Hi TI,
We got a custom camera (w/ built-in TI-953 Ser) from our vendor. Its parameters are Sony ISX021 sensor, 1920x1280, 30 FPS, FPD-Link III, MIPI 4 Lane YUV422 8bits. Now we want to apply it to our TDA4VEN platform. The settings before capturing the frame are:
(We detect TI960/954 Deser on the fourth I2C bus so we also update the /boot/dtb/ti/k3-j722s-evm-fpdlink-fusion.dtbo and apply it at booting)
/dts-v1/; / { fragment@0 { target-path = "/"; __overlay__ { fixed-clock-25M { compatible = "fixed-clock"; #clock-cells = <0x00>; clock-frequency = <0x17d7840>; phandle = <0x01>; }; }; }; fragment@1 { target = <0xffffffff>; __overlay__ { #address-cells = <0x01>; #size-cells = <0x00>; status = "okay"; i2c@4 { #address-cells = <0x01>; #size-cells = <0x00>; reg = <0x00>; deser@3d { compatible = "ti,ds90ub960-q1"; reg = <0x3d>; clocks = <0x01>; clock-names = "refclk"; i2c-alias-pool = <0x4a 0x4b 0x4c 0x4d 0x4e 0x4f>; ports { #address-cells = <0x01>; #size-cells = <0x00>; phandle = <0x06>; port@4 { reg = <0x04>; endpoint { clock-lanes = <0x00>; data-lanes = <0x01 0x02 0x03 0x04>; link-frequencies = <0x00 0x2faf0800>; remote-endpoint = <0x02>; phandle = <0x04>; }; }; }; links { #address-cells = <0x01>; #size-cells = <0x00>; phandle = <0x07>; }; }; deser@36 { compatible = "ti,ds90ub960-q1"; reg = <0x36>; clocks = <0x01>; clock-names = "refclk"; i2c-alias-pool = <0x5a 0x5b 0x5c 0x5d 0x5e 0x5f>; ports { #address-cells = <0x01>; #size-cells = <0x00>; phandle = <0x08>; port@4 { reg = <0x04>; endpoint { clock-lanes = <0x00>; data-lanes = <0x01 0x02 0x03 0x04>; link-frequencies = <0x00 0x2faf0800>; remote-endpoint = <0x03>; phandle = <0x05>; }; }; }; links { #address-cells = <0x01>; #size-cells = <0x00>; phandle = <0x09>; }; }; }; }; }; fragment@2 { target = <0xffffffff>; __overlay__ { ports { #address-cells = <0x01>; #size-cells = <0x00>; port@0 { reg = <0x00>; status = "okay"; phandle = <0x0a>; endpoint { remote-endpoint = <0x04>; clock-lanes = <0x00>; data-lanes = <0x01 0x02 0x03 0x04>; link-frequencies = <0x00 0x2faf0800>; phandle = <0x02>; }; }; }; }; }; }; fragment@3 { target = <0xffffffff>; __overlay__ { ports { #address-cells = <0x01>; #size-cells = <0x00>; port@0 { reg = <0x00>; status = "okay"; phandle = <0x0b>; endpoint { remote-endpoint = <0x05>; clock-lanes = <0x00>; data-lanes = <0x01 0x02 0x03 0x04>; link-frequencies = <0x00 0x2faf0800>; phandle = <0x03>; }; }; }; }; }; fragment@4 { target = <0xffffffff>; __overlay__ { status = "okay"; }; }; fragment@5 { target = <0xffffffff>; __overlay__ { status = "okay"; }; }; fragment@6 { target = <0xffffffff>; __overlay__ { status = "okay"; }; }; fragment@7 { target = <0xffffffff>; __overlay__ { status = "okay"; }; }; __symbols__ { clk_fusion_25M_fixed = "/fragment@0/__overlay__/fixed-clock-25M"; ds90ub960_0_ports = "/fragment@1/__overlay__/i2c@4/deser@3d/ports"; ds90ub960_0_csi_out = "/fragment@1/__overlay__/i2c@4/deser@3d/ports/port@4/endpoint"; ds90ub960_0_links = "/fragment@1/__overlay__/i2c@4/deser@3d/links"; ds90ub960_1_ports = "/fragment@1/__overlay__/i2c@0/deser@36/ports"; ds90ub960_1_csi_out = "/fragment@1/__overlay__/i2c@0/deser@36/ports/port@4/endpoint"; ds90ub960_1_links = "/fragment@1/__overlay__/i2c@0/deser@36/links"; csi0_port0 = "/fragment@2/__overlay__/ports/port@0"; csi2_phy0 = "/fragment@2/__overlay__/ports/port@0/endpoint"; csi1_port0 = "/fragment@3/__overlay__/ports/port@0"; csi2_phy1 = "/fragment@3/__overlay__/ports/port@0/endpoint"; }; __fixups__ { pca9543_0 = "/fragment@1:target:0"; cdns_csi2rx0 = "/fragment@2:target:0"; cdns_csi2rx1 = "/fragment@3:target:0"; ti_csi2rx0 = "/fragment@4:target:0"; dphy0 = "/fragment@5:target:0"; ti_csi2rx1 = "/fragment@6:target:0"; dphy1 = "/fragment@7:target:0"; }; __local_fixups__ { fragment@1 { __overlay__ { i2c@4 { deser@3d { clocks = <0x00>; ports { port@4 { endpoint { remote-endpoint = <0x00>; }; }; }; }; deser@36 { clocks = <0x00>; ports { port@4 { endpoint { remote-endpoint = <0x00>; }; }; }; }; }; }; }; }; fragment@2 { __overlay__ { ports { port@0 { endpoint { remote-endpoint = <0x00>; }; }; }; }; }; fragment@3 { __overlay__ { ports { port@0 { endpoint { remote-endpoint = <0x00>; }; }; }; }; }; }; };
j722s-evm:/opt/edgeai-gst-apps# media-ctl -p Media controller API version 6.6.32 Media device information ------------------------ driver j721e-csi2rx model TI-CSI2RX serial bus info platform:30102000.ticsi2rx hw revision 0x1 driver version 6.6.32 Device topology - entity 1: 30102000.ticsi2rx (7 pads, 7 links, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev0 routes: 0/0 -> 1/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] <- "cdns_csi2rx.30101000.csi-bridge":1 [ENABLED,IMMUTABLE] pad1: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "30102000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE] pad2: Source -> "30102000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE] pad3: Source -> "30102000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE] pad4: Source -> "30102000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE] pad5: Source -> "30102000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE] pad6: Source -> "30102000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE] - entity 9: cdns_csi2rx.30101000.csi-bridge (5 pads, 2 links, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev1 routes: 0/0 -> 1/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] <- "ds90ub960 4-003d":4 [ENABLED,IMMUTABLE] pad1: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "30102000.ticsi2rx":0 [ENABLED,IMMUTABLE] pad2: Source pad3: Source pad4: Source - entity 15: ds90ub960 4-003d (6 pads, 1 link, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev2 routes: 0/0 -> 4/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] pad1: Sink pad2: Sink pad3: Sink pad4: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "cdns_csi2rx.30101000.csi-bridge":0 [ENABLED,IMMUTABLE] pad5: Source - entity 26: 30102000.ticsi2rx context 0 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video3 pad0: Sink <- "30102000.ticsi2rx":1 [ENABLED,IMMUTABLE] - entity 32: 30102000.ticsi2rx context 1 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video4 pad0: Sink <- "30102000.ticsi2rx":2 [ENABLED,IMMUTABLE] - entity 38: 30102000.ticsi2rx context 2 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video5 pad0: Sink <- "30102000.ticsi2rx":3 [ENABLED,IMMUTABLE] - entity 44: 30102000.ticsi2rx context 3 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video6 pad0: Sink <- "30102000.ticsi2rx":4 [ENABLED,IMMUTABLE] - entity 50: 30102000.ticsi2rx context 4 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video7 pad0: Sink <- "30102000.ticsi2rx":5 [ENABLED,IMMUTABLE] - entity 56: 30102000.ticsi2rx context 5 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video8 pad0: Sink <- "30102000.ticsi2rx":6 [ENABLED,IMMUTABLE]
j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'ds90ub960 4-003d':0 [fmt:UYVY8_1X16/1920x1280 field:none]" j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.csi-bridge':0 [fmt:UYVY8_1X16/1920x1280 field:none]" j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 field:none]" j722s-evm:/opt/edgeai-gst-apps# v4l2-ctl -d /dev/video3 --set-fmt-video width=1920,height=1280,pixelformat=UYVY
After executing the commands above:
Thus, we use v4l2-ctl -d/dev/video3 --stream-mmap --stream-to=frame-raw --stream-count=1, but the kernel crashes:
