I run vision_apps in SBL boot flow with combined_appimage. And run the demo run_app_tidl.sh,the program is stopped and cannot be executed downwards. I use the version 08_06_00_12.
Thanks for your reply. How to check the MCU2_0?
root@j7-evm:/opt/vision_apps# [MCU2_0] 17.737236 s: CIO: Init ... Done !!!
[MCU2_0] 17.737312 s: ### CPU Frequency = 1000000000 Hz
[MCU2_0] 17.737356 s: CPU is running FreeRTOS
[MCU2_0] 17.737383 s: APP: Init ... !!!
[MCU2_0] 17.737407 s: SCICLIENT: Init ... !!!
[MCU2_0] 17.737970 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[MCU2_0] 17.738020 s: SCICLIENT: DMSC FW revision 0x8
[MCU2_0] 17.738055 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_0] 17.738093 s: SCICLIENT: Init ... Done !!!
[MCU2_0] 17.738121 s: UDMA: Init ... !!!
[MCU2_0] 17.740040 s: UDMA: Init ... Done !!!
[MCU2_0] 17.740109 s: MEM: Init ... !!!
[MCU2_0] 17.740157 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!!
[MCU2_0] 17.740234 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!!
[MCU2_0] 17.740297 s: MEM: Init ... Done !!!
[MCU2_0] 17.740323 s: IPC: Init ... !!!
[MCU2_0] 17.740385 s: IPC: 6 CPUs participating in IPC !!!
[MCU2_0] 17.740433 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU2_0] 33.981801 s: IPC: HLOS is ready !!!
[MCU2_0] 33.997139 s: IPC: Init ... Done !!!
[MCU2_0] 33.997204 s: APP: Syncing with 5 CPUs ... !!!
[MCU2_0] 36.011216 s: APP: Syncing with 5 CPUs ... Done !!!
[MCU2_0] 36.011394 s: REMOTE_SERVICE: Init ... !!!
[MCU2_0] 36.013108 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_0] 36.013172 s: ETHFW: Init ... !!!
[MCU2_0] 36.016948 s: Warning: Using 6 MAC address(es) from static pool
[MCU2_0] 36.017060 s: ETHFW: Shared multicasts (software fanout):
[MCU2_0] 36.017108 s: ETHFW: Reserved multicasts:
[MCU2_0] 36.017140 s: 01:80:c2:00:00:0e
[MCU2_0] 36.017192 s: 01:1b:19:00:00:00
[MCU2_0] 36.017544 s: EnetMcm: CPSW_9G on MAIN NAVSS
[MCU2_0] 36.026899 s: Mdio_open: MDIO manual mode enabled
[MCU2_0] 36.030744 s: PHY 16 is alive
[MCU2_0] 36.030902 s: PHY 17 is alive
[MCU2_0] 36.031017 s: PHY 18 is alive
[MCU2_0] 36.031123 s: PHY 19 is alive
[MCU2_0] 36.034314 s:
[MCU2_0] ETHFW Version : 0.02.00
[MCU2_0] 36.034392 s: ETHFW Build Date: Feb 28, 2023
[MCU2_0] 36.034434 s: ETHFW Build Time: 23:37:07
[MCU2_0] 36.034465 s: ETHFW Commit SHA: 8c7326da
[MCU2_0] 36.034542 s: ETHFW: Init ... DONE !!!
[MCU2_0] 36.034578 s: ETHFW: Remove server Init ... !!!
[MCU2_0] 36.034760 s: CpswProxyServer: Virtual port configuration:
[MCU2_0] 36.034832 s: mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0
[MCU2_0] 36.034881 s: mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1
[MCU2_0] 36.034928 s: mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1
[MCU2_0] 36.034970 s: mcu_2_1 <-> MAC port 4: mcu_2_1_ethmac-device-4
[MCU2_0] 36.036042 s: CpswProxyServer: initialization completed (core: mcu2_0)
[MCU2_0] 36.036109 s: ETHFW: Remove server Init ... DONE !!!
[MCU2_0] 36.037298 s: Starting lwIP, local interface IP is dhcp-enabled
[MCU2_0] 36.045136 s: Host MAC address: 70:ff:76:1d:92:c3
[MCU2_0] 36.049273 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully
[MCU2_0] 36.049371 s: Added interface 'ti1', IP is 0.0.0.0
[MCU2_0] 36.085835 s: FVID2: Init ... !!!
[MCU2_0] 36.085945 s: FVID2: Init ... Done !!!
[MCU2_0] 36.086002 s: DSS: Init ... !!!
[MCU2_0] 36.086031 s: DSS: Display type is eDP !!!
[MCU2_0] 36.086059 s: DSS: M2M Path is enabled !!!
[MCU2_0] 36.086089 s: DSS: SoC init ... !!!
[MCU2_0] 36.086116 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2
[MCU2_0] 36.086248 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 36.086292 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2
[MCU2_0] 36.086387 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 36.086424 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2
[MCU2_0] 36.086513 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 36.086549 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11
[MCU2_0] 36.086658 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0] 36.086694 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18
[MCU2_0] 36.086794 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0] 36.086952 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2
[MCU2_0] 36.087069 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0] 36.087113 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000
[MCU2_0] 36.088337 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
[MCU2_0] 36.088388 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0
[MCU2_0] 36.088553 s: SCICLIENT: Sciclient_pmModuleClkRequest success
[MCU2_0] 36.088598 s: DSS: SoC init ... Done !!!
[MCU2_0] 36.088629 s: DSS: Board init ... !!!
[MCU2_0] 36.088658 s: DSS: Board init ... Done !!!
[MCU2_1] 17.737448 s: CIO: Init ... Done !!!
