Part Number: AM6548
Hi Ti,
We tired to boot SDK 07_01_00_18 on our AM654x EVM board and ASSM #:4P0081 REV:1.0.
However, we got the below error message when boot into kernel.
[ 2.641800] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[ 2.641814] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 2.641819] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004
[ 2.641823] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x000000dd
[ 2.641828] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033
[ 2.641833] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b
[ 2.641838] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 2.641843] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 2.641847] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 2.641851] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b
[ 2.641856] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 2.641860] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407
[ 2.641865] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000
[ 2.641868] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x003b377f
[ 2.641873] 000: mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000b00
[ 2.641877] 000: mmc1: sdhci: Host ctl2: 0x00000000
[ 2.641881] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b73224
[ 2.641885] 000: mmc1: sdhci: ============================================
Do you have any idea why the error log happened?
Attached the kernel log.
U-Boot SPL 2020.01-dirty (Dec 17 2020 - 08:54:17 +0800) SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla') Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.3():07.01.00.004-1-g52c334fc3-dirty NOTICE: BL31: Built : 04:16:36, Nov 26 2020 U-Boot SPL 2020.01-dirty (Dec 17 2020 - 08:52:45 +0800) SYSFW ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla') Detected: AM6-IDKAPPEVM rev E4 Trying to boot from MMC2 U-Boot 2020.01-dirty (Dec 17 2020 - 08:52:45 +0800) SoC: AM65X SR1.0 Model: Texas Instruments AM654 Base Board Board: AM6-COMPROCEVM rev E4 DRAM: 4 GiB MMC: sdhci@4f80000: 0, sdhci@4fa0000: 1 Loading Environment from MMC... OK In: serial Out: serial Err: serial Detected: AM6-IDKAPPEVM rev E4 Net: eth3: pruss1_eth, eth2: pruss0_eth, eth0: ethernet@46000000, eth1: pruss2_eth Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 1011 bytes read in 5 ms (197.3 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 15392776 bytes read in 652 ms (22.5 MiB/s) 64327 bytes read in 11 ms (5.6 MiB/s) 11133 bytes read in 5 ms (2.1 MiB/s) ## Flattened Device Tree blob at 82000000 Booting using the fdt blob at 0x82000000 Loading Device Tree to 00000000fddb0000, end 00000000fdec2fff ... OK Starting kernel ... [ 0.000000] 000: printk: bootconsole [ns16550a0] enabled [ 0.000000] 000: Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] 000: OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] 000: Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] 000: OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] 000: Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] 000: OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] 000: Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] 000: OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] 000: cma: Reserved 24 MiB at 0x00000000fe800000 [ 0.000000] 000: On node 0 totalpages: 896512 [ 0.000000] 000: DMA zone: 4096 pages used for memmap [ 0.000000] 000: DMA zone: 0 pages reserved [ 0.000000] 000: DMA zone: 247296 pages, LIFO batch:63 [ 0.000000] 000: DMA32 zone: 1952 pages used for memmap [ 0.000000] 000: DMA32 zone: 124928 pages, LIFO batch:31 [ 0.000000] 000: Normal zone: 8192 pages used for memmap [ 0.000000] 000: Normal zone: 524288 pages, LIFO batch:63 [ 0.000000] 000: psci: probing for conduit method from DT. [ 0.000000] 000: psci: PSCIv1.1 detected in firmware. [ 0.000000] 000: psci: Using standard PSCI v0.2 function IDs [ 0.000000] 000: psci: Trusted OS migration not required [ 0.000000] 000: psci: SMC Calling Convention v1.0 [ 0.000000] 000: percpu: Embedded 18 pages/cpu s32960 r8192 d32576 u73728 [ 0.000000] 000: pcpu-alloc: s32960 r8192 d32576 u73728 alloc=18*4096 [ 0.000000] 000: [ 0.000000] 000: pcpu-alloc: [ 0.000000] 000: [0] [ 0.000000] 000: 0 [ 0.000000] 000: [0] [ 0.000000] 000: 1 [ 0.000000] 000: [0] [ 0.000000] 000: 2 [ 0.000000] 000: [0] [ 0.000000] 000: 3 [ 0.000000] 000: [ 0.000000] 000: Detected VIPT I-cache on CPU0 [ 0.000000] 000: CPU features: detected: ARM erratum 845719 [ 0.000000] 000: CPU features: detected: GIC system register CPU interface [ 0.000000] 000: Built 1 zonelists, mobility grouping on. Total pages: 882272 [ 0.000000] 000: Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs) root=PARTUUID=1e3617d0-02 rw rootfstype=ext4 rootwait [ 0.000000] 000: Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes, linear) [ 0.000000] 000: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] 000: mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] 000: software IO TLB: mapped [mem 0xbbfff000-0xbffff000] (64MB) [ 0.000000] 000: Memory: 3944420K/3586048K available (9278K kernel code, 632K rwdata, 3600K rodata, 1472K init, 423K bss, 18446744073709168668K reserved, 24576K cma-reserved) [ 0.000000] 000: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] 000: rcu: Preemptible hierarchical RCU implementation. [ 0.000000] 000: rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] 000: rcu: RCU priority boosting: priority 1 delay 500 ms. [ 0.000000] 000: rcu: RCU_SOFTIRQ processing moved to rcuc kthreads. [ 0.000000] 000: No expedited grace period (rcu_normal_after_boot). [ 0.000000] 000: Tasks RCU enabled. [ 0.000000] 000: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] 000: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] 000: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] 000: GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] 000: GICv3: 960 SPIs implemented [ 0.000000] 000: GICv3: 0 Extended SPIs implemented [ 0.000000] 000: GICv3: Distributor has no Range Selector support [ 0.000000] 000: GICv3: 16 PPIs implemented [ 0.000000] 000: GICv3: no VLPI support, no direct LPI support [ 0.000000] 000: GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] 000: ITS [mem 0x01820000-0x0182ffff] [ 0.000000] 000: GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] 000: ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] 000: ITS@0x0000000001820000: allocated 524288 Devices @8f9c00000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] 000: ITS: using cache flushing for cmd queue [ 0.000000] 000: GICv3: using LPI property table @0x00000008fa440000 [ 0.000000] 000: GIC: using cache flushing for LPI property table [ 0.000000] 000: GICv3: CPU0: using allocated LPI pending table @0x00000008fa450000 [ 0.000000] 000: random: get_random_bytes called from start_kernel+0x2bc/0x440 with crng_init=0 [ 0.000000] 000: arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] 000: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] 000: sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.009103] 000: Console: colour dummy device 80x25 [ 0.014159] 000: Calibrating delay loop (skipped), value calculated using timer frequency.. [ 0.022798] 000: 400.00 BogoMIPS (lpj=800000) [ 0.027257] 000: pid_max: default: 32768 minimum: 301 [ 0.032567] 000: LSM: Security Framework initializing [ 0.037828] 000: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.045874] 000: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.056482] 000: ASID allocator initialised with 32768 entries [ 0.062601] 000: rcu: Hierarchical SRCU implementation. [ 0.068603] 000: Platform MSI: gic-its@1820000 domain created [ 0.074814] 000: PCI/MSI: /bus@100000/interrupt-controller@1800000/gic-its@1820000 domain created [ 0.084331] 000: smp: Bringing up secondary CPUs ... [ 0.090680] 001: Detected VIPT I-cache on CPU1 [ 0.095256] 001: GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.102741] 001: GICv3: CPU1: using allocated LPI pending table @0x00000008fa460000 [ 0.110610] 001: CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.119134] 002: Detected VIPT I-cache on CPU2 [ 0.123724] 002: GICv3: CPU2: found redistributor 100 region 0:0x00000000018c0000 [ 0.131385] 002: GICv3: CPU2: using allocated LPI pending table @0x00000008fa470000 [ 0.139258] 002: CPU2: Booted secondary processor 0x0000000100 [0x410fd034] [ 0.147746] 003: Detected VIPT I-cache on CPU3 [ 0.152308] 003: GICv3: CPU3: found redistributor 101 region 0:0x00000000018e0000 [ 0.159964] 003: GICv3: CPU3: using allocated LPI pending table @0x00000008fa480000 [ 0.167817] 003: CPU3: Booted secondary processor 0x0000000101 [0x410fd034] [ 0.175092] 000: smp: Brought up 1 node, 4 CPUs [ 0.179760] 000: SMP: Total of 4 processors activated. [ 0.185043] 000: CPU features: detected: 32-bit EL0 Support [ 0.190772] 000: CPU features: detected: CRC32 instructions [ 0.207992] 000: CPU: All CPU(s) started at EL2 [ 0.212700] 000: alternatives: patching kernel code [ 0.219480] 000: devtmpfs: initialized [ 0.237297] 000: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.247764] 000: futex hash table entries: 1024 (order: 5, 131072 bytes, linear) [ 0.256554] 000: pinctrl core: initialized pinctrl subsystem [ 0.263496] 000: NET: Registered protocol family 16 [ 0.270622] 000: DMA: preallocated 256 KiB pool for atomic allocations [ 0.278261] 000: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.312118] 001: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.319473] 001: HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.326848] 001: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.334208] 001: HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.343033] 001: cryptd: max_cpu_qlen set to 1000 [ 0.353747] 001: iommu: Default domain type: Translated [ 0.359730] 001: SCSI subsystem initialized [ 0.364840] 001: mc: Linux media interface: v0.10 [ 0.369737] 001: videodev: Linux video capture interface: v2.00 [ 0.375873] 001: pps_core: LinuxPPS API ver. 1 registered [ 0.381420] 001: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.391252] 001: PTP clock support registered [ 0.395760] 001: EDAC MC: Ver: 3.0.0 [ 0.400864] 001: FPGA manager framework [ 0.404951] 001: Advanced Linux Sound Architecture Driver Initialized. [ 0.412634] 000: clocksource: Switched to clocksource arch_sys_counter [ 0.419564] 000: VFS: Disk quotas dquot_6.6.0 [ 0.424110] 000: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.440084] 000: thermal_sys: Registered thermal governor 'step_wise' [ 0.446713] 000: thermal_sys: Registered thermal governor 'power_allocator' [ 0.454501] 000: NET: Registered protocol family 2 [ 0.460119] 000: tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.469585] 000: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.478558] 000: TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear) [ 0.488462] 000: TCP: Hash tables configured (established 32768 bind 32768) [ 0.495910] 000: UDP hash table entries: 2048 (order: 6, 262144 bytes, linear) [ 0.503634] 000: UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear) [ 0.512071] 000: NET: Registered protocol family 1 [ 0.517793] 001: RPC: Registered named UNIX socket transport module. [ 0.524338] 001: RPC: Registered udp transport module. [ 0.529614] 001: RPC: Registered tcp transport module. [ 0.534886] 001: RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.541945] 001: PCI: CLS 0 bytes, default 64 [ 0.547528] 001: hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 0.561757] 003: Initialise system trusted keyrings [ 0.567002] 003: workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.582810] 003: squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.590110] 003: NFS: Registering the id_resolver key type [ 0.595784] 003: Key type id_resolver registered [ 0.600544] 003: Key type id_legacy registered [ 0.605133] 003: nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.612739] 003: 9p: Installing v9fs 9p2000 file system support [ 0.639049] 003: Key type asymmetric registered [ 0.643727] 003: Asymmetric key parser 'x509' registered [ 0.649237] 003: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.657278] 003: io scheduler mq-deadline registered [ 0.662391] 003: io scheduler kyber registered [ 0.670104] 003: pinctrl-single 4301c000.pinmux: 70 pins, size 280 [ 0.677141] 003: pinctrl-single 11c000.pinmux: 185 pins, size 740 [ 0.683616] 003: pinctrl-single 11c2e8.pinmux: 9 pins, size 36 [ 0.697234] 003: k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.704096] 003: k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.716701] 003: Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.744117] 003: brd: module loaded [ 0.759488] 002: loop: module loaded [ 0.768116] 002: libphy: Fixed MDIO Bus: probed [ 0.773574] 002: tun: Universal TUN/TAP device driver, 1.6 [ 0.780148] 002: igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k [ 0.788662] 002: igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.795258] 002: sky2: driver version 1.30 [ 0.801094] 002: VFIO - User Level meta-driver version: 0.3 [ 0.807900] 002: i2c /dev entries driver [ 0.813522] 002: sdhci: Secure Digital Host Controller Interface