We recently changed memory from MT53D1024M32D4DT-046AATD to MT53E1G32D2FW-046 AAT: B.
However, only 1.6GB of memory is recognized in 4GB's MT53E1G32D2FW-046 AAT: B.
Can you tell me the points we need to check?
We are using the SDK Linux provided by Ti.
Thanks.
Jungin
Can you share the complete U-Boot/SPL boot logs?
Can you share the patch if any applied for the specific part?
- Kerthy
boot mode: 0 U-Boot 2020.01 (Feb 16 2024 - 12:03:12 +0900) *** Warning - bad CRC, using default environment Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0(part 0) is current device SD/MMC found on device 0 ** Unrecognized filesystem type ** 3938712 bytes read in 78 ms (48.2 MiB/s) Load Remote Processor 2 with data@addr=0x82000000 3938712 bytes: Success! 1968128 bytes read in 62 ms (30.3 MiB/s) Load Remote Processor 3 with data@addr=0x82000000 1968128 bytes: Success! 210796 bytes read in 12 ms (16.8 MiB/s) Load Remote Processor 4 with data@addr=0x82000000 210796 bytes: Success! 157548 bytes read in 12 ms (12.5 MiB/s) Load Remote Processor 5 with data@addr=0x82000000 157548 bytes: Success! 1382480 bytes read in 22 ms (59.9 MiB/s) Load Remote Processor 6 with data@addr=0x82000000 1382480 bytes: Success! 1382480 bytes read in 30 ms (43.9 MiB/s) Load Remote Processor 7 with data@addr=0x82000000 1382480 bytes: Success! 9998320 bytes read in 42 ms (227 MiB/s) Load Remote Processor 8 with data@addr=0x82000000 9998320 bytes: Success! 12433416 bytes read in 178 ms (66.6 MiB/s) 92907 bytes read in 8 ms (11.1 MiB/s) 10974 bytes read in 2 ms (5.2 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008fee6000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.4.106 (eintelligence@97ed533f89ce) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 SMP PREEMPT Fri Feb 16 12:03:24 KST 2024 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 576 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 1024 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] cma: Failed to reserve 512 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] percpu: Embedded 2 pages/cpu s48088 r8192 d74792 u131072 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] Built 1 zonelists, mobility grouping off. Total pages: 46400 [ 0.000000] Kernel command line: root_part=0:2 boot_part=0:5 app_part=0:6 console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=65696e74-656c-6c69-6765-6e63650d0a02 ro rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x9a800000-0x9e800000] (64MB) [ 0.000000] Memory: 1539712K/2973696K available (7166K kernel code, 686K rwdata, 2752K rodata, 1152K init, 598K bss, 1433984K reserved, 0K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: no VLPI support, no direct LPI support [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008c00c0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c00d0000 [ 0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x42c with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.010477] Console: colour dummy device 80x25 [ 0.016188] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.029524] pid_max: default: 32768 minimum: 301 [ 0.035463] LSM: Security Framework initializing [ 0.041408] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.050877] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear) [ 0.062430] ASID allocator initialised with 32768 entries [ 0.069427] rcu: Hierarchical SRCU implementation. [ 0.075760] Platform MSI: gic-its@1820000 domain created [ 0.083038] smp: Bringing up secondary CPUs ... [ 0.089822] Detected PIPT I-cache on CPU1 [ 0.089856] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.089871] GICv3: CPU1: using allocated LPI pending table @0x00000008c00e0000 [ 0.089907] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.089977] smp: Brought up 1 node, 2 CPUs [ 0.126658] SMP: Total of 2 processors activated. [ 0.132663] CPU features: detected: 32-bit EL0 Support [ 0.139230] CPU features: detected: CRC32 instructions [ 0.153114] CPU: All CPU(s) started at EL2 [ 0.158361] alternatives: patching kernel code [ 0.164850] devtmpfs: initialized [ 0.175724] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.188187] futex hash table entries: 512 (order: -1, 32768 bytes, linear) [ 0.197436] pinctrl core: initialized pinctrl subsystem [ 0.204742] NET: Registered protocol family 16 [ 0.210694] DMA: preallocated 256 KiB pool for atomic allocations [ 0.218779] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.234584] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages [ 0.243155] HugeTLB registered 512 MiB page size, pre-allocated 0 pages [ 0.251602] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.261238] cryptd: max_cpu_qlen set to 1000 [ 0.268968] vsys_3v3: supplied by evm_12v0 [ 0.274334] vsys_5v0: supplied by evm_12v0 [ 0.279719] iommu: Default domain type: Translated [ 0.286171] SCSI subsystem initialized [ 0.291141] mc: Linux media interface: v0.10 [ 0.296602] videodev: Linux video capture interface: v2.00 [ 0.303615] EDAC MC: Ver: 3.0.0 [ 0.308661] clocksource: Switched to clocksource arch_sys_counter [ 0.319440] Carveout Heap: Exported 512 MiB at 0x00000000b8000000 [ 0.327235] thermal_sys: Registered thermal governor 'step_wise' [ 0.327236] thermal_sys: Registered thermal governor 'power_allocator' [ 0.335301] NET: Registered protocol family 2 [ 0.349633] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear) [ 0.360589] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear) [ 0.370833] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear) [ 0.380596] TCP: Hash tables configured (established 32768 bind 32768) [ 0.389034] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.397645] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear) [ 0.406914] NET: Registered protocol family 1 [ 0.412946] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 0.425519] Initialise system trusted keyrings [ 0.431301] workingset: timestamp_bits=46 max_order=15 bucket_order=0 [ 0.442217] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.458425] Key type asymmetric registered [ 0.463660] Asymmetric key parser 'x509' registered [ 0.469907] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250) [ 0.479355] io scheduler mq-deadline registered [ 0.485136] io scheduler kyber registered [ 0.491248] pinctrl-single 4301c000.pinmux: 94 pins, size 376 [ 0.498839] pinctrl-single 11c000.pinmux: 173 pins, size 692 [ 0.507277] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.515100] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.524337] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.539034] brd: module loaded [ 0.547257] loop: module loaded [ 0.551989] i2c /dev entries driver [ 0.556910] sdhci: Secure Digital Host Controller Interface driver [ 0.564802] sdhci: Copyright(c) Pierre Ossman [ 0.570491] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.578780] NET: Registered protocol family 17 [ 0.584488] Key type dns_resolver registered [ 0.590142] registered taskstats version 1 [ 0.595381] Loading compiled-in X.509 certificates [ 0.603652] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.611522] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.620029] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.1.1--v2021.01a (Terrific Lla') [ 0.654058] random: fast init done [ 0.673507] omap_i2c 40b10000.i2c: bus 0 rev0.12 at 100 kHz [ 0.681138] omap_i2c 42120000.i2c: bus 1 rev0.12 at 100 kHz [ 0.688732] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz [ 0.696189] omap_i2c 2040000.i2c: bus 3 rev0.12 at 100 kHz [ 0.703681] omap_i2c 2050000.i2c: bus 4 rev0.12 at 100 kHz [ 0.711374] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 0.723895] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [ 0.734976] ti-sci-intr bus@100000:navss@30000000:interrupt-controller1: Interrupt Router 213 domain created [ 0.747817] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain -1 created [ 0.760328] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 0.772684] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 0.781132] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 0.792451] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 0.805144] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 0.813592] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 0.823525] printk: console [ttyS2] disabled [ 0.829006] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 15, base_baud = 3000000) is a 8250 [ 0.839932] printk: console [ttyS2] enabled [ 0.839932] printk: console [ttyS2] enabled [ 0.850480] printk: bootconsole [ns16550a0] disabled [ 0.850480] printk: bootconsole [ns16550a0] disabled [ 0.863606] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 16, base_baud = 3000000) is a 8250 [ 0.874694] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001f8f) [ 0.886910] arm-smmu-v3 36600000.smmu: allocated 524288 entries for cmdq [ 0.900397] arm-smmu-v3 36600000.smmu: allocated 524288 entries for evtq [ 0.910428] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs [ 0.921400] mmc0: CQHCI version 5.10 [ 0.966848] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit [ 0.981207] GPIO line 326 (DP_POWER_EN) hogged as output/high [ 0.992093] vdd_mmc1: supplied by vsys_3v3 [ 0.997853] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 1.006446] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 1.015040] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 1.023681] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 1.032331] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 1.044158] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 1.057380] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16) [ 1.071731] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 1.081004] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 1.090138] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 1.099281] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 1.120645] Waiting for root device PARTUUID=65696e74-656c-6c69-6765-6e63650d0a02... [ 1.196699] mmc0: Command Queue Engine enabled [ 1.202252] mmc0: new HS200 MMC card at address 0001 [ 1.208950] mmcblk0: mmc0:0001 DG4008 7.28 GiB [ 1.214790] mmcblk0boot0: mmc0:0001 DG4008 partition 1 4.00 MiB [ 1.222348] mmcblk0boot1: mmc0:0001 DG4008 partition 2 4.00 MiB [ 1.229844] mmcblk0rpmb: mmc0:0001 DG4008 partition 3 4.00 MiB, chardev (248:0) [ 1.241308] GPT:Primary header thinks Alt. header is not at the end of the disk. [ 1.250539] GPT:15269887 != 15273599 [ 1.254992] GPT:Alternate GPT header not at the end of the disk. [ 1.262479] GPT:15269887 != 15273599 [ 1.266932] GPT: Use GNU Parted to correct GPT errors. [ 1.273351] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 [ 1.296756] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 1.306913] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [ 1.315746] devtmpfs: mounted [ 1.319924] Freeing unused kernel memory: 1152K [ 1.325603] Run /sbin/init as init process [ 1.386747] systemd[1]: System time before build time, advancing clock. [ 1.408733] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 1.435620] systemd[1]: Detected architecture arm64. Welcome to Arago 2019.11! [ 1.485095] systemd[1]: Set hostname to <j7-evm>. [ 1.493810] random: systemd: uninitialized urandom read (16 bytes read) [ 1.502083] systemd[1]: Initializing machine ID from random generator. [ 1.510354] systemd[1]: Installed transient /etc/machine-id file. [ 1.609412] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ 1.630723] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 1.650488] systemd[1]: /etc/systemd/system/systemd-udevd.service:30: Unknown lvalue 'ProtectHostname' in section 'Service' [ 1.664405] systemd[1]: /etc/systemd/system/systemd-udevd.service:34: Unknown lvalue 'RestrictSUIDSGID' in section 'Service' [ 1.712834] systemd[1]: /lib/systemd/system/network-rndis.service:9: Unknown lvalue 'LimitCore' in section 'Service' [ 1.759160] random: systemd: uninitialized urandom read (16 bytes read) [ OK ] Reached target Swap. [ 1.776783] random: systemd: uninitialized urandom read (16 bytes read) [ OK ] Listening on udev Kernel Socket. [ OK ] Listening on Process Core Dump Socket. [ OK ] Listening on initctl Compatibility Named Pipe. [ OK ] Reached target Remote File Systems. [ OK ] Created slice system-getty.slice. [ OK ] Listening on Network Service Netlink Socket. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ OK ] Reached target Paths. [ OK ] Listening on udev Control Socket. [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Created slice User and Session Slice. [ OK ] Reached target Slices. [ OK ] Created slice system-serial\x2dgetty.slice. [ OK ] Listening on Journal Socket. Mounting Kernel Debug File System... Starting Remount Root and Kernel File Systems... [ 2.028638] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Mounting Huge Pages File System... [ OK ] Started Hardware RNG Entropy Gatherer Daemon. Mounting Temporary Directory (/tmp)... Starting udev Coldplug all Devices... Mounting POSIX Message Queue File System... Starting Journal Service... Starting Dual partition... [ OK ] Started Journal Service. [ OK ] Mounted Kernel Debug File System. [ OK ] Started Remount Root and Kernel File Systems.