[MCU2_1] 17.737518 s: ### CPU Frequency = 1000000000 Hz
[MCU2_1] 17.737558 s: CPU is running FreeRTOS
[MCU2_1] 17.737584 s: APP: Init ... !!!
[MCU2_1] 17.737607 s: SCICLIENT: Init ... !!!
[MCU2_1] 17.738063 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[MCU2_1] 17.738125 s: SCICLIENT: DMSC FW revision 0x8
[MCU2_1] 17.738162 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_1] 17.738199 s: SCICLIENT: Init ... Done !!!
[MCU2_1] 17.738227 s: UDMA: Init ... !!!
[MCU2_1] 17.740881 s: UDMA: Init ... Done !!!
[MCU2_1] 17.740943 s: MEM: Init ... !!!
[MCU2_1] 17.740988 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!!
[MCU2_1] 17.741062 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!!
[MCU2_1] 17.741138 s: MEM: Init ... Done !!!
[MCU2_1] 17.741169 s: IPC: Init ... !!!
[MCU2_1] 17.741235 s: IPC: 6 CPUs participating in IPC !!!
[MCU2_1] 17.741286 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU2_1] 35.491088 s: IPC: HLOS is ready !!!
[MCU2_1] 35.506297 s: IPC: Init ... Done !!!
[MCU2_1] 35.506365 s: APP: Syncing with 5 CPUs ... !!!
[MCU2_1] 36.011221 s: APP: Syncing with 5 CPUs ... Done !!!
[MCU2_1] 36.011409 s: REMOTE_SERVICE: Init ... !!!
[MCU2_1] 36.013014 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_1] 36.013082 s: FVID2: Init ... !!!
[MCU2_1] 36.013165 s: FVID2: Init ... Done !!!
[MCU2_1] 36.013198 s: VHWA: DMPAC: Init ... !!!
[MCU2_1] 36.013224 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2
[MCU2_1] 36.013671 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1] 36.013713 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2
[MCU2_1] 36.014072 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1] 36.014118 s: VHWA: DOF Init ... !!!
[MCU2_1] 36.021751 s: VHWA: DOF Init ... Done !!!
[MCU2_1] 36.021817 s: VHWA: SDE Init ... !!!
[MCU2_1] 36.024246 s: VHWA: SDE Init ... Done !!!
[MCU2_1] 36.024306 s: VHWA: DMPAC: Init ... Done !!!
[MCU2_1] 36.024353 s: VX_ZONE_INIT:Enabled
[MCU2_1] 36.024385 s: VX_ZONE_ERROR:Enabled
[MCU2_1] 36.024412 s: VX_ZONE_WARNING:Enabled
[MCU2_1] 36.025828 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-1
[MCU2_1] 36.026068 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_SDE
[MCU2_1] 36.026308 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_DOF
[MCU2_1] 36.026366 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[MCU2_1] 36.026405 s: APP: OpenVX Target kernel init ... !!!
[MCU2_1] 36.026688 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_1] 36.026733 s: UDMA Copy: Init ... !!!
[MCU2_1] 36.028578 s: UDMA Copy: Init ... Done !!!
[MCU2_1] 36.028647 s: APP: Init ... Done !!!
[MCU2_1] 36.028678 s: APP: Run ... !!!
[MCU2_1] 36.028703 s: IPC: Starting echo test ...
[MCU2_1] 36.031266 s: APP: Run ... Done !!!
[MCU2_1] 36.032402 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.]
[MCU2_1] 36.032519 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.]
[MCU2_1] 36.032612 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
[C6x_1 ] 17.737901 s: CIO: Init ... Done !!!
[C6x_1 ] 17.737927 s: ### CPU Frequency = 1350000000 Hz
[C6x_1 ] 17.737937 s: CPU is running FreeRTOS
[C6x_1 ] 17.737945 s: APP: Init ... !!!
[C6x_1 ] 17.737952 s: SCICLIENT: Init ... !!!
[C6x_1 ] 17.738282 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[C6x_1 ] 17.738294 s: SCICLIENT: DMSC FW revision 0x8
[C6x_1 ] 17.738303 s: SCICLIENT: DMSC FW ABI revision 3.1
[C6x_1 ] 17.738313 s: SCICLIENT: Init ... Done !!!
[C6x_1 ] 17.738323 s: UDMA: Init ... !!!
[C6x_1 ] 17.741328 s: UDMA: Init ... Done !!!
[C6x_1 ] 17.741347 s: MEM: Init ... !!!
[C6x_1 ] 17.741361 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!!
[C6x_1 ] 17.741378 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
[C6x_1 ] 17.741393 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ dd000000 of size 50331648 bytes !!!
[C6x_1 ] 17.741409 s: MEM: Init ... Done !!!
[C6x_1 ] 17.741417 s: IPC: Init ... !!!
[C6x_1 ] 17.741437 s: IPC: 6 CPUs participating in IPC !!!
[C6x_1 ] 17.741451 s: IPC: Waiting for HLOS to be ready ... !!!
[C6x_1 ] 32.956601 s: IPC: HLOS is ready !!!
[C6x_1 ] 32.960313 s: IPC: Init ... Done !!!
[C6x_1 ] 32.960340 s: APP: Syncing with 5 CPUs ... !!!
[C6x_1 ] 36.011215 s: APP: Syncing with 5 CPUs ... Done !!!
[C6x_1 ] 36.011227 s: REMOTE_SERVICE: Init ... !!!
[C6x_1 ] 36.011861 s: REMOTE_SERVICE: Init ... Done !!!
