Part Number: TLC072
Other Parts Discussed in Thread: TLV9154, TLV9152, TLV9102
I use TLC072 to build a instrumental OP-Amp in capture CIS and do simulation in PSpice.
As I don't have this part model in my lib, so I download this spice model-sboc020a.zip from your website.
After I complete the transfer from spice to PSpice for this model, in can simulate in PSpice.
But, when I set the CM volt in my circuit as negative value (below 0Vdc, for instance is -2Vdc), the simulation result isn't symmetry with the positive value (for instance +2Vdc).
This result makes me confuse, so would you please help me to check if the part PSpice model is the c
TLC072-PSpiceModel-Check-with-TI.xlsxorrect without any problems?
Attachment files are the circuit I use and simulation result I got.
