Part Number: DP83822H
We use the Ethernet PHY DP83822H in one application and use the 10BASE-Te configuration. Customer wants to use 10BASE-T now. As it looks, the device cannot be reconfigured to the higher levels. Is there a pin-compatible PHY that can drop into the same layout without changing anything?
Thanks a lot!
Frank