driver [ 0.820323] 002: sdhci: Copyright(c) Pierre Ossman [ 0.825928] 002: sdhci-pltfm: SDHCI platform and OF driver helper [ 0.833774] 002: ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: invalid resource [ 0.843465] 002: optee: probing for conduit method from DT. [ 0.849224] 002: optee: revision 3.8 (199fca17) [ 0.854609] 002: optee: initialized driver [ 0.860926] 002: NET: Registered protocol family 17 [ 0.866165] 002: 9pnet: Installing 9P2000 support [ 0.871101] 002: Key type dns_resolver registered [[ 00..087006500700]] 000030:: Broegoitsitnge reLid ntuax skosnt pahtys sivceralsi oCnPU 1 0 x0[0 0 0 0000.8008507 [009x]4 01003:fd 0L3oa4d]i ng compiled-in X.509 certificates [ 0.904729] 003: k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.911785] 003: k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.925197] 003: ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: invalid resource [ 0.933516] 003: ti-sci bus@100000:bus@28380000:bus@42040000:dmsc: ABI: 3.1 (firmware rev 0x0014 '20.8.5--v2020.08b (Terrific Lla') [ 1.000119] 000: random: fast init done [ 1.011861] 003: omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz [ 1.018912] 003: omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz [ 1.026062] 003: pca953x 2-0041: 2-0041 supply vcc not found, using dummy regulator [ 1.034028] 003: pca953x 2-0041: using no AI [ 1.061375] 003: pca953x 2-0021: 2-0021 supply vcc not found, using dummy regulator [ 1.069307] 003: pca953x 2-0021: using no AI [ 1.074560] 003: omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz [ 1.081733] 003: omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz [ 1.088707] 003: omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz [ 1.095546] 003: omap_i2c 2030000.i2c: bus 5 rev0.12 at 100 kHz [ 1.102756] 003: ti-sci-intr bus@100000:bus@28380000:bus@42040000:interrupt-controller2: Interrupt Router 156 domain created [ 1.114505] 003: ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 100 domain created [ 1.123925] 003: ti-sci-intr bus@100000:navss@30800000:interrupt-controller1: Interrupt Router 182 domain created [ 1.134848] 003: ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 179 created [ 1.154390] 003: k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,160] sci-dev-id:195 [ 1.164864] 003: k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: enabled [ 1.172015] 003: k3-ringacc 2b800000.ringacc: RA Proxy rev. 66344100, num_proxies:64 [ 1.197842] 003: k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:818, gp-rings[304,464] sci-dev-id:187 [ 1.208415] 003: k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: enabled [ 1.215565] 003: k3-ringacc 3c000000.ringacc: RA Proxy rev. 66344100, num_proxies:64 [ 1.224543] 003: 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 8, base_baud = 6000000) is a 8250 [ 1.235027] 003: 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 21, base_baud = 3000000) is a 8250 [ 1.244291] 003: printk: console [ttyS2] enabled [ 1.249062] 003: printk: bootconsole [ns16550a0] disabled [ 1.244291] 003: printk: console [ttyS2] enabled [ 1.249062] 003: printk: bootconsole [ns16550a0] disabled [ 1.260132] 003: 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 22, base_baud = 3000000) is a 8250 [ 1.261020] 003: 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 23, base_baud = 3000000) is a 8250 [ 1.312679] 003: davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.312699] 003: libphy: 46000f00.mdio: probed [ 1.314111] 003: davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 1.314152] 003: am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA07100, cpsw version 0x6BA80100 Ports: 2 quirks:00000001 [ 1.314459] 003: am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517 [ 1.317085] 003: am65-cpts 310d0000.cpts: CPTS ver 0x4e8a2109, freq:200000000, add_val:4 pps:0 [ 1.318761] 003: mmc0: CQHCI version 5.10 [ 1.359271] 003: mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit [ 1.375307] 003: pca953x 0-0039: 0-0039 supply vcc not found, using dummy regulator [ 1.375452] 003: pca953x 0-0039: using no AI [ 1.398307] 003: omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc5900 [ 1.398790] 003: omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc5900 [ 1.403402] 003: ti-udma 285c0000.dma-controller: Channels: 96 (tchan: 48, rchan: 48, gp-rflow: 48) [ 1.421800] 003: ti-udma 31150000.dma-controller: Channels: 267 (tchan: 119, rchan: 148, gp-rflow: 150) [ 1.443745] 003: mmc0: Command Queue Engine enabled [ 1.443771] 003: mmc0: new HS200 MMC card at address 0001 [ 1.444582] 003: mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 1.444891] 003: mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB [ 1.445176] 003: mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB [ 1.445431] 003: mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (240:0) [ 1.447190] 003: mmcblk0: p1 p2 [ 1.483168] 003: cadence-qspi 47040000.spi: PHY calibration failed: -2 [ 1.483182] 003: spi-nor spi7.0: mt35xu512aba (65536 Kbytes) [ 1.483206] 003: 7 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 1.483212] 003: Creating 7 MTD partitions on "47040000.spi.0": [ 1.483228] 003: 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.484979] 003: 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.486568] 003: 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.488226] 003: 0x000000680000-0x0000006a0000 : "ospi.env" [ 1.489847] 003: 0x0000006a0000-0x0000006c0000 : "ospi.env.backup" [ 1.491435] 003: 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 1.493062] 003: 0x000000800000-0x000004000000 : "ospi.rootfs" [ 1.504158] 003: spi-nor spi9.0: n25q128a13 (16384 Kbytes) [ 1.544685] 003: davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.544701] 003: libphy: 46000f00.mdio: probed [ 1.546149] 003: davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 1.546190] 003: am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA07100, cpsw version 0x6BA80100 Ports: 2 quirks:00000001 [ 1.548099] 003: am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 1.548857] 003: am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 57.4 [ 1.548866] 003: am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.549938] 003: am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a2109, freq:200000000, add_val:4 pps:0 [ 1.555083] 003: mmc1: CQHCI version 5.10 [ 2.387936] 003: mmc1: SDHCI controller on 4fa0000.sdhci [4fa0000.sdhci] using ADMA 64-bit [ 2.389407] 000: debugfs: Directory 'pd:121' with parent 'pm_genpd' already present! [ 2.389508] 000: debugfs: Directory 