[ 2.194718] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null) [ 2.216554] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null) [ OK ] Mounted Huge Pages File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Mounted POSIX Message Queue File System. [ OK ] Started Dual partition. Starting Load Kernel Modules... Starting Create Static Device Nodes in /dev... Starting Flush Journal to Persistent Storage... [ 2.358739] udc-core: couldn't find an available UDC - added [g_ether] to list of pending drivers [ OK ] Started Create Static Device Nodes in /dev. [ 2.382801] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 2.401694] systemd-journald[135]: Received request to flush runtime journal from PID 1 [ OK ] [ 2.411981] platform 41000000.r5f: configured R5F for IPC-only mode Started udev Coldplug all Devices. [ 2.422308] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 2.437587] remoteproc remoteproc0: 41000000.r5f is available [ 2.447146] platform 5c00000.r5f: configured R5F for IPC-only mode [ 2.455311] remoteproc remoteproc0: powering up 41000000.r5f [ 2.455324] remoteproc remoteproc0: Booting fw image j7-mcu-r5f0_0-fw, size 318396 [ 2.455545] platform 41000000.r5f: R5F core initialized in IPC-only mode [ 2.455558] remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 2.456323] virtio_rpmsg_bus virtio0: rpmsg host is online [ 2.456353] remoteproc0#vdev0buffer: registered virtio0 (type 7) [ 2.456358] remoteproc remoteproc0: remote processor 41000000.r5f is now up [[ 2.456467] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 2.456594] remoteproc remoteproc1: 5c00000.r5f is available OK [ 2.475211] platform 5d00000.r5f: configured R5F for IPC-only mode ] Started Flush Journal to Persistent Storage. [ 2.546903] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 2.564101] remoteproc remoteproc2: 5d00000.r5f is available [ 2.574352] remoteproc remoteproc1: powering up 5c00000.r5f [ OK ] Reached target Local File Systems (Pre). [ 2.581887] remoteproc remoteproc1: Booting fw image j7-main-r5f0_0-fw, size 3938712 [ 2.583567] platform 5e00000.r5f: configured R5F for IPC-only mode [ 2.599456] platform 5c00000.r5f: R5F core initialized in IPC-only mode [ 2.615383] remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 2.618561] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x21 [ 2.633021] remoteproc remoteproc2: powering up 5d00000.r5f [ 2.637978] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000 [ 2.643101] remoteproc remoteproc2: Booting fw image j7-main-r5f0_1-fw, size 1968128 [ 2.664720] remoteproc remoteproc3: 5e00000.r5f is available [ 2.664768] virtio_rpmsg_bus virtio1: rpmsg host is online Mounting /var/volatile... [ 2.679323] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd [ 2.679454] platform 5d00000.r5f: R5F core initialized in IPC-only mode [ 2.699274] remoteproc1#vdev0buffer: registered virtio1 (type 7) [ 2.703017] remoteproc remoteproc3: powering up 5e00000.r5f [ 2.706907] remoteproc remoteproc1: remote processor 5c00000.r5f is now up [ 2.715080] platform 5f00000.r5f: configured R5F for IPC-only mode [ 2.722448] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 2.735435] remoteproc remoteproc3: Booting fw image j7-main-r5f1_0-fw, size 210796 [ 2.742808] virtio_rpmsg_bus virtio2: rpmsg host is online [ 2.752507] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000 [ 2.758913] remoteproc2#vdev0buffer: registered virtio2 (type 7) [ 2.770499] platform 5e00000.r5f: R5F core initialized in IPC-only mode [ 2.779864] remoteproc remoteproc2: remote processor 5d00000.r5f is now up [ 2.786688] remoteproc remoteproc4: 5f00000.r5f is available [ 2.801331] remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000 Starting udev Kernel Device Manager... [ 2.816207] virtio_rpmsg_bus virtio3: rpmsg host is online [ 2.816692] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000 [ 