Hi All,
How to reduce the ripple content in TIDA-010015 based design .We have about 2V peak to peak voltage ripple at full load. What is the acceptable range of ripple in power supply.
Please advise here .
Hi All,
Hi Bala,
What is the frequency of the ripple? AC frequency or LLC switching frequency?
If for AC frequency:
1. Please check the PFC ripple is big or not. If yes, maybe you need to increase the PFC capacitance value; 2. If not, you could adjust the loop gain to increase the 概gain of the low frequency in the LLC stage;
If for LLC switching frequency:
You could increase the ceramic capacitor at the LLC output.
BR
Cheng
Hi Cheng,
We are measuring 100Hz ripple in the output only at 25A load under low input AC voltage .
Note: Other than US standard voltage the ripple content is only 800mV under UK standard.
We have 330uF Bulk Cap at the PFC side and required cap is about 300uF.
Please advise how to proceed here.
Hi Bala,
"We are measuring 100Hz ripple in the output only at 25A load under low input AC voltage . "
I am confused about this sentence.
Do you mean there is 100Hz ripple only under this test setup(25A load and 110VAC input)?
For other test condition, there is no 100Hz ripple issue, right?
BR
Cheng
Hi Bala,
It is unexpected.
Please send me the ripple waveform at 20A/25A/30A with low input voltage.
BR
Cheng
Hi Bala,
It is a good waveform.
Please share with me the waveform at the abnormal condition 25A load!
BR
Cheng
Hi Bala,
Here is my suggestion:
Try to power on the LLC stage with external 390VDC voltage, and then check if there is oscillation of output voltage?
If there is still oscillation, it verify that the LLC's feedback loop need to be adjusted; You can try to adjust R69 slowly and then check the performance.
If there is no oscillation, there maybe two possibilities:
1. The output oscillation is from PFC oscillation. You can power on the PFC stage separately, and check if there is oscillation of the PFC output voltage or not?
2. The output oscillation is from the combination of PFC and LLC. In this case, maybe you need to check this design layout.
If you have any question, please let me know.
BR
Cheng