[C6x_1 ] 36.011897 s: VX_ZONE_INIT:Enabled
[C6x_1 ] 36.011907 s: VX_ZONE_ERROR:Enabled
[C6x_1 ] 36.011916 s: VX_ZONE_WARNING:Enabled
[C6x_1 ] 36.012692 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[C6x_1 ] 36.012705 s: APP: OpenVX Target kernel init ... !!!
[C6x_1 ] 36.012961 s: APP: OpenVX Target kernel init ... Done !!!
[C6x_1 ] 36.012975 s: UDMA Copy: Init ... !!!
[C6x_1 ] 36.016307 s: UDMA Copy: Init ... Done !!!
[C6x_1 ] 36.016329 s: APP: Init ... Done !!!
[C6x_1 ] 36.016338 s: APP: Run ... !!!
[C6x_1 ] 36.016345 s: IPC: Starting echo test ...
[C6x_1 ] 36.017386 s: APP: Run ... Done !!!
[C6x_1 ] 36.017681 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P]
[C6x_1 ] 36.018000 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_1 ] 36.031787 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_2 ] 17.738131 s: CIO: Init ... Done !!!
[C6x_2 ] 17.738157 s: ### CPU Frequency = 1350000000 Hz
[C6x_2 ] 17.738166 s: CPU is running FreeRTOS
[C6x_2 ] 17.738174 s: APP: Init ... !!!
[C6x_2 ] 17.738182 s: SCICLIENT: Init ... !!!
[C6x_2 ] 17.738491 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[C6x_2 ] 17.738503 s: SCICLIENT: DMSC FW revision 0x8
[C6x_2 ] 17.738512 s: SCICLIENT: DMSC FW ABI revision 3.1
[C6x_2 ] 17.738522 s: SCICLIENT: Init ... Done !!!
[C6x_2 ] 17.738531 s: UDMA: Init ... !!!
[C6x_2 ] 17.741644 s: UDMA: Init ... Done !!!
[C6x_2 ] 17.741664 s: MEM: Init ... !!!
[C6x_2 ] 17.741678 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!!
[C6x_2 ] 17.741695 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
[C6x_2 ] 17.741711 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e1000000 of size 50331648 bytes !!!
[C6x_2 ] 17.741728 s: MEM: Init ... Done !!!
[C6x_2 ] 17.741736 s: IPC: Init ... !!!
[C6x_2 ] 17.741758 s: IPC: 6 CPUs participating in IPC !!!
[C6x_2 ] 17.741772 s: IPC: Waiting for HLOS to be ready ... !!!
[C6x_2 ] 34.547308 s: IPC: HLOS is ready !!!
[C6x_2 ] 34.550839 s: IPC: Init ... Done !!!
[C6x_2 ] 34.550866 s: APP: Syncing with 5 CPUs ... !!!
[C6x_2 ] 36.011215 s: APP: Syncing with 5 CPUs ... Done !!!
[C6x_2 ] 36.011227 s: REMOTE_SERVICE: Init ... !!!
[C6x_2 ] 36.011876 s: REMOTE_SERVICE: Init ... Done !!!
[C6x_2 ] 36.011910 s: VX_ZONE_INIT:Enabled
[C6x_2 ] 36.011920 s: VX_ZONE_ERROR:Enabled
[C6x_2 ] 36.011929 s: VX_ZONE_WARNING:Enabled
[C6x_2 ] 36.012707 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[C6x_2 ] 36.012721 s: APP: OpenVX Target kernel init ... !!!
[C6x_2 ] 36.012982 s: APP: OpenVX Target kernel init ... Done !!!
[C6x_2 ] 36.012997 s: UDMA Copy: Init ... !!!
[C6x_2 ] 36.016487 s: UDMA Copy: Init ... Done !!!
[C6x_2 ] 36.016508 s: APP: Init ... Done !!!
[C6x_2 ] 36.016517 s: APP: Run ... !!!
[C6x_2 ] 36.016525 s: IPC: Starting echo test ...
[C6x_2 ] 36.017648 s: APP: Run ... Done !!!
[C6x_2 ] 36.017946 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.]
[C6x_2 ] 36.018008 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P]
[C6x_2 ] 36.031813 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
[C7x_1 ] 17.737339 s: CIO: Init ... Done !!!
[C7x_1 ] 17.737353 s: ### CPU Frequency = 1000000000 Hz
[C7x_1 ] 17.737364 s: CPU is running FreeRTOS
[C7x_1 ] 17.737372 s: APP: Init ... !!!
[C7x_1 ] 17.737379 s: SCICLIENT: Init ... !!!
[C7x_1 ] 17.737900 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[C7x_1 ] 17.737915 s: SCICLIENT: DMSC FW revision 0x8
[C7x_1 ] 17.737925 s: SCICLIENT: DMSC FW ABI revision 3.1
[C7x_1 ] 17.737936 s: SCICLIENT: Init ... Done !!!
[C7x_1 ] 17.737945 s: UDMA: Init ... !!!
[C7x_1 ] 17.740461 s: UDMA: Init ... Done !!!
[C7x_1 ] 17.740473 s: MEM: Init ... !!!
[C7x_1 ] 17.740484 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!!
[C7x_1 ] 17.740505 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!!
[C7x_1 ] 17.740523 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!!
[C7x_1 ] 17.740540 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
[C7x_1 ] 17.740557 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 100000000 of size 385875968 bytes !!!
[C7x_1 ] 17.740576 s: MEM: Init ... Done !!!
[C7x_1 ] 17.740584 s: IPC: Init ... !!!
[C7x_1 ] 17.740598 s: IPC: 6 CPUs participating in IPC !!!
[C7x_1 ] 17.740612 s: IPC: Waiting for HLOS to be ready ... !!!
