Actually i have tested gstreamer application on AM5728 EVM board. But because of some issue i want to use my own application.
So,Is it possible to use apis of "ducati-decoder" in my aaplication?
Can you provide me apis to use in my application?
Kishan Patel.
root@am57xx-evm:/usr/bin# modetest trying to open device 'i915'...failed trying to open device 'amdgpu'...failed trying to open device 'radeon'...failed trying to open device 'nouveau'...failed trying to open device 'vmwgfx'...failed trying to open device 'omapdrm'...done Encoders: id crtc type possible crtcs possible clones 34 0 TMDS 0x00000001 0x00000000 40 47 TMDS 0x00000002 0x00000000 Connectors: id encoder status name size (mm) modes encoders 35 0 disconnected HDMI-A-1 0x0 0 34 props: 1 EDID: flags: immutable blob blobs: value: 2 DPMS: flags: enum enums: On=0 Standby=1 Suspend=2 Off=3 value: 0 5 link-status: flags: enum enums: Good=0 Bad=1 value: 0 41 40 connected DPI-1 0x0 1 40 modes: name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot) 800x480 60 800 1010 1040 1056 480 502 515 525 33000 flags: nhsync, nvsync; type: preferred, driver props: 1 EDID: flags: immutable blob blobs: value: 2 DPMS: flags: enum enums: On=0 Standby=1 Suspend=2 Off=3 value: 0 5 link-status: flags: enum enums: Good=0 Bad=1 value: 0 CRTCs: id fb pos size 39 0 (0,0) (0x0) 0 0 0 0 0 0 0 0 0 0 flags: ; type: props: 23 CTM: flags: blob blobs: value: 24 GAMMA_LUT: flags: blob blobs: value: 25 GAMMA_LUT_SIZE: flags: immutable range values: 0 4294967295 value: 256 30 background: flags: range values: 0 16777215 value: 0 31 trans-key-mode: flags: enum enums: disable=0 gfx-dst=1 vid-src=2 value: 0 32 trans-key: flags: range values: 0 16777215 value: 0 33 alpha_blender: flags: range values: 0 1 value: 0 37 rotation: flags: bitmask values: rotate-0=0x1 rotate-90=0x2 rotate-180=0x4 rotate-270=0x8 reflect-x=0x10 reflect-y=0x20 value: 1 27 zorder: flags: range values: 0 3 value: 0 47 60 (0,0) (800x480) 800x480 60 800 1010 1040 1056 480 502 515 525 33000 flags: nhsync, nvsync; type: preferred, driver props: 23 CTM: flags: blob blobs: value: 24 GAMMA_LUT: flags: blob blobs: value: 25 GAMMA_LUT_SIZE: flags: immutable range values: 0 4294967295 value: 256 30 background: flags: range values: 0 16777215 value: 0 31 trans-key-mode: flags: enum enums: disable=0 gfx-dst=1 vid-src=2 value: 0 32 trans-key: flags: range values: 0 16777215 value: 0 33 alpha_blender: flags: range values: 0 1 value: 0 43 rotation: flags: bitmask values: rotate-0=0x1 rotate-90=0x2 rotate-180=0x4 rotate-270=0x8 reflect-x=0x10 reflect-y=0x20 value: 1 27 zorder: flags: range values: 0 3 value: 0 Planes: id crtc fb CRTC x,y x,y gamma size possible crtcs 36 0 0 0,0 0,0 0 0x00000003 formats: RX12 AR12 RG16 XR24 RG24 AR24 RA24 RX24 AR15 XR12 RA12 XR15 props: 6 type: flags: immutable enum enums: Overlay=0 Primary=1 Cursor=2 value: 1 37 rotation: flags: bitmask values: rotate-0=0x1 rotate-90=0x2 rotate-180=0x4 rotate-270=0x8 reflect-x=0x10 reflect-y=0x20 value: 1 27 zorder: flags: range values: 0 3 value: 0 38 zpos: flags: range values: 0 3 value: 0 28 global_alpha: flags: range values: 0 255 value: 255 29 pre_mult_alpha: flags: range values: 0 1 value: 0 42 47 60 0,0 0,0 0 0x00000003 formats: RG16 RX12 YUYV AR15 RA24 NV12 RA12 XR24 RG24 UYVY AR12 XR15 AR24 XR12 RX24 props: 6 type: flags: immutable enum enums: Overlay=0 Primary=1 Cursor=2 value: 1 43 rotation: flags: bitmask values: rotate-0=0x1 rotate-90=0x2 rotate-180=0x4 rotate-270=0x8 reflect-x=0x10 reflect-y=0x20 value: 1 27 zorder: flags: range values: 0 3 value: 0 44 zpos: flags: range values: 0 3 value: 0 28 global_alpha: flags: range values: 0 255 value: 255 29 pre_mult_alpha: flags: range values: 0 1 value: 0 48 0 0 0,0 0,0 0 0x00000003 formats: RG16 RX12 YUYV AR15 RA24 NV12 RA12 XR24 RG24 UYVY AR12 XR15 AR24 XR12 RX24 props: 6 type: flags: immutable enum enums: Overlay=0 Primary=1 Cursor=2 value: 0 49 rotation: flags: bitmask values: rotate-0=0x1 rotate-90=0x2 rotate-180=0x4 rotate-270=0x8 reflect-x=0x10 reflect-y=0x20 value: 1 27 zorder: flags: range values: 0 3 value: 2 50 zpos: flags: range values: 0 3 value: 2 28 global_alpha: flags: range values: 0 255 value: 255 29 pre_mult_alpha: flags: range values: 0 1 value: 0 53 0 0 0,0 0,0 0 0x00000003 formats: RG16 RX12 YUYV AR15 RA24 NV12 RA12 XR24 RG24 UYVY AR12 XR15 AR24 XR12 RX24 props: 6 type: flags: immutable enum enums: Overlay=0 Primary=1 Cursor=2 value: 0 54 rotation: flags: bitmask values: rotate-0=0x1 rotate-90=0x2 rotate-180=0x4 rotate-270=0x8 reflect-x=0x10 reflect-y=0x20 value: 1 27 zorder: flags: range values: 0 3 value: 3 55 zpos: flags: range values: 0 3 value: 3 28 global_alpha: flags: range values: 0 255 value: 255 29 pre_mult_alpha: flags: range values: 0 1 value: 0 Frame buffers: id size pitch root@am57xx-evm:/usr/bin#
I have try to test above demo. But got some error. Please check as below:
error:
root@am57xx-evm:/usr/bin# ./viddec3test -s 41:800x480 /home/root/video_test.avi
0x2f008: Opening Display..
