TDA4VM: TDA4VM: Using TDA4's CPSW9G, connecting to phy chip, link up successfully but we can't ping other devices
Part Number: TDA4VM
Hi TI,
Please help me check whether my configuration is correct.
SDK-10.00
serdes0-lane1: rtl9010(sgmii2)
configure
1.uboot:
2.linux dts  k3-j721e-common-proc-board.dts
&serdes_ln_ctrl {
idle-states = <J721E_SERDES0_LANE0_QSGMII_LANE1>, <J721E_SERDES0_LANE1_QSGMII_LANE2>,
<J721E_SERDES1_LANE0_PCIE1_LANE0>, <J721E_SERDES1_LANE1_PCIE1_LANE1>,
<J721E_SERDES2_LANE0_PCIE2_LANE0>, <J721E_SERDES2_LANE1_PCIE2_LANE1>,
<J721E_SERDES3_LANE0_USB3_0_SWAP>, <J721E_SERDES3_LANE1_USB3_0>,
<J721E_SERDES4_LANE0_EDP_LANE0>, <J721E_SERDES4_LANE1_EDP_LANE1>,
<J721E_SERDES4_LANE2_EDP_LANE2>, <J721E_SERDES4_LANE3_EDP_LANE3>;
&serdes_wiz0 {
status = "okay";
&serdes0 {
status = "okay";
assigned-clocks = <&serdes0 CDNS_SIERRA_PLL_CMNLC>, <&serdes0 CDNS_SIERRA_PLL_CMNLC1>;
assigned-clock-parents = <&wiz0_pll1_refclk>, <&wiz0_pll1_refclk>;
#address-cells = <1>;
#size-cells = <0>;
serdes0_sgmii_link: phy@0 {
reg = <0>;
cdns,num-lanes = <2>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_SGMII>;
resets = <&serdes_wiz0 1>,<&serdes_wiz0 2>;
&cpsw0 {
status = "okay";
&cpsw0_port2 {
status = "okay";
phy-handle = <&cpsw9g_phy1>;
phy-mode = "sgmii";
mac-address = [00 00 00 00 00 00];
phys = <&cpsw0_phy_gmii_sel 2>,<&serdes0_sgmii_link>;
phy-names = "portmode", "serdes-phy";
&cpsw9g_mdio {
status = "okay";
pinctrl-names = "default";
pinctrl-0 = <&mdio0_pins_default>;
reset-post-delay-us = <120000>;
#size-cells = <0>;
cpsw9g_phy1: ethernet-phy@1 {
reg = <1>;
compatible = "ethernet-phy-id001c.cb30","ethernet-phy-ieee802.3-c22";
fixed-link {
speed = <1000>;
full-duplex;
3.remove j7-main-r5f0_0-fw
4. ethtool eth0
5.boot log
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 6.6.32-ti-gdb8871293143-dirty (bingo@ubuntu) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240620) #29 SMP PREEMPT Thu Nov 14 14:39:50 CST 2024
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments J721e EVM
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x00000008e0000000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000008e0000000..0x00000008ffffffff (524288 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a0000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a0100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a1000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a1100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a2000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a3ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a2100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a4000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a5ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a4100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a6000000..0x00000000a60fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a6000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a6100000..0x00000000a6ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a6100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000a70fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a7000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a7100000..0x00000000a7ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a7100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a8000000..0x00000000a80fffff (1024 KiB) nomap non-reusable vision-apps-c66-dma-memory@a8000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a8100000..0x00000000a8ffffff (15360 KiB) nomap non-reusable vision-apps-c66-memory@a8100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a9000000..0x00000000a90fffff (1024 KiB) nomap non-reusable vision-apps-c66-dma-memory@a9000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a9100000..0x00000000a9ffffff (15360 KiB) nomap non-reusable vision-apps-c66-memory@a9100000
[    0.000000] OF: reserved mem: 0x00000000aa000000..0x00000000abffffff (32768 KiB) nomap non-reusable vision-apps-rtos-ipc-memory-region
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000ac000000..0x00000000b1ffffff (98304 KiB) nomap non-reusable vision-apps-dma-memory@ac000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000b2000000..0x00000000b20fffff (1024 KiB) nomap non-reusable vision-apps-c71-dma-memory@b2000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000b2100000..0x00000000b7ffffff (97280 KiB) nomap non-reusable vision-apps-c71-memory@b2100000
[    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[    0.000000] OF: reserved mem: 0x00000000b8000000..0x00000000d7ffffff (524288 KiB) map non-reusable vision_apps_shared-memories
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000d8000000..0x00000000e3ffffff (196608 KiB) nomap non-reusable vision-apps-core-heap-memory-lo@d8000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000e4000000..0x00000000e47fffff (8192 KiB) nomap non-reusable vision-apps-r5f-virtual-eth-queues@e4000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000e4800000..0x00000000e5ffffff (24576 KiB) nomap non-reusable vision-apps-r5f-virtual-eth-buffers@e4800000
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000880000000..0x00000008a6ffffff (638976 KiB) nomap non-reusable vision-apps-core-heap-memory-hi@880000000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000b7ffffff]
[    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000e5ffffff]
[    0.000000]   node   0: [mem 0x00000000e6000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008a6ffffff]
[    0.000000]   node   0: [mem 0x00000008a7000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920
[    0.000000] pcpu-alloc: s42920 r8192 d30808 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-v3a
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 2.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] Memory: 1694808K/4194304K available (11904K kernel code, 1244K rwdata, 4016K rodata, 2432K init, 436K bss, 1975208K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008a7040000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7050000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008413] Console: colour dummy device 80x25
[    0.012979] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023650] pid_max: default: 32768 minimum: 301
[    0.028398] LSM: initializing lsm=capability,integrity
[    0.033693] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.041263] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.050050] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.057304] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.065134] rcu: Hierarchical SRCU implementation.
[    0.070031] rcu: 	Max phase no-delay instances is 1000.
[    0.075553] Platform MSI: msi-controller@1820000 domain created
[    0.081810] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.091247] EFI services will not be available.
[    0.095988] smp: Bringing up secondary CPUs ...
[    0.109191] Detected PIPT I-cache on CPU1
[    0.109237] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.109248] GICv3: CPU1: using allocated LPI pending table @0x00000008a7060000
[    0.109277] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.109329] smp: Brought up 1 node, 2 CPUs
[    0.138674] SMP: Total of 2 processors activated.
[    0.143479] CPU features: detected: 32-bit EL0 Support
[    0.148732] CPU features: detected: CRC32 instructions
[    0.154008] CPU: All CPU(s) started at EL2
[    0.158190] alternatives: applying system-wide alternatives
[    0.164718] devtmpfs: initialized
[    0.174987] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.184965] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.197945] pinctrl core: initialized pinctrl subsystem
[    0.203571] DMI not present or invalid.
[    0.207904] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.214411] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.221711] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.229707] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.237827] audit: initializing netlink subsys (disabled)
[    0.243429] audit: type=2000 audit(0.156:1): state=initialized audit_enabled=0 res=1
[    0.243625] thermal_sys: Registered thermal governor 'step_wise'
[    0.251348] thermal_sys: Registered thermal governor 'power_allocator'
[    0.257501] cpuidle: using governor menu
[    0.268240] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.275197] ASID allocator initialised with 65536 entries
[    0.291167] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts
[    0.302716] Modules: 27712 pages in range for non-PLT usage
[    0.302721] Modules: 519232 pages in range for PLT usage
[    0.308813] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.321180] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.327582] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.334517] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.340918] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.347852] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.354253] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.361187] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.368271] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.1 JTAGID[0x1bb6402f] Detected
[    0.377398] iommu: Default domain type: Translated
[    0.382320] iommu: DMA domain TLB invalidation policy: strict mode
[    0.388752] SCSI subsystem initialized
[    0.392670] libata version 3.00 loaded.
[    0.392746] usbcore: registered new interface driver usbfs
[    0.398365] usbcore: registered new interface driver hub
[    0.403811] usbcore: registered new device driver usb
[    0.409215] pps_core: LinuxPPS API ver. 1 registered
[    0.414287] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.423626] PTP clock support registered
[    0.427730] EDAC MC: Ver: 3.0.0
[    0.431154] scmi_core: SCMI protocol bus registered
[    0.436270] FPGA manager framework
[    0.439781] Advanced Linux Sound Architecture Driver Initialized.
[    0.446470] clocksource: Switched to clocksource arch_sys_counter
[    0.452810] VFS: Disk quotas dquot_6.6.0
[    0.456832] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.466990] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[    0.473282] NET: Registered PF_INET protocol family
[    0.478403] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.487318] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.496073] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.503995] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.512196] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.520632] TCP: Hash tables configured (established 32768 bind 32768)
[    0.527413] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.534322] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.541741] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.547798] RPC: Registered named UNIX socket transport module.
[    0.553853] RPC: Registered udp transport module.
[    0.558659] RPC: Registered tcp transport module.
[    0.563462] RPC: Registered tcp-with-tls transport module.