[C7x_1 ] 36.009267 s: IPC: HLOS is ready !!!
[C7x_1 ] 36.011186 s: IPC: Init ... Done !!!
[C7x_1 ] 36.011200 s: APP: Syncing with 5 CPUs ... !!!
[C7x_1 ] 36.011214 s: APP: Syncing with 5 CPUs ... Done !!!
[C7x_1 ] 36.011225 s: REMOTE_SERVICE: Init ... !!!
[C7x_1 ] 36.011373 s: REMOTE_SERVICE: Init ... Done !!!
[C7x_1 ] 36.011394 s: VX_ZONE_INIT:Enabled
[C7x_1 ] 36.011406 s: VX_ZONE_ERROR:Enabled
[C7x_1 ] 36.011416 s: VX_ZONE_WARNING:Enabled
[C7x_1 ] 36.011575 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1
[C7x_1 ] 36.011667 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2
[C7x_1 ] 36.011771 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3
[C7x_1 ] 36.011841 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4
[C7x_1 ] 36.011904 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5
[C7x_1 ] 36.011998 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6
[C7x_1 ] 36.012094 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7
[C7x_1 ] 36.012159 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8
[C7x_1 ] 36.012181 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[C7x_1 ] 36.012193 s: APP: OpenVX Target kernel init ... !!!
[C7x_1 ] 36.012333 s: APP: OpenVX Target kernel init ... Done !!!
[C7x_1 ] 36.012347 s: APP: Init ... Done !!!
[C7x_1 ] 36.012356 s: APP: Run ... !!!
[C7x_1 ] 36.012364 s: IPC: Starting echo test ...
[C7x_1 ] 36.012521 s: APP: Run ... Done !!!
[C7x_1 ] 36.017685 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s]
[C7x_1 ] 36.018013 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s]
[C7x_1 ] 36.031834 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
The last log from MCU2_0 is from DSS initialization. You Display initialization has not gone through.
You have selected eDP as the port. Did you connect the eDP on your board?
Nikhil
Thanks for your reply. I disabled the DSS,and now there's VX_ZONE_ERROR.
root@j7-evm:/opt/vision_apps# source ./vision_apps_init.sh
root@j7-evm:/opt/vision_apps# [MCU2_0] 18.706313 s: CIO: Init ... Done !!!
[MCU2_0] 18.706389 s: ### CPU Frequency = 1000000000 Hz
[MCU2_0] 18.706437 s: CPU is running FreeRTOS
[MCU2_0] 18.706467 s: APP: Init ... !!!
[MCU2_0] 18.706493 s: SCICLIENT: Init ... !!!
[MCU2_0] 18.707114 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[MCU2_0] 18.707172 s: SCICLIENT: DMSC FW revision 0x8
[MCU2_0] 18.707215 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_0] 18.707255 s: SCICLIENT: Init ... Done !!!
[MCU2_0] 18.707287 s: UDMA: Init ... !!!
[MCU2_0] 18.709251 s: UDMA: Init ... Done !!!
[MCU2_0] 18.709315 s: MEM: Init ... !!!
[MCU2_0] 18.709365 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!!
[MCU2_0] 18.709445 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!!
[MCU2_0] 18.709513 s: MEM: Init ... Done !!!
[MCU2_0] 18.709543 s: IPC: Init ... !!!
[MCU2_0] 18.709609 s: IPC: 6 CPUs participating in IPC !!!
[MCU2_0] 18.709671 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU2_0] 34.826355 s: IPC: HLOS is ready !!!
[MCU2_0] 34.841787 s: IPC: Init ... Done !!!
[MCU2_0] 34.841853 s: APP: Syncing with 5 CPUs ... !!!
[MCU2_0] 36.814023 s: APP: Syncing with 5 CPUs ... Done !!!
[MCU2_0] 36.814202 s: REMOTE_SERVICE: Init ... !!!
[MCU2_0] 36.815780 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_0] 36.815846 s: ETHFW: Init ... !!!
[MCU2_0] 36.819772 s: Warning: Using 6 MAC address(es) from static pool
[MCU2_0] 36.819883 s: ETHFW: Shared multicasts (software fanout):
[MCU2_0] 36.819929 s: ETHFW: Reserved multicasts:
[MCU2_0] 36.819961 s: 01:80:c2:00:00:0e
[MCU2_0] 36.820012 s: 01:1b:19:00:00:00
[MCU2_0] 36.820276 s: EnetMcm: CPSW_9G on MAIN NAVSS
[MCU2_0] 36.829724 s: Mdio_open: MDIO manual mode enabled
[MCU2_0] 36.833563 s: PHY 16 is alive
[MCU2_0] 36.833728 s: PHY 17 is alive
[MCU2_0] 36.833854 s: PHY 18 is alive
[MCU2_0] 36.833974 s: PHY 19 is alive
[MCU2_0] 36.837225 s:
[MCU2_0] 36.837307 s: ETHFW Build Date: Feb 28, 2023
[MCU2_0] 36.837347 s: ETHFW Build Time: 23:37:07
[MCU2_0] 36.837382 s: ETHFW Commit SHA: 8c7326da
[MCU2_0] 36.837456 s: ETHFW: Init ... DONE !!!
[MCU2_0] 36.837492 s: ETHFW: Remove server Init ... !!!
[MCU2_0] 36.837679 s: CpswProxyServer: Virtual port configuration:
[MCU2_0] 36.837740 s: mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0
[MCU2_0] 36.837792 s: mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1
[MCU2_0] 36.837841 s: mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1
[MCU2_0] 36.837887 s: mcu_2_1 <-> MAC port 4: mcu_2_1_ethmac-device-4
[MCU2_0] 36.838883 s: CpswProxyServer: initialization completed (core: mcu2_0)
[MCU2_0] 36.838950 s: ETHFW: Remove server Init ... DONE !!!