2.826505] remoteproc3#vdev0buffer: registered virtio3 (type 7) [ 2.846594] remoteproc remoteproc3: remote processor 5e00000.r5f is now up [ 2.855230] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode [ 2.855313] remoteproc remoteproc5: 4d80800000.dsp is available [ 2.864125] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd [ OK [ 2.880734] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd [ 2.882230] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000 ] Mounted /var/volatile. [ 2.891154] remoteproc remoteproc4: powering up 5f00000.r5f [ 2.903742] remoteproc remoteproc5: powering up 4d80800000.dsp [ 2.915102] remoteproc remoteproc4: Booting fw image j7-main-r5f1_1-fw, size 157548 [ 2.929940] platform 5f00000.r5f: R5F core initialized in IPC-only mode [ 2.938607] remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000 [ 2.940716] remoteproc remoteproc5: Booting fw image j7-c66_0-fw, size 1382480 [ 2.954789] virtio_rpmsg_bus virtio4: rpmsg host is online [ 2.961879] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode [ 2.967613] remoteproc4#vdev0buffer: registered virtio4 (type 7) [ 2.974744] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode [ 2.974806] remoteproc remoteproc6: 4d81800000.dsp is available [ 2.983355] remoteproc remoteproc4: remote processor 5f00000.r5f is now up [ 2.995485] remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000 [ 3.000613] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd [ 3.009601] virtio_rpmsg_bus virtio5: rpmsg host is online [ 3.021133] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd [ 3.028494] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000 [ 3.052800] overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off. [ 3.055997] remoteproc5#vdev0buffer: registered virtio5 (type 7) Starting Bind mount volatile /var/lib... [ 3.074460] remoteproc remoteproc5: remote processor 4d80800000.dsp is now up [ 3.088601] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode [ 3.096981] remoteproc remoteproc7: 64800000.dsp is available Starting Bind mount volatile /srv... Starting Bind mount volatile /var/cache... [ 3.142097] remoteproc remoteproc6: powering up 4d81800000.dsp [ 3.156908] remoteproc remoteproc6: Booting fw image j7-c66_1-fw, size 1382480 [ 3.157076] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode [ 3.169517] overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off. [ 3.188232] remoteproc remoteproc7: powering up 64800000.dsp [ 3.204785] remoteproc remoteproc7: Booting fw image j7-c71_0-fw, size 9998320 [ 3.208631] overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off. [ 3.215279] remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000 [ 3.228125] overlayfs: upper fs does not support xattr, falling back to index=off and metacopy=off. Starting Bind mount volatile /var/spool... [ 3.256827] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode [ OK ] Started udev Kernel Device Manager. [ 3.278496] remoteproc7#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000 [ OK ] Started Load Kernel Modules.[ 3.302835] virtio_rpmsg_bus virtio6: rpmsg host is online [ 3.308920] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd [ 3.319879] remoteproc6#vdev0buffer: registered virtio6 (type 7) [ 3.327503] remoteproc remoteproc6: remote processor 4d81800000.dsp is now up [ OK ] Started Bind mount volatile /var/lib. [ 3.340533] virtio_rpmsg_bus virtio7: rpmsg host is online [ 3.344497] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd [ 3.350953] remoteproc7#vdev0buffer: registered virtio7 (type 7) [ 3.366583] remoteproc remoteproc7: remote processor 64800000.dsp is now up [ 3.373044] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15 [ OK ] Started Bind mount volatile /srv. [ 3.393377] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe [ OK ] Started Bind mount volatile /var/cache. [ 3.411694] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15 [ OK ] Started Bind mount volatile /var/spool. [ 3.433040] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. [ 3.461193] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15 Starting Create Volatile Files and Directories... [ 3.488301] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe [ 3.505422] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15 