We have designed a PCB by taking AM5728 EVM as reference.
When we initiate the Reboot Command, please let us know will the power cycle to the AM5728 gets reseted(i:e will the PMIC gets reseted).??
chandan
Hi Yordan ,
We have followed the AM5728 reference design and the reset outn pin is connected to the PMIC NRESWARM pin .
When the reboot command is executed the PMIC NRESWARM pin is getting low but the OFF2ACT Sequence is not affecting the change of power state for any of the SMPS & LDO 's(i:e the power rails of MPU,CORE,DDR,DSP etc will never be toggled or changed) .
In TPS659037 User's Guide to Power AM572x and AM571x" doc with the reference of Figure 12 it is stated that
"Figure 12 shows the warm reset sequence of TPS6590376ZWSR in the case that all resources are turned off. If any resource is on when NRESWARM is asserted, the resource remains on.
Since during the execution of reboot command all the SMPS & LDO are in ON condition ,and even after the OFF2ACT sequence is initiated the power states of the SMPS and LDO will remains unchanged as it is in its ON condition during the execution of REBOOT command .
So please let me know whether by any means i can reset the AM5728 core power rails once the reboot command is executed.
Thanks.
chandan
Hi ,
I request you to please reply for the above issue.
Also please let us know how can i initiate the cold reset for my core using software. We tried making SW_RST pin high using i2cset commands but it didnt work.Please let us know is any any dependencies for triggering the cold reset ?
chandan