[    0.569065] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.575647] NET: Registered PF_XDP protocol family
[    0.580549] PCI: CLS 0 bytes, default 64
[    0.585116] Initialise system trusted keyrings
[    0.589748] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.596488] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.602578] NFS: Registering the id_resolver key type
[    0.607764] Key type id_resolver registered
[    0.612036] Key type id_legacy registered
[    0.616139] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.622988] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.644363] Key type asymmetric registered
[    0.648547] Asymmetric key parser 'x509' registered
[    0.653551] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.661111] io scheduler mq-deadline registered
[    0.665741] io scheduler kyber registered
[    0.669850] io scheduler bfq registered
[    0.675783] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.682118] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.688398] pinctrl-single 104200.pinctrl: 20 pins, size 80
[    0.694155] pinctrl-single 104280.pinctrl: 8 pins, size 32
[    0.700115] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    0.709669] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.718644] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.726826] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    0.733934] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    0.741725] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.752428] loop: module loaded
[    0.756165] megasas: 07.725.01.00-rc1
[    0.761679] tun: Universal TUN/TAP device driver, 1.6
[    0.767375] VFIO - User Level meta-driver version: 0.3
[    0.773232] usbcore: registered new interface driver usb-storage
[    0.779700] i2c_dev: i2c /dev entries driver
[    0.784701] sdhci: Secure Digital Host Controller Interface driver
[    0.791021] sdhci: Copyright(c) Pierre Ossman
[    0.795586] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.801687] ledtrig-cpu: registered to indicate activity on CPUs
[    0.807995] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.814821] usbcore: registered new interface driver usbhid
[    0.820516] usbhid: USB HID core driver
[    0.825187] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.833795] optee: probing for conduit method.
[    0.838348] optee: revision 4.2 (12d7c4ee)
[    0.854765] optee: dynamic shared memory is enabled
[    0.864338] random: crng init done
[    0.867871] optee: initialized driver
[    0.872885] NET: Registered PF_PACKET protocol family
[    0.878097] Key type dns_resolver registered
[    0.885636] registered taskstats version 1
[    0.889886] Loading compiled-in X.509 certificates
[    0.900563] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
[    1.001189] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[    1.007512] pca953x 1-0020: supply vcc not found, using dummy regulator
[    1.014329] pca953x 1-0020: using no AI
[    2.022474] omap_i2c 2000000.i2c: timeout waiting for bus ready
[    2.028531] pca953x 1-0020: failed writing register
[    2.033572] pca953x: probe of 1-0020 failed with error -16
[    2.039370] pca953x 1-0022: supply vcc not found, using dummy regulator
[    2.046185] pca953x 1-0022: using AI
[    3.054473] omap_i2c 2000000.i2c: timeout waiting for bus ready
[    3.060525] pca953x 1-0022: failed writing register
[    3.065559] pca953x: probe of 1-0022 failed with error -16
[    3.071261] st_asm330lhh_i2c: probe of 1-006a failed with error -22
[    3.077680] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
[    3.083811] pca953x 2-0020: supply vcc not found, using dummy regulator
[    3.090625] pca953x 2-0020: using no AI
[    3.118534] pca953x 2-0020: failed writing register
[    3.123562] pca953x: probe of 2-0020 failed with error -121
[    3.129317] omap_i2c 2030000.i2c: bus 2 rev0.12 at 400 kHz
[    3.135053] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
[    3.143596] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
[    3.152934] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
[    3.161531] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    3.176836] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    3.186723] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    3.193482] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    3.203047] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    3.213192] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    3.219951] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    3.227886] printk: console [ttyS2] disabled
[    3.232414] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 204, base_baud = 3000000) is a 8250
[    3.241296] printk: console [ttyS2] enabled
[    3.249792] printk: bootconsole [ns16550a0] disabled
[    3.263159] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 205, base_baud = 3000000) is a 8250
[    3.272316] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 206, base_baud = 3000000) is a 8250
[    3.282253] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
[    3.326474] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    3.334896] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver RTL9010 PHY Driver
[    3.343685] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
[    3.356454] am65-cpsw-nuss c000000.ethernet: Use random MAC address
[    3.362722] am65-cpsw-nuss c000000.ethernet: initialized cpsw ale version 1.4
[    3.369842] am65-cpsw-nuss c000000.ethernet: ALE Table size 512
[    3.376130] am65-cpsw-nuss c000000.ethernet: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    3.387878] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    3.396611] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    3.396856] mmc0: CQHCI version 5.10
[    3.406721] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    3.413680] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    3.420505] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    3.427307] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    3.442501] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    3.515731] mmc0: mmc_select_hs200 failed, error -110
[    3.520789] mmc0: error -110 whilst initialising MMC card
[    3.637368] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
[    3.641467] mmc0: mmc_select_hs200 failed, error -110
[    3.648242] mmc0: error -110 whilst initialising MMC card
[    3.654428] tps6594-rtc tps6594-rtc.4.auto: setting system clock to 2024-02-28T15:35:24 UTC (1709134524)
[    3.786064] mmc0: mmc_select_hs200 failed, error -110
[    3.791127] mmc0: error -110 whilst initialising MMC card
[    3.921892] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    3.933016] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[    3.946919] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    3.954237] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
[    3.974759] mmc0: mmc_select_hs200 failed, error -110
[    3.979806] mmc0: error -110 whilst initialising MMC card
[    3.986488] mmc0: Failed to initialize a non-removable card
[    3.998474] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    4.012457] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver RTL9010 PHY Driver
[    4.021257] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
[    4.034026] am65-cpsw-nuss c000000.ethernet: Use random MAC address
[    4.040291] am65-cpsw-nuss c000000.ethernet: initialized cpsw ale version 1.4
[    4.047410] am65-cpsw-nuss c000000.ethernet: ALE Table size 512
[    4.053668] am65-cpsw-nuss c000000.ethernet: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    4.072633] am65-cpsw-nuss c000000.ethernet: set new flow-id-base 140
[    4.084628] mmc1: CQHCI version 5.10
[    4.091815] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    4.098862] clk: Disabling unused clocks
[    4.121844] ALSA device list:
[    4.124813]   No soundcards found.
[    4.129125] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    4.136694] Waiting for root device PARTUUID=076c4a2a-02...
[    4.177849] tps6594 0-004c: Error IRQ trap overvoltage for LDO1
[    4.186585] mmc1: new ultra high speed DDR50 SDHC card at address 59b4
[    4.193438] mmcblk1: mmc1:59b4 EZSD1 29.1 GiB
[    4.199454]  mmcblk1: p1 p2
[    4.604108] EXT4-fs (mmcblk1p2): mounted filesystem b57c3b63-12a8-42de-8aac-e86cbb7e3fbc r/w with ordered data mode. Quota mode: none.
[    4.616265] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    4.623297] devtmpfs: mounted
[    4.627253] Freeing unused kernel memory: 2432K
[    4.631859] Run /sbin/init as init process
[    4.635948]   with arguments:
[    4.635949]     /sbin/init
[    4.635951]   with environment:
[    4.635953]     HOME=/
[    4.635955]     TERM=linux
[    5.071944] ipv6: Unknown symbol make_kuid (err -2)
[    5.077047] ipv6: Unknown symbol __put_net (err -2)
[    5.082011] ipv6: Unknown symbol from_kuid_munged (err -2)
[    5.144070] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    5.175839] systemd[1]: Detected architecture arm64.
[    5.202544] systemd[1]: Hostname set to <j721e-evm>.
[    5.451736] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[    5.460628] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[    5.494098] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    5.518106] systemd[1]: Configuration file /etc/systemd/system/app-init.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    5.594187] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    5.662210] systemd[1]: Queued start job for default target Graphical Interface.
[    5.701189] systemd[1]: Created slice Slice /system/getty.
[    5.723647] systemd[1]: Created slice Slice /system/modprobe.
[    5.747536] systemd[1]: Created slice Slice /system/serial-getty.
[    5.771288] systemd[1]: Created slice User and Session Slice.
[    5.794680] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    5.818610] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.842549] systemd[1]: Expecting device /dev/ttyS2...
[    5.858578] systemd[1]: Reached target Path Units.
[    5.874531] systemd[1]: Reached target Remote File Systems.
[    5.894522] systemd[1]: Reached target Slice Units.
[    5.910527] systemd[1]: Reached target Swaps.
[    5.949051] systemd[1]: Listening on RPCbind Server Activation Socket.
[    5.974608] systemd[1]: Reached target RPC Port Mapper.
[    5.998175] systemd[1]: Listening on Process Core Dump Socket.
[    6.018700] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    6.043092] systemd[1]: Listening on Journal Audit Socket.
[    6.066811] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.086820] systemd[1]: Listening on Journal Socket.
[    6.102876] systemd[1]: Listening on Network Service Netlink Socket.
[    6.129939] systemd[1]: Listening on udev Control Socket.
[    6.150775] systemd[1]: Listening on udev Kernel Socket.
[    6.170778] systemd[1]: Listening on User Database Manager Socket.
[    6.214685] systemd[1]: Mounting Huge Pages File System...
[    6.232445] systemd[1]: Mounting POSIX Message Queue File System...
[    6.258767] systemd[1]: Mounting Kernel Debug File System...
[    6.264851] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    6.305801] systemd[1]: Mounting Temporary Directory /tmp...
[    6.334891] systemd[1]: Starting Create List of Static Device Nodes...
[    6.378937] systemd[1]: Starting Load Kernel Module configfs...
[    6.386999] systemd[1]: Starting Load Kernel Module drm...
[    6.402931] systemd[1]: Starting Load Kernel Module fuse...
