.2.auto/input/input0
    [    3.267270] rtc-ds1307 0-0032: oscillator failed, set time!
    [    3.273199] rtc-ds1307 0-0032: registered as rtc0
    [    3.278169] rtc-ds1307 0-0032: hctosys: unable to read the hardware clock
    [    3.287351] at24 0-0050: supply vcc not found, using dummy regulator
    [    3.294333] at24 0-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
    [    3.301271] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    3.312253] i2c 0-000e: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/hdmi@48
    [    3.320507] platform hdmi-connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/hdmi@48
    [    3.329889] i2c 1-0048: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/dsi@e
    [    3.337872] i2c 1-0048: Fixed dependency cycle(s) with /hdmi-connector
    [    3.345276] pca953x 1-0021: supply vcc not found, using dummy regulator
    [    3.352209] pca953x 1-0021: using no AI
    [    3.376632] pca953x 1-0021: failed writing register
    [    3.381847] pca953x: probe of 1-0021 failed with error -121
    [    3.388276] at24 1-0057: supply vcc not found, using dummy regulator
    [    3.395574] at24 1-0057: 256 byte 24c02 EEPROM, writable, 16 bytes/write
    [    3.402521] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    3.413215] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz
    [    3.423362] omap_i2c 20030000.i2c: bus 4 rev0.12 at 100 kHz
    [    3.438515] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    3.456036] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    3.483596] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    3.572973] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    3.608733] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    3.619914] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    3.794725] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    3.808767] 4a00000.serial: ttyS3 at MMIO 0x4a00000 (irq = 291, base_baud = 3000000) is a 8250
    [    3.822323] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 292, base_baud = 3000000) is a 8250
    [    3.831247] printk: console [ttyS2] enabled
    [    3.839713] printk: bootconsole [ns16550a0] disabled
    [    3.854316] 2810000.serial: ttyS0 at MMIO 0x2810000 (irq = 293, base_baud = 3000000) is a 8250
    [    3.867207] omap8250 2850000.serial: PM domain pd:156 will not be powered off
    [    3.874678] 2850000.serial: ttyS4 at MMIO 0x2850000 (irq = 294, base_baud = 3000000) is a 8250
    [    3.883432] serial serial0: tty port ttyS4 registered
    [    3.904896] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    3.948502] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    3.957384] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    3.970333] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    3.977475] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    3.991089] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    4.143567] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    4.324902] platform connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    4.334514] platform 31000000.usb: Fixed dependency cycle(s) with /connector
    [    4.491076] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
    [    4.496717] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
    [    4.504534] xhci-hcd xhci-hcd.3.auto: USB3 root hub has no ports
    [    4.510546] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020010010
    [    4.520015] xhci-hcd xhci-hcd.3.auto: irq 299, io mem 0x31100000
    [    4.526928] hub 1-0:1.0: USB hub found
    [    4.530729] hub 1-0:1.0: 1 port detected
    [    4.788557] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    4.852077] gpio-488 (PCIE_1_RESET#): hogged as output/low
    [    4.896931] mmc0: CQHCI version 5.10
    [    4.944254] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    5.002297] mmc0: new HS200 MMC card at address 0001
    [    5.007628] hub 1-1:1.0: USB hub found
    [    5.011686] hub 1-1:1.0: 4 ports detected
    [    5.016454] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
    [    5.023474]  mmcblk0: p1 p2
    [    5.027251] mmcblk0boot0: mmc0:0001 Q2J55L 16.0 MiB
    [    5.035335] mmcblk0boot1: mmc0:0001 Q2J55L 16.0 MiB
    [    5.043255] mmcblk0rpmb: mmc0:0001 Q2J55L 4.00 MiB, chardev (241:0)
    [    5.206832] reg-fixed-voltage regulator-force-sleep-moci: nonexclusive access to GPIO for regulator-force-sleep-moci
    [    5.356835] usb 1-1.4: new high-speed USB device number 3 using xhci-hcd
    [    5.514172] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    5.560600] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    5.577406] mdio_bus 8000f00.mdio: MDIO device at address 7 is missing.
    [    5.584074] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    5.598829] usb 1-1.4: USB disconnect, device number 3
    [    5.638419] sdhci-am654 fa00000.mmc: Got CD GPIO
    [    5.638460] sdhci-am654 fa20000.mmc: allocated mmc-pwrseq
    [    5.652699] mmc1: CQHCI version 5.10
    [    5.671153] mmc2: CQHCI version 5.10
    [    5.678779] hub 1-1:1.0: USB hub found
    [    5.682676] hub 1-1:1.0: 4 ports detected
    [    5.710520] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    5.718116] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
    [    5.772464] mmc2: new ultra high speed DDR50 SDIO card at address 0001
    [    5.779554] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    5.794022] input: gpio-keys as /devices/platform/gpio-keys/input/input1
    [    5.924498] usb 1-1.4: new high-speed USB device number 4 using xhci-hcd
    [    6.042113] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=81, clk=20, ret=-19
    [    6.342096] ALSA device list:
    [    6.345088]   No soundcards found.
    [    6.357344] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [    6.364790] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [    7.242819] EXT4-fs (mmcblk0p2): recovery complete
    [    7.249734] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    7.258477] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    7.269069] devtmpfs: mounted
    [    7.273867] Freeing unused kernel memory: 2304K
    [    7.278622] Run /sbin/init as init process
    [    7.424583] systemd[1]: System time before build time, advancing clock.
    [    7.473204] NET: Registered PF_INET6 protocol family
    [    7.480009] Segment Routing with IPv6
    [    7.483913] In-situ OAM (IOAM) with IPv6
    [    7.515019] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    7.546990] systemd[1]: Detected architecture arm64.
    Welcome to TDX Wayland with XWayland 6.7.0+build.13 (kirkstone)!
    [    7.605388] systemd[1]: Hostname set to <verdin-am62-15313467>.
    [    8.047784] systemd[1]: Queued start job for default target Graphical Interface.
    [    8.105643] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    8.131138] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    8.155004] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    8.178337] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    8.201129] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password …ts to Console Directory Watch.
    [    8.225049] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password R…uests to Wall Directory Watch.
    [    8.249370] systemd[1]: Reached target Host and Network Name Lookups.
    [  OK  ] Reached target Host and Network Name Lookups.
    [    8.272788] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    8.288911] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    8.308794] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    8.324905] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    8.401574] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    8.425206] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    8.450425] systemd[1]: Listening on Syslog Socket.
    [  OK  ] Listening on Syslog Socket.
    [    8.465755] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    8.490735] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    8.515226] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    8.538353] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    8.554859] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    8.578506] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    8.601996] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    8.627308] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    8.681187] systemd[1]: Mounting Huge Pages File System...
    [    8.702599] systemd[1]: Mounting POSIX Message Queue File System...
    [    8.730969] systemd[1]: Mounting Kernel Debug File System...
    [    8.753444] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    8.793266] systemd[1]: Mounting Temporary Directory /tmp...
    [    8.816245] systemd[1]: Starting Create List of Static Device Nodes...
    [    8.849845] systemd[1]: Starting Load Kernel Module configfs...
    [    8.878379] systemd[1]: Starting Load Kernel Module drm...
    [    8.930270] systemd[1]: Starting Load Kernel Module fuse...
    [    8.945654] fuse: init (API version 7.37)
    [    8.962324] systemd[1]: Starting RPC Bind...
    [    9.006140] systemd[1]: Starting File System Check on Root Device...
    [    9.037310] systemd[1]: Starting Journal Service...
    [    9.060953] systemd[1]: Starting Load Kernel Modules...
    [    9.081946] systemd[1]: Starting Generate network units from Kernel command line...
             Starting Generate network …ts from Kernel command line...
    [    9.110681] systemd[1]: Starting Coldplug All udev Devices...
    [    9.150459] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    9.166425] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    9.193709] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [    9.225710] systemd[1]: Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Debug File System.
    [    9.253674] systemd[1]: Mounted Temporary Directory /tmp.
    [  OK  ] Mounted Temporary Directory /tmp.
    [    9.282989] systemd[1]: Finished Create List of Static Device Nodes.
    [  OK  ] Finished Create List of Static Device Nodes.
    [    9.305582] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [  OK  ] Finished File System Check on Root Device.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Remount Root and Kernel File Systems...
             Starting Apply Kernel Variables...
    [    9.594540] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Remount Root and Kernel File Systems.
    [  OK  ] Finished Apply Kernel Variables.
             Starting Flush Journal to Persistent Storage...
    [    9.729997] systemd-journald[169]: Received client request to flush runtime journal.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /var/volatile...
    [    9.879505] audit: type=1334 audit(1651167747.452:2): prog-id=5 op=LOAD
    [    9.887406] audit: type=1334 audit(1651167747.460:3): prog-id=6 op=LOAD
             Starting Rule-based Manage…for Device Events and Files...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Mounted /var/volatile.
             Starting Wait for udev To …plete Device Initialization...
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started Network Time Synchronizatio[   10.682424] systemd-journald[169]: Oldest entry in /run/log/journal/1495eaee79b84a7fa9584d8b71d7811b/system.journal is older than the configured file retention duration (1month), suggesting rotation.
    n.
    [   10.717893] systemd-journald[169]: /run/log/journal/1495eaee79b84a7fa9584d8b71d7811b/system.journal: Journal header limits reached or header out-of-date, rotating.
    [  OK  ] Reached target System Time Set.
    [   10.868545] random: crng init done
    [  OK  ] Finished Load/Save Random Seed.
    [   10.972624] nau8822 1-001a: Failed to issue reset: -121
    [   10.978041] nau8822: probe of 1-001a failed with error -121
    [   10.983827] ina2xx 1-0040: error configuring the device: -121
    [   11.014143] CAN device driver interface
    [   11.014888] lm75 0-0048: supply vs not found, using dummy regulator
    [   11.048878] hwmon hwmon1: temp1_input not attached to any thermal zone
    [   11.058735] lm75 0-0048: hwmon1: sensor 'tmp1075'
    [   11.072843] lm75 1-004f: supply vs not found, using dummy regulator
    [   11.084841] m_can_platform 4e08000.can: m_can device registered (irq=0, version=32)
    [   11.097072] hwmon hwmon2: temp1_input not attached to any thermal zone
    [   11.110536] lm75 1-004f: hwmon2: sensor 'tmp75c'
    [  OK  ] Found device /dev/ttyS2.
