Other Parts Discussed in Thread: AM5728, DRA752, TPD12S015, PMP, TPIC2810
Tool/software: Linux
We are trying to boot a custom board using the AM5726. We started with the IDK Dev board configuration.
Linux starts to boot, but appears not to initialize the SD card correctly and therefore does not boot the root device.
Here is the boot output (I have also attached a txt output file as well). Do you have any recommendations to debug this? Thanks.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.40-g4796173fc5 (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #5 SMP PREEMPT Thu Mar 21 22:17:53 UTC 2019
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM5728 IDK
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x00000000fe400000
[ 0.000000] OMAP4: Map 0x00000000ffd00000 to fe600000 for dram barrier
[ 0.000000] DRA752 ES2.0
[ 0.000000] percpu: Embedded 15 pages/cpu @eed34000 s31372 r8192 d21876 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 472640
[ 0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=8df90da6-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1673568K/1897472K available (10240K kernel code, 356K rwdata, 2776K rodata, 2048K init, 313K bss, 35488K reserved, 188416K cma-reserved, 1283072K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0c00000 (12256 kB)
[ 0.000000] .init : 0xc1000000 - 0xc1200000 (2048 kB)
[ 0.000000] .data : 0xc1200000 - 0xc1259258 ( 357 kB)
[ 0.000000] .bss : 0xc125b000 - 0xc12a947c ( 314 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000016] Switching to timer-based delay loop, resolution 162ns
[ 0.000348] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000357] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000824] Console: colour dummy device 80x30
[ 0.000840] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[ 0.000847] This ensures that you still see kernel messages. Please
[ 0.000854] update your kernel commandline.
[ 0.000875] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000891] pid_max: default: 32768 minimum: 301
[ 0.001013] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001026] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001562] CPU: Testing write buffer coherency: ok
[ 0.001775] /cpus/cpu@0 missing clock-frequency property
[ 0.001793] /cpus/cpu@1 missing clock-frequency property
[ 0.001805] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.039869] Setting up static identity map for 0x80200000 - 0x80200060
[ 0.059877] Hierarchical SRCU implementation.
[ 0.080063] EFI services will not be available.
[ 0.099939] smp: Bringing up secondary CPUs ...
[ 0.170246] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.170339] smp: Brought up 1 node, 2 CPUs
[ 0.170353] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.170360] CPU: All CPU(s) started in HYP mode.
[ 0.170367] CPU: Virtualization extensions available.
[ 0.170876] devtmpfs: initialized
[ 0.188453] random: get_random_u32 called from bucket_table_alloc+0x108/0x230 with crng_init=0
[ 0.188708] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.188897] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.188913] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.192754] xor: measuring software checksum speed
[ 0.290177] arm4regs : 2011.600 MB/sec
[ 0.390246] 8regs : 1622.400 MB/sec
[ 0.490326] 32regs : 1538.000 MB/sec
[ 0.590405] neon : 2975.200 MB/sec
[ 0.590413] xor: using function: neon (2975.200 MB/sec)
[ 0.590426] pinctrl core: initialized pinctrl subsystem
[ 0.590873] DMI not present or invalid.
[ 0.591130] NET: Registered protocol family 16
[ 0.592163] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.593079] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.729565] omap_hwmod: gpu: _wait_target_ready failed: -16
[ 0.729578] omap_hwmod: gpu: cannot be enabled for reset (3)
[ 0.784600] cpuidle: using governor ladder
[ 0.784632] cpuidle: using governor menu
[ 0.792155] OMAP GPIO hardware version 0.1
[ 0.819426] No ATAGs?