Mounting Kernel Configuration File System... [ 3.517544] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe Starting Apply Kernel Variables... [ 3.539658] rti-wdt 2200000.watchdog: heartbeat 60 sec [ OK ] Started Load/Save Random Seed. [ 3.550598] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15 [ OK ] Started Create Volatile Files and Directories[ 3.569590] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe . [ 3.585571] cdns-mhdp a000000.dp-bridge: no PHY configured [ 3.592640] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15 [ OK ] Mounted Kernel Configuration File System. [ 3.602756] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x21 [ OK ] Started Apply Kernel Variables. [ OK ] Found device /dev/ttyS2. [ 3.634552] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe [ 3.661325] rti-wdt 2210000.watchdog: heartbeat 60 sec [ 3.668298] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15 Starting Network Service... [ 3.686170] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x21 Starting Network Time Synchronization... [ 3.712451] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe [ OK ] Started Network Service. [ 3.728821] cdns-mhdp a000000.dp-bridge: no PHY configured [ OK ] Reached target Network. [ 3.769272] cdns-mhdp a000000.dp-bridge: no PHY configured [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Synchronized. [ OK ] Reached target System Initialization. [ OK ] Started Daily rotation of log files. [ OK ] Listening on RPCbind Server Activation Socket. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Listening on dropbear.socket. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. Starting Permit User Sessions... [ OK ] Started Checking of th rndis usb0 iface. Starting RPC Bind Service... [ OK ] Started HW Version Check.... Starting GENIVI DLT Logging daemon... [ OK ] Started D-Bus System Message Bus. Starting Login Service... Starting Reboot and dump vmcore via kexec... [ OK ] Started irqbalance daemon. [ OK ] Started Permit User Sessions. [ OK ] Started Reboot and dump vmcore via kexec. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Reached target Login Prompts. [ 4.271550] NET: Registered protocol family 10 [ 4.282294] EXT4-fs (mmcblk0p8): recovery complete [ 4.293414] Segment Routing with IPv6 [ 4.315073] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null) [ OK ] Started Login Service. [ OK ] Started RPC Bind Service. RootFS Partition Version = 7.0.2 BOOT Partition Version = 7.0.2 APP Partition Version = 7.0.2 HW Version = REV_C.05 Release Version = 1.00.09 Internal Version = VFe34_SOP_1.00.09_r22 [ OK ] Started GENIVI DLT Logging daemon. [ OK ] Reached target Multi-User System. [ OK ] Started Erae VF Application. _rpmsg_char_find_rproc: 41400000.r5f is either not probed or not a remoteproc! _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio1.rpmsg_chrdev.-1.33 _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio2.rpmsg_chrdev.-1.33 _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org j7-evm ttyS2 Arago 2020.05 j7-evm ttyS2 j7-evm login: [ 6.559217] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c [ 6.559272] random: crng init done [ 6.571833] cdns-mhdp a000000.dp-bridge: no PHY configured [ 6.578360] random: 7 urandom warning(s) missed due to ratelimiting [ 7.165841] cdns-usb3 6000000.usb: DRD version v1 (ID: 0004024e, rev: 00000200) [ 7.965442] cdns-mhdp a000000.dp-bridge: no PHY configured [ 7.970887] cdns-usb3 6400000.usb: DRD version v1 (ID: 0004024e, rev: 00000200) [ 7.981679] cdns-usb3 6400000.usb: Initialized ep0 support: [ 7.988978] cdns-usb3 6400000.usb: Initialized ep1out support: BULK, INT ISO [ 7.998174] cdns-usb3 6400000.usb: Initialized ep2out support: BULK, INT ISO [ 8.007129] cdns-usb3 6400000.usb: Initialized ep3out support: BULK, INT ISO [ 8.016050] cdns-usb3 6400000.usb: Initialized ep4out support: BULK, INT ISO [ 8.024958] cdns-usb3 6400000.usb: Initialized ep5out support: BULK, INT ISO [ 8.033870] cdns-usb3 6400000.usb: Initialized ep6out support: BULK, INT ISO [ 8.042774] cdns-usb3 6400000.usb: Initialized ep7out support: BULK, INT ISO [ 8.051685] cdns-usb3 6400000.usb: Initialized ep8out support: BULK, INT ISO [ 8.060590] cdns-usb3 6400000.usb: Initialized ep9out