    [   11.310829] Bluetooth: Core ver 2.22
    [   11.325205] NET: Registered PF_BLUETOOTH protocol family
    [   11.334832] Bluetooth: HCI device and connection manager initialized
    [   11.346068] Bluetooth: HCI socket layer initialized
    [   11.351168] Bluetooth: L2CAP socket layer initialized
    [   11.376472] Bluetooth: SCO socket layer initialized
    [   11.494752] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   11.521168] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   11.528944] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [   11.995322] mwifiex_sdio mmc2:0001:1: info: FW download over, size 578116 bytes
    [   12.176510] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   12.176537] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
    [   12.176564] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.189900] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.197267] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
    [   12.197292] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.209678] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_recalc_rate+0x48/0xb0)
    [   12.219625] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   12.227608] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.235644] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   12.247875] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   12.252681] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.264833] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=190, clk=0, ret=-110
    [   12.274933] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.281826] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: k3_ringacc_ring_cfg_sci+0x94/0x100)
    [   12.292881] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.301070] ti-sci 44043000.system-controller: RM_RA:Mbox config send fail -110
    [   12.321027] ti-udma 485c0000.dma-controller: TISCI config ring fail (-110) ring_idx 142
    [   12.329225] ti-udma 485c0000.dma-controller: get channel fail in udma_of_xlate.
    [   12.336867] saul-crypto 40900000.crypto: error -EINVAL: Unable to request rx1 DMA channel
    [   12.347061] saul-crypto: probe of 40900000.crypto failed with error -22
    [   12.485514] pvrsrvkm: loading out-of-tree module taints kernel.
    [   12.528578] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: k3_m4_rproc_probe+0x1a4/0x4fc [ti_k3_m4_remoteproc])
    [   12.540744] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.548384] k3-m4-rproc 5000000.m4fss: ti-sci processor request failed: -110
    [   12.555722] k3-m4-rproc 5000000.m4fss: ti_sci_proc_request failed, ret = -110
    [   12.566552] remoteproc remoteproc0: releasing 5000000.m4fss
    [   12.572713] k3-m4-rproc: probe of 5000000.m4fss failed with error -110
    [   12.720714] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   12.737637] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.136645] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
    [   13.148410] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
    [   13.162153] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.171930] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.181129] lt8912 1-0048: supply vccmipirx not found, using dummy regulator
    [   13.191355] lt8912 1-0048: supply vccsysclk not found, using dummy regulator
    [   13.206169] lt8912 1-0048: supply vcclvdstx not found, using dummy regulator
    [   13.219667] lt8912 1-0048: supply vcchdmitx not found, using dummy regulator
    [   13.234587] lt8912 1-0048: supply vcclvdspll not found, using dummy regulator
    [   13.250308] lt8912 1-0048: supply vcchdmipll not found, using dummy regulator
    [   13.300605] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
    [   13.310948] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   13.321911] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.328671] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_set_parent+0x34/0x40)
    [   13.331612] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.349401] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.392710] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   13.439367] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.520734] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   13.539973] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.548631] mwifiex_sdio mmc2:0001:1: WLAN FW is active
    [   13.579420] mwifiex_sdio mmc2:0001:1: event: unknown event id: 0x81
    [   13.586077] mwifiex_sdio mmc2:0001:1: Unknown api_id: 5
    [   13.591426] mwifiex_sdio mmc2:0001:1: Unknown GET_HW_SPEC TLV type: 0x23e
    [   13.630006] mwifiex_sdio mmc2:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.92.21.p119)
    [   13.638353] mwifiex_sdio mmc2:0001:1: driver_version = mwifiex 1.0 (16.92.21.p119)
    [   14.288564] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   14.302388] ti-sci 44043000.system-controller: Mbox send fail -110
    [   14.384728] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_recalc_rate+0x48/0xb0)
    [   14.421367] ti-sci 44043000.system-controller: Mbox send fail -110
    [   14.433797] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=190, clk=0, ret=-110
    [*     ] A start job is running for Wait for…ic[   14.453954] clk: failed to reparent clk:190:0 to clk:190:2: -110
    e Initialization (2s / 2min 57s)
    M
    [  OK  ] Created slice Slice /system/systemd-fsck.
    [   14.608597] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
    [   14.618749] ti-sci 44043000.system-controller: Mbox send fail -110
             Starting File System Check on /dev/mmcblk0p1...
    [  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
             Starting Load/Save RF Kill Switch Status...
    [   15.115924] ti-sci 44043000.system-controller: Message for 1 is not expected!
    [   15.153773] ti-sci 44043000.system-controller: Message for 4 is not expected!
    [   15.161012] ti-sci 44043000.system-controller: Message for 5 is not expected!
    [   15.168186] ti-sci 44043000.system-controller: Message for 3 is not expected!
             Mounting /boot...
    [   15.292241] Internal error: synchronous external abort: 0000000096000010 [#1] PREEMPT SMP
    [   15.300473] Modules linked in: crct10dif_ce snd_soc_simple_card snd_soc_simple_card_utils btnxpuart display_connector pvrsrvkm(O) ti_k3_r5_remoteproc virtio_rpmsg_bus rpmsg_ns rtc_ti_k3 mwifiex_sdio mwifiex ti_k3_m4_remoteproc ti_k3_common cfg80211 bluetooth ecdh_generic ecc sa2ul rfkill tidss snd_soc_davinci_mcasp(+) drm_dma_helper snd_soc_ti_udma mcrc snd_soc_ti_edma pruss snd_soc_ti_sdma pwm_tiehrpwm lontium_lt8912b tc358768 drm_kms_helper syscopyarea m_can_platform m_can can_dev spi_omap2_mcspi sysfillrect sysimgblt fb_sys_fops lm75 ina2xx snd_soc_nau8822 libcomposite fuse drm drm_panel_orientation_quirks ipv6
    [   15.354964] CPU: 0 PID: 201 Comm: systemd-udevd Tainted: G           O       6.1.83-6.7.0+git.0a32d33d5fb7 #1
    [   15.364878] Hardware name: Toradex Verdin AM62 WB on Verdin Development Board (DT)
    [   15.372440] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [   15.379396] pc : iomap_read_reg+0xc/0x30 [m_can_platform]
    [   15.384812] lr : m_can_get_berr_counter+0x3c/0x10c [m_can]
    [   15.390304] sp : ffff800009b9b5f0
    [   15.393612] x29: ffff800009b9b5f0 x28: 0000000000000240 x27: ffff800000d1a1a0
    [   15.400750] x26: ffff000003691800 x25: ffff000003691a40 x24: 0000000000000000
    [   15.407882] x23: 0000000000000000 x22: ffff000000c0dc10 x21: ffff000003668000
    [   15.415013] x20: ffff000003668980 x19: ffff800009b9b62c x18: 0000000000000000
    [   15.422144] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000141
    [   15.429274] x14: 0000000000000232 x13: 0000000000000001 x12: 0000000000000000
    [   15.436405] x11: 0000000000000001 x10: 00000000000009b0 x9 : 0000002c48fd6040
    [   15.443535] x8 : 0000b23a1ff88492 x7 : 000000000000b9f1 x6 : ffff000000c0dd90
    [   15.450666] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 0000000000000000
    [   15.457796] x2 : ffff800000d31000 x1 : 0000000000000040 x0 : ffff800009ab0040
    [   15.464928] Call trace:
    [   15.467370]  iomap_read_reg+0xc/0x30 [m_can_platform]
    [   15.472421]  can_fill_info+0x108/0x524 [can_dev]
    [   15.477056]  rtnl_fill_ifinfo+0x844/0x11b0
    [   15.481157]  rtnl_getlink+0x23c/0x424
    [   15.484815]  rtnetlink_rcv_msg+0x130/0x3a0
    [   15.488907]  netlink_rcv_skb+0x60/0x130
    [   15.492743]  rtnetlink_rcv+0x18/0x2c
    [   15.496312]  netlink_unicast+0x2f0/0x360
    [   15.500232]  netlink_sendmsg+0x1b0/0x420
    [   15.504150]  __sys_sendto+0x138/0x174
    [   15.507813]  __arm64_sys_sendto+0x28/0x3c
    [   15.511818]  invoke_syscall+0x48/0x114
    [   15.515567]  el0_svc_common.constprop.0+0xd4/0xfc
    [   15.520266]  do_el0_svc+0x20/0x30
    [   15.523575]  el0_svc+0x28/0xa0
    [   15.526629]  el0t_64_sync_handler+0xbc/0x140
    [   15.530893]  el0t_64_sync+0x18c/0x190
    [   15.534562] Code: bad PC value
    [   15.537617] ---[ end trace 0000000000000000 ]---
    [   16.056864] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [   16.064951] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [   16.173390] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [   16.452448] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
    [**    ] (1 of 2) A start job is running for…e RF Kill Switch Status (2s / 30s)
    M
    [***   ] (1 of 2) A start job is running for…e RF Kill Switch Status (3s / 30s)
    M
    [ ***  ] (2 of 2) A start job is running for…ice Initialization (3s / 2min 54s)
    M
    [  *** ] (2 of 2) A start job is running for…ice Initialization (4s / 2min 54s)
    M
    [   ***] (2 of 2) A start job is running for…ice Initialization (4s / 2min 54s)
    M
    [    **] (1 of 2) A start job is running for…e RF Kill Switch Status (5s / 30s)
