We want help regarding a design where we have to amplify a DAC output to a large voltage level
We are getting a analog voltage output from a 12-bit DAC port of our micro-controller. The analog output voltage range is 0V to 1.8V. As per the 12-bit DAC, the minimum LSB voltage is 1.8/4096= 439uV and maximum voltage is 1.8V
Now we want to scale up or translate the DAC voltage range from (439uV --- 1.8V ) to (800uV----- 3.3V).
Since the DAC output voltages are in micro volts we are bit confused whether to use a general pupose or any instrumentation amplifier
Can you share any suitable application design which can perform above scaling up or translation of voltage range?
Vihang Waze
Senior Engineer
Tata Elxsi Limited, Pune, INDIA
