Other Parts Discussed in Thread: XTR300,
I've been able to get a voltage output using a PWM using the Evaluation Module however, have not been able to get a current output. The voltage Also has not been perfectly accurate from the documentations provided by Texas Instruments here: http://www.ti.com/lit/ug/sbou034a/sbou034a.pdf
Is there any solution or helpful feed back to get a zero output from PWM set to a 0% duty cycle? as well as getting a current output from this chip/Evaluation Module using a PWM from a Raspberry PI?
