Hi Team,
We have a working ar1335 camera module integrated on TI-AM625 Starter Kit with processor SDK Version: 08.06.00.42. Now we have ported the camera driver to processor SDK Version: 09.02.01.10.
I have done the following changes in the dtso file and camera driver.
DTSO:
/dts-v1/;
/plugin/;
#include <dt-bindings/gpio/gpio.h>
clk_ar1335_fixed: ar1335-xclk {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <24000000>;
&main_i2c2 {
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
i2c-switch@71 {
compatible = "nxp,pca9543";
#size-cells = <0>;
reg = <0x71>;
/* CAM port */
i2c@1 {
#size-cells = <0>;
reg = <1>;
ar1335: camera@42 {
compatible = "aptina,ar1335";
reg = <0x42>;
clocks = <&clk_ar1335_fixed>;
clock-names = "xclk";
port {
csi2_cam0: endpoint {
remote-endpoint = <&csi2rx0_in_sensor>;
link-frequencies = /bits/ 64 <500000000>;
clock-lanes = <0>;
data-lanes = <1 2>;
&csi0_port0 {
status = "okay";
csi2rx0_in_sensor: endpoint {
remote-endpoint = <&csi2_cam0>;
bus-type = <4>; /* CSI2 DPHY. */
clock-lanes = <0>;
data-lanes = <1 2>;
Driver:
- static int ar1335_remove(struct i2c_client *client)
+ static void ar1335_remove(struct i2c_client *client)
The driver loaded successfully and created the video nodes. But I could get the streaming.
root@am62xx-evm:~# v4l2-ctl --list-devices
j721e-csi2rx (platform:30102000.ticsi2rx):
/dev/video0
/dev/video1
/dev/video2
/dev/video3
/dev/media0
Media controller API version 6.1.83
Media device information
driver j721e-csi2rx
model TI-CSI2RX
serial
bus info platform:30102000.ticsi2rx
hw revision 0x1
driver version 6.1.83
Device topology
- entity 1: 30102000.ticsi2rx (5 pads, 5 links, 1 route)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
[stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range]
<- "cdns_csi2rx.30101000.csi-bridge":1 [ENABLED,IMMUTABLE]
pad1: Source
-> "30102000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE]
pad2: Source
-> "30102000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE]
pad3: Source
-> "30102000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE]
pad4: Source
-> "30102000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE]
- entity 7: cdns_csi2rx.30101000.csi-bridge (5 pads, 2 links, 1 route)
device node name /dev/v4l-subdev1
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
<- "ar1335 4-0042":0 [ENABLED,IMMUTABLE]
pad1: Source
-> "30102000.ticsi2rx":0 [ENABLED,IMMUTABLE]
pad2: Source
pad3: Source
pad4: Source
- entity 13: ar1335 4-0042 (1 pad, 1 link, 0 route)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev2
pad0: Source
[stream:0 fmt:UYVY8_2X8/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:full-range]
-> "cdns_csi2rx.30101000.csi-bridge":0 [ENABLED,IMMUTABLE]
- entity 19: 30102000.ticsi2rx context 0 (1 pad, 1 link, 0 route)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "30102000.ticsi2rx":1 [ENABLED,IMMUTABLE]
- entity 25: 30102000.ticsi2rx context 1 (1 pad, 1 link, 0 route)
device node name /dev/video1
pad0: Sink
<- "30102000.ticsi2rx":2 [ENABLED,IMMUTABLE]
- entity 31: 30102000.ticsi2rx context 2 (1 pad, 1 link, 0 route)
device node name /dev/video2
pad0: Sink
<- "30102000.ticsi2rx":3 [ENABLED,IMMUTABLE]
- entity 37: 30102000.ticsi2rx context 3 (1 pad, 1 link, 0 route)
device node name /dev/video3
pad0: Sink
<- "30102000.ticsi2rx":4 [ENABLED,IMMUTABLE]
ioctl: VIDIOC_SUBDEV_ENUM_MBUS_CODE (pad=0,stream=0)
0x2006: MEDIA_BUS_FMT_UYVY8_2X8
ioctl: VIDIOC_SUBDEV_ENUM_FRAME_SIZE (pad=0,stream=0)
Size Range: 640x480 - 640x480
Size Range: 1280x720 - 1280x720
Size Range: 1920x1080 - 1920x1080
Size Range: 3840x2160 - 3840x2160
Size Range: 4096x2160 - 4096x2160
Size Range: 4192x3120 - 4192x3120
ioctl: VIDIOC_SUBDEV_ENUM_FRAME_INTERVAL (pad=0,stream=0)
Interval: 0.008s (120.000 fps)
driver j721e-csi2rx
model TI-CSI2RX
serial
hw revision 0x1
Device topology
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
pad1: Source
pad2: Source
pad3: Source
pad4: Source
routes:
0/0 -> 1/0 [ACTIVE]
pad0: Sink
pad1: Source
pad2: Source
pad3: Source
pad4: Source
pad0: Source
pad0: Sink
pad0: Sink
pad0: Sink
pad0: Sink
root@am62xx-evm:~# gst-launch-1.0 v4l2src device="/dev/video0" ! video/x-raw , width=640, height=480, ! kmssink driver-name=tidss
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
Additional debug info:
../gst-plugins-good-1.20.7/sys/v4l2/gstv4l2src.c(777): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Buffer pool activation failed
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
../gstreamer-1.20.7/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Do I need to change anything in the driver source for the latest processor SDK ?
Could you please provide some pointers to debug this issue.
Ajith Kumaresh S.