[ 0.819498] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.819512] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.819879] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.819889] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.820402] OMAP DMA hardware revision 0.0
[ 0.991078] raid6: int32x1 gen() 224 MB/s
[ 1.161018] raid6: int32x1 xor() 260 MB/s
[ 1.331136] raid6: int32x2 gen() 334 MB/s
[ 1.501222] raid6: int32x2 xor() 331 MB/s
[ 1.671355] raid6: int32x4 gen() 425 MB/s
[ 1.841417] raid6: int32x4 xor() 348 MB/s
[ 2.011492] raid6: int32x8 gen() 465 MB/s
[ 2.181587] raid6: int32x8 xor() 323 MB/s
[ 2.351720] raid6: neonx1 gen() 932 MB/s
[ 2.521772] raid6: neonx1 xor() 1010 MB/s
[ 2.691912] raid6: neonx2 gen() 1312 MB/s
[ 2.861979] raid6: neonx2 xor() 1703 MB/s
[ 3.032085] raid6: neonx4 gen() 1923 MB/s
[ 3.202190] raid6: neonx4 xor() 1794 MB/s
[ 3.372282] raid6: neonx8 gen() 1715 MB/s
[ 3.542402] raid6: neonx8 xor() 1492 MB/s
[ 3.542410] raid6: using algorithm neonx4 gen() 1923 MB/s
[ 3.542417] raid6: .... xor() 1794 MB/s, rmw enabled
[ 3.542425] raid6: using neon recovery algorithm
[ 3.549541] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 3.550802] edma 43300000.edma: memcpy is disabled
[ 3.553950] edma 43300000.edma: TI EDMA DMA engine driver
[ 3.557032] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 3.557234] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 3.557470] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 3.557713] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 3.558059] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 3.558274] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 3.558497] iommu: Adding device 58820000.ipu to group 1
[ 3.558570] iommu: Adding device 55020000.ipu to group 2
[ 3.558705] iommu: Adding device 40800000.dsp to group 0
[ 3.558943] iommu: Adding device 41000000.dsp to group 3
[ 3.561128] palmas 0-0058: Irq flag is 0x00000004
[ 3.592039] palmas 0-0058: POLARITY_CTRL update failed: -121
[ 3.592492] palmas: probe of 0-0058 failed with error -121
[ 3.592702] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 3.592862] media: Linux media interface: v0.10
[ 3.592896] Linux video capture interface: v2.00
[ 3.592980] pps_core: LinuxPPS API ver. 1 registered
[ 3.592989] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 3.593007] PTP clock support registered
[ 3.593034] EDAC MC: Ver: 3.0.0
[ 3.593278] dmi: Firmware registration failed.
[ 3.593640] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 3.593916] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 3.594206] Advanced Linux Sound Architecture Driver Initialized.
[ 3.594904] clocksource: Switched to clocksource arch_sys_counter
[ 3.602503] NET: Registered protocol family 2
[ 3.603027] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 3.603091] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.603217] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.603284] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 3.603316] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 3.603439] NET: Registered protocol family 1
[ 3.613740] RPC: Registered named UNIX socket transport module.
[ 3.613749] RPC: Registered udp transport module.
[ 3.613757] RPC: Registered tcp transport module.
[ 3.613764] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.614617] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 3.614797] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 3.615796] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 3.619818] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.630318] NFS: Registering the id_resolver key type
[ 3.630346] Key type id_resolver registered
[ 3.630354] Key type id_legacy registered
[ 3.630392] ntfs: driver 2.1.32 [Flags: R/O].