    M
    [     *] (1 of 2) A start job is running for…e RF Kill Switch Status (6s / 30s)
    M
    [    **] (1 of 2) A start job is running for…e RF Kill Switch Status (6s / 30s)
    M
    [   ***] (2 of 2) A start job is running for…ice Initialization (7s / 2min 54s)
    M
    [  *** ] (2 of 2) A start job is running for…ice Initialization (7s / 2min 54s)
    M
    [ ***  ] (2 of 2) A start job is running for…ice Initialization (8s / 2min 54s)
    M
    [***   ] (1 of 2) A start job is running for…e RF Kill Switch Status (8s / 30s)
    M
    [**    ] (1 of 2) A start job is running for…e RF Kill Switch Status (9s / 30s)
    M
    [*     ] (1 of 2) A start job is running for… RF Kill Switch Status (10s / 30s)
    M
    [**    ] (2 of 2) A start job is running for…ce Initialization (10s / 2min 54s)
    M
    [***   ] (2 of 2) A start job is running for…ce Initialization (11s / 2min 54s)
    M
    [ ***  ] (2 of 2) A start job is running for…ce Initialization (11s / 2min 54s)
    M
    [  *** ] (1 of 2) A start job is running for… RF Kill Switch Status (12s / 30s)
    M
    [   ***] (1 of 2) A start job is running for… RF Kill Switch Status (13s / 30s)
    M
    [    **] (1 of 2) A start job is running for… RF Kill Switch Status (13s / 30s)
    M
    [     *] (2 of 2) A start job is running for…ce Initialization (14s / 2min 54s)
    M
    [    **] (2 of 2) A start job is running for…ce Initialization (14s / 2min 54s)
    M
    [   ***] (2 of 2) A start job is running for…ce Initialization (15s / 2min 54s)
    M
    [  *** ] (1 of 2) A start job is running for… RF Kill Switch Status (15s / 30s)
    M
    [ ***  ] (1 of 2) A start job is running for… RF Kill Switch Status (16s / 30s)
    M
    [***   ] (1 of 2) A start job is running for… RF Kill Switch Status (17s / 30s)
    M
    [**    ] (2 of 2) A start job is running for…ce Initialization (17s / 2min 54s)
    M
    [*     ] (2 of 2) A start job is running for…ce Initialization (18s / 2min 54s)
    M
    [**    ] (2 of 2) A start job is running for…ce Initialization (18s / 2min 54s)
    M
    [***   ] (1 of 2) A start job is running for… RF Kill Switch Status (19s / 30s)
    M
    [ ***  ] (1 of 2) A start job is running for… RF Kill Switch Status (20s / 30s)
    M
    M
    [   ***] (2 of 2) A start job is running for…ce Initialization (20s / 2min 54s)
    M
    [    **] (2 of 2) A start job is running for…ce Initialization (21s / 2min 54s)
    M
    [     *] (2 of 2) A start job is running for…ce Initialization (21s / 2min 54s)
    M
    [    **] (1 of 2) A start job is running for… RF Kill Switch Status (22s / 30s)
    M
    [   ***] (1 of 2) A start job is running for… RF Kill Switch Status (23s / 30s)
    M
    [  *** ] (1 of 2) A start job is running for… RF Kill Switch Status (23s / 30s)
    M
    [ ***  ] (2 of 2) A start job is running for…ce Initialization (23s / 2min 54s)
    M
    [***   ] (2 of 2) A start job is running for…ce Initialization (24s / 2min 54s)
    M
    [**    ] (2 of 2) A start job is running for…ce Initialization (24s / 2min 54s)
    M
    [*     ] (1 of 2) A start job is running for… RF Kill Switch Status (25s / 30s)
    M
    [**    ] (1 of 2) A start job is running for… RF Kill Switch Status (26s / 30s)
    M
    [***   ] (1 of 2) A start job is running for… RF Kill Switch Status (26s / 30s)
    M
    [ ***  ] (2 of 2) A start job is running for…ce Initialization (26s / 2min 54s)
    M
    [  *** ] (2 of 2) A start job is running for…ce Initialization (27s / 2min 54s)
    M
    [   ***] (2 of 2) A start job is running for…ce Initialization (27s / 2min 54s)
    M
    [    **] (1 of 2) A start job is running for… RF Kill Switch Status (28s / 30s)
    M
    [     *] (1 of 2) A start job is running for… RF Kill Switch Status (29s / 30s)
    M
    [    **] (1 of 2) A start job is running for… RF Kill Switch Status (29s / 30s)
    M
    [   ***] (2 of 2) A start job is running for…ce Initialization (29s / 2min 54s)
    M
    [  *** ] (2 of 2) A start job is running for…ce Initialization (30s / 2min 54s)
    M
    M
    [***   ] (1 of 2) A start job is running for…RF Kill Switch Status (31s / 1min)
    M
    [**    ] (1 of 2) A start job is running for…RF Kill Switch Status (32s / 1min)
    M
    [*     ] (1 of 2) A start job is running for…RF Kill Switch Status (32s / 1min)
    M
    [**    ] (2 of 2) A start job is running for…ce Initialization (32s / 2min 54s)
    M
    [***   ] (2 of 2) A start job is running for…ce Initialization (33s / 2min 54s)
    M
    [ ***  ] (2 of 2) A start job is running for…ce Initialization (33s / 2min 54s)
    M
    [  *** ] (1 of 2) A start job is running for…RF Kill Switch Status (34s / 1min)
    M
    [   ***] (1 of 2) A start job is running for…RF Kill Switch Status (35s / 1min)
    M
    [    **] (1 of 2) A start job is running for…RF Kill Switch Status (35s / 1min)
    M
    [     *] (2 of 2) A start job is running for…ce Initialization (35s / 2min 54s)
    M
    [    **] (2 of 2) A start job is running for…ce Initialization (36s / 2min 54s)
    M
    [   ***] (2 of 2) A start job is running for…ce Initialization (36s / 2min 54s)
    M
    [  *** ] (1 of 2) A start job is running for…RF Kill Switch Status (37s / 1min)
    M
    [ ***  ] (1 of 2) A start job is running for…RF Kill Switch Status (38s / 1min)
    M
    [***   ] (1 of 2) A start job is running for…RF Kill Switch Status (38s / 1min)
    M
    [**    ] (2 of 2) A start job is running for…ce Initialization (38s / 2min 54s)
    M
    [*     ] (2 of 2) A start job is running for…ce Initialization (39s / 2min 54s)
    M
    [**    ] (2 of 2) A start job is running for…ce Initialization (39s / 2min 54s)
    M
    [***   ] (1 of 2) A start job is running for…RF Kill Switch Status (40s / 1min)
    M
    [ ***  ] (1 of 2) A start job is running for…RF Kill Switch Status (41s / 1min)
    M
    M
    [   ***] (2 of 2) A start job is running for…ce Initialization (41s / 2min 54s)
    M
    [    **] (2 of 2) A start job is running for…ce Initialization (42s / 2min 54s)
    M
    [     *] (2 of 2) A start job is running for…ce Initialization (42s / 2min 54s)
    M
    [    **] (1 of 2) A start job is running for…RF Kill Switch Status (43s / 1min)
    M
    [   ***] (1 of 2) A start job is running for…RF Kill Switch Status (44s / 1min)
    M
    [  *** ] (1 of 2) A start job is running for…RF Kill Switch Status (44s / 1min)
    M
    [ ***  ] (2 of 2) A start job is running for…ce Initialization (44s / 2min 54s)
    M
    [***   ] (2 of 2) A start job is running for…ce Initialization (45s / 2min 54s)
    M
    [**    ] (2 of 2) A start job is running for…ce Initialization (45s / 2min 54s)
    M
    [*     ] (1 of 2) A start job is running for…RF Kill Switch Status (46s / 1min)
    M
    [**    ] (1 of 2) A start job is running for…RF Kill Switch Status (47s / 1min)
    M
    [***   ] (1 of 2) A start job is running for…RF Kill Switch Status (47s / 1min)
    M
    [ ***  ] (2 of 2) A start job is running for…ce Initialization (47s / 2min 54s)
    M
    [  *** ] (2 of 2) A start job is running for…ce Initialization (48s / 2min 54s)
    M
    [   ***] (2 of 2) A start job is running for…ce Initialization (48s / 2min 54s)
    M
    [    **] (1 of 2) A start job is running for…RF Kill Switch Status (49s / 1min)
    M
    [     *] (1 of 2) A start job is running for…RF Kill Switch Status (50s / 1min)
    M
    [    **] (1 of 2) A start job is running for…RF Kill Switch Status (50s / 1min)
    M
    [   ***] (2 of 2) A start job is running for…ce Initialization (50s / 2min 54s)
    M
    [  *** ] (2 of 2) A start job is running for…ce Initialization (51s / 2min 54s)
    M
    M
    [***   ] (1 of 2) A start job is running for…RF Kill Switch Status (52s / 1min)
    M
    [**    ] (1 of 2) A start job is running for…RF Kill Switch Status (53s / 1min)
    M
    [*     ] (1 of 2) A start job is running for…RF Kill Switch Status (53s / 1min)
    M
    [**    ] (2 of 2) A start job is running for…ce Initialization (53s / 2min 54s)
    M
    [***   ] (2 of 2) A start job is running for…ce Initialization (54s / 2min 54s)
    M
    [ ***  ] (2 of 2) A start job is running for…ce Initialization (54s / 2min 54s)
    M
    [  *** ] (1 of 2) A start job is running for…RF Kill Switch Status (55s / 1min)
    M
    [   ***] (1 of 2) A start job is running for…RF Kill Switch Status (56s / 1min)
    M
    [    **] (1 of 2) A start job is running for…RF Kill Switch Status (56s / 1min)
    M
    [     *] (2 of 2) A start job is running for…ce Initialization (56s / 2min 54s)
    M
    [    **] (2 of 2) A start job is running for…ce Initialization (57s / 2min 54s)
    M
    [   ***] (2 of 2) A start job is running for…ce Initialization (57s / 2min 54s)
    M
    [  *** ] (1 of 2) A start job is running for…RF Kill Switch Status (58s / 1min)
    M
    [ ***  ] (1 of 2) A start job is running for…RF Kill Switch Status (59s / 1min)
    M
    [***   ] (1 of 2) A start job is running for…RF Kill Switch Status (59s / 1min)
    M
    [**    ] (2 of 2) A start job is running for…ce Initialization (59s / 2min 54s)
    M
    [*     ] (2 of 2) A start job is running for…e Initialization (1min / 2min 54s)
    M
    [**    ] (2 of 2) A start job is running for…e Initialization (1min / 2min 54s)
    M
    [***   ] (1 of 2) A start job is running for…Switch Status (1min 1s / 1min 30s)
    M
    [ ***  ] (1 of 2) A start job is running for…Switch Status (1min 2s / 1min 30s)
    M
    M
    [   ***] (2 of 2) A start job is running for…nitialization (1min 2s / 2min 54s)
    M
    [    **] (2 of 2) A start job is running for…nitialization (1min 3s / 2min 54s)
    M
    [     *] (2 of 2) A start job is running for…nitialization (1min 3s / 2min 54s)
    M
    [    **] (1 of 2) A start job is running for…Switch Status (1min 4s / 1min 30s)
    M
    [   ***] (1 of 2) A start job is running for…Switch Status (1min 5s / 1min 30s)