[MCU2_0] 36.840080 s: Starting lwIP, local interface IP is dhcp-enabled
[MCU2_0] 36.847700 s: Host MAC address: 70:ff:76:1d:92:c3
[MCU2_0] 36.851760 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully
[MCU2_0] 36.851857 s: Added interface 'ti1', IP is 0.0.0.0
[MCU2_0] 36.888683 s: FVID2: Init ... !!!
[MCU2_0] 36.888795 s: FVID2: Init ... Done !!!
[MCU2_0] 36.888848 s: VHWA: VPAC Init ... !!!
[MCU2_0] 36.888883 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2
[MCU2_0] 36.889016 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 36.889060 s: VHWA: LDC Init ... !!!
[MCU2_0] 36.892501 s: VHWA: LDC Init ... Done !!!
[MCU2_0] 36.892569 s: VHWA: MSC Init ... !!!
[MCU2_0] 36.904191 s: VHWA: MSC Init ... Done !!!
[MCU2_0] 36.904260 s: VHWA: NF Init ... !!!
[MCU2_0] 36.906146 s: VHWA: NF Init ... Done !!!
[MCU2_0] 36.906214 s: VHWA: VISS Init ... !!!
[MCU2_0] 36.917298 s: VHWA: VISS Init ... Done !!!
[MCU2_0] 36.917365 s: VHWA: VPAC Init ... Done !!!
[MCU2_0] 36.917416 s: VX_ZONE_INIT:Enabled
[MCU2_0] 36.917449 s: VX_ZONE_ERROR:Enabled
[MCU2_0] 36.917481 s: VX_ZONE_WARNING:Enabled
[MCU2_0] 36.919103 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-0
[MCU2_0] 36.919342 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_NF
[MCU2_0] 36.919558 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_LDC1
[MCU2_0] 36.919949 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC1
[MCU2_0] 36.920203 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC2
[MCU2_0] 36.920471 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_VISS1
[MCU2_0] 36.920846 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE1
[MCU2_0] 36.921122 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE2
[MCU2_0] 36.921385 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY1
[MCU2_0] 36.921637 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY2
[MCU2_0] 36.922007 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX
[MCU2_0] 36.922277 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE3
[MCU2_0] 36.922531 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE4
[MCU2_0] 36.922905 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE5
[MCU2_0] 36.923178 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE6
[MCU2_0] 36.923442 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE7
[MCU2_0] 36.923809 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE8
[MCU2_0] 36.924059 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M1
[MCU2_0] 36.924285 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M2
[MCU2_0] 36.924507 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M3
[MCU2_0] 36.924908 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M4
[MCU2_0] 36.924976 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[MCU2_0] 36.925017 s: APP: OpenVX Target kernel init ... !!!
[MCU2_0] 36.945557 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_0] 36.945626 s: CSI2RX: Init ... !!!
[MCU2_0] 36.945774 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
[MCU2_0] 36.945916 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 36.945961 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2
[MCU2_0] 36.946054 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 36.946091 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2
[MCU2_0] 36.946178 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 36.946214 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2
[MCU2_0] 36.946297 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 36.946334 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2
[MCU2_0] 36.946416 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 36.946644 s: CSI2RX: Init ... Done !!!
[MCU2_0] 36.946810 s: CSI2TX: Init ... !!!
[MCU2_0] 36.946845 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
[MCU2_0] 36.946946 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 36.946989 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2
[MCU2_0] 36.947072 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 36.947110 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2
[MCU2_0] 36.947193 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0] 36.947288 s: CSI2TX: Init ... Done !!!
[MCU2_0] 36.947324 s: ISS: Init ... !!!
[MCU2_0] 36.947361 s: IssSensor_Init ... Done !!!
[MCU2_0] 36.947442 s: IttRemoteServer_Init ... Done !!!
[MCU2_0] 36.947481 s: VISS REMOTE SERVICE: Init ... !!!
[MCU2_0] 36.947547 s: VISS REMOTE SERVICE: Init ... Done !!!
[MCU2_0] 36.947582 s: UDMA Copy: Init ... !!!
[MCU2_0] 36.949398 s: UDMA Copy: Init ... Done !!!
[MCU2_0] 36.949509 s: APP: Init ... Done !!!
[MCU2_0] 36.949550 s: APP: Run ... !!!
[MCU2_0] 36.949579 s: IPC: Starting echo test ...
[MCU2_0] 36.952451 s: APP: Run ... Done !!!
[MCU2_0] 36.954275 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.]
[MCU2_0] 36.954395 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[.] C7X_1[.]
[MCU2_0] 36.954495 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.]
