My customer reported an issue related EMIF wait feature in asynchronous access.
Customer is doing memory access stress test and it worked fine more than 12 hours in room temp. (25~30C).
Then temperature is increased step by step and the test failed at 70C in 10~20 min.
After the test failed once, it failed again immediately after power cycle.
Please see attached excel sheet.
Left waveform is failing case at 70C. Right waveform is normal case at RT.
EMIF wait issue.xlsx
It seems EMIF configuration and timing meet requirements.
Why it is failing at 70C? Any points should be checked?
Thanks and regards,
Koichiro Tashiro
