Installing on a virtual machine might be causing problems. Let me check into this.
David
Hi Massimo,
Please run the following commands in power shell and share the outpouts:
wmic bios get serialnumber
Get-WmiObject -Class Win32_Bios | Format-List -Property *
JC
Hi JC,
Attached is the Txt file with the results of the command you asked me for.
Massimo
Windows PowerShell Copyright (C) Microsoft Corporation. All rights reserved. Try the new cross-platform PowerShell https://aka.ms/pscore6 PS C:\Users\massimo> wmic bios get serialnumber SerialNumber PS C:\Users\massimo> Get-WmiObject -Class Win32_Bios | Format-List -Property * PSComputerName : VMSYNOWIN10 Status : OK Name : Intel IGD BDSM enabled at 0x%08x, size %lldMB, dev 00:02.0 Caption : Intel IGD BDSM enabled at 0x%08x, size %lldMB, dev 00:02.0 SMBIOSPresent : True __GENUS : 2 __CLASS : Win32_BIOS __SUPERCLASS : CIM_BIOSElement __DYNASTY : CIM_ManagedSystemElement __RELPATH : Win32_BIOS.Name="Intel IGD BDSM enabled at 0x%08x, size %lldMB, dev 00:02.0",SoftwareElementID="Intel IGD BDSM enabled at 0x%08x, size %lldMB, dev 00:02.0",SoftwareElementState=3,TargetOperatingSystem=0,Version="BOCHS - 1" __PROPERTY_COUNT : 31 __DERIVATION : {CIM_BIOSElement, CIM_SoftwareElement, CIM_LogicalElement, CIM_ManagedSystemElement} __SERVER : VMSYNOWIN10 __NAMESPACE : root\cimv2 __PATH : \\VMSYNOWIN10\root\cimv2:Win32_BIOS.Name="Intel IGD BDSM enabled at 0x%08x, size %lldMB, dev 00:02.0",SoftwareElementID="Intel IGD BDSM enabled at 0x%08x, size %lldMB, dev 00:02.0",SoftwareElementState=3,TargetOperatingSystem=0,Version="BOCHS - 1" BiosCharacteristics : {3, 42} BIOSVersion : {BOCHS - 1, Intel IGD BDSM enabled at 0x%08x, size %lldMB, dev 00:02.0} BuildNumber : CodeSet : CurrentLanguage : Description : Intel IGD BDSM enabled at 0x%08x, size %lldMB, dev 00:02.0 EmbeddedControllerMajorVersion : 255 EmbeddedControllerMinorVersion : 255 IdentificationCode : InstallableLanguages : InstallDate : LanguageEdition : ListOfLanguages : Manufacturer : SeaBIOS OtherTargetOS : PrimaryBIOS : True ReleaseDate : 20140401000000.000000+000 SerialNumber : SMBIOSBIOSVersion : Virtualization-2.5.1-11303-200428-0-gfff70e7 SMBIOSMajorVersion : 2 SMBIOSMinorVersion : 8 SoftwareElementID : Intel IGD BDSM enabled at 0x%08x, size %lldMB, dev 00:02.0 SoftwareElementState : 3 SystemBiosMajorVersion : 0 SystemBiosMinorVersion : 0 TargetOperatingSystem : 0 Version : BOCHS - 1 Scope : System.Management.ManagementScope Path : \\VMSYNOWIN10\root\cimv2:Win32_BIOS.Name="Intel IGD BDSM enabled at 0x%08x, size %lldMB, dev 00:02.0",SoftwareElementID="Intel IGD BDSM enabled at 0x%08x, size %lldMB, dev 00:02.0",SoftwareElementState=3,TargetOperatingSystem=0,Version="BOCHS - 1" Options : System.Management.ObjectGetOptions ClassPath : \\VMSYNOWIN10\root\cimv2:Win32_BIOS Properties : {BiosCharacteristics, BIOSVersion, BuildNumber, Caption...} SystemProperties : {__GENUS, __CLASS, __SUPERCLASS, __DYNASTY...} Qualifiers : {dynamic, Locale, provider, UUID} Site : Container :
Hi Massimo,
Thanks. I believe SerialNumber is required:
Please check your VM settings.
JC