[    6.427541] systemd[1]: Starting Start psplash boot splash screen...
[    6.438211] fuse: Unknown symbol make_kuid (err -2)
[    6.444716] fuse: Unknown symbol put_pid_ns (err -2)
[    6.450069] fuse: Unknown symbol from_kgid (err -2)
[    6.454972] fuse: Unknown symbol from_kuid (err -2)
[    6.459917] fuse: Unknown symbol current_in_userns (err -2)
[    6.459947] fuse: Unknown symbol make_kgid (err -2)
[    6.459956] fuse: Unknown symbol from_kgid_munged (err -2)
[    6.460014] fuse: Unknown symbol __put_user_ns (err -2)
[    6.460033] fuse: Unknown symbol from_kuid_munged (err -2)
[    6.483383] drm: Unknown symbol from_kuid_munged (err -2)
[    6.494871] systemd[1]: Starting RPC Bind...
[    6.514721] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[    6.530917] systemd[1]: Starting Journal Service...
[    6.563226] ipv6: Unknown symbol make_kuid (err -2)
[    6.568318] ipv6: Unknown symbol __put_net (err -2)
[    6.573279] ipv6: Unknown symbol from_kuid_munged (err -2)
[    6.590941] systemd[1]: Starting Load Kernel Modules...
[    6.608945] ipv6: Unknown symbol make_kuid (err -2)
[    6.614095] ipv6: Unknown symbol __put_net (err -2)
[    6.620056] ipv6: Unknown symbol from_kuid_munged (err -2)
[    6.622894] systemd[1]: Starting Generate network units from Kernel command line...
[    6.626066] systemd-journald[108]: Collecting audit messages is enabled.
[    6.659065] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.673782] cryptodev: loading out-of-tree module taints kernel.
[    6.676312] ipv6: Unknown symbol make_kuid (err -2)
[    6.691178] ipv6: Unknown symbol __put_net (err -2)
[    6.696191] ipv6: Unknown symbol from_kuid_munged (err -2)
[    6.727474] systemd[1]: Starting Coldplug All udev Devices...
[    6.730772] cryptodev: driver 1.13 loaded.
[    6.761136] systemd[1]: Started Journal Service.
[    6.770894] EXT4-fs (mmcblk1p2): re-mounted b57c3b63-12a8-42de-8aac-e86cbb7e3fbc r/w. Quota mode: none.
[    7.170207] systemd-journald[108]: Received client request to flush runtime journal.
[    7.403821] audit: type=1334 audit(1709134528.248:2): prog-id=6 op=LOAD
[    7.410762] audit: type=1334 audit(1709134528.256:3): prog-id=7 op=LOAD
[    7.596593] audit: type=1334 audit(1709134528.440:4): prog-id=8 op=LOAD
[    7.629073] audit: type=1334 audit(1709134528.472:5): prog-id=9 op=LOAD
[    7.790936] audit: type=1334 audit(1709134528.636:6): prog-id=10 op=LOAD
[    7.803190] audit: type=1334 audit(1709134528.640:7): prog-id=11 op=LOAD
[    7.814773] audit: type=1334 audit(1709134528.640:8): prog-id=12 op=LOAD
[    8.261372] drm: Unknown symbol from_kuid_munged (err -2)
[    8.286766] kfifo_buf: exports duplicate symbol iio_kfifo_allocate (owned by kernel)
[    8.299337] pinctrl-single 11c000.pinctrl: pin PIN164 already requested by 601000.gpio; cannot claim for 4104000.cdns-usb
[    8.313788] pinctrl-single 11c000.pinctrl: pin-164 (4104000.cdns-usb) status -22
[    8.321262] pinctrl-single 11c000.pinctrl: could not request pin 164 (PIN164) from group main-usbss0-default-pins  on device pinctrl-single
[    8.333865] cdns3-ti 4104000.cdns-usb: Error applying setting, reverse things back
[    8.346011] drm: Unknown symbol from_kuid_munged (err -2)
[    8.363544] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[    8.371774] mc: Linux media interface: v0.10
[    8.372214] CAN device driver interface
[    8.384363] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[    8.402027] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
[    8.415537] kfifo_buf: exports duplicate symbol iio_kfifo_allocate (owned by kernel)
[    8.427888] remoteproc remoteproc0: 4d80800000.dsp is available
[    8.434584] remoteproc remoteproc0: attaching to 4d80800000.dsp
[    8.447154] videodev: Linux video capture interface: v2.00
[    8.461739] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
[    8.472181] kfifo_buf: exports duplicate symbol iio_kfifo_allocate (owned by kernel)
[    8.491116] rproc-virtio rproc-virtio.11.auto: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[    8.523971] virtio_rpmsg_bus virtio0: rpmsg host is online
[    8.529503] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[    8.543080] kfifo_buf: exports duplicate symbol iio_kfifo_allocate (owned by kernel)
[    8.559354] rproc-virtio rproc-virtio.11.auto: registered virtio0 (type 7)
[    8.576078] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
[    8.585172] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[    8.598276] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
[    8.608456] audit: type=1334 audit(1709134529.452:9): prog-id=13 op=LOAD
[    8.610849] remoteproc remoteproc1: 4d81800000.dsp is available
[    8.625514] remoteproc remoteproc1: attaching to 4d81800000.dsp
[    8.636850] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
[    8.645989] rproc-virtio rproc-virtio.14.auto: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[    8.683628] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    8.702924] platform 41000000.r5f: configured R5F for IPC-only mode
[    8.711093] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[    8.715919] virtio_rpmsg_bus virtio1: rpmsg host is online
[    8.720298] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[    8.734606] remoteproc remoteproc2: 41000000.r5f is available
[    8.744823] remoteproc remoteproc2: attaching to 41000000.r5f
[    8.747358] at24 0-0050: supply vcc not found, using dummy regulator
[    8.762540] rproc-virtio rproc-virtio.14.auto: registered virtio1 (type 7)
[    8.763804] platform 41000000.r5f: R5F core initialized in IPC-only mode
[    8.780047] rproc-virtio rproc-virtio.15.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[    8.791501] virtio_rpmsg_bus virtio2: rpmsg host is online
[    8.792913] remoteproc remoteproc1: remote processor 4d81800000.dsp is now attached
[    8.804728] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[    8.811400] rproc-virtio rproc-virtio.15.auto: registered virtio2 (type 7)
[    8.812386] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[    8.826145] remoteproc remoteproc2: remote processor 41000000.r5f is now attached
[    8.837198] platform 5c00000.r5f: configured R5F for remoteproc mode
[    8.850690] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[    8.863679] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[    8.874139] remoteproc remoteproc3: 5c00000.r5f is available
[    8.887411] remoteproc remoteproc3: Direct firmware load for j7-main-r5f0_0-fw failed with error -2
[    8.898375] remoteproc remoteproc3: powering up 5c00000.r5f
[    8.906758] remoteproc remoteproc3: Direct firmware load for j7-main-r5f0_0-fw failed with error -2
[    8.918796] remoteproc remoteproc3: request_firmware failed: -2
[    8.939585] drm: Unknown symbol from_kuid_munged (err -2)
[    8.943918] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[    8.953247] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
[    8.953399] remoteproc remoteproc4: 64800000.dsp is available
[    8.953444] remoteproc remoteproc4: attaching to 64800000.dsp
[    8.953653] remoteproc remoteproc4: unsupported resource 65538
[    8.971696] m_can_platform 40528000.can: registering can0 failed (err=-22)
[    8.993345] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
[    9.000477] rproc-virtio rproc-virtio.16.auto: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
[    9.011059] img_enc 4200000.video-encoder: encoder registered as /dev/video1
[    9.013392] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[    9.022632] m_can_platform: probe of 40528000.can failed with error -22
[    9.032718] virtio_rpmsg_bus virtio3: rpmsg host is online
[    9.039776] m_can_platform 40568000.can: registering can0 failed (err=-22)
[    9.046674] drm: Unknown symbol from_kuid_munged (err -2)
[    9.049109] rproc-virtio rproc-virtio.16.auto: registered virtio3 (type 7)
[    9.059138] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[    9.059976] remoteproc remoteproc4: remote processor 64800000.dsp is now attached
[    9.082526] m_can_platform: probe of 40568000.can failed with error -22
[    9.106765] m_can_platform 2721000.can: registering can0 failed (err=-22)
[    9.126699] m_can_platform: probe of 2721000.can failed with error -22
[    9.167164] dbus-broker-lau[306]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[    9.181564] yaxon update start...
[    9.215467] Waiting for USB to be mounted...