j722s-evm:/opt/edgeai-gst-apps# v4l2-ctl -d/dev/video3 --stream-mmap --stream-to=frame.raw --stream-count=1 [ 3281.219864] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000010 [ 3281.228692] Mem abort info: [ 3281.231475] ESR = 0x0000000096000006 [ 3281.235230] EC = 0x25: DABT (current EL), IL = 32 bits [ 3281.240546] SET = 0, FnV = 0 [ 3281.243591] EA = 0, S1PTW = 0 [ 3281.246731] FSC = 0x06: level 2 translation fault [ 3281.251605] Data abort info: [ 3281.254485] ISV = 0, ISS = 0x00000006, ISS2 = 0x00000000 [ 3281.259965] CM = 0, WnR = 0, TnD = 0, TagAccess = 0 [ 3281.265013] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0 [ 3281.270337] user pgtable: 4k pages, 48-bit VAs, pgdp=00000008a6b72000 [ 3281.276854] [0000000000000010] pgd=08000008a3eda003, p4d=08000008a3eda003, pud=08000008b446b003, pmd=0000000000000000 [ 3281.287534] Internal error: Oops: 0000000096000006 [#1] PREEMPT SMP [ 3281.293788] Modules linked in: overlay onboard_usb_hub cfg80211 rpmsg_ctrl rpmsg_char snd_soc_hdmi_codec cdns_csi2rx cdns3 bluetooth cdns_6 [ 3281.367486] CPU: 0 PID: 1840 Comm: v4l2-ctl Tainted: G O 6.6.32-ti-gdb8871293143-dirty #1 [ 3281.377034] Hardware name: Texas Instruments J722S EVM (DT) [ 3281.382590] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 3281.389537] pc : ub960_get_frame_desc+0xf4/0x334 [ds90ub960] [ 3281.395201] lr : ub960_get_frame_desc+0xc8/0x334 [ds90ub960] [ 3281.400854] sp : ffff80008378b810 [ 3281.404156] x29: ffff80008378b8d0 x28: ffff000826b05240 x27: ffff0008223ea640 [ 3281.411282] x26: ffff000821620020 x25: ffff80007969da90 x24: ffff0008229b91e0 [ 3281.418407] x23: ffff000828980880 x22: ffff0008229b9210 x21: ffff80008378b950 [ 3281.425532] x20: 0000000000000004 x19: 0000000000000000 x18: 0000000000000000 [ 3281.432656] x17: ffff000828887800 x16: ffff000829ac8800 x15: ffff800081a9f000 [ 3281.439781] x14: 0000000000000000 x13: 00000000000002b2 x12: 0000000000000002 [ 3281.446905] x11: 000000000080007d x10: fffffc0020ca3290 x9 : 0000000000000000 [ 3281.454030] x8 : ffff80008378b8c4 x7 : 0000000000000000 x6 : 000000000000003f [ 3281.461154] x5 : 0000000000000040 x4 : ffffffffffffffe0 x3 : 0000000000000000 [ 3281.468278] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff000828980880 [ 3281.475403] Call trace: [ 3281.477840] ub960_get_frame_desc+0xf4/0x334 [ds90ub960] [ 3281.483146] csi2rx_get_frame_desc_from_source+0x7c/0xac [cdns_csi2rx] [ 3281.489669] csi2rx_get_frame_desc+0x50/0x1a8 [cdns_csi2rx] [ 3281.495233] ti_csi2rx_get_vc+0x114/0x134 [j721e_csi2rx] [ 3281.500543] ti_csi2rx_start_streaming+0x120/0x294 [j721e_csi2rx] [ 3281.506630] vb2_start_streaming+0x68/0x15c [videobuf2_common] [ 3281.512468] vb2_core_streamon+0xf8/0x1bc [videobuf2_common] [ 3281.518128] vb2_ioctl_streamon+0x4c/0x90 [videobuf2_v4l2] [ 3281.523620] v4l_streamon+0x24/0x30 [videodev] [ 3281.528134] __video_do_ioctl+0x330/0x3fc [videodev] [ 3281.533142] video_usercopy+0x2c8/0x658 [videodev] [ 3281.537977] video_ioctl2+0x18/0x24 [videodev] [ 3281.542469] v4l2_ioctl+0x40/0x60 [videodev] [ 3281.546787] __arm64_sys_ioctl+0xac/0xf0 [ 3281.550705] invoke_syscall+0x48/0x114 [ 3281.554449] el0_svc_common.constprop.0+0xc0/0xe0 [ 3281.559143] do_el0_svc+0x1c/0x28 [ 3281.562450] el0_svc+0x2c/0x84 [ 3281.565497] el0t_64_sync_handler+0x120/0x12c [ 3281.569844] el0t_64_sync+0x190/0x194 [ 3281.573503] Code: 1a822260 1a822273 8b000ee0 f9405401 (f9400820) [ 3281.579582] ---[ end trace 0000000000000000 ]---
Is there any step went wrong?
V.C.
Hi V. C.
Can you please try the small change that i shared in below link in uboot?
Brijesh
Hi Brijesh,
After I rebuild and install u-boot in SDK by make u-boot_install and re-run the commands above, the kernel still crashes.
root@j722s-evm:/opt/edgeai-gst-apps# v4l2-ctl -d /dev/video3 --set-fmt-video width=1920,height=1280,pixelformat=UYVY --stream-mmap --stream-to=frame.raw --stream-count=1 [ 270.899499] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000010 [ 270.908398] Mem abort info: [ 270.911183] ESR = 0x0000000096000006 [ 270.914980] EC = 0x25: DABT (current EL), IL = 32 bits [ 270.920311] SET = 0, FnV = 0 [ 270.923366] EA = 0, S1PTW = 0 [ 270.926496] FSC = 0x06: level 2 translation fault [ 270.931371] Data abort info: [ 270.934240] ISV = 0, ISS = 0x00000006, ISS2 = 0x00000000 [ 270.939722] CM = 0, WnR = 0, TnD = 0, TagAccess = 0 [ 270.944773] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0 [ 270.950081] user pgtable: 4k pages, 48-bit VAs, pgdp=00000008a66ef000 [ 270.956517] [0000000000000010] pgd=08000008b75e6003, p4d=08000008b75e6003, pud=08000008a50b4003, pmd=0000000000000000 [ 270.967127] Internal error: Oops: 0000000096000006 [#1] PREEMPT SMP [ 270.973381] Modules linked in: onboard_usb_hub snd_soc_hdmi_codec overlay cdns3 cdns_usb_common rpmsg_ctrl cdns_csi2rx cfg80211 rpmsg_char crct10dif_ce snd_soc_si6 [ 271.049599] CPU: 3 PID: 1597 Comm: v4l2-ctl Tainted: G O 6.6.44-ti-01478-g541c20281af7-dirty #1 [ 271.059668] Hardware name: Texas Instruments J722S EVM (DT) [ 271.065224] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 271.072170] pc : ub960_get_frame_desc+0xf4/0x334 [ds90ub960] [ 271.077835] lr : ub960_get_frame_desc+0xc8/0x334 [ds90ub960] [ 271.083488] sp : ffff80008370b810 [ 271.086790] x29: ffff80008370b8d0 x28: ffff0008251f9900 x27: ffff00082731a700 [ 271.093915] x26: ffff0008201ab020 x25: ffff800079666a90 x24: ffff000827131420 [ 271.101041] x23: ffff0008220a9880 x22: ffff000827131450 x21: ffff80008370b950 [ 271.108165] x20: 0000000000000004 x19: 0000000000000000 x18: 0000000000000000 [ 271.115290] x17: 1fffe001058acb41 x16: 0000000000000000 x15: 0000000000000002 [ 271.122414] x14: 0000000000000000 x13: 00000000000000d0 x12: 0000000000000002 [ 271.129538] x11: 0000000000000000 x10: 000000000000003a x9 : 0000000000000000 [ 271.136662] x8 : ffff80008370b8c4 x7 : 0000000000000000 x6 : 000000000000003f [ 271.143787] x5 : 0000000000000040 x4 : ffffffffffffffe0 x3 : 0000000000000000 [ 271.150911] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0008220a9880 [ 271.158036] Call trace: [ 271.160473] ub960_get_frame_desc+0xf4/0x334 [ds90ub960] [ 271.165780] csi2rx_get_frame_desc_from_source+0x7c/0xac [cdns_csi2rx] [ 271.172302] csi2rx_get_frame_desc+0x50/0x1bc [cdns_csi2rx] [ 271.177866] ti_csi2rx_get_vc+0x114/0x134 [j721e_csi2rx] [ 271.183176] ti_csi2rx_start_streaming+0x120/0x294 [j721e_csi2rx] [ 271.189261] vb2_start_streaming+0x68/0x15c [videobuf2_common] [ 271.195098] vb2_core_streamon+0xf8/0x1bc [videobuf2_common] [ 271.200756] vb2_ioctl_streamon+0x4c/0x90 [videobuf2_v4l2] [ 271.206247] v4l_streamon+0x24/0x30 [videodev] [ 271.210749] __video_do_ioctl+0x330/0x3fc [videodev] [ 271.215754] video_usercopy+0x2c8/0x658 [videodev] [ 271.220584] video_ioctl2+0x18/0x24 [videodev] [ 271.225066] v4l2_ioctl+0x40/0x60 [videodev] [ 271.229375] __arm64_sys_ioctl+0xac/0xf0 [ 271.233293] invoke_syscall+0x48/0x114 [ 271.237036] el0_svc_common.constprop.0+0xc0/0xe0 [ 271.241731] do_el0_svc+0x1c/0x28 [ 271.245038] el0_svc+0x2c/0x84 [ 271.248086] el0t_64_sync_handler+0x120/0x12c [ 271.252431] el0t_64_sync+0x190/0x194 [ 271.256089] Code: 1a822260 1a822273 8b000ee0 f9405401 (f9400820) [ 271.262167] ---[ end trace 0000000000000000 ]---
I'm not sure the change is applied correctly or not.
(BTW, I realize I pasted the wrong message of fourth block of code. The real resolution for it should all be set at UYVY/1920x1280.)
Hi Gokul,
We download the sdk from here: https://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-AM67A/10.01.00.04
V.C.
Hi Chen,
Thank you for sharing, we are checking with our experts internally and will update soon.
