Other Parts Discussed in Thread: LMP91000
Hi Gordon,
I spoke to you early this year about this board and I was trying to use it to CV measurements using SPIO4 board and you suggested my board could be damaged and that is why it isnt working. You were right we got a new one recently and I am trying to use it and the software is working fine thankfully and it is recognizing all the boards, but I am not sure how to conduct the cyclic voltammetry experiments, because every measurement I make is more or less is the same regardless if the electrodes are connected or what the solution is, how can I know the settings of the software to make my experiment.
Also, every time I pick a sensor from the list in the software, I get a message saying I need to open 2-wire jumper although I did remove the jumper on the board. Is there something inside the program that I need to change?
Thank you.
Yomna