support: BULK, INT ISO [ 8.069511] cdns-usb3 6400000.usb: Initialized ep10out support: BULK, INT ISO [ 8.078647] cdns-usb3 6400000.usb: Initialized ep11out support: BULK, INT ISO [ 8.087686] cdns-usb3 6400000.usb: Initialized ep12out support: BULK, INT ISO [ 8.096715] cdns-usb3 6400000.usb: Initialized ep13out support: BULK, INT ISO [ 8.105737] cdns-usb3 6400000.usb: Initialized ep14out support: BULK, INT ISO [ 8.114756] cdns-usb3 6400000.usb: Initialized ep15out support: BULK, INT ISO [ 8.123777] cdns-usb3 6400000.usb: Initialized ep1in support: BULK, INT ISO [ 8.132592] cdns-usb3 6400000.usb: Initialized ep2in support: BULK, INT ISO [ 8.141392] cdns-usb3 6400000.usb: Initialized ep3in support: BULK, INT ISO [ 8.150194] cdns-usb3 6400000.usb: Initialized ep4in support: BULK, INT ISO [ 8.158992] cdns-usb3 6400000.usb: Initialized ep5in support: BULK, INT ISO [ 8.167788] cdns-usb3 6400000.usb: Initialized ep6in support: BULK, INT ISO [ 8.176585] cdns-usb3 6400000.usb: Initialized ep7in support: BULK, INT ISO [ 8.185385] cdns-usb3 6400000.usb: Initialized ep8in support: BULK, INT ISO [ 8.194183] cdns-usb3 6400000.usb: Initialized ep9in support: BULK, INT ISO [ 8.203002] cdns-usb3 6400000.usb: Initialized ep10in support: BULK, INT ISO [ 8.211921] cdns-usb3 6400000.usb: Initialized ep11in support: BULK, INT ISO [ 8.220830] cdns-usb3 6400000.usb: Initialized ep12in support: BULK, INT ISO [ 8.229736] cdns-usb3 6400000.usb: Initialized ep13in support: BULK, INT ISO [ 8.238646] cdns-usb3 6400000.usb: Initialized ep14in support: BULK, INT ISO [ 8.247550] cdns-usb3 6400000.usb: Initialized ep15in support: BULK, INT ISO [ 8.256637] using random self ethernet address [ 8.262194] using random host ethernet address [ 8.268159] usb0: HOST MAC a6:84:f7:54:55:4f [ 8.273594] usb0: MAC 0a:1b:7a:ac:59:9a [ 8.278419] using random self ethernet address [ 8.283976] using random host ethernet address [ 8.289577] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008 [ 8.297862] g_ether gadget: g_ether ready [ 8.303660] cdns-mhdp a000000.dp-bridge: no PHY configured [ 8.332347] usbcore: registered new interface driver usbfs [ 8.339425] usbcore: registered new interface driver hub [ 8.347160] usbcore: registered new device driver usb [ 8.362066] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 8.368955] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 [ 8.380043] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000000000010010 [ 8.392010] xhci-hcd xhci-hcd.2.auto: irq 572, io mem 0x06010000 [ 8.400011] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04 [ 8.410414] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 8.419471] usb usb1: Product: xHCI Host Controller [ 8.425606] usb usb1: Manufacturer: Linux 5.4.106 xhci-hcd [ 8.432482] usb usb1: SerialNumber: xhci-hcd.2.auto [ 8.439501] hub 1-0:1.0: USB hub found [ 8.444267] hub 1-0:1.0: 1 port detected [ 8.449746] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 8.456687] cdns-mhdp a000000.dp-bridge: no PHY configured [ 8.457697] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [ 8.463848] cdns-mhdp a000000.dp-bridge: no PHY configured [ 8.474335] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed [ 8.488192] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 8.498374] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04 [ 8.508735] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 8.517777] usb usb2: Product: xHCI Host Controller [ 8.523874] usb usb2: Manufacturer: Linux 5.4.106 xhci-hcd [ 8.530723] usb usb2: SerialNumber: xhci-hcd.2.auto [ 8.537178] hub 2-0:1.0: USB hub found [ 8.541906] hub 2-0:1.0: 1 port detected [ 8.547379] cdns-mhdp a000000.dp-bridge: no PHY configured [ 8.554608] cdns-mhdp a000000.dp-bridge: no PHY configured [ 31.804676] vdd_mmc1: disabling _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org j7-evm ttyS2 Arago 2020.05 j7-evm ttyS2 j7-evm login: root Password: root@j7-evm:~# root@j7-evm:~# root@j7-evm:~# cat /proc/meminfo MemTotal: 1540864 kB MemFree: 1249024 kB MemAvailable: 1184896 kB Buffers: 12032 kB Cached: 96896 kB SwapCached: 0 kB Active: 64000 kB Inactive: 76544 kB Active(anon): 35904 kB Inactive(anon): 9664 kB Active(file): 28096 kB Inactive(file): 66880 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 