'pd:120' with parent 'pm_genpd' already present! [ 2.393097] 000: input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 2.393493] 000: hctosys: unable to open rtc device (rtc0) [ 2.411080] 001: ALSA device list: [ 2.411088] 001: No soundcards found. [ 2.428899] 001: Waiting for root device PARTUUID=1e3617d0-02... [ 2.443675] 003: mmc1: error -110 whilst initialising SD card [ 2.629615] 003: mmc1: new high speed SDHC card at address e624 [ 2.630452] 003: mmcblk1: mmc1:e624 SU08G 7.40 GiB [ 2.634589] 003: mmcblk1: p1 p2 [ 2.641800] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 2.641814] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 2.641819] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 2.641823] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x000000dd [ 2.641828] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 2.641833] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 2.641838] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 2.641843] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 2.641847] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 2.641851] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 2.641856] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 2.641860] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 2.641865] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 2.641868] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x003b377f [ 2.641873] 000: mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000b00 [ 2.641877] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 2.641881] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b73224 [ 2.641885] 000: mmc1: sdhci: ============================================ [ 2.643268] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 2.643274] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 2.643277] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 2.643281] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x000000e0 [ 2.643285] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 2.643289] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 2.643293] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 2.643297] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 2.643301] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 2.643305] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 2.643309] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 2.643314] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 2.643318] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 2.643322] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x003b377f [ 2.643326] 000: mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000b00 [ 2.643330] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 2.643333] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b73224 [ 2.643337] 000: mmc1: sdhci: ============================================ [ 2.919995] 001: EXT4-fs (mmcblk1p2): warning: mounting fs with errors, running e2fsck is recommended [ 2.929698] 001: EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 2.929781] 001: VFS: Mounted root (ext4 filesystem) on device 179:98. [ 2.932649] 001: devtmpfs: mounted [ 2.933772] 001: Freeing unused kernel memory: 1472K [ 2.933893] 001: Run /sbin/init as init process [ 2.936759] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 2.936768] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 2.936773] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 2.936778] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000066 [ 2.936782] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 2.936786] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 2.936791] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 2.936795] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 2.936799] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 2.936803] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 2.936808] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 2.936812] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 2.936816] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 2.936820] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 2.936825] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00000b00 [ 2.936829] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 2.936833] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b73224 [ 2.936837] 000: mmc1: sdhci: ============================================ [ 2.938805] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 2.938811] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 2.938815] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 2.938819] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000068 [ 2.938825] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 2.938829] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 2.938833] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 2.938837] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 2.938841] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 2.938845] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 2.938849] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 2.938853] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 2.938857] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 2.938861] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 2.938865] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00000b00 [ 2.938869] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 2.938872] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b73224 [ 2.938876] 000: mmc1: sdhci: ============================================ [ 3.184720] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.184728] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 3.184732] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 3.184736] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x000000dc [ 3.184740] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 3.184744] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 3.184748] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 3.184751] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 3.184755] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 3.184759] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 3.184763] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 3.184767] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 3.184771] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 3.184774] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 3.184778] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00000b00 [ 3.184782] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 3.184786] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b73218 [ 3.184790] 000: mmc1: sdhci: ============================================ [ 3.186251] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.186257] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 3.186261] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 3.186265] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x000000de [ 3.186269] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 3.186274] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 3.186278] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 3.186282] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 3.186285] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 3.186289] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 3.186293] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 3.186297] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 3.186301] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 3.186305] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 3.186309] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00000b00 [ 3.186312] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 3.186316] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b73218 [ 3.186319] 000: mmc1: sdhci: ============================================ [ 3.463308] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.463317] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 3.463321] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 3.463325] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x000000d8 [ 3.463329] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 3.463333] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 3.463337] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 3.463341] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 3.463345] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 3.463348] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 3.463353] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 3.463356] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 3.463361] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 3.463364] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 3.463368] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00000b00 [ 3.463373] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 3.463376] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 3.463380] 000: mmc1: sdhci: ============================================ [ 3.464643] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.464648] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 3.464652] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 3.464656] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x000000dd [ 3.464660] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 3.464664] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 3.464667] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 3.464671] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 3.464675] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 3.464679] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 3.464683] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 3.464687] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 3.464691] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 3.464694] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 3.464698] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00000b00 [ 3.464702] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 3.464705] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 3.464709] 000: mmc1: sdhci: ============================================ [ 3.739167] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.739179] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 3.739182] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 3.739187] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000013 [ 3.739191] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 3.739195] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 3.739199] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 3.739203] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 3.739207] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 3.739210] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 3.739215] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 3.739220] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 3.739224] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 3.739228] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 3.739232] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00000b00 [ 3.739236] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 3.739240] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 3.739244] 000: mmc1: sdhci: ============================================ [ 3.740366] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.740372] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 3.740375] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 3.740379] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000013 [ 3.740383] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 3.740386] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 3.740390] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 3.740394] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 3.740398] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 3.740402] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 3.740406] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 3.740409] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 3.740413] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 3.740417] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 3.740421] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00000b00 [ 3.740425] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 3.740428] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 3.740432] 000: mmc1: sdhci: ============================================ [ 3.936535] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.936546] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 3.936550] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 3.936554] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x0000002b [ 3.936558] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 3.936562] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 3.936567] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 3.936570] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 