Gokul
Hi Chen,
Sorry for the dealy, can you share the entire boot logs.
Gokul
Sure, the attachment is the output from `dmesg`. (Note: It contains some commands to set up the deserializer, media-ctl, and v4l2-ctl.)
script "bin/setup-minicom.sh" line 33: unknown command "cwd=`dirname" j722s-evm login: root [ 98.914247] audit: type=1006 audit(1741155621.909:23): pid=1480 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1 [ 98.927908] audit: type=1300 audit(1741155621.909:23): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff1e46708 a2=1 a3=1 items=0 ppid=1 pid=1480 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null) [ 98.955716] audit: type=1327 audit(1741155621.909:23): proctitle="(systemd)" [ 98.962821] audit: type=1334 audit(1741155621.941:24): prog-id=21 op=LOAD [ 98.969690] audit: type=1300 audit(1741155621.941:24): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc4b77b08 a2=90 a3=0 items=0 ppid=1 pid=1480 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null) [ 98.996603] audit: type=1327 audit(1741155621.941:24): proctitle="(systemd)" [ 99.003706] audit: type=1334 audit(1741155621.953:25): prog-id=21 op=UNLOAD [ 99.010701] audit: type=1300 audit(1741155621.953:25): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff9b22dc60 items=0 ppid=1 pid=1480 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null) [ 99.037410] audit: type=1327 audit(1741155621.953:25): proctitle="(systemd)" [ 99.044533] audit: type=1334 audit(1741155621.953:26): prog-id=22 op=LOAD root@j722s-evm:/opt/edgeai-gst-apps# dmesg | grep ds90 [ 8.148066] ds90ub960 5-0036: supply vddio not found, using dummy regulator [ 8.185227] ds90ub960 5-0036: ub960_write: cannot write register 0x01 (-121)! [ 8.196126] ds90ub960 5-0036: reset failed: -121 [ 8.201409] ds90ub960 5-0036: ub960_read: cannot read register 0x03 (-121)! [ 8.208524] ds90ub960 5-0036: error -EREMOTEIO: Cannot read first register, abort [ 8.217933] ds90ub960: probe of 5-0036 failed with error -121 [ 8.224015] ds90ub960 5-003d: supply vddio not found, using dummy regulator root@j722s-evm:/opt/edgeai-gst-apps# script "bin/setup-minicom.sh" line 33: unknown command "cwd=`dirname" root@j722s-evm:/opt/edgeai-gst-apps# i2cdetect -y -r 3 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- 62 -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- root@j722s-evm:/opt/edgeai-gst-apps# i2cdetect -y -r 4 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- UU -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: UU UU -- -- -- -- -- -- root@j722s-evm:/opt/edgeai-gst-apps# i2cdetect -y -r 5 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- UU -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: UU UU -- -- -- -- -- -- root@j722s-evm:/opt/edgeai-gst-apps# i2cdetect -y -r 6 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: UU UU -- -- -- -- -- -- root@j722s-evm:/opt/edgeai-gst-apps# i2cdetect -y -r 7 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- 3d -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: UU UU -- -- -- -- -- -- root@j722s-evm:/opt/edgeai-gst-apps# i2cset -y -y 7 0x3d 0x01 0x01 root@j722s-evm:/opt/edgeai-gst-apps# dmesg | grep ds90 [ 8.148066] ds90ub960 5-0036: supply vddio not found, using dummy regulator [ 8.185227] ds90ub960 5-0036: ub960_write: cannot write register 0x01 (-121)! [ 8.196126] ds90ub960 5-0036: reset failed: -121 [ 8.201409] ds90ub960 5-0036: ub960_read: cannot read register 0x03 (-121)! [ 8.208524] ds90ub960 5-0036: error -EREMOTEIO: Cannot read first register, abort [ 8.217933] ds90ub960: probe of 5-0036 failed with error -121 [ 8.224015] ds90ub960 5-003d: supply vddio not found, using dummy regulator root@j722s-evm:/opt/edgeai-gst-apps# i2cset -y 7 0x3d 0x01 0x01 root@j722s-evm:/opt/edgeai-gst-apps# i2cset -y 7 0x3d 0x4c 0x01 root@j722s-evm:/opt/edgeai-gst-apps# i2cset -y 7 0x3d 0x58 0x5e root@j722s-evm:/opt/edgeai-gst-apps# i2cset -y 7 0x3d 0x1f 0x02 root@j722s-evm:/opt/edgeai-gst-apps# i2cset -y 7 0x3d 0x20 0x20 root@j722s-evm:/opt/edgeai-gst-apps# i2cset -y 7 0x3d 0x33 0x03 root@j722s-evm:/opt/edgeai-gst-apps# media-ctl -p Media controller API version 6.6.44 Media device information ------------------------ driver j721e-csi2rx model TI-CSI2RX serial bus info platform:30102000.ticsi2rx hw revision 0x1 driver version 6.6.44 Device topology - entity 1: 30102000.ticsi2rx (7 pads, 7 links, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev0 routes: 0/0 -> 1/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] <- "cdns_csi2rx.30101000.csi-bridge":1 [ENABLED,IMMUTABLE] pad1: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "30102000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE] pad2: Source -> "30102000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE] pad3: Source -> "30102000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE] pad4: Source -> "30102000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE] pad5: Source -> "30102000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE] pad6: Source -> "30102000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE] - entity 9: cdns_csi2rx.30101000.csi-bridge (5 pads, 2 links, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev1 routes: 0/0 -> 1/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] <- "ds90ub960 5-003d":4 [ENABLED,IMMUTABLE] pad1: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "30102000.ticsi2rx":0 [ENABLED,IMMUTABLE] pad2: Source pad3: Source pad4: Source - entity 15: ds90ub960 5-003d (6 pads, 1 link, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev2 routes: 0/0 -> 4/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] pad1: Sink pad2: Sink pad3: Sink pad4: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "cdns_csi2rx.30101000.csi-bridge":0 [ENABLED,IMMUTABLE] pad5: Source - entity 26: 30102000.ticsi2rx context 0 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video3 pad0: Sink <- "30102000.ticsi2rx":1 [ENABLED,IMMUTABLE] - entity 32: 30102000.ticsi2rx context 1 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video4 pad0: Sink <- "30102000.ticsi2rx":2 [ENABLED,IMMUTABLE] - entity 38: 30102000.ticsi2rx context 2 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video5 pad0: Sink <- "30102000.ticsi2rx":3 [ENABLED,IMMUTABLE] - entity 44: 30102000.ticsi2rx context 3 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video6 pad0: Sink <- "30102000.ticsi2rx":4 [ENABLED,IMMUTABLE] - entity 50: 30102000.ticsi2rx context 4 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video7 pad0: Sink <- "30102000.ticsi2rx":5 [ENABLED,IMMUTABLE] - entity 56: 30102000.ticsi2rx context 5 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video8 pad0: Sink <- "30102000.ticsi2rx":6 [ENABLED,IMMUTABLE] root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "; '^V^H^[[Api2cget -y 7 0x3d 0x33 set -y 7 0x3d 0x33 0x03get -y 7 0x3d 0x33 media-ctl -p Media controller API version 6.6.44 Media device information ------------------------ driver j721e-csi2rx model TI-CSI2RX serial bus info platform:30102000.ticsi2rx hw revision 0x1 driver version 6.6.44 Device topology - entity 1: 30102000.ticsi2rx (7 pads, 7 links, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev0 routes: 0/0 -> 1/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] <- "cdns_csi2rx.30101000.csi-bridge":1 [ENABLED,IMMUTABLE] pad1: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "30102000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE] pad2: Source -> "30102000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE] pad3: Source -> "30102000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE] pad4: Source -> "30102000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE] pad5: Source -> "30102000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE] pad6: Source -> "30102000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE] - entity 9: cdns_csi2rx.30101000.csi-bridge (5 pads, 2 links, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev1 routes: 0/0 -> 1/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] <- "ds90ub960 5-003d":4 [ENABLED,IMMUTABLE] pad1: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "30102000.ticsi2rx":0 [ENABLED,IMMUTABLE] pad2: Source pad3: Source pad4: Source - entity 15: ds90ub960 5-003d (6 pads, 1 link, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev2 routes: 0/0 -> 4/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] pad1: Sink pad2: Sink pad3: Sink pad4: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "cdns_csi2rx.30101000.csi-bridge":0 [ENABLED,IMMUTABLE] pad5: Source - entity 26: 30102000.ticsi2rx context 0 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video3 pad0: Sink <- "30102000.ticsi2rx":1 [ENABLED,IMMUTABLE] - entity 32: 30102000.ticsi2rx context 1 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video4 pad0: Sink <- "30102000.ticsi2rx":2 [ENABLED,IMMUTABLE] - entity 38: 30102000.ticsi2rx context 2 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video5 pad0: Sink <- "30102000.ticsi2rx":3 [ENABLED,IMMUTABLE] - entity 44: 30102000.ticsi2rx context 3 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video6 pad0: Sink <- "30102000.ticsi2rx":4 [ENABLED,IMMUTABLE] - entity 50: 30102000.ticsi2rx context 4 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video7 pad0: Sink <- "30102000.ticsi2rx":5 [ENABLED,IMMUTABLE] - entity 56: 30102000.ticsi2rx context 5 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video8 pad0: Sink <- "30102000.ticsi2rx":6 [ENABLED,IMMUTABLE] root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --setv4l2-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920/ x1280 fil ed:none]" Unable to setup formats: Invalid argument (22) root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 fileed:none]"root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 fi1X16/1920x1280 fi edl Unable to setup formats: Invalid argument (22) root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 fillld:none]"root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 