    M
    [  *** ] (1 of 2) A start job is running for…Switch Status (1min 5s / 1min 30s)
    M
    [ ***  ] (2 of 2) A start job is running for…nitialization (1min 5s / 2min 54s)
    M
    [***   ] (2 of 2) A start job is running for…nitialization (1min 6s / 2min 54s)
    M
    [**    ] (2 of 2) A start job is running for…nitialization (1min 6s / 2min 54s)
    M
    [*     ] (1 of 2) A start job is running for…Switch Status (1min 7s / 1min 30s)
    M
    [**    ] (1 of 2) A start job is running for…Switch Status (1min 8s / 1min 30s)
    M
    [***   ] (1 of 2) A start job is running for…Switch Status (1min 8s / 1min 30s)
    M
    [ ***  ] (2 of 2) A start job is running for…nitialization (1min 8s / 2min 54s)
    M
    [  *** ] (2 of 2) A start job is running for…nitialization (1min 9s / 2min 54s)
    M
    [   ***] (2 of 2) A start job is running for…nitialization (1min 9s / 2min 54s)
    M
    [    **] (1 of 2) A start job is running for…witch Status (1min 10s / 1min 30s)
    M
    [     *] (1 of 2) A start job is running for…witch Status (1min 11s / 1min 30s)
    M
    [    **] (1 of 2) A start job is running for…witch Status (1min 11s / 1min 30s)
    M
    [   ***] (2 of 2) A start job is running for…itialization (1min 11s / 2min 54s)
    M
    [  *** ] (2 of 2) A start job is running for…itialization (1min 12s / 2min 54s)
    M
    M
    [***   ] (1 of 2) A start job is running for…witch Status (1min 13s / 1min 30s)
    M
    [**    ] (1 of 2) A start job is running for…witch Status (1min 14s / 1min 30s)
    M
    [*     ] (1 of 2) A start job is running for…witch Status (1min 14s / 1min 30s)
    M
    [**    ] (2 of 2) A start job is running for…itialization (1min 14s / 2min 54s)
    End Temperature:       -36.3�C
    Shelf Temperature:     -35.8�C
    Test duration:         73.94s
    Test Log
    20:10:55.11 10->11 Waited 30.00s
    20:10:25.01 9->10 Set Reset Low
    20:10:24.91 8->9 Power Off
    20:10:24.80 7->8 Waited 5.00s
    20:10:19.60 6->7 Message found: "login:"
    20:09:54.26 5->6 Message found: "Starting kernel"
    20:09:48.31 4->5 Message found: "U-Boot"
    20:09:48.30 3->4 Waited 1.00s
    20:09:47.19 2->3 Set Reset High
    20:09:47.08 1->2 Power On
    20:09:46.97 0->1 Waited 5.00s
    Search Strings
    PASS : U-Boot
    PASS : cut here
    PASS : rcu: INFO: rcu_preempt detected
    PASS : I/O error
    PASS : login:
    PASS : FAILURE
    0 : OAK ERROR
    0 : UART ERROR
    3 : USB hub found
    0 : xception stack
    PASS : hwclock
    Terminal
    I/TC:
    DRAM:  1 GiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Serial#: 15313467
    Net:
    Scanning mmc 0:1...
    70051 bytes read in 11 ms (6.1 MiB/s)
    560 bytes read in 10 ms (54.7 KiB/s)
    8305029 bytes read in 69 ms (114.8 MiB/s)
    Starting kernel ...
    [    0.008606] Console: colour dummy device 80x25
    [    0.017857] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.028555] pid_max: default: 32768 minimum: 301
    [    0.033332] LSM: Security Framework initializing
    [    0.038201] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
    [    0.045790] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
    [    0.055742] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.063228] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.069538] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.076946] cblist_init_generic: Setting shift to 1 and lim to 1.
    [    0.083343] rcu: Hierarchical SRCU implementation.
    [    0.088260] rcu: 	Max phase no-delay instances is 1000.
    [    0.094374] Platform MSI: msi-controller@1820000 domain created
    [    0.100826] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.110282] EFI services will not be available.
    [    0.115251] smp: Bringing up secondary CPUs ...
    [    0.160037] Detected VIPT I-cache on CPU1
    [    0.160169] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.160189] GICv3: CPU1: using allocated LPI pending table @0x0000000080050000
    [    0.160254] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.160380] smp: Brought up 1 node, 2 CPUs
    [    0.189795] SMP: Total of 2 processors activated.
    [    0.194615] CPU features: detected: 32-bit EL0 Support
    [    0.199894] CPU features: detected: CRC32 instructions
    [    0.205211] CPU: All CPU(s) started at EL2
    [    0.209404] alternatives: applying system-wide alternatives
    [    0.216743] devtmpfs: initialized
    [    0.229707] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.239767] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.252581] pinctrl core: initialized pinctrl subsystem
    [    0.258802] DMI not present or invalid.
    [    0.263460] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.270740] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
    [    0.278091] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.286103] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.294310] audit: initializing netlink subsys (disabled)
    [    0.300130] audit: type=2000 audit(0.176:1): state=initialized audit_enabled=0 res=1
    [    0.300714] thermal_sys: Registered thermal governor 'step_wise'
    [    0.308071] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.314415] cpuidle: using governor menu
    [    0.325333] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.332347] ASID allocator initialised with 65536 entries
    [    0.351172] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/dsi@e
    [    0.361429] platform connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.373294] KASLR disabled due to lack of seed
    [    0.384286] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.391284] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.397702] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.404649] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.411063] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.418010] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.424424] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.431370] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.439491] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.449600] iommu: Default domain type: Translated
    [    0.454626] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.461349] SCSI subsystem initialized
    [    0.465592] usbcore: registered new interface driver usbfs
    [    0.471253] usbcore: registered new interface driver hub
    [    0.476717] usbcore: registered new device driver usb
    [    0.482454] pps_core: LinuxPPS API ver. 1 registered
    [    0.487545] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.496905] PTP clock support registered
    [    0.501068] EDAC MC: Ver: 3.0.0
    [    0.505436] FPGA manager framework
    [    0.509042] Advanced Linux Sound Architecture Driver Initialized.
    [    0.516330] clocksource: Switched to clocksource arch_sys_counter
    [    0.522883] VFS: Disk quotas dquot_6.6.0
    [    0.526952] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.540084] NET: Registered PF_INET protocol family
    [    0.545371] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.554090] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
    [    0.562743] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.570690] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.578677] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
    [    0.586416] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.593120] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.599956] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [    0.607385] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.613744] RPC: Registered named UNIX socket transport module.
    [    0.619848] RPC: Registered udp transport module.
    [    0.624665] RPC: Registered tcp transport module.
    [    0.629480] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.636081] NET: Registered PF_XDP protocol family
    [    0.641004] PCI: CLS 0 bytes, default 64
    [    0.645724] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.656051] Initialise system trusted keyrings
    [    0.660924] workingset: timestamp_bits=46 max_order=18 bucket_order=0
    [    0.671958] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.678686] NFS: Registering the id_resolver key type
    [    0.683928] Key type id_resolver registered
    [    0.688212] Key type id_legacy registered
    [    0.692384] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.699249] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.741192] Key type asymmetric registered
    [    0.745398] Asymmetric key parser 'x509' registered
    [    0.750452] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.758251] io scheduler mq-deadline registered
    [    0.762898] io scheduler kyber registered
    [    0.771118] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.778342] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.791893] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
    [    0.809321] brd: module loaded
    [    0.817469] loop: module loaded
    [    0.825433] tun: Universal TUN/TAP device driver, 1.6
    [    0.831523] VFIO - User Level meta-driver version: 0.3
    [    0.838221] usbcore: registered new interface driver usb-storage
    [    0.844496] usbcore: registered new device driver onboard-usb-hub
    [    0.851730] i2c_dev: i2c /dev entries driver
    [    0.858516] sdhci: Secure Digital Host Controller Interface driver
    [    0.864909] sdhci: Copyright(c) Pierre Ossman
    [    0.869636] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.876090] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.882455] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.889461] usbcore: registered new interface driver usbhid
    [    0.895176] usbhid: USB HID core driver
    [    0.900230] optee: probing for conduit method.
