Hi Expert,
AM3352: DDR3 tDQSS out of specification - Processors forum - Processors - TI E2E support forums
Doese it mean that 16-bit wide DDR DON'T have to do Software Leveling, is it correct?
Does I have to do Software Leveling if my design is 2x 8-bit wide DDR?
Do I need JTAG interface If I have to do Software Leveling?
Could I do Software Leveling via SD card?
Daniel
Daniel, software leveling is required if your DDR layout implements a fly by topology. I'm assuming this is what you have since you are using 2x 8-bit wide DDRs. The software leveling algorithm will calculate the appropriate registers which adjust the address/command delays for each of the memories on the bus. The algorithm is run via JTAG. Please see the following appnote: https://www.ti.com/lit/pdf/sprack4
James