[MCU2_0] 36.954582 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P]
[MCU2_0] 37.650567 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6
[MCU2_0] 37.765040 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6
[MCU2_0] 42.601729 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c2, FlowIdx:173, FlowIdxOffset:1
[MCU2_0] 42.655549 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6,mode:disable
[MCU2_0] 42.655928 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6,mode:disable
[MCU2_0] 42.656180 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6,mode:disable
[MCU2_0] 42.683754 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:172, FlowIdxOffset:0
[MCU2_0] 42.686923 s: Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:11, Policer Entry:2
[MCU2_0] 42.743417 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:1, vlanId:0, FlowIdx:172, FlowIdOffset:0
[MCU2_0] 42.746919 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:1, vlanId:0, FlowIdx:172, FlowIdOffset:0
[MCU2_0] 42.750358 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6, MacAddress:33:33:ff:1d:92:c1, vlanId:0, FlowIdx:172, FlowIdOffset:0
[MCU2_0] 42.812828 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6,mode:disable
[MCU2_0] 42.813111 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6,mode:disable
[MCU2_0] 42.813352 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6,mode:disable
[MCU2_0] 42.821391 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:172, FlowIdOffset:0
[MCU2_0] 42.824878 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:172, FlowIdOffset:0
[MCU2_0] 42.828315 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:172, FlowIdOffset:0
[MCU2_0] 42.828464 s: CpswProxyServer_isRsvdMcast: Reserved mcast cannot be added to filter
[MCU2_0] 43.217259 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6,mode:disable
[MCU2_0] 43.217917 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:fb, vlanId:0, FlowIdx:172, FlowIdOffset:0
[MCU2_0] 44.318644 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6,mode:disable
[MCU2_0] 44.473592 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a19bfc,CoreKey:38acb7e6, MacAddress:33:33:0:1:0:3, vlanId:0, FlowIdx:172, FlowIdOffset:0
[MCU2_1] 18.706564 s: CIO: Init ... Done !!!
[MCU2_1] 18.706638 s: ### CPU Frequency = 1000000000 Hz
[MCU2_1] 18.706679 s: CPU is running FreeRTOS
[MCU2_1] 18.706704 s: APP: Init ... !!!
[MCU2_1] 18.706728 s: SCICLIENT: Init ... !!!
[MCU2_1] 18.707206 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[MCU2_1] 18.707260 s: SCICLIENT: DMSC FW revision 0x8
[MCU2_1] 18.707296 s: SCICLIENT: DMSC FW ABI revision 3.1
[MCU2_1] 18.707333 s: SCICLIENT: Init ... Done !!!
[MCU2_1] 18.707360 s: UDMA: Init ... !!!
[MCU2_1] 18.710138 s: UDMA: Init ... Done !!!
[MCU2_1] 18.710201 s: MEM: Init ... !!!
[MCU2_1] 18.710246 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!!
[MCU2_1] 18.710320 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!!
[MCU2_1] 18.710381 s: MEM: Init ... Done !!!
[MCU2_1] 18.710408 s: IPC: Init ... !!!
[MCU2_1] 18.710472 s: IPC: 6 CPUs participating in IPC !!!
[MCU2_1] 18.710523 s: IPC: Waiting for HLOS to be ready ... !!!
[MCU2_1] 36.314361 s: IPC: HLOS is ready !!!
[MCU2_1] 36.329572 s: IPC: Init ... Done !!!
[MCU2_1] 36.329639 s: APP: Syncing with 5 CPUs ... !!!
[MCU2_1] 36.814036 s: APP: Syncing with 5 CPUs ... Done !!!
[MCU2_1] 36.814237 s: REMOTE_SERVICE: Init ... !!!
[MCU2_1] 36.815855 s: REMOTE_SERVICE: Init ... Done !!!
[MCU2_1] 36.815918 s: FVID2: Init ... !!!
[MCU2_1] 36.815988 s: FVID2: Init ... Done !!!
[MCU2_1] 36.816018 s: VHWA: DMPAC: Init ... !!!
[MCU2_1] 36.816045 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2
[MCU2_1] 36.816477 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1] 36.816520 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2
[MCU2_1] 36.816872 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_1] 36.816911 s: VHWA: DOF Init ... !!!
[MCU2_1] 36.824595 s: VHWA: DOF Init ... Done !!!
[MCU2_1] 36.824663 s: VHWA: SDE Init ... !!!
[MCU2_1] 36.827138 s: VHWA: SDE Init ... Done !!!
[MCU2_1] 36.827198 s: VHWA: DMPAC: Init ... Done !!!
[MCU2_1] 36.827246 s: VX_ZONE_INIT:Enabled
[MCU2_1] 36.827277 s: VX_ZONE_ERROR:Enabled
[MCU2_1] 36.827303 s: VX_ZONE_WARNING:Enabled
[MCU2_1] 36.828708 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-1
[MCU2_1] 36.828967 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_SDE
[MCU2_1] 36.829191 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_DOF
[MCU2_1] 36.829247 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[MCU2_1] 36.829284 s: APP: OpenVX Target kernel init ... !!!
[MCU2_1] 36.829550 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_1] 36.829594 s: UDMA Copy: Init ... !!!
[MCU2_1] 36.831342 s: UDMA Copy: Init ... Done !!!
[MCU2_1] 36.831410 s: APP: Init ... Done !!!
[MCU2_1] 36.831443 s: APP: Run ... !!!
[MCU2_1] 36.831468 s: IPC: Starting echo test ...
[MCU2_1] 36.834030 s: APP: Run ... Done !!!
[MCU2_1] 36.835165 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.]
[MCU2_1] 36.835275 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.]
[MCU2_1] 36.835367 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
[MCU2_1] 36.954263 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P]
[C6x_1 ] 18.707109 s: CIO: Init ... Done !!!
[C6x_1 ] 18.707135 s: ### CPU Frequency = 1350000000 Hz
[C6x_1 ] 18.707145 s: CPU is running FreeRTOS
[C6x_1 ] 18.707154 s: APP: Init ... !!!
[C6x_1 ] 18.707162 s: SCICLIENT: Init ... !!!
[C6x_1 ] 18.707410 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[C6x_1 ] 18.707422 s: SCICLIENT: DMSC FW revision 0x8
[C6x_1 ] 18.707431 s: SCICLIENT: DMSC FW ABI revision 3.1
[C6x_1 ] 18.707441 s: SCICLIENT: Init ... Done !!!
[C6x_1 ] 18.707451 s: UDMA: Init ... !!!
