We are seeing issues during cold temperature cycling. Failure Scenario 1: Three out of four proximity sensors had the thermal register and Rp register value drop to nothing at the same time. We have seen failures in both the far mode (no target present) and near mode (target present). Failures occurred between -10C and -35C, within the operating temperature range of the LMP91300NHZ. The failures did not occur every cold temperature cycle. Please see attachment. Failure Scenario 2: Three out of four proximity sensors had the output change state when in the near mode (target present) indicating the target temporarily was not present but it was. The Rp value did not change when the output changed state. Failures occurred between -30C and -35C, within the operating temperature range of the LMP91300NHZ. Please see attachment.
I am working with Paul Sparacino at Texas Instruments to get a NDA in place so that we can share schematic, board layout and coil design. Until then I am looking for input as to what maybe causing the failures. I appreciate your help. Thank you.What Gave TI.rar