3.936574] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 3.936578] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 3.936583] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 3.936588] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 3.936592] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 3.936595] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 3.936599] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00035344 [ 3.936603] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 3.936607] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 3.936611] 000: mmc1: sdhci: ============================================ [ 3.939198] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.939204] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 3.939207] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 3.939211] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x0000002d [ 3.939215] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 3.939219] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 3.939223] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 3.939227] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 3.939231] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 3.939235] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 3.939239] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 3.939242] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 3.939246] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 3.939250] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 3.939254] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00035344 [ 3.939258] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 3.939261] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 3.939265] 000: mmc1: sdhci: ============================================ [ 3.996697] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.996704] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 3.996707] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 3.996712] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x0000007f [ 3.996716] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 3.996719] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 3.996723] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 3.996727] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 3.996731] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 3.996734] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 3.996738] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 3.996742] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 3.996746] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 3.996750] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 3.996753] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00035344 [ 3.996757] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 3.996761] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 3.996765] 000: mmc1: sdhci: ============================================ [ 3.997447] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 3.997452] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 3.997455] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 3.997460] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000080 [ 3.997465] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 3.997468] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 3.997472] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 3.997476] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 3.997480] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 3.997483] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 3.997487] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 3.997491] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 3.997495] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 3.997499] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 3.997502] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00035344 [ 3.997506] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 3.997509] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 3.997513] 000: mmc1: sdhci: ============================================ [ 4.051924] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 4.051932] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 4.051935] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 4.051939] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x0000005f [ 4.051943] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 4.051947] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 4.051951] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 4.051955] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 4.051960] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 4.051964] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 4.051968] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 4.051972] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 4.051976] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 4.051980] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 4.051983] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00035344 [ 4.051987] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 4.051990] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 4.051994] 000: mmc1: sdhci: ============================================ [ 4.095784] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 4.095791] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 4.095795] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 4.095798] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x000000c6 [ 4.095802] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 4.095807] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 4.095811] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 4.095815] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 4.095819] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 4.095823] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 4.095827] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 4.095831] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 4.095835] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 4.095839] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 4.095843] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00035344 [ 4.095846] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 4.095849] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 4.095853] 000: mmc1: sdhci: ============================================ [ 4.097032] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 4.097037] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 