Other Parts Discussed in Thread: HALCOGEN
I want to enable parity bit (whatever odd or even) for SCI module, I was using generated code from HalCoGen on LAUNCHXL-TMS570LC43
Using SCI1 and SCI3, SCI1 output via XDSv110, and SCI3 output via USB-bridge.
Both of them can only be received correctly via parity none option: picocom -b 1500000 -y n -d 8 -p 1 /dev/ttyACM0
with picocom -y e or picocom -y o will receive garbage results
Following is the sciInit generated from HalCoGen
void sciInit(void) { /* USER CODE BEGIN (2) */ /* USER CODE END */ /** @b initialize @b SCI1 */ /** - bring SCI1 out of reset */ sciREG1->GCR0 = 0U; sciREG1->GCR0 = 1U; /** - Disable all interrupts */ sciREG1->CLEARINT = 0xFFFFFFFFU; sciREG1->CLEARINTLVL = 0xFFFFFFFFU; /** - global control 1 */ sciREG1->GCR1 = (uint32)((uint32)1U << 25U) /* enable transmit */ | (uint32)((uint32)1U << 24U) /* enable receive */ | (uint32)((uint32)1U << 5U) /* internal clock (device has no clock pin) */ | (uint32)((uint32)(1U-1U) << 4U) /* number of stop bits */ | (uint32)((uint32)1U << 3U) /* even parity, otherwise odd */ | (uint32)((uint32)1U << 2U) /* enable parity */ | (uint32)((uint32)1U << 1U); /* asynchronous timing mode */ /** - set baudrate */ sciREG1->BRS = 2U; /* baudrate */ /** - transmission length */ sciREG1->FORMAT = 8U - 1U; /* length */ /** - set SCI1 pins functional mode */ sciREG1->PIO0 = (uint32)((uint32)1U << 2U) /* tx pin */ | (uint32)((uint32)1U << 1U); /* rx pin */ /** - set SCI1 pins default output value */ sciREG1->PIO3 = (uint32)((uint32)0U << 2U) /* tx pin */ | (uint32)((uint32)0U << 1U); /* rx pin */ /** - set SCI1 pins output direction */ sciREG1->PIO1 = (uint32)((uint32)0U << 2U) /* tx pin */ | (uint32)((uint32)0U << 1U); /* rx pin */ /** - set SCI1 pins open drain enable */ sciREG1->PIO6 = (uint32)((uint32)0U << 2U) /* tx pin */ | (uint32)((uint32)0U << 1U); /* rx pin */ /** - set SCI1 pins pullup/pulldown enable */ sciREG1->PIO7 = (uint32)((uint32)0U << 2U) /* tx pin */ | (uint32)((uint32)0U << 1U); /* rx pin */ /** - set SCI1 pins pullup/pulldown select */ sciREG1->PIO8 = (uint32)((uint32)1U << 2U) /* tx pin */ | (uint32)((uint32)1U << 1U); /* rx pin */ /** - set interrupt level */ sciREG1->SETINTLVL = (uint32)((uint32)0U << 26U) /* Framing error */ | (uint32)((uint32)0U << 25U) /* Overrun error */ | (uint32)((uint32)0U << 24U) /* Parity error */ | (uint32)((uint32)0U << 9U) /* Receive */ | (uint32)((uint32)0U << 8U) /* Transmit */ | (uint32)((uint32)0U << 1U) /* Wakeup */ | (uint32)((uint32)0U << 0U); /* Break detect */ /** - set interrupt enable */ sciREG1->SETINT = (uint32)((uint32)0U << 26U) /* Framing error */ | (uint32)((uint32)0U << 25U) /* Overrun error */ | (uint32)((uint32)0U << 24U) /* Parity error */ | (uint32)((uint32)0U << 9U) /* Receive */ | (uint32)((uint32)0U << 1U) /* Wakeup */ | (uint32)((uint32)0U << 0U); /* Break detect */ /** - initialize