[    9.256820] kfifo_buf: exports duplicate symbol iio_kfifo_allocate (owned by kernel)
[    9.279239] xhci-hcd xhci-hcd.17.auto: xHCI Host Controller
[    9.289448] xhci-hcd xhci-hcd.17.auto: new USB bus registered, assigned bus number 1
[    9.304417] xhci-hcd xhci-hcd.17.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000008010
[    9.318969] xhci-hcd xhci-hcd.17.auto: irq 833, io mem 0x06410000
[    9.326628] kfifo_buf: exports duplicate symbol iio_kfifo_allocate (owned by kernel)
[    9.327833] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    9.334599] xhci-hcd xhci-hcd.17.auto: xHCI Host Controller
[    9.347607] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    9.362153] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    9.372930] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    9.379569] remoteproc remoteproc5: b034000.pru is available
[    9.384772] xhci-hcd xhci-hcd.17.auto: new USB bus registered, assigned bus number 2
[    9.396794] xhci-hcd xhci-hcd.17.auto: Host supports USB 3.0 SuperSpeed
[    9.404841] remoteproc remoteproc6: b004000.rtu is available
[    9.411984] hub 1-0:1.0: USB hub found
[    9.419199] remoteproc remoteproc7: b00a000.txpru is available
[    9.438222] hub 1-0:1.0: 1 port detected
[    9.442763] scsi host0: ufshcd
[    9.455599] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    9.466835] hub 2-0:1.0: USB hub found
[    9.475458] remoteproc remoteproc8: b038000.pru is available
[    9.475847] hub 2-0:1.0: 1 port detected
[    9.498660] audit: type=1334 audit(1709134530.344:10): prog-id=14 op=LOAD
[    9.510730] remoteproc remoteproc9: b006000.rtu is available
[    9.516934] audit: type=1334 audit(1709134530.356:11): prog-id=15 op=LOAD
[    9.525375] remoteproc remoteproc10: b00c000.txpru is available
[    9.534839] remoteproc remoteproc11: b134000.pru is available
[    9.543561] remoteproc remoteproc12: b104000.rtu is available
[    9.544783] remoteproc remoteproc13: b10a000.txpru is available
[    9.546049] remoteproc remoteproc14: b138000.pru is available
[    9.547307] remoteproc remoteproc15: b106000.rtu is available
[    9.548506] remoteproc remoteproc16: b10c000.txpru is available
[    9.613055] ipv6: Unknown symbol make_kuid (err -2)
[    9.631054] ipv6: Unknown symbol __put_net (err -2)
[    9.643624] ipv6: Unknown symbol from_kuid_munged (err -2)
[    9.708020] ipv6: Unknown symbol make_kuid (err -2)
[    9.717637] ipv6: Unknown symbol __put_net (err -2)
[    9.723648] ipv6: Unknown symbol from_kuid_munged (err -2)
[    9.746461] ipv6: Unknown symbol make_kuid (err -2)
[    9.757386] ipv6: Unknown symbol __put_net (err -2)
[    9.765976] ipv6: Unknown symbol from_kuid_munged (err -2)
[    9.856470] cdns-ufshcd 4e84000.ufs: link startup failed 1
[    9.862106] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[    9.867417] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[    9.867423] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[    9.867426] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[    9.867429] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[    9.867432] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[    9.867434] cdns-ufshcd 4e84000.ufs: Clk gate=1
[    9.867437] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[    9.867440] cdns-ufshcd 4e84000.ufs: last intr at 9856447 us, last intr status=0x404
[    9.867443] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[    9.867446] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[    9.867449] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[    9.867452] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[    9.867455] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[    9.867458] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[    9.867476] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[    9.867479] host_regs: 00000010: 00000000 00000000 00000000 00000000
[    9.867482] host_regs: 00000020: 00000000 00000470 00000000 00000000
[    9.867485] host_regs: 00000030: 00000008 00000001 00000000 00000000
[    9.867487] host_regs: 00000040: 00000000 00000000 00000000 00000000
[    9.867490] host_regs: 00000050: 00000000 00000000 00000000 00000000
[    9.867492] host_regs: 00000060: 00000000 00000000 00000000 00000000
[    9.867495] host_regs: 00000070: 00000000 00000000 00000000 00000000
[    9.867497] host_regs: 00000080: 00000000 00000000 00000000 00000000
[    9.867500] host_regs: 00000090: 00000016 00000000 00000001 00000000
[    9.867503] cdns-ufshcd 4e84000.ufs: No record of pa_err
[    9.867506] cdns-ufshcd 4e84000.ufs: No record of dl_err
[    9.867509] cdns-ufshcd 4e84000.ufs: No record of nl_err
[    9.867511] cdns-ufshcd 4e84000.ufs: No record of tl_err
[    9.867513] cdns-ufshcd 4e84000.ufs: No record of dme_err
[    9.867515] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[    9.867518] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[    9.867520] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 9856465 us
[    9.867523] cdns-ufshcd 4e84000.ufs: link_startup_fail: total cnt=1
[    9.867526] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[    9.867529] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[    9.867531] cdns-ufshcd 4e84000.ufs: No record of wlun resume_fail
[    9.867533] cdns-ufshcd 4e84000.ufs: No record of wlun suspend_fail
[    9.867535] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[    9.867537] cdns-ufshcd 4e84000.ufs: No record of host_reset
[    9.867539] cdns-ufshcd 4e84000.ufs: No record of task_abort
[    9.880680] cdns-ufshcd 4e84000.ufs: ufshcd_async_scan failed: 1
[   10.196880] cfg80211: Unknown symbol __put_net (err -2)
[   10.202522] cfg80211: Unknown symbol get_net_ns_by_fd (err -2)
[   10.246695] Update script not found
[   10.250320] yaxon update end
[   10.263116] bluetooth: Unknown symbol from_kuid (err -2)
[   10.268585] bluetooth: Unknown symbol from_kgid_munged (err -2)
[   10.274651] bluetooth: Unknown symbol from_kuid_munged (err -2)
[   10.519296] rtl9010_init_phy: RTL9010 mode= 4 neg= 0 speed =1000 dup=1 ============
[   10.594699] overlay: Unknown symbol from_kgid (err -2)
[   10.610924] overlay: Unknown symbol from_kuid (err -2)
[   10.618158] rtl9010_hardware_reset success!
[   10.624013] RTL9010Ax_Initial_Configuration: RTL9010  ============
[   10.637904] RTL9010Ax_Initial_Configuration_Check: RTL9010  ============
[   10.649651] RTL9010Ax_Initial_with_SGMII_Configuration: RTL9010  ============
[   10.649741] ipv6: Unknown symbol make_kuid (err -2)
[   10.665163] ipv6: Unknown symbol __put_net (err -2)
[   10.670569] ipv6: Unknown symbol from_kuid_munged (err -2)
[   10.699350] RTL9010Ax_Initial_with_SGMII_Configuration_Check: RTL9010  ============
[   10.788743] RTL9010Ax_Soft_Reset: RTL9010  ============
[   10.794413] rtl9010_config_init:RTL9010 phy driver config init end.
[   10.800706] rtl9010_init_phy: RTL9010 mode= 4 neg= 0 speed =1000 dup=1 ============
[   10.808366] rtl9010_power_on:GPIO_PHY_VSYS request.
[   10.813242] rtl9010_power_on:GPIO_PHY_POWER request .
[   10.818336] rtl9010_power_on:GPIO_PHY_RESET request .
[   10.882500] k3_r5_rproc bus@100000:r5fss@5c00000: Timed out waiting for 5c00000.r5f core to power up!
[   10.900211] platform 5e00000.r5f: configured R5F for remoteproc mode
[   10.915222] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[   10.925942] rtl9010_hardware_reset success!
[   10.930393] RTL9010Ax_Initial_Configuration: RTL9010  ============
[   10.937655] remoteproc remoteproc17: 5e00000.r5f is available
[   10.949751] RTL9010Ax_Initial_Configuration_Check: RTL9010  ============
[   10.971598] RTL9010Ax_Initial_with_SGMII_Configuration: RTL9010  ============
[   11.023034] RTL9010Ax_Initial_with_SGMII_Configuration_Check: RTL9010  ============
[   11.030761] remoteproc remoteproc17: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
[   11.042894] remoteproc remoteproc17: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
[   11.058527] remoteproc remoteproc17: powering up 5e00000.r5f
[   11.068368] remoteproc remoteproc17: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
[   11.082527] remoteproc remoteproc17: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
[   11.097998] remoteproc remoteproc17: request_firmware failed: -22
[   11.166347] RTL9010Ax_Soft_Reset: RTL9010  ============
[   11.172176] am65-cpsw-nuss c000000.ethernet eth0: PHY [c000f00.mdio:01] driver [RTL9010 PHY Driver] (irq=POLL)
[   11.187479] am65-cpsw-nuss c000000.ethernet eth0: configuring for phy/sgmii link mode
[   11.187495] rtl9010_init_phy: RTL9010 mode= 4 neg= 0 speed =1000 dup=1 ============
[   11.187502] rtl9010_power_on:GPIO_PHY_VSYS request.
[   11.187506] rtl9010_power_on:GPIO_PHY_POWER request .
[   11.187510] rtl9010_power_on:GPIO_PHY_RESET request .
[   11.266424] rtl9010_hardware_reset success!
[   11.270827] RTL9010Ax_Initial_Configuration: RTL9010  ============
[   11.281850] RTL9010Ax_Initial_Configuration_Check: RTL9010  ============
[   11.293280] RTL9010Ax_Initial_with_SGMII_Configuration: RTL9010  ============
[   11.330971] RTL9010Ax_Initial_with_SGMII_Configuration_Check: RTL9010  ============
[   11.394608] RTL9010Ax_Soft_Reset: RTL9010  ============
[   11.401536] am65-cpsw-nuss c000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   11.988494] ipv6: Unknown symbol make_kuid (err -2)
[   11.994075] ipv6: Unknown symbol __put_net (err -2)
[   11.999591] ipv6: Unknown symbol from_kuid_munged (err -2)
[   12.962492] k3_r5_rproc bus@100000:r5fss@5e00000: Timed out waiting for 5e00000.r5f core to power up!