    [    0.904850] optee: revision 4.1 (012cdca4)
    [    0.921491] optee: dynamic shared memory is enabled
    [    0.930966] optee: initialized driver
    [    0.936948] Initializing XFRM netlink socket
    [    0.941402] NET: Registered PF_PACKET protocol family
    [    0.946662] Key type dns_resolver registered
    [    0.951517] registered taskstats version 1
    [    0.955752] Loading compiled-in X.509 certificates
    [    0.974037] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)')
    [    2.620910] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=81, clk=20, ret=-19
    [    3.177062] omap_i2c 4900000.i2c: bus 3 rev0.12 at 100 kHz
    [    3.187268] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/dsi@e
    [    3.196428] i2c 0-000e: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/hdmi@48
    [    3.204550] i2c 0-000e: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    3.212538] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
    [    3.252804] input: tps65219-pwrbutton as /devices/platform/bus@f0000/20000000.i2c/i2c-0/0-0030/tps65219-pwrbutton.2.auto/input/input0
    [    3.267127] rtc-ds1307 0-0032: oscillator failed, set time!
    [    3.273048] rtc-ds1307 0-0032: registered as rtc0
    [    3.278015] rtc-ds1307 0-0032: hctosys: unable to read the hardware clock
    [    3.287209] at24 0-0050: supply vcc not found, using dummy regulator
    [    3.294169] at24 0-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
    [    3.301109] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    3.312030] i2c 0-000e: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/hdmi@48
    [    3.320287] platform hdmi-connector: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/hdmi@48
    [    3.329680] i2c 1-0048: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/dsi@e
    [    3.337664] i2c 1-0048: Fixed dependency cycle(s) with /hdmi-connector
    [    3.345067] pca953x 1-0021: supply vcc not found, using dummy regulator
    [    3.351987] pca953x 1-0021: using no AI
    [    3.376473] pca953x 1-0021: failed writing register
    [    3.381685] pca953x: probe of 1-0021 failed with error -121
    [    3.387970] at24 1-0057: supply vcc not found, using dummy regulator
    [    3.395184] at24 1-0057: 256 byte 24c02 EEPROM, writable, 16 bytes/write
    [    3.402118] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    3.412835] omap_i2c 20020000.i2c: bus 2 rev0.12 at 100 kHz
    [    3.422986] omap_i2c 20030000.i2c: bus 4 rev0.12 at 100 kHz
    [    3.438156] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    3.455671] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    3.483223] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    3.572615] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    3.608311] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    3.619527] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    3.794302] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    3.808249] 4a00000.serial: ttyS3 at MMIO 0x4a00000 (irq = 291, base_baud = 3000000) is a 8250
    [    3.821806] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 292, base_baud = 3000000) is a 8250
    [    3.830735] printk: console [ttyS2] enabled
    [    3.839201] printk: bootconsole [ns16550a0] disabled
    [    3.853835] 2810000.serial: ttyS0 at MMIO 0x2810000 (irq = 293, base_baud = 3000000) is a 8250
    [    3.866713] omap8250 2850000.serial: PM domain pd:156 will not be powered off
    [    3.874178] 2850000.serial: ttyS4 at MMIO 0x2850000 (irq = 294, base_baud = 3000000) is a 8250
    [    3.882926] serial serial0: tty port ttyS4 registered
    [    3.904450] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    3.948341] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    3.957199] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    3.970132] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    3.977273] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    3.990905] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
    [    4.143495] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    4.324835] platform connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    4.334456] platform 31000000.usb: Fixed dependency cycle(s) with /connector
    [    4.490959] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
    [    4.496607] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
    [    4.504418] xhci-hcd xhci-hcd.3.auto: USB3 root hub has no ports
    [    4.510431] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020010010
    [    4.519890] xhci-hcd xhci-hcd.3.auto: irq 299, io mem 0x31100000
    [    4.526781] hub 1-0:1.0: USB hub found
    [    4.530585] hub 1-0:1.0: 1 port detected
    [    4.788398] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    4.851848] gpio-488 (PCIE_1_RESET#): hogged as output/low
    [    4.878610] mmc0: CQHCI version 5.10
    [    4.924788] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    4.984800] mmc0: new HS200 MMC card at address 0001
    [    4.990937] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
    [    4.998236]  mmcblk0: p1 p2
    [    5.002205] mmcblk0boot0: mmc0:0001 Q2J55L 16.0 MiB
    [    5.007879] hub 1-1:1.0: USB hub found
    [    5.009257] mmcblk0boot1: mmc0:0001 Q2J55L 16.0 MiB
    [    5.016675] hub 1-1:1.0: 4 ports detected
    [    5.018204] mmcblk0rpmb: mmc0:0001 Q2J55L 4.00 MiB, chardev (241:0)
    [    5.198415] reg-fixed-voltage regulator-force-sleep-moci: nonexclusive access to GPIO for regulator-force-sleep-moci
    [    5.356364] usb 1-1.4: new high-speed USB device number 3 using xhci-hcd
    [    5.519277] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    5.564457] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    5.580803] mdio_bus 8000f00.mdio: MDIO device at address 7 is missing.
    [    5.587468] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    5.602205] usb 1-1.4: USB disconnect, device number 3
    [    5.641870] sdhci-am654 fa00000.mmc: Got CD GPIO
    [    5.645585] sdhci-am654 fa20000.mmc: allocated mmc-pwrseq
    [    5.662221] mmc1: CQHCI version 5.10
    [    5.669029] mmc2: CQHCI version 5.10
    [    5.678493] hub 1-1:1.0: USB hub found
    [    5.682414] hub 1-1:1.0: 4 ports detected
    [    5.711113] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
    [    5.719036] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    5.764962] mmc2: new ultra high speed DDR50 SDIO card at address 0001
    [    5.784371] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
    [    5.798722] input: gpio-keys as /devices/platform/gpio-keys/input/input1
    [    5.924382] usb 1-1.4: new high-speed USB device number 4 using xhci-hcd
    [    6.057230] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=81, clk=20, ret=-19
    [    6.360388] ALSA device list:
    [    6.363394]   No soundcards found.
    [    6.375283] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [    6.382700] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [    6.995165] EXT4-fs (mmcblk0p2): recovery complete
    [    7.001944] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [    7.010734] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    7.021820] devtmpfs: mounted
    [    7.026971] Freeing unused kernel memory: 2304K
    [    7.031706] Run /sbin/init as init process
    [    7.176479] systemd[1]: System time before build time, advancing clock.
    [    7.224686] NET: Registered PF_INET6 protocol family
    [    7.231272] Segment Routing with IPv6
    [    7.235148] In-situ OAM (IOAM) with IPv6
    [    7.265957] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
    [    7.298071] systemd[1]: Detected architecture arm64.
    [    7.357347] systemd[1]: Hostname set to <verdin-am62-15313467>.
    [    7.847954] systemd[1]: Queued start job for default target Graphical Interface.
    [    7.905361] systemd[1]: Created slice Slice /system/getty.
    [    7.930970] systemd[1]: Created slice Slice /system/modprobe.
    [    7.954716] systemd[1]: Created slice Slice /system/serial-getty.
    [    7.978152] systemd[1]: Created slice User and Session Slice.
    [    8.000964] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    8.024889] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    8.049120] systemd[1]: Reached target Host and Network Name Lookups.
    [    8.072597] systemd[1]: Reached target Path Units.
    [    8.088764] systemd[1]: Reached target Remote File Systems.
    [    8.108589] systemd[1]: Reached target Slice Units.
    [    8.124743] systemd[1]: Reached target Swaps.
    [    8.201334] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    8.225043] systemd[1]: Reached target RPC Port Mapper.
    [    8.250347] systemd[1]: Listening on Syslog Socket.
    [    8.265617] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    8.290564] systemd[1]: Listening on Journal Audit Socket.
    [    8.314986] systemd[1]: Listening on Journal Socket (/dev/log).
    [    8.338063] systemd[1]: Listening on Journal Socket.
    [    8.354626] systemd[1]: Listening on Network Service Netlink Socket.
    [    8.378314] systemd[1]: Listening on udev Control Socket.
    [    8.401799] systemd[1]: Listening on udev Kernel Socket.
    [    8.427120] systemd[1]: Listening on User Database Manager Socket.
    [    8.481020] systemd[1]: Mounting Huge Pages File System...
    [    8.504636] systemd[1]: Mounting POSIX Message Queue File System...
    [    8.553051] systemd[1]: Mounting Kernel Debug File System...
    [    8.577223] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
    [    8.597301] systemd[1]: Mounting Temporary Directory /tmp...
    [    8.649711] systemd[1]: Starting Create List of Static Device Nodes...
    [    8.686532] systemd[1]: Starting Load Kernel Module configfs...
    [    8.733638] systemd[1]: Starting Load Kernel Module drm...
    [    8.757935] systemd[1]: Starting Load Kernel Module fuse...
    [    8.783777] fuse: init (API version 7.37)
    [    8.791522] systemd[1]: Starting RPC Bind...
    [    8.845588] systemd[1]: Starting File System Check on Root Device...
    [    8.880594] systemd[1]: Starting Journal Service...
    [    8.910112] systemd[1]: Starting Load Kernel Modules...
    [    8.946868] systemd[1]: Starting Generate network units from Kernel command line...
    [    8.970003] systemd[1]: Starting Coldplug All udev Devices...
    [    8.995543] systemd[1]: Started RPC Bind.
    [    9.011781] systemd[1]: Mounted Huge Pages File System.
    [    9.033679] systemd[1]: Mounted POSIX Message Queue File System.
    [    9.061463] systemd[1]: Mounted Kernel Debug File System.
    [    9.085525] systemd[1]: Mounted Temporary Directory /tmp.
    [    9.110767] systemd[1]: Finished Create List of Static Device Nodes.
    [    9.137789] systemd[1]: Started Journal Service.
    [  OK  ] Finished Apply Kernel Variables[    9.460923] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    [    9.546038] systemd-journald[168]: Received client request to flush runtime journal.
    [    9.697824] audit: type=1334 audit(1651167747.520:2): prog-id=5 op=LOAD
    [    9.709923] audit: type=1334 audit(1651167747.528:3): prog-id=6 op=LOAD
    [   10.543926] systemd-journald[168]: Oldest entry in /run/log/journal/1495eaee79b84a7fa9584d8b71d7811b/system.journal is older than the configured file retention duration (1month), suggesting rotation.
    [  OK  ] Started Network Time Synchronization.