using 1 connectors, 800x480 display, multiplanar: 1
Setting mode 800x480 on connector 41, crtc 47
ERROR:post_buffer:298: Could not post buffer on crtc 47: Permission denied (-13)
0x2f008: Opening Demuxer..
[h264 @ 0x31680] error while decoding MB 57 26, bytestream -22
[h264 @ 0x31680] concealing 1512 DC, 1512 AC, 1512 MV errors in I frame
Input #0, h264, from '/home/root/video_test.avi':
Duration: N/A, bitrate: N/A
Stream #0:0: Video: h264 (High), yuvj420p(pc, bt709, progressive), 1280x720 [SAR 1:1 DAR 16:9], 30 fps, 30 tbr, 1200k tbn, 60 tbc
0x2f008: infile=/home/root/video_test.avi, width=1280, height=720
0x2f008: padded_width=1408, padded_height=816, num_buffers=12
^Croot@am57xx-evm:/usr/bin#
I am also sharing you file which shows details of connectors by executing "modetest" command.
Kishan Patel.
root@am57xx-evm:/usr/bin# ./viddec3test -s 47:800x480 /usr/share/ti/video/HistoryOfTI-480p.264 --fps 30 0x2f008: Opening Display.. Forcing playback rate at 30 fps. ERROR:connector_find_mode:492: failed to find mode "800x480" using 1 connectors, 0x0 display, multiplanar: 1 ERROR:alloc_buffer:182: drmModeAddFB2 failed: Invalid argument (-22) ERROR:alloc_buffers:226: allocation failed Segmentation fault (core dumped) root@am57xx-evm:/usr/bin# ./viddec3test -s 41:800x480 /usr/share/ti/video/HistoryOfTI-480p.264 --fps 30 0x2f008: Opening Display.. Forcing playback rate at 30 fps. using 1 connectors, 800x480 display, multiplanar: 1 Setting mode 800x480 on connector 41, crtc 47 0x2f008: Opening Demuxer.. Input #0, h264, from '/usr/share/ti/video/HistoryOfTI-480p.264': Duration: N/A, bitrate: N/A Stream #0:0: Video: h264 (Main), yuv420p(progressive), 720x406 [SAR 406:405 DAR 16:9], 29.92 fps, 29.97 tbr, 1200k tbn, 59.94 tbc 0x2f008: infile=/usr/share/ti/video/HistoryOfTI-480p.264, width=720, height=406 0x2f008: padded_width=896, padded_height=512, num_buffers=19 Page flip: frame=115870, sec=8192, usec=867208, remaining=0 0x2f008: Opening Engine.. displayBufsMode: 1 ^Croot@am57xx-evm:/usr/bin# ==================================================================== root@am57xx-evm:/usr/bin# ./viddec3test -s 41:800x480 /home/root/video_test.avi --fps 3030 0x2f008: Opening Display.. Forcing playback rate at 30 fps. using 1 connectors, 800x480 display, multiplanar: 1 Setting mode 800x480 on connector 41, crtc 47 0x2f008: Opening Demuxer.. [h264 @ 0x31680] error while decoding MB 57 26, bytestream -22 [h264 @ 0x31680] concealing 1512 DC, 1512 AC, 1512 MV errors in I frame Input #0, h264, from '/home/root/video_test.avi': Duration: N/A, bitrate: N/A Stream #0:0: Video: h264 (High), yuvj420p(pc, bt709, progressive), 1280x720 [SAR 1:1 DAR 16:9], 30 fps, 30 tbr, 1200k tbn, 60 tbc 0x2f008: infile=/home/root/video_test.avi, width=1280, height=720 0x2f008: padded_width=1408, padded_height=816, num_buffers=12 Page flip: frame=116256, sec=8239, usec=747979, remaining=0 0x2f008: Opening Engine.. displayBufsMode: 1 ERROR:decoder_process:427: 0x2f008: process returned error: -1 ERROR:decoder_process:428: 0x2f008: extendedError: 02000a00 ERROR:decoder_process:427: 0x2f008: process returned error: -1 ERROR:decoder_process:428: 0x2f008: extendedError: 02000a00 ERROR:decoder_process:427: 0x2f008: process returned error: -1 ERROR:decoder_process:428: 0x2f008: extendedError: 02000a00 ^C^[[Aroot@am57xx-evm:/usr/bin#
Now, i can test demo. Since, i got some errors but video can play.
Please check the errors in attached file.
