Other Parts Discussed in Thread: TMS320F28335
When I compared the library files with CG_XML , I got the results something like below.( For almost all the obj files)
Filename _lock.obj
Comparing Sections : section = $build.attributes
Raw data is different
Comparing Sections : section = $build.attributes : build_attributes : vendor_sec
tion : vendor_name = TI : attribute_section : attribute_list : tag = Tag_Produce
r_VPatch : arguments
Differences: C:\Release\rts_TMS320F28335_Flash.lib c:\updated_with
_5.1.3\rts_TMS320F28335_Flash.lib
const: 0x2 0x4
* Copyright Honeywell ASCa 2011. All Rights Reserved.
* This software and all information and expression are the property of
* Honeywell ASCa Inc., contain trade secrets and may not, in whole or in
* part, be licensed, used, duplicated, or disclosed for any purpose without
* prior written permission of Honeywell ASCa Inc. All Rights Reserved.
* File Name : Flash28_Prog.c
* CSCI Name : C Run Time Library for TMS320F28335 DSC
* CSU Name : Flash Program CSU
* SCI Number : 51352153
* Description:
* The C Run Time Library for TMS320F28335 CSU provides run time support
* functions for applications executing on TMS320F28335.
* This is the top level Flash programming function.
* Deviation from Coding Standard:
* Deviations: the deviation from the coding standard are for complexity,
* variable and function naming standards, source file name length and case,
* layout of the source files for different sections, explicit use of spaces,
* braces and parenthesis, pointer verification of null, divide by zero,
* Justification:
* The source files for the C RTL are obtained as COTS from TI as part of the
* Code Composer Studio compiler suite, C28x Floating Point fastRTS and from
* TMS320F28335 Flash APIs. No executable line of source code is modified in
* the source files. Hence these files do not follow the coding standards.
* Revision History:
* Version Author Date Description
* E-ID (DD/MM/YY)
* 1-3 E244183 06/09/2010 Initial Version.
* 4 E329175 08/04/2011 Modified as per Review ID 636
* 5 E329175 27/05/2011 Implemented as per
* SCR EPS00005384
* 6 E329175 23/06/2011 Implemented as per
* SCR EPS00005662
// TI File $Revision: /main/15 $
// Checkin $Date: December 4, 2007 16:03:51 $
// FILE: Flash28_Prog.c
// TITLE: F28x Program Algorithums
// NOTE:
//This is the top level FO5 programming function.
// $TI Release:$
// $Release Date:$
/***************************** HEADER FILES **********************************/
#include "Flash28_Internals.h"
#include <stdio.h>
/************************** PRE-PROCESSOR DIRECTIVES *************************/
/************************** IMPORTED DATA ELEMENTS ***************************/
// None
/************************ IMPORTED OPERATION DECLARATION *********************/
// None
/************************ LOCAL DATA TYPES (Enum/Struct/Union)****************/
// None
/************************ EXPORTED DATA ELEMENTS *****************************/
// None
/************************** LOCAL DATA ELEMENTS ******************************/
// None
/************************ LOCAL OPERATION DECLARATIONS ***********************/
// None
/************************ LOCAL OPERATION DEFINITIONS ************************/
// None
/********************** EXPORTED OPERATION DEFINITIONS ***********************/
// CRTL_SDD_02_05_004_Derived
* Description :
* Function Flash_Program programs a buffer into the Flash or OTP memory.
* Only bits that need to be programmed are touched, the rest are masked
* out and not touched.
* Arguments:
* Uint16 *StartAddr : Points to the first word to be programmed
* Uint16 *BufAddr : Points to the buffer with data to program
* Uint32 Length : Number of 16 bit words to program
* FPROG_STAT *FProgStat : Flash status structure
* Return Value:
* The function returns a status value.
* STATUS_SUCCESS Program was successful
* STATUS_FAIL_CSM_LOCKED CSM is locked, nothing to do
* STATUS_FAIL_PROGRAM Programing failed.
* STATUS_FAIL_ZERO_BIT_ERROR A bit is already 0 that should be 1
* Notes:
* If the address to be programmed lies within the OTP block, then the
* user or TI OTP section will be programmed. Which (TI or user) is
* controlled by a compile switch in Flash28_Internals.h.
* This switch should not be changed by customers as the TI half is for
* engineering data and not memory mapped.
* This function disables the watchdog
* This function assumes that the CSM is unlocked
// Program Block
// This function programs a buffer into the Flash or OTP memory
// Only bits that need to be programmed are, the rest are masked
// out and not touched.
// Parameters:
// Uint16 *StartAddr Points to the first word to be programmed
// Uint16 *BufAddr Points to the buffer with data to program
// Uint32 Length Number of 16 bit words to program
// FPROG_STAT *FProgStat Flash status structure
// Return Values:
// The function returns a status value.
// STATUS_SUCCESS Erase was successful
// STATUS_FAIL_CSM_LOCKED CSM is locked, nothing to do
// STATUS_FAIL_PROGRAM Programing failed.
// STATUS_FAIL_ZERO_BIT_ERROR A bit is already 0 that should be 1
// Notes:
// If the address to be programmed lies within the OTP block, then the
// user or TI OTP section will be programmed. Which (TI or user) is
// controlled by a compile switch in Flash28_Internals.h.
// This switch should not be changed by customers as the TI half is for
// engineering data and not memory mapped.
