AM6548: Build evn tools in uboot
Part Number: AM6548
Hi Ti,
We are using Linux SDK, and we want to build env tools for test..
I tried below command, but got some error response.
Is there any config need to modify or command is not correct?
#export PATH=$HOME/gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu/bin:$PATH
#make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- env
scripts/kconfig/conf --syncconfig Kconfig
*** Configuration file ".config" not found!
*** Please run some configurator (e.g. "make oldconfig" or
*** "make menuconfig" or "make xconfig").
scripts/kconfig/Makefile:46: recipe for target 'syncconfig' failed
make[2]: *** [syncconfig] Error 1
Makefile:539: recipe for target 'syncconfig' failed
make[1]: *** [syncconfig] Error 2
make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/uboot.release'. Stop.
Thanks.
Eric
