TUSB2046B: not working
Part Number: TUSB2046B
Other Parts Discussed in Thread: TPS2044
Hi Team,
Whenever there is no devices connected to down PORT2 of hub through USB connector (irrespective of USB keyboard or mouse), devices connected to down port 3 and port 4 is not working. However, as soon as device is connected to port 2,  devices connected to port 3 and port 4 started working.
Please find below schematic for reference , can you please check and comment.
Regards, Shinu.
  • Hi Shinu:
      Here are issues I found form schemaiic:
    1:  pin 26 EXTMEM should be directly pulllup to 3.3v.
    2:  there are two 1.5k pullup to 3.3v on DP0, only one is needed.
    3: No 1.5k pullup needed on DP1.
    4: There is no 5v for downstream port 4.
    5:  what status on pin6 GANG mode?
    Regarsd
    Brian
  • Hi Brian,
    Thanks for the inputs. Customer done the correction and below are the feedback.
    1. Pin26  EXTEMEM pin I pulled up through 4.7K ohm, I already made R368 #4.7K DNP.
    2. Additional 1.5K on DP0 removed
    3. DP1 pullup 1.5K removed
    4. Pin 6# ganged pin is grounded, I’ve made R366 # 33 ohm DNP.
    5. There is no 5v for downstream port 4. ?
    What does it exactly? Is it HUB port4 or TPS2044 pin 10? As I’m using only 3 down stream port for USB device and one port is for FT230 IC which is running on board 3.3V supply.
    I implemented but result is same. Now whenever I removed keyboard  port 2 device, COM port is also get disconnected
    (I don’t see any com port on device manager, once I connect keyboard back to port 2 then again COM port gets detected)
    What could be other issue?
    Regards, Shinu.
  • Maybe that keyboard has issue, did you try other keyboards on port 2 ?  or try that special keyboard on port 3?
    Do you have USB analyer to take the USB trace?
    Brian
  • Thanks Brian,
    I will check with customer.
    Thanks.
  • ok, Pls keep me update.
    Regadrs
    Brian
