DRA71XEVM: DRA71XEVM - How to reduce booting time
Part Number: DRA71XEVM
Hi experts,
I'm working on a DRA71XEVM (JACINTO 6 ENTRY/RSP EVM) and using VISION_SDK (PROCESSOR_SDK_VISION_03_08_00_00)
Due to product demand of H/Lamp, boot time need to be reduced to 1s and now is about 3s.0
I find that it takes a long time (about 700ms) for GRPXSRC to create. My question is how to optimize it or is there any reference design?
[IPU1-0]      1.997773 s:  GRPXSRC: Create in progress !!!
[IPU1-0]      2.657658 s:  GRPXSRC: Create Done !!!
Are there any additional ways to shorten the boot time ?
thanks.
teraterm_SBL_210429.log
 TDA2Ex SBL Boot
 DPLL Configuration Completed
 Clock Domain Configuration Completed
 Module Enable Configuration Completed
 TI EVM PAD Config Completed
 DDR Config Completed
 App Image Download Begins
 Manufacturer ID - 0x1
 Device ID - 0x18
 MPU CPU0 Image Load Completed
 IPU1 CPU0 Image Load Completed
 IPU1 CPU1 Image Load Completed
 DSP1 Image Load Completed
 App Image Download Completed
 PMCCNTR counts once every 64 clock cycles, multiple by 64 to get actual CPU cycles
 SBL Initial Config Cycles - 1690362  (135.22 ms)
 SOC Init Cycles - 212921  (17.3 ms)
 DDR Config Clock Cycles - 49050  (3.92 ms)
 App Image Load Cycles - 3151887  (252.15 ms)
 Slave Core Bootup Cycles - 16327  (1.30 ms)
 SBL Boot-up Cycles - 5128600  (410.28 ms)
 Time at which SBL started IPU1_0 - 15872  (1.26 ms)
 Jumping to MPU CPU0 App
[IPU1-0]      0.489660 s:  ***** IPU1_0 Firmware build time 12:43:03 Apr 29 2021
[IPU1-0]      0.489843 s:  *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[IPU1-0]      0.551790 s:  SYSTEM: Notify register to [IPU1-1] line 0, event 15...
[IPU1-0]      0.551942 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
[IPU1-0]      0.552095 s:  SYSTEM: Notify register to [HOST] line 0, event 15...
[IPU1-0]      0.553894 s:  *** UTILS: CPU MHz = 20 Mhz ***
[IPU1-0]      0.554047 s:  SYSTEM: System Common Init in progress !!!
[IPU1-0]      0.563777 s:  UTILS: CIO: Init Done !!!
[IPU1-0]      0.563868 s:  SYSTEM: IPC init in progress !!!
[IPU1-0]      0.563929 s:  SYSTEM: Notify init done !!!
[IPU1-0]      0.565698 s:  SYSTEM: MsgQ init done !!!
[IPU1-0]      0.565790 s:  SYSTEM: IPC init DONE !!!
[IPU1-0]      0.569602 s:  SYSTEM: System Common Init Done !!!
[IPU1-0]      0.569694 s:  SYSTEM: System Init in progress !!!
[IPU1-0]      0.569755 s:  SYSTEM: BSP Common Init in progress !!!
[IPU1-0]      0.569816 s:  SYSTEM: BSP Common Init Done !!!
[IPU1-0]      0.569877 s:  SYSTEM: BSP Platform Init in progress !!!
[IPU1-0]      0.570029 s:  SYSTEM: BSP Platform Init Done !!!
[IPU1-0]      0.570121 s:  SYSTEM: FVID2 Init in progress !!!
[IPU1-0]      0.570243 s:  SYSTEM: FVID2 Init Done !!!
[IPU1-0]      0.570334 s:  SYSTEM: VPS Init in progress !!!
[IPU1-0]      0.570456 s:  SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0xa0000000 -> 0x80000000]
[IPU1-0]      0.573232 s: *** VPDMA Firmware Loading... ***
[IPU1-0]      0.573354 s: VPDMA Firmware Address = 0x9fd197c0
[IPU1-0]      0.573476 s: VPDMA Load Address     = 0x4897d004
[IPU1-0]      0.573598 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0]      0.573689 s: VPDMA List Busy Status = 0x00000000
[IPU1-0]      0.573750 s: *** VPDMA Firmware Load Success ***
[IPU1-0]      0.574086 s: *** VPDMA Firmware Loading... ***
[IPU1-0]      0.574178 s: VPDMA Firmware Address = 0x9fd197c0
[IPU1-0]      0.574269 s: VPDMA Load Address     = 0x489dd004
[IPU1-0]      0.574361 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0]      0.574513 s: VPDMA List Busy Status = 0x00000000
[IPU1-0]      0.574605 s: *** VPDMA Firmware Load Success ***
[IPU1-0]      0.607759 s:  SYSTEM: VPS Init Done !!!