global transfer variables */ g_sciTransfer_t[0U].mode = (uint32)0U << 8U; g_sciTransfer_t[0U].tx_length = 0U; g_sciTransfer_t[0U].rx_length = 0U; /** - Finaly start SCI1 */ sciREG1->GCR1 |= 0x80U; /** @b initialize @b SCI3 */ /** - bring SCI3 out of reset */ sciREG3->GCR0 = 0U; sciREG3->GCR0 = 1U; /** - Disable all interrupts */ sciREG3->CLEARINT = 0xFFFFFFFFU; sciREG3->CLEARINTLVL = 0xFFFFFFFFU; /** - global control 1 */ sciREG3->GCR1 = (uint32)((uint32)1U << 25U) /* enable transmit */ | (uint32)((uint32)1U << 24U) /* enable receive */ | (uint32)((uint32)1U << 5U) /* internal clock (device has no clock pin) */ | (uint32)((uint32)(1U-1U) << 4U) /* number of stop bits */ | (uint32)((uint32)1U << 3U) /* even parity, otherwise odd */ | (uint32)((uint32)1U << 2U) /* enable parity */ | (uint32)((uint32)1U << 1U); /* asynchronous timing mode */ /** - set baudrate */ sciREG3->BRS = 2U; /* baudrate */ /** - transmission length */ sciREG3->FORMAT = 8U - 1U; /* length */ /** - set SCI3 pins functional mode */ sciREG3->PIO0 = (uint32)((uint32)1U << 2U) /* tx pin */ | (uint32)((uint32)1U << 1U); /* rx pin */ /** - set SCI3 pins default output value */ sciREG3->PIO3 = (uint32)((uint32)0U << 2U) /* tx pin */ | (uint32)((uint32)0U << 1U); /* rx pin */ /** - set SCI3 pins output direction */ sciREG3->PIO1 = (uint32)((uint32)0U << 2U) /* tx pin */ | (uint32)((uint32)0U << 1U); /* rx pin */ /** - set SCI3 pins open drain enable */ sciREG3->PIO6 = (uint32)((uint32)0U << 2U) /* tx pin */ | (uint32)((uint32)0U << 1U); /* rx pin */ /** - set SCI3 pins pullup/pulldown enable */ sciREG3->PIO7 = (uint32)((uint32)0U << 2U) /* tx pin */ | (uint32)((uint32)0U << 1U); /* rx pin */ /** - set SCI3 pins pullup/pulldown select */ sciREG3->PIO8 = (uint32)((uint32)1U << 2U) /* tx pin */ | (uint32)((uint32)1U << 1U); /* rx pin */ /** - set interrupt level */ sciREG3->SETINTLVL = (uint32)((uint32)0U << 26U) /* Framing error */ | (uint32)((uint32)0U << 25U) /* Overrun error */ | (uint32)((uint32)0U << 24U) /* Parity error */ | (uint32)((uint32)0U << 9U) /* Receive */ | (uint32)((uint32)0U << 8U) /* Transmit */ | (uint32)((uint32)0U << 1U) /* Wakeup */ | (uint32)((uint32)0U << 0U); /* Break detect */ /** - set interrupt enable */ sciREG3->SETINT = (uint32)((uint32)1U << 26U) /* Framing error */ | (uint32)((uint32)1U << 25U) /* Overrun error */ | (uint32)((uint32)1U << 24U) /* Parity error */ | (uint32)((uint32)0U << 9U) /* Receive */ | (uint32)((uint32)1U << 1U) /* Wakeup */ | (uint32)((uint32)1U << 0U); /* Break detect */ /** - initialize global transfer variables */ g_sciTransfer_t[2U].mode = (uint32)0U << 8U; g_sciTransfer_t[2U].tx_length = 0U; g_sciTransfer_t[2U].rx_length = 0U; /** - Finaly start SCI3 */ sciREG3->GCR1 |= 0x80U; /* USER CODE BEGIN (3) */ // sciREG3->SETINT |= (uint32)(((uint32)1U << 16U) | ((uint32)1U << 8U)); /* SET TX DMA / SET TX INT*/ /* USER CODE END */ }
