Other Parts Discussed in Thread: INA229
I use the INA229 to monitor the current in a battery powered system.
From time to time, the current reading becomes wrong, with different behaviours from one failure to the other (small gain difference, big one...) The actual current going through the circuit is still what I expect it to be.
I tracked the issue down to a corruption of the config register of the INA229. When the current reading becomes wrong, I check the values of the config registers, and they are different from what I programmed at startup.
Would you know any reason why this corruption would happen? And would you have a solution to overcome this issue?
Benoit