[IPU1-0]      0.608613 s:  UTILS: DMA: HWI Create for INT34 !!!
[IPU1-0]      0.608796 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[IPU1-0]      0.608887 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 258104 B (252 KB)
[IPU1-0]      0.609040 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[IPU1-0]      0.609192 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x85083000, Total size = 368037888 B (350 MB), Free size = 368037888 B (350 MB)
[IPU1-0]      0.609406 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xbfc00000, Total size = 129408 B (0 MB), Free size = 124800 B (0 MB)
[IPU1-0]      0.609619 s:  SYSTEM: Initializing Links !!!
[IPU1-0]      0.779814 s:  SYSTEM: Initializing Links ... DONE !!!
[IPU1-0]      0.788415 s:  BOARD: Board Init in progress !!!
[IPU1-0]      0.788812 s:  BOARD: Board Init Done !!!
[IPU1-0]      0.798755 s:
[IPU1-0]      0.798816 s:  Vision SDK Version    : [REL_VISION_SDK_03_08_00_00]
[IPU1-0]      0.798908 s:  FVID2 Version         : [FVID_02_01_00_01]
[IPU1-0]      0.798969 s:  BSP Version           : [PDK_01_10_04__xx]
[IPU1-0]      0.799030 s:  Platform              : [EVM]
[IPU1-0]      0.799091 s:  SOC                   : [TDA2EX]
[IPU1-0]      0.799152 s:  SOC Revision          : [ES2.1]
[IPU1-0]      0.799213 s:  Board Detected        : [Vision]
[IPU1-0]      0.806655 s:  EEPROM Base Board Name: [DRA79x,DRA71x]
[IPU1-0]      0.806746 s:  EEPROM Base Board EMIF1 Size: 2048 MB
[IPU1-0]      0.806838 s:  EEPROM Base Board EMIF2 Size: 0 MB
[IPU1-0]      0.806899 s:  Base Board Revision   : [REV C]
[IPU1-0]      0.808210 s:  Daughter Card Revision: [REV D]
[IPU1-0]      0.808271 s:
[IPU1-0]      0.811901 s:  SYSTEM: UART: INTERRUPT Mode is Selected
[IPU1-1]      0.500152 s:  ***** IPU1_1 Firmware build time 12:40:02 Apr 29 2021
[IPU1-1]      0.500335 s:  *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[IPU1-1]      0.552186 s:  SYSTEM: Notify register to [IPU1-0] line 0, event 15...
[IPU1-1]      0.552369 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
[IPU1-1]      0.552491 s:  SYSTEM: Notify register to [HOST] line 0, event 15...
[IPU1-1]      0.554413 s:  SYSTEM: System Common Init in progress !!!
[IPU1-1]      0.555450 s:  UTILS: CIO: Init Done !!!
[IPU1-1]      0.555572 s:  SYSTEM: IPC init in progress !!!
[IPU1-1]      0.555633 s:  SYSTEM: Notify init done !!!
[IPU1-1]      0.557311 s:  SYSTEM: MsgQ init done !!!
[IPU1-1]      0.557402 s:  SYSTEM: IPC init DONE !!!
[IPU1-1]      0.560940 s:  SYSTEM: System Common Init Done !!!
[IPU1-1]      0.561062 s:  SYSTEM: System IPU1_1 Init in progress !!!
[IPU1-1]      0.561855 s:  UTILS: DMA: HWI Create for INT25 !!!
[IPU1-1]      0.562038 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[IPU1-1]      0.562160 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 258232 B (252 KB)
[IPU1-1]      0.562282 s:  SYSTEM: Initializing Links !!!