// This function disables the watchdog
// This function assumes that the CSM is unlocked
// The volatile is just for compatability with the original 281x API.
#if FL28_FLASH_YANTRA
Uint16 Flash_Program(
volatile Uint16 *StartAddr,
volatile Uint16 *BufAddr,
Uint32 Length,
FLASH_ST *FProgStat
#else
Uint16 *StartAddr,
Uint16 *BufAddr,
Uint32 Length,
FLASH_ST *FProgStat
#endif
Uint16 *EndAddr; // End address
Uint32 FAddr; // Address adjusted by the wrapper start address
Uint16 FDataout; // Data read out of the array by program verify
Uint16 FDatain; // Data to be programmed, properly masked
// according to what partial value is already programmed
Uint16 Status; // Status that will be returned to the caller
Uint16 Array; // Used to modify which control signals are toggled
// in particular this is used when programming the OTP
Uint32 CurrentLoc; // Current location relative to the first addr
Uint16 PulseCount; // Number of pulses
// Watchdog, check REVID (Y only), boot ROM location check,
// and make sure we can access the flash registers (no CSM blocking)
Status = Fl28x_Init(FProgStat);
if(Status != STATUS_SUCCESS)
return Status;
else Status = STATUS_BUSY;
EndAddr = (Uint16 *)StartAddr+Length-1;
// Check if the start and end addresses are within the Flash block
// If not, check if the start and end addresses are within the OTP block
// If not, return error
// Otherwise adjust the address for the flash wrapper
if(StartAddr >= FL28_FADDR_START && EndAddr <= FL28_FADDR_END)
FAddr = ((Uint32)StartAddr - (Uint32)FL28_FADDR_ADJUST);
Array = FL28_FLASH_ARRAY;
#if ((FL28_OTP_TI && (FL28_FLASH_YANTRA||FL28_FLASH_SHAKTI||FL28_FLASH_DD6)) || FL28_OTP_USR)
else if(StartAddr >= FL28_OTPADDR_START && EndAddr <= FL28_OTPADDR_END)
FAddr = ((Uint32)StartAddr - (Uint32)FL28_OTPADDR_ADJUST);
Array = FL28_OTP_ARRAY;
#elif (FL28_OTP_TI)
else if(StartAddr >= FL28_TIOTPADDR_START && EndAddr <= FL28_TIOTPADDR_END)
FAddr = ((Uint32)StartAddr - (Uint32)FL28_TIOTPADDR_ADJUST);
#endif
else return STATUS_FAIL_ADDR_INVALID;
Fl28x_EnterCmdMode(); // Enter the command mode for the flash
// Sector interleraving must be accounted for 280x devices.
#if FL28_INTERLEAVING
FL28_EALLOW;
*FL28_FSECTM = FL28_PROG_SECTMODE;
FL28_EDIS;
#endif
// For each word that needs to be programed:
// * Read the current value of the location via prog verify
// * Program only the bits that are not correct, mask out the
// ones that are correct
// * repeat until the value is programmed, or the maximum
// program pulses is reached.
for(CurrentLoc = 1; CurrentLoc <= Length; CurrentLoc++)
// Get the current value stored in the flash location
// ProgVerify will return 0's where the bits are programmed.
FDataout = Fl28x_ProgVerify(FAddr,FL28_FUSER_SPACE|Array);
for(PulseCount = 0; PulseCount < FL28_MAX_PROGRAM_PULSES; PulseCount++)
#if FL28_CALLBACK
if(NULL != Flash_CallbackPtr)
Flash_CallbackPtr();
#endif
#if !FL28_STOMP
// Make sure there are no bits already programmed that we want to be a 1.
// If so, then we are done
if( ( (FDataout ^ 0xFFFF) & *BufAddr ) != 0x0000)
Status = STATUS_FAIL_ZERO_BIT_ERROR;
break;
#endif // endif !FL28_STOMP
// If the word is already programmed then we are done.
if(FDataout == *BufAddr) break;
// Otherwise mask out the bits that are already programmed
// and attempt to program the rest
FDatain = (~FDataout | *BufAddr);
Fl28x_ProgPulse(FAddr,FDatain,FL28_FUSER_SPACE|Array);
// Check for failure
if(FDataout != *BufAddr)
// If Status is still busy then this was a prog error
// and not a zero bit error
if( Status == STATUS_BUSY) Status = STATUS_FAIL_PROGRAM;
FProgStat->ActualData = FDataout;
FProgStat->ExpectedData = *BufAddr;
if(Array == FL28_FLASH_ARRAY)
FProgStat->FirstFailAddr = FAddr + FL28_FADDR_ADJUST;
else
FProgStat->FirstFailAddr = FAddr + FL28_OTPADDR_ADJUST;
break;
// Move to the next flash location and buffer location
BufAddr++;
FAddr++;
Fl28x_LeaveCmdMode();
// If Status is still busy, then no error was flagged
if(Status == STATUS_BUSY) Status = STATUS_SUCCESS;
return Status;
/********************** ISR OPERATION DEFINITIONS ****************************/
// None
/************************** End of Flash28_Prog.c ****************************/
Just want to decipher , whats the trigger for the lib change.
When we compared through the hex difference , I got to know the difference is generated in the functionality Flash28_Prog.obj and I have attached the file for reference.
Jeba
