Hi everyone,
is there any detailes description on the LVDS-Protocol of the AWR1243 available?
It is not clear how the samples are transfered over the lanes when used in parallel. The programmer guide gives an introdution (section 2.1.2.1) about the transferred data and the order but there is nothing about the parallel lanes, how they are involved in which order.
Also I cannot find any information on how the synchronize the LVDS receiver on byte and words. Are there some test patterns send at the beginning of each transfer? Where are they defined?
Fabian
Hello Fabian,
Its not needed to tramsmit the sync pattern and its not possible to send it at the beginning also. LVDS Frame clock with bit clock will be enough for the data deserialization.
In TSW1400, the FPGA Hard macro-Deserializer deserializes the data and the Frame clock too. this would keep the data and Frame clock delays same. Frame clock transition from Low to high , marks the valid data capture start.
Let me know if you need more information.
regards
AK
