Hi E2E,
Good day!
Do we have the rise time and fall time information for LF442-MIL?
Franz
The TINA model will tell you in sim for your particular configuration - But at 1MHz GBP and 1V/usec slew rate, it will be the opposite of swift.
An intended schematic would help, also keep in mind a lot of transition times are actually set by slew limiting not rise time.
Hi Franz,
As discussed in the previous thread, it will depend on the circuit and conditions.
Primarily, you need to ask whether the amplifier will be used in its small-signal response region (more normal operation) or in slew rate.
Here is a great resource for the subject. Let me know if you need further help.
Daniel
Hi All,
Thank you for your response.
Will check on this.
Franz
Hi Franz,
Since we haven't heard back from you in a while, I'm going to mark this issue as resolved. If you feel like you need more help, you can come back and give some follow up.
Daniel
Hi Daniel,
Sorry if the late update. You may now close this post. I am now communicating your recommendations to my customer.
Thank you for your support.
Franz