[   19.884890] kauditd_printk_skb: 8 callbacks suppressed
[   19.884897] audit: type=1006 audit(1709134540.728:16): pid=834 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
[   19.902858] audit: type=1300 audit(1709134540.728:16): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff83be848 a2=1 a3=1 items=0 ppid=1 pid=834 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[   19.929916] audit: type=1327 audit(1709134540.728:16): proctitle="(systemd)"
[   19.937187] audit: type=1334 audit(1709134540.732:17): prog-id=18 op=LOAD
[   19.944308] audit: type=1300 audit(1709134540.732:17): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc0f4c738 a2=90 a3=0 items=0 ppid=1 pid=834 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[   19.970203] audit: type=1327 audit(1709134540.732:17): proctitle="(systemd)"
[   19.977454] audit: type=1334 audit(1709134540.748:18): prog-id=18 op=UNLOAD
[   19.984645] audit: type=1300 audit(1709134540.748:18): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffb21fec60 items=0 ppid=1 pid=834 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[   20.010329] audit: type=1327 audit(1709134540.748:18): proctitle="(systemd)"
[   20.017505] audit: type=1334 audit(1709134540.748:19): prog-id=19 op=LOAD
[   23.170984] platform 2701000.can: deferred probe pending
[   23.176297] platform 2920000.pcie: deferred probe pending
[   23.181690] platform 2900000.pcie: deferred probe pending
[   23.188266] platform 2910000.pcie: deferred probe pending
[   23.193680] platform can-phy2: deferred probe pending
[   52.009580] ipv6: Unknown symbol make_kuid (err -2)
[   52.014695] ipv6: Unknown symbol __put_net (err -2)
[   52.019685] ipv6: Unknown symbol from_kuid_munged (err -2)
    1) Please change the "phy-names" in CPSW ports as below.
    + phy-names = "portmode", "serdes";
    2) Also, no need to add below serdes clock assignment under Serdes node.
    Can you please check with above suggested changes.
    Sudheer
  • Hi ,
    After modification as you suggested, eth0 is gone.
    Can you please share the A72 log?
    Sudheer
    I could see SerDes driver failure form the A72 log, causing cpsw driver probe fail.
    Can you please share the log of below command after booting Linux.
    # k3conf dump clock 292
    Sudheer
    The result of executing this command is shown below.
    Can you please check with below clock configuration in Serdes node and check once.
    Also, share the log of below command after booting Linux.
    Sudheer
    [    0.000000] Linux version 6.6.32-ti-gdb8871293143-dirty (bingo@ubuntu) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240620) #33 SMP PREEMPT Fri Nov 15 10:35:44 CST 2024
    [    0.008425] Console: colour dummy device 80x25
    [    0.012992] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023662] pid_max: default: 32768 minimum: 301
    [    0.028411] LSM: initializing lsm=capability,integrity
    [    0.033706] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.041277] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.050069] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.057324] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.065154] rcu: Hierarchical SRCU implementation.
    [    0.070050] rcu: 	Max phase no-delay instances is 1000.
    [    0.075573] Platform MSI: msi-controller@1820000 domain created
    [    0.081829] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.091273] EFI services will not be available.
    [    0.096014] smp: Bringing up secondary CPUs ...
    [    0.109218] Detected PIPT I-cache on CPU1
    [    0.109263] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.109275] GICv3: CPU1: using allocated LPI pending table @0x00000008a7060000
    [    0.109303] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.109359] smp: Brought up 1 node, 2 CPUs
    [    0.138703] SMP: Total of 2 processors activated.
    [    0.143508] CPU features: detected: 32-bit EL0 Support
    [    0.148761] CPU features: detected: CRC32 instructions
    [    0.154035] CPU: All CPU(s) started at EL2
    [    0.158217] alternatives: applying system-wide alternatives
    [    0.164742] devtmpfs: initialized
    [    0.175081] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.185059] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.198022] pinctrl core: initialized pinctrl subsystem
    [    0.203655] DMI not present or invalid.
    [    0.207990] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.214494] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.221793] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.229790] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.237910] audit: initializing netlink subsys (disabled)
    [    0.243511] audit: type=2000 audit(0.156:1): state=initialized audit_enabled=0 res=1
    [    0.243708] thermal_sys: Registered thermal governor 'step_wise'
    [    0.251430] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.257584] cpuidle: using governor menu
    [    0.268323] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.275282] ASID allocator initialised with 65536 entries
    [    0.291240] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts
    [    0.302812] Modules: 27712 pages in range for non-PLT usage
    [    0.302817] Modules: 519232 pages in range for PLT usage
    [    0.308901] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.321267] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.327670] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.334604] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.341005] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.347939] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.354341] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.361274] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.368345] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.1 JTAGID[0x1bb6402f] Detected
    [    0.377484] iommu: Default domain type: Translated
    [    0.382404] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.388840] SCSI subsystem initialized
    [    0.392755] libata version 3.00 loaded.
    [    0.392831] usbcore: registered new interface driver usbfs
    [    0.398450] usbcore: registered new interface driver hub
    [    0.403894] usbcore: registered new device driver usb
    [    0.409305] pps_core: LinuxPPS API ver. 1 registered
    [    0.414377] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.423717] PTP clock support registered
    [    0.427820] EDAC MC: Ver: 3.0.0
    [    0.431250] scmi_core: SCMI protocol bus registered
    [    0.436363] FPGA manager framework
    [    0.439875] Advanced Linux Sound Architecture Driver Initialized.
    [    0.446547] clocksource: Switched to clocksource arch_sys_counter
    [    0.452886] VFS: Disk quotas dquot_6.6.0
    [    0.456909] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.467046] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
    [    0.473338] NET: Registered PF_INET protocol family
    [    0.478460] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.487380] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.496148] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.504070] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.512272] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
    [    0.520707] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.527490] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.534405] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.541822] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.547871] RPC: Registered named UNIX socket transport module.
    [    0.553926] RPC: Registered udp transport module.
    [    0.558729] RPC: Registered tcp transport module.
    [    0.563532] RPC: Registered tcp-with-tls transport module.
    [    0.569135] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.575717] NET: Registered PF_XDP protocol family
    [    0.580619] PCI: CLS 0 bytes, default 64
    [    0.585195] Initialise system trusted keyrings
    [    0.589830] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.596564] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.602647] NFS: Registering the id_resolver key type
    [    0.607822] Key type id_resolver registered
    [    0.612099] Key type id_legacy registered
    [    0.616201] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.623050] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.644154] Key type asymmetric registered
    [    0.648342] Asymmetric key parser 'x509' registered
    [    0.653344] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.660903] io scheduler mq-deadline registered
    [    0.665530] io scheduler kyber registered
    [    0.669641] io scheduler bfq registered
    [    0.675584] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.681903] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.688197] pinctrl-single 104200.pinctrl: 20 pins, size 80
    [    0.693946] pinctrl-single 104280.pinctrl: 8 pins, size 32
    [    0.699891] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.709476] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.718375] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.726567] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.733669] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.741426] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.752216] loop: module loaded
    [    0.755997] megasas: 07.725.01.00-rc1
    [    0.761540] tun: Universal TUN/TAP device driver, 1.6
    [    0.767255] VFIO - User Level meta-driver version: 0.3
    [    0.773130] usbcore: registered new interface driver usb-storage
    [    0.779604] i2c_dev: i2c /dev entries driver
    [    0.784604] sdhci: Secure Digital Host Controller Interface driver
    [    0.790923] sdhci: Copyright(c) Pierre Ossman
    [    0.795491] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.801598] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.807904] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.814738] usbcore: registered new interface driver usbhid
    [    0.820433] usbhid: USB HID core driver
    [    0.825121] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.833749] optee: probing for conduit method.
