Part Number: TMS320C6678
Other Parts Discussed in Thread: CCSTUDIO
How to set Static and DHCP IP configuration using PDK in C667x and C665x family Processors ?
To run the NIMU EMAC example for C667x devices make sure the prerequisites are present.
Now Import the CCS project into CCS and go on
// IP Configuration
char *HostName = "tidsp";
char *LocalIPAddr = "192.168.1.4";
char *LocalIPMask = "255.255.255.0"; // Not used when using DHCP
char *GatewayIP = "192.168.1.1"; // Not used when using DHCP
char *DomainName = "demo.net"; // Not used when using DHCP
char *DNSServer = "0.0.0.0"; // Used when set to anything but zero
* Main thread
int StackTest()
if(1) // set '1' for manual IP configuration
// Manual IP configuration
CI_IPNET NA;
CI_ROUTE RT;
else
//DHCP configuration
}int StackTest()
if(0) // set '0' for DHCP IP configuration
CI_IPNET NA;
CI_ROUTE RT;
else
Thanks & Rgards,
Rajarajan U
