TDA4VM: Does TDA4's DP interface force output?
Part Number: TDA4VM
I ran into a problem when I was using TDA4's DP interface to output video.
I have a DP interface screen and a type-c interface screen.
(1) I connect the DP interface of TDA4 with the DP screen and then turn on the power supply of TDA4, and the DP screen can display pictures.
(2) I connected the DP interface of TDA4 to the type-c screen with a DP-to-Type-C conversion cable and then turned on the power supply of TDA4. The type-c screen could not display the picture and indicated no signal.
(3) I first execute (1) and then do not power off the TDA4 and then unplug the DP screen and connect the type-c screen, the type-c screen can display the picture.
