Hello
I have recently tested the SN74LVC1G123 part to confirm the retriggering time as mentioned in the datasheet,
For 300mHz to 100Mhz with Rext=325K and Cext=10uF , LED was glowing continuously with output around 3V (with 250mVpp ripples at the higher frequencies).
So i believe retriggering happening all in the range of 3.33s to 10ns pulse period.
But datasheet says, the minimum retriggering requirements, for example if we take 0.01uF as Cext then for 3.3V the minimum retriggering time should be 1us or above?
If so may i know how the retriggering is happening for above test circuit for such a wide range of frequencies, am i missing anything here?
Note: Sorry for the explanation without pictures, I cant share the screen shot of results due to company policies
