PROCESSOR-SDK-AM335X: GPIO interrupt priority
Part Number: PROCESSOR-SDK-AM335X
In am335x, I used the rtlinux version of PSDK. I consulted Datasheet about the interrupt part and found that MPU_INTC.INTC_ILRm registercould set the interrupt priority. Could I modify the gpio interrupt priority through this register in the driver?If so, how to modify and which function interface to call?
  • Hi Chen,
    Yes, this MPU_INTC.INTC_ILRm register could be used for interrupt priority settings. This register is handled in below linux kernel file:
    linux-kernel/drivers/irqchip/irq-omap-intc.c
    Please refer to below e2e threads for details:
    https://e2e.ti.com/support/processors/f/791/t/646848
    https://e2e.ti.com/support/processors/f/791/t/523690
    https://e2e.ti.com/support/processors/f/791/t/651105
    https://e2e.ti.com/support/processors/f/791/t/496264
    Pavel
  • thank you,
    96 GPIOINT0A GPIO 0 POINTRPEND1
    97 GPIOINT0B GPIO 0 POINTRPEND2
    dts:
    gpio0: gpio@44e07000 {
    compatible = "ti,omap4-gpio";
    ti,hwmods = "gpio1";
    clocks = <&dpll_core_m4_div2_ck>, <&gpio0_dbclk>;
    clock-names = "fck", "dbclk";
    gpio-controller;
    #gpio-cells = <2>;
    interrupt-controller;
    #interrupt-cells = <1>;
    reg = <0x44e07000 0x1000>;
    interrupts = <96>;
    I use GPIO_0_19 and GPIO_0_07, and I want to set GPIO_0_19 interrupt priority higher or lower than GPIO_0_07.
    Is GPIO0 interrupt priority NTC_ILR96?How can I change the interrupt priority ofGPIO_0_19 and GPIO_0_07 ?
    INTC_ILR96 Register (offset = 280h) [reset = 0h]
    root@am335x-evm:~# devmem2 0x48200000
    /dev/mem opened.
    Memory mapped at address 0xb6f08000.
    Read at address 0x48200000 (0xb6f08000): 0x00000050
    root@am335x-evm:~# devmem2 0x48200280
    /dev/mem opened.
    Memory mapped at address 0xb6f47000.
    Read at address 0x48200280 (0xb6f47280): 0x00000000
    root@am335x-evm:~#
  • Chen,
    You need to configure gpio0_7 for GPIOINT0A, and gpio0_19 for GPIOINT0B.
    gpio0_7 -> GPIO_IRQSTATUS_SET_0[7] INTLINE = 0x1 -> GPIOINT0A 96
    gpio0_19 -> GPIO_IRQSTATUS_SET_1[19] INTLINE = 0x1 -> GPIOINT0B 97
    Then you need to configure IRQ number 97 with higher priority than 96.
    And gpio0 module in linux-kernel/arch/arm/boot/dts/am33xx.dtsi as below:
    - interrupts = <96>;
    + interrupts = <96 97>;
    + interrupt-names = "gpioint0a", "gpioint0b";
    You can explore how the two McASP0 interrupts are coded, 80 and 81.
    Thus gpio0_7 IRQ priority is controlled by INTC_ILR_96, gpio0_19 IRQ priority is controlled by INTC_ILR_97
    Pavel