fii ld:none]"root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 fifil root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280illd:oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280lld:noot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280ld:nooot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280d:nonoot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280:noneoot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280none]"ot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280one]"oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280ne]" root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280" fil ed root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 fil root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 fi root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 fi fie ld:none]" root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 fielld:none]"root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 firoot@j722s-evm:/opt/edgeai-gst-apps# root@j722s-evm:/opt/edgeai-gst-apps# medis a-ctl -p Media controller API version 6.6.44 Media device information ------------------------ driver j721e-csi2rx model TI-CSI2RX serial bus info platform:30102000.ticsi2rx hw revision 0x1 driver version 6.6.44 Device topology - entity 1: 30102000.ticsi2rx (7 pads, 7 links, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev0 routes: 0/0 -> 1/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/1920x1280 field:none] <- "cdns_csi2rx.30101000.csi-bridge":1 [ENABLED,IMMUTABLE] pad1: Source [stream:0 fmt:UYVY8_1X16/1920x1280 field:none] -> "30102000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE] pad2: Source -> "30102000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE] pad3: Source -> "30102000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE] pad4: Source -> "30102000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE] pad5: Source -> "30102000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE] pad6: Source -> "30102000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE] - entity 9: cdns_csi2rx.30101000.csi-bridge (5 pads, 2 links, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev1 routes: 0/0 -> 1/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] <- "ds90ub960 5-003d":4 [ENABLED,IMMUTABLE] pad1: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "30102000.ticsi2rx":0 [ENABLED,IMMUTABLE] pad2: Source pad3: Source pad4: Source - entity 15: ds90ub960 5-003d (6 pads, 1 link, 1 route) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev2 routes: 0/0 -> 4/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] pad1: Sink pad2: Sink pad3: Sink pad4: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "cdns_csi2rx.30101000.csi-bridge":0 [ENABLED,IMMUTABLE] pad5: Source - entity 26: 30102000.ticsi2rx context 0 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video3 pad0: Sink <- "30102000.ticsi2rx":1 [ENABLED,IMMUTABLE] - entity 32: 30102000.ticsi2rx context 1 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video4 pad0: Sink <- "30102000.ticsi2rx":2 [ENABLED,IMMUTABLE] - entity 38: 30102000.ticsi2rx context 2 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video5 pad0: Sink <- "30102000.ticsi2rx":3 [ENABLED,IMMUTABLE] - entity 44: 30102000.ticsi2rx context 3 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video6 pad0: Sink <- "30102000.ticsi2rx":4 [ENABLED,IMMUTABLE] - entity 50: 30102000.ticsi2rx context 4 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video7 pad0: Sink <- "30102000.ticsi2rx":5 [ENABLED,IMMUTABLE] - entity 56: 30102000.ticsi2rx context 5 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video8 pad0: Sink <- "30102000.ticsi2rx":6 [ENABLED,IMMUTABLE] root@j722s-evm:/opt/edgeai-gst-apps# media-ctl -p--set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 fielld:none]"root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2rx':0 [fmt:UYVY8_1X16/1920x1280 fi':0 [fmt:UYVY8_1X16/1920x1280 fieldoot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2r':0 [fmt:UYVY8_1X16/1920x1280 field:oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi2':0 [fmt:UYVY8_1X16/1920x1280 field:noot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ticsi':0 [fmt:UYVY8_1X16/1920x1280 field:nooot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.tics':0 [fmt:UYVY8_1X16/1920x1280 field:nonoot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.tic':0 [fmt:UYVY8_1X16/1920x1280 field:noneoot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.ti':0 [fmt:UYVY8_1X16/1920x1280 field:none]"ot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.t':0 [fmt:UYVY8_1X16/1920x1280 field:none]"oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000.':0 [fmt:UYVY8_1X16/1920x1280 field:none]" root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'30102000 root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'3010200cdns_csi2rx.30101000.csi-bridge':0 [fmt:UYVY8_1X16//1920x1280 field:none]"eai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.csi-bridge root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.csi-bridge':0 [fmt:UYVY8_1X16//1920x1280 field:none]"root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.csi-bridge':0 [fmt:UYVY8_1X1':0 [fmt:UYVY8_1X16/1oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.csi-bridg':0 [fmt:UYVY8_1X16/19oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.csi-brid':0 [fmt:UYVY8_1X16/192oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.csi-bri':0 [fmt:UYVY8_1X16/1920oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.csi-br':0 [fmt:UYVY8_1X16/1920xoot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.csi-b':0 [fmt:UYVY8_1X16/1920x1oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.csi-':0 [fmt:UYVY8_1X16/1920x12oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.csi':0 [fmt:UYVY8_1X16/1920x128oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.cs':0 [fmt:UYVY8_1X16/1920x1280oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.c':0 [fmt:UYVY8_1X16/1920x1280 oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000.':0 [fmt:UYVY8_1X16/1920x1280 foot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101000':0 [fmt:UYVY8_1X16/1920x1280 fioot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.3010100':0 [fmt:UYVY8_1X16/1920x1280 fieoot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.301010':0 [fmt:UYVY8_1X16/1920x1280 fieloot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30101':0 [fmt:UYVY8_1X16/1920x1280 fieldoot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.3010':0 [fmt:UYVY8_1X16/1920x1280 field:oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.301':0 [fmt:UYVY8_1X16/1920x1280 field:noot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.30':0 [fmt:UYVY8_1X16/1920x1280 field:nooot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.3':0 [fmt:UYVY8_1X16/1920x1280 field:nonoot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx.':0 [fmt:UYVY8_1X16/1920x1280 field:noneoot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2rx':0 [fmt:UYVY8_1X16/1920x1280 field:none]"ot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2r':0 [fmt:UYVY8_1X16/1920x1280 field:none]"oot@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi2':0 [fmt:UYVY8_1X16/1920x1280 field:none]" root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csi root@j722s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'cdns_csds90ub960 5-003d':0 [fmt:UYVY8_1X16/1920x1280 fieldd:none]"2s-evm:/opt/edgeai-gst-apps# media-ctl --set-v4l2 "'ds90ub960 5-003d root@j722s-evm:/opt/edgeai-gst-apps# clear root@j722s-evm:/opt/edgeai-gst-apps# script "bin/setup-minicom.sh" line 33: unknown command "cwd=`dirname" root@j722s-evm:/opt/edgeai-gst-apps# m dmesg [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.6.44-ti-01478-g541c20281af7-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Thu Nov 14 19:20:24 UTC 2024 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Texas Instruments J722S EVM [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000 [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a0000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a0100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a1000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a1100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a2000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a3ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a2100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@a5000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a6ffffff (32768 KiB) nomap non-reusable vision-apps-rtos-ipc-memory-region@a5000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000acffffff (98304 KiB) nomap non-reusable vision-apps-dma-memory@a7000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ad000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@ad000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000ad000000..0x00000000ad0fffff (1024 KiB) nomap non-reusable vision-apps-c71-dma-memory@ad000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ad100000, size 63 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@ad100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000ad100000..0x00000000b0ffffff (64512 KiB) nomap non-reusable vision-apps-c71_0-memory@ad100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b1000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000b1000000..0x00000000b10fffff (1024 KiB) nomap non-reusable vision-apps-c71_1-dma-memory@b1000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b1100000, size 63 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b1100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000b1100000..0x00000000b4ffffff (64512 KiB) nomap non-reusable vision-apps-c71_1-memory@b1100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b5000000, size 40 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@b5000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000b5000000..0x00000000b77fffff (40960 KiB) nomap non-reusable vision-apps-core-heap-memory-lo@b5000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 512 MiB [ 0.000000] OF: reserved mem: initialized node c7x-ddr-heaps-hi@880000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000880000000..0x000000089fffffff (524288 KiB) nomap non-reusable c7x-ddr-heaps-hi@880000000 [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] OF: reserved mem: 0x0000000900000000..0x000000091fffffff (524288 KiB) map non-reusable vision_apps_shared-memories [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000980000000, size 896 MiB [ 0.000000] OF: reserved mem: initialized node linux-cma-buffers@980000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000980000000..0x00000009b7ffffff (917504 KiB) map reusable linux-cma-buffers@980000000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000009ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000008007ffff] [ 0.000000] node 0: [mem 0x0000000080080000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a3ffffff] [ 0.000000] node 0: [mem 0x00000000a4000000-0x00000000a4ffffff] [ 0.000000] node 0: [mem 0x00000000a5000000-0x00000000b77fffff] [ 0.000000] node 0: [mem 0x00000000b7800000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x000000089fffffff] [ 0.000000] node 0: [mem 0x00000008a0000000-0x00000009ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.5 [ 0.000000] percpu: Embedded 20 pages/cpu s43176 r8192 d30552 u81920 [ 0.000000] pcpu-alloc: s43176 r8192 d30552 u81920 alloc=20*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=03f98e74-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2064384 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 5782612K/8388608K available (12480K kernel code, 1272K rwdata, 4184K rodata, 2496K init, 528K bss, 1688492K reserved, 917504K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a0800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008a0040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a0050000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008582] Console: colour dummy device 80x25 [ 0.013177] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023847] pid_max: default: 32768 minimum: 301 [ 0.028649] LSM: initializing lsm=capability,selinux,integrity [ 0.034632] SELinux: Initializing. [ 0.038323] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.046084] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.055992] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.063290] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.071198] rcu: Hierarchical SRCU implementation. [ 0.076098] rcu: Max phase no-delay instances is 1000. [ 0.081682] Platform MSI: msi-controller@1820000 domain created [ 0.088031] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.097538] EFI services will not be available. [ 0.102444] smp: Bringing up secondary CPUs ... [ 0.107666] Detected VIPT I-cache on CPU1 [ 0.107741] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.107756] GICv3: CPU1: using allocated LPI pending table @0x00000008a0060000 [ 0.107805] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.108484] Detected VIPT I-cache on CPU2 [ 0.108540] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.108553] GICv3: CPU2: using allocated LPI pending table @0x00000008a0070000 [ 0.108584] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.109167] Detected VIPT I-cache on CPU3 [ 0.109215] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.109227] GICv3: CPU3: using allocated LPI pending table @0x00000008a0080000 [ 0.109255] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.109332] smp: Brought up 1 node, 4 CPUs [ 0.188968] SMP: Total of 4 processors activated. [ 0.193774] CPU features: detected: 32-bit EL0 Support [ 0.199040] CPU features: detected: CRC32 instructions [ 0.204345] CPU: All CPU(s) started at EL2 [ 0.208537] alternatives: applying system-wide alternatives [ 0.215896] devtmpfs: initialized [ 0.231991] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.241984] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.272489] pinctrl core: initialized pinctrl subsystem [ 0.278380] DMI not present or invalid. [ 0.282901] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.289833] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 0.297278] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.305387] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.313632] audit: initializing netlink subsys (disabled) [ 0.319341] audit: type=2000 audit(0.204:1): state=initialized audit_enabled=0 res=1 [ 0.319771] thermal_sys: Registered thermal governor 'step_wise' [ 0.327264] thermal_sys: Registered thermal governor 'power_allocator' [ 0.333441] cpuidle: using governor menu [ 0.344275] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.351287] ASID allocator initialised with 65536 entries [ 0.372448] platform 30220000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.384702] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.395600] Modules: 27488 pages in range for non-PLT usage [ 0.395608] Modules: 519008 pages in range for PLT usage [ 0.402028] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.414408] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.420811] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.427743] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.434144] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.441075] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.447475] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.454405] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.462171] k3-chipinfo 43000014.chipid: Family:J722S rev:SR1.0 JTAGID[0x0bba002f] Detected [ 0.471969] iommu: Default domain type: Translated [ 0.476887] iommu: DMA domain TLB invalidation policy: strict mode [ 0.483477] SCSI subsystem initialized [ 0.487448] libata version 3.00 loaded. [ 0.487614] usbcore: registered new interface driver usbfs [ 0.493244] usbcore: registered new interface driver hub [ 0.498697] usbcore: registered new device driver usb [ 0.504427] pps_core: LinuxPPS API ver. 1 registered [ 0.509498] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.518838] PTP clock support registered [ 0.523032] EDAC MC: Ver: 3.0.0 [ 0.526759] scmi_core: SCMI protocol bus registered [ 0.532051] FPGA manager framework [ 0.535609] Advanced Linux Sound Architecture Driver Initialized. [ 0.542735] vgaarb: loaded [ 0.545864] clocksource: Switched to clocksource arch_sys_counter [ 0.552342] VFS: Disk quotas dquot_6.6.0 [ 0.556380] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.570080] Carveout Heap: Exported 512 MiB at 0x0000000900000000 [ 0.576427] NET: Registered PF_INET protocol family [ 0.581696] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.594665] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) [ 0.603504] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.611439] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.619927] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 0.629262] TCP: Hash tables configured (established 65536 bind 65536) [ 0.636137] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.643244] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.650920] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.657174] RPC: Registered named UNIX socket transport module. [ 0.663247] RPC: Registered udp transport module. [ 0.668052] RPC: Registered tcp transport module. [ 0.672855] RPC: Registered tcp-with-tls transport module. [ 0.678464] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.685047] NET: Registered PF_XDP protocol family [ 0.689956] PCI: CLS 0 bytes, default 64 [ 0.695316] Initialise system trusted keyrings [ 0.700083] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 0.706992] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.713206] NFS: Registering the id_resolver key type [ 0.718396] Key type id_resolver registered [ 0.722670] Key type id_legacy registered [ 0.726780] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.733627] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.773858] Key type asymmetric registered [ 0.778055] Asymmetric key parser 'x509' registered [ 0.783085] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.790800] io scheduler mq-deadline registered [ 0.795434] io scheduler kyber registered [ 0.799559] io scheduler bfq registered [ 0.806809] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.813468] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.826711] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.844307] loop: module loaded [ 0.848616] megasas: 07.725.01.00-rc1 [ 0.856171] tun: Universal TUN/TAP device driver, 1.6 [ 0.862490] VFIO - User Level meta-driver version: 0.3 [ 0.869028] usbcore: registered new interface driver usb-storage [ 0.875812] i2c_dev: i2c /dev entries driver [ 0.881664] sdhci: Secure Digital Host Controller Interface driver [ 0.888009] sdhci: Copyright(c) Pierre Ossman [ 0.892709] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.899173] ledtrig-cpu: registered to indicate activity on CPUs [ 0.905641] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.912889] usbcore: registered new interface driver usbhid [ 0.918585] usbhid: USB HID core driver [ 0.923842] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.932880] optee: probing for conduit method. [ 0.937460] optee: revision 4.4 (8f645256efc0dc66) [ 0.937769] optee: dynamic shared memory is enabled [ 0.948320] random: crng init done [ 0.951889] optee: initialized driver [ 0.957678] Initializing XFRM netlink socket [ 0.962103] NET: Registered PF_PACKET protocol family [ 0.967345] Key type dns_resolver registered [ 0.979595] registered taskstats version 1 [ 0.983938] Loading compiled-in X.509 certificates [ 1.001714] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.1.6--v10.01.06 (Fiery Fox)') [ 1.063559] omap_i2c 4900000.i2c: bus 0 rev0.12 at 400 kHz [ 1.070324] omap_i2c 2b200000.i2c: bus 1 rev0.12 at 400 kHz [ 1.077145] pca953x 2-0023: supply vcc not found, using dummy regulator [ 1.084068] pca953x 2-0023: using AI [ 1.111939] omap_i2c 20000000.i2c: bus 2 rev0.12 at 400 kHz [ 1.118850] platform connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.128804] platform 30220000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.138541] i2c 3-003b: Fixed dependency cycle(s) with /connector-hdmi [ 1.145279] i2c 3-003b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000 [ 1.152849] omap_i2c 20010000.i2c: bus 3 rev0.12 at 100 kHz [ 1.159736] pca954x 4-0070: supply vdd not found, using dummy regulator [ 1.190262] i2c 5-0036: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30122000/csi-bridge@30121000 [ 1.200103] i2c 5-003d: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000 [ 1.209796] i2c i2c-4: Added multiplexed i2c bus 5 [ 1.214899] i2c i2c-4: Added multiplexed i2c bus 6 [ 1.219810] pca954x 4-0070: registered 2 multiplexed busses for I2C switch pca9543 [ 1.227746] pca954x 4-0071: supply vdd not found, using dummy regulator [ 1.234910] i2c i2c-4: Added multiplexed i2c bus 7 [ 1.239996] i2c i2c-4: Added multiplexed i2c bus 8 [ 1.244903] pca954x 4-0071: registered 2 multiplexed busses for I2C switch pca9543 [ 1.252678] omap_i2c 20020000.i2c: bus 4 rev0.12 at 400 kHz [ 1.258581] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created [ 1.266898] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.276102] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.285087] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created [ 1.299549] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.308088] ti-udma 485c0100.dma-controller: Channels: 44 (bchan: 16, tchan: 12, rchan: 16) [ 1.318982] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.329974] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.339556] ti-udma 4e230000.dma-controller: Number of rings: 40 [ 1.348413] ti-udma 4e230000.dma-controller: Channels: 40 (bchan: 0, tchan: 8, rchan: 32) [ 1.359683] printk: console [ttyS2] disabled [ 1.364386] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 310, base_baud = 3000000) is a 8250 [ 1.373270] printk: console [ttyS2] enabled [ 1.381735] printk: bootconsole [ns16550a0] disabled [ 1.397034] spi-nor spi0.0: s28hs512t (65536 Kbytes) [ 1.402119] 7 fixed-partitions partitions found on MTD device fc40000.spi.0 [ 1.409083] Creating 7 MTD partitions on "fc40000.spi.0": [ 1.414478] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.421157] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.427588] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.434153] 0x000000680000-0x0000006c0000 : "ospi.env" [ 1.440362] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 1.447196] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.453677] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 1.633851] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000 [ 1.645245] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867 [ 1.653380] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006 [ 1.666424] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.673557] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.680126] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0 [ 1.693996] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.706626] cpu cpu0: _of_add_opp_table_v2: no supported OPPs [ 1.712484] cpu cpu0: OPP table can't be empty [ 1.718222] mmc0: CQHCI version 5.10 [ 1.726337] pca953x 3-0020: supply vcc not found, using dummy regulator [ 1.733106] pca953x 3-0020: using no AI [ 1.763200] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.766586] j721e-pcie f102000.pcie: host bridge /bus@f0000/pcie@f102000 ranges: [ 1.778209] j721e-pcie f102000.pcie: IO 0x0068001000..0x0068010fff -> 0x0068001000 [ 1.786369] j721e-pcie f102000.pcie: MEM 0x0068011000..0x006fffffff -> 0x0068011000 [ 1.794477] j721e-pcie f102000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.885399] mmc0: Command Queue Engine enabled [ 1.889874] mmc0: new HS400 MMC card at address 0001 [ 1.895443] mmcblk0: mmc0:0001 G1M15L 29.6 GiB [ 1.903301] mmcblk0: p1 p2 [ 1.906662] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB [ 1.912518] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB [ 1.918327] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0) [ 2.914784] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00 [ 2.921123] pci_bus 0000:00: root bus resource [bus 00-ff] [ 2.926634] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x68001000-0x68010fff]) [ 2.936102] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff] [ 2.942998] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400 [ 2.949069] pci 0000:00:00.0: supports D1 [ 2.953075] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.961443] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.969624] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 2.976257] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.981357] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22 [ 2.988286] pcieport 0000:00:00.0: PME: Signaling with IRQ 523 [ 2.994423] pcieport 0000:00:00.0: AER: enabled with IRQ 523 [ 3.001905] mmc1: CQHCI version 5.10 [ 3.005342] clk: Disabling unused clocks [ 3.015655] ALSA device list: [ 3.018707] No soundcards found. [ 3.044431] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 3.052139] Waiting for root device PARTUUID=03f98e74-02... [ 3.109789] mmc1: new ultra high speed SDR104 SDXC card at address 0001 [ 3.117058] mmcblk1: mmc1:0001 USD 58.2 GiB [ 3.123098] mmcblk1: p1 p2 [ 3.140560] EXT4-fs (mmcblk1p2): mounted filesystem ff497811-1164-4abd-a0ab-b8eb34781240 r/w with ordered data mode. Quota mode: none. [ 3.152735] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 3.160201] devtmpfs: mounted [ 3.163916] Freeing unused kernel memory: 2496K [ 3.168535] Run /sbin/init as init process [ 3.172627] with arguments: [ 3.172631] /sbin/init [ 3.172634] with environment: [ 3.172637] HOME=/ [ 3.172640] TERM=linux [ 3.379782] systemd[1]: System time before build time, advancing clock. [ 3.424578] NET: Registered PF_INET6 protocol family [ 3.430573] Segment Routing with IPv6 [ 3.434288] In-situ OAM (IOAM) with IPv6 [ 3.473197] systemd[1]: systemd 255.13^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 3.505128] systemd[1]: Detected architecture arm64. [ 3.526754] systemd[1]: Hostname set to <j722s-evm>. [ 3.630343] systemd-sysv-generator[110]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. ! [ 3.858155] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 3.976767] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 4.062479] systemd[1]: Queued start job for default target Graphical Interface. [ 4.108068] systemd[1]: Created slice Slice /system/getty. [ 4.132445] systemd[1]: Created slice Slice /system/modprobe. [ 4.156456] systemd[1]: Created slice Slice /system/serial-getty. [ 4.179775] systemd[1]: Created slice User and Session Slice. [ 4.202338] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 4.226232] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 4.250048] systemd[1]: Expecting device /dev/ttyS2... [ 4.266087] systemd[1]: Reached target Path Units. [ 4.281987] systemd[1]: Reached target Remote File Systems. [ 4.301965] systemd[1]: Reached target Slice Units. [ 4.317977] systemd[1]: Reached target Swaps. [ 4.371784] systemd[1]: Listening on RPCbind Server Activation Socket. [ 4.394177] systemd[1]: Reached target RPC Port Mapper. [ 4.421394] systemd[1]: Listening on Process Core Dump Socket. [ 4.442436] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 4.467197] systemd[1]: Listening on Journal Audit Socket. [ 4.490717] systemd[1]: Listening on Journal Socket (/dev/log). [ 4.514730] systemd[1]: Listening on Journal Socket. [ 4.530901] systemd[1]: Listening on Network Service Netlink Socket. [ 4.557623] systemd[1]: Listening on udev Control Socket. [ 4.578662] systemd[1]: Listening on udev Kernel Socket. [ 4.598652] systemd[1]: Listening on User Database Manager Socket. [ 4.646256] systemd[1]: Mounting Huge Pages File System... [ 4.666387] systemd[1]: Mounting POSIX Message Queue File System... [ 4.708169] systemd[1]: Mounting Kernel Debug File System... [ 4.726530] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [ 4.744761] systemd[1]: Mounting Temporary Directory /tmp... [ 4.768200] systemd[1]: Starting Create List of Static Device Nodes... [ 4.795055] systemd[1]: Starting Load Kernel Module configfs... [ 4.814864] systemd[1]: Starting Load Kernel Module drm... [ 4.842981] systemd[1]: Starting Load Kernel Module fuse... [ 4.872776] systemd[1]: Starting Start psplash boot splash screen... [ 4.886719] fuse: init (API version 7.39) [ 4.904207] systemd[1]: Starting RPC Bind... [ 4.922398] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/). [ 4.958269] systemd[1]: Starting Journal Service... [ 4.985711] systemd[1]: Starting Load Kernel Modules... [ 5.015655] systemd[1]: Starting Generate network units from Kernel command line... [ 5.043659] systemd[1]: Starting Remount Root and Kernel File Systems... [ 5.043752] cryptodev: loading out-of-tree module taints kernel. [ 5.058084] cryptodev: driver 1.14 loaded. [ 5.069804] systemd-journald[129]: Collecting audit messages is enabled. [ 5.083714] systemd[1]: Starting Coldplug All udev Devices... [ 5.117471] systemd[1]: Started RPC Bind. [ 5.134942] systemd[1]: Mounted Huge Pages File System. [ 5.149949] EXT4-fs (mmcblk1p2): re-mounted ff497811-1164-4abd-a0ab-b8eb34781240 r/w. Quota mode: none. [ 5.162099] systemd[1]: Mounted POSIX Message Queue File System. [ 5.186869] systemd[1]: Started Journal Service. [ 5.543263] systemd-journald[129]: Received client request to flush runtime journal. [ 5.841183] audit: type=1334 audit(1728487094.456:2): prog-id=6 op=LOAD [ 5.848020] audit: type=1334 audit(1728487094.464:3): prog-id=7 op=LOAD [ 6.068785] audit: type=1334 audit(1728487094.684:4): prog-id=8 op=LOAD [ 6.126103] audit: type=1334 audit(1728487094.744:5): prog-id=9 op=LOAD [ 6.180917] audit: type=1334 audit(1728487094.796:6): prog-id=10 