    [    0.838304] optee: revision 4.2 (12d7c4ee)
    [    0.854714] optee: dynamic shared memory is enabled
    [    0.864298] random: crng init done
    [    0.867828] optee: initialized driver
    [    0.872890] NET: Registered PF_PACKET protocol family
    [    0.878104] Key type dns_resolver registered
    [    0.885677] registered taskstats version 1
    [    0.890029] Loading compiled-in X.509 certificates
    [    0.900627] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    [    1.001752] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.008071] pca953x 1-0020: supply vcc not found, using dummy regulator
    [    1.014902] pca953x 1-0020: using no AI
    [    2.026554] omap_i2c 2000000.i2c: timeout waiting for bus ready
    [    2.032616] pca953x 1-0020: failed writing register
    [    2.037670] pca953x: probe of 1-0020 failed with error -16
    [    2.043454] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    2.050257] pca953x 1-0022: using AI
    [    3.058549] omap_i2c 2000000.i2c: timeout waiting for bus ready
    [    3.064601] pca953x 1-0022: failed writing register
    [    3.069633] pca953x: probe of 1-0022 failed with error -16
    [    3.075342] st_asm330lhh_i2c: probe of 1-006a failed with error -22
    [    3.081760] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
    [    3.087899] pca953x 2-0020: supply vcc not found, using dummy regulator
    [    3.094719] pca953x 2-0020: using no AI
    [    3.122610] pca953x 2-0020: failed writing register
    [    3.127640] pca953x: probe of 2-0020 failed with error -121
    [    3.133396] omap_i2c 2030000.i2c: bus 2 rev0.12 at 400 kHz
    [    3.139130] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
    [    3.147677] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
    [    3.157020] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
    [    3.165620] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
    [    3.180898] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
    [    3.190787] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    3.197546] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    3.207109] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
    [    3.217256] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    3.224015] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
    [    3.231956] printk: console [ttyS2] disabled
    [    3.236482] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 204, base_baud = 3000000) is a 8250
    [    3.245405] printk: console [ttyS2] enabled
    [    3.253851] printk: bootconsole [ns16550a0] disabled
    [    3.267245] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 205, base_baud = 3000000) is a 8250
    [    3.276406] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 206, base_baud = 3000000) is a 8250
    [    3.286373] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
    [    3.330550] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    3.338973] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver RTL9010 PHY Driver
    [    3.347760] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
    [    3.361703] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    3.370478] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    3.370616] mmc0: CQHCI version 5.10
    [    3.380584] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    3.387489] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    3.394317] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    3.401123] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    3.418557] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    3.490937] mmc0: mmc_select_hs200 failed, error -110
    [    3.495996] mmc0: error -110 whilst initialising MMC card
    [    3.609401] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
    [    3.616090] tps6594-rtc tps6594-rtc.4.auto: setting system clock to 2024-02-28T20:48:52 UTC (1709153332)
    [    3.616753] mmc0: mmc_select_hs200 failed, error -110
    [    3.630605] mmc0: error -110 whilst initialising MMC card
    [    3.768198] mmc0: mmc_select_hs200 failed, error -110
    [    3.773259] mmc0: error -110 whilst initialising MMC card
    [    3.893653] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    3.904750] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
    [    3.918639] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
    [    3.925971] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
    [    3.958768] mmc0: mmc_select_hs200 failed, error -110
    [    3.963815] mmc0: error -110 whilst initialising MMC card
    [    3.970496] mmc0: Failed to initialize a non-removable card
    [    3.970551] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    3.984532] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver RTL9010 PHY Driver
    [    3.993322] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
    [    4.106864] cdns-sierra-phy 5000000.serdes: Timeout waiting for CMN ready
    [    4.113643] phy phy-5000000.serdes.9: phy poweron failed --> -110
    [    4.120090] am65-cpsw-nuss: probe of c000000.ethernet failed with error -110
    [    4.128085] mmc1: CQHCI version 5.10
    [    4.132189] input: gpio-keys as /devices/platform/gpio-keys/input/input0
    [    4.139244] clk: Disabling unused clocks
    [    4.162195] ALSA device list:
    [    4.165161]   No soundcards found.
    [    4.169114] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    4.176689] Waiting for root device PARTUUID=076c4a2a-02...
    [    4.218188] tps6594 0-004c: Error IRQ trap overvoltage for LDO1
    [    4.226904] mmc1: new ultra high speed DDR50 SDHC card at address 59b4
    [    4.233780] mmcblk1: mmc1:59b4 EZSD1 29.1 GiB
    [    4.239842]  mmcblk1: p1 p2
    [    4.662772] EXT4-fs (mmcblk1p2): mounted filesystem b57c3b63-12a8-42de-8aac-e86cbb7e3fbc r/w with ordered data mode. Quota mode: none.
    [    4.674891] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    4.681921] devtmpfs: mounted
    [    4.685838] Freeing unused kernel memory: 2432K
    [    4.690456] Run /sbin/init as init process
    [    4.694547]   with arguments:
    [    4.694548]     /sbin/init
    [    4.694551]   with environment:
    [    4.694552]     HOME=/
    [    4.694554]     TERM=linux
    [    5.116403] ipv6: Unknown symbol make_kuid (err -2)
    [    5.121507] ipv6: Unknown symbol __put_net (err -2)
    [    5.126468] ipv6: Unknown symbol from_kuid_munged (err -2)
    [    5.188279] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    5.220050] systemd[1]: Detected architecture arm64.
    [    5.246599] systemd[1]: Hostname set to <j721e-evm>.
    [    5.492128] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
    [    5.501019] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
    [    5.534621] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    5.558670] systemd[1]: Configuration file /etc/systemd/system/app-init.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    5.634943] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    5.703002] systemd[1]: Queued start job for default target Graphical Interface.
    [    5.737353] systemd[1]: Created slice Slice /system/getty.
    [    5.759722] systemd[1]: Created slice Slice /system/modprobe.
    [    5.783610] systemd[1]: Created slice Slice /system/serial-getty.
    [    5.807375] systemd[1]: Created slice User and Session Slice.
    [    5.830754] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    5.854688] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    5.878628] systemd[1]: Expecting device /dev/ttyS2...
    [    5.894646] systemd[1]: Reached target Path Units.
    [    5.910608] systemd[1]: Reached target Remote File Systems.
    [    5.930599] systemd[1]: Reached target Slice Units.
    [    5.946605] systemd[1]: Reached target Swaps.
    [    5.981159] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    6.006683] systemd[1]: Reached target RPC Port Mapper.
    [    6.030260] systemd[1]: Listening on Process Core Dump Socket.
    [    6.050787] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    6.075111] systemd[1]: Listening on Journal Audit Socket.
    [    6.098886] systemd[1]: Listening on Journal Socket (/dev/log).
    [    6.118906] systemd[1]: Listening on Journal Socket.
    [    6.138942] systemd[1]: Listening on Network Service Netlink Socket.
    [    6.165883] systemd[1]: Listening on udev Control Socket.
    [    6.186852] systemd[1]: Listening on udev Kernel Socket.
    [    6.206873] systemd[1]: Listening on User Database Manager Socket.
    [    6.250763] systemd[1]: Mounting Huge Pages File System...
    [    6.272509] systemd[1]: Mounting POSIX Message Queue File System...
    [    6.298859] systemd[1]: Mounting Kernel Debug File System...
    [    6.304920] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    6.325519] systemd[1]: Mounting Temporary Directory /tmp...
    [    6.354978] systemd[1]: Starting Create List of Static Device Nodes...
    [    6.407134] systemd[1]: Starting Load Kernel Module configfs...
    [    6.415757] systemd[1]: Starting Load Kernel Module drm...
    [    6.457231] systemd[1]: Starting Load Kernel Module fuse...
    [    6.489704] drm: Unknown symbol from_kuid_munged (err -2)
    [    6.495050] systemd[1]: Starting Start psplash boot splash screen...
    [    6.507727] fuse: Unknown symbol make_kuid (err -2)
    [    6.512658] fuse: Unknown symbol put_pid_ns (err -2)
    [    6.514987] systemd[1]: Starting RPC Bind...
    [    6.517704] fuse: Unknown symbol from_kgid (err -2)
    [    6.526770] fuse: Unknown symbol from_kuid (err -2)
    [    6.531663] fuse: Unknown symbol current_in_userns (err -2)
    [    6.537302] fuse: Unknown symbol make_kgid (err -2)
    [    6.542311] fuse: Unknown symbol from_kgid_munged (err -2)
    [    6.551674] fuse: Unknown symbol __put_user_ns (err -2)
    [    6.556974] fuse: Unknown symbol from_kuid_munged (err -2)
    [    6.557458] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    6.598967] systemd[1]: Starting Journal Service...
    [    6.611833] ipv6: Unknown symbol make_kuid (err -2)
    [    6.617027] ipv6: Unknown symbol __put_net (err -2)
    [    6.622470] ipv6: Unknown symbol from_kuid_munged (err -2)
    [    6.633171] systemd[1]: Starting Load Kernel Modules...
    [    6.643399] systemd-journald[102]: Collecting audit messages is enabled.
    [    6.653047] ipv6: Unknown symbol make_kuid (err -2)
    [    6.663092] systemd[1]: Starting Generate network units from Kernel command line...
    [    6.672417] cryptodev: loading out-of-tree module taints kernel.
    [    6.674913] ipv6: Unknown symbol __put_net (err -2)
    [    6.686312] ipv6: Unknown symbol from_kuid_munged (err -2)
    [    6.707772] cryptodev: driver 1.13 loaded.
    [    6.721237] ipv6: Unknown symbol make_kuid (err -2)
    [    6.727380] ipv6: Unknown symbol __put_net (err -2)
    [    6.732284] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    6.739329] ipv6: Unknown symbol from_kuid_munged (err -2)
    [    6.763055] systemd[1]: Starting Coldplug All udev Devices...
    [    6.779253] EXT4-fs (mmcblk1p2): re-mounted b57c3b63-12a8-42de-8aac-e86cbb7e3fbc r/w. Quota mode: none.
    [    6.809138] systemd[1]: Started Journal Service.
    [    7.210813] systemd-journald[102]: Received client request to flush runtime journal.
