Hi, Ti Expert
if pipeline depth is set to 1, the tidl results of each frame are correct. but the pipeline depth is changed to 2
you can also have a look at the picture above, you can see that the pipeline 0 work normally, but the pipeline 1 does not spend any time on tidl. so it seems that the pipeline 1 was not trigggered to run
the same application code can work normally in j721s2 8.5sdk 8.6sdk
Is there some issue in the j784s4 sdk 9.2?
Looking forward to your replay!
