Part Number: IND-COMMS-SDK
Dear TI Team,
I have observed a faulty behavior. It seems to be similar to the issue described in the related question, but compared to that, I am running in SM2-synchronous mode (instead of Freerun mode).
- Running ethercat slave simple demo of industrial communications sdk 09.01.00.03 on AM64x
- I have modified the stack to send received process data back to the master
- running in SyncManager2 synchronous mode (but also in Distributed Clocks mode with certain settings)
- PLC running Codesys as master
- increments process data by 1 on each EtherCAT cycle
- determines the difference between sent and received process data
- Tested with EtherCAT cycle time of 100µs and 1000µs; does not appear to occur at cycle times higher than 1000µs
In most EtherCAT cycles the determined difference is 1, just as I would have expected. But in quite a few cycles the difference is bigger than 1. From this I conclude that the process data in the slave is not always up to date.
I would be happy to receive the provided fix so that I can determine if my problem is also related to the firmware bug.
Thanks for your help,
Jonas