[ 3.631823] bounce: pool size: 64 pages
[ 3.631865] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 3.631963] io scheduler noop registered
[ 3.631974] io scheduler deadline registered
[ 3.632125] io scheduler cfq registered (default)
[ 3.632135] io scheduler mq-deadline registered
[ 3.632144] io scheduler kyber registered
[ 3.636724] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 3.684106] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 3.686663] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 43, base_baud = 3000000) is a 8250
[ 4.691187] console [ttyS2] enabled
[ 4.696473] omap_rng 48090000.rng: Random Number Generator ver. 20
[ 4.704003] omapdss_dss 58000000.dss: master bind failed: -517
[ 4.710570] tpd12s015 encoder@0: failed to find video source
[ 4.716886] connector-hdmi connector@0: failed to find video source
[ 4.730918] brd: module loaded
[ 4.739496] loop: module loaded
[ 4.746219] m25p80 spi0.0: unrecognized JEDEC id bytes: 00, 00, 00
[ 4.753288] libphy: Fixed MDIO Bus: probed
[ 4.814935] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 4.822629] davinci_mdio 48485000.mdio: detected phy mask ffffffc1
[ 4.849737] libphy: 48485000.mdio: probed
[ 4.853770] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver unknown
[ 4.861834] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver unknown
[ 4.869895] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver unknown
[ 4.877961] davinci_mdio 48485000.mdio: phy[4]: device 48485000.mdio:04, driver unknown
[ 4.886022] davinci_mdio 48485000.mdio: phy[5]: device 48485000.mdio:05, driver unknown
[ 4.894724] cpsw 48484000.ethernet: Detected MACID = 44:ea:d8:19:1d:9e
[ 4.901364] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[ 4.907767] cpsw 48484000.ethernet: ALE Table size 1024
[ 4.913027] cpsw 48484000.ethernet: device node lookup for pps timer failed
[ 4.920076] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[ 4.927935] cpsw 48484000.ethernet: cpsw: Detected MACID = 44:ea:d8:19:1d:9f
[ 4.936096] i2c /dev entries driver
[ 4.940221] IR NEC protocol handler initialized
[ 4.944774] IR RC5(x/sz) protocol handler initialized
[ 4.949871] IR RC6 protocol handler initialized
[ 4.954423] IR JVC protocol handler initialized
[ 4.959146] IR Sony protocol handler initialized
[ 4.963784] IR SANYO protocol handler initialized
[ 4.968523] IR Sharp protocol handler initialized
[ 4.973248] IR MCE Keyboard/mouse protocol handler initialized
[ 4.979125] IR XMP protocol handler initialized
[ 4.987492] sdhci: Secure Digital Host Controller Interface driver
[ 4.993703] sdhci: Copyright(c) Pierre Ossman
[ 4.998561] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.026281] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 5.052199] sdhci-omap 4809c000.mmc: failed to set system capabilities
[ 5.101460] sdhci-omap 480b4000.mmc: failed to set system capabilities
[ 5.109390] ledtrig-cpu: registered to indicate activity on CPUs
[ 5.119111] NET: Registered protocol family 10
[ 5.124517] Segment Routing with IPv6
[ 5.128273] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 5.134645] NET: Registered protocol family 17
[ 5.139287] Key type dns_resolver registered
[ 5.143698] omap_voltage_late_init: Voltage driver support not added
[ 5.150104] Power Management for TI OMAP4+ devices.
[ 5.155263] Registering SWP/SWPB emulation handler
[ 5.161590] Btrfs loaded, crc32c=crc32c-generic
[ 5.177472] dmm 4e000000.dmm: workaround for errata i878 in use
[ 5.184979] dmm 4e000000.dmm: initialized all PAT entries
[ 5.191736] omapdss_dss 58000000.dss: master bind failed: -517
[ 5.197922] tpd12s015 encoder@0: failed to find video source
[ 5.203905] connector-hdmi connector@0: failed to find video source
[ 5.232144] sdhci-omap 4809c000.mmc: Got CD GPIO
[ 5.258076] sdhci-omap 4809c000.mmc: failed to set system capabilities
[ 5.317709] sdhci-omap 480b4000.mmc: failed to set system capabilities
[ 5.324737] hctosys: unable to open rtc device (rtc0)
[ 5.330480] pbias_mmc_omap5: disabling
[ 5.334254] ALSA device list:
[ 5.337254] No soundcards found.
[ 5.341393] Waiting for root device PARTUUID=8df90da6-02...