    [   10.580201] systemd-journald[168]: /run/log/journal/1495eaee79b84a7fa9584d8b71d7811b/system.journal: Journal header limits reached or header out-of-date, rotating.
    [   10.781699] CAN device driver interface
    [   10.828384] random: crng init done
    [   10.885360] lm75 0-0048: supply vs not found, using dummy regulator
    [   10.937117] m_can_platform 4e08000.can: m_can device registered (irq=0, version=32)
    [   10.945638] nau8822 1-001a: Failed to issue reset: -121
    [   10.954501] hwmon hwmon1: temp1_input not attached to any thermal zone
    [   10.961503] nau8822: probe of 1-001a failed with error -121
    [   10.961570] ina2xx 1-0040: error configuring the device: -121
    [   10.967221] lm75 0-0048: hwmon1: sensor 'tmp1075'
    [   10.979583] lm75 1-004f: supply vs not found, using dummy regulator
    [   11.031536] hwmon hwmon2: temp1_input not attached to any thermal zone
    [   11.038198] lm75 1-004f: hwmon2: sensor 'tmp75c'
    [   11.200260] Bluetooth: Core ver 2.22
    [   11.217574] NET: Registered PF_BLUETOOTH protocol family
    [   11.228572] Bluetooth: HCI device and connection manager initialized
    [   11.235830] Bluetooth: HCI socket layer initialized
    [   11.246143] Bluetooth: L2CAP socket layer initialized
    [   11.259265] Bluetooth: SCO socket layer initialized
    [   11.336198] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   11.377589] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   11.386777] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [   11.856835] mwifiex_sdio mmc2:0001:1: info: FW download over, size 578116 bytes
    [   12.016365] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   12.016365] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
    [   12.016416] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.027242] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.112346] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_recalc_rate+0x48/0xb0)
    [   12.122171] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.128366] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=190, clk=0, ret=-110
    [   12.144364] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   12.144363] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   12.144405] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.155176] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   12.169032] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: k3_ringacc_ring_cfg_sci+0x94/0x100)
    [   12.172155] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.184396] ti-sci 44043000.system-controller: RM_RA:Mbox config send fail -110
    [   12.193142] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.202080] ti-udma 485c0000.dma-controller: TISCI config ring fail (-110) ring_idx 142
    [   12.227554] ti-udma 485c0000.dma-controller: get channel fail in udma_of_xlate.
    [   12.236802] saul-crypto 40900000.crypto: error -EINVAL: Unable to request rx1 DMA channel
    [   12.246421] saul-crypto: probe of 40900000.crypto failed with error -22
    [   12.374997] pvrsrvkm: loading out-of-tree module taints kernel.
    [   12.432751] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: k3_m4_rproc_probe+0x1a4/0x4fc [ti_k3_m4_remoteproc])
    [   12.444720] ti-sci 44043000.system-controller: Mbox send fail -110
    [   12.451150] k3-m4-rproc 5000000.m4fss: ti-sci processor request failed: -110
    [   12.459765] k3-m4-rproc 5000000.m4fss: ti_sci_proc_request failed, ret = -110
    [   12.468756] remoteproc remoteproc0: releasing 5000000.m4fss
    [   12.474551] k3-m4-rproc: probe of 5000000.m4fss failed with error -110
    [   12.592464] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   12.605299] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.040420] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
    [   13.053358] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   13.064660] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.072411] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   13.083499] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
    [   13.093969] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.098090] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.105259] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.123068] lt8912 1-0048: supply vccmipirx not found, using dummy regulator
    [   13.135720] lt8912 1-0048: supply vccsysclk not found, using dummy regulator
    [   13.150361] lt8912 1-0048: supply vcclvdstx not found, using dummy regulator
    [   13.163940] lt8912 1-0048: supply vcchdmitx not found, using dummy regulator
    [   13.172808] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_set_parent+0x34/0x40)
    [   13.183036] lt8912 1-0048: supply vcclvdspll not found, using dummy regulator
    [   13.193608] lt8912 1-0048: supply vcchdmipll not found, using dummy regulator
    [   13.204472] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
    [   13.216652] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.231192] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.300477] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   13.321997] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.410692] mwifiex_sdio mmc2:0001:1: WLAN FW is active
    [   13.424489] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   13.455614] ti-sci 44043000.system-controller: Mbox send fail -110
    [   13.456618] mwifiex_sdio mmc2:0001:1: event: unknown event id: 0x81
    [   13.475955] mwifiex_sdio mmc2:0001:1: Unknown api_id: 5
    [   13.486813] mwifiex_sdio mmc2:0001:1: Unknown GET_HW_SPEC TLV type: 0x23e
    [   13.530717] mwifiex_sdio mmc2:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.92.21.p119)
    [   13.541880] mwifiex_sdio mmc2:0001:1: driver_version = mwifiex 1.0 (16.92.21.p119)
    [   14.224395] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   14.240436] ti-sci 44043000.system-controller: Mbox send fail -110
    [   14.256498] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_recalc_rate+0x48/0xb0)
    [   14.277465] ti-sci 44043000.system-controller: Mbox send fail -110
    [   14.286502] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=190, clk=0, ret=-110
    [   14.288463] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
    [   14.298254] clk: failed to reparent clk:190:0 to clk:190:2: -110
    [   14.319761] ti-sci 44043000.system-controller: Mbox send fail -110
    [*     ] A start job is running for Wait for…ice Initialization (2s / 2min 57s)
    M
    [  OK  ] Found device /dev/mmcblk0p1.
    [  OK  ] Finished File System Check on /dev/mmcblk0p1.
             Mounting /media/BOOT-mmcblk0p1...
    [  OK  ] Mounted /media/BOOT-mmcblk0p1.
             Mounting /boot...
    [  OK  ] Mounted /boot.
    [   15.280350] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   15.291241] ti-sci 44043000.system-controller: Mbox send fail -110
    [   15.312384] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_determine_rate+0x68/0xf0)
    [   15.322459] ti-sci 44043000.system-controller: Mbox send fail -110
    [   15.328652] ti-sci-clk 44043000.system-controller:clock-controller: determine-rate failed for dev=135, clk=0, ret=-110
    [   15.376346] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
    [   15.386316] ti-sci 44043000.system-controller: Mbox send fail -110
    [   16.304347] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   16.315208] ti-sci 44043000.system-controller: Mbox send fail -110
    [   16.368359] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_determine_rate+0x68/0xf0)
    [   16.378430] ti-sci 44043000.system-controller: Mbox send fail -110
    [   16.384623] ti-sci-clk 44043000.system-controller:clock-controller: determine-rate failed for dev=135, clk=0, ret=-110
    [   17.328345] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   17.339198] ti-sci 44043000.system-controller: Mbox send fail -110
    [   17.424354] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_determine_rate+0x68/0xf0)
    [   17.434434] ti-sci 44043000.system-controller: Mbox send fail -110
    [   17.440627] ti-sci-clk 44043000.system-controller:clock-controller: determine-rate failed for dev=135, clk=0, ret=-110
    [   17.451360] cpu cpu0: _opp_config_clk_single: failed to set clock rate: -22
    [   17.458337] cpufreq: __target_index: Failed to change cpu frequency: -22
    [**    ] (1 of 2) A start job is running for…ice Initialization (2s / 2min 54s)
    M
    [***   ] (1 of 2) A start job is running for…ice Initialization (3s / 2min 54s)
    [   18.352346] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   18.363211] ti-sci 44043000.system-controller: Mbox send fail -110
    [   18.480376] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_clock+0x28/0x34)
    [   18.480420] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   18.490268] ti-sci 44043000.system-controller: Mbox send fail -110
    [   18.501035] ti-sci 44043000.system-controller: Mbox send fail -110
    M
    [ ***  ] (2 of 2) A start job is running for…e RF Kill Switch Status (3s / 30s)
    M
    [  *** ] (2 of 2) A start job is running for…e RF Kill Switch Status (4s / 30s)
    [   19.376350] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
    [   19.387216] ti-sci 44043000.system-controller: Mbox send fail -110
    [   19.536366] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_determine_rate+0x68/0xf0)
    [   19.546440] ti-sci 44043000.system-controller: Mbox send fail -110
    [   19.552634] ti-sci-clk 44043000.system-controller:clock-controller: determine-rate failed for dev=135, clk=0, ret=-110
    [   19.563413] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_put_device+0x18/0x24)
    [   19.573381] ti-sci 44043000.system-controller: Mbox send fail -110
    M
    [  OK  ] Started Load/Save RF Kill Switch Status.
    [  OK  ] Finished Wait for udev To Complete Device Initialization.
    [   19.748698] audit: type=1334 audit(1721924256.892:4): prog-id=7 op=LOAD
    [   19.756256] audit: type=1334 audit(1721924256.896:5): prog-id=8 op=LOAD
    [  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on GPS (Global P…ioning System) Daemon Sockets.
             Starting Weston socket...
    [  OK  ] Listening on Weston socket.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
             Starting Bluetooth service...
    [  OK  ] Started Kernel Logging Service.
    [  OK  ] Started System Logging Service.
             Starting D-Bus System Message Bus...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
             Starting Telephony service...
    [   20.286103] audit: type=1334 audit(1721924257.428:6): prog-id=9 op=LOAD
    [   20.302962] audit: type=1334 audit(1721924257.444:7): prog-id=10 op=LOAD
             Starting User Login Management...
    [  OK  ] Started Timestamping service.
    [   20.400438] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: ti_sci_cmd_get_device_exclusive+0x18/0x2c)
             Starting Load default USB gadget schema g1.sch[   20.427053] ti-sci 44043000.system-controller: Mbox send fail -110
    ema...
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [   20.517408] using random self ethernet address
    [   20.522482] using random host ethernet address
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [   20.558655] Bluetooth: MGMT ver 1.22
    [  OK  ] Reached target Preparation for Netw[   20.587279] NET: Registered PF_ALG protocol family
    ork.