    [    7.447928] audit: type=1334 audit(1709153336.328:2): prog-id=6 op=LOAD
    [    7.455467] audit: type=1334 audit(1709153336.336:3): prog-id=7 op=LOAD
    [    7.625667] audit: type=1334 audit(1709153336.504:4): prog-id=8 op=LOAD
    [    7.662969] audit: type=1334 audit(1709153336.540:5): prog-id=9 op=LOAD
    [    7.890602] audit: type=1334 audit(1709153336.768:6): prog-id=10 op=LOAD
    [    7.903645] audit: type=1334 audit(1709153336.768:7): prog-id=11 op=LOAD
    [    7.916113] audit: type=1334 audit(1709153336.768:8): prog-id=12 op=LOAD
    [    8.269568] drm: Unknown symbol from_kuid_munged (err -2)
    [    8.285568] CAN device driver interface
    [    8.315172] drm: Unknown symbol from_kuid_munged (err -2)
    [    8.343154] pinctrl-single 11c000.pinctrl: pin PIN164 already requested by 601000.gpio; cannot claim for 4104000.cdns-usb
    [    8.361458] pinctrl-single 11c000.pinctrl: pin-164 (4104000.cdns-usb) status -22
    [    8.375074] pinctrl-single 11c000.pinctrl: could not request pin 164 (PIN164) from group main-usbss0-default-pins  on device pinctrl-single
    [    8.388295] cdns3-ti 4104000.cdns-usb: Error applying setting, reverse things back
    [    8.391090] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [    8.407457] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode
    [    8.414696] remoteproc remoteproc0: 4d80800000.dsp is available
    [    8.429157] remoteproc remoteproc0: attaching to 4d80800000.dsp
    [    8.437442] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode
    [    8.450730] kfifo_buf: exports duplicate symbol iio_kfifo_allocate (owned by kernel)
    [    8.451346] rproc-virtio rproc-virtio.11.auto: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
    [    8.469296] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    8.472492] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    8.474885] rproc-virtio rproc-virtio.11.auto: registered virtio0 (type 7)
    [    8.488862] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached
    [    8.498760] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    8.516416] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode
    [    8.538047] remoteproc remoteproc1: 4d81800000.dsp is available
    [    8.545032] remoteproc remoteproc1: attaching to 4d81800000.dsp
    [    8.551062] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [    8.564653] kfifo_buf: exports duplicate symbol iio_kfifo_allocate (owned by kernel)
    [    8.570649] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode
    [    8.587981] rproc-virtio rproc-virtio.12.auto: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
    [    8.610213] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    8.615777] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [    8.625724] kfifo_buf: exports duplicate symbol iio_kfifo_allocate (owned by kernel)
    [    8.656812] rproc-virtio rproc-virtio.12.auto: registered virtio1 (type 7)
    [    8.663925] remoteproc remoteproc1: remote processor 4d81800000.dsp is now attached
    [    8.666731] mc: Linux media interface: v0.10
    [    8.683205] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [    8.700635] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [    8.707847] remoteproc remoteproc2: 64800000.dsp is available
    [    8.714707] remoteproc remoteproc2: attaching to 64800000.dsp
    [    8.720507] kfifo_buf: exports duplicate symbol iio_kfifo_allocate (owned by kernel)
    [    8.730955] audit: type=1334 audit(1709153337.612:9): prog-id=13 op=LOAD
    [    8.733244] remoteproc remoteproc2: unsupported resource 65538
    [    8.755599] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [    8.762649] rproc-virtio rproc-virtio.15.auto: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [    8.774280] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    8.776828] at24 0-0050: supply vcc not found, using dummy regulator
    [    8.784193] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    8.798282] rproc-virtio rproc-virtio.15.auto: registered virtio2 (type 7)
    [    8.816294] remoteproc remoteproc2: remote processor 64800000.dsp is now attached
    [    8.852631] videodev: Linux video capture interface: v2.00
    [    8.865039] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    8.924610] m_can_platform 40528000.can: registering can0 failed (err=-22)
    [    8.946770] m_can_platform: probe of 40528000.can failed with error -22
    [    8.950966] platform 41000000.r5f: configured R5F for IPC-only mode
    [    8.960484] m_can_platform 40568000.can: registering can0 failed (err=-22)
    [    8.982487] drm: Unknown symbol from_kuid_munged (err -2)
    [    8.987986] m_can_platform: probe of 40568000.can failed with error -22
    [    8.997319] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    9.010991] m_can_platform 2721000.can: registering can0 failed (err=-22)
    [    9.020713] dbus-broker-lau[295]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
    [    9.033005] remoteproc remoteproc3: 41000000.r5f is available
    [    9.042750] m_can_platform: probe of 2721000.can failed with error -22
    [    9.043562] remoteproc remoteproc3: attaching to 41000000.r5f
    [    9.061369] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    9.065509] yaxon update start...
    [    9.068920] rproc-virtio rproc-virtio.16.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    9.085653] virtio_rpmsg_bus virtio3: rpmsg host is online
    [    9.092419] Waiting for USB to be mounted...
    [    9.101106] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.101219] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
    [    9.123981] drm: Unknown symbol from_kuid_munged (err -2)
    [    9.131575] rproc-virtio rproc-virtio.16.auto: registered virtio3 (type 7)
    [    9.140473] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
    [    9.152631] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
    [    9.177740] platform 5c00000.r5f: configured R5F for remoteproc mode
    [    9.192968] img_enc 4200000.video-encoder: encoder registered as /dev/video1
    [    9.207397] img_dec 4300000.video-decoder: decoder registered as /dev/video0
    [    9.221008] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    9.235858] remoteproc remoteproc4: 5c00000.r5f is available
    [    9.253919] remoteproc remoteproc4: Direct firmware load for j7-main-r5f0_0-fw failed with error -2
    [    9.275827] remoteproc remoteproc4: powering up 5c00000.r5f
    [    9.294916] remoteproc remoteproc4: Direct firmware load for j7-main-r5f0_0-fw failed with error -2
    [    9.309972] remoteproc remoteproc4: request_firmware failed: -2
    [    9.368946] audit: type=1334 audit(1709153338.248:10): prog-id=14 op=LOAD
    [    9.386636] audit: type=1334 audit(1709153338.248:11): prog-id=15 op=LOAD
    [    9.423592] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    9.434222] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    9.434228] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    9.434231] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    9.467189] scsi host0: ufshcd
    [    9.489249] kfifo_buf: exports duplicate symbol iio_kfifo_allocate (owned by kernel)
    [    9.509736] kfifo_buf: exports duplicate symbol iio_kfifo_allocate (owned by kernel)
    [    9.533586] ipv6: Unknown symbol make_kuid (err -2)
    [    9.538788] remoteproc remoteproc5: b034000.pru is available
    [    9.542017] ipv6: Unknown symbol __put_net (err -2)
    [    9.567482] remoteproc remoteproc6: b004000.rtu is available
    [    9.577375] ipv6: Unknown symbol from_kuid_munged (err -2)
    [    9.586638] remoteproc remoteproc7: b00a000.txpru is available
    [    9.614485] ipv6: Unknown symbol make_kuid (err -2)
    [    9.624029] remoteproc remoteproc8: b038000.pru is available
    [    9.625283] ipv6: Unknown symbol __put_net (err -2)
    [    9.641889] ipv6: Unknown symbol from_kuid_munged (err -2)
    [    9.654607] remoteproc remoteproc9: b006000.rtu is available
    [    9.663623] remoteproc remoteproc10: b00c000.txpru is available
    [    9.678870] remoteproc remoteproc11: b134000.pru is available
    [    9.687033] remoteproc remoteproc12: b104000.rtu is available
    [    9.695081] remoteproc remoteproc13: b10a000.txpru is available
    [    9.715670] remoteproc remoteproc14: b138000.pru is available
    [    9.723763] remoteproc remoteproc15: b106000.rtu is available
    [    9.730444] remoteproc remoteproc16: b10c000.txpru is available
    [    9.887984] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [    9.893558] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [    9.899482] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [    9.905813] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [    9.912297] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [    9.919291] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [    9.925951] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [    9.932387] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [    9.936966] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [    9.945320] cdns-ufshcd 4e84000.ufs: last intr at 9887967 us, last intr status=0x404
    [    9.953111] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [    9.960615] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [    9.969700] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [    9.975734] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [    9.982084] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [    9.988467] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [   10.000038] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    [   10.009996] host_regs: 00000010: 00000000 00000000 00000000 00000000
    [   10.016403] host_regs: 00000020: 00000000 00000470 00000000 00000000
    [   10.022895] host_regs: 00000030: 00000008 00000001 00000000 00000000
    [   10.029274] host_regs: 00000040: 00000000 00000000 00000000 00000000
    [   10.036083] host_regs: 00000050: 00000000 00000000 00000000 00000000
    [   10.042468] host_regs: 00000060: 00000000 00000000 00000000 00000000
    [   10.048881] host_regs: 00000070: 00000000 00000000 00000000 00000000
    [   10.055492] host_regs: 00000080: 00000000 00000000 00000000 00000000
    [   10.061873] host_regs: 00000090: 00000016 00000000 00000001 00000000
    [   10.068472] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [   10.073830] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [   10.079188] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [   10.084553] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [   10.089944] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [   10.095394] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [   10.101633] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [   10.107265] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 9887978 us
    [   10.114456] cdns-ufshcd 4e84000.ufs: link_startup_fail: total cnt=1
    [   10.120972] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [   10.126769] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [   10.132635] cdns-ufshcd 4e84000.ufs: No record of wlun resume_fail
    [   10.138852] cdns-ufshcd 4e84000.ufs: No record of wlun suspend_fail
    [   10.145736] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [   10.151329] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [   10.157034] cdns-ufshcd 4e84000.ufs: No record of task_abort
    [   10.162956] cdns-ufshcd 4e84000.ufs: ufshcd_async_scan failed: 1
    [   10.166819] Update script not found
    [   10.173961] yaxon update end
    [   10.195481] xhci-hcd xhci-hcd.17.auto: xHCI Host Controller
    [   10.218531] xhci-hcd xhci-hcd.17.auto: new USB bus registered, assigned bus number 1
    [   10.227162] xhci-hcd xhci-hcd.17.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000008010
    [   10.239371] bluetooth: Unknown symbol from_kuid (err -2)
    [   10.244775] xhci-hcd xhci-hcd.17.auto: irq 840, io mem 0x06410000
    [   10.251040] bluetooth: Unknown symbol from_kgid_munged (err -2)
    [   10.252692] cfg80211: Unknown symbol __put_net (err -2)
    [   10.257119] bluetooth: Unknown symbol from_kuid_munged (err -2)
    [   10.268020] cfg80211: Unknown symbol get_net_ns_by_fd (err -2)
    [   10.268610] xhci-hcd xhci-hcd.17.auto: xHCI Host Controller
    [   10.279638] xhci-hcd xhci-hcd.17.auto: new USB bus registered, assigned bus number 2
    [   10.287471] xhci-hcd xhci-hcd.17.auto: Host supports USB 3.0 SuperSpeed
    [   10.310962] hub 1-0:1.0: USB hub found
    [   10.329597] hub 1-0:1.0: 1 port detected
    [   10.350257] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [   10.359097] hub 2-0:1.0: USB hub found
    [   10.363427] hub 2-0:1.0: 1 port detected
    [   10.543548] ipv6: Unknown symbol make_kuid (err -2)
    [   10.549383] ipv6: Unknown symbol __put_net (err -2)
    [   10.554526] ipv6: Unknown symbol from_kuid_munged (err -2)
    [   10.632443] overlay: Unknown symbol from_kgid (err -2)
    [   10.647233] overlay: Unknown symbol from_kuid (err -2)
    [   11.362588] k3_r5_rproc bus@100000:r5fss@5c00000: Timed out waiting for 5c00000.r5f core to power up!