4.097041] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 4.097045] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x000000c7 [ 4.097048] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 4.097052] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 4.097056] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 4.097059] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 4.097063] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 4.097067] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 4.097071] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 4.097074] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 4.097078] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 4.097082] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 4.097086] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00035344 [ 4.097089] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 4.097093] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 4.097096] 000: mmc1: sdhci: ============================================ [ 4.191004] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 4.191011] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 4.191015] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 4.191020] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000014 [ 4.191024] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 4.191028] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 4.191032] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 4.191036] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 4.191039] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 4.191043] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 4.191048] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 4.191052] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 4.191056] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 4.191060] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 4.191064] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00000b00 [ 4.191067] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 4.191071] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 4.191074] 000: mmc1: sdhci: ============================================ [ 4.191911] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 4.191917] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 4.191920] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 4.191924] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000015 [ 4.191928] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 4.191931] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 4.191935] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 4.191939] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 4.191943] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 4.191947] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 4.191951] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 4.191954] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 4.191958] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 4.191962] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 4.191966] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00000b00 [ 4.191970] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 4.191973] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 4.191977] 000: mmc1: sdhci: ============================================ [ 4.387970] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 4.387978] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 4.387981] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 4.387985] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000056 [ 4.387989] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 4.387993] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 4.387997] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 4.388001] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 4.388005] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 4.388008] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 4.388013] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 4.388016] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 4.388020] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 4.388024] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 4.388028] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00035344 [ 4.388031] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 4.388035] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 4.388038] 000: mmc1: sdhci: ============================================ [ 4.389800] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 4.389805] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 4.389808] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 4.389812] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000057 [ 4.389816] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 4.389820] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 4.389824] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 4.389828] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 4.389831] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 4.389835] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 4.389839] 000: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000 [ 4.389843] 000: mmc1: sdhci: Caps: 0x3fe8c801 | Caps_1: 0x18000407 [ 4.389847] 000: mmc1: sdhci: Cmd: 0x00000c1a | Max curr: 0x00000000 [ 4.389851] 000: mmc1: sdhci: Resp[0]: 0x00000b00 | Resp[1]: 0x478030c0 [ 4.389854] 000: mmc1: sdhci: Resp[2]: 0x53553038 | Resp[3]: 0x00035344 [ 4.389858] 000: mmc1: sdhci: Host ctl2: 0x00000000 [ 4.389861] 000: mmc1: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000008f8b7320c [ 4.389866] 000: mmc1: sdhci: ============================================ [ 4.448795] 000: mmc1: Got data interrupt 0x00000002 even though no data operation was in progress. [ 4.448802] 000: mmc1: sdhci: ============ SDHCI REGISTER DUMP =========== [ 4.448805] 000: mmc1: sdhci: Sys addr: 0x00000000 | Version: 0x00001004 [ 4.448809] 000: mmc1: sdhci: Blk size: 0x00007200 | Blk cnt: 0x000000f6 [ 4.448814] 000: mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x00000033 [ 4.448818] 000: mmc1: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001b [ 4.448823] 000: mmc1: sdhci: Power: 0x0000000f | Blk gap: 0x00000080 [ 4.448827] 000: mmc1: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207 [ 4.448830] 000: mmc1: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000 [ 4.448834] 000: mmc1: sdhci: Int enab: 0x03ff008b | Sig enab: 0x03ff008b [ 4.448838] 000: mmc1: sdhci: ACmd stat: 0x00000000 |
Thanks.
Eric