[IPU1-1]      0.663819 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC1 ####
[IPU1-1]      0.666564 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC2 ####
[IPU1-1]      0.669340 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC3 ####
[IPU1-1]      0.672512 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM0 ####
[IPU1-1]      0.675593 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM1 ####
[IPU1-1]      0.678551 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM2 ####
[IPU1-1]      0.681540 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM3 ####
[IPU1-1]      0.684895 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM4 ####
[IPU1-1]      0.688464 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM5 ####
[IPU1-1]      0.691972 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM6 ####
[IPU1-1]      0.695632 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM7 ####
[IPU1-1]      0.695784 s:  SYSTEM: Initializing Links ... DONE !!!
[IPU1-1]      0.695845 s:  SYSTEM: System IPU1_1 Init Done !!!
[HOST  ]      0.550417 s:  ***** A15_0 Firmware build time 12:41:49 Apr 29 2021
[HOST  ]      0.550448 s:  *** SYSTEM: CPU Frequency <ORG = 588000000 Hz>, <NEW = 800000000 Hz>
[HOST  ]      0.551851 s:  SYSTEM: Notify register to [IPU1-0] line 0, event 15...
[HOST  ]      0.551881 s:  SYSTEM: Notify register to [IPU1-1] line 0, event 15...
[HOST  ]      0.551881 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST  ]      0.551942 s:  SYSTEM: System Common Init in progress !!!
[HOST  ]      0.551973 s:  SYSTEM: IPC init in progress !!!
[HOST  ]      0.551973 s:  SYSTEM: Notify init done !!!
[HOST  ]      0.552003 s:  SYSTEM: MsgQ init done !!!
[HOST  ]      0.552003 s:  SYSTEM: IPC init DONE !!!
[HOST  ]      0.552552 s:  SYSTEM: System Common Init Done !!!
[HOST  ]      0.552552 s:  SYSTEM: System A15 Init in progress !!!
[HOST  ]      0.552583 s:  UTILS: DMA: HWI Create for INT66 !!!
[HOST  ]      0.552613 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST  ]      0.552613 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 6291456 B (6144 KB), Free size = 6286416 B (6139 KB)
[HOST  ]      0.552644 s:  SYSTEM: Initializing Links !!!
[HOST  ]      0.554809 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC1 ####
[HOST  ]      0.554870 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC2 ####
[HOST  ]      0.554931 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC3 ####
[HOST  ]      0.554992 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM0 ####
[HOST  ]      0.555084 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM1 ####
[HOST  ]      0.555145 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM2 ####
[HOST  ]      0.555206 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM3 ####
[HOST  ]      0.555267 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM4 ####
[HOST  ]      0.555358 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM5 ####
[HOST  ]      0.555419 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM6 ####
[HOST  ]      0.555480 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM7 ####
[HOST  ]      0.555480 s:  SYSTEM: Initializing Links ... DONE !!!
[HOST  ]      0.555511 s:  SYSTEM: System A15 Init Done !!!
[DSP1  ]      0.552186 s:  SYSTEM: Notify register to [IPU1-0] line 0, event 15...
[DSP1  ]      0.552247 s:  SYSTEM: Notify register to [IPU1-1] line 0, event 15...
[DSP1  ]      0.552278 s:  SYSTEM: Notify register to [HOST] line 0, event 15...
[DSP1  ]      0.552400 s:  *** UTILS: CPU MHz = 20 Mhz ***
[DSP1  ]      0.552430 s:  SYSTEM: System Common Init in progress !!!
[DSP1  ]      0.552613 s:  UTILS: CIO: Init Done !!!
[DSP1  ]      0.552644 s:  SYSTEM: IPC init in progress !!!
[DSP1  ]      0.552644 s:  SYSTEM: Notify init done !!!
[DSP1  ]      0.552796 s:  SYSTEM: MsgQ init done !!!
[DSP1  ]      0.552796 s:  SYSTEM: IPC init DONE !!!
[DSP1  ]      0.553467 s:  SYSTEM: System Common Init Done !!!
[DSP1  ]      0.553498 s:  SYSTEM: System DSP Init in progress !!!
[DSP1  ]      0.553681 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[DSP1  ]      0.553711 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[DSP1  ]      0.553772 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 520400 B (508 KB)
[DSP1  ]      0.553803 s:  SYSTEM: Initializing Links !!!
[DSP1  ]      0.561367 s:  SYSTEM: Initializing Links ... DONE !!!
[DSP1  ]      0.561398 s:  SYSTEM: System DSP Init Done !!!
