When reading table 7.6 of the LMX2492-Q1 datasheet, the following question arises:
What is the frequency range that I can use on pin fOSCin if the signal is single ended?
I think that there is no problem in using the following range 100MHz to 200MHz (single ended), but I would like to read your opinions, since the datasheet could be interpreted in another way.
Best Regards