[C6x_1 ] 18.710550 s: UDMA: Init ... Done !!!
[C6x_1 ] 18.710569 s: MEM: Init ... !!!
[C6x_1 ] 18.710582 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!!
[C6x_1 ] 18.710599 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
[C6x_1 ] 18.710614 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ dd000000 of size 50331648 bytes !!!
[C6x_1 ] 18.710631 s: MEM: Init ... Done !!!
[C6x_1 ] 18.710639 s: IPC: Init ... !!!
[C6x_1 ] 18.710660 s: IPC: 6 CPUs participating in IPC !!!
[C6x_1 ] 18.710673 s: IPC: Waiting for HLOS to be ready ... !!!
[C6x_1 ] 33.827246 s: IPC: HLOS is ready !!!
[C6x_1 ] 33.830937 s: IPC: Init ... Done !!!
[C6x_1 ] 33.830966 s: APP: Syncing with 5 CPUs ... !!!
[C6x_1 ] 36.814022 s: APP: Syncing with 5 CPUs ... Done !!!
[C6x_1 ] 36.814034 s: REMOTE_SERVICE: Init ... !!!
[C6x_1 ] 36.814664 s: REMOTE_SERVICE: Init ... Done !!!
[C6x_1 ] 36.814700 s: VX_ZONE_INIT:Enabled
[C6x_1 ] 36.814709 s: VX_ZONE_ERROR:Enabled
[C6x_1 ] 36.814719 s: VX_ZONE_WARNING:Enabled
[C6x_1 ] 36.815501 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[C6x_1 ] 36.815515 s: APP: OpenVX Target kernel init ... !!!
[C6x_1 ] 36.815777 s: APP: OpenVX Target kernel init ... Done !!!
[C6x_1 ] 36.815792 s: UDMA Copy: Init ... !!!
[C6x_1 ] 36.819131 s: UDMA Copy: Init ... Done !!!
[C6x_1 ] 36.819152 s: APP: Init ... Done !!!
[C6x_1 ] 36.819161 s: APP: Run ... !!!
[C6x_1 ] 36.819169 s: IPC: Starting echo test ...
[C6x_1 ] 36.820212 s: APP: Run ... Done !!!
[C6x_1 ] 36.820509 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P]
[C6x_1 ] 36.820797 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_1 ] 36.834556 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_1 ] 36.954125 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P]
[C6x_2 ] 18.707279 s: CIO: Init ... Done !!!
[C6x_2 ] 18.707305 s: ### CPU Frequency = 1350000000 Hz
[C6x_2 ] 18.707315 s: CPU is running FreeRTOS
[C6x_2 ] 18.707323 s: APP: Init ... !!!
[C6x_2 ] 18.707331 s: SCICLIENT: Init ... !!!
[C6x_2 ] 18.707658 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[C6x_2 ] 18.707670 s: SCICLIENT: DMSC FW revision 0x8
[C6x_2 ] 18.707680 s: SCICLIENT: DMSC FW ABI revision 3.1
[C6x_2 ] 18.707689 s: SCICLIENT: Init ... Done !!!
[C6x_2 ] 18.707699 s: UDMA: Init ... !!!
[C6x_2 ] 18.710948 s: UDMA: Init ... Done !!!
[C6x_2 ] 18.710969 s: MEM: Init ... !!!
[C6x_2 ] 18.710983 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!!
[C6x_2 ] 18.711000 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!!
[C6x_2 ] 18.711017 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e1000000 of size 50331648 bytes !!!
[C6x_2 ] 18.711033 s: MEM: Init ... Done !!!
[C6x_2 ] 18.711042 s: IPC: Init ... !!!
[C6x_2 ] 18.711064 s: IPC: 6 CPUs participating in IPC !!!
[C6x_2 ] 18.711079 s: IPC: Waiting for HLOS to be ready ... !!!
[C6x_2 ] 35.325369 s: IPC: HLOS is ready !!!
[C6x_2 ] 35.328941 s: IPC: Init ... Done !!!
[C6x_2 ] 35.328967 s: APP: Syncing with 5 CPUs ... !!!
[C6x_2 ] 36.814022 s: APP: Syncing with 5 CPUs ... Done !!!
[C6x_2 ] 36.814035 s: REMOTE_SERVICE: Init ... !!!
[C6x_2 ] 36.814675 s: REMOTE_SERVICE: Init ... Done !!!
[C6x_2 ] 36.814710 s: VX_ZONE_INIT:Enabled
[C6x_2 ] 36.814719 s: VX_ZONE_ERROR:Enabled
[C6x_2 ] 36.814729 s: VX_ZONE_WARNING:Enabled
[C6x_2 ] 36.815515 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[C6x_2 ] 36.815529 s: APP: OpenVX Target kernel init ... !!!
[C6x_2 ] 36.815783 s: APP: OpenVX Target kernel init ... Done !!!
[C6x_2 ] 36.815797 s: UDMA Copy: Init ... !!!
[C6x_2 ] 36.819312 s: UDMA Copy: Init ... Done !!!
[C6x_2 ] 36.819335 s: APP: Init ... Done !!!
[C6x_2 ] 36.819344 s: APP: Run ... !!!
[C6x_2 ] 36.819352 s: IPC: Starting echo test ...
[C6x_2 ] 36.820476 s: APP: Run ... Done !!!
[C6x_2 ] 36.820795 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.]
[C6x_2 ] 36.820828 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P]
[C6x_2 ] 36.834579 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
[C6x_2 ] 36.954164 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P]
[C7x_1 ] 18.706447 s: CIO: Init ... Done !!!