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.14.40-g4796173fc5 (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #5 SMP PREEMPT Thu Mar 21 22:17:53 UTC 2019 [ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [ 0.000000] OF: fdt: Machine model: TI AM5728 IDK [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB [ 0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool [ 0.000000] cma: Reserved 24 MiB at 0x00000000fe400000 [ 0.000000] OMAP4: Map 0x00000000ffd00000 to fe600000 for dram barrier [ 0.000000] DRA752 ES2.0 [ 0.000000] percpu: Embedded 15 pages/cpu @eed34000 s31372 r8192 d21876 u61440 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 472640 [ 0.000000] Kernel command line: console=ttyO2,115200n8 root=PARTUUID=8df90da6-02 rw rootfstype=ext4 rootwait [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 1673568K/1897472K available (10240K kernel code, 356K rwdata, 2776K rodata, 2048K init, 313K bss, 35488K reserved, 188416K cma-reserved, 1283072K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0c00000 (12256 kB) [ 0.000000] .init : 0xc1000000 - 0xc1200000 (2048 kB) [ 0.000000] .data : 0xc1200000 - 0xc1259258 ( 357 kB) [ 0.000000] .bss : 0xc125b000 - 0xc12a947c ( 314 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] OMAP clockevent source: timer1 at 32786 Hz [ 0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns [ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns [ 0.000016] Switching to timer-based delay loop, resolution 162ns [ 0.000348] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.000357] OMAP clocksource: 32k_counter at 32768 Hz [ 0.000824] Console: colour dummy device 80x30 [ 0.000840] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2' [ 0.000847] This ensures that you still see kernel messages. Please [ 0.000854] update your kernel commandline. [ 0.000875] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475) [ 0.000891] pid_max: default: 32768 minimum: 301 [ 0.001013] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001026] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001562] CPU: Testing write buffer coherency: ok [ 0.001775] /cpus/cpu@0 missing clock-frequency property [ 0.001793] /cpus/cpu@1 missing clock-frequency property [ 0.001805] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.039869] Setting up static identity map for 0x80200000 - 0x80200060 [ 0.059877] Hierarchical SRCU implementation. [ 0.080063] EFI services will not be available. [ 0.099939] smp: Bringing up secondary CPUs ... [ 0.170246] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.170339] smp: Brought up 1 node, 2 CPUs [ 0.170353] SMP: Total of 2 processors activated (24.59 BogoMIPS). [ 0.170360] CPU: All CPU(s) started in HYP mode. [ 0.170367] CPU: Virtualization extensions available. [ 0.170876] devtmpfs: initialized [ 0.188453] random: get_random_u32 called from bucket_table_alloc+0x108/0x230 with crng_init=0 [ 0.188708] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0 [ 0.188897] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.188913] futex hash table entries: 512 (order: 3, 32768 bytes) [ 0.192754] xor: measuring software checksum speed [ 0.290177] arm4regs : 2011.600 MB/sec [ 0.390246] 8regs : 1622.400 MB/sec [ 0.490326] 32regs : 1538.000 MB/sec [ 0.590405] neon : 2975.200 MB/sec [ 0.590413] xor: using function: neon (2975.200 MB/sec) [ 0.590426] pinctrl core: initialized pinctrl subsystem [ 0.590873] DMI not present or invalid. [ 0.591130] NET: Registered protocol family 16 [ 0.592163] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.593079] omap_hwmod: l3_main_2 using broken dt data from ocp [ 0.729565] omap_hwmod: gpu: _wait_target_ready failed: -16 [ 0.729578] omap_hwmod: gpu: cannot be enabled for reset (3) [ 0.784600] cpuidle: using governor ladder [ 0.784632] cpuidle: using governor menu [ 0.792155] OMAP GPIO hardware version 0.1 [ 0.819426] No ATAGs? [ 