[DSP1  ]      0.788415 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
[DSP1  ]      0.788446 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
[IPU1-0]      1.815409 s:  QSPI Init Started
[IPU1-0]      1.815714 s:  MID - 1
[IPU1-0]      1.815775 s:  DID - 18
[IPU1-0]      1.815836 s:  QSPI Init Completed Sucessfully
[IPU1-0]      1.986671 s:  IPC_OUT_1   : Create in progress !!!
[IPU1-0]      1.987006 s:  IPC_OUT_1   : Create Done !!!
[IPU1-0]      1.992130 s:  IPC_IN_1   : Create in progress !!!
[IPU1-0]      1.993076 s:  IPC_IN_1   : Create Done !!!
[IPU1-0]      1.993259 s:  IPC_OUT_0   : Create in progress !!!
[IPU1-0]      1.993594 s:  IPC_OUT_0   : Create Done !!!
[IPU1-0]      1.995241 s:  IPC_IN_0   : Create in progress !!!
[IPU1-0]      1.996156 s:  IPC_IN_0   : Create Done !!!
[IPU1-0]      1.997010 s:  DISPLAY: Create in progress !!!
[IPU1-0]      1.997620 s:  DISPLAY: Create Done !!!
[IPU1-0]      2.658055 s:  DISPLAY: Create in progress !!!
[IPU1-0]      2.658543 s:  DISPLAY: Create Done !!!
[IPU1-0]      2.659702 s:  UTILS_MCSPI: McSPI is configured in interrupt mode!!
[IPU1-0]      2.663514 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
[IPU1-0]      2.663636 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254088 B (248 KB)
[IPU1-0]      2.663789 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[IPU1-0]      2.663941 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x85083000, Total size = 368037888 B (350 MB), Free size = 356978688 B (340 MB)
[IPU1-0]      2.664124 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xbfc00000, Total size = 129408 B (0 MB), Free size = 124800 B (0 MB)
[IPU1-0]      2.664307 s:  MCSPI: Communication Task Start...
[IPU1-0]      2.664582 s:  MCSPI: Communication Task Start...
[IPU1-0]      2.666687 s:  *** UTILS: CPU KHz = 20000 Khz ***
[IPU1-0]      2.767919 s:  DISPLAY: Start in progress !!!
[IPU1-0]      2.768010 s:  DISPLAY: Start Done !!!
[IPU1-0]      2.768681 s:  DISPLAY: Start in progress !!!
[IPU1-0]      2.768742 s:  DISPLAY: Start Done !!!
[IPU1-0]      2.769596 s:
[IPU1-0]
[IPU1-0]  ====================
[IPU1-0]  Chains Run-time Menu
[IPU1-0]
[IPU1-0]  0: Stop Chain
[IPU1-0]
[IPU1-0]  p: Print Performance Statistics
[IPU1-0]
[IPU1-0]  Enter Choice:
[IPU1-0]
[IPU1-1]      2.665100 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[IPU1-1]      2.665253 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 255912 B (249 KB)
[HOST  ]      1.993747 s:  IPC_IN_0   : Create in progress !!!
[HOST  ]      1.994052 s:  IPC_IN_0   : Create Done !!!
[HOST  ]      1.994113 s:  ALGORITHM: Create in progress (algId = 15) !!!
[HOST  ]      1.995028 s:  ALGORITHM: Create Done (algId = 15) !!!
[HOST  ]      1.995119 s:  IPC_OUT_0   : Create in progress !!!
[HOST  ]      1.995150 s:  IPC_OUT_0   : Create Done !!!
[HOST  ]      2.665649 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[HOST  ]      2.665680 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 6291456 B (6144 KB), Free size = 6264640 B (6117 KB)
[DSP1  ]      1.987189 s:  IPC_IN_0   : Create in progress !!!
[DSP1  ]      1.987616 s:  IPC_IN_0   : Create Done !!!
[DSP1  ]      1.987769 s:  ALGORITHM: Create in progress (algId = 44) !!!
[DSP1  ]      1.987860 s:  ALG_SlampDsp: DMA: Allocated CH (TCC) = 0 (0)
[DSP1  ]      1.991825 s:  ALGORITHM: Create Done (algId = 44) !!!
[DSP1  ]      1.991978 s:  IPC_OUT_0   : Create in progress !!!
[DSP1  ]      1.992039 s:  IPC_OUT_0   : Create Done !!!
[DSP1  ]      2.665893 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[DSP1  ]      2.665924 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[DSP1  ]      2.665954 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 505464 B (493 KB)