[C7x_1 ] 18.706461 s: ### CPU Frequency = 1000000000 Hz
[C7x_1 ] 18.706472 s: CPU is running FreeRTOS
[C7x_1 ] 18.706480 s: APP: Init ... !!!
[C7x_1 ] 18.706488 s: SCICLIENT: Init ... !!!
[C7x_1 ] 18.707042 s: SCICLIENT: DMSC FW version [8.6.3--v08.06.03 (Chill Capybar]
[C7x_1 ] 18.707058 s: SCICLIENT: DMSC FW revision 0x8
[C7x_1 ] 18.707068 s: SCICLIENT: DMSC FW ABI revision 3.1
[C7x_1 ] 18.707078 s: SCICLIENT: Init ... Done !!!
[C7x_1 ] 18.707088 s: UDMA: Init ... !!!
[C7x_1 ] 18.709548 s: UDMA: Init ... Done !!!
[C7x_1 ] 18.709561 s: MEM: Init ... !!!
[C7x_1 ] 18.709572 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!!
[C7x_1 ] 18.709593 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!!
[C7x_1 ] 18.709611 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!!
[C7x_1 ] 18.709629 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!!
[C7x_1 ] 18.709646 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 100000000 of size 385875968 bytes !!!
[C7x_1 ] 18.709665 s: MEM: Init ... Done !!!
[C7x_1 ] 18.709673 s: IPC: Init ... !!!
[C7x_1 ] 18.709687 s: IPC: 6 CPUs participating in IPC !!!
[C7x_1 ] 18.709700 s: IPC: Waiting for HLOS to be ready ... !!!
[C7x_1 ] 36.812018 s: IPC: HLOS is ready !!!
[C7x_1 ] 36.813993 s: IPC: Init ... Done !!!
[C7x_1 ] 36.814008 s: APP: Syncing with 5 CPUs ... !!!
[C7x_1 ] 36.814021 s: APP: Syncing with 5 CPUs ... Done !!!
[C7x_1 ] 36.814032 s: REMOTE_SERVICE: Init ... !!!
[C7x_1 ] 36.814181 s: REMOTE_SERVICE: Init ... Done !!!
[C7x_1 ] 36.814204 s: VX_ZONE_INIT:Enabled
[C7x_1 ] 36.814221 s: VX_ZONE_ERROR:Enabled
[C7x_1 ] 36.814232 s: VX_ZONE_WARNING:Enabled
[C7x_1 ] 36.814385 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1
[C7x_1 ] 36.814475 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2
[C7x_1 ] 36.814540 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3
[C7x_1 ] 36.814650 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4
[C7x_1 ] 36.814713 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5
[C7x_1 ] 36.814820 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6
[C7x_1 ] 36.814904 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7
[C7x_1 ] 36.814970 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8
[C7x_1 ] 36.814992 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
[C7x_1 ] 36.815004 s: APP: OpenVX Target kernel init ... !!!
[C7x_1 ] 36.815142 s: APP: OpenVX Target kernel init ... Done !!!
[C7x_1 ] 36.815156 s: APP: Init ... Done !!!
[C7x_1 ] 36.815165 s: APP: Run ... !!!
[C7x_1 ] 36.815173 s: IPC: Starting echo test ...
[C7x_1 ] 36.815328 s: APP: Run ... Done !!!
[C7x_1 ] 36.820516 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s]
[C7x_1 ] 36.820790 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s]
[C7x_1 ] 36.834603 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
[C7x_1 ] 36.954197 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
./run_app_tidl.sh
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
IPC: Init ... !!!
0.000000 s: GTC Frequency = 0 MHz
0.000000 s: VX_ZONE_INIT:Enabled
0.000000 s: VX_ZONE_ERROR:Enabled
0.000000 s: VX_ZONE_WARNING:Enabled
0.000000 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
0.000000 s: VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!!
Demo : TIDL Object Classification
p: Print performance statistics
x: Exit
Enter Choice: network file: /opt/vision_apps/test_data/tivx/tidl_models/tidl_net_mobilenet_v1.bin
config file: /opt/vision_apps/test_data/tivx/tidl_models/tidl_io_mobilenet_v1_1.bin
Iteration 0 of 1000000 ...
0.000000 s: VX_ZONE_ERROR:[tivx_utils_bmp_write:1043] Failed to open file <./app_tidl_out/0001.bmp>.
0.000000 s: VX_ZONE_ERROR:[tivx_utils_bmp_write:1043] Failed to open file <./app_tidl_out/0002.bmp>.
0.000000 s: VX_ZONE_ERROR:[tivx_utils_bmp_write:1043] Failed to open file <./app_tidl_out/0003.bmp>.
0.000000 s: VX_ZONE_ERROR:[tivx_utils_bmp_write:1043] Failed to open file <./app_tidl_out/0004.bmp>.
0.000000 s: VX_ZONE_ERROR:[tivx_utils_bmp_write:1043] Failed to open file <./app_tidl_out/0005.bmp>.
0.000000 s: VX_ZONE_ERROR:[tivx_utils_bmp_write:1043] Failed to open file <./app_tidl_out/0006.bmp>.
0.000000 s: VX_ZONE_ERROR:[tivx_utils_bmp_write:1043] Failed to open file <./app_tidl_out/0007.bmp>.
0.000000 s: VX_ZONE_ERROR:[tivx_utils_bmp_write:1043] Failed to open file <./app_tidl_out/0008.bmp>.
0.000000 s: VX_ZONE_ERROR:[tivx_utils_bmp_write:1043] Failed to open file <./app_tidl_out/0009.bmp>.
0.000000 s: VX_ZONE_ERROR:[tivx_utils_bmp_write:1043] Failed to open file <./app_tidl_out/0010.bmp>.