op=LOAD [ 6.187973] audit: type=1334 audit(1728487094.804:7): prog-id=11 op=LOAD [ 6.194828] audit: type=1334 audit(1728487094.812:8): prog-id=12 op=LOAD [ 6.937788] audit: type=1334 audit(1741155511.456:9): prog-id=13 op=LOAD [ 7.192165] dbus-broker-lau[323]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set [ 7.586536] audit: type=1334 audit(1741155512.108:10): prog-id=14 op=LOAD [ 7.597826] audit: type=1334 audit(1741155512.116:11): prog-id=15 op=LOAD [ 7.793708] CAN device driver interface [ 7.855339] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100 [ 7.866773] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100 [ 7.892319] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100 [ 7.892440] mc: Linux media interface: v0.10 [ 7.899899] omap-mailbox 29030000.mailbox: omap mailbox rev 0x66fca100 [ 7.978482] videodev: Linux video capture interface: v2.00 [ 8.105441] Bluetooth: Core ver 2.22 [ 8.109249] NET: Registered PF_BLUETOOTH protocol family [ 8.117125] Bluetooth: HCI device and connection manager initialized [ 8.125512] Bluetooth: HCI socket layer initialized [ 8.132793] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@ad000000 [ 8.138511] Bluetooth: L2CAP socket layer initialized [ 8.147518] Bluetooth: SCO socket layer initialized [ 8.148066] ds90ub960 5-0036: supply vddio not found, using dummy regulator [ 8.150040] k3-dsp-rproc 7e000000.dsp: configured DSP for IPC-only mode [ 8.167600] remoteproc remoteproc0: 7e000000.dsp is available [ 8.173766] remoteproc remoteproc0: attaching to 7e000000.dsp [ 8.185227] ds90ub960 5-0036: ub960_write: cannot write register 0x01 (-121)! [ 8.196126] ds90ub960 5-0036: reset failed: -121 [ 8.201409] ds90ub960 5-0036: ub960_read: cannot read register 0x03 (-121)! [ 8.208524] ds90ub960 5-0036: error -EREMOTEIO: Cannot read first register, abort [ 8.217933] ds90ub960: probe of 5-0036 failed with error -121 [ 8.222365] rproc-virtio rproc-virtio.0.auto: assigned reserved memory node vision-apps-c71-dma-memory@ad000000 [ 8.224015] ds90ub960 5-003d: supply vddio not found, using dummy regulator [ 8.241435] platform 79000000.r5f: configured R5F for IPC-only mode [ 8.247998] platform 79000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000 [ 8.274554] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports [ 8.277723] virtio_rpmsg_bus virtio0: rpmsg host is online [ 8.283209] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd [ 8.289555] remoteproc remoteproc1: 79000000.r5f is available [ 8.302086] remoteproc remoteproc1: attaching to 79000000.r5f [ 8.311682] vdec 30210000.video-codec: OPP table not found in device tree [ 8.313503] rproc-virtio rproc-virtio.0.auto: registered virtio0 (type 7) [ 8.320833] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000 [ 8.325143] remoteproc remoteproc0: remote processor 7e000000.dsp is now attached [ 8.349592] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports [ 8.361557] virtio_rpmsg_bus virtio1: rpmsg host is online [ 8.361602] rproc-virtio rproc-virtio.1.auto: registered virtio1 (type 7) [ 8.361610] remoteproc remoteproc1: remote processor 79000000.r5f is now attached [ 8.361885] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd [ 8.368112] k3-dsp-rproc 7e200000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b1000000 [ 8.402513] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe [ 8.409765] k3-dsp-rproc 7e200000.dsp: configured DSP for IPC-only mode [ 8.427877] remoteproc remoteproc2: 7e200000.dsp is available [ 8.429682] remoteproc remoteproc2: attaching to 7e200000.dsp [ 8.439691] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports [ 8.442305] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE' [ 8.456737] vdec 30210000.video-codec: Product Code: 0x521c [ 8.456753] vdec 30210000.video-codec: Firmware Revision: 334314 [ 8.466566] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 8.468779] platform 78000000.r5f: configured R5F for IPC-only mode [ 8.468976] platform 78000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 8.470344] remoteproc remoteproc3: 78000000.r5f is available [ 8.516888] remoteproc remoteproc3: attaching to 78000000.r5f [ 8.564863] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports [ 8.581223] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 8.582496] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports [ 8.582629] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 8.583149] virtio_rpmsg_bus virtio2: rpmsg host is online [ 8.583177] rproc-virtio rproc-virtio.3.auto: registered virtio2 (type 7) [ 8.583184] remoteproc remoteproc3: remote processor 78000000.r5f is now attached [ 8.586367] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd [ 8.586737] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node vision-apps-c71_1-dma-memory@b1000000 [ 8.605799] virtio_rpmsg_bus virtio3: rpmsg host is online [ 8.612924] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd [ 8.618549] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports [ 8.618777] rproc-virtio rproc-virtio.2.auto: registered virtio3 (type 7) [ 8.618789] remoteproc remoteproc2: remote processor 7e200000.dsp is now attached [ 8.625698] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe [ 8.640056] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 8.652729] platform 78400000.r5f: configured R5F for IPC-only mode [ 8.657016] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 8.663651] platform 78400000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 8.710076] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports [ 8.713692] remoteproc remoteproc4: 78400000.r5f is available [ 8.736021] remoteproc remoteproc4: attaching to 78400000.r5f [ 8.748792] rproc-virtio rproc-virtio.5.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 8.760027] virtio_rpmsg_bus virtio4: rpmsg host is online [ 8.760959] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd [ 8.765690] rproc-virtio rproc-virtio.5.auto: registered virtio4 (type 7) [ 8.772822] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15 [ 8.779587] remoteproc remoteproc4: remote processor 78400000.r5f is now attached [ 8.803160] rtc-ti-k3 2b1f0000.rtc: registered as rtc0 [ 8.809031] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15 [ 8.812450] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:00 UTC (0) [ 8.826228] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe [ 8.866920] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe [ 8.874678] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports [ 8.874737] virtio_rpmsg_bus virtio4: msg received with no recipient [ 8.889767] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15 [ 8.892345] sii902x 3-003b: supply iovcc not found, using dummy regulator [ 8.897200] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe [ 8.904344] sii902x 3-003b: supply cvcc12 not found, using dummy regulator [ 8.911552] virtio_rpmsg_bus virtio3: msg received with no recipient [ 8.925996] virtio_rpmsg_bus virtio0: msg received with no recipient [ 8.935527] i2c i2c-3: Added multiplexed i2c bus 9 [ 8.943919] i2c 5-0036: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30122000/csi-bridge@30121000 [ 8.960510] OF: graph: no port node found in /bus@f0000/dss@30220000/oldi-txes/oldi@1/ports [ 8.999750] platform 30121000.csi-bridge: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/i2c-mux@70/i2c@5/deser@36 [ 9.080778] [drm] Initialized tidss 1.0.0 20180215 for 30220000.dss on minor 0 [ 9.084188] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 9.097906] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 9.106669] tidss 30220000.dss: [drm] Cannot find any crtc or sizes [ 9.111798] PVR_K: 199: Device: fd80000.gpu [ 9.115994] tidss 30220000.dss: [drm] Cannot find any crtc or sizes [ 9.130711] m_can_platform 4e08000.can: m_can device registered (irq=542, version=32) [ 9.153060] m_can_platform 4e18000.can: m_can device registered (irq=544, version=32) [ 9.168935] e5010 fd20000.e5010: Device registered as /dev/video2 [ 9.331970] m_can_platform 20701000.can: m_can device registered (irq=545, version=32) [ 9.546267] PVR_K: 199: Read BVNC 36.53.104.796 from HW device registers [ 9.571270] PVR_K: 199: RGX Device registered BVNC 36.53.104.796 with 1 core in the system [ 9.587587] [drm] Initialized pvr 24.1.6554834 20170530 for fd80000.gpu on minor 1 [ 9.851995] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 9.889959] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 1 [ 9.902183] xhci-hcd xhci-hcd.7.