0.819498] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.819512] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.819879] omap4_sram_init:Unable to allocate sram needed to handle errata I688 [ 0.819889] omap4_sram_init:Unable to get sram pool needed to handle errata I688 [ 0.820402] OMAP DMA hardware revision 0.0 [ 0.991078] raid6: int32x1 gen() 224 MB/s [ 1.161018] raid6: int32x1 xor() 260 MB/s [ 1.331136] raid6: int32x2 gen() 334 MB/s [ 1.501222] raid6: int32x2 xor() 331 MB/s [ 1.671355] raid6: int32x4 gen() 425 MB/s [ 1.841417] raid6: int32x4 xor() 348 MB/s [ 2.011492] raid6: int32x8 gen() 465 MB/s [ 2.181587] raid6: int32x8 xor() 323 MB/s [ 2.351720] raid6: neonx1 gen() 932 MB/s [ 2.521772] raid6: neonx1 xor() 1010 MB/s [ 2.691912] raid6: neonx2 gen() 1312 MB/s [ 2.861979] raid6: neonx2 xor() 1703 MB/s [ 3.032085] raid6: neonx4 gen() 1923 MB/s [ 3.202190] raid6: neonx4 xor() 1794 MB/s [ 3.372282] raid6: neonx8 gen() 1715 MB/s [ 3.542402] raid6: neonx8 xor() 1492 MB/s [ 3.542410] raid6: using algorithm neonx4 gen() 1923 MB/s [ 3.542417] raid6: .... xor() 1794 MB/s, rmw enabled [ 3.542425] raid6: using neon recovery algorithm [ 3.549541] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported) [ 3.550802] edma 43300000.edma: memcpy is disabled [ 3.553950] edma 43300000.edma: TI EDMA DMA engine driver [ 3.557032] omap-iommu 40d01000.mmu: 40d01000.mmu registered [ 3.557234] omap-iommu 40d02000.mmu: 40d02000.mmu registered [ 3.557470] omap-iommu 58882000.mmu: 58882000.mmu registered [ 3.557713] omap-iommu 55082000.mmu: 55082000.mmu registered [ 3.558059] omap-iommu 41501000.mmu: 41501000.mmu registered [ 3.558274] omap-iommu 41502000.mmu: 41502000.mmu registered [ 3.558497] iommu: Adding device 58820000.ipu to group 1 [ 3.558570] iommu: Adding device 55020000.ipu to group 2 [ 3.558705] iommu: Adding device 40800000.dsp to group 0 [ 3.558943] iommu: Adding device 41000000.dsp to group 3 [ 3.561128] palmas 0-0058: Irq flag is 0x00000004 [ 3.592039] palmas 0-0058: POLARITY_CTRL update failed: -121 [ 3.592492] palmas: probe of 0-0058 failed with error -121 [ 3.592702] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz [ 3.592862] media: Linux media interface: v0.10 [ 3.592896] Linux video capture interface: v2.00 [ 3.592980] pps_core: LinuxPPS API ver. 1 registered [ 3.592989] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 3.593007] PTP clock support registered [ 3.593034] EDAC MC: Ver: 3.0.0 [ 3.593278] dmi: Firmware registration failed. [ 3.593640] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400 [ 3.593916] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400 [ 3.594206] Advanced Linux Sound Architecture Driver Initialized. [ 3.594904] clocksource: Switched to clocksource arch_sys_counter [ 3.602503] NET: Registered protocol family 2 [ 3.603027] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 3.603091] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 3.603217] TCP: Hash tables configured (established 8192 bind 8192) [ 3.603284] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 3.603316] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 3.603439] NET: Registered protocol family 1 [ 3.613740] RPC: Registered named UNIX socket transport module. [ 3.613749] RPC: Registered udp transport module. [ 3.613757] RPC: Registered tcp transport module. [ 3.613764] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 3.614617] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 3.614797] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available [ 3.615796] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 3.619818] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 3.630318] NFS: Registering the id_resolver key type [ 3.630346] Key type id_resolver registered [ 3.630354] Key type id_legacy registered [ 3.630392] ntfs: driver 2.1.32 [Flags: R/O]. [ 3.631823] bounce: pool size: 64 pages [ 3.631865] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 3.631963] io scheduler noop registered [ 3.631974] io scheduler deadline registered [ 3.632125] io scheduler cfq registered (default) [ 3.632135] io scheduler mq-deadline registered [ 3.632144] io scheduler kyber registered [ 3.636724] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128 [ 3.684106] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 3.686663] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 43, base_baud = 3000000) is a 8250 [ 4.691187] console [ttyS2] enabled [ 4.696473] omap_rng 48090000.rng: Random Number Generator ver. 20 [ 4.704003] omapdss_dss 58000000.dss: master bind failed: -517 [ 4.710570] tpd12s015 encoder@0: failed to find video source [ 4.716886] connector-hdmi connector@0: failed to find video source [ 4.730918] brd: module loaded [ 4.739496] loop: module loaded [ 4.746219] m25p80 spi0.0: unrecognized JEDEC id bytes: 00, 00, 00 [ 4.753288] libphy: Fixed MDIO Bus: probed [ 4.814935] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 4.822629] davinci_mdio 48485000.mdio: detected phy mask ffffffc1 [ 4.849737] libphy: 48485000.mdio: probed [ 4.853770] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver unknown [ 4.861834] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver unknown [ 4.869895] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver unknown [ 4.877961] davinci_mdio 48485000.mdio: phy[4]: device 48485000.mdio:04, driver unknown [ 4.886022] davinci_mdio 48485000.mdio: phy[5]: device 48485000.mdio:05, driver unknown [ 4.894724] cpsw 48484000.ethernet: Detected MACID = 44:ea:d8:19:1d:9e [ 4.901364] cpsw 48484000.ethernet: initialized cpsw ale version 1.4 [ 4.907767] cpsw 48484000.ethernet: ALE Table size 1024 [ 4.913027] cpsw 48484000.ethernet: device node lookup for pps timer failed [ 4.920076] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies) [ 4.927935] cpsw 48484000.ethernet: cpsw: Detected MACID = 44:ea:d8:19:1d:9f [ 4.936096] i2c /dev entries driver [ 4.940221] IR NEC protocol handler initialized [ 4.944774] IR RC5(x/sz) protocol handler initialized [ 4.949871] IR RC6 protocol handler initialized [ 4.954423] IR JVC protocol handler initialized [ 4.959146] IR Sony protocol handler initialized [ 4.963784] IR SANYO protocol handler initialized [ 4.968523] IR Sharp protocol handler initialized [ 4.973248] IR MCE Keyboard/mouse protocol handler initialized [ 4.979125] IR XMP protocol handler initialized [ 4.987492] sdhci: Secure Digital Host Controller Interface driver [ 4.993703] sdhci: Copyright(c) Pierre Ossman [ 4.998561] sdhci-pltfm: SDHCI platform and OF driver helper [ 5.026281] sdhci-omap 4809c000.mmc: Got CD GPIO [ 5.052199] sdhci-omap 4809c000.mmc: failed to set system capabilities [ 5.101460] sdhci-omap 480b4000.mmc: failed to set system capabilities [ 5.109390] ledtrig-cpu: registered to indicate activity on CPUs [ 5.119111] NET: Registered protocol family 10 [ 5.124517] Segment Routing with IPv6 [ 5.128273] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 5.134645] NET: Registered protocol family 17 [ 5.139287] Key type dns_resolver registered [ 5.143698] omap_voltage_late_init: Voltage driver support not added [ 5.150104] Power Management for TI OMAP4+ devices. [ 5.155263] Registering SWP/SWPB emulation handler [ 5.161590] Btrfs loaded, crc32c=crc32c-generic [ 5.177472] dmm 4e000000.dmm: workaround for errata i878 in use [ 5.184979] dmm 4e000000.dmm: initialized all PAT entries [ 5.191736] omapdss_dss 58000000.dss: master bind failed: -517 [ 5.197922] tpd12s015 encoder@0: failed to find video source [ 5.203905] connector-hdmi connector@0: failed to find video source [ 5.232144] sdhci-omap 4809c000.mmc: Got CD GPIO [ 5.258076] sdhci-omap 4809c000.mmc: failed to set system capabilities [ 5.317709] sdhci-omap 480b4000.mmc: failed to set system capabilities [ 5.324737] hctosys: unable to open rtc device (rtc0) [ 5.330480] pbias_mmc_omap5: disabling [ 5.334254] ALSA device list: [ 5.337254] No soundcards found. [ 5.341393] Waiting for root device PARTUUID=8df90da6-02...