    [   11.375044] platform 5e00000.r5f: configured R5F for remoteproc mode
    [   11.381945] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [   11.391760] remoteproc remoteproc17: 5e00000.r5f is available
    [   11.429154] remoteproc remoteproc17: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
    [   11.438357] remoteproc remoteproc17: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
    [   11.447610] remoteproc remoteproc17: powering up 5e00000.r5f
    [   11.453351] remoteproc remoteproc17: loading /lib/firmware/j7-main-r5f1_0-fw failed with error -22
    [   11.462481] remoteproc remoteproc17: Direct firmware load for j7-main-r5f1_0-fw failed with error -22
    [   11.471715] remoteproc remoteproc17: request_firmware failed: -22
    [   11.939216] ipv6: Unknown symbol make_kuid (err -2)
    [   11.944606] ipv6: Unknown symbol __put_net (err -2)
    [   11.949837] ipv6: Unknown symbol from_kuid_munged (err -2)
    [   13.410568] k3_r5_rproc bus@100000:r5fss@5e00000: Timed out waiting for 5e00000.r5f core to power up!
    [   23.427174] platform 2900000.pcie: deferred probe pending
    [   23.432584] platform 2910000.pcie: deferred probe pending
    [   23.437975] platform 2920000.pcie: deferred probe pending
    [   23.443366] platform can-phy2: deferred probe pending
    [   23.448409] platform 2701000.can: deferred probe pending
    [   23.453711] platform regulator-dp-pwr: deferred probe pending
    [   26.985969] kauditd_printk_skb: 8 callbacks suppressed
    [   26.985975] audit: type=1006 audit(1709153355.864:16): pid=826 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
    [   27.003917] audit: type=1300 audit(1709153355.864:16): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff3fb1518 a2=1 a3=1 items=0 ppid=1 pid=826 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
    [   27.031037] audit: type=1327 audit(1709153355.864:16): proctitle="(systemd)"
    [   27.038371] audit: type=1334 audit(1709153355.872:17): prog-id=18 op=LOAD
    [   27.045470] audit: type=1300 audit(1709153355.872:17): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffdcf7f0a8 a2=90 a3=0 items=0 ppid=1 pid=826 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   27.071447] audit: type=1327 audit(1709153355.872:17): proctitle="(systemd)"
    [   27.078767] audit: type=1334 audit(1709153355.884:18): prog-id=18 op=UNLOAD
    [   27.086008] audit: type=1300 audit(1709153355.884:18): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffa342bc60 items=0 ppid=1 pid=826 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
    [   27.111713] audit: type=1327 audit(1709153355.884:18): proctitle="(systemd)"
    [   27.118897] audit: type=1334 audit(1709153355.884:19): prog-id=19 op=LOAD
    Can you dump below register details, and share with us.
    # devmem2 0x0500e000
    # devmem2 0x05000404
    # devmem2 0x05000408
    # devmem2 0x0500040C
    # devmem2 0x05000480
    # devmem2 0x05000484
    # devmem2 0x05000488
    # devmem2 0x0500048C
    Sudheer
    Reading these registers results in the following.
    root@j721e-evm:~# devmem2 0x0500e000
    /dev/mem opened.
    Memory mapped at address 0xffffb3221000.
    Read at address 0x0500E000 (0xffffb3221000): 0x00003010
    root@j721e-evm:~# devmem2 0x05000404
    /dev/mem opened.
    Memory mapped at address 0xffffa8489000.
    Read at address 0x05000404 (0xffffa8489404): 0x00000000
    root@j721e-evm:~# devmem2 0x05000408
    /dev/mem opened.
    Memory mapped at address 0xffffb863d000.
    Read at address 0x05000408 (0xffffb863d408): 0x9A000000
    root@j721e-evm:~# devmem2 0x0500040C
    /dev/mem opened.
    Memory mapped at address 0xffff9afd3000.
    Read at address 0x0500040C (0xffff9afd340c): 0x92000000
    root@j721e-evm:~# devmem2 0x05000480
    /dev/mem opened.
    Memory mapped at address 0xffffb7a17000.
    Read at address 0x05000480 (0xffffb7a17480): 0x70800000
    root@j721e-evm:~# devmem2 0x05000484
    /dev/mem opened.
    Memory mapped at address 0xffffb9447000.
    Read at address 0x05000484 (0xffffb9447484): 0x00010002
    root@j721e-evm:~# devmem2 0x05000488
    /dev/mem opened.
    Memory mapped at address 0xffffa32aa000.
    Read at address 0x05000488 (0xffffa32aa488): 0x00000000
    root@j721e-evm:~# devmem2 0x0500048c
    /dev/mem opened.
    Memory mapped at address 0xffffbe74f000.
    Read at address 0x0500048C (0xffffbe74f48c): 0x00000002
    root@j721e-evm:~#
    root@j721e-evm:~#
    /dev/mem opened.
    It seems like PLL is not locked.
    But, clock information of SerDes is same in TI EVM.
    Can you check whether "CONFIG_PHY_J721E_WIZ" enabled in your case.
    Sudheer
    I have checked the configuration file and CONFIG_PHY_J721E_WIZ has been enabled.
    board-support/ti-linux-kernel-6.6.32+git-ti/.config:
    Are there any other configurations to check? Please help to analyze it again,thank you.
    It would be fine, for SerDes configuration.
    If possible can you please check with SDK 9.2 once. Means while will check PLL locking on 10.0 SDK.
    Sudheer
  • Hi Sudheer,
    I have seen a problem similar to the one I encountered, which SDK version was used and how was it resolved?
    TDA4VM: Using TDA4's CPSW9G, connecting to phy chip, link fails. - Processors forum - Processors - TI E2E support forums
    Using SDK 9.2 I need to make a lot of modifications that I will try.
    I see you have suggested using "serdes-phy", what is the difference between "serdes" and "serdes-phy"?
    And, Is there a problem that we do not use the REFCLK in serdes0?This is different from the TIEVM design.
    It is CPSW Driver specific, to configure SerDes, "serdes" is used in am65-cpsw-nuss driver.
    Can you please try to integrate the Cadence Sierra patch and check once.
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/7776.0001_2D00_phy_2D00_cadence_2D00_Sierra_2D00_Add_2D00_Single_2D00_link_2D00_SGMII_2D00_PHY_2D00_configu.patch
    After integrating the patch, Build Linux and copy image to SD card root partition.
    Sudheer
  • Hi Sudheer,
    I have solved this problem using the following configuration. Thank you!
    1.phy-names = "portmode", "serdes-phy";
    2.
    &wiz0_pll1_refclk {
    	assigned-clocks = <&wiz0_pll1_refclk>;
    	assigned-clock-parents = <&k3_clks 292 0>;
    &wiz0_pll1_refclk {
    Thanks for the update and I could see by default  "wiz0_pll1_refclk" was set with above configuration.
    Sudheer
    In addition to the k3-j721e-main.dtsi, k3-j721e-common-proc-board.dts also has the wiz0_pll1_refclk configuration.
    &wiz0_pll1_refclk {
    	assigned-clock-parents = <&cmn_refclk1>;
  • HI,
    Thank you for the details.
    Will be closing this thread.
    If you need any help, please create new thread.
    Sudheer