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000008010 [ 9.911857] xhci-hcd xhci-hcd.7.auto: irq 547, io mem 0x31210000 [ 9.918300] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 9.924748] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 2 [ 9.932647] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed [ 9.940235] hub 1-0:1.0: USB hub found [ 9.944184] hub 1-0:1.0: 1 port detected [ 9.945099] cdns-csi2rx 30101000.csi-bridge: Probed CSI2RX with 4/4 lanes, 4 streams, external D-PHY [ 9.962352] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 10.197501] hub 2-0:1.0: USB hub found [ 10.204769] hub 2-0:1.0: 1 port detected [ 10.208089] m_can_platform 4e08000.can mcu_mcan0: renamed from can0 [ 10.213896] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 10.218150] cdns-csi2rx 30121000.csi-bridge: Probed CSI2RX with 4/4 lanes, 4 streams, external D-PHY [ 10.324563] m_can_platform 20701000.can main_mcan0: renamed from can2 [ 10.383694] hub 1-1:1.0: USB hub found [ 10.397993] hub 1-1:1.0: 4 ports detected [ 10.414756] m_can_platform 4e18000.can mcu_mcan1: renamed from can1 [ 10.545991] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd [ 10.576087] hub 2-1:1.0: USB hub found [ 10.581386] hub 2-1:1.0: 4 ports detected [ 11.109148] usbcore: registered new device driver onboard-usb-hub [ 11.299206] hub 1-1:1.0: USB hub found [ 11.305015] hub 1-1:1.0: 4 ports detected [ 11.323122] hub 1-1:1.0: USB hub found [ 11.328625] hub 1-1:1.0: 4 ports detected [ 11.463448] hub 2-1:1.0: USB hub found [ 11.467498] hub 2-1:1.0: 4 ports detected [ 11.479628] hub 2-1:1.0: USB hub found [ 11.484738] hub 2-1:1.0: 4 ports detected [ 11.646847] kauditd_printk_skb: 5 callbacks suppressed [ 11.646860] audit: type=1006 audit(1741155516.166:15): pid=599 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=tty7 old-ses=4294967295 ses=2 res=1 [ 11.666447] audit: type=1300 audit(1741155516.166:15): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffff2511b68 a2=4 a3=1 items=0 ppid=1 pid=599 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=tty7 ses=2 comm="(weston)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null) [ 11.694091] audit: type=1327 audit(1741155516.166:15): proctitle="(weston)" [ 12.838264] PVR_K: 599: RGX Firmware image 'rgx.fw.36.53.104.796' loaded [ 12.852030] PVR_K: 599: Shader binary image 'rgx.sh.36.53.104.796' loaded [ 13.209018] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [ 14.638204] audit: type=1701 audit(1741155519.158:16): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=898 comm="edgeai-gui-app" exe="/usr/bin/edgeai-gui-app" sig=6 res=1 [ 14.706313] audit: type=1334 audit(1741155519.226:17): prog-id=18 op=LOAD [ 14.713201] audit: type=1334 audit(1741155519.230:18): prog-id=19 op=LOAD [ 14.720061] audit: type=1334 audit(1741155519.238:19): prog-id=20 op=LOAD [ 15.494125] audit: type=1334 audit(1741155520.014:20): prog-id=20 op=UNLOAD [ 15.501743] audit: type=1334 audit(1741155520.014:21): prog-id=19 op=UNLOAD [ 15.508817] audit: type=1334 audit(1741155520.014:22): prog-id=18 op=UNLOAD [ 98.914247] audit: type=1006 audit(1741155621.909:23): pid=1480 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1 [ 98.927908] audit: type=1300 audit(1741155621.909:23): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff1e46708 a2=1 a3=1 items=0 ppid=1 pid=1480 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null) [ 98.955716] audit: type=1327 audit(1741155621.909:23): proctitle="(systemd)" [ 98.962821] audit: type=1334 audit(1741155621.941:24): prog-id=21 op=LOAD [ 98.969690] audit: type=1300 audit(1741155621.941:24): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc4b77b08 a2=90 a3=0 items=0 ppid=1 pid=1480 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null) [ 98.996603] audit: type=1327 audit(1741155621.941:24): proctitle="(systemd)" [ 99.003706] audit: type=1334 audit(1741155621.953:25): prog-id=21 op=UNLOAD [ 99.010701] audit: type=1300 audit(1741155621.953:25): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff9b22dc60 items=0 ppid=1 pid=1480 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null) [ 99.037410] audit: type=1327 audit(1741155621.953:25): proctitle="(systemd)" [ 99.044533] audit: type=1334 audit(1741155621.953:26): prog-id=22 op=LOAD root@j722s-evm:/opt/edgeai-gst-apps# v4l2-ctl -d vide de /deb v/video3 --set-fmt-video width=1920,wi height=1280,pixelforma t=UYVY root@j722s-evm:/opt/edgeai-gst-apps# v4l2-ctl -d /dev/video3 --set-fmt-video width=1920,height=1280,pixelformatt=UYVY --stream-mmap --stream-to =frame.raw --stream-count=1 [ 583.397287] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000010 [ 583.406120] Mem abort info: [ 583.408923] ESR = 0x0000000096000006 [ 583.412678] EC = 0x25: DABT (current EL), IL = 32 bits [ 583.417990] SET = 0, FnV = 0 [ 583.421046] EA = 0, S1PTW = 0 [ 583.424177] FSC = 0x06: level 2 translation fault [ 583.429053] Data abort info: [ 583.431922] ISV = 0, ISS = 0x00000006, ISS2 = 0x00000000 [ 583.437405] CM = 0, WnR = 0, TnD = 0, TagAccess = 0 [ 583.442453] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0 [ 583.447761] user pgtable: 4k pages, 48-bit VAs, pgdp=00000008a231a000 [ 583.454198] [0000000000000010] pgd=08000008a4547003, p4d=08000008a4547003, pud=08000008a602c003, pmd=0000000000000000 [ 583.464810] Internal error: Oops: 0000000096000006 [#1] PREEMPT SMP [ 583.471063] Modules linked in: onboard_usb_hub snd_soc_hdmi_codec cdns_csi2rx cdns3 cdns_usb_common rpmsg_ctrl rpmsg_char overlay crct10dif_ce snd_soc_simple_card e5010_jpeg_enc snd_soc_simple_card_utils pvrsrvkm(O) v4l2_jpeg display_connector phy_can_transceiver pci_endpoint_test k3_j72xx_bandgap rtc_ti_k3 cfg80211 rti_wdt cdns3_ti wave5 j721e_csi2rx tidss ti_k3_r5_remoteproc v4l2_mem2mem videobuf2_dma_contig ds90ub960 videobuf2_memops snd_soc_tlv320aic3x_i2c mcrc64 ti_k3_dsp_remoteproc sii902x videobuf2_v4l2 bluetooth drm_dma_helper sa2ul v4l2_fwnode videobuf2_common v4l2_async ecdh_generic snd_soc_tlv320aic3x drm_kms_helper videodev snd_soc_davinci_mcasp snd_soc_ti_udma m_can_platform ecc mc i2c_atr snd_soc_ti_edma m_can rfkill cdns_dphy_rx snd_soc_ti_sdma can_dev omap_mailbox omap_hwspinlock cryptodev(O) fuse drm drm_panel_orientation_quirks backlight ipv6 [ 583.547280] CPU: 0 PID: 1629 Comm: v4l2-ctl Tainted: G O 6.6.44-ti-01478-g541c20281af7-dirty #1 [ 583.557349] Hardware name: Texas Instruments J722S EVM (DT) [ 583.562905] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 583.569851] pc : ub960_get_frame_desc+0xf4/0x334 [ds90ub960] [ 583.575515] lr : ub960_get_frame_desc+0xc8/0x334 [ds90ub960] [ 583.581168] sp : ffff800084543810 [ 583.584469] x29: ffff8000845438d0 x28: ffff000828924000 x27: ffff000828b00ec0 [ 583.591595] x26: ffff000821623020 x25: ffff8000796b4a90 x24: ffff000822233d20 [ 583.598720] x23: ffff000828b94080 x22: ffff000822233d50 x21: ffff800084543950 [ 583.605845] x20: 0000000000000004 x19: 0000000000000000 x18: 0000000000000000 [ 583.612969] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000002 [ 583.620093] x14: 0000000000000000 x13: 00000000000002d7 x12: 0000000000000002 [ 583.627218] x11: 0000000000000000 x10: 000000000000003a x9 : 0000000000000000 [ 583.634342] x8 : ffff8000845438c4 x7 : 0000000000000000 x6 : 000000000000003f [ 583.641466] x5 : 0000000000000040 x4 : ffffffffffffffe0 x3 : 0000000000000000 [ 583.648591] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff000828b94080 [ 583.655716] Call trace: [ 583.658152] ub960_get_frame_desc+0xf4/0x334 [ds90ub960] [ 583.663457] csi2rx_get_frame_desc_from_source+0x7c/0xac [cdns_csi2rx] [ 583.669981] csi2rx_get_frame_desc+0x50/0x1bc [cdns_csi2rx] [ 583.675546] ti_csi2rx_get_vc+0x114/0x134 [j721e_csi2rx] [ 583.680856] ti_csi2rx_start_streaming+0x120/0x294 [j721e_csi2rx] [ 583.686941] vb2_start_streaming+0x68/0x15c [videobuf2_common] [ 583.692780] vb2_core_streamon+0xf8/0x1bc [videobuf2_common] [ 583.698439] vb2_ioctl_streamon+0x4c/0x90 [videobuf2_v4l2] [ 583.703928] v4l_streamon+0x24/0x30 [videodev] [ 583.708432] __video_do_ioctl+0x330/0x3fc [videodev] [ 583.713434] video_usercopy+0x2c8/0x658 [videodev] [ 583.718263] video_ioctl2+0x18/0x24 [videodev] [ 583.722745] v4l2_ioctl+0x40/0x60 [videodev] [ 583.727053] __arm64_sys_ioctl+0xac/0xf0 [ 583.730970] invoke_syscall+0x48/0x114 [ 583.734713] el0_svc_common.constprop.0+0xc0/0xe0 [ 583.739408] do_el0_svc+0x1c/0x28 [ 583.742715] el0_svc+0x2c/0x84 [ 583.745762] el0t_64_sync_handler+0x120/0x12c [ 583.750108] el0t_64_sync+0x190/0x194 [ 583.753766] Code: 1a822260 1a822273 8b000ee0 f9405401 (f9400820) [ 583.759844] ---[ end trace 0000000000000000 ]---
Hi Chen,
Thank you for sharing the logs,
our experts are busy this week, we will get back to you next week. Sorry for the delay.
Gokul
Hi Chen,
It seems camera is not getting probed, Can you check with your camera vendor for the drivers, we don't support driver for isx021.
Gokul
I noticed that a few days ago and we tried another sensor with imx390, then, the problem was solved.
However, it keeps hanging on the line 88 (dequeuing) in the test code:
#include <stdio.h> #include <stdlib.h> #include <fcntl.h> #include <unistd.h> #include <sys/ioctl.h> #include <sys/mman.h> #include <linux/videodev2.h> #include <string.h> #include <errno.h> #define DEVICE "/dev/video4" #define WIDTH 1936 #define HEIGHT 1100 int main() { int fd = open(DEVICE, O_RDWR); if (fd == -1) { perror("Error opening video device"); return 1; } // Set video format struct v4l2_format fmt; memset(&fmt, 0, sizeof(fmt)); fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; fmt.fmt.pix.width = WIDTH; fmt.fmt.pix.height = HEIGHT; fmt.fmt.pix.pixelformat = V4L2_PIX_FMT_SRGGB12; // 10-bit Bayer Packed fmt.fmt.pix.field = V4L2_FIELD_NONE; if (ioctl(fd, VIDIOC_S_FMT, &fmt) == -1) { perror("VIDIOC_S_FMT failed"); printf("Error: %d\n", errno); close(fd); return 1; } // Request buffers struct v4l2_requestbuffers req; memset(&req, 0, sizeof(req)); req.count = 1; // Request 1 buffer req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; req.memory = V4L2_MEMORY_MMAP; if (ioctl(fd, VIDIOC_REQBUFS, &req) == -1) { perror("VIDIOC_REQBUFS failed"); close(fd); return 1; } // Query buffer struct v4l2_buffer buf; memset(&buf, 0, sizeof(buf)); buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE; buf.memory = V4L2_MEMORY_MMAP; buf.index = 0; if (ioctl(fd, VIDIOC_QUERYBUF, &buf) == -1) { perror("VIDIOC_QUERYBUF failed"); close(fd); return 1; } // Map buffer to user space void* buffer = mmap(NULL, buf.length, PROT_READ | PROT_WRITE, MAP_SHARED, fd, buf.m.offset); if (buffer == MAP_FAILED) { perror("Memory mapping failed"); close(fd); return 1; } // Queue buffer if (ioctl(fd, VIDIOC_QBUF, &buf) == -1) { perror("VIDIOC_QBUF failed"); close(fd); return 1; } // Start streaming int type = V4L2_BUF_TYPE_VIDEO_CAPTURE; if (ioctl(fd, VIDIOC_STREAMON, &type) == -1) { perror("VIDIOC_STREAMON failed"); close(fd); return 1; } // Dequeue buffer (capture frame) if (ioctl(fd, VIDIOC_DQBUF, &buf) == -1) { perror("VIDIOC_DQBUF failed"); close(fd); return 1; } // Save raw Bayer frame FILE* file = fopen("frame.raw", "wb"); if (file) { fwrite(buffer, buf.length, 1, file); fclose(file); printf("Frame captured and saved as frame.raw\n"); } else { perror("Error saving frame"); } // Stop streaming if (ioctl(fd, VIDIOC_STREAMOFF, &type) == -1) { perror("VIDIOC_STREAMOFF failed"); } // Cleanup munmap(buffer, buf.length); close(fd); return 0; }
I would mark this problem is solved and open another one for the above problem.
