Other Parts Discussed in Thread: TCAN1043, , TCAN1043A-Q1
Hi team,
1. What is the internal architecture of nFault pin? it is open drain or push pull? didnt find it in datasheet
not sure if below description means it is push pull output, pull up to VIO?
2. when TCAN1043 power pin (VCC VIO VSUP ) all in normal range, and Wake pin connect to GND, under which condition nFault pin will pull low?
even enter sleep mode, but VCC VIO are within normal supply range, nfault should not be pull low, right?
Scarlett