    [   20.592411] ti-sci 44043000.system-controller: Mbox timedout in resp(caller: sci_clk_determine_rate+0x68/0xf0)
    [   20.608087] ti-sci 44043000.system-controller: Mbox send fail -110
    [   20.614445] ti-sci-clk 44043000.system-controller:clock-controller: determine-rate failed for dev=135, clk=0, ret=-110
             Starting Connection service...
             Starting Network Configuration...
    [  OK  ] Started Telephony service.
    [  OK  ] Started Bluetooth service.
    [   20.783720] audit: type=1334 audit(1721924257.924:8): prog-id=11 op=LOAD
             Starting BlueALSA service...
    [   20.815549] audit: type=1334 audit(1721924257.932:9): prog-id=12 op=LOAD
    [   20.824046] PVR_K:  9: Device: fd00000.gpu
    [   20.829662] Internal error: synchronous external abort: 0000000096000010 [#1] PREEMPT SMP
    [   20.833297] ti-sci 44043000.system-controller: Message for 2 is not expected!
    [   20.837852] Modules linked in: af_alg usb_f_ncm u_ether crct10dif_ce snd_soc_simple_card snd_soc_simple_card_utils btnxpuart display_connector pvrsrvkm(O) ti_k3_r5_remoteproc virtio_rpmsg_bus rpmsg_ns rtc_ti_k3 mwifiex_sdio mwifiex ti_k3_m4_remoteproc ti_k3_common cfg80211 bluetooth ecdh_generic ecc rfkill tidss pruss sa2ul mcrc
    [   20.845089] ti-sci 44043000.system-controller: Message for 3 is not expected!
    [   20.845092]  snd_soc_davinci_mcasp
    [   20.865425] ti-sci 44043000.system-controller: Message for 4 is not expected!
    [   20.874137]  snd_soc_ti_udma snd_soc_ti_edma drm_dma_helper snd_soc_ti_sdma
    [   20.890639] ti-sci 44043000.system-controller: Message for 5 is not expected!
    [   20.891790]  tc358768
    [   20.898745] ti-sci 44043000.system-controller: Message for 1 is not expected!
    [   20.905843]  lontium_lt8912b ina2xx drm_kms_helper snd_soc_nau8822 syscopyarea sysfillrect sysimgblt lm75 fb_sys_fops m_can_platform m_can can_dev pwm_tiehrpwm spi_omap2_mcspi libcomposite fuse drm drm_panel_orientation_quirks ipv6
    [   20.935797] CPU: 1 PID: 9 Comm: kworker/u4:0 Tainted: G           O       6.1.83-6.7.0+git.0a32d33d5fb7 #1
    [   20.945440] Hardware name: Toradex Verdin AM62 WB on Verdin Development Board (DT)
    [   20.953002] Workqueue: events_unbound deferred_probe_work_func
    [   20.958845] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [   20.965800] pc : _RGXReadBVNCFromReg.isra.0+0x1c/0x140 [pvrsrvkm]
    [   20.972149] lr : RGXBvncInitialiseConfiguration+0x294/0x9b0 [pvrsrvkm]
    [   20.978797] sp : ffff8000094fb9a0
    [   20.982104] x29: ffff8000094fb9d0 x28: 0000000000000000 x27: 0000000000000000
    [   20.989237] x26: ffff8000094fb9a8 x25: ffff00000415a000 x24: ffff000005a9d1b8
    [   20.996368] x23: 0000000000000000 x22: ffff800001093000 x21: ffff000005a9d008
    [   21.003499] x20: ffff80000103c688 x19: 0000000000000000 x18: 000000000003420c
    [   21.010630] x17: 000000ffc0000000 x16: ffff800000fef670 x15: 0000000000000000
    [   21.017761] x14: 0000000000000001 x13: 0000000000000002 x12: ffff800008000000
    [   21.024891] x11: ffff000005a9d008 x10: 0000000000000020 x9 : 0000000000000000
    [   21.032021] x8 : 0000000000000024 x7 : ffff800009f20024 x6 : ffff800009f20000
    [   21.039152] x5 : ffff8000094fb9b0 x4 : ffff8000094fb9ac x3 : ffff8000094fb9a8
    [   21.046282] x2 : ffff8000094fb9a4 x1 : 0000000000000000 x0 : ffff000005a9d008
    [   21.053413] Call trace:
    [   21.055856]  _RGXReadBVNCFromReg.isra.0+0x1c/0x140 [pvrsrvkm]
    [   21.061724]  RGXRegisterDevice+0x3f0/0xc50 [pvrsrvkm]
    [   21.066896]  PVRSRVCommonDeviceCreate+0x260/0x750 [pvrsrvkm]
    [   21.072674]  pvr_drm_load+0x98/0x1b0 [pvrsrvkm]
    [   21.077323]  pvr_probe+0x58/0xbc [pvrsrvkm]
    [   21.081627]  platform_probe+0x68/0xe0
    [   21.085287]  really_probe+0xc0/0x3dc
    [   21.088860]  __driver_probe_device+0x7c/0x160
    [   21.093215]  driver_probe_device+0x3c/0x110
    [   21.097393]  __device_attach_driver+0xbc/0x160
    [   21.101832]  bus_for_each_drv+0x7c/0xdc
    [   21.105663]  __device_attach+0xac/0x1f0
    [   21.109495]  device_initial_probe+0x14/0x20
    [   21.113673]  bus_probe_device+0x9c/0xa4
    [   21.117504]  deferred_probe_work_func+0x9c/0xf0
    [   21.122030]  process_one_work+0x1d0/0x320
    [   21.126040]  worker_thread+0x14c/0x444
    [   21.129787]  kthread+0x10c/0x110
    [   21.133013]  ret_from_fork+0x10/0x20
    [   21.136590] Code: d503233f 1100812a 91001148 8b0800c7 (b94000e7)
    [   21.142679] ---[ end trace 0000000000000000 ]---
    [   21.242893] Bluetooth: RFCOMM socket layer initialized
    [   21.248258] audit: type=1334 audit(1721924258.388:10): prog-id=13 op=LOAD
    [   21.257502] audit: type=1334 audit(1721924258.388:11): prog-id=14 op=LOAD
             Starting Hostname Service...
    [   21.295039] Bluetooth: RFCOMM ver 1.11
    [   21.379454] usb0: HOST MAC c2:1e:cd:2d:c4:e0
    [   21.389000] usb0: MAC e2:4e:12:48:22:c3
    [  OK  ] Finished Load default USB gadget schema g1.schema.
    [  OK  ] Started User Login Management.
    [  OK  ] Reached target Hardware activated USB gadget.
    [  OK  ] Started Connection service.
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Network Configuration.
    [  OK  ] Reached target Network.
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting Permit User Sessions...
             Starting WPA supplicant...
    [  OK  ] Finished Permit User Sessions.
    [   22.052809] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=359)
    [  OK  ] Started Getty on tty1.
    [   22.095236] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
    [  OK  ] Reached target Multi-User System.
             Starting Weston, a Wayland…ositor, as a system service...
    [  OK  ] Started WPA supplicant.
    [  OK  ] Started BlueALSA service.
    [  OK  ] Reached target Bluetooth Support.
    [   22.270539] audit: type=1334 audit(1721924259.412:12): prog-id=15 op=LOAD
    [   22.288183] audit: type=1334 audit(1721924259.424:13): prog-id=16 op=LOAD
             Starting User Database Manager...
    [  OK  ] Started Hostname Service.
    [  OK  ] Started User Database Manager.
    [  OK  ] Created slice User Slice of UID 0.
             Starting User Runtime Directory /run/user/0...
    [  OK  ] Finished User Runtime Directory /run/user/0.
             Starting User Manager for UID 0...
    [  OK  ] Started User Manager for UID 0.
    [  OK  ] Started Session c1 of User root.
    [FAILED] Failed to start Weston, a …mpositor, as a system service.
    See 'systemctl status weston.service' for details.
    [DEPEND] Dependency failed for Start a wayland application.
    [  OK  ] Reached target Graphical Interface.
             Starting Record Runlevel Change in UTMP...
    [  OK  ] Finished Record Runlevel Change in UTMP.
    TDX Wayland with XWayland 6.7.0+build.13 (kirkstone) verdin-am62-15313467 -
    Verdin-AM62_Reference-Multimedia-Image
    verdin-am62-15313467 login: [   25.514252] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   25.520573] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   25.561114] 8021q: 802.1Q VLAN Support v1.8
    [   25.565807] 8021q: adding VLAN 0 to HW filter on device eth0
    I forgot to set the timestamp, I hope it's still good enough without it, otherwise I can redo the test.
  • Hi Franz,
    Thanks for running the test. I am still discussing the test result with our dev team, but I think the kernel Mbox timeout message is due the the timeout value defined in kernel is short, since now this DM firmware removes the timeout regulation.
    Can you please apply the following kernel patch to change the kernel Mbox timeout from 10 seconds to 50 seconds to see if the kernel Mbox message go away and MCAN failure issue doesn't not happen in your stress test?
    diff --git a/drivers/firmware/ti_sci.c b/drivers/firmware/ti_sci.c
    index ae1ef599df71..c7a3be484d37 100644
    --- a/drivers/firmware/ti_sci.c
    +++ b/drivers/firmware/ti_sci.c
    @@ -3725,7 +3725,7 @@ static const struct ti_sci_desc ti_sci_pmmc_k2g_desc = {
     static const struct ti_sci_desc ti_sci_pmmc_am654_desc = {
            .default_host_id = 12,
            /* Conservative duration */
    -       .max_rx_timeout_ms = 10000,
    +       .max_rx_timeout_ms = 50000,
            /* Limited by MBOX_TX_QUEUE_LEN. K2G can handle upto 128 messages! */
            .max_msgs = 20,
            .max_msg_size = 60,
  • Hi Bin,
    I applied the changes but the Mbox and MCAN failure are still present.
    24-07-29_19-44-20-Fail.txt
    Here the wakeup uart log (now with timestamp again).
    canNewFwMBox.txt
    Franz
  • Hi Bin,
    Have you had a chance to discuss the latest results with your dev team?