0 kB SwapFree: 0 kB Dirty: 384 kB Writeback: 0 kB AnonPages: 31360 kB Mapped: 15744 kB Shmem: 14208 kB KReclaimable: 22208 kB Slab: 79360 kB SReclaimable: 22208 kB SUnreclaim: 57152 kB KernelStack: 8256 kB PageTables: 5312 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 770432 kB Committed_AS: 289792 kB VmallocTotal: 133009506240 kB VmallocUsed: 18624 kB VmallocChunk: 0 kB Percpu: 768 kB HardwareCorrupted: 0 kB AnonHugePages: 0 kB ShmemHugePages: 0 kB ShmemPmdMapped: 0 kB FileHugePages: 0 kB FilePmdMapped: 0 kB CmaTotal: 0 kB CmaFree: 0 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 524288 kB Hugetlb: 0 kB root@j7-evm:~# top top - 08:39:17 up 0 min, 0 users, load average: 0.56, 0.20, 0.07 Tasks: 100 total, 1 running, 99 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 3.1 sy, 0.0 ni, 96.9 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 1504.8 total, 1217.8 free, 158.3 used, 128.7 buff/cache MiB Swap: 0.0 total, 0.0 free, 0.0 used. 1155.4 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 603 root 20 0 934464 8192 4352 S 6.7 0.5 0:00.91 eraeADAS.out 1 root 20 0 9920 8064 5184 S 0.0 0.5 0:01.93 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd 3 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_gp 4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 rcu_par_gp 5 root 20 0 0 0 0 I 0.0 0.0 0:00.06 kworker/0:0-memcg_kmem_cache 6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/0:0H-kblockd 7 root 20 0 0 0 0 I 0.0 0.0 0:00.00 kworker/u4:0-events_unbound 8 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 mm_percpu_wq 9 root 20 0 0 0 0 S 0.0 0.0 0:00.02 ksoftirqd/0 10 root 20 0 0 0 0 I 0.0 0.0 0:00.02 rcu_preempt 11 root rt 0 0 0 0 S 0.0 0.0 0:00.01 migration/0 12 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0 13 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1 14 root rt 0 0 0 0 S 0.0 0.0 0:00.00 migration/1 15 root 20 0 0 0 0 S 0.0 0.0 0:00.02 ksoftirqd/1 16 root 20 0 0 0 0 I 0.0 0.0 0:00.00 kworker/1:0-cgroup_destroy 17 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/1:0H-kblockd 18 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs 19 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 netns 20 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_tasks_kthre 21 root 20 0 0 0 0 I 0.0 0.0 0:00.00 kworker/1:1-memcg_kmem_cache 22 root 20 0 0 0 0 S 0.0 0.0 0:00.00 oom_reaper 23 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 writeback 24 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kcompactd0 25 root 20 0 0 0 0 I 0.0 0.0 0:00.51 kworker/0:1-events 26 root 25 5 0 0 0 S 0.0 0.0 0:00.00 ksmd 27 root 39 19 0 0 0 S 0.0 0.0 0:00.00 khugepaged 36 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 cryptd 58 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kintegrityd 59 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kblockd 60 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 blkcg_punt_bio 61 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 edac-poller 62 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 devfreq_wq 63 root rt 0 0 0 0 S 0.0 0.0 0:00.00 watchdogd 64 root 20 0 0 0 0 I 0.0 0.0 0:00.00 kworker/u4:1-events_unbound 94 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kswapd0 96 root 20 0 0 0 0 I 0.0 0.0 0:00.57 kworker/0:2-events 97 root -51 0 0 0 0 S 0.0 0.0 0:00.00 irq/7-40b10000. 98 root -51 0 0 0 0 S 0.0 0.0 0:00.00 irq/8-42120000. 99 root -51 0 0 0 0 S 0.0 0.0 0:00.00 irq/17-2000000. 100 root -51 0 0 0 0 S 0.0 0.0 0:00.00 irq/18-2040000. 101 root -51 0 0 0 0 S 0.0 0.0 0:00.00 irq/19-2050000. 102 root -51 0 0 0 0 S 0.0 0.0 0:00.00 irq/12-arm-smmu 103 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/u5:0 104 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 sdhci 105 root -51 0 0 0 0 S 0.0 0.0 0:00.00 irq/21-mmc0 106 root 20 0 0 0 0 I 0.0 0.0 0:00.00 kworker/0:3-events 107 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 mmc_complete 108 root 0 -20 0 0 0 I 0.0 0.0 0:00.01 kworker/0:1H-kblockd 109 root 0 -20 0 0 0 I 0.0 0.0 0:00.01 kworker/1:1H-kblockd root@j7-evm:~# root@j7-evm:~#
I share to boot log.
Please check.
I have no patches applied.
U-Boot/SPL
U-Boot prints exact size of DDR memory recognized by it. Can you please share the logs form the beginning?
- Keerthy