    Do you need any other tests with other changes to get more data to proceed on this issue?
    Franz
  • Hi Franz,
    Bin is Out of Office today and can provide an update as soon as he can.
  • Hi Franz
    We constructed a simpler test case that runs in CCS, more bare metal , running on one of the M4s , we have run long iterations of this on EVM in the temp chamber/
    The test is essentially
    -Will toggle LPSC_MAIN_MCANSS_0 between PSC_DISABLE and PS_ENABLE states indefinitely
    -Will count the number of transitions (DISABLE->ENABLE) and print every 64K transitions the transition number
    -Any error will stop loop and produce error message
    This test does not fail on the EVM either, (similar to your and our previous observations with Linux tests)
    Would you be willing to try this on your board in your test environment, just to continue to see if the failure is somehow board dependent
  • Hey Franz,
    My name is Andrew, and I am here to help you get our attached bare metal test case up and running in CCS.  To get started, please download the latest version of CCS (12.71 or 12.8) from the following link: https://www.ti.com/tool/download/CCSTUDIO. We recommend using the on-demand (web) installer so that only the required components are downloaded & setup.  Select the default for all installation prompts until you reach the "Select Components Page"; on this page select only the "Sitara Am3x, AM4x, AM5x and AM6x MPUs" option.
    Select Components (Sitara MPUs)
    Continue installation process with all other page defaults (input your https proxy information when prompted if installing within a firewall/vpn).  When this is complete, reboot your computer before launching CCS.  From here, please follow these steps:
    1. After installing CCS, navigate to the below directory in file explorer:
    -C:\ti\ccs1271\ccs\ccs_base\emulation\gel\AM62x
    2. Edit the "AM62x.gel" file in directory #1 using any text editor:
        -Comment out lines 72-74 & save the file
            //Set_PSC_All_On();
            //GEL_TextOut("\n");
            //GEL_TextOut("*****Use R5 or A53 GELs to configure DDR\n");
    3. Launch CCS and create a new AM62x target configuration (named AM62x_MCAN.ccxml in this guide): <file->new->Target Configuration File>
        -Connection: Texas Instruments XDS110 USB Debug Probe
        -Board or Device: AM62
        -<click "Advanced" tab from bottom menu, listed between "Basic" & "Source">
        -<click "SMS_CM4_0_TIFS_0" from core listings>
        -initialization script: point to file modified in step #2, in directory #1
        -save this target configuration
    AM62x_MCAN target config (Basic tab)
    4. Connect device/evm & Launch the target configuration
        -<view->target configurations>
        -<right click on AM62x_MCAN.ccxml -> Launch Selected Configuration>
    5. Connect to: Texas Instruments XDS110 USB Debug Probe_0/SMS_CM4_0_TIFS_0
        -Initialization script will run and setup all PLLs to OFC1 settings automatically
    6. Load attached program to core: "AM62X_MCAN_PSC_Test_TIFS.out"
        -If core immediately starts running after load, pause core and reload again
    7. Click run on this TIFS core, program will begin LPSC transitions, and start printing transaction numbers:
        -If error occurs, program will stop transitions and display error print.
    Please find attached the "AM62X_MCAN_PSC_Test_TIFS.out" file, and a copy of these instructions in "README.txt" for convenience. Do not hesitate to reach out if you encounter any difficulty with these installation steps, or the test program.
    Andrew
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/AM62X_5F00_MCAN_5F00_PSC_5F00_Test_5F00_TIFS.out
    Instructions to Run AM62x LPSC_MAIN_MCAN Toggle Test Case
    -Andrew Shutzberg
    Test Details:
    -Run on TIFS_M4 core
    Requirements:
    -Latest CCS Release (12.5 or later, 12.71 used in this guide)
    Test Setup:
    2. Edit the AM62x.gel file in directory #1:
    		//Set_PSC_All_On();
    3. Open CCS and create a new AM62x target configuration (named AM62x_MCAN.ccxml in this guide)
    4. Connect device/evm & Launch the target configuration:
    6. Load program to core: "AM62X_MCAN_PSC_Test_TIFS.out"
    7. Click run on TIFS core, program will begin LPSC transitions, and start printing transaction numbers
  • Hi Andrew,
    Thanks for the nice guide.
    I've run the test on the same module that shows the issue on Linux for 48h+ in our climate chamber.
    So more then enough time for the error to show up in normal case.
    I could not see any errors on the console output, expect for one that stopped the test due to inability to access the debug access point but I think this was more a communication error with host/debug probe rather than an error in the MCAN transition on the module.
    Thoughts on the results?
    SMS_CM4_0_TIFS_0: GEL Output: RAT has been configured
    SMS_CM4_0_TIFS_0: GEL Output: Configuring ATCM for the DM R5F
    SMS_CM4_0_TIFS_0: GEL Output: ATCM Configured.
    SMS_CM4_0_TIFS_0: GEL Output: DM R5F Halt bit set.
    SMS_CM4_0_TIFS_0: GEL Output: Configuring DM R5F bootvector
    SMS_CM4_0_TIFS_0: GEL Output: DM R5F Bootvector configured.
    SMS_CM4_0_TIFS_0: GEL Output: Programming all PLLs.
    SMS_CM4_0_TIFS_0: GEL Output: Programming Main PLL 0 (Main PLL)
    SMS_CM4_0_TIFS_0: GEL Output: Setting PLL in integer mode
    SMS_CM4_0_TIFS_0: GEL Output: Waiting for PLL Lock...
    SMS_CM4_0_TIFS_0: GEL Output: Waiting for Calibration Lock...
    SMS_CM4_0_TIFS_0: GEL Output: Cal locked
    SMS_CM4_0_TIFS_0: GEL Output: Main PLL 0 (Main PLL) Set.
    SMS_CM4_0_TIFS_0: GEL Output: Programming Main PLL 1 (Peripheral 0 PLL)
    SMS_CM4_0_TIFS_0: GEL Output: Setting PLL in fractional mode
    SMS_CM4_0_TIFS_0: GEL Output: Main PLL 1 (Peripheral 0 PLL) Set.
    SMS_CM4_0_TIFS_0: GEL Output: Programming Main PLL 2 (Peripheral 1 PLL)
    SMS_CM4_0_TIFS_0: GEL Output: Main PLL 2 (Peripheral 1 PLL) Set.
    SMS_CM4_0_TIFS_0: GEL Output: Programming Main PLL 8 (ARM0 PLL)
    SMS_CM4_0_TIFS_0: GEL Output: Main PLL 8 (ARM0 PLL) Set.
    SMS_CM4_0_TIFS_0: GEL Output: Programming Main PLL 12 (DDR PLL)
    SMS_CM4_0_TIFS_0: GEL Output: Main PLL 12 (DDR PLL) Set.
    SMS_CM4_0_TIFS_0: GEL Output: Programming Main PLL 15 (SMS PLL)
    SMS_CM4_0_TIFS_0: GEL Output: Main PLL 15 (SMS PLL) Set.
    SMS_CM4_0_TIFS_0: GEL Output: Programming Main PLL 16 (DSS0 PLL)
    SMS_CM4_0_TIFS_0: GEL Output: Main PLL 16 (DSS0 PLL) Set.
    SMS_CM4_0_TIFS_0: GEL Output: Programming Main PLL 17 (DSS1 PLL)
    SMS_CM4_0_TIFS_0: GEL Output: Main PLL 17 (DSS1 PLL) Set.
    SMS_CM4_0_TIFS_0: GEL Output: Programming MCU PLL 0 (MCU PLL)
    SMS_CM4_0_TIFS_0: GEL Output: MCU PLL 0 (MCU PLL) Set.
    SMS_CM4_0_TIFS_0: GEL Output: All PLLs programmed.
    [SMS_CM4_0_TIFS_0] AVV_TEST_START:AM62X_MCAN_PSC_Test_TIFS
    PD_NAME PD State: ON
    LPSC_NAME MD State: DISABLE
    65536
    131072
    442499072
    SMS_CM4_0_TIFS_0: Error: (Error -1170 @ 0x0) Unable to access the DAP. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 12.8.0.00189)
  • Hi Franz,
    Sorry if this has been communicated before and I forget - for the SoC clock source, does your board use an external crystal, or HCMOS oscillator (as the SK-AM62 EVM)?
  • Hi Bin Liu.
    We use an external crystal as clock source for the SoC
  • Hi Oleksiy,
    Our hardware experts want to check if the issue is related to the noise on the sine wave of the crystal. Is it possible to remove the crystal from your board and place a signal generator as the clock source to see if the CAN issue still happens?
    For your reference, the AM62x Datasheet Section 7.11.4.1.1 (MCU_OSC0 Internal Oscillator Clock Source) shows the design of using a crystal, while Section 7.11.4.1.2 (MCU_OSC0 LVCMOS Digital Clock Source) shows using a digital signal as the clock source.
    (Our hardware experts also mentioned about noise on the power supplies, but I think we can check the crystal first, then look at the power supply if the crystal design is not the cause.)
  • Hi Bin,
    Excuse the delay, I was out of office.
    We applied the suggestion and we saw no improvement, nor did it make things worse, so no impact at all.
    I don't believe that checking the power supply will give us any more valuable information. As it was said before, if the CAN driver is blacklisted, we have no problems at all. I assume that if there were some glitches in the power supply, the issues at low temperature would appear even if the specific driver isn't blacklisted.
    What about the relation of this issue to the transition timeout we could see in the collected debug traces?
    As the bare metal test performed on the M4 core only enabling/disabling the MCAN showed no issues the problem points to be in the timeout?
  • Hi Bin,
    Any updates or further ideas on this topic from your side?
    Or any answers to the points I made in my last comment?
    We have in the meantime also tested it with the 6.6.y kernel. The SYSFW version used is '10.0.8--v10.00.08 (Fiery Fox)'.
    The issue